19-QoS Configuration Guide
HomeSupportWirelessWX3800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX3800X Series Access Controllers Configuration Guides(R1210P01)-6W10119-QoS Configuration Guide
01-QoS configuration
01-QoS configuration 321.80 KB
QoS overview·· 1
QoS service models· 1
Best-effort service model 1
IntServ model 1
DiffServ model 1
QoS techniques in a network· 1
QoS processing flow in a device· 2
QoS configuration approaches· 3
Configuring a QoS policy· 4
About QoS policies· 4
QoS policy tasks at a glance· 4
Defining a traffic class· 4
Defining a traffic behavior 4
Defining a QoS policy· 5
Applying the QoS policy· 5
Application destinations· 5
Restrictions and guidelines for applying a QoS policy· 5
Applying the QoS policy to an interface· 5
Applying the QoS policy to a user profile· 6
Setting the QoS policy-based traffic rate statistics collection period for an interface· 6
Verifying and maintaining QoS policies· 7
Verifying QoS policy configuration· 7
Configuring priority mapping· 8
About priority mapping· 8
About priorities· 8
Priority maps· 8
Priority mapping configuration methods· 9
Priority mapping process· 9
Priority mapping tasks at a glance· 11
Configuring a priority map· 11
Configuring a port to trust packet priority for priority mapping· 12
Changing the port priority of an interface· 12
Verifying and maintaining commands for priority mapping· 13
Configuring traffic policing· 14
About traffic policing· 14
Traffic evaluation and token buckets· 14
Traffic policing· 15
Configuring traffic policing· 16
Verifying and maintaining traffic policing and rate limit 17
Configuring traffic filtering· 18
About traffic filtering· 18
Restrictions and guidelines: Traffic filtering configuration· 18
Procedure· 18
Verifying and maintaining traffic filtering· 19
Configuring priority marking· 20
About priority marking· 20
Configuring priority marking by using the MQC approach· 20
Verifying and maintaining priority marking· 21
Appendixes· 22
Appendix A Acronyms· 22
Appendix B Default priority maps· 23
Appendix C Introduction to packet precedence· 24
IP precedence and DSCP values· 24
802.1p priority· 25
802.11e priority· 26
EXP values· 26
QoS overview
In data communications, Quality of Service (QoS) provides differentiated service guarantees for diversified traffic in terms of bandwidth, delay, jitter, and drop rate, all of which can affect QoS.
QoS manages network resources and prioritizes traffic to balance system resources.
The following section describes typical QoS service models and widely used QoS techniques.
QoS service models
This section describes several typical QoS service models.
The best-effort model is a single-service model. The best-effort model is not as reliable as other models and does not guarantee delay-free delivery.
The best-effort service model is the default model for the Internet and applies to most network applications. It uses the First In First Out (FIFO) queuing mechanism.
IntServ model
The integrated service (IntServ) model is a multiple-service model that can accommodate diverse QoS requirements. This service model provides the most granularly differentiated QoS by identifying and guaranteeing definite QoS for each data flow.
In the IntServ model, an application must request service from the network before it sends data. IntServ signals the service request with the RSVP. All nodes receiving the request reserve resources as requested and maintain state information for the application flow.
The IntServ model demands high storage and processing capabilities because it requires all nodes along the transmission path to maintain resource state information for each flow. This model is suitable for small-sized or edge networks. However, it is not suitable for large-sized networks, for example, the core layer of the Internet, where billions of flows are present.
DiffServ model
The differentiated service (DiffServ) model is a multiple-service model that can meet diverse QoS requirements. It is easy to implement and extend. DiffServ does not signal the network to reserve resources before sending data, as IntServ does.
The QoS techniques include the following features:
·     Traffic classification.
·     Traffic policing.
·     Traffic shaping.
·     Rate limit.
·     Congestion management.
·     Congestion avoidance.
The following section briefly introduces these QoS techniques.
All QoS techniques in this document are based on the DiffServ model.
Figure 1 Position of the QoS techniques in a network
As shown in Figure 1, traffic classification, traffic shaping, traffic policing, congestion management, and congestion avoidance mainly implement the following functions:
·     Traffic classification—Uses match criteria to assign packets with the same characteristics to a traffic class. Based on traffic classes, you can provide differentiated services.
