08-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10108-Layer 3—IP Routing Command Reference
08-Policy-based routing commands
08-Policy-based routing commands 208.70 KB
Certain router models do not support SRv6 TE policies because they do not support the segment routing feature. For more information about SRv6 TE policies, see Segment Routing Command Reference.
apply access-vpn
Use apply access-vpn to specify the forwarding tables that can be used for the matching packets.
Use undo apply access-vpn to remove the specified forwarding tables.
apply access-vpn { public | vpn-instance vpn-instance-name&<1-4> }
undo apply access-vpn { public | vpn-instance [ vpn-instance-name&<1-4> ] }
The device forwards matching packets by using the forwarding table for the network from which the packets are received.
Policy node view
public: Specifies the forwarding table for the public network.
vpn-instance: Specifies the forwarding table for the specified MPLS L3VPN instances.
vpn-instance-name&<1-4>: Specifies a space-separated list of up to n VPN instance names. A VPN instance name is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist. The value for n is 4.
Use this command only in special scenarios that require sending packets received from one network to another network, for example, from a VPN to the public network, or from one VPN to another VPN.
You can repeat this command to specify the forwarding tables for the public network and VPN instances. The device forwards the matching packets by using the first available forwarding table selected in the order in which they are specified.
If you specify the vpn-instance keyword without specifying any VPN instances when you execute the undo form of this command, all the VPN instances are removed from the policy node.
After all the forwarding tables on the policy node are removed, the default forwarding behavior restores.
# Specify the VPN 1 and VPN 2 forwarding tables on node 10. In this example, VPN 1 and VPN 2 already exist.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10] apply access-vpn vpn-instance vpn1 vpn2
# Specify the public network forwarding table on node 10.
[Sysname-pbr-policy1-10] apply access-vpn public
apply remark-vpn
apply continue
Use apply continue to compare packets with the next policy node upon failure on the current node.
Use undo apply continue to restore the default.
apply continue
undo apply continue
PBR does not compare packets with the next policy node upon failure on the current node.
Policy node view
This command takes effect only when the match mode of the node is permit.
This command applies when either of the following conditions exist:
·     None of the following clauses is configured for packet forwarding:
¡     apply access-vpn
¡     apply next-hop
¡     apply output-interface
¡     apply default-next-hop
¡     apply default-output-interface
·     A clause listed above is configured, but it has become invalid. Then, a routing table lookup also fails for the matching packet.
A clause might become invalid because the specified next hop is unreachable, packets cannot be forwarded in the specified VPN instance, or the specified output interface is down.
# Compare with the next policy node upon failure on the current node.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply continue
apply default-gateway
Use apply default-gateway to set the default next hop addresses for matching packets to the specified gateway addresses.
Use undo apply default-gateway to remove the configuration.
apply default-gateway { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply default-gateway [ { interface-type interface-number }&<1-4> ]
The default next hop addresses for matching packets are not set to gateway addresses.
Policy node view
interface-type interface-number: Specifies an interface to obtain the gateway address. The interface-type interface-number argument represents the interface type and interface number.
track track-entry-number: Specifies a track entry by its number in the range 1 to 1024.
&<1-4>: Indicates that the argument before it can be entered up to four times.
After you execute this command, PBR uses the specified interfaces to obtain gateway addresses to be used as the default next hop addresses for matching packets. Upon a change of a gateway address, the device automatically changes the associated default next hop address. If the specified interface fails to obtain a gateway address or the obtained gateway address is invalid, the command does not take effect.
You can specify multiple interfaces in one command line or by executing this command multiple times to obtain gateway addresses to be used as default next hop addresses for backup. PBR selects the first available default next hop address according to configuration order to forward matching packets.
With an interface specified, the undo form of the command removes the default next hop address (gateway address) obtained by the interface.
Without any interfaces specified, the undo form of the command removes all default next hop addresses obtained from gateway addresses.
# Set the default next hop address for matching packets to the gateway address obtained by interface GigabitEthernet 1/0/1.
[Sysname-pbr-aa-11] apply default-gateway gigabitethernet 1/0/1
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] }&<1-4>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name | inbound-vpn ] ip-address&<1-4> ]
No default next hops are set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
inbound-vpn: Specifies the VPN instance where the inbound interface belongs.
ip-address: Specifies the IP address of a default next hop. If you do not specify the vpn-instance vpn-instance-name option or the inbound-vpn keyword, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-4>: Indicates that you can specify up to four default next hops, each of which can be associated with a track entry.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
apply loadshare
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply default-output-interface [ { interface-type interface-number }&<1-4> ]
No default output interfaces are set.
