01-Typical configuration example
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-F Routers Configuration Examples All-In-One-R8530Pxx-6W10001-Typical configuration example
Table of Contents
Related Documents
43-H3C_MPLS OAM_Configuration_Examples
43-H3C_MPLS OAM_Configuration_Examples 186.27 KB
Introduction
This document provides MPLS OAM configuration examples.
MPLS Operation, Administration, and Maintenance (OAM) provides fault management tools for the following purposes:
·     MPLS data plane connectivity verification.
·     Data plane and control plane consistency verification.
·     Fault isolation.
This document assumes that you have basic knowledge of MPLS OAM.
Example: Configuring BFD for an LSP
As shown in Figure 1, Branch 1 and Branch 2 of a company are connected to each other through an MPLS backbone of the ISP. The branches need to exchange real-time data.
To ensure high availability of the real-time service between the branches, deploy LDP FRR on the MPLS backbone to provide a primary LSP and a backup LSP. Configure BFD for the primary LSP, so when the primary LSP fails, BFD can quickly detect the failure and notify LDP of the failure to trigger a traffic switchover to the backup LSP.
Figure 1 Network diagram
Procedures
1.     Assign IP addresses to interfaces:
# Assign an IP address to Ten-GigabitEthernet 3/1/1 on PE 1.
<PE1> system-view
[PE1] interface ten-gigabitethernet 3/1/1
[PE1-Ten-GigabitEthernet3/1/1] ip address 12.12.12.1 24
[PE1-Ten-GigabitEthernet3/1/1] quit
# Assign IP addresses to other interfaces (including the loopback interfaces) according to Figure 1. (Details not shown.)
2.     On the MPLS backbone, configure OSPF to ensure IP connectivity between the routers, and enable OSPF FRR.
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.168.10.0 0.0.0.255
[PE1-ospf-1] fast-reroute lfa
[PE1-ospf-1] quit
# Configure P.
[P1] ospf
[P1-ospf-1] area 0
[P1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] quit
[P1-ospf-1] quit
# Configure PE 2.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 34.34.34..0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[PE2-ospf-1] fast-reroute lfa
[PE2-ospf-1] quit
# Configure P 2.
[P2] ospf
[P2-ospf-1] area 0
[P2-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] network 34.34.34.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] quit
[P2-ospf-1] quit
# Adjust the OSPF cost values of Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 to ensure that the OSPF cost of the backup LSP is greater than that of the primary LSP.
[P2] interface ten-gigabitethernet 3/1/1
[P2-Ten-GigabitEthernet3/1/1] ospf cost 10
[P2-Ten-GigabitEthernet3/1/1] quit
[P2] interface ten-gigabitethernet 3/1/2
[P2-Ten-GigabitEthernet3/1/2] ospf cost 10
[P2-Ten-GigabitEthernet3/1/2] quit
3.     Configure basic MPLS and enable LDP.
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/1/1] mpls enable
[PE1-Ten-GigabitEthernet3/1/1] mpls ldp enable
[PE1] interface ten-gigabitethernet 3/1/2
[PE1-Ten-GigabitEthernet3/1/2] mpls enable
[PE1-Ten-GigabitEthernet3/1/2] mpls ldp enable
[PE1-Ten-GigabitEthernet3/1/2] quit
# Configure P 1.
[P1] mpls lsr-id 2.2.2.2
[P1] mpls ldp
[P1-ldp] quit
[P1] interface ten-gigabitethernet 3/1/1
[P1-Ten-GigabitEthernet3/1/1] mpls enable
[P1-Ten-GigabitEthernet3/1/1] mpls ldp enable
[P1-Ten-GigabitEthernet3/1/1] quit
[P1] interface ten-gigabitethernet 3/1/2
[P1-Ten-GigabitEthernet3/1/2] mpls enable
[P1-Ten-GigabitEthernet3/1/2] mpls ldp enable
[P1-Ten-GigabitEthernet3/1/2] quit
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface ten-gigabitethernet 2/0/1