·     Traffic policing—Polices flows and imposes penalties to prevent aggressive use of network resources. You can apply traffic policing to both incoming and outgoing traffic of a port.
·     Traffic shaping—Adapts the output rate of traffic to the network resources available on the downstream device to eliminate packet drops. Traffic shaping usually applies to the outgoing traffic of a port.
·     Congestion management—Provides a resource scheduling policy to determine the packet forwarding sequence when congestion occurs. Congestion management usually applies to the outgoing traffic of a port.
·     Congestion avoidance—Monitors the network resource usage. It is usually applied to the outgoing traffic of a port. When congestion worsens, congestion avoidance reduces the queue length by dropping packets.
Figure 2 briefly describes how the QoS module processes traffic.
1.     Traffic classifier identifies and classifies traffic for subsequent QoS actions.
2.     The QoS module takes various QoS actions on classified traffic as configured, depending on the traffic processing phase and network status. For example, you can configure the QoS module to perform the following operations:
¡     Traffic policing for incoming traffic.
¡     Traffic shaping for outgoing traffic.
¡     Congestion avoidance before congestion occurs.
¡     Congestion management when congestion occurs.
Figure 2 QoS processing flow
You can configure QoS by using the MQC approach or non-MQC approach.
In the modular QoS configuration (MQC) approach, you configure QoS service parameters by using QoS policies. A QoS policy defines QoS actions to take on different classes of traffic and can be applied to an object (such as an interface) to control traffic.
In the non-MQC approach, you configure QoS service parameters without using a QoS policy. For example, you can use the rate limit feature to set a rate limit on an interface without using a QoS policy.
Some features support both approaches, but some support only one.
About QoS policies
A QoS policy has the following components:
·     Traffic class—Defines criteria to match packets.
·     Traffic behavior—Defines QoS actions to take on matching packets.
By associating a traffic class with a traffic behavior, a QoS policy can perform the QoS actions on matching packets.
A QoS policy can have multiple class-behavior associations.
To configure a QoS policy, perform the following tasks:
1.     Defining a traffic class
2.     Defining a traffic behavior
3.     Defining a QoS policy
4.     Applying the QoS policy
¡     Applying the QoS policy to an interface
¡     Applying the QoS policy to a user profile
5.     (Optional.) Setting the QoS policy-based traffic rate statistics collection period for an interface
2.     Create a traffic class and enter traffic class view.
3.     (Optional.) Configure a description for the traffic class.
By default, no description is configured for a traffic class.
4.     Configure a match criterion.
if-match [ not ] match-criteria
By default, no match criterion is configured.
For more information, see the if-match command in ACL and QoS Command Reference.
2.     Create a traffic behavior and enter traffic behavior view.
3.     Configure an action in the traffic behavior.
By default, no action is configured for a traffic behavior.
For more information about configuring an action, see the subsequent chapters for traffic policing, traffic filtering, priority marking, class-based accounting, and so on.
2.     Create a QoS policy and enter QoS policy view.
qos policy policy-name
3.     Associate a traffic class with a traffic behavior to create a class-behavior association in the QoS policy.
classifier classifier-name behavior behavior-name [ insert-before before-classifier-name ]
By default, a traffic class is not associated with a traffic behavior.
Repeat this step to create more class-behavior associations.
You can apply a QoS policy to the following destinations:
·     Interface—The QoS policy can be applied to the traffic sent or received on the interface.
·     User profile—The QoS policy can be applied to the traffic sent or received by the online users of the user profile.
You can modify traffic classes, traffic behaviors, and class-behavior associations in a QoS policy even after it is applied (except that it is applied to a user profile). If a traffic class uses an ACL for traffic classification, you can delete or modify the ACL.
If an action in a traffic behavior cannot take effect, all other actions in the traffic behavior do not take effect.
A QoS policy can be applied to multiple interfaces. However, only one QoS policy can be applied to one direction (inbound or outbound) of an interface.
The QoS policy applied to the outgoing traffic on an interface does not regulate local packets. Local packets refer to critical protocol packets sent by the local system for operation maintenance. The most common local packets include link maintenance, RIP, LDP, and SSH packets.
