H3C UIS 3000 G6 Hyper-Converged Infrastructure User Guide-5W100
HomeSupportCloud ComputingUIS 3000 G6 SeriesInstall & UpgradeInstallation GuidesH3C UIS 3000 G6 Hyper-Converged Infrastructure User Guide-5W100
02-Appendix
02-Appendix 7.31 MB
Appendix A  Server specifications· 1
Server models and chassis view· 1
Technical specifications· 1
Components· 2
Front panel 4
Front panel view of the server 4
LEDs and buttons· 7
Ports· 8
Rear panel 9
Rear panel view· 9
LEDs· 10
Ports· 10
System board· 11
System board components· 11
System maintenance switch· 14
DIMM slots· 15
Appendix B  Component specifications· 16
About component model names· 16
DIMMs· 16
DRAM DIMM rank classification label 16
HDDs and SSDs· 17
Drive numbering· 17
Drive LEDs· 18
Drive backplanes· 20
Front 8SFF SAS/SATA drive backplane· 20
Front 8SFF UniBay drive backplane· 21
Front 8LFF SAS/SATA drive backplane· 21
Front 12LFF SAS/SATA drive backplane· 22
Front 8SAS/SATA+4UniBay drive backplane· 22
Front 4SAS/SATA+8UniBay drive backplane· 23
Front 12LFF UniBay drive backplane· 24
Front 17SAS/SATA+8UniBay drive backplane· 24
Rear 2LFF SAS/SATA drive backplane· 25
Rear 4LFF SAS/SATA drive backplane· 26
Rear 2SFF SAS/SATA drive backplane· 26
Rear 2SFF UniBay drive backplane· 26
Rear 4SFF SAS/SATA drive backplane· 27
Rear 4SFF UniBay drive backplane· 27
Rear 8E1.S drive backplane· 28
Riser cards· 29
Riser card guidelines· 29
RC-3FHFL-2U-G6· 29
RC-3FHHL-2U-G6· 30
RC-FHHL-2U-G6· 32
RC-2HHHL-R4-2U-G6· 33
PCA-R4900-4GPU-G6· 33
LCD smart management module· 35
Fan modules· 36
PCIe slot 37
PCIe modules· 37
Storage controllers· 38
NVMe VROC modules· 38
SATA M.2 expander module· 38
NVMe M.2 expander module· 39
Server management module· 39
Serial & DSD module· 40
B/D/F information· 41
Appendix C  Managed removal of OCP network adapters· 41
Before you begin· 41
Performing a hot removal 42
Appendix D  Environment requirements· 44
About environment requirements· 44
General environment requirements· 44
Operating temperature requirements· 44
General guidelines· 44
Appendix E  Product recycling· 46
Appendix F  Glossary· 47
Appendix G  Acronyms· 49
The information in this document might differ from your product if it contains custom configuration options or features.
Figures in this document are for illustration only.
H3C UIS 3000 G6 HCI appliance are 2U dual-processor servers independently developed by H3C based on the new-generation Eagle Stream platform of Intel. The servers can be widely used in general computing scenarios, including cloud computing, virtualization, distributed storage, and enterprise resource allocation. They are suitable for typical applications in industries such as Internet, service providers, enterprises, and government. The servers provide balanced computing performance, storage capacity, power efficiency, scalability, and reliability, and are easy to deploy and manage.
Figure 1 Chassis view
The servers come in the models listed in Table 1. These models support different drive configurations. For more information about drive configuration and compatible storage controller configuration, see H3C UIS 3000 G6 Hyper-Converged Infrastructure Drive Configurations and Cabling Solutions.
Table 1 3000 G6 HCI appliance models
Model
Maximum drive configuration
LFF
12LFF drives at the front + drives (4LFF+2SFF) at the rear
SFF
25SFF drives at the front + 4SFF drives at the rear
Item
Specifications
Dimensions (H × W × D)
·     Without a security bezel: 87.5 × 445.4 × 780 mm (3.44 × 17.54 × 30.71 in)
·     With a security bezel: 87.5 × 445.4 × 808 mm (3.44 × 17.54 × 31.81 in)
Max. weight
39.5 kg (87.08 lb)
Processors
2 × Intel Eagle Stream processors, maximum 350 W power consumption per processor
Supports Montage Jintide processors
Memory
Up to 32 DIMMs (DDR5 supported)
Storage controllers
·     High-performance standard storage controller
·     NVMe VROC module
·     Serial & DSD module (supports RAID 1)
Chipset
Intel Emmitsburg
Integrated graphics
The graphics chip (model AST2600) is integrated in the BMC management chip to provide a maximum resolution of 1920 × 1200@60Hz (32bpp), where:
·     1920 × 1200: 1920 horizontal pixels and 1200 vertical pixels.