[PE2-Ten-GigabitEthernet2/0/1] mpls enable
[PE2-Ten-GigabitEthernet2/0/1] mpls ldp enable
[PE2-Ten-GigabitEthernet2/0/1] quit
[PE2] interface ten-gigabitethernet 2/0/2
[PE2-Ten-GigabitEthernet2/0/2] mpls enable
[PE2-Ten-GigabitEthernet2/0/2] mpls ldp enable
[PE2-Ten-GigabitEthernet2/0/2] quit
# Configure P 2.
[P2] mpls lsr-id 4.4.4.4
[P2] mpls ldp
[P2-ldp] quit
[P2-Ten-GigabitEthernet3/1/1] mpls enable
[P2-Ten-GigabitEthernet3/1/1] mpls ldp enable
[P2-Ten-GigabitEthernet3/1/2] mpls enable
[P2-Ten-GigabitEthernet3/1/2] mpls ldp enable
After the previous configuration, you can see that the state of LDP sessions is Operational. Take PE 1 as an example:
 [PE1] display mpls ldp peer
Total number of peers: 2
Peer LDP ID             State         Role     GR   MD5  KA Sent/Rcvd
2.2.2.2:0               Operational   Passive  Off  Off  55/55
4.4.4.4:0               Operational   Passive  Off  Off  6/6
4.     Configure an LSP generation policy to establish LSPs for routes destined for 192.168.10.0/24, 192.168.20.0/24, 1.1.1.1/32, and 3.3.3.3/32:
# On PE 1, create an IP prefix list named PE1. Configure that only the routes permitted by the prefix can trigger LDP to establish LSPs.
[PE1] ip prefix-list PE1 index 10 permit 192.168.10.0 24
[PE1] ip prefix-list PE1 index 20 permit 192.168.20.0 24
[PE1] ip prefix-list PE1 index 30 permit 1.1.1.1 32
[PE1] ip prefix-list PE1 index 40 permit 3.3.3.3 32
[PE1] mpls ldp
[PE1-ldp] lsp-trigger prefix-list PE1
[PE1-ldp] quit
# On P 1, create an IP prefix list named P1. Configure that only the routes permitted by the prefix can trigger LDP to establish LSPs.
[P1] ip prefix-list P1 index 10 permit 192.168.10.0 24
[P1] ip prefix-list P1 index 20 permit 192.168.20.0 24
[P1] ip prefix-list P1 index 30 permit 1.1.1.1 32
[P1] ip prefix-list P1 index 40 permit 3.3.3.3 32
[P1] mpls ldp
[P1-ldp] lsp-trigger prefix-list P1
[P1-ldp] quit
# On PE 2, create an IP prefix list named PE2. Configure that only the routes permitted by the prefix can trigger LDP to establish LSPs.
[PE2] ip prefix-list PE2 index 10 permit 192.168.10.0 24
[PE2] ip prefix-list PE2 index 20 permit 192.168.20.0 24
[PE2] ip prefix-list PE2 index 30 permit 1.1.1.1 32
[PE2] ip prefix-list PE2 index 40 permit 3.3.3.3 32
[PE2] mpls ldp
[PE2-ldp] lsp-trigger prefix-list PE2
[PE2-ldp] quit
# On P 2, create an IP prefix list named P2. Configure that only the routes permitted by the prefix can trigger LDP to establish LSPs.
[P2] ip prefix-list P2 index 10 permit 192.168.10.0 24
[P2] ip prefix-list P2 index 20 permit 192.168.20.0 24
[P2] ip prefix-list P2 index 30 permit 1.1.1.1 32
[P2] ip prefix-list P2 index 40 permit 3.3.3.3 32
[P2] mpls ldp
[P2-ldp] lsp-trigger prefix-list P2
[P2-ldp] quit
# Execute the display mpls ldp lsp command on PE 1. The output shows that the LSP destined for 192.168.20.0/24 has been established.
[PE1]display mpls ldp lsp
VPN instance: public instance
Status Flags: * - stale, L - liberal, B - backup, N/A – unavailable
FECs: 4            Ingress: 4          Transit: 4      Egress: 2
FEC                In/Out Label        Nexthop         OutInterface/LSINDEX
1.1.1.1/32         3/-
                   -/1151(L)
                   -/1279(L)
3.3.3.3/32         -/1150              12.12.12.2      XGE3/1/1
                   1150/1150           12.12.12.2      XGE3/1/1
                   -/1150(B)           12.12.12.2      XGE3/1/2
                   1150/1150(B)        12.12.12.2      XGE3/1/2
192.168.10.0/24    1141/-
                   -/1141(L)
                   -/1141(L)
