03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS6812 & S6813 SeriesConfigure & DeployConfiguration GuidesH3C S6812 & S6813 Switch Series Configuration Guide-R6615Pxx-6W10103-Layer 2—LAN Switching Configuration Guide
01-Ethernet interface configuration
01-Ethernet interface configuration 321.04 KB
Configuring Ethernet interfaces· 1
About Ethernet interface· 1
Configuring a management Ethernet interface· 1
Ethernet interface naming conventions· 1
Restrictions and guidelines: Ethernet interface configuration· 2
Configuring common Ethernet interface settings· 2
Configuring the physical type for a combo interface (single combo interface) 3
Splitting a 40-GE interface and combining 10-GE breakout interfaces· 3
Splitting a 100-GE interface and combining 25-GE breakout interfaces· 4
Configuring basic settings of an Ethernet interface· 5
Configuring basic settings of an Ethernet subinterface· 6
Configuring the link mode of an Ethernet interface· 6
Configuring jumbo frame support 7
Configuring physical state change suppression on an Ethernet interface· 7
Configuring dampening on an Ethernet interface· 8
Configuring storm suppression· 9
Configuring generic flow control on an Ethernet interface· 10
Configuring PFC· 11
Configuring PFC deadlock detection· 13
Configuring the early warning thresholds for PFC packets· 14
Setting the statistics polling interval 15
Enabling loopback testing on an Ethernet interface· 15
Forcibly bringing up a fiber port 16
Configuring interface alarm functions· 17
Shutting down all physical interfaces· 19
Restoring the default settings for an interface· 19
Configuring a Layer 2 Ethernet interface· 20
Setting the MDIX mode of an Ethernet interface· 20
Configuring storm control on an Ethernet interface· 21
Testing the cable connection of an Ethernet interface· 22
Enabling bridging on an Ethernet interface· 22
Configuring a Layer 3 Ethernet interface or subinterface· 23
Setting the MTU for an Ethernet interface or subinterface· 23
Display and maintenance commands for Ethernet interfaces· 23
The Switch Series supports Ethernet interfaces, management Ethernet interfaces, Console interfaces, and USB interfaces. For the interface types and the number of interfaces supported by a switch model, see the installation guide.
This chapter describes how to configure management Ethernet interfaces and Ethernet interfaces.
A management interface uses an RJ-45 connector. You can connect the interface to a PC for software loading and system debugging, or connect it to a remote NMS for remote system management.
2.     Enter management Ethernet interface view.
interface M-GigabitEthernet interface-number
3.     (Optional.) Set the interface description.
The default setting is M-GigabitEthernet0/0/0 Interface.
4.     (Optional.) Set the duplex mode for the management Ethernet interface.
duplex { auto | full | half }
By default, the duplex mode is auto for a management Ethernet interface.
5.     (Optional.)_Set the speed for the management Ethernet interface.
speed { 10 | 100 | 1000 | auto }
By default, the speed is auto for a management Ethernet interface.
6.     (Optional.) Shut down the interface.
shutdown
By default, the management Ethernet interface is up.
CAUTION
CAUTION:
Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution.
The Ethernet interfaces are named in the format of interface type A/B/C. The letters that follow the interface type represent the following elements:
·     A—IRF member ID. If the switch is not in an IRF fabric, A is 1 by default.
·     B—Card slot number. 0 indicates the interface is a fixed interface of the switch.
·     C—Port index.
A 10-GE breakout interface split from a 40-GE interface is named in the format of interface type A/B/C:D. A/B/C is the interface number of the 40-GE interface. D is the number of the 10-GE interface, which is in the range of 1 to 4. For information about splitting a 40-GE interface into 10-GE breakout interfaces, see "Splitting a 40-GE interface and combining 10-GE breakout interfaces."
A 25-GE breakout interface split from a 100-GE interface is named in the format of interface type A/B/C:D. A/B/C is the interface number of the 100-GE interface. D is the number of the 25-GE interface, which is in the range of 1 to 4. For information about splitting a 100-GE interface into 25-GE breakout interfaces, see "Splitting a 100-GE interface and combining 25-GE breakout interfaces."
When you configure the Ethernet interface speed, follow these restrictions and guidelines:
·     For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface. Support of copper ports for keywords of this command varies by copper port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a copper port, the copper port supports this speed. Otherwise, the copper port does not support this speed.
·     For a fiber port, use the speed command to set its speed to match the rate of a transceiver module. Support of fiber ports for keywords of this command varies by fiber port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a fiber port, the fiber port supports this speed. Otherwise, the fiber port does not support this speed. Additionally, you must select a speed for a fiber port according to the transceiver module installed to ensure that the transceiver module can be used properly. If the transceiver module installed in a fiber port does not support the speed for the fiber port, the transceiver module cannot be used. For example, the transceiver module cannot be used in either of the following conditions:.
¡     The transceiver module installed in an SFP+ fiber port is an SFP GE transceiver module and the speed 10000 command is executed on the fiber port.
¡     The transceiver module installed in an SFP+ fiber port is a 10-GE transceiver module and the speed 1000 command is executed on the fiber port.
The Ethernet interface configuration restrictions might be updated because more switch models and compatible interface card models will be added. For exact information, see the installation guide or hardware description for the product.
This section describes the settings common to Layer 2 Ethernet interfaces, Layer 3 Ethernet interfaces, and Layer 3 Ethernet subinterfaces. For more information about the settings specific to Layer 2 Ethernet interfaces, see "Configuring a Layer 2 Ethernet interface." For more information about the settings specific to Layer 3 Ethernet interfaces or subinterfaces, see "Configuring a Layer 3 Ethernet interface or subinterface."
A combo interface is a logical interface that physically comprises one fiber combo port and one copper combo port. The two ports share one forwarding channel and one interface view. As a result, they cannot work simultaneously. When you activate one port, the other port is automatically disabled. If you execute the combo enable auto command on a combo interface, the interface automatically identifies the media inserted and activates the corresponding combo port. In the interface view, you can activate the fiber or copper combo port, and configure other port attributes such as the interface rate and duplex mode.
Before you configure combo interfaces, complete the following tasks:
·     Determine the combo interfaces on your device. Identify the two physical interfaces that belong to each combo interface according to the marks on the device panel.
·     Use the display interface command to determine which port (fiber or copper) of each combo interface is active:
¡     If the copper port is active, the output includes "Media type is twisted pair."
¡     If the fiber port is active, the output does not include this information.
2.     Enter Ethernet interface view.
3.     Activate the copper combo port or fiber combo port.
combo enable { auto | copper | fiber }
The default is auto.
You can use a 40-GE interface as a single interface. To improve port density, reduce costs, and improve network flexibility, you can also split a 40-GE interface into four 10-GE breakout interfaces. The 10-GE breakout interfaces support the same configuration and attributes as common 10-GE interfaces, except that they are numbered differently.
For example, you can split 40-GE interface FortyGigE 1/0/1 into four 10-GE breakout interfaces Ten-GigabitEthernet 1/0/1:1 through Ten-GigabitEthernet 1/0/1:4.
If you need higher bandwidth on a single interface, you can combine the four 10-GE breakout interfaces into a 40-GE interface.
Restrictions and guidelines for 40-GE interface splitting and 10-GE breakout interface combining
·     A 40-GE interface split into four 10-GE breakout interfaces must use a dedicated 1-to-4 cable. After you combine the four 10-GE breakout interfaces, replace the dedicated 1-to-4 cable with a dedicated 1-to-1 cable or a 40-GE transceiver module. For more information about the cable or transceiver module, see the installation guides.
·     Device reboot is not required for this feature to take effect. To view information about the breakout or combined interfaces, execute the display interface brief command. The 10-GE breakout interfaces cannot act as IRF physical interfaces.
Splitting a 40-GE interface into four 10-GE breakout interfaces
2.     Enter 40-GE interface view.
interface fortygige interface-number
3.     Split the 40-GE interface into four 10-GE breakout interfaces.
using tengige
By default, a 40-GE interface is not split and operates as a single interface.
Combining four 10-GE breakout interfaces into a 40-GE interface
2.     Enter the view of any 10-GE breakout interface.
interface ten-gigabitethernet interface-number
3.     Combine the four 10-GE breakout interfaces into a 40-GE interface.
using fortygige
By default, a 10-GE breakout interface operates as a single interface.
You can use a 100-GE interface as a single interface. To improve port density, reduce costs, and improve network flexibility, you can also split a 100-GE interface into four 25-GE breakout interfaces. The 25-GE breakout interfaces support the same configuration and attributes as common 25-GE interfaces, except that they are numbered differently.
For example, you can split 100-GE interface HundredGigE 1/0/1 into four 25-GE breakout interfaces Twenty-FiveGigE 1/0/1:1 through Twenty-FiveGigE 1/0/1:4.
If you need higher bandwidth on a single interface, you can combine the four 25-GE breakout interfaces into a 100-GE interface.
