07-Layer 3—IP Routing Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R1340-6W10007-Layer 3—IP Routing Command Reference
08-IPv6 static routing commands
08-IPv6 static routing commands 87.82 KB
delete ipv6 static-routes all
Use delete ipv6 static-routes all to delete all IPv6 static routes.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all IPv6 static routes for the public network.
CAUTION
CAUTION:
This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network.
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all IPv6 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ipv6 route-static
display ipv6 route-static nib
Use display ipv6 route-static nib to display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed IPv6 static route next hop information. If you do not specify this keyword, the command displays brief IPv6 static route next hop information.
# Display brief IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib
Total number of nexthop(s): 35
      NibID: 0x21000000        Sequence: 0
       Type: 0x41               Flushed: Yes
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: 2::3
    IFIndex: 0x0              LocalAddr: ::
     NewUK0: 0x0                 NewUK1: 0x0
     NewUK2: 0x0                 NewUK3: 0x0
     NewUK4: 0x0                 NewUK5: 0x0
     NewUK6: 0x0                 NewUK7: 0x0
   TopoNthp: Invalid            ExtType: 0x0
      Color: 0                   COFlag: 0x0
   SIDIndex: 0x0                SRPName:
 OriNexthop: ::
      NibID: 0x21000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 3::4
 OriNexthop: ::
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
Local interface address.
NewUK0
New reserved data 1.
NewUK1
New reserved data 2.
NewUK2
New reserved data 3.
NewUK3
New reserved data 4.
NewUK4
New reserved data 5.
NewUK5
New reserved data 6.
NewUK6
New reserved data 7.
NewUK7
New reserved data 8.
TopoNthp
Index of the topology that contains the next hop.
This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies.
ExtType
NIB extension type.
Color
Color extended community attribute.
COFlag
Flag of the color extended community attribute.
SIDIndex
SID index value.
SRPName
SR-MPLS TE policy name.
OriNexthop
Original next hop address of the route.
If the route is obtained from a BGP UPDATE message, the address is the next hop IP address in the BGP UPDATE message.
# Display detailed IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib verbose
 OriNexthop: ::
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x12               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 2::3
  RelyDepth: 2              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0                    Flags: 0x0
SRPolicyNID: 4294967295     SRInterface:
ColorWeight: 0                  Locator: N/A
 OriNexthop: ::
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 3::4
  RelyDepth: 1              RealNexthop: ::
  Interface: GE1/0            LocalAddr: ::
x nexthop(s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN instance name. For the public network, this field displays default-vrf.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. This field is blank for IPv6, because IPv6 does not support non-base topologies.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
Flags
Flags of the detailed next hop.
SRPolicyNID
NIB ID of the route obtained from an SR-MPLS TE policy through route recursion.
SRInterface
Output interface of the route obtained from the SR-MPLS TE policy through route recursion.
ColorWeight
Weight value of the color attribute in the SR-MPLS TE policy.
Locator
IPv6 prefix of the locator to which the SID belongs.
If no locator is available, this field displays N/A.
display ipv6 route-static routing-table
Use display ipv6 route-static routing-table to display IPv6 static routing table information.
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv6 static routing table information for the public network.
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# Display IPv6 static routing table information.
<Sysname> display ipv6 route-static routing-table
Total number of routes: 5
Status: * - valid
*Destination: 1::1/128
       NibID: 0x21000000        NextHop: 2::2
   MainNibID: N/A             BkNextHop: N/A
     BkNibID: N/A             Interface: GigabitEthernet1/0
     TableID: 0xa           BkInterface: N/A
        Flag: 0x80d0a          BfdSrcIp: N/A
     DbIndex: 0x3            BfdIfIndex: 0x0
        Type: Normal        BfdVrfIndex: 0
  TrackIndex: 0xffffffff          Label: NULL
  Preference: 60            vrfIndexDst: 0
     BfdMode: N/A            vrfIndexNH: 0
   Permanent: 0                     Tag: 0
*Destination: 1::1234/128
     BkNibID: N/A             Interface: NULL0
     DbIndex: 0x1            BfdIfIndex: 0x0
   Permanent: 0                     Tag: 0
Destination
Destination address/prefix.
NibID
ID of the NIB.
MainNibID
ID of the primary next hop for static route FRR.