192.168.20.0/24    -/1133              12.12.12.2      XGE3/1/1
                   1133/1133           12.12.12.2      XGE3/1/1
                   -/1133(B)           14.14.14.4      XGE3/1/2
                   1133/1133(B)        14.14.14.4      XGE3/1/2
5.     Enable BFD for MPLS, and configure BFD to verify connectivity for the LSP:
# Configure PE 1.
[PE1] mpls bfd enable
[PE1] mpls bfd 3.3.3.3 32
# Configure PE 2.
[PE2] mpls bfd enable
[PE2] mpls bfd 1.1.1.1 32
1.     On PE 1 and PE 2, execute the display mpls bfd command to view information about the BFD sessions for the LSPs. Take PE 1 as an example:
[PE1]display mpls bfd
 Total number of sessions: 2, 2 up, 0 down, 0 init
 FEC Type: LSP
 FEC Info:
   Destination: 1.1.1.1
   Mask Length: 32
 NHLFE ID: -
 Local Discr: 1026                   Remote Discr: 514
 Source IP: 1.1.1.1                  Destination IP: 3.3.3.3
 Session State: Up                   Session Role: Active
 Template Name: -
 FEC Type: LSP
 FEC Info:
   Destination: 3.3.3.3
   Mask Length: 32
 NHLFE ID: 1028
 Local Discr: 1025                   Remote Discr: -
 Source IP: 1.1.1.1                  Destination IP: 127.0.0.1
 Session State: Up                   Session Role: Passive
 Template Name: -
2.     On PE 1, execute the tracert mpls ipv4 command to verify that the current LSP in use is the primary LSP. (To use the tracert feature, you must also enable sending of ICMP time exceeded messages on the transit devices and enable sending of ICMP destination unreachable messages on the destination device.)
<PE1>tracert mpls -a 192.168.10.1 ipv4 192.168.20.0 24
MPLS trace route FEC 192.168.20.0/24
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   12.12.12.2/[1141]
  1     12.12.12.2         2 ms    Transit   23.23.23.3/[1141]
  2     23.23.23.3         2 ms    Egress
3.     Continuously ping PE 2 from PE 1. During this period, shut down Ten-GigabitEthernet 3/1/1 of P 1. Verify the communication between PE 1 and PE 2.