·     60Hz: Screen refresh rate, 60 times per second.
·     32bpp: Color depts. The higher the value, the more colors that can be displayed.
If you attach monitors to both the front and rear VGA connectors, only the monitor connected to the front VGA connector is available.
Network connectors
·     1 × embedded 1 Gbps HDM dedicated management port
·     Up to two OCP 3.0 network adapter connectors (OCP 3.0 network adapters support NCSI)
I/O connectors
·     5 × USB connectors
¡     3 × USB3.0 connectors (one on the right chassis ear, and two on the rear panel)
¡     2 × USB2.0 connectors (one on the system board, and one available on the left chassis ear only when the multifunctional rack mount kit is used)
·     16 × built-in SATA connectors (displayed as 4 × x4 SlimSAS connectors)
·     14 × MCIO connectors (PCIe5.0 x8)
·     1 × RJ-45 HDM dedicated network port (at the server rear)
·     2 × VGA connectors (one on the front panel, and one available on the left chassis ear only when the multifunctional rack mount kit is used)
·     1 × serial port (available only when the Serial & DSD module is used)
·     1 × dedicated management port (available on the left chassis ear only when the multifunctional rack mount kit is used)
Expansion slots
10 × PCIe standard slots (6 × PCIe 5.0 slots and 4 × PCIe 4.0 slots)
Optical drives
External USB optical drives
Power supplies
2 × hot-swappable power supplies, 1 + 1 redundancy
Standards
CCC, UL, CE
Components
Figure 2 3000 G6 HCI appliance components
Item
(1) Chassis access panel
N/A
(2) CPU heatsink
Cools the processor.
(3) Storage controller
Provides RAID capability to SAS/SATA drives, including RAID configuration and RAID scale-up. It supports online upgrade of the controller firmware and remote configuration.
(4) System battery
Supplies power to the system clock to ensure system time correctness.
(5) Standard PCIe network adapter
Installed in a standard PCIe slot to provide network ports.
(6) Riser card
Provides PCIe slots.
(7) GPU module
Provides computing services such as graphics processing and AI.
(8) NVMe VROC module
Works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
(9) Memory
Stores computing data and data exchanged with external storage temporarily.
(10) Serial & DSD module
Provides one serial port and two SD card slots.
(11) Server management module
Provides I/O connectors and HDM out-of-band management features.
(12) Rear drive cage
Installed at the server rear to accommodate drives.
(13) Rear drive backplane
Provides power and data channels for drives at the server rear.
(14) Riser card blank
Installed on an empty PCIe riser connector to ensure good ventilation.
(15) OCP network adapter
Network adapter installed onto the OCP network adapter connector on the system board.
(16) Power supply
Supplies power to the server. The power supplies support hot swapping and 1+1 redundancy.
(17) Chassis
Accommodate all components.
(18) Chassis ears
Attach the server to the rack. The right ear is integrated with the front I/O component, and the left ear is integrated with VGA connector, dedicated management connector, and USB 3.0 connector.
(19) Front drive backplane
Provides power and data channels for drives at the server front. This document installs an 8SFF front drive backplane as an example.
(20) LCD smart management module
Displays basic server information, operating status, and fault information. Together with HDM event logs, users can fast locate faulty components and troubleshoot the server, ensuring server operation.
(21) Drive
Provides data storage space. Drives support hot swapping.
(22) SATA M.2 SSD expander module
Provides M.2 SSD slots.
(23) SATA M.2 SSD
Provides data storage space for the server.
(24) Encryption module
Provides encryption services for the server to enhance data security.
(25) System board
One of the most important parts of a server, on which multiple components are installed, such as processor, memory, and fan. It is integrated with basic server components, including the BIOS chip and PCIe connectors.
(26) Processor socket cover
Installed over an empty processor socket to protect pins in the socket.
(27) Fan cage
Accommodates fan modules.
(28) Chassis open-alarm module
Detects if the access panel is removed. The detection result can be displayed from the HDM Web interface.
