11-Security Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R1340-6W10011-Security Command Reference
04-User profile commands
04-User profile commands 55.47 KB
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
In standalone mode:
display user-profile [ session-group ] [ name profile-name ]
In IRF mode:
display user-profile [ session-group ] [ name profile-name ] [ slot slot-number ]
session-group: Specifies a session group profile.
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user profile configuration and online user information for all member devices. (In IRF mode.)
# Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
  User-Profile: aaa
    Inbound:
      Committed Access Rate:
        Rule: If-match any
          CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
        Rule: If-match acl 2000
          CIR 3000 (kbps), CBS 187500 (Bytes), EBS 0 (Bytes)
      Policy: p1
    Outbound:
        Rule: If-match acl 3000
          CIR 1000 (kbps), CBS 62500 (Bytes), EBS 0 (Bytes)
        Rule: If-match any
    Overhead compensation length: 18
    User user_1:
      Authentication type: Portal
      Network attributes:
        Interface    : GigabitEthernet1/0
        MAC address  : 0000-1111-2222
      Failed action list:
        Inbound: Policy p1
        Inbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
# Display configuration and online user information for all session group profiles.
<Sysname> display user-profile session-group
  Session-Group-Profile: aaa
    Outbound:
    QMProfile: a
    User user_1:
      Network attributes:
      Failed action list:
        Outbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
        QMProfile: a
    User user_2:
      Network attributes:
        Interface    : GigabitEthernet3/0
        IP address   : 172.16.187.16
        VPN          : N/A
        Service VLAN : 100
  Session-Group-Profile: bbb
    Outbound:
      CIR 512 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
    QMProfile: a
    User user_4:
      Network attributes:
        Interface    : GigabitEthernet2/0
        IP address   : 172.16.187.166
        VPN          : N/A
        Service VLAN : 100
User-Profile
User profile name.
Inbound
Policy applied to incoming traffic.
Outbound
Policy applied to outgoing traffic.
Session group profile name.
CIR
Committed information rate, in kbps.
CBS
Committed burst size, in bytes.
EBS
Excess burst size, in bytes.
PIR
Peak information rate, in kbps.
Policy
Policy name.
QMProfile
Queue scheduling profile.
User user_1
Username of a user account with which a user profile or session group profile is associated.
Authentication type
·     802.1X—802.1X authentication.
·     Portal—Portal authentication.
·     PPP—PPP authentication.
·     MACA—MAC authentication.
Network attributes
Online user information.
Failed action list
Actions that failed to be applied to the user.
Packet compensation length in bytes for outbound traffic policing.
Rule
Match criteria.
qos session-group identify
Use qos session-group identify to identify a session group on an interface.
Use undo qos session-group identify to restore the default.
qos session-group identify { customer-vlan | service-vlan | customer-service-vlan | subscriber-id }
No session group is identified on the interface.
Interface view
customer-vlan: Identifies a session group by CVLAN. A CVLAN is used by a customer on the private network.
service-vlan: Identifies a session group by SVLAN. An SVLAN is used by a service provider to transmit VLAN tagged traffic for customers.
customer-service-vlan: Identifies a session group by CVLAN and SVLAN.
subscriber-id: Identifies a session group by subscriber ID.
To configure a session group profile, you must first use the command.
# Configure GigabitEthernet 1/0 to identify a session group by an SVLAN.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] qos session-group identify service-vlan
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name [ type session-group ]
undo user-profile profile-name
No user profiles exist.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters (a-z, A-Z), digits (0-9), and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique.
type session-group: Specifies a session group profile.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123]
# Create session group profile a123 and enter the view of a123.
[Sysname] user-profile a123 type session-group
[Sysname-session-group-profile-a123]