# Continuously ping PE 2 from PE 1.
<PE1>ping -c 100000 -a 192.168.10.1 192.168.20.1
Ping 192.168.20.1 (192.168.20.1) from 192.168.10.1: 56 data bytes, press CTRL_C
to break
56 bytes from 192.168.20.1: icmp_seq=0 ttl=254 time=2.576 ms
56 bytes from 192.168.20.1: icmp_seq=1 ttl=254 time=1.996 ms
# Shut down Ten-GigabitEthernet 3/1/1 of P 1.
[P1] interface ten-gigabitethernet3/1/1
[P1-Ten-GigabitEthernet3/1/1] shut
# You can see that PE 1 and PE 2 resumed connectivity quickly after a short period of disconnection.
to break
56 bytes from 192.168.20.1: icmp_seq=7 ttl=254 time=2.214 ms
Request time out
56 bytes from 192.168.20.1: icmp_seq=9 ttl=254 time=2.659 ms
56 bytes from 192.168.20.1: icmp_seq=10 ttl=254 time=5.049 ms
56 bytes from 192.168.20.1: icmp_seq=11 ttl=254 time=2.098 ms
56 bytes from 192.168.20.1: icmp_seq=12 ttl=254 time=2.225 ms
56 bytes from 192.168.20.1: icmp_seq=13 ttl=254 time=2.187 ms
--- Ping statistics for 192.168.20.1 ---
14 packet(s) transmitted, 13 packet(s) received, 7.1% packet loss
round-trip min/avg/max/std-dev = 1.990/2.455/5.049/0.772 ms
4.     Test whether a switchover has happened:
# On PE 1, execute the tracert mpls ipv4 command. You can see the currently used LSP is the bakcup LSP.
  0                                Ingress   14.14.14.4/[1133]
  1     14.14.14.4         2 ms    Transit   34.34.34.3/[1141]
  2     34.34.34.3         2 ms    Egress
Configuration files
·     PE 1
ospf 1
 fast-reroute lfa
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
mpls ldp
 mpls bfd enable
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface Ten-GigabitEthernet3/1/1
 port link-mode route
 ip address 12.12.12.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface Ten-GigabitEthernet3/1/2
 ip address 14.14.14.1 255.255.255.0
 mpls enable
 mpls ldp enable
 mpls bfd 3.3.3.3 32
·     PE 2
ospf 1
 fast-reroute lfa
 area 0.0.0.0
 mpls lsr-id 3.3.3.3
mpls ldp
 mpls bfd enable
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 34.34.34.3 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 23.23.23.3 255.255.255.0
 mpls enable
 mpls ldp enable
 mpls bfd 1.1.1.1 32
·     P 1
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
mpls ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 12.12.12.2 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 23.23.23.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     P 2
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.4
mpls ldp
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 34.34.34.4 255.255.255.0
 ospf cost 10
 mpls enable
 mpls ldp enable
 ip address 14.14.14.4 255.255.255.0
 ospf cost 10
 mpls enable
 mpls ldp enable
Example: Configuring BFD for an MPLS TE tunnel
As shown in Figure 2, Branch 1 and Branch 2 of a company are connected to each other through an MPLS TE tunnel. The branches need to exchange real-time data.
To ensure high availability of the real-time service between the branches, deploy CRLSP backup for the MPLS TE tunnel to provide a primary CRLSP and a backup CRLSP. Configure BFD for the MPLS TE tunnel, so when the primary CRLSP fails, BFD can quickly detect the failure and notify RSVP of the failure to trigger a traffic switchover to the backup CRLSP.
Figure 2 Network diagram
·     OSPF TE uses Opaque Type 10 LSAs to carry link TE attributes. To configure OSPF TE, you must enable the OSPF Opaque capability. For more information about the OSPF Opaque capability, see OSPF configuration in Layer 3—IP Routing Configuration Guide for the device.
·     MPLS TE cannot reserve resources and allocate labels on OSPF virtual links to establish CRLSPs. To configure OSPF TE, make sure no virtual links exist in OSPF areas.
Procedures
# Assign an IP address to Ten-GigabitEthernet 3/1/1 on Router A.
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] ip address 12.12.12.1 24
[RouterA-Ten-GigabitEthernet3/1/1] quit
# # Assign IP addresses to other interfaces (including the loopback interfaces) according to Figure 2. (Details not shown.)
2.     Configure an LSR ID, enable MPLS, MPLS TE, and RSVP-TE on the routers:
# Configure Router A.
[RouterA] mpls lsr-id 1.1.1.1
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterA-Ten-GigabitEthernet3/1/1] mpls enable
[RouterA-Ten-GigabitEthernet3/1/1] mpls te enable
[RouterA-Ten-GigabitEthernet3/1/1] rsvp enable
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] mpls enable
[RouterA-Ten-GigabitEthernet3/1/2] mpls te enable
[RouterA-Ten-GigabitEthernet3/1/2] rsvp enable
[RouterA-Ten-GigabitEthernet3/1/2] quit
# Configure Router B, Router C, and Router D in the same way as you configure Route A. (Details not shown.)
3.     On the MPLS backbone, configure OSPF to ensure IP connectivity between the routers, enable the OSPF Opaque capability, and enable MPLS TE in OSPF area 0:
[RouterA] ospf
[RouterA-ospf-1] opaque-capability enable
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] mpls te enable
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 192.168.10.0 0.0.0.255
[RouterA-ospf-1] quit
# Configure Router B.
[RouterB] ospf
[RouterB-ospf-1] opaque-capability enable
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] mpls te enable
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
[RouterC] ospf
[RouterC-ospf-1] opaque-capability enable
[RouterC ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] mpls te enable
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[RouterC ospf-1-area-0.0.0.0] network 34.34.34..0 0.0.0.255
[RouterC ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[RouterC ospf-1-area-0.0.0.0] quit
[RouterC ospf-1] quit
# Configure Router D.
[RouterD] ospf
[RouterD-ospf-1] opaque-capability enable
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] mpls te enable
[RouterD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 34.34.34.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
4.     Configure the MPLS TE tunnel:
# On Router A, create an MPLS TE tunnel named Tunnel3. Specify the destination address as the LSR ID of Router C (3.3.3.3), specify the signaling protocol as RSVP-TE, and enable CRLSP hot-standby backup for the tunnel.