Policy node view
&<1-4>: Indicates that you can specify up to four interfaces, each of which can be associated with a track entry.
You can specify multiple default output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The default output interface must be P2P type. Using a non-P2P default output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and non-broadcast multi-access (NBMA) interfaces such as Ethernet and virtual-template interfaces. In NBMA networks, packets are sent in unicast.
With a default output interface specified, the undo apply default-output-interface command removes the default output interface.
Without any default output interface specified, the undo apply default-output-interface command removes all default output interfaces.
# Specify GigabitEthernet 1/0/1 as the default output interface for IP packets.
[Sysname-pbr-aa-11] apply default-output-interface gigabitethernet 1/0/1
apply loadshare
apply default-srv6-policy
Use apply default-srv6-policy to set default SRv6 TE policies.
Use undo apply default-srv6-policy to remove default SRv6 TE policies.
apply default-srv6-policy { endpoint color [ { sid | vpnsid } sid ] }&<1-2>
undo apply default-srv6-policy [ { endpoint color }&<1-2> ]
No default SRv6 TE policies are set.
Policy node view
endpoint: Specifies a default SRv6 TE policy by its endpoint IPv6 address.
color: Specifies a default SRv6 TE policy by its color attribute value in the range of 0 to 4294967295.
sid: Indicates that the SRv6 SID of the destination node is a public network SID.
vpnsid: Indicates that the SRv6 SID of the destination node is a VPN SID.
sid: Specifies the SRv6 SID of the destination node in IPv6 address format.
&<1-2>: Indicates that you can specify up to two default SRv6 TE policies.
You can specify multiple default SRv6 TE policies for backup in one command line or by executing this command multiple times. The first available default SRv6 TE policy selected according to configuration order will be used to forward matching packets.
Without any default SRv6 TE policy specified, the undo apply default-srv6-policy command removes all default SRv6 TE policies.
Use the { sid | vpnsid } sid option to specify the SRv6 SID of the destination node and its attribute information (public network SID or VPN SID). The attribute information is not encapsulated in packets and does not affect packet fowarding.
When encapsulating packets matching the default SRv6 TE policy, the source node adds the SRv6 SID of the destination node to the SID list in the SRH header of the packets. Upon receiving the packets, the destination node uses the SRv6 SID to perform an SRv6 local SID forwarding table lookup to forward the packets.
# Specify a default SRv6 TE policy with destination node IPv6 address 1000::1, color attribute value 10, and destination node SRv6 SID 2000::2.
[Sysname-pbr-aa-1] apply default-srv6-policy 1000::1 10 sid 2000::2
apply loadshare
apply gateway
Use apply gateway to set the next hop addresses for matching packets to the specified gateway addresses.
Use undo apply gateway to remove the configuration.
apply gateway { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply gateway [ { interface-type interface-number }&<1-4> ]
The next hop addresses for matching packets are not set to gateway addresses.
Policy node view
After you execute this command, PBR uses the specified interfaces to obtain gateway addresses to be used as the next hop addresses for matching packets. Upon a change of a gateway address, the device automatically changes the associated next hop address. If the specified interface fails to obtain a gateway address or the obtained gateway address is invalid, the command does not take effect.
You can specify multiple interfaces in one command line or by executing this command multiple times to obtain gateway addresses to be used as next hops addresses for backup. PBR selects the first available next hop address according to configuration order to forward matching packets.
With an interface specified, the undo form of the command removes the next hop address (gateway address) obtained by the interface.
Without any interfaces specified, the undo form of the command removes all next hop addresses obtained from gateway addresses.
# Set the next hop address for matching packets to the gateway address obtained by interface GigabitEthernet 1/0/1.
[Sysname-pbr-aa-11] apply gateway gigabitethernet 1/0/1
apply ip-df
Use apply ip-df to set the Don't Fragment (DF) bit in the IP header of matching packets.
Use undo apply ip-df to restore the default.
apply ip-df df-value
undo apply ip-df
The DF bit is not set.
Policy node view
df-value: Sets the DF bit in the IP header of matching packets. The value can be 0 or 1.
Setting the DF bit to 0 allows packet fragmentation.
Setting the DF bit to 1 prohibits packet fragmentation.
# Set the DF bit in the IP header of matching packets to 0.
[Sysname-pbr-aa-11] apply ip-df 0
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops, output interfaces, SRv6 TE policies, default next hops, default output interfaces, or default SRv6 TE policies.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | default-output-interface | default-srv6-policy | next-hop | output-interface | srv6-policy }
undo apply loadshare { default-next-hop | default-output-interface | default-srv6-policy | next-hop | output-interface | srv6-policy }
Multiple next hops, output interfaces, SRv6 TE policies, default next hops, default output interfaces, or default SRv6 TE policies operate in primary/backup mode.