BkNibID
ID of the backup next hop for static route FRR.
NextHop
Next hop address.
BkNextHop
Backup next hop address.
Output interface of the route.
BkInterface
Backup output interface.
TableID
ID of the table to which the route belongs.
DbIndex
Index of the database to which the route belongs.
Route type:
·     Normal.
·     DHCP.
·     NAT.
BfdSrcIp
Source IPv6 address of the indirect BFD session.
BfdIfIndex
Index of the interface where BFD is enabled.
BfdVrfIndex
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network.
BfdMode
BFD session mode:
·     N/A—No BFD session is configured.
·     Ctrl—Control packet mode.
·     Echo—Echo packet mode.
TrackIndex
NQA Track index.
vrfIndexDst
Index of the VPN instance to which the destination belongs. For the public network, this field displays 0.
vrfIndexNH
Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0.
Permanent
Permanent static route flag. 1 indicates a permanent static route.
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } [ bfd-source ipv6-address ] | permanent | track track-entry-number ] | [ vpn-instance d-vpn-instance-name ] next-hop-address [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | [ vpn-instance d-vpn-instance-name ] next-hop-address ] [ preference preference ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } [ bfd-source ipv6-address ] | permanent | track track-entry-number ] | next-hop-address [ public ] [ bfd control-packet bfd-source ipv6-address | permanent ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is an NBMA interface or broadcast interface and not a point-to-point (P2P) interface, the next hop address must be specified.
next-hop-address: Specifies the next hop IPv6 address.
bfd: Enables BFD to detect reachability of the static route's next hop.
control-packet: Specifies the BFD control packet mode.
bfd-source ipv6-address: Specifies the source IPv6 address of BFD packets.
echo-packet: Specifies the BFD echo packet mode.
permanent: Specifies the IPv6 route as a permanent IPv6 static route. If the output interface is down, the permanent IPv6 static route is still active.
track track-entry-number: Associates the IPv6 static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
public: Indicates the next hop is on the public network.
·     With this keyword specified, the system searches for an output interface for the IPv6 static route from the public network IPv6 routing table based on the specified next hop.
·     Without this keyword and the destination VPN instance specified, the next hop of the IPv6 static route belongs to the source VPN instance. In this case, the system searches for an output interface for the IPv6 static route from the routing table of the source VPN instance based on the specified next hop.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If a destination VPN is specified, packets will search for the output interface based on the specified next hop (IPv6 address) for the static route.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
description text: Configures a description for the IPv6 static route, which consists of 1 to 60 characters, including special characters such as the space, but excluding the question mark (?).
vpn-instance s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN has its own routing table, and the configured static route is installed in the routing tables of the specified VPNs.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
Follow these guidelines to configure the output interface, next hop address, or both for a static route:
·     If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified.
·     If the output interface is a P2P interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
Follow these guidelines when you configure BFD for IPv6 static routes:
·     If you specify the source IPv6 address of BFD packets, you must specify the IPv6 address as the next hop IPv6 address on the peer device.
·     If you specify a non-P2P output interface and a direct next hop, specify the bfd-source ipv6-address option as a best practice. Make sure the source IPv6 address of BFD packets meets the following requirements:
¡     The address is the same as the IPv6 address of the output interface.
¡     The address is on the same network segment as the next hop IPv6 address of the same type.
For example, if the next hop IPv6 address is a link-local address, the source IPv6 address of BFD packets must also be a link-local address.
Follow these guidelines when you configure a static route:
·     Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution. For more information about BFD, see High Availability Configuration Guide.
·     The next hop IPv6 address of echo packets must be a global unicast address.
For IPv6 static routing-Track-NQA collaboration, you must configure the same VPN instance ID for the next hop to be detected and the NQA operation.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
display ipv6 routing-table protocol
ipv6 route-static default-preference
Use ipv6 route-static default-preference to set a default preference for IPv6 static routes.
Use undo ipv6 route-static default-preference to restore the default.
ipv6 route-static default-preference default-preference
The default preference of IPv6 static routes is 60.
default-preference: Specifies a default preference for IPv6 static routes, in the range of 1 to 255.
If no preference is specified for an IPv6 static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added IPv6 static routes.
# Set a default preference of 120 for IPv6 static routes.
[Sysname] ipv6 route-static default-preference 120
