Title | Size | Downloads |
V7-IPS-1.0.285.dat | 14.01 MB |
Version number
V7-IPS-1.0.285
MD5 number
51980a8538f2096cb2dc3e504699aa62
Update time
2024-03-14
Update attack list
Key new rules:
51722 CVE-2024-2016_ZhiCms_setcontroller.php_index_code_Injection_Vulnerability[2]
---- Category: Vulnerability
---- Description: A vulnerability, which was classified as critical,
---- was found in ZhiCms 4.0. Affected is the function index of the file
---- app/manage/controller/setcontroller.php. The manipulation of
---- the argument sitename leads to code injection. It is possible to
---- launch the attack remotely. The exploit has been disclosed to
---- the public and may be used. VDB-255270 is the identifier assigned to this vulnerability.
51726 CVE-2024-2068_SourceCodester_Computer_Inventory_System_XSS_Vulnerability[2]
---- Description: A vulnerability was found in SourceCodester Computer Inventory
---- System 1.0. It has been rated as problematic. This issue affects some unknown processing of
---- the file /endpoint/update-computer.php. The manipulation of the argument model leads to
---- cross site scripting. The attack may be initiated remotely. The exploit has
---- been disclosed to the public and may be used. The associated identifier of
---- this vulnerability is VDB-255383.
51734 CVE-2024-2067_SourceCodester_Computer_Inventory_System_SQL_Injection_Vulnerability[2]
---- System 1.0. It has been declared as critical. This vulnerability affects unknown code of
---- the file /endpoint/delete-computer.php. The manipulation of the argument computer leads to
---- sql injection. The attack can be initiated remotely. The exploit has been disclosed to
---- the public and may be used. VDB-255382 is the identifier assigned to this vulnerability.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 21890 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3192 predefined rules can be generated in "Intrusion Prevention System"