Policy node view
default-next-hop: Enables load sharing among multiple default next hops.
default-output-interface: Enables load sharing among multiple default output interfaces.
default-srv6-policy: Enables load sharing among multiple default SRv6 TE policies.
next-hop: Enables load sharing among multiple next hops.
output-interface: Enables load sharing among multiple output interfaces.
srv6-policy: Enables load sharing among multiple SRv6 TE policies.
Multiple next hop, output interface, SRv6 TE policy, default next hop, default output interface, or default SRv6 TE policy options operate in either primary/backup or load sharing mode. The following description uses multiple next hops as an example:
·     Primary/backup mode—A next hop is selected from all next hops in configuration order for packet forwarding, with all remaining next hops as backups. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Matching traffic is distributed across the available next hops. If the traffic does not match any fast forwarding entries, per-packet load sharing is performed. If the traffic matches a fast forwarding entry, per-flow load sharing is performed.
# Enable load sharing among multiple next hops.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare next-hop
# Enable load sharing among multiple output interfaces.
[Sysname-pbr-aa-11] apply output-interface gigabitethernet 1/0/1 gigabitethernet 1/0/2
[Sysname-pbr-aa-11] apply loadshare output-interface
# Enable load sharing among multiple SRv6 TE policies.
[Sysname-pbr-aa-11] apply srv6-policy 1000::1 10 sid 2000::2 3000::1 12 sid 4000::2
[Sysname-pbr-aa-11] apply loadshare srv6-policy
# Enable load sharing among multiple default next hops.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare default-next-hop
# Enable load sharing among multiple default output interfaces.
[Sysname-pbr-aa-11] apply default-output-interface gigabitethernet 1/0/1 gigabitethernet 1/0/2
[Sysname-pbr-aa-11] apply loadshare default-output-interface
# Enable load sharing among multiple default SRv6 TE policies.
[Sysname-pbr-aa-11] apply default-srv6-policy 1000::1 10 sid 2000::2 3000::1 12 sid 4000::2
[Sysname-pbr-aa-11] apply loadshare default-srv6-policy
apply next-hop
apply srv6-policy
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] [ weight weight-value ] }&<1-4>
undo apply next-hop [ [ vpn-instance vpn-instance-name | inbound-vpn ] ip-address&<1-4> ]
No next hops are set.
Policy node view
ip-address: Specifies the IP address of a next hop. If you do not specify the vpn-instance vpn-instance-name option or the inbound-vpn keyword, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
weight weight-value: Specifies a load sharing weight for the next hop, in the range of 1 to 100. The default is 10. If you specify weights 1, 1, and 2 for three next hops, they share 1/4, 1/4, and 1/2 of the whole traffic, respectively.
&<1-4>: Indicates that you can specify up to four next hops, each of which can be associated with a track entry.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply loadshare
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply output-interface [ { interface-type interface-number }&<1-4> ]
No output interfaces are set.
Policy node view
You can specify multiple output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces.
With an output interface specified, the undo apply output-interface command removes the output interface.
Without any output interface specified, the undo apply output-interface command removes all output interfaces.
# Specify GigabitEthernet 1/0/1 as the output interface for IP packets.
apply loadshare
apply precedence
Use apply precedence to set a precedence for IP packets.
Use undo apply precedence to restore the default.
No precedence is set for IP packets.
Policy node view
type: Specifies the precedence type for IP packets.
value: Specifies the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
# Set the precedence to 5 (critical) for IP packets.
[Sysname-pbr-aa-11] apply precedence critical
apply remark-vpn
Use apply remark-vpn to enable VPN remark action.
Use undo apply remark-vpn to restore the default.
apply remark-vpn
VPN remark action is not configured.
Policy node view
VPN remark action marks the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command. All subsequent service modules of PBR handle the packets as belonging to the re-marked VPN instance.
If the VPN remark action is not enabled, the forwarded matching packets are marked as belonging to the VPN instance or the public network from which they were received.
VPN remark action applies only to packets that have been successfully forwarded based on the apply access-vpn vpn-instance command.
# Forward packets that match ACL 3000 based on the forwarding table of VPN instance vpn1 and perform VPN remark action on the successfully forwarded packets.
[Sysname] policy-based-route aaa permit node 10
[Sysname-pbr-aaa-10] if-match acl 3000
[Sysname-pbr-aaa-10] apply access-vpn vpn-instance vpn1
[Sysname-pbr-aaa-10] apply remark-vpn
apply srv6-policy
Use apply srv6-policy to set SRv6 TE policies.
