Title | Size | Downloads |
V7-APR-1.0.174.dat | 2.70 MB |
Version number
V7-APR-1.0.174
MD5 number
f6f4c2c1c13c8f86805db90d972d3c66
Update time
2024-04-16
Update protocol list
Modified protocols: [1]
----GoogleDrive
----OneDrive
Update protocols: [2]
----AIPaperPass
----AIPPT
----YmiAI
----SmartRead
----BaiPingAI
----AiRunSe
----IBiLing
----QingYuAI
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9605 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1557 predefined applications can be generated