Restrictions and guidelines for 100-GE interface splitting and 25-GE breakout interface combining
·     A 100-GE interface split into four 25-GE breakout interfaces must use a dedicated 1-to-4 cable. After you combine the four 25-GE breakout interfaces, replace the dedicated 1-to-4 cable with a dedicated 1-to-1 cable or a 100-GE transceiver module. For more information about the cable or transceiver module, see the installation guides.
·     This feature is available only on devices that support 100-GE interfaces.
·     Device reboot is not required for this feature to take effect. To view information about the breakout or combined interfaces, execute the display interface brief command. The 25-GE breakout interfaces cannot act as IRF physical interfaces.
Splitting a 100-GE interface into four 25-GE breakout interfaces
2.     Enter 100-GE interface view.
interface hundredgige interface-number
3.     Split the 100-GE interface into four 25-GE breakout interfaces.
using twenty-fivegige
By default, a 100-GE interface is not split and operates as a single interface.
Combining four 25-GE breakout interfaces into a 100-GE interface
2.     Enter the view of any 25-GE breakout interface.
interface twenty-fivegige interface-number
3.     Combine the four 25-GE breakout interfaces into a 100-GE interface.
using hundredgige
By default, a 25-GE breakout interface operates as a single interface.
You can configure an Ethernet interface to operate in one of the following duplex modes:
·     Full-duplex mode—The interface can send and receive packets simultaneously.
·     Autonegotiation mode—The interface negotiates a duplex mode with its peer.
You can set the speed of an Ethernet interface or enable it to automatically negotiate a speed with its peer.
The shutdown and port up-mode commands are mutually exclusive.
The shutdown command cannot be configured on an Ethernet interface in a loopback test.
3.     Set the description for the Ethernet interface.
The default setting is interface-name Interface. For example, Ten-GigabitEthernet1/0/1 Interface.
4.     Set the duplex mode for the Ethernet interface.
duplex { auto | full }
By default, the duplex mode is auto for Ethernet interfaces.
5.     Set the speed for the Ethernet interface.
speed { 10 | 100 | 1000 | 10000 | 25000 | 40000 | 100000 | auto }
By default, an Ethernet interface negotiates a speed with its peer.
6.     Set the expected bandwidth for the Ethernet interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
7.     Bring up the Ethernet interface.
By default, Ethernet interfaces are in up state.
By default, a Layer 3 Ethernet subinterface processes packets for only the VLAN whose ID is the same as the subinterface number.
Restrictions and guidelines for Ethernet subinterface basic settings
·     The shutdown, port up-mode, and loopback commands are mutually exclusive.
·     The shutdown command cannot be configured on an Ethernet interface in a loopback test.
2.     Create an Ethernet subinterface.
interface interface-type interface-number.subnumber
3.     Set the description for the Ethernet subinterface.
The default setting is interface-name Interface. For example, Ten-GigabitEthernet1/0/1.1 Interface.
4.     Set the expected bandwidth for the Ethernet subinterface.
5.     Bring up the Ethernet subinterface.
By default, Ethernet subinterfaces are in up state.
Interfaces on the device can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can use commands to set the link mode to bridge or route.
3.     Configure the link mode of the Ethernet interface.
By default, all Ethernet interfaces on the device operate in bridge mode.
CAUTION
CAUTION:
After you change the link mode of an Ethernet interface, all commands (except the description, duplex, jumboframe enable, speed, shutdown, and combo enable commands) on the Ethernet interface are restored to their defaults in the new link mode.
Jumbo frames are frames larger than 1536 bytes and are typically received by an Ethernet interface during high-throughput data exchanges, such as file transfers.
The Ethernet interface processes jumbo frames in the following ways:
·     When the Ethernet interface is configured to deny jumbo frames (by using the undo jumboframe enable command), the Ethernet interface discards jumbo frames.
·     When the Ethernet interface is configured with jumbo frame support, the Ethernet interface performs the following operations:
¡     Processes jumbo frames within the specified length.
¡     Discards jumbo frames that exceed the specified length.
3.     Configure jumbo frame support.
jumboframe enable [ size ]
By default, the device allows jumbo frames within 10000 bytes to pass through.
If you set the size argument multiple times, the most recent configuration takes effect.
The physical link state of an Ethernet interface is either up or down. Each time the physical link of an interface comes up or goes down, the interface immediately reports the change to the CPU. The CPU then performs the following operations:
·     Notifies the upper-layer protocol modules (such as routing and forwarding modules) of the change for guiding packet forwarding.