Use undo apply srv6-policy to remove SRv6 TE policies.
apply srv6-policy { endpoint color [ { sid | vpnsid } sid ] }&<1-2>
undo apply srv6-policy [ { endpoint color }&<1-2> ]
No SRv6 TE policies are set.
Policy node view
endpoint: Specifies an SRv6 TE policy by its endpoint IPv6 address.
color: Specifies an SRv6 TE policy by its color attribute value in the range of 0 to 4294967295.
&<1-2>: Indicates that you can specify up to two SRv6 TE policies.
You can specify multiple SRv6 TE policies for backup in one command line or by executing this command multiple times. The first available SRv6 TE policy selected according to configuration order will be used to forward matching packets.
Without any SRv6 TE policy specified, the undo apply srv6-policy command removes all SRv6 TE policies.
When encapsulating packets matching the SRv6 TE policy, the source node adds the SRv6 SID of the destination node to the SID list in the SRH header of the packets. Upon receiving the packets, the destination node uses the SRv6 SID to perform an SRv6 local SID forwarding table lookup to forward the packets.
# Specify an SRv6 TE policy with destination node IPv6 address 1000::1, color attribute value 10, and destination node SRv6 SID 2000::2.
[Sysname-pbr-aa-1] apply srv6-policy 1000::1 10 sid 2000::2
apply loadshare
display ip policy-based-route
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
    apply srv6-policy 1000::1 10 sid 2000::2(NID: 2150629377)
    apply default-srv6-policy 3000::3 20 vpnsid 4000::4(NID: 2149580801)
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
Specifies an SRv6 TE policy for permitted packets. Associated information about the SRv6 TE policy include:
·     Destination node IPv6 address 1000::1.
·     Color attribute value 10.
·     Destination node SRv6 SID 2000::2.
·     Next Hop Label Forwarding Entry (NHLFE) index 2150629377.
Specifies a default SRv6 TE policy for permitted packets. Associated information about the SRv6 TE policy include:
·     Destination node IPv6 address 3000::3.
·     Color attribute value 20.
·     Destination node SRv6 SID 4000::4.
·     NHLFE index 2149580801.
policy-based-route
display ip policy-based-route interface
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
In standalone mode:
display ip policy-based-route interface interface-type interface-number
In IRF mode:
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information on the master device. (In IRF mode.)
# Display PBR configuration and statistics on GigabitEthernet 1/0/1.
<Sysname> display ip policy-based-route interface gigabitethernet 1/0/1
Policy based routing information for interface GigabitEthernet1/0/1(failed):
Policy name: aaa
  node 0 deny:
  Matches: 0
  node 1 permit:
    if-match acl 3999
  Matches: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 2.2.2.2
  Matches: 0
  node 5 permit:
    if-match acl 3101
    apply output-interface GigabitEthernet1/0/2 track 1 (down)
    apply output-interface GigabitEthernet1/0/3 track 2 (inactive)
  Matches: 0
  node 8 permit:
   if-match acl 3200
  Matches: 0
Total matches: 0
Policy based routing information for interface XXXX
PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To issue the policy, you must remove the policy from the interface and then apply it on the interface again.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·     For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·     For a physical interface, specify its slot number.
node 0 deny
node 2 permit
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·     not support—The device does not support the match criteria configured on the node.
·     no resource—No sufficient resources (for example, ACLs) are available for the node.
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
apply next-hop
Specifies an output interface and its associated track entry for permitted packets.
This field displays the interface status in brackets.
·     down—The interface is down at network layer.
·     inactive—The card that hosts the interface is not in position.
Matches
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
Total matches
Total number of successful matches on all nodes.
display ip policy-based-route local
Use display ip policy-based-route local to display local PBR configuration and statistics.
In standalone mode:
In IRF mode:
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays local PBR configuration and statistics for the master device. (In IRF mode.)
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matches: 0
  node 1 permit:
    if-match acl 3999
  Matches: 0
  node 2 permit:
    if-match acl 2000
  Matches: 0
  node 5 permit:
    if-match acl 3101
  Matches: 0
  node 8 permit:
   if-match acl 3200
  Matches: 0
Total matches: 0
Local PBR configuration and statistics.
node 0 deny/node 2 permit
Match mode of the node: permit or deny.
if-match acl
apply next-hop
Matches
Total matches
ip local policy-based-route
display ip policy-based-route setup
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
Policy name              Type     Interface
aaa                      Forward  GigabitEthernet1/0/1
aaa                      Forward  GigabitEthernet1/0/2
aaa                      Local    N/A
Table 5 Command output
Type of the PBR:
·     Forward—Interface PBR.
