- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
13-License management commands | 110.82 KB |
display license install failed
license activation-file install
license activation-file uninstall
snmp-agent trap enable license
license client install feature
license client install standard
display license
Use display license to display detailed license information.
In standalone mode:
display license [ activation-file ]
In IRF mode:
display license [ activation-file ] [ slot slot-number ]
activation-file: Displays license information about activation files.
slot slot-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices. (In IRF mode.)
# Display detailed information about all licenses.
<Sysname> display license
Slot 1:
flash:/license/AdvanceTemporary.ak
Feature: STANDARD
Product Description: H3C VSR1000 License(Comware V7,STANDARD Edition,256vCPUs,1Y
ear)
License SN: 213130A4E1019B000001
Registered at: 2019-12-25 08:56:58
License Type: Trial (days restricted)
Trial Time Left (days): 0
Current State: Expired
flash:/license/StandardTemporary.ak
Feature: STANDARD
Product Description: H3C VSR1000 License(Comware V7,STANDARD Edition,8vCPUs,1Yea
r)
License SN: 213130A1DN0174000004
Registered at: 2019-11-21 07:25:23
Feature |
Feature name. |
Product Description |
License description. |
Registered at |
Time when the license was installed. |
License Type |
License type by validity period: · NA—The system cannot obtain the license type. · Permanent—Purchased license that never expires and is always valid. · Days restricted—Purchased license that is valid for a period of days, for example, 30 days. · Date restricted—Purchased license that is valid for an absolute date range, for example, 2017-05-01 to 2017-05-30. · Trial (days restricted)—Free trial license that is valid for a period of days. · Trial (date restricted)—Free trial license that is valid for an absolute date range. |
Time Left (days) |
Remaining days of the license. |
Trial Time Left (days) |
Remaining days of the trial period. This field is available for a trial license. |
Validity Period |
Start date and end state for a date restricted purchased license. If the license is permanent, this field displays No limit. |
Trial Validity Period |
Start date and end state for a date restricted trial license. If the license is permanent, this field displays No limit. |
Current State |
State of the license: · In use—The license is being used. · Usable—The license is available for use. ¡ If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state. ¡ A date restricted license is in this state if its start date is not reached. · Expired—The license has expired. · Uninstalled—The license has been uninstalled. · Unusable—The license cannot be used. · Invalid—The license is invalid and cannot be used. |
Uninstall Key |
This field is available for licenses that have been uninstalled. |
Uninstall Date |
Date when the activation file was uninstalled. |
display license device-id
Use display license device-id to display SN and DID information.
In standalone mode:
In IRF mode:
display license device-id slot slot-number
slot slot-number: Specifies the member ID of an IRF member device. (In IRF mode.)
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# (In standalone mode.) Display the device SN and DID.
<Sysname> display license device-id
SN: 000c29e6c55afcda18120407
Device ID: flash:/license/000c29e6c55afcda18120407.did
# (In IRF mode.) Display the SN and DID for the specified slot.
<Sysname> display license device-id slot 1
SN: 000c29e6c55afcda18110417
Device ID: flash:/license/000c29e6c55afcda18110417.did
display license feature
Use display license feature to display brief license information for features.
# (In standalone mode.) Display brief feature license information.
<Sysname> display license feature
Total: 128 Usage: 1
Feature Licensed State
ADVANCED-FIREWALL-1vCPU N -
ADVANCED-FIREWALL-4vCPU N -
ADVANCED-FIREWALL-8vCPU N -
ADVANCED-LOADBALANCE-1vCPU N -
ADVANCED-LOADBALANCE-4vCPU N -
ADVANCED-LOADBALANCE-8vCPU N -
BRAS-4vCPU N -
BRAS-8vCPU N -
CGNAT-4vCPU N -
CGNAT-8vCPU N -
SSLVPN N -
STANDARD Y Trial
# (In IRF mode.) Display brief feature license information.
Slot 1:
Total: 128 Usage: 1
BRAS-4vCPU N -
BRAS-8vCPU N -
CGNAT-4vCPU N -
CGNAT-8vCPU N -
SSLVPN N -
STANDARD Y Trial
Total |
Total number of licenses that can be installed. |
Usage |
Number of licenses stored in the license storage. |
Feature |
Feature that must be licensed before being used. |
Licensed |
Licensing state of the feature: · N—Not licensed. · Y—Licensed. |
State |
License type by purchasing state: · Trial—Trial license. If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license. |
Use display license install failed to display information about the activation files that failed to be installed in the most recent installation.