·     Automatically generates traps and logs to inform users to take the correct actions.
To prevent frequent physical link flapping from affecting system performance, configure physical state change suppression. You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event to the CPU.
Do not enable this feature on an interface that has RRPP, spanning tree protocols, or Smart Link enabled.
You can configure different suppression intervals for link-up and link-down events.
If you execute the link-delay command multiple times on an interface, the following rules apply:
·     You can configure the suppression intervals for link-up and link-down events separately.
·     If you configure the suppression interval multiple times for link-up or link-down events, the most recent configuration takes effect.
The link-delay and dampening commands are mutually exclusive on an Ethernet interface.
3.     Configure physical state change suppression.
By default, each time the physical link of an interface goes up or comes down, the interface immediately reports the change to the CPU.
The interface dampening feature uses an exponential decay mechanism to prevent excessive interface flapping events from adversely affecting routing protocols and routing tables in the network. Suppressing interface state change events protects the system resources.
If an interface is not dampened, its state changes are reported. For each state change, the system also generates an SNMP trap and log message.
After a flapping interface is dampened, it does not report its state changes to the CPU. For state change events, the interface only generates SNMP trap and log messages.
·     Penalty—The interface has an initial penalty of 0. When the interface flaps, the penalty increases by 1000 for each down event until the ceiling is reached. It does not increase for up events. When the interface stops flapping, the penalty decreases by half each time the half-life timer expires until the penalty drops to the reuse threshold.
·     Ceiling—The penalty stops increasing when it reaches the ceiling.
·     Suppress-limit—The accumulated penalty that triggers the device to dampen the interface. In dampened state, the interface does not report its state changes to the CPU. For state change events, the interface only generates SNMP traps and log messages.
·     Reuse-limit—When the accumulated penalty decreases to this reuse threshold, the interface is not dampened. Interface state changes are reported to the upper layers. For each state change, the system also generates an SNMP trap and log message.
·     Decay—The amount of time (in seconds) after which a penalty is decreased.
·     Max-suppress-time—The maximum amount of time the interface can be dampened. If the penalty is still higher than the reuse threshold when this timer expires, the penalty stops increasing for down events. The penalty starts to decrease until it drops below the reuse threshold.
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2(Max-suppress-time/Decay)  × reuse-limit. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
Figure 1 shows the change rule of the penalty value. The lines t0 and t2 indicate the start time and end time of the suppression, respectively. The period from t0 to t2 indicates the suppression period, t0 to t1 indicates the max-suppress-time, and t1 to t2 indicates the complete decay period.
Figure 1 Change rule of the penalty value
·     The dampening and link-delay commands are mutually exclusive on an interface.
·     The dampening command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the upper-layer protocols.
·     Do not enable the dampening feature on an interface with RRPP, MSTP, or Smart Link enabled.
3.     Enable dampening on the interface.
By default, interface dampening is disabled on Ethernet interfaces.
The storm suppression feature ensures that the size of a particular type of traffic (broadcast, multicast, or unknown unicast traffic) does not exceed the threshold on an interface. When the broadcast, multicast, or unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the traffic drops below this threshold.
Both storm suppression and storm control can suppress storms on an interface. Storm suppression uses the chip to suppress traffic. Storm suppression has less impact on the device performance than storm control, which uses software to suppress traffic.
·     For the traffic suppression result to be determined, do not configure storm control together with storm suppression for the same type of traffic. For more information about storm control, see "Configuring storm control on an Ethernet interface."
·     When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
¡     If the configured value is smaller than 64, the value of 64 takes effect.
¡     If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
For the suppression threshold that takes effect, see the prompt on the device.
3.     Enable broadcast suppression and set the broadcast suppression threshold.
By default, broadcast suppression is disabled.
4.     Enable multicast suppression and set the multicast suppression threshold.
By default, multicast suppression is disabled.
5.     Enable unknown unicast suppression and set the unknown unicast suppression threshold.
By default, unknown unicast suppression is disabled.
To avoid dropping packets on a link, you can enable generic flow control at both ends of the link. When traffic congestion occurs at the receiving end, the receiving end sends a flow control (Pause) frame to ask the sending end to suspend sending packets. Generic flow control includes the following types:
·     TxRx-mode generic flow control—Enabled by using the flow-control command. With TxRx-mode generic flow control enabled, an interface can both send and receive flow control frames:
¡     When congestion occurs, the interface sends a flow control frame to its peer.
