03-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000][VFW] Firewalls Series Configuration Guides(V7)-6W60003-Security Configuration Guide
05-Object group configuration
05-Object group configuration 91.35 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL to identify packets. Object groups are divided into the following types:
·     MAC address object group—A group of MAC address objects used to match the MAC address in a packet.
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
·     Service object group—A group of service objects used to match the upper-layer service in a packet.
Restrictions and guidelines: Object group configuration
You cannot edit an object group if the group is used by a global static NAT rule.
Configuring a MAC address object group
2.     Create a MAC address object group and enter its view.
object-group mac-address object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the MAC address object group.
By default, an object group does not have a description.
4.     Configure a MAC address object.
[ object-id ] mac { mac-address | group-object group-object-name }
5.     Configure a description for the MAC address object.
object object-id description text
By default, a MAC address object does not have a description.
Configuring an IPv4 address object group
2.     Create an IPv4 address object group and enter its view.
object-group ip address object-group-name
3.     (Optional.) Configure a description for the IPv4 address object group.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
5.     Configure a description for the IPv4 address object.
By default, an IPv4 address object does not have a description.
6.     Exclude an IPv4 address or a subnet from the IPv4 address object.
object-id network exclude { ip-address | subnet ip-address { mask-length | mask } }
By default, no IPv4 address in an IPv4 address object is excluded.
7.     (Optional.) Specify a security zone for the IPv4 address object group.
security-zone security-zone-name
By default, no security zone is specified for an IPv4 address object group.
Configuring an IPv6 address object group
2.     Create an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
5.     Configure a description for an IPv6 address object.
By default, an IPv6 address object does not have a description.
6.     Exclude an IPv6 address or a subnet from the IPv6 address object.
object-id network exclude { ip-address | subnet ipv6-address prefix-length }
By default, no IPv6 address in an IPv6 address object is excluded.
7.     (Optional.) Specify a security zone for the IPv6 address object group.
By default, no security zone is specified for an IPv6 address object group.
Configuring a service object group
2.     Create a service object group and enter its view.
object-group service object-group-name
The system has multiple default service object groups.
3.     (Optional.) Configure a description for the service object group.
4.     Configure a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
5.     Configure a description for the service object.
By default, a service object does not have a description.
Renaming an object group
2.     Rename an object group.
object-group rename old-object-group-name new-object-group-name
You can only rename non-default object groups.
Configuring aging of DNS-resolved IP addresses from host names
In load balancing scenarios where one host name maps to several IP addresses, DNS-resolved IP address for a host name changes between these mapping addresses. Upon every change, the object group module notifies relevant policies (such as security policy) of the change, which causes policies to submit changes frequently and consumes memory. To resolve this issue, you can enable aging of DNS-resolved IP addresses from host names.
With this feature enabled, the system maintains an IP address group for each host name. If a resolved IP address is not in the group, the system adds the address to the group and notifies relevant policies of the change. If a resolved IP address is in the group, the system does not notify relevant policies.
Hardware and feature compatibility
Hardware series
Model
Feature compatibility
F50X0 series
F5010, F5020, F5020-GM, F5030, F5030-6GW, F5040, F5060, F5080, F5000-A, F5000-C, F5000-S, F5000-M
Yes
F5000-CN series
F5000-CN30, F5000-CN60
Yes
F5000-AI series
F5000-AI-15, F5000-AI-20, F5000-AI-40
Yes
F5000-V series
F5000-V30
Yes
F1000-AI series
F1000-AI-10, F1000-AI-15, F1000-AI-25, F1000-AI-35, F1000-AI-55
No
F1000-AI-05, F1000-AI-20, F1000-AI-30, F1000-AI-50, F1000-AI-60, F1000-AI-65, F1000-AI-70, F1000-AI-75, F1000-AI-80, F1000-AI-90
Yes
F1000-L series
F1003-L, F1005-L, F1010-L
Yes
F10X0 series
F1005, F1010, F1020, F1020-GM, F1030, F1030-GM, F1050, F1060, F1070, F1070-GM, F1070-GM-L, F1080, F1090
Yes
F1000-V series
F1000-V50
No
F1000-V70, F1000-V60, F1000-V90
Yes
F1000-SASE series
F1000-SASE100
Yes
F1000-SASE200
No
F1000-AK series
F1000-AK108, F1000-AK109, F1000-AK110, F1000-AK115, F1000-AK120, F1000-AK125, F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK180, F1000-AK185, F1000-GM-AK370, F1000-GM-AK380, F1000-AK710, F1000-AK711, F1000-AK1010, F1000-AK1020, F1000-AK1030, F1000-AK1110, F1000-AK1120, F1000-AK1130, F1000-AK1140, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK1342, F1000-AK1352, F1000-AK1362, F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614, F1000-AK9110, F1000-AK9210
Yes
F1000-AK1150, F1000-AK1160, F1000-AK1170, F1000-AK1180, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272
No
Firewall modules
IM-NGFWX-IV, LSPM6FWD, LSPM6FWDB, LSQM1FWDSC0, LSQM2FWDSC0, LSU3FWCEA0, LSUM1FWCEAB0, LSUM1FWDEC0, LSWM1FWD0, LSX1FWCEA1, LSXM1FWDF1
No
vFW series
vFW1000, vFW2000
No
As a best practice, set the aging time to be longer than the TTL of resolution records on the DNS server.
2.     Enable aging of DNS-resolved IP addresses from host names.
object-group dns-aging [ time aging-time ]
By default, aging of DNS-resolved IP addresses from host names is disabled.
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address | mac-address | service } [ default ] [ name object-group-name ] | name object-group-name ]
Display IPv4 or IPv6 addresses for host names.
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } *
