08-IP Multicast Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R1340-6W10008-IP Multicast Command Reference
07-MLD commands
07-MLD commands 228.70 KB
MLD commands
display mld group
Use display mld group to display information about MLD multicast groups (IPv6 multicast groups that hosts have joined through MLD).
display mld [ vpn-instance vpn-instance-name ] group [ ipv6-group-address | interface interface-type interface-number ] [ static | verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about MLD multicast groups on the public network.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays information about all MLD multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about MLD multicast groups for all interfaces.
static: Specifies MLD multicast groups that hosts have joined statically. If you do not specify this keyword, the command displays information about MLD multicast groups that hosts have joined dynamically.
verbose: Displays detailed information about MLD multicast groups.
# Display information about MLD multicast groups that hosts have dynamically joined on the public network.
<Sysname> display mld group
MLD groups in total: 1
 GigabitEthernet1/0(FE80::101):
  MLD groups reported in total: 1
   Group address: FF03::101
    Last reporter: FE80::10
    Uptime: 00:02:04
    Expires: 00:01:15
MLD groups in total
Total number of MLD multicast groups.
Total number of MLD multicast groups that the hosts attached to the interface have joined dynamically.
Group address
Last reporter
IPv6 address of the receiver host that last reported membership for the group.
Uptime
Length of time since the IPv6 multicast group was joined.
Expires
Remaining lifetime for the IPv6 multicast group. This field displays Off if the timer is disabled.
# Display detailed information about MLD multicast group FF3E::101 that hosts have statically joined on the public network. In this example, the router is configured with MLD SSM mappings.
<Sysname> display mld group ff3e::101 verbose
   Group: FF3E::101
     Uptime: 00:01:46
     Exclude expires: 00:04:16
     Mapping expires: 00:02:16
     Last-listener-query-counter: 0
     Last-listener-query-timer-expiry: Off
     Mapping last-listener-query-counter: 0
     Mapping last-listener-query-timer-expiry: Off
     Group mode: Exclude
     Version1-host-present-timer-expiry: Off
     Source list (sources in total: 1):
       Source: 10::10
          Uptime: 00:00:09
          V2 expires: 00:04:11
Group
Uptime
Length of time since the IPv6 multicast group was reported.
Exclude expires
Remaining time for the IPv6 multicast group in Exclude mode. This field displays Off if the timer is disabled.
Mapping expires
Remaining time for the IPv6 multicast group specified in MLD SSM mappings.
This field is displayed only when the device is configured with MLD SSM mappings.
Last reporter
IPv6 address of the receiver host that last reported membership for this group.
Number of MLD multicast-address-specific queries or MLD multicast-address-and-source-specific queries sent for the group.
Remaining time for the MLD last listener query timer for the multicast group. This field displays Off if the timer is disabled.
Number of MLD multicast-address-specific queries or MLD multicast-address-and-source-specific queries sent for the IPv6 multicast group specified in MLD SSM mappings.
Remaining time for the last listener query timer of the IPv6 multicast group specified in MLD SSM mappings.
Group mode
IPv6 multicast source filtering mode:
·     Include—Include mode.
·     Exclude—Exclude mode.
For a device that runs MLDv1:
·     If MLD SSM mappings are not configured, this field displays Exclude.
·     If MLD SSM mappings are configured, this field displays Include or Exclude depending on the SSM mappings and the IPv6 multicast groups that the host joins.
Remaining time for the MLDv1 host present timer.
This field is displayed only when the device runs MLDv2.
Source list (sources in total 1)
List of IPv6 multicast sources and total number of IPv6 multicast sources.
This field is displayed only when the device runs MLDv2 or is configured with MLD SSM mappings.
Source
IPv6 multicast source address.
This field is displayed only when the device runs MLDv2 or the device is configured with MLD SSM mappings.
Uptime
Length of time since the IPv6 multicast source was reported.
V2 expires
Remaining time for the IPv6 multicast source when the device runs MLDv2.
This field displays three hyphens (---) if the IPv6 multicast source is specified in MLD SSM mappings.
Mapping expires
Remaining time for the IPv6 multicast sources specified in MLD SSM mappings.
Number of MLD multicast-address-specific queries or MLD multicast-address-and-source-specific queries sent for the IPv6 multicast source and group.
Remaining time for the last listener query timer for the IPv6 multicast source and group.
# Display information about the MLD multicast groups that hosts have statically joined on the public network.
<Sysname> display mld group static
 Entries in total: 2
  (*, FF03::101)
   Interface: GE1/0
   Expires: Never
  (2001::101, FF3E::202)
   Interface: GE1/0
   Expires: Never
Entries in total
Total number of the IPv6 multicast groups that hosts have joined statically.
(*, FF03::101)
(*, G) entry.
(S, G) entry.
Expires
This field always displays Never, which means that the IPv6 multicast group never expires.
reset mld group
display mld interface
Use display mld interface to display MLD information for interfaces.
display mld [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ proxy ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays MLD information for interfaces on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays MLD information for all interfaces.
proxy: Displays the MLD proxy interface information. If you do not specify this keyword, the command displays MLD information for all interfaces.
verbose: Displays detailed MLD information.
# Display detailed MLD information for GigabitEthernet 1/0 (non-proxy interface) on the public network.
<Sysname> display mld interface gigabitethernet 1/0 verbose
 GigabitEthernet1/0(FE80::200:AFF:FE01:101):
   MLD is enabled.
   MLD version: 1
   Query interval for MLD: 125s
   Other querier present time for MLD: 255s
   Maximum query response time for MLD: 10s
   Last listener query interval: 1s
   Last listener query count: 2
   Startup query interval: 31s
   Startup query count: 2
   General query timer expiry (hh:mm:ss): 00:00:23
   Querier for MLD: FE80::200:AFF:FE01:101 (This router)
   MLD activity: 1 join(s), 0 done(s)
   IPv6 multicast routing on this interface: Enabled
   Robustness: 2
   Require-router-alert: Disabled
   Fast-leave: Disabled
   Startup-query: Off
   Other-querier-present-timer-expiry (hh:mm:ss): Off
   Authorization: Disabled
   Join-by-session: Disabled
   User-VLAN-aggregation: Disabled
# Display detailed MLD information for all MLD proxy interfaces on the public network.
<Sysname> display mld interface proxy verbose
 GigabitEthernet2/0(FE80::100:CEF:FE01:101):
   MLD proxy is enabled.
   MLD version: 1
   Version1-querier-present-timer-expiry (hh:mm:ss): Off
Interface and its IPv6 link-local address.
MLD is enabled
MLD is enabled on the interface.
MLD version
Version of MLD that the interface runs.
MLD query interval, in seconds.
MLD other querier present interval, in seconds.
Maximum response time for MLD general query messages, in seconds.
Interval for sending MLD multicast-address-specific queries or MLD multicast-address-and-source-specific queries, in seconds.
MLD startup query interval, in seconds.
Startup query count
Number of MLD general queries sent on startup.
Remaining time for the MLD general query timer. This field displays Off if the timer is disabled.
Querier for MLD
IPv6 link-local address of the MLD querier.
MLD activity statistics:
·     join(s)—Total number of IPv6 multicast groups that the interface has joined.
·     done(s)—Total number of IPv6 multicast groups that the interface has left.
Whether IPv6 multicast routing is enabled: Enabled or Disabled.
Robustness
Robustness variable of the MLD querier.
Whether the feature of dropping MLD messages without Router-Alert is enabled: Enabled or Disabled.
Fast-leave
Whether fast-leave processing is enabled: Enabled or Disabled.
Startup-query
Whether the MLD querier sends MLD general queries at the startup query interval on startup:
·     OnThe MLD querier performs the above action.
·     OffThe MLD querier does not perform the above action.
Remaining time for MLD other querier present timer. This field displays Off if the timer is disabled.
Authorization
Whether the IPv6 multicast access control feature is enabled: Enabled or Disabled.
Join-by-session
Whether the per-session IPv6 multicast forwarding feature is enabled: Enabled or Disabled.
Whether the IPv6 multicast packet VLAN tagging feature is enabled: Enabled or Disabled.
Total number of IPv6 multicast groups that the interface has joined dynamically.
This field is not displayed if the interface does not join IPv6 multicast groups.
MLD proxying is enabled.
Remaining time for the MLDv1 querier present timer. This field displays Off if the timer is disabled.
display mld proxy group
Use display mld proxy group to display information about IPv6 multicast groups maintained by the MLD proxy.
display mld [ vpn-instance vpn-instance-name ] proxy group [ ipv6-group-address | interface interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about IPv6 multicast groups maintained by the MLD proxy on the public network.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays IPv6 multicast group membership entries for all IPv6 multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IPv6 multicast groups maintained by the MLD proxy for all interfaces.
verbose: Displays detailed information.
# Display information about IPv6 multicast groups maintained by the MLD proxy on the public network.
<Sysname> display mld proxy group
MLD proxy group records in total: 2
 GigabitEthernet1/0(FE80::16:1):
   Group address: FF1E::1
    Member state: Idle
    Expires: Off
   Group address: FF1E::2
    Member state: Idle
    Expires: Off
# Display detailed information about IPv6 multicast group FF1E::1 maintained by the MLD proxy on the public network.
<Sysname> display mld proxy group ff1e::1 verbose
   Group: FF1E::1
     Group mode: Include
     Member state: Idle
     Expires: Off
       100::1
Table 5 Command output
Total number of IPv6 multicast group membership entries maintained by the MLD proxy.
Interface and its IPv6 address.
Pending proxy group
Pending IPv6 multicast group membership entries maintained by the MLD proxy.
Group address/Group
Member state
Member host states:
·     Delay—The member host has joined a group and started a delay timer.
·     Idle—The member host has joined a group, but didn't start a delay timer.
Expires
Remaining delay time for a member host to send a responding report. This field displays Off if the timer is disabled.
Group mode
·     Include.
·     Exclude.
List of IPv6 multicast sources in the group membership database maintained by the MLD proxy, and the total number of the IPv6 multicast sources.
display mld proxy routing-table
Use display mld proxy routing-table to display IPv6 multicast routing entries maintained by the MLD proxy.
display mld [ vpn-instance vpn-instance-name ] proxy routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] ] * [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast routing entries maintained by the MLD proxy on the public network.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays IPv6 multicast routing entries maintained by the MLD proxy for all IPv6 multicast sources.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays IPv6 multicast routing entries for all IPv6 multicast groups maintained by the MLD proxy.
prefix-length: Specifies an address prefix length. For an IPv6 multicast source address, the value range for this argument is 0 to 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. The default value is 128.
verbose: Displays detailed information about IPv6 multicast routing entries maintained by the MLD proxy.
# Display IPv6 multicast routing entries maintained by the MLD proxy on the public network.
<Sysname> display mld proxy routing-table
 Total 1 (*, G) entries, 2 (S, G) entries.
 (100::1, FF1E::1)
     Upstream interface: GigabitEthernet1/0
     Downstream interfaces (1 in total):
         1: GigabitEthernet2/0
             Protocol: MLD
 (*, FF1E::2)
             Protocol: STATIC
 (2::2, FF1E::2)
     Downstream interfaces (2 in total):
         1: LoopBack1
             Protocol: STATIC
         2: GigabitEthernet2/0
             Protocol: PROXY
# Display detailed information about IPv6 multicast routing entries maintained by the MLD proxy on the public network.
<Sysname> display mld proxy routing-table verbose
 (100::1, FF1E::1)
             Protocol: MLD
             Querier state: Querier
             Join/Prune state: Join
     Non-downstream interfaces: None
 (*, FF1E::2)
             Protocol: STATIC
     Non-downstream interfaces (1 in total):
         1: GigabitEthernet3/0
             Protocol: MLD
             Querier state: Non-querier
 (2::2, FF1E::2)
         1: LoopBack1
             Protocol: STATIC
             Protocol: PROXY
Table 6 Command output
Total number of (*, G ), and the total number of (S, G) entries.
(100::1, FF1E::1)
(S, G) entry.
Upstream interface
Incoming interface of a forwarding entry.
Outgoing interfaces, and the total number of outgoing interfaces.
Non-outgoing interfaces, and the total number of non-outgoing interfaces.
Index of an outgoing interface and the outgoing interface.
Protocol
Protocol type:
·     MLD—Dynamic MLD.
·     PROXY—MLD proxy.
·     STATIC—Static MLD.
Querier state
Querier state:
·     Querier.
·     Non-querier.
Join/Prune state
Joined or pruned state of the interface:
·     NI—Default state.
·     Join—Joined state.
·     Prune—Pruned state.
display mld ssm-mapping
Use display mld ssm-mapping to display MLD SSM mappings.
display mld [ vpn-instance vpn-instance-name ] ssm-mapping ipv6-group-address
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays MLD SSM mappings on the public network.
# Display MLD SSM mappings for IPv6 multicast group FF3E::101 on the public network.
<Sysname> display mld ssm-mapping ff3e::101
 Group: FF3E::101
 Source list:
        1::1
        1::2
        10::1
        100::10
Table 7 Command output
Group
Source list
List of IPv6 multicast source addresses.
display mld user-authorization
Use display mld user-authorization to display information about authorized MLD users.
display mld user-authorization [ interface interface-type interface-number ]
interface-type interface-number: Specifies an interface by its interface type and number. If you do not specify an interface, this command displays information about authorized MLD users on all interfaces.
# Display information about all authorized MLD users.
<Sysname> display mld user-authorization
 Authorized users in total: 3
   User name: user1@isp1
   Access type: PPP
   Interface: Virtual-Access0
   Access interface: Virtual-Access0
   Maximum programs for order: 10
   User profile: profile1
   Authorized programs list:
     FF03::101
   User name: user2
   Access type: Portal
   Interface: Multicast-UA0
   Access interface: GigabitEthernet1/0.1
   VLAN ID: 100
   Second VLAN ID: 10
     FF03::101
     FF03::102
     FF03::103
   User name: user3
   Access type: Portal
   Interface: Multicast-UA1
   Access interface: GigabitEthernet2/0
     FF03::101
     FF03::103
Table 8  Command output
Total number of access users.
Access type
Access type:
·     Portal.
·     PPP.
User interface.
Access interface
Interface through which the user accesses the BRAS.
VLAN ID
Outer VLAN ID (or the unique VLAN ID) for the user.
Second VLAN ID
Inner VLAN ID for the user.
Maximum number of the IPv6 multicast groups that the user can join.
User profile
User profile name of the authorized user.
The user can join IPv6 multicast groups permitted by the MLD user access control policy in the user profile. You can use the mld access-policy command to configure an MLD user access control policy.
List of the IPv6 multicast groups that the user is authorized to join.
last-listener-query-count (MLD view)
Use last-listener-query-count to set the MLD last listener query count globally.
Use undo last-listener-query-count to restore the default.
mld last-member-query-count count
undo mld last-member-query-count
The MLD last listener query count equals the MLD querier's robustness variable.
MLD view
count: Specifies an MLD last listener query count in the range of 1 to 255.
You can set the MLD last listener query count globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global MLD last listener query count to 6 on the public network.
[Sysname] mld
[Sysname-mld] last-listener-query-count 6
mld last-listener-query-count
last-listener-query-interval (MLD view)
Use last-listener-query-interval to set the MLD last listener query interval globally.
Use undo last-listener-query-interval to restore the default.
The MLD last listener query interval is 1 second.
MLD view
interval: Specifies an MLD last listener query interval in the range of 1 to 25 seconds.
You can set the MLD last listener query interval globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global MLD last listener query interval to 6 seconds on the public network.
[Sysname] mld
[Sysname-mld] last-listener-query-interval 6
mld last-listener-query-interval
max-response-time (MLD view)
Use max-response-time to set the maximum response time for MLD general queries globally.
Use undo max-response-time to restore the default.
max-response-time time
The maximum response time for MLD general queries is 10 seconds.
MLD view
time: Specifies the maximum response time for MLD general queries in the range of 1 to 3174 seconds.
You can set the maximum response time globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global maximum response time for MLD general queries to 25 seconds on the public network.
[Sysname] mld
[Sysname-mld] max-response-time 25
mld max-response-time
mld
Use mld to enter MLD view.
Use undo mld to delete the configurations in MLD view.
undo mld [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command takes effect on the public network.
# Enter MLD view of the public network.
[Sysname] mld
[Sysname-mld]
# Enter MLD view of VPN instance mvpn.
[Sysname] mld vpn-instance mvpn
[Sysname-mld-mvpn]
mld access-policy
Use mld access-policy to configure an MLD user access policy.
Use undo mld access-policy to delete an MLD user access policy.
mld access-policy ipv6-acl-number
undo mld access-policy ipv6-acl-number
No MLD user access policies exist. MLD users are not authorized to join any IPv6 multicast groups.
User profile view
ipv6-acl-number: Specifies an IPv6 basic or advanced ACL number, in the range of 2000 to 3999. MLD users can join only IPv6 multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, MLD users cannot join IPv6 multicast groups.
You can configure multiple MLD user access policies by using this command multiple times. An MLD report is permitted if it matches one of the access policies.
When you configure a rule in the IPv6 ACL, follow these restrictions and guidelines:
·     For the rule to take effect, do not specify the vpn-instance vpn-instance option.
·     In a basic ACL, the source source-address source-prefix option specifies an IPv6 multicast source address.
·     In an advanced ACL, the source source-address source-prefix option specifies an IPv6 multicast source address. The destination dest-address dest-prefix option specifies an IPv6 multicast group address.
Set the source source-address source-prefix option to 0::0 to match the following MLD reports:
¡     MLDv1 reports.
¡     MLDv2 IS_EX and MLDv2 TO_EX reports that do not carry multicast source addresses.
·     Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure an MLD user access policy in user profile abc to authorize MLD users to join IPv6 multicast group FF03::101.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source ff03::101 128
[Sysname] user-profile abc
[Sysname-user-profile-abc] mld access-policy 2000
mld authorization-enable
Use mld authorization-enable to enable the IPv6 multicast access control feature.
Use undo mld authorization-enable to disable the IPv6 multicast access control feature.
The IPv6 multicast access control feature is disabled.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
VT interface view
This command takes effect only on local online users. Non-local users and offline users are not affected.
# Enable the IPv6 multicast access control feature on GigabitEthernet 1/0.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] mld authorization-enable
mld enable
Use mld enable to enable MLD on an interface.
Use undo mld enable to disable MLD on an interface.
mld enable
undo mld enable
MLD is disabled on an interface.
Interface view
This command takes effect only when IPv6 multicast routing is enabled on the public network or for the VPN instance to which the interface belongs.
Other MLD configurations on the interface take effect only when MLD is enabled on the interface.
# Enable IPv6 multicast routing on the public network, and enable MLD for GigabitEthernet 1/0.
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname-GigabitEthernet1/0] mld enable
mld fast-leave
Use mld fast-leave to enable fast-leave processing on an interface.
Use undo mld fast-leave to disable fast-leave processing on an interface.
mld fast-leave [ group-policy ipv6-acl-number ]
undo mld fast-leave
Fast-leave processing is disabled. The MLD querier sends MLD multicast-address-specific or multicast-address-and-source-specific queries after receiving a done message.
Interface view
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the fast-leave processing feature takes effect only on the IPv6 multicast groups that the ACL permits. The feature takes effect on all IPv6 multicast groups when one of the following conditions exists:
·     You do not specify an ACL.
·     The specified ACL does not exist.
·     The specified ACL does not have valid rules.
The fast-leave processing feature enables an MLD querier to suppress MLD multicast-address-specific or multicast-address-and-source-specific queries upon receiving MLD done messages permitted by the ACL.
When you configure a rule in the IPv6 basic ACL, follow these restrictions and guidelines:
·     The source source-address source-prefix option specifies an IPv6 multicast group address.
# Enable fast-leave processing on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld fast-leave
mld group-policy
Use mld group-policy to configure an IPv6 multicast group policy on an interface to control the IPv6 multicast groups that hosts attached to the interface can join.
Use undo mld group-policy to delete the IPv6 multicast group policy on an interface.
mld group-policy ipv6-acl-number [ version-number ]
No IPv6 multicast group policy exists. Hosts attached to the interface can join any IPv6 multicast groups.
Interface view
ipv6-acl-number: Specifies an IPv6 basic or advanced ACL by its number in the range of 2000 to 3999. Receiver hosts can join only the IPv6 multicast groups that the ACL permits. If the ACL does not exist or have valid rules, receiver hosts cannot join IPv6 multicast groups.
version-number: Specifies an MLD version number, 1 or 2. By default, this command takes effect on both MLDv1 reports and MLDv2 reports.
An IPv6 multicast group policy filters MLD reports to control the IPv6 multicast groups that hosts can join.
This command does not take effect on static member interfaces because static member interfaces do not send MLD reports.
·     In a basic ACL, the source source-address source-prefix option specifies an IPv6 multicast group address.
To match the following MLD reports, set the source source-address source-prefix option to 0::0:
¡     MLDv1 reports.
# Configure an IPv6 multicast group policy on GigabitEthernet 1/0 so that hosts attached to the interface can join only IPv6 multicast group FF03::101.
[Sysname] acl ipv6 basic 2005
[Sysname-acl-ipv6-basic-2005] rule permit source ff03::101 128
[Sysname-acl-ipv6-basic-2005] quit
[Sysname-GigabitEthernet1/0] mld group-policy 2005
mld join-by-session
Use mld join-by-session to enable per-session IPv6 multicast forwarding.
Use undo mld join-by-session to restore the default.
mld join-by-session
IPv6 multicast data is forwarded on a per-interface basis.
This feature enables an interface to send a separate copy of IPv6 multicast data to each user attached to the interface.
The mld join-by-session and mld user-vlan-aggregation dot1q commands are mutually exclusive. You cannot configure them on the same device.
# Enable per-session IPv6 multicast forwarding on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld join-by-session
Use mld last-listener-query-count to set the MLD last member query count on an interface.
Use undo mld last-listener-query-count to restore the default.
mld last-listener-query-count count
Interface view
You can set the MLD last listener query count for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the MLD last listener query count to 6 on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld last-listener-query-count 6
Use mld last-listener-query-interval to set the MLD last listener query interval on an interface.
Use undo mld last-listener-query-interval to restore the default.
mld last-listener-query-interval interval
Interface view
You can set the MLD last listener query interval for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the MLD last listener query interval to 6 seconds on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld last-listener-query-interval 6
Use mld max-response-time to set the maximum response time for MLD general queries on an interface.
Use undo mld max-response-time to restore the default.
mld max-response-time time
Interface view
time: Specifies the maximum response time for MLD general queries, in the range of 1 to 3174 seconds.
You can set the maximum response time for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the maximum response time for MLD general queries to 25 seconds on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld max-response-time 25
mld non-stop-routing
Use mld non-stop-routing to enable MLD NSR.
Use undo mld non-stop-routing to disable MLD NSR.
MLD NSR is disabled.
# Enable MLD NSR.
[Sysname] mld non-stop-routing
mld other-querier-present-timeout
Use mld other-querier-present-timeout to set the MLD other querier present timer on an interface.
Use undo mld other-querier-present-timeout to restore the default.
mld other-querier-present-timeout time
The MLD other querier present timer is calculated by using the following formula:
[ MLD general query interval ] × [ MLD querier's robustness variable ] + [ maximum response time for MLD general queries ] / 2.
Interface view
time: Specifies an MLD other querier present timer in the range of 1 to 31744 seconds.
You can set the MLD other querier present timer for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the MLD other querier present timer to 125 seconds on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld other-querier-present-timeout 125
other-querier-present-timeout (MLD view)
mld proxy enable
Use mld proxy enable to enable MLD proxying on an interface.
Use undo mld proxy enable to disable MLD proxying on an interface.
mld proxy enable
MLD proxying is disabled on an interface.
Interface view
# Enable IPv6 multicast routing on the public network, and enable MLD proxying on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld proxy enable
mld proxy forwarding
Use mld proxy forwarding to enable IPv6 multicast forwarding on a non-querier interface.
Use undo mld proxy forwarding to disable IPv6 multicast forwarding on a non-querier interface.
IPv6 multicast forwarding is disabled for a non-querier interface.
Interface view
Typically, only MLD queriers can forward IPv6 multicast traffic and non-queriers cannot. This prevents IPv6 multicast data from being repeatedly forwarded. If a router interface on the MLD proxy device failed the querier election, enable multicast forwarding capability on this interface to forward multicast data to attached receivers.
# Enable IPv6 multicast forwarding on GigabitEthernet 1/0 (non-querier interface).
[Sysname-GigabitEthernet1/0] mld proxy forwarding
mld query-interval
Use mld query-interval to set the MLD general query interval on an interface.
Use undo mld query-interval to restore the default.
mld query-interval interval
The MLD general query interval is 125 seconds.
Interface view
interval: Specifies an MLD general interval in the range of 1 to 31744 seconds.
You can set the MLD general interval for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the MLD general query interval to 60 seconds on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld query-interval 60
mld robust-count
Use mld robust-count to set the MLD querier's robustness variable on an interface.
Use undo mld robust-count to restore the default.
mld robust-count count
The MLD querier's robustness variable is 2.
Interface view
count: Specifies an MLD querier's robustness variable in the range of 1 to 255.
The MLD querier's robustness variable defines the number of times to retransmit MLD queries if packet loss occurs. A higher robustness variable makes the MLD querier more robust, but it increases the timeout time for IPv6 multicast groups.
You can set the MLD querier's robustness variable for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the MLD querier's robustness variable to 5 on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld robust-count 5
robust-count (MLD view)
mld startup-query-count
Use mld startup-query-count to set the MLD startup query count on an interface.
Use undo mld startup-query-count to restore the default.
mld startup-query-count count
The MLD startup query count equals the MLD querier's robustness variable.
Interface view
count: Specifies an MLD startup query count in the range of 1 to 255.
You can set the MLD startup query count for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the MLD startup query count to 5 on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld startup-query-count 5
startup-query-count (MLD view)
mld startup-query-interval
Use mld startup-query-interval to set the MLD startup query interval on an interface.
Use undo mld startup-query-interval to restore the default.
mld startup-query-interval interval
The MLD startup query interval equals one quarter of the MLD general query interval.