[RouterA] interface tunnel 3 mode mpls-te
[RouterA-Tunnel3] ip address 9.1.1.1 255.255.255.0
[RouterA-Tunnel3] destination 3.3.3.3
[RouterA-Tunnel3] mpls te signaling rsvp-te
[RouterA-Tunnel3] mpls te backup hot-standby
[RouterA-Tunnel3] quit
# Create explicit paths for the tunnel. Configure CR-LSP 1 as the primary path and CR-LSP 2 as the backup path by setting the preference of CR-LSP 1 to 1 and that of CR-LSP 2 to 2.
[RouterA] explicit-path cr-lsp1
[RouterA-explicit-path-cr-lsp1] nexthop 12.12.12.2
[RouterA-explicit-path-cr-lsp1] quit
[RouterA]explicit-path cr-lsp2
[RouterA-explicit-path-cr-lsp2] nexthop 14.14.14.4
[RouterA-explicit-path-cr-lsp2]quit
[RouterA-Tunnel3] mpls te path preference 1 explicit-path cr-lsp1
[RouterA-Tunnel3] mpls te path preference 2 explicit-path cr-lsp2
# On Router C, create an MPLS TE tunnel named Tunnel3. Specify the destination address as the LSR ID of Router A1.1.1.1), specify the signaling protocol as RSVP-TE, and enable CRLSP hot-standby backup for the tunnel.
[RouterC] interface tunnel 3 mode mpls-te
[RouterC-Tunnel3] ip address 9.3.3.3 255.255.255.0
[RouterC-Tunnel3] destination 1.1.1.1
[RouterC-Tunnel3] mpls te signaling rsvp-te
[RouterC-Tunnel3] mpls te backup hot-standby
[RouterC-Tunnel3] quit
[RouterC] explicit-path cr-lsp1
[RouterC-explicit-path-cr-lsp1] nexthop 23.23.23.2
[RouterC-explicit-path-cr-lsp1] quit
[RouterC]explicit-path cr-lsp2
[RouterC-explicit-path-cr-lsp2] nexthop 34.34.34.4
[RouterC-explicit-path-cr-lsp2]quit
[RouterC-Tunnel3] mpls te path preference 1 explicit-path cr-lsp1
[RouterC-Tunnel3] mpls te path preference 2 explicit-path cr-lsp2
5.     Configure a static route to direct traffic to the MPLS TE tunnel:
# On Router A, configure a static route to direct traffic destined for 192.168.20.0/24 to MPLS TE tunnel interface Tunnel3.
[RouterA] ip route-static 192.168.20.0 24 tunnel 3 preference 1
# On Router C, configure a static route to direct traffic destined for 192.168.10.0/24 to MPLS TE tunnel interface Tunnel3.
[RouterC] ip route-static 192.168.10.0 24 tunnel 3 preference 1
6.     Enable BFD for MPLS, and configure BFD to verify connectivity of the MPLS TE tunnel:
[RouterA] mpls bfd enable
[RouterA-Tunnel3] mpls bfd
[RouterC] mpls bfd enable
[RouterC-Tunnel3] mpls bfd
1.     Verify that the MPLS TE tunnel has been established successfully:
# On Router A and Router C, execute the display interface tunnel command. The output shows that the tunnel state is UP. Take Router A as an example:
<RouterA> display interface tunnel
Tunnel3
Interface index: 17796
Current state: UP
Line protocol state: UP
Description: Tunnel3 Interface
Bandwidth: 64kbps
Maximum Transmit Unit: 1496
Internet Address is 9.1.1.1/24 Primary
Tunnel source unknown, destination 3.3.3.3
Tunnel TTL 255
2.     On Router A, execute the tracert mpls te command to verify that the current path in use is CR-LSP1. (To use the tracert feature, you must also enable sending of ICMP time exceeded messages on the transit devices and enable sending of ICMP destination unreachable messages on the destination device.)