¡     When the interface receives a flow control frame from its peer, it suspends sending packets to its peer.
·     Rx-mode generic flow control—Enabled by using the flow-control receive enable command. With Rx-mode generic flow control enabled, an interface can receive flow control frames, but it cannot send flow control frames:
¡     When congestion occurs, the interface cannot send flow control frames to its peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end and the flow-control command at the other end. To enable both ends of a link to handle traffic congestion, configure the flow-control command at both ends.
3.     Enable generic flow control.
¡     Enable TxRx-mode generic flow control.
flow-control
¡     Enable Rx-mode generic flow control.
By default, generic flow control is disabled on an Ethernet interface.
Configuring PFC
When congestion occurs in the network, the local device notifies the peer to stop sending packets carrying the specified 802.1p priority if all of the following conditions exist:
·     Both the local end and the remote end have priority-based flow control (PFC) enabled.
·     Both the local end and the remote end have the priority-flow-control no-drop dot1p command configured.
·     The specified 802.1p priority is in the 802.1p priority list specified by the dot1p-list argument.
·     The local end receives a packet carrying the specified 802.1p priority.
The state of the PFC feature is determined by the PFC configuration on the local end and on the peer end. In Table 1:
·     The first row lists the PFC configuration on the local interface.
·     The first column lists the PFC configuration on the peer.
·     The Enabled and Disabled fields in other cells are possible negotiation results.
Make sure all interfaces that a data flow passes through have the same PFC configuration.
Table 1 PFC configurations and negotiation results
Local (right)
Peer (below)
enable
auto
enable
Enabled
Enabled.
Disabled
auto
Enabled
·     Enabled if negotiation succeeds.
·     Disabled if negotiation fails.
Disabled
Disabled
Disabled.
Disabled
·     You can configure PFC in both system view and Ethernet interface view. If you configure PFC in system view and Ethernet interface view multiple times, the most recent configuration takes effect.
·     For IRF and other protocols to operate correctly, as a best practice, do not enable PFC for 802.1p priorities 0, 6, and 7.
·     To perform PFC on an IRF port, configure PFC on the IRF port and the IRF physical interfaces that are bound to the IRF port. For information about IRF, see Virtual Technologies Configuration Guide.
·     To perform PFC in an overlay network, execute the qos trust tunnel-dot1p command. For information about the overlay network, see VXLAN Configuration Guide. For information about the qos trust tunnel-dot1p command, see ACL and QoS Command Reference.
·     To avoid packet loss, apply the same PFC configuration to all interfaces that the packets pass through.
·     If you do not enable PFC on an interface, the interface can receive but cannot process PFC pause frames. To make PFC take effect, you must enable PFC on both ends.
·     If you configure the flow control or flow-control receive enable command on a PFC-enabled interface, the following rules apply:
¡     The PFC configuration takes effect.
¡     The configuration of the flow control or flow-control receive enable command is ignored.
¡     The flow control or flow-control receive enable command takes effect on the interface only when PFC is disabled on it.
Configuring PFC in system view
2.     Enable PFC on all Ethernet interfaces.
priority-flow-control { auto | enable }
By default, PFC is disabled on all Ethernet interfaces.
3.     Enable PFC for 802.1p priorities on all Ethernet interfaces.
priority-flow-control no-drop dot1p dot1p-list
By default, PFC is disabled for all 802.1p priorities on all Ethernet interfaces.
Configuring PFC in Ethernet interface view
3.     Enable PFC on the Ethernet interface.
By default, PFC is disabled on an Ethernet interface.
4.     Enable PFC for 802.1p priorities.
By default, PFC is disabled for all 802.1p priorities.
When packets carrying the specified 802.1p priority are transmitted in a loop, packets in the data buffer cannot be forwarded and PFC frames are repeatedly transmitted between devices. As a result, the cell resources in the buffer for device interfaces always cannot be released. In this case, the device enters the PFC deadlock state.
This feature periodically detects whether the device is in the PFC deadlock state. If an interface is always in the PFC XOFF state within the PFC deadlock detection interval, the device enters the PFC deadlock state. If PFC deadlock detection is recovered in automatic mode, the device automatically releases the deadlock state and recovers PFC and PFC deadlock detection after the delay timer expires. During the delay timer period, the device disables PFC and PFC deadlock detection on the interface, so that packets can be forwarded properly.
After the PFC deadlock state is released, the PFC deadlock detection feature can be recovered on the interface in automatic or manual mode. Recovering this feature enables the PFC feature again at the same time. Use the automatic recovery mode when no serious failures occur.