2.     Enter interface view.
3.     Apply the QoS policy to the interface.
By default, no QoS policy is applied to an interface.
When a user profile is configured, you can perform traffic policing based on users. After a user passes authentication, the authentication server sends the name of the user profile associated with the user to the device. The QoS policy configured in user profile view takes effect only when users come online.
You can apply a QoS policy to multiple user profiles. In one direction of each user profile, only one policy can be applied. To modify a QoS policy already applied to a direction, first remove the applied QoS policy.
2.     Enter user profile view.
user-profile profile-name
3.     Apply the QoS policy to the user profile.
By default, no QoS policy is applied to a user profile.
Parameter
inbound
Applies a QoS policy to the traffic incoming traffic (traffic received by the device from online users).
outbound
Applies a QoS policy to the outgoing traffic (traffic sent by the device to online users).
You can enable collection of per-class traffic statistics over a period of time, including the average forwarding rate and drop rate. For example, if you set the statistics collection period to n minutes, the system performs the following operations:
·     Collects traffic statistics for the most recent n minutes.
·     Refreshes the statistics every n/5 minutes.
You can use the display qos policy interface command to view the collected traffic rate statistics.
A subinterface uses the statistics collection period configured on the main interface.
3.     Set the traffic rate statistics collection period for the interface.
qos flow-interval interval
The default setting is 5 minutes.
·     Display traffic class configuration.
display traffic classifier  user-defined [ classifier-name ]
·     Display traffic behavior configuration.
display traffic behavior  user-defined [ behavior-name ]
·     Display QoS policy configuration.
display qos policy user-defined [ policy-name [ classifier classifier-name ] ]
When a packet arrives, a device assigns a set of QoS priority parameters to the packet based on either of the following:
·     A priority field carried in the packet.
·     The port priority of the incoming port.
This process is called priority mapping. During this process, the device can modify the priority of the packet according to the priority mapping rules. The set of QoS priority parameters decides the scheduling priority and forwarding priority of the packet.
Priority mapping is implemented with priority maps and involves the following priorities:
·     802.11e priority.
·     802.1p priority.
·     DSCP.
·     EXP.
·     IP precedence.
·     Local precedence.
·     Drop priority.
About priorities
Priorities include the following types: priorities carried in packets, and priorities locally assigned for scheduling only.
Packet-carried priorities include 802.1p priority, DSCP precedence, IP precedence, and EXP. These priorities have global significance and affect the forwarding priority of packets across the network. For more information about these priorities, see "Appendix C Introduction to packet precedence."
Locally assigned priorities only have local significance. They are assigned by the device only for scheduling. These priorities include the local precedence, drop priority, and user priority, as follows:
·     Local precedence—Used for queuing. A local precedence value corresponds to an output queue. A packet with higher local precedence is assigned to a higher priority output queue to be preferentially scheduled.
·     Drop priority—Used for making packet drop decisions. Packets with the highest drop priority are dropped preferentially.
·     User priority—Precedence that the device automatically extracts from a priority field of the packet according to its forwarding path. It is a parameter for determining the scheduling priority and forwarding priority of the packet. The user priority represents the following items:
¡     The 802.1p priority for Layer 2 packets.
¡     The IP precedence for Layer 3 packets.
¡     The EXP for MPLS packets.
Priority maps
The device provides various types of priority maps. By looking through a priority map, the device decides which priority value to assign to a packet for subsequent packet processing.
The default priority maps (as shown in Appendix B Default priority maps) are available for priority mapping. They are adequate in most cases. If a default priority map cannot meet your requirements, you can modify the priority map as required.
You can configure priority mapping by using any of the following methods:
·     Configuring priority trust mode—In this method, you can configure a port to look up a trusted priority type (802.1p, for example) in incoming packets in the priority maps. Then, the system maps the trusted priority to the target priority types and values.
·     Changing port priority—If no packet priority is trusted, the port priority of the incoming port is used. By changing the port priority of a port, you change the priority of the incoming packets on the port.
·     Configuring a QoS policy containing the priority mapping (called primap) action with the primap command.