Interface view
interval: Specifies an MLD startup query interval in the range of 1 to 31744 seconds.
You can set the MLD startup query interval for an interface in interface view or globally for all interfaces in MLD view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the MLD startup query interval to 100 seconds on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld startup-query-interval 100
startup-query-interval (MLD view)
mld static-group
Use mld static-group to configure an interface as a static group member of an IPv6 multicast group.
Use undo mld static-group to restore the default.
mld static-group ipv6-group-address [ source ipv6-source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ]
undo mld static-group { all | ipv6-group-address [ source ipv6-source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ] }
An interface is not a static member of IPv6 multicast groups.
Interface view
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command configures an interface as a static group member of the multicast groups with all IPv6 multicast source addresses.
dot1q vid vlan-list: Specifies a space-separated list of up to 10 outer VLAN ID items. Each item specifies an outer VLAN ID or a range of outer VLAN IDs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. If you specify this keyword, the command configures an interface as a single-VLAN-tagged static group member for an IPv6 multicast group. This option is supported in Layer 3 Ethernet subinterface view and Layer 3 aggregate subinterface view.
dot1q vid vlan-id second-dot1q vlan-list: Specifies the outer and inner VLAN IDs. The vlan-id argument specifies the outer VLAN ID in the range of 1 to 4094. The vlan-list argument specifies a space-separated list of up to 10 inner VLAN ID items. Each item specifies an inner VLAN ID or a range of inner VLAN IDs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. If you specify this keyword, the command configures an interface as a double-VLAN-tagged static group member for an IPv6 multicast group. This option is supported in Layer 3 Ethernet subinterface view and Layer 3 aggregate subinterface view.
all: Specifies all IPv6 multicast groups that the interface has statically joined.
For IPv6 multicast routing entries to be created, specify an IPv6 multicast source address if the specified IPv6 multicast group address is in the SSM group range.
For the same IPv6 multicast group, the non-VLAN-based, single-VLAN-based, or double-VLAN-based static member interface configurations are mutually exclusive.
When you configure a subinterface as a non-VLAN-based static member interface, do not configure the mld join-by-session or mld user-vlan-aggregation dot1q command on the subinterface. Otherwise, IPv6 static IPv6 multicast forwarding entries cannot be created.
When you configure a subinterface as a VLAN-based static member interface, you must also configure the mld join-by-session or mld user-vlan-aggregation dot1q command on the subinterface. An IPv6 static multicast forwarding entry can be created under either of the following conditions:
·     When the mld join-by-session command is configured, users that belong to the specified VLANs log in.
·     When the user-vlan-aggregation dot1q command is configured, the specified VLAN IDs are the same as or are included in the VLAN IDs specified in the mld static-group command.
# Configure GigabitEthernet 1/0 as a static group member of IPv6 multicast group FF03::101.
[Sysname-GigabitEthernet1/0] mld static-group ff03::101
# Configure GigabitEthernet 1/0 as a static group member of IPv6 multicast source and group (2001::101, FF3E::202).
[Sysname-GigabitEthernet1/0] mld static-group ff3e::202 source 2001::101
# Enable per-session IPv6 multicast forwarding on GigabitEthernet 1/0.1. Configure the subinterface as a static group member of IPv6 multicast group FF03::101 for users with outer VLAN ID 10 and inner VLAN IDs in the range of 10 to 20.
[Sysname] interface gigabitethernet 1/0.1
[Sysname-GigabitEthernet1/0.1] mld join-by-session
[Sysname-GigabitEthernet1/0.1] mld static-group ff03::101 dot1q vid 10 second-dot1q 10 to 20
Use mld user-vlan-aggregation dot1q to configure VLAN tagging on IPv6 multicast packets.
Use undo mld user-vlan-aggregation dot1q to restore the default.
mld user-vlan-aggregation dot1q vid vlan-id [ second-dot1q vlan-id ]
The IPv6 multicast packets are not tagged with VLAN IDs.
vid vlan-id: Specifies an outer VLAN ID in the range of 1 to 4094.
second-dot1q vlan-id: Specifies an inner VLAN ID in the range of 1 to 4094.
# Configure IPv6 multicast packets to be tagged with outer VLAN ID 10 and inner VLAN ID 20 on GigabitEthernet 1/0.1.
[Sysname-GigabitEthernet1/0.1] mld user-vlan-aggregation dot1q vid 10 second-dot1q 20
mld version
Use mld version to specify an MLD version for an interface.
Use undo mld version to restore the default.
mld version version-number
undo mld version
The MLD version is 1.