When a packet loop cannot be eliminated and the device enters PFC deadlock state frequently, manually recover PFC deadlock detection on the interface as follows:
1.     Perform troubleshooting and set the manual recovery mode for PFC deadlock detection.
2.     Execute the priority-flow-control deadlock recover command to recover the PFC deadlock detection and PFC features.
The specified CoS value must be within the 802.1p priority list specified by using the priority-flow-control no-drop dot1p command. To view the 802.1p priority for each CoS value, execute the display qos map-table dot1p-lp command.
Before you configure PFC deadlock detection on an Ethernet interface, complete the following tasks:
·     Enable PFC in auto mode or forcibly on the Ethernet interface.
·     Enable PFC for 802.1p priorities on the Ethernet interface.
2.     Set the precision for the PFC deadlock detection timer.
priority-flow-control deadlock precision { high | normal | low }
By default, the PFC deadlock detection timer uses normal precision.
3.     Set the PFC deadlock detection interval for the specified CoS value.
priority-flow-control deadlock cos cos-value interval interval [ pause-recover ]
By default, the PFC deadlock detection interval is not set.
4.     Configure the delay timer for PFC deadlock detection automatic recovery.
priority-flow-control deadlock auto-recover cos cos-value delay delay-interval
By default, the delay timer for PFC deadlock detection automatic recovery is not configured.
5.     Configure the action to take on packets during the delay timer period for PFC deadlock automatic recovery.
priority-flow-control deadlock auto-recover action { discard | forwarding }
By default, the device forwards received data packets during the delay timer period for PFC deadlock detection automatic recovery.
6.     Configure the upper threshold for PFC deadlock times during the specified period.
priority-flow-control deadlock threshold cos cos-value period period count count
By default, the upper threshold for PFC deadlock times during the specified period is not configured.
7.     Enter Ethernet interface view.
8.     Set the recovery mode for PFC deadlock detection on the Ethernet interface.
priority-flow-control deadlock recover-mode { auto | manual }
By default, PFC deadlock detection recovers in automatic mode.
9.     Enable PFC deadlock detection on the Ethernet interface.
priority-flow-control deadlock enable
By default, PFC deadlock detection is disabled.
10.      (Optional.) Recover PFC deadlock detection on the Ethernet interface.
You can use only this command to recover PFC deadlock detection if you set the manual recovery mode for PFC deadlock detection on the Ethernet interface.
You can configure the early warning threshold for incoming or outgoing PFC packets of an interface as needed. The early warning threshold notifies a situation where the PFC packet transmission rate is still within a normal range but needs attention.
When the rate of PFC packets that an interface sends or receives reaches the early warning threshold, the system generates traps and logs to notify the user. According to the traps and logs, the user can discover some exceptions in the network, for example:
·     The NIC of the peer device fails and continuously sends PFC packets at a high speed. In this case, you can set the early warning threshold for incoming PFC packets.
·     The device fails and continuously sends PFC frames. In this case, you can set the early warning threshold for outgoing PFC packets.
To monitor bidirectional PFC packets, you can set the early warning thresholds for incoming packets and outgoing packets separately.
The number of PFC pause frames that an interface sends or receives is counted and the early warning threshold configuration takes effect only when PFC is enabled.
3.     Configure the early warning threshold for incoming PFC packets.
priority-flow-control early-warning dot1p dot1p-list inpps pps-value
By default, no early warning threshold is configured for incoming PFC packets.
4.     Configure the early warning threshold for outgoing PFC packets.
priority-flow-control early-warning dot1p dot1p-list outpps pps-value
By default, no early warning threshold is configured for outgoing PFC packets.
To display the interface statistics collected in the last statistics polling interval, use the display interface command. To clear the interface statistics, use the reset counters interface command.
Setting the statistics polling interval in Ethernet interface view
3.     Set the statistics polling interval for the Ethernet interface.
flow-interval interval
By default, the statistics polling interval is 300 seconds.
Perform this task to determine whether an Ethernet link works correctly.
Loopback testing includes the following types:
·     Internal loopback testing—Tests the device where the Ethernet interface resides. The Ethernet interface sends outgoing packets back to the local device. If the device fails to receive the packets, the device fails.
·     External loopback testing—Tests the inter-device link. The Ethernet interface sends incoming packets back to the remote device. If the remote device fails to receive the packets, the inter-device link fails.
·     After you enable this feature on an Ethernet interface, the interface does not forward data traffic.