On receiving an Ethernet packet on a port, the switch marks the scheduling priorities (local precedence and drop precedence) for the Ethernet packet. This procedure is done according to the priority trust mode of the receiving port and the 802.1Q tagging status of the packet, as shown in Figure 3.
Figure 3 Priority mapping process for an Ethernet packet
The switch marks a received MPLS packet with a scheduling priority based on the priority trust mode and the packet EXP value, as shown in Figure 4.
Figure 4 Priority mapping process for an MPLS packet
For information about priority marking, see "Configuring priority marking."
To configure priority mapping, perform the following tasks:
1.     (Optional.) Configuring a priority map
2.     Configure a priority mapping method:
¡     Configuring a port to trust packet priority for priority mapping
¡     Changing the port priority of an interface
2.     Enter priority map view.
qos map-table { dot11e-lp | dot1p-dot1p | dscp-lp | lp-dot11e | lp-dot1p lp-dscp }
3.     Configure mappings for the priority map.
By default, the default priority maps are used. For more information, see "Appendix B Default priority maps."
You can configure the device to trust a particular priority field carried in packets for priority mapping on ports or globally. When you configure the trusted packet priority type on an interface, use the following available keywords:
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
3.     Configure the trusted packet priority type.
qos trust { dot1p | dscp }
By default, an interface does not trust any packet priority and uses the port priority as the 802.1p priority for mapping.
If an interface does not trust any packet priority, the device uses its port priority to look for priority parameters for the incoming packets. By changing port priority, you can prioritize traffic received on different interfaces.
3.     Set the port priority of the interface.
qos priority priority-value
The default setting is 0.
·     Display priority map configuration.
display qos map-table  [ dot11e-lp | dot1p-dot1p | dscp-lp | lp-dot11e | lp-dot1p | lp-dscp ]
·     Display the trusted packet priority type on a port.
Traffic limit helps assign network resources (including bandwidth) and increase network performance. For example, you can configure a flow to use only the resources committed to it in a certain time range. This avoids network congestion caused by burst traffic.
Traffic policing controls the traffic rate and resource usage according to traffic specifications. You can use token buckets for evaluating traffic specifications.
Token bucket features
A token bucket is analogous to a container that holds a certain number of tokens. Each token represents a certain forwarding capacity. The system puts tokens into the bucket at a constant rate. When the token bucket is full, the extra tokens cause the token bucket to overflow.
Evaluating traffic with the token bucket
A token bucket mechanism evaluates traffic by looking at the number of tokens in the bucket. If the number of tokens in the bucket is enough for forwarding the packets:
·     The traffic conforms to the specification (called conforming traffic).
·     The corresponding tokens are taken away from the bucket.
Otherwise, the traffic does not conform to the specification (called excess traffic).
A token bucket has the following configurable parameters:
·     Mean rate at which tokens are put into the bucket, which is the permitted average rate of traffic. It is usually set to the committed information rate (CIR).
·     Burst size or the capacity of the token bucket. It is the maximum traffic size permitted in each burst. It is usually set to the committed burst size (CBS). The set burst size must be greater than the maximum packet size.
Each arriving packet is evaluated.
Complicated evaluation
You can set two token buckets, bucket C and bucket E, to evaluate traffic in a more complicated environment and achieve more policing flexibility. The following are main mechanisms used for complicated evaluation:
·     Single rate two color—Uses one token bucket and the following parameters:
¡     CIR—Rate at which tokens are put into bucket C. It sets the average packet transmission or forwarding rate allowed by bucket C.
¡     CBS—Size of bucket C, which specifies the transient burst of traffic that bucket C can forward.
When a packet arrives, the following rules apply:
¡     If bucket C has enough tokens to forward the packet, the packet is colored green.
¡     Otherwise, the packet is colored red.
·     Single rate three color—Uses two token buckets and the following parameters:
¡     EBS—Size of bucket E minus size of bucket C, which specifies the transient burst of traffic that bucket E can forward. The EBS cannot be 0. The size of E bucket is the sum of the CBS and EBS.
¡     If bucket C has enough tokens, the packet is colored green.
¡     If bucket C does not have enough tokens but bucket E has enough tokens, the packet is colored yellow.