In standalone mode:
In IRF mode:
display license install failed [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays information about the activation files that failed to be installed in the most recent installation on all IRF member devices. (In IRF mode.)
# (In standalone mode.) Display information about the activation files that failed to be installed in the most recent installation.
<Sysname> display license install failed slot 1
Activation files failed to be installed: 1
flash:/license/K1.ak
# (In IRF mode.) Display information about the activation files that failed to be installed in the most recent installation.
Slot 1:
flash:/license/1K1.ak
Activation files failed to be installed |
Total number of activation files that failed to be installed. |
flash:/license/1K1.ak |
Absolute path of the activation file that failed to be installed. |
Use license activation-file install to install an activation file.
In standalone mode:
license activation-file install license-file
In IRF mode:
license activation-file install license-file slot slot-number
license-file: Specifies the path of an activation file., a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
(In standalone mode.) License registration requires the device's hardware SN and DID.
In IRF mode:
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the device.
Activation files are device locked. A licensed feature can run on the IRF member device where its activation file is installed even after the member device is moved from one IRF fabric to another IRF fabric.
# (In standalone mode.) Install activation file 20170810.ak.
[Sysname] license activation-file install flash:/license/20170810.ak
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...Done.
# (In IRF mode.) Install activation file 20170811.ak to the specified slot.
[Sysname] license activation-file install flash:/license/20170811.ak slot 1
display license
Use license activation-file uninstall to uninstall an activation file.
In standalone mode:
license activation-file uninstall license-file
In IRF mode:
license activation-file uninstall license-file slot slot-number
license-file: Specifies the file path, a case-sensitive string of 1 to 127 characters.
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# (In standalone mode.) Uninstall activation file flash:/license/20130810.ak.
[Sysname] license activation-file uninstall flash:/license/20130810.ak
Uninstall file: flash:/license/20130810.uak
# (In IRF mode.) Uninstall activation file flash:/license/20130811.ak from the specified slot.
[Sysname] license activation-file uninstall flash:/license/20130811.ak slot 1
Uninstall file: flash:/license/20130811.uak
display license
license compress
Use license compress to compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress slot slot-number
The license storage is limited. You can execute this command to clear expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID or DID file change. Before performing a compression, make sure all licenses registered with the old DID or DID file have been installed. You will be unable to install such licenses after the compression.
# (In standalone mode.) Compress the license storage.
[Sysname] license compress
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
# (In IRF mode.) Compress the license storage on the specified slot.
[Sysname] license compress slot 1
Use snmp-agent trap enable license to enable SNMP notifications for licensing.
Use undo snmp-agent trap enable license to disable SNMP notifications for licensing.
SNMP notifications for licensing are enabled.
After you enable SNMP notifications for licensing, the device automatically generates notifications for the following events:
· The activation file being used by the device is lost.
· The device disconnects from the license server or reconnects to the license server successfully after it disconnects from the license server.
· The license obtained from the license server is about to expire or has expired.
For license event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for licensing.
[Sysname] snmp-agent trap enable license
display snmp-agent trap-list (Network Management and Monitoring Command Reference)
license client enable
License client commands
display license client
Use display license client to display the license client configuration and the obtained license information on the license client.