·     You cannot perform a loopback test on the following Ethernet interfaces:
¡     Ethernet interfaces manually brought down (displayed as in ADM or Administratively DOWN state).
¡     Ethernet interfaces configured with the port up-mode command.
·     The speed, duplex, and shutdown commands cannot be configured on an Ethernet interface in a loopback test.
·     After you enable this feature on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable this feature, the Ethernet interface restores to its duplex setting.
3.     Enable loopback testing.
loopback{ external | internal }
As shown in Figure 2, a fiber port uses separate fibers for transmitting and receiving packets. The physical state of the fiber port is up only when both transmit and receive fibers are physically connected. If one of the fibers is disconnected, the fiber port does not work.
To enable a fiber port to forward traffic over a single link, you can use the port up-mode command. This command forcibly brings up a fiber port, even when no fiber links or transceiver modules are present for the fiber port. When one fiber link is present and up, the fiber port can forward packets over the link unidirectionally.
Figure 2 Forcibly bring up a fiber port
·     Copper ports do not support this feature.
·     The port up-mode and shutdown commands are mutually exclusive.
·     A fiber port does not support this feature if the port is shut down by a protocol or by using the shutdown command.
·     A fiber port does not support this feature if the port joins an aggregation group.
·     A fiber port forcibly brought up stays physically up whether or not a transceiver module or a fiber link is present for the port.
3.     Forcibly bring up the fiber port.
port up-mode
By default, a fiber port is not forcibly brought up, and the physical state of a fiber port depends on the physical state of the fibers.
With the interface alarm functions enabled, when the number of error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the interface alarm parameters in system view and interface view.
·     The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface.
·     For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
An interface that is shut down because of error packet alarms cannot automatically recover. To bring up the interface, execute the undo shutdown command on the interface.
Enabling interface alarm functions
2.     Enable alarm functions for the interface monitoring module.
snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause ] *
By default, all alarm functions are enabled for interfaces.
Configuring CRC error packet parameters
2.     Configure global CRC error packet alarm parameters.
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for CRC error packets.
3.     Enter Ethernet interface view.
4.     Configure CRC error packet alarm parameters for the interface.
By default, an interface uses the global CRC error packet alarm parameters.
Configuring input error packet alarm parameters
2.     Configure global input error packet alarm parameters.
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for input error packets.
4.     Configure input error packet alarm parameters for the interface.
By default, an interface uses the global input error packet alarm parameters.
Configuring output error packet alarm parameters
2.     Configure global output error packet alarm parameters.
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for output error packets.
4.     Configure output error packet alarm parameters.
By default, an interface uses the global output error packet alarm parameters.
Configuring received pause frame alarm parameters
2.     Configure global received pause frame alarm parameters.
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
By default, the upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for received pause frames.
4.     Configure received pause frame alarm parameters.
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
By default, an interface uses the global received pause frame alarm parameters.
Configuring sent pause frame alarm parameters
2.     Configure global sent pause frame alarm parameters.
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
By default, the upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for sent pause frames.
4.     Configure sent pause frame alarm parameters.
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval
By default, an interface uses the global sent pause frame alarm parameters.
This feature allows you to shut down all physical interfaces except the management Ethernet interfaces on a device. Physical interfaces shut down by using this command are in ADM state. To bring one of these interfaces, execute the shutdown command on the interface.
If you configure this feature in system view and execute the shutdown command in interface view multiple times, the most recent configuration takes effect.
2.     Shut down all physical interfaces.
shutdown all-physical-interfaces
By default, physical interfaces are up.
CAUTION
CAUTION:
This feature might interrupt ongoing network services. Make sure you are fully aware of the impacts of this feature when you use it in a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
2.     Enter Ethernet interface view or Ethernet subinterface view.
3.     Restore the default settings for the interface.
default
IMPORTANT
IMPORTANT:
Fiber ports do not support the MDIX mode setting.
A physical Ethernet interface has eight pins, each of which plays a dedicated role. For example, pins 1 and 2 transmit signals, and pins 3 and 6 receive signals. You can use both crossover and straight-through Ethernet cables to connect copper Ethernet interfaces. To accommodate these types of cables, a copper Ethernet interface can operate in one of the following Medium Dependent Interface-Crossover (MDIX) modes:
·     MDIX mode—Pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
·     MDI mode—Pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
·     AutoMDIX mode—The interface negotiates pin roles with its peer.
This feature does not take effect on pins 4, 5, 7, and 8 of physical Ethernet interfaces.
