Title | Size | Downloads |
V7-APR-1.0.173.dat | 2.70 MB |
Version number
V7-APR-1.0.173
MD5 number
b21c6d114d522561990d6fa706c908a4
Update time
2024-03-27
Update protocol list
Modified protocols: [1]
----dicom
Modified protocols: [2]
----RBC
----DaZhongWang
----Takungpao
----ChuanBeiOnline
----ChengDuShangBao
----ChinaByte
----EEPW
----PC84
----IRuiWang
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9595 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1555 predefined applications can be generated
