03-Interface Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R1340-6W10003-Interface Command Reference
02-Ethernet interface commands
02-Ethernet interface commands 199.54 KB
Common Ethernet interface commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
Ethernet subinterface view
# Set the expected bandwidth of GigabitEthernet 1/0 to 1000 kbps.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] bandwidth 1000
# Set the expected bandwidth of GigabitEthernet 1/0.1 to 1000 kbps.
[Sysname] interface gigabitethernet 1/0.1
[Sysname-GigabitEthernet1/0.1] bandwidth 1000
speed
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
After an interface in down state is dampened, the interface state displayed through the display interface command is always down.
# Enable interface dampening on GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] dampening
# Enable interface dampening on GigabitEthernet 1/0, and set the following parameters:
·     Half life time to 2 seconds.
·     Reuse value to 800.
·     Suppression threshold to 3000.
·     Maximum suppression interval to 5 seconds.
[Sysname-GigabitEthernet1/0] dampening 2 800 3000 5
display interface
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] default
This command will restore the default settings. Continue? [Y/N]:y
# Restore the default settings for GigabitEthernet 1/0.1.
[Sysname-GigabitEthernet1/0.1] default
description
The description of an interface is the interface name plus Interface (for example, GigabitEthernet1/0 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of GigabitEthernet 1/0 to lan-interface.
[Sysname-GigabitEthernet1/0] description lan-interface
# Set the description of GigabitEthernet 1/0.1 to subinterface1/0.1.
[Sysname-GigabitEthernet1/0.1] description subinterface1/0.1
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
GE1/0                         100                 100                   0           0
GE2/0                    Overflow            Overflow            Overflow    Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
‌Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow when any of the following conditions exist:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
GE1/0                       0             0                --               --
 Overflow: More than 14 digits.
       --: Not supported.
Usage (%)
Bandwidth usage (in percentage) of the interface for the last statistics polling interval.
Total (pps)
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval.
Broadcast (pps)
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval.
Multicast (pps)
‌Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval. .
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
In standalone mode:
In IRF mode:
display ethernet statistics slot slot-number
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
# (In standalone mode.) Display the Ethernet module statistics.
<Sysname> display ethernet statistics
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
# (In IRF mode.) Display the Ethernet module statistics for the specified slot.
<Sysname> display ethernet statistics slot 1
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
    ErrHdrLen       : 0
Table 3 Output description
Statistics about the Ethernet packets received by the Ethernet module:
·     Totalnum—Total number of received packets.
·     ETHIINum—Number of packets encapsulated by using Ethernet II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISISNum—Number of packets encapsulated by using ISIS.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets.
·     MPLS—Number of MPLS packets.
·     ISIS—Number of IS-IS packets.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.
·     MbufRelayNum—Number of packets transparently sent.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module:
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQoSTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
reset ethernet statistics
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display information about Layer 3 interface GigabitEthernet 1/0.
<Sysname> display interface gigabitethernet 1/0
GigabitEthernet1/0
Line protocol state: DOWN
Description: GigabitEthernet1/0 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
loopback: not set, promiscuous mode: not set
1000Mb/s, Full-duplex, link type: autonegotiation,
flow-control: disabled
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
Last link flapping: 5 days 3 hours 6 minutes
Last clearing of counters: 09:59:36 Wed 12/26/2018
Current system time:2018-12-26 10:33:19
Last time when physical state changed to up:2018-12-21 07:27:13
Last time when physical state changed to down:2018-12-21 07:27:10
 Last 200 second input: 6 packets/sec 1728 bytes/sec 0%
 Last 200 second output: 0 packets/sec 22 bytes/sec 0%
 Input (total):  10694 packets, 2944465 bytes
          951 unicasts, 3337 broadcasts, 6406 multicasts, 0 pauses
 Input (normal):  10694 packets, 2944465 bytes
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output (total): 1325 packets, 83462 bytes
          1321 unicasts, 4 broadcasts, 0 multicasts, 0 pauses
 Output (normal): 1325 packets, 83462 bytes
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command.