·     Local—Local PBR.
Interface where the policy is applied.
This field displays N/A for a local PBR policy.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
If the vpn-instance keyword is specified for an ACL rule, the rule applies to only VPN packets. If the vpn-instance keyword is not specified, the rule applies to only public network packets.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
if-match app-group
Use if-match app-group to set application group match criteria.
Use undo if-match app-group to delete application group match criteria.
if-match app-group app-group-name&<1-6>
undo if-match app-group [ app-group-name&<1-6> ]
No application group match criteria are set.
Policy node view
app-group-name&<1-6>: Specifies up to six application groups by their names. An application group name is a case-insensitive string of 1 to 63 characters, which can contain letters, digits, underscores (_), and hyphens (-). The application group name cannot be Invalid, other, or any application group name predefined by the system.
The application match criteria apply only to interface PBR.
If you specify an application group, the undo if-match app-group command deletes the application group match criterion.
If you do not specify an application group, the undo if-match app-group command deletes all application group match criteria.
# Specify the application group test as a match criterion.
[Sysname-pbr-aa-11] if-match app-group test
if-match object-group
Use if-match object-group to set service object group match criteria.
Use undo if-match object-group to delete service object group match criteria.
if-match object-group service object-group-name&<1-6>
undo if-match object-group service [ object-group-name&<1-6> ]
No service object group match criteria are set.
Policy node view
object-group-name&<1-6>: Specifies up to six service object groups by their names. A service object group name is a case-insensitive string of 1 to 63 characters, which can contain letters, digits, underscores (_), and hyphens (-).
If you specify a service object group, the undo if-match object-group command deletes the service object group match criterion.
If you do not specify a service object group, the undo if-match object-group command deletes all service object group match criteria.
# Specify the service object group test as a match criterion.
[Sysname-pbr-aa-11] if-match object-group service test
if-match packet-length
Use if-match packet-length to set a packet length match criterion.
Use undo if-match packet-length to restore the default.
if-match packet-length min-len max-len
No packet length match criterion is set.
Policy node view
min-len: Specifies the minimum IP packet length in the range of 1 to 65535 bytes.
max-len: Specifies the maximum IP packet length in the range of 1 to 65535 bytes. The maximum length must be no less than the minimum length.
Use this command to set a criterion to match the total length of data packets.
The packet length range includes boundary values. For example, if you set the min-len and max-len arguments to 100 and 200, respectively, packets with lengths of 100 bytes and 200 bytes are also matched.
# Match packets with a length from 100 to 200 bytes.
[Sysname-pbr-aa-11] if-match packet-length 100 200
if-match source-ip
Use if-match source-ip to set a source IP address match criterion to match locally generated packets.
Use undo if-match source-ip to delete the source IP address match criterion to match locally generated packets.
if-match source-ip { interface interface-type interface-number | [ vpn-instance vpn-instance-name ] ip-address }
No source IP address match criterion is set.
Policy node view
interface interface-type interface-number: Specifies an interface by its type and number. The primary IP address of the interface will be used to match packets.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the specified IP address belongs to the public network.
ip-address: Specifies an IP address in dotted decimal notation.
This command matches locally generated packets sent out with the specified IP address or the primary IP address of the specified interface.
Typically, you use this command to make sure local tunneled or VPN traffic (for example, IPsec packets) is sent towards the correct ISP when the device is dual- or multi-homed to different ISPs. This command helps you avoid packet drops that might occur when packets are sent to an incorrect ISP.
For the matching traffic, use the apply next-hop or apply output-interface command to specify the next hop or the output interface. As a best practice, specify the output interface in the apply clause if you specify the source interface in the if-match clause.
As a best practice, do not specify the interface of a VXLAN tunnel automatically created by EVPN for this command. If the tunnel interface number changes upon VXLAN tunnel reestablishment, the match criterion no longer takes effect. For more information about EVPN, see EVPN overview in EVPN Configuration Guide.
If you execute this command multiple times on a policy node, the most recent configuration takes effect.
# Match locally generated packets with source IP address 1.1.1.1.
[Sysname-pbr-aa-11] if-match source-ip 1.1.1.1
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is specified for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
Before you apply a new policy, you must first remove the current policy.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
# Apply policy aaa to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ip policy-based-route aaa
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
·     If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
·     If a match mode is specified, the command deletes all nodes configured with the match mode.
·     If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
reset ip policy-based-route statistics
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