display license client slot slot-number
# Display the license client configuration and the obtained license information on the license client.
<Sysname> display license client slot 1
Username: user
Ciphertext password: ******
License server's IPv4 address: 192.168.3.124, port: 5001
License client: Enabled
License Name: STANDARD
License Description: H3C VSR1000 License(Comware V7,STANDARD Edition,8vCPUs,1Year)
Current State: In use
Get Time: 2019-02-06 05:08:33
Username |
Username for accessing the license server. This field displays Not configured if no username is specified. |
Ciphertext password |
Password in encrypted form for accessing the license server. This field displays Not configured if no password is specified. |
License server's IPv4 address |
IPv4 address of the license server. This field displays Not configured if no IPv4 address of the license server is specified. |
Port |
Port number of the license server. This field displays Not configured if no port number of the license server is specified. |
License client |
Status of the license client: · Enabled. · Disabled. |
License name |
Name of the license. |
License description |
Description of the license. |
Current State |
Current status of the license: · In use—The license is in use. · Unusable—The license is not in use. · Reserved (client is disconnected from license server, but license is still available for n days)—The device is disconnected from the license server for more than 32 hours (excluding 32 hours), and the value n represents the number of validity days of the license. · Expired (will be reclaimed in n days)—The license is expired and will be reclaimed in n days. |
Get Time |
Time when the license was obtained from the license server. |
license client username
Use license client username to specify the username and password on the license client for logging in to the license server.
Use undo license client username to delete the username and password settings.
license client username username password { cipher | simple } password
No username or password is specified on the license client.
username: Specify the username, a case-sensitive string of 1 to 31 characters.
cipher: Specify a password in encrypted form.
simple: Specifies a password in plaintext form.
password: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its encrypted form is a case-sensitive string of 33 to 73 characters.
You can specify only one username and one password on the license client for login to the license server.
If you execute the command multiple times before enabling the license client, the most recent configuration takes effect.
To modify the username and password settings on an enabled license client, disable the license client first.
# Specify test and 123456 as the username and password on the license client.
[Sysname] license client username test password simple 123456
Use license client enable to enable the license client.
Use undo license client enable to disable the license client.
License client is disabled, and it cannot get licenses from the license server.
Specify the IP address, username, and password of the license server before enabling the license client. Otherwise, the configuration fails.
After you enable the license client, the device automatically initiates a connection to the license server. The license server verifies the license client identity through the username and password. If they are consistent with those specified on the license server, the license client passes authentication. Then the client can apply for licenses from the license server and use the licensed features.
# Enable the license client.
[Sysname] license client enable
Use license client install feature to apply for feature licenses from the license server and install them.
Use undo license client install feature to uninstall feature licenses and release them.
license client install feature { bras-4vcpu | bras-8vcpu | ipsec-acc-2g | l3vpn-50 count l3vpn-count | sslvpn-100 count count | sslvpn-1000 count count | sslvpn-25 count count | sslvpn-500 count count }
undo license client install feature { bras-4vcpu | bras-8vcpu | ipsec-acc-2g | l3vpn-50 | sslvpn-100 | sslvpn-1000 | sslvpn-25 | sslvpn-500 }
The license client does not apply for feature licenses from the license server automatically.
bras-4vcpu: Specify a BRAS 4-vCPU license. The license allows 4 vCPUs for the BRAS feature.
bras-8vcpu: Specify a BRAS 8-vCPU license. The license allows 8 vCPUs for the BRAS feature.
ipsec-acc-2g: Specify an IPSec license that allows 2Gbps bandwidth.
l3vpn-50 count l3vpn-count: Specify the number of L3VPN-50 licenses, each allowing 50 L3VPNs.
sslvpn-100: Specify an SSL VPN-100 license.
sslvpn-1000: Specify an SSL VPN-1000 license.
sslvpn-25: Specify an SSL VPN-25 license.
sslvpn-500: Specify an SSL VPN-500 license.
count count: Specifies the maximum number of SSL VPN licenses, in the range of 1 to 64.
The n in the sslvpn-n license represents the number of SSL VPNs allowed on a virtual device. The number of allowed SSL VPNs are accumulated as multiple SSL VPN licenses are installed on a virtual device.
The number of L3VPNs allowed on a virtual device are accumulated as multiple L3VPN-50 licenses are installed on the device. The total number of L3VPNs allowed on a virtual device cannot exceed the upper limit on the L3VPN count supported by the device.
After a license is uninstalled and released, the license server withdraws the license. The withdrawn license can be used on other virtual devices within the validity period.
# Apply for one SSL VPN-100 license and install it.
[Sysname] license client install feature sslvpn-100 count 1
Use license client install standard to apply for a standard license from the license server and install it.