·     DOWN ( Tunnel-Bundle administratively down )—The tunnel bundle interface to which the interface belongs has been shut down by using the shutdown command.
·     DOWN (Monitor-Link uplink down )—The interface has been shut down by Monitor Link.
·     ETH-rddc Shutdown—The interface has been shut down by the Reth module.
·     mac-address moving down—The interface has been shut down by the MAC address move suppression feature.
·     MAD ShutDown—The interface has been shut down by IRF MAD. This state occurs if the interface is on an IRF fabric placed in Recovery state after an IRF split.
·     OFP DOWN—The interface has been shut down by OpenFlow.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
·     DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include:
¡     DLDP—Shuts down the data link layer when it detects that the link is unidirectional.
¡     OAM—Shuts down the data link layer when it detects a remote link failure.
¡     LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports.
¡     BFD—Shuts down the data link layer when it detects a link failure.
¡     MACSEC—Shuts down the data link layer when it fails to negotiate the encryption parameters.
The peer line protocol state is DOWN(Bit-error down)
Bit errors occur on the peer interface, so the data link layer state of the interface is down.
This field is displayed when the local interface receives bit error messages from the peer interface.
Link quality grade
Link quality grade:
·     GOOD—The link quality is good. GOOD is displayed in either of the following conditions:
¡     The bit error ratio has not exceeded the upper threshold.
¡     The bit error ratio exceeds the upper threshold and then drops below the lower threshold.
·     LOW—The link quality is low. LOW is displayed when the bit error ratio of the interface is higher than the upper threshold.
This field is not displayed if the link-quality crc-error bit-error-ratio command is not executed.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
IPv4 packet framing format.
hardware address
MAC address of the interface.
IPv6 packet framing format.
Statistics for the urgent queue in the output queue:
·     Number of buffered packets.
·     Maximum number of packets that can be buffered.
·     Number of dropped packets.
Statistics for the protocol queue in the output queue:
Statistics for the FIFO queue in the output queue:
Port priority
Port priority of the interface.
Loopback is not set
No loopback test is running on the interface. This field depends on your configuration.
1000Mbps-speed mode
The interface is operating at 1000 Mbps. This field depends on your configuration and the link parameter negotiation result.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
full-duplex mode
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
Link speed type is force link
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command.
link duplex type is force link
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command.
Flow-control is not enabled
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result.
Maximum frame length
Maximum length of Ethernet frames allowed to pass through the interface.
Allow jumbo frame to pass
The interface allows jumbo frames to pass through.
Broadcast max-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast max-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
MDI type
MDIX mode of the interface:
·     automdix.
·     mdi.
·     mdix.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
VLAN Passing
VLANs whose packets can be forwarded by the port. The VLANs must have been created.
VLAN permitted
VLANs whose packets are permitted by the port.
Trunk port encapsulation
Encapsulation protocol type for the trunk port.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Last hardware down reason
Reason for which the interface hardware went down:
·     PHY line side is down.
·     PHY system side is down.
·     No optical signal has been received at the optical port.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS format.
Last time when physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has not changed to up.
Last time when physical state of the interface changed to down.
A hyphen (-) indicates that the physical state of the interface has not changed to down.
Last 300 second input:  0 packets/sec 0 bytes/sec 0%
Last 300 second output:  0 packets/sec 0 bytes/sec 0%
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
‌The four fields on the second line represent:
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
‌Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
‌Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
Top n input bit rates
Top n input rates in bps and the time when each top bit rate appeared.
Top n output bit rates
Top n output rates in bps and the time when each top bit rate appeared.
Top n input packet rates
Top n input rates in pps and the time when each top packet rate appeared.
Top n output packet rates
Top n output rates in pps and the time when each top packet rate appeared.
# Display brief information about all interfaces.
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP      Description
GE1/0                DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   UP       --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
GE2/0                DOWN auto    A      A    1
# Display brief information about GigabitEthernet 1/0, including the complete description of the interface.
<Sysname> display interface gigabitethernet 1/0 brief description
Speed: (a) - auto
GE1/0                UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
GE1/0                DOWN Not connected
Vlan2                DOWN Not connected
GE2/0                DOWN Not connected
Table 5 Command output
Brief information about Layer 3 interfaces.
Interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Brief information of interfaces in bridge mode:
Brief information about Layer 2 interfaces.
Type: A - access; T - trunk; H – hybrid
Link type options for interfaces.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down.
·     DOWN (Loopback detection down)—The loopback detection module has detected loops.
·     DOWN ( Monitor-Link uplink down )—The monitor link module has detected that the uplink is down.
·     MAD ShutDown—The interface is on an IRF fabric placed by IRF MAD in Recovery state after an IRF split.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Storm-Constrain—The storm control feature has detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold.
·     STP DOWN—The interface has been shut down by the BPDU guard feature.
·     Port Security Disabled—The interface has been shut down by the intrusion detection mechanism because the interface received illegal packets.
·     Standby—The interface is a backup interface in standby state.
display interface link-info
Use display interface link-info to display the status and packet statistics of interfaces.
display interface link-info [ main ]
main: Specifies all interfaces except subinterfaces. If you do not specify this keyword, this command displays status and packet statistics of all interfaces.
# Display status and statistics of all interfaces.
<Sysname> display interface link-info
Protocol: (s) - spoofing
Interface                    Link Protocol  InUsage OutUsage   InErrs  OutErrs
GE1/0                        UP   UP         10.09%       0%        0        0
NULL0                        UP   UP(s)          0%       0%        0        0
BAGG11                       ADM  DOWN           --       --       --       --
  GE2/0                      DOWN DOWN           --       --       --       --
RAGG11                       ADM  DOWN           --       --       --       --
  GE3/0                      DOWN DOWN           --       --       --       --
 Overflow: More than 7 digits.
       --: Not supported.
Table 6 Command output
The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
Link
Protocol
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
InUsage
Inbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average inbound speed of the interface within the most recent statistics polling interval/interface bandwidth. When the usage is smaller than 0.01%, 0.01% is displayed. To set the statistics polling interval, use the flow-interval command.
OutUsage
Outbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average outbound speed of the interface within the most recent statistics polling interval/interface bandwidth. When the usage is smaller than 0.01%, 0.01% is displayed. To set the statistics polling interval, use the flow-interval command.
InErrs
Number of error packets received.
OutErrs
Number of error packets sent.
The data length of a statistical item value is greater than 7 decimal digits.
--: Not supported.
A hyphen (-) indicates that the corresponding statistical item is not supported.
flow-interval
display interface main
Use display interface main to display operating status and information of all interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type: Specifies an interface type. If you do not specify this argument, the command displays information about interfaces of all types.
# Display operating status and information of all interfaces except subinterfaces.
<Sysname> display interface main
GigabitEthernet2/0
Current state: DOWN
Description: GigabitEthernet2/0 Interface
IP packet frame type: Ethernet II, hardware address: 4005-6538-0107
IPv6 packet frame type: Ethernet II, hardware address: 4005-6538-0107
Media type:Twisted pair
Port priority:0
Unknown-speed mode,Unknown-duplex mode
Link speed type is autonegotiation,link duplex type is autonegotiation
Flow-control disabled
The Maximum Frame Length is 9664
Last link flapping: Never
Current system time:2018-04-11 10:20:24
Last time when physical state changed to up:-
Last time when physical state changed to down:2018-04-11 09:33:52
 Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
 Last 300 second input: 0 packets/sec 0 bytes/sec -%
 Last 300 second output: 0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, 0 bytes
 Output (normal): 0 packets, 0 bytes
# Display brief information of all interfaces except subinterfaces.
<Sysname> display interface brief main
GE1/0                DOWN DOWN     --
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
# Display information about interfaces (except subinterfaces) in DOWN state and the causes.
<Sysname> display interface brief down main
For description on the display interface main command output, see Table 4 and Table 5.
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds.