·     Pins 4, 5, 7, and 8 of interfaces operating at 10 Mbps or 100 Mbps do not receive or transmit signals.
·     Pins 4, 5, 7, and 8 of interfaces operating at 1000 Mbps or higher rates receive and transmit signals.
To enable a copper Ethernet interface to communicate with its peer, set the MDIX mode of the interface by following these guidelines:
·     Typically, set the MDIX mode of the interface to AutoMDIX. Set the MDIX mode of the interface to MDI or MDIX only when the device cannot determine the cable type.
·     When a straight-through cable is used, configure the interface to operate in an MDIX mode different than its peer.
·     When a crossover cable is used, perform one of the following tasks:
¡     Configure the interface to operate in the same MDIX mode as its peer.
¡     Configure either end to operate in AutoMDIX mode.
3.     Set the MDIX mode of the Ethernet interface.
mdix-mode { automdix | mdi | mdix }
By default, a copper Ethernet interface operates in auto mode to negotiate pin roles with its peer.
Storm control compares broadcast, multicast and unknown unicast traffic regularly with their respective traffic thresholds on an Ethernet interface. For each type of traffic, storm control provides a lower threshold and an upper threshold.
Depending on your configuration, when a particular type of traffic exceeds its upper threshold, the interface performs either of the following operations:
·     Blocks this type of traffic and forwards other types of traffic—Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the interface begins to forward the traffic.
·     Goes down automatically—The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not automatically come up. To bring up the interface, use the undo shutdown command or disable the storm control feature.
You can configure an Ethernet interface to output threshold event traps and log messages when monitored traffic meets one of the following conditions:
·     Exceeds the upper threshold.
·     Drops below the lower threshold.
Both storm suppression and storm control can suppress storms on an interface. Storm suppression uses the chip to suppress traffic. Storm suppression has less impact on the device performance than storm control, which uses software to suppress traffic. For more information about storm suppression, see "Configuring storm suppression."
Storm control uses a complete polling cycle to collect traffic data, and analyzes the data in the next cycle. An interface takes one to two polling intervals to take a storm control action.
2.     (Optional.) Set the statistics polling interval of the storm control module.
storm-constrain interval interval
The default setting is 10 seconds.
For network stability, use the default or set a longer statistics polling interval.
4.     Enable storm control, and set the lower and upper thresholds for broadcast, multicast, or unknown unicast traffic.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
By default, storm control is disabled.
5.     Set the control action to take when monitored traffic exceeds the upper threshold.
6.     Enable the Ethernet interface to output log messages when it detects storm control threshold events.
storm-constrain enable log
By default, the Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
7.     Enable the Ethernet interface to send storm control threshold event traps.
storm-constrain enable trap
By default, the Ethernet interface sends traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from the upper threshold from a value above the upper threshold.
IMPORTANT
IMPORTANT:
If the link of an Ethernet interface is up, testing its cable connection will cause the link to go down and then come up.
This feature tests the cable connection of an Ethernet interface and displays cable test result within 5 seconds. The test result includes the cable's status and some physical parameters. If any fault is detected, the test result shows the length from the local port to the faulty point.
Fiber ports do not support this feature.
3.     Perform a test for the cable connected to the Ethernet interface.
virtual-cable-test
By default, the device drops packets whose outgoing interface and incoming interface are the same.
To enable the device to forward such packets rather than drop them, enable the bridging feature in Ethernet interface view.
3.     Enable bridging on the Ethernet interface.
port bridge enable
By default, bridging is disabled on an Ethernet interface.
The maximum transmission unit (MTU) of an Ethernet interface affects the fragmentation and reassembly of IP packets on the interface. Typically, you do not need to modify the MTU of an interface.
2.     Enter interface view.
3.     Set the MTU for the interface.
mtu size
The default setting is 1500 bytes.
For more information about the display diagnostic-information command, see device management in Fundamentals Command Reference.
Display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
Display traffic rate statistics of interfaces in up state over the last statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
Display the operating information for the IFMGR module.
display diagnostic-information ifmgr [ key-info ] [ filename ]
Display the Ethernet module statistics.
display ethernet statistics slot slot-number
Display the operational and status information of the specified interfaces.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
Display the status and packet statistics of interfaces.
display interface link-info [ main ]
Display the operational and status information of interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
Display PFC information on the specified interfaces.
display priority-flow-control interface [ interface-type [ interface-number ] ]
Display information about storm control on the specified interfaces.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
Clear interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Clear the Ethernet module statistics.
reset ethernet statistics [ slot slot-number ]