Use undo license client install standard to uninstall the standard license and release it.
license client install standard { 1vcpu-1year | 1vcpu-3year | 1vcpu- permanent | 4vcpu-1year | 4vcpu-3year | 4vcpu-permanent | 8vcpu-1year | 8vcpu-3year | 8vcpu-permanent | l3vpn-advance | license-type }
The license client does not apply for a standard license from the license server automatically.
1vcpu-1year: Specifies the 1-vCPU license with 1-year validity period.
1vcpu-3year: Specifies the 1-vCPU license with 3-year validity period.
1vcpu-permanent: Specifies the 1-vCPU license with permanent validity period.
4vcpu-1year: Specifies the 4-vCPU license with 1-year validity period.
4vcpu-3year: Specifies the 4-vCPU license with 3-year validity period.
4vcpu-permanent: Specifies the 4-vCPU license with permanent validity period.
8vcpu-1year: Specifies the 8-vCPU license with 1-year validity period.
8vcpu-3year: Specifies the 8-vCPU license with 3-year validity period.
8vcpu-permanent: Specifies the 8-vCPU license with permanent validity period.
l3vpn-advance: Specifies the permanent L3VPN license. The license allows 256 vCPUs and 240 L3VPNs.
license-type: Specify a standard license type in the format of m(v)cpu-nyear or m(v)cpu-permanent. The value for m represents the number of physical or vCPUs, and the value for n represents the number of license validity years. Make sure the specified license already exists on the license server.
Each virtual device comes with a trail license that allows 256 vCPUs free for 180 days. The trial period starts when the virtual device is created. To ensure service continuity, execute this command to apply for a formal license from the license server and install it before the trail period expires.
Choose a proper formal license to match the virtual device requirement. The number of licensed vCPUs must be equal to or greater than the vCPU upper limit supported by the virtual device. The upper limit is defined when the virtual device is created. For example, for a virtual device supporting a maximum of 5 vCPUs, an 8-vCPU license will be appropriate.
By default, a virtual device allows 8191 L3VPNs. The installation of a vCPU license does not affect this number count, but an l3vpn-advance license does. To license more than 8 vCPUs, you need to install the l3vpn-advance license. After installation, the number of allowed vCPUs is increased to 256, but the number of licensed L3VPNs is decreased to 240. In this case, you can use either of or both the following methods to increase the number of L3VPNs allowed on the virtual device:
· Remote licensing—Execute the license client install feature l3vpn-50 count l3vpn-count command to apply for l3vpn-50 licenses from the license server. The number of L3VPNs on the virtual device will be accumulated.
· Local licensing—Install the L3VPN advance licenses and L3VPN-50 licenses on the virtual device.
The number of licensed L3VPNs cannot exceed the L3VPN upper limit supported by the device.
Each virtual device supports only one standard license. If you apply for a new standard license on the device where a standard license has been installed, the license client will first uninstall the existing license and release it, and then apply for the new license.
Before applying for a standard license, make sure the license client and license server are reachable to each other, and the requested license exists on the license server.
# Apply for standard license 1vcpu-1year from the license server and install it.
[Sysname] license client install standard 1vcpu-1year
license server
Use license server to specify the IP address and port number of the license server.
Use undo license server to delete the license server settings on the license client.
license server ipv4 ipv4-address port port-number [ vpn-instance vpn-instance-name ]
undo license server ipv4 ipv4-address port port-number [ vpn-instance vpn-instance-name ]
No IP address or port number of the license server is specified.
ipv4-address: Specifies the IPv4 address of the license server.
port-number: Specifies the port number of the license server, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies a VPN instance to which the license server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the license server is on the public network, do not specify this option.
You can specify a maximum of four license servers on the license client. Each license server is uniquely identified by the combination of an IP address, a port number, and a VPN instance.
When the upper limit is reached, you cannot specify new license servers unless you delete existing license server settings.
If you apply for a new standard license on a device with a standard license installed, the license client will first uninstall the existing license and release it, and then apply for the new license.
As a best practice, make sure only one license server is reachable.
To modify the license server settings on an enabled license client, disable the license client first.
# Specify 192.168.100.1 and 5001 as the IPv4 address and port number of the license server, respectively.
[Sysname] license server ipv4 192.168.100.1 port 5001