[Sysname] flow-interval 100
interface
Use interface to enter interface view, create a subinterface and enter its view, or enter the view of an existing subinterface.
# Enter the view of GigabitEthernet 1/0.
# Create Ethernet subinterface GigabitEthernet 1/0.1 and enter its view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows frames within 16384 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value for this argument is 1536 to 16384.
# Allow jumbo frames to pass through GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] jumboframe enable
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces except VA interfaces. For more information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for GigabitEthernet 1/0.
<Sysname> reset counters interface gigabitethernet 1/0
display counters interface
display counters rate interface
display interface
Use reset ethernet statistics to clear the Ethernet module statistics.
In standalone mode:
In IRF mode:
reset ethernet statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics for all IRF member devices. (In IRF mode.)
# (In standalone mode.) Clear the Ethernet module statistics.
<Sysname> reset ethernet statistics
# (In IRF mode.) Clear the Ethernet module statistics for the specified slot.
<Sysname> reset ethernet statistics slot 1
shutdown
Use shutdown to shut down an Ethernet interface or subinterface.
Use undo shutdown to bring up an Ethernet interface or subinterface.
shutdown
An Ethernet interface or subinterface is up.
CAUTION
CAUTION:
Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution.
Some interface configurations might require an interface restart before taking effect.
# Shut down and then bring up GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] shutdown
[Sysname-GigabitEthernet1/0] undo shutdown
# Shut down and then bring up GigabitEthernet 1/0.1.
[Sysname-GigabitEthernet1/0.1] shutdown
[Sysname-GigabitEthernet1/0.1] undo shutdown
sub-interface rate-statistic
Use sub-interface rate-statistic to enable rate statistics collection for the subinterfaces of an Ethernet interface.
Use undo sub-interface rate-statistic to disable rate statistics collection for the subinterfaces of an Ethernet interface.
The system does not collect rate statistics for the subinterfaces of an Ethernet interface.
This command is resource intensive. When you use this command, make sure you fully understand its impact on system performance.
# Enable rate statistics collection for the subinterfaces of GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
Layer 3 Ethernet interface or subinterface commands
mac-address
Use mac-address to set the MAC address of an Ethernet interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is configured for an Ethernet interface.
mac-address: Specifies a MAC address in the format of H-H-H.
Do not set a VRRP-reserved MAC address for a Layer 3 Ethernet subinterface.
# Set the MAC address of GigabitEthernet 1/0 to 0001-0001-0001.
[Sysname-GigabitEthernet1/0] mac-address 1-1-1
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
size: Sets the MTU in bytes. The value range for this argument varies by interface type.
A smaller MTU size results in more fragments. When you set the MTU for an interface, consider QoS queue lengths, for example, consider that the default FIFO queue length is 75. To prevent a too small MTU from causing packet drops in QoS queuing, you can perform one of the following configurations:
·     Tune the MTU with the mtu command.
·     Tune QoS queue lengths with the qos fifo queue-length command.
For more information about the qos fifo queue-length command, see ACL and QoS Command Reference.
# Set the MTU to 1430 bytes for GigabitEthernet 1/0.
[Sysname-GigabitEthernet1/0] mtu 1430
# Set the MTU to 1430 bytes for GigabitEthernet 1/0.1.
[Sysname-GigabitEthernet1/0.1] mtu 1430
traffic-statistic enable
Use traffic-statistic enable to enable subinterface rate statistics collection for a Layer 3 Ethernet subinterface.
Use undo traffic-statistic enable to disable subinterface rate statistics collection for a Layer 3 Ethernet subinterface.
Subinterface rate statistics collection is disabled for a Layer 3 Ethernet subinterface.
This command is resource intensive. The system becomes busy and the CPU usage increases when you enable this feature on a large number of Ethernet subinterfaces or set a shorter interval by using the flow-interval command.
You can use the display interface or display counters command to display the subinterface rate statistics.
# Enable subinterface rate statistics collection for GigabitEthernet 1/0.1.
[Sysname-GigabitEthernet1/0.1] traffic-statistic enable
display counters
display interface
flow-interval