¡     If neither bucket C nor bucket E has sufficient tokens, the packet is colored red.
·     Two rate three color—Uses two token buckets and the following parameters:
¡     PIR—Rate at which tokens are put into bucket E, which specifies the average packet transmission or forwarding rate allowed by bucket E.
¡     EBS—Size of bucket E, which specifies the transient burst of traffic that bucket E can forward.
Traffic policing
A typical application of traffic policing is to supervise the specification of traffic entering a network and limit it within a reasonable range. Another application is to "discipline" the extra traffic to prevent aggressive use of network resources by an application. For example, you can limit bandwidth for HTTP packets to less than 50% of the total. If the traffic of a session exceeds the limit, traffic policing can drop the packets or reset the IP precedence of the packets. Figure 5 shows an example of policing outbound traffic on an interface.
Figure 5 Traffic policing
Traffic policing can classify the policed traffic and take predefined policing actions on each packet depending on the evaluation result:
·     Forwarding the packet.
·     Dropping the packet.
·     Forwarding the packet with its precedence re-marked.
·     Delivering the packet to next-level traffic policing with its precedence re-marked.
The device supports applying a traffic policing action to an interface.
2.     Define a traffic class.
a.     Create a traffic class and enter traffic class view.
b.     Configure a match criterion.
For more information about the if-match command, see ACL and QoS Command Reference.
c.     Return to system view.
3.     Define a traffic behavior.
a.     Create a traffic behavior and enter traffic behavior view.
b.     Configure a traffic policing action.
car cir committed-information-rate [ cbs committed-burst-size ] [ green action | red action ] *
By default, no traffic policing action is configured.
4.     Define a QoS policy.
a.     Create a QoS policy and enter QoS policy view.
b.     Associate the traffic class with the traffic behavior in the QoS policy.
5.     Apply the QoS policy.
For more information, see "Applying the QoS policy."
By default, no QoS policy is applied.
To verify MQC-based traffic policing configuration, execute the following command in any view:
You can filter in or filter out traffic of a class by associating the class with a traffic filtering action. For example, you can filter packets sourced from an IP address according to network status.
The device supports the following application destinations for traffic filtering:
·     Interface.
·     User profile.
For more information about configuring match criteria, see ACL and QoS Command Reference.
b.     Configure the traffic filtering action.
filter { deny | permit }
By default, no traffic filtering action is configured.
If a traffic behavior has the filter deny action, all other actions in the traffic behavior except class-based accounting do not take effect.
To verify traffic filtering configuration, execute the following command in any view:
Priority marking sets the priority fields or flag bits of packets to modify the priority of packets. For example, you can use priority marking to set IP precedence or DSCP for a class of IP packets to control the forwarding of these packets.
To configure priority marking to set the priority fields or flag bits for a class of packets, perform the following tasks:
1.     Configure a traffic behavior with a priority marking action.
2.     Associate the traffic class with the traffic behavior.
Priority marking can be used together with priority mapping. For more information, see "Configuring priority mapping." You can configure priority marking by using the MQC approach.
The device supports the following application destinations for priority marking:
·     Interface.
·     User profile.
b.     Configure a priority marking action.
For configurable priority marking actions, see the remark commands in ACL and QoS Command Reference.
To verify priority marking configuration, execute the following command in any view:
Appendixes
Appendix A Acronyms
Table 1 Appendix A Acronyms
Acronym
Full spelling
AF
Assured Forwarding
BE
Best Effort
BQ
Bandwidth Queuing
CAR
Committed Access Rate
CBS
Committed Burst Size
CBQ
Class Based Queuing
CE
Congestion Experienced
CIR
Committed Information Rate
CQ
Custom Queuing
DCBX
Data Center Bridging Exchange Protocol
DiffServ
Differentiated Service
DSCP
Differentiated Services Code Point
EBS
Excess Burst Size
ECN
Explicit Congestion Notification
EF
Expedited Forwarding
FIFO
First in First out
FQ
Fair Queuing
GMB
Guaranteed Minimum Bandwidth
GTS
Generic Traffic Shaping
IntServ
Integrated Service
ISP
Internet Service Provider
LLQ
Low Latency Queuing
LSP
Label Switched Path
MPLS
Multiprotocol Label Switching
PE
Provider Edge
PIR
Peak Information Rate
PQ
Priority Queuing
PW
Pseudowire
QoS
Quality of Service
QPPB
QoS Policy Propagation Through the Border Gateway Protocol
RED
Random Early Detection
RSVP
Resource Reservation Protocol
RTP
Real-Time Transport Protocol
SP
Strict Priority
ToS
Type of Service
VoIP
Voice over IP
VPN
Virtual Private Network
WFQ
Weighted Fair Queuing
WRED
Weighted Random Early Detection
WRR
Weighted Round Robin
For the default dot1p-dot1p priority map, an input value yields a target value equal to it.