<RouterA>tracert mpls te Tunnel 3
MPLS trace route TE tunnel Tunnel3
  0                                Ingress   12.12.12.2/[1140]
  1     12.12.12.2         30 ms   Transit   23.23.23.3/[3]
3.     On Router A, execute the display mpls bfd command. The output shows that two BFD sessions have been created for the MPLS TE tunnel. The session for the primary CRLSP is up and that for the backup CRLSP is down. Take Router A as an example:
<RouterA>display mpls bfd te tunnel 3
 Total number of sessions: 2, 1 up, 1 down, 0 init
 FEC Type: TE Tunnel
 FEC Info:
   Send Addr: 1.1.1.1
   End  Addr: 3.3.3.3
   Tunnel ID: 3
   LSP ID   : 1150
 NHLFE ID: 1045
 Local Discr: 1026                   Remote Discr: -
 Source IP: 1.1.1.1                  Destination IP: 127.0.0.2
 Session State: Down                 Session Role: Passive
 Template Name: -
 FEC Type: TE Tunnel
 FEC Info:
   Send Addr: 1.1.1.1
   End  Addr: 3.3.3.3
   Tunnel ID: 3
   LSP ID   : 1151
 NHLFE ID: 1047
 Local Discr: 1027                   Remote Discr: 515
 Template Name: -
4.     Continuously ping Router C from Router A. During this period, shut down Ten-GigabitEthernet 3/1/1 of Router B. Verify the communication between Router A and Router C.
# Continuously ping Router C from Router A.
<RouterA>ping -c 10000 -a 192.168.10.1 192.168.20.1
to break
56 bytes from 192.168.20.1: icmp_seq=0 ttl=254 time=3.443 ms
56 bytes from 192.168.20.1: icmp_seq=1 ttl=254 time=2.835 ms
# Shut down Ten-GigabitEthernet 3/1/1 of Router B.
[RouterB] interface ten-gigabitethernet3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] shutdown
# You can see that Router A and Router C resumed connectivity quickly after a short period of disconnection.
to break
56 bytes from 192.168.20.1: icmp_seq=22 ttl=254 time=3.503 ms
Request time out
56 bytes from 192.168.20.1: icmp_seq=24 ttl=254 time=2.434 ms
56 bytes from 192.168.20.1: icmp_seq=25 ttl=254 time=3.196 ms
56 bytes from 192.168.20.1: icmp_seq=26 ttl=254 time=3.592 ms
56 bytes from 192.168.20.1: icmp_seq=27 ttl=254 time=2.305 ms
56 bytes from 192.168.20.1: icmp_seq=28 ttl=254 time=2.139 ms
29 packet(s) transmitted, 28 packet(s) received, 3.4% packet loss
round-trip min/avg/max/std-dev = 2.076/2.701/3.921/0.609 ms
5.     Test whether a switchover has happened:
# On Router A, execute the tracert mpls te command. You can see the currently used path of the tunnel is CR-LSP2.
  0                                Ingress   14.14.14.4/[1142]
  1     14.14.14.4         198 ms  Transit   34.34.34.3/[3]
  2     34.34.34.3         7 ms    Egress
# On Router A, execute the display mpls bfd command. The output shows that a BFD session exists for the CR-LSP2 path of the tunnel and the session state is up.
 Total number of sessions: 1, 1 up, 0 down, 0 init
 FEC Type: TE Tunnel
 FEC Info:
   Send Addr: 1.1.1.1
   End  Addr: 3.3.3.3
   Tunnel ID: 3
   LSP ID   : 1151
 NHLFE ID: 1047
 Template Name: -
Configuration files
·     Router A:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 1.1.1.1
mpls te
 nexthop index 1 12.12.12.2 include strict
 nexthop index 1 14.14.14.4 include strict
rsvp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
interface Ten-GigabitEthernet3/1/3
 ip address 192.168.10.1 255.255.255.0
interface Tunnel3 mode mpls-te
 mpls bfd
 destination 3.3.3.3
 ip route-static 192.168.20.0 24 Tunnel3 preference 1
·     Router B:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 2.2.2.2
mpls te
rsvp
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
·     Router C:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 3.3.3.3
mpls te
 nexthop index 1 23.23.23.2 include strict
 nexthop index 1 34.34.34.4 include strict
rsvp
 mpls bfd enable
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
 ip address 192.168.20.1 255.255.255.0
 mpls bfd
 destination 1.1.1.1
 ip route-static 192.168.10.0 24 Tunnel3 preference 1
·     Router D:
ospf 1
 area 0.0.0.0
  mpls te enable
 mpls lsr-id 4.4.4.4
mpls te
rsvp
interface LoopBack0
 mpls enable
 mpls te enable
 rsvp enable
 mpls enable
 mpls te enable
 rsvp enable
Related documentation
·     H3C SR8800-F Routers MPLS Configuration Guide
·     H3C SR8800-F Routers MPLS Command Reference
