Title | Size | Downloads |
V7-APR-1.0.170.dat | 2.70 MB |
Version number
V7-APR-1.0.170
MD5 number
fa348025002c3e85e0440540d289eb8d
Update time
2024-01-26
New protocol list
Modified protocols: [1]
----mongodb-protocol
----postgresql-protocol
----mysql-protocol
Update protocol list
----ibm-db2
----ms-sql-s
----sqlnet
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the APR feature library file of this version, 9595 predefined applications can be generated
[4] The device memory is less than or equal to 2GB. After loading the APR feature library file of this version, 1555 predefined applications can be generated