Table 2 Default dot11e-lp priority map
dot11e
lp
0
2
1
0
2
1
3
3
4
4
5
5
6
6
7
7
Table 3 Default dscp-lp priority map
Input priority value
dscp-lp map
dscp
lp
0 to 7
0
8 to 15
1
16 to 23
2
24 to 31
3
32 to 39
4
40 to 47
5
48 to 55
6
56 to 63
7
Table 4 Default lp-dot1p, lp-dot11e, and lp-dscp priority maps
lp-dot1p map
lp-dot11e map
lp-dscp map
lp
dot1p
dot11e
DSCP
0
1
1
0
1
2
2
8
2
0
0
16
3
3
3
24
4
4
4
32
5
5
5
40
6
6
6
48
7
7
7
56
Figure 6 ToS and DS fields
As shown in Figure 6, the ToS field in the IP header contains 8 bits. The first 3 bits (0 to 2) represent IP precedence from 0 to 7. According to RFC 2474, the ToS field is redefined as the differentiated services (DS) field. A DSCP value is represented by the first 6 bits (0 to 5) of the DS field and is in the range 0 to 63. The remaining 2 bits (6 and 7) are reserved.
Table 5 IP precedence
IP precedence (decimal)
IP precedence (binary)
0
000
Routine
1
001
priority
2
010
immediate
3
011
flash
4
100
flash-override
5
101
critical
6
110
internet
7
111
network
Table 6 DSCP values
DSCP value (decimal)
DSCP value (binary)
46
101110
ef
10
001010
af11
12
001100
af12
14
001110
af13
18
010010
af21
20
010100
af22
22
010110
af23
26
011010
af31
28
011100
af32
30
011110
af33
34
100010
af41
36
100100
af42
38
100110
af43
8
001000
cs1
16
010000
cs2
24
011000
cs3
32
100000
cs4
40
101000
cs5
48
110000
cs6
56
111000
cs7
0
000000
be (default)
802.1p priority
802.1p priority lies in the Layer 2 header. It applies to occasions where Layer 3 header analysis is not needed and QoS must be assured at Layer 2.
Figure 7 An Ethernet frame with an 802.1Q tag header
As shown in Figure 7, the 4-byte 802.1Q tag header contains the 2-byte tag protocol identifier (TPID) and the 2-byte tag control information (TCI). The value of the TPID is 0x8100. Figure 8 shows the format of the 802.1Q tag header. The Priority field in the 802.1Q tag header is called 802.1p priority, because its use is defined in IEEE 802.1p. Table 7 shows the values for 802.1p priority.
Figure 8 802.1Q tag header
Table 7 Description on 802.1p priority
802.1p priority (decimal)
802.1p priority (binary)
0
000
best-effort
1
001
background
2
010
spare
3
011
excellent-effort
4
100
controlled-load
5
101
video
6
110
voice
7
111
network-management
802.11e priority
To provide QoS services on WLAN, the 802.11e standard was developed. IEEE 802.11e is a MAC-layer enhancement to IEEE 802.11. IEEE 802.11e adds a 2-byte QoS control field to the 802.11e MAC frame header. The 3-bit QoS control field represents the 802.11e priority in the range of 0 to 7.
Figure 9 802.11e frame structure
EXP values
The EXP field is in MPLS labels for MPLS QoS purposes. As shown in Figure 10, the EXP field is 3-bit long and is in the range of 0 to 7.
Figure 10 MPLS label structure
