Title | Size | Downloads |
V7-APR-1.0.171.dat | 2.70 MB |
Version number
V7-APR-1.0.171
MD5 number
aec35b976d5392d84efe4c87d073f96e
Update time
2024-02-27
Update protocol list
Modified protocols: [1]
----MyFitnessPal
----AiZhan
Modified protocols: [2]
----ITEYE
----ItpubJiShuLunTan
----JQueryEasyUI
----BaiDaJob
----PiKaCN
----XiangYinWang
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9595 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1555 predefined applications can be generated