Interface view
version-number: Specifies an MLD version, 1 or 2.
CAUTION
CAUTION:
For MLD to operate correctly, specify the same MLD version for all devices on the same subnet.
# Specify MLD version 2 for GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mld version 2
Use other-querier-present-timeout to set the MLD other querier present timer globally.
Use undo other-querier-present-timeout to restore the default.
MLD view
You can set the MLD other querier present timer globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global MLD other querier present timer to 125 seconds on the public network.
[Sysname] mld
[Sysname-mld] other-querier-present-timeout 125
proxy multipath (MLD view)
Use proxy multipath to enable load splitting on the MLD proxy.
Use undo proxy multipath to disable load splitting on the MLD proxy.
proxy multipath
The load splitting feature is disabled on the MLD proxy.
MLD view
Use this feature when the MLD proxy has multiple proxy interfaces. All proxy interfaces on the MLD proxy share IPv6 multicast traffic on a per-group basis. If you do not enable this feature, only the proxy interface with the highest IPv6 address forwards IPv6 multicast traffic.
# Enable load splitting on the MLD proxy device on the public network.
[Sysname] mld
[Sysname-mld] proxy multipath
Use query-interval to set the MLD general query interval globally.
Use undo query-interval to restore the default.
undo query-interval
MLD view
interval: Specifies an MLD general query interval in the range of 1 to 31744 seconds.
You can set the MLD general query interval globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global MLD general query interval to 60 seconds on the public network.
[Sysname] mld
[Sysname-mld] query-interval 60
mld query-interval
reset mld group
Use reset mld group to clear dynamic MLD multicast group entries.
reset mld [ vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | ipv6-group-address [ prefix-length ] [ ipv6-source-address [ prefix-length ] ] } }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears dynamic MLD multicast group entries on the public network.
all: The first all specifies all interfaces, and the second all specifies all MLD multicast groups.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command clears dynamic MLD multicast group entries for all IPv6 multicast sources.
prefix-length: Specifies an address prefix length. The default is 128. For a multicast source address, the value range for this argument is 0 to 128. For a multicast group address, the value range for this argument is 8 to 128.
CAUTION
CAUTION:
This command might interrupt the IPv6 multicast information transmission.
# Clear dynamic MLD multicast groups for all interfaces on the public network.
<Sysname> reset mld group all
# Clear all dynamic MLD multicast group entries for GigabitEthernet 1/0 on the public network.
<Sysname> reset mld group interface gigabitethernet 1/0 all
# Clear the dynamic entry of the MLD multicast group FF03::101:10 for GigabitEthernet 1/0 on the public network.
<Sysname> reset mld group interface gigabitethernet 1/0 ff03::101:10
display mld group
Use robust-count to set the MLD querier's robustness variable globally.
Use undo robust-count to restore the default.
robust-count count
undo robust-count
MLD view
You can set the MLD querier's robustness variable globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global MLD querier's robustness variable to 5 on the public network.
[Sysname] mld
[Sysname-mld] robust-count 5
mld robust-count
ssm-mapping (MLD view)
Use ssm-mapping to configure an MLD SSM mapping.
Use undo ssm-mapping to delete MLD SSM mappings.
ssm-mapping ipv6-source-address ipv6-acl-number
undo ssm-mapping { ipv6-source-address | all }
No MLD SSM mappings exist.
MLD view
ipv6-acl-number: Specifies an IPv6 basic ACL number in the range of 2000 to 2999. IPv6 multicast groups in MLD reports permitted by the ACL are associated with the IPv6 multicast source. If the ACL does not exist or does not have valid rules, no IPv6 multicast groups are associated with the IPv6 multicast source.
all: Specifies all MLD SSM mappings.
# Configure an MLD SSM mapping with IPv6 multicast source 1::1 and IPv6 multicast group range FF3E::/64 on the public network.
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source ff3e:: 64
[Sysname] mld
[Sysname-mld] ssm-mapping 1::1 2001
Use startup-query-count to set the MLD startup query count globally.
Use undo startup-query-count to restore the default.
MLD view
You can set the MLD startup query count globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global MLD startup query count to 5 on the public network.
[Sysname] mld
[Sysname-mld] startup-query-count 5
Use startup-query-interval to set the MLD startup query interval globally.
Use undo startup-query-interval to restore the default.
MLD view
You can set the MLD startup query interval globally for all interfaces in MLD view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global MLD startup query interval to 100 seconds on the public network.
[Sysname] mld
[Sysname-mld] startup-query-interval 100