(29) Air baffle
Provides ventilation aisles for processor heatsinks and memory modules and provides support for the supercapacitor.
(30) Fan
Helps server ventilation. Fans support hot swapping and N+1 redundancy.
(31) Processor
Integrates memory and PCIe controllers to provide data processing capabilities for the server.
(32) Processor retaining bracket
Attaches a processor to the heatsink.
(33) Supercapacitor
Supplies power to the flash card on the power fail safeguard module, which enables the storage controller to back up data to the flash card for protection when power outage occurs.
(34) Supercapacitor holder
Secures a supercapacitor in the chassis.
Front panel
Figure 3 8LFF front panel
Table 2 8LFF front panel description
Item
1
USB 3.0 connector
2
Drive or LCD mart management module (optional)
3
Serial label pull tab
4
Dedicated management connector
5
USB 2.0 connector
6
VGA connector
Figure 4 12LFF front panel
Table 3 12LFF front panel description
Item
1
12LFF UniBay drives*
2
USB 3.0 connector
3
4
5
6
USB 2.0 connector
7
VGA connector
*: Drive types supported by the server vary by drive backplane configuration. For more information, see "_Ref135054927."
Figure 5 8SFF front panel
Table 4 8SFF front panel description
Item
1
Bay 1: 8SFF drives (optional)*
2
Bay 2: 8SFF drives (optional)*
3
Bay 3: 8SFF drives (optional)*
4
USB 3.0 connector
5
LCD smart management module (optional)
6
7
8
USB 2.0 connector
9
VGA connector
Figure 6 25SFF front panel
Table 5 25SFF front panel description
Item
1
25SFF drives*
2
USB 3.0 connector
3
4
5
6
USB 2.0 connector
7
VGA connector
LEDs and buttons
Figure 7 Front panel LEDs and buttons
Table 6 LEDs and buttons on the front panel
Button/LED
Status
Power on/standby button and system power LED
·     Steady green—The system has started.
·     Flashing green (1 Hz)—The system is starting.
·     Steady amber—The system is in standby state.
·     Off—No power is present. Possible reasons:
¡     No power source is connected.
¡     No power supplies are present.
¡     The installed power supplies are faulty.
¡     The system power cords are not connected correctly.
OCP 3.0 network adapter Ethernet port LED
·     Steady green—A link is present on a port of an OCP 3.0 network adapter.
·     Flashing green (1 Hz)—A port on an OCP 3.0 network adapter is receiving or sending data.
·     Off—No link is present on any port of either OCP 3.0 network adapter.
The server supports a maximum of two OCP3.0 network adapters.
Health LED
·     Steady green—The system is operating correctly or a minor alarm is present.
·     Flashing green (4 Hz)—HDM is initializing.
·     Flashing amber (1 Hz)—A major alarm is present.
·     Flashing red (1 Hz)—A critical alarm is present.
If a system alarm is present, log in to HDM to obtain more information about the system running status.
UID button LED
·     Steady blue—UID LED is activated. The UID LED can be activated by using the following methods:
¡     Press the UID button LED.
¡     Activate the UID LED from HDM.
·     Flashing blue:
¡     1 Hz—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server.
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds.
·     Off—UID LED is not activated.
Security bezel light
The security bezel provides hardened security and uses effect light to visualize operation and health status to help inspection and fault location. The default effect light is as shown in Figure 8.
Figure 8 Security bezel
Table 7 Security bezel effect light
System status
Light status
Standby
Steady white: The system is in standby state.
Startup
·     Beads turn on white from middle in turn—POST progress.
·     Beads turn on white from middle three times—POST has finished.
Running
·     Breathing white (gradient at 0.2 Hz)—Normal state, indicating the system load by the percentage of beads turning on from the middle to the two sides of the security bezel.
¡     No loadLess than 10%.
¡     Light load—10% to 50%.
¡     Middle load—50% to 80%.
¡     Heavy loadMore than 80%.
·     Breathing white (gradient at 1 Hz )—A pre-alarm is present (only for drive pre-failure).
·     Flashing red (1 Hz)—A critical alarm is present (only for power supply errors).
UID
·     All beads flash white (1 Hz)—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server.
·     Some beads flash white (1 Hz)—HDM is restarting.
Ports
Table 8 Ports on the front panel
Port
VGA connector
DB-15
Connects a display terminal, such as a monitor or KVM device.
USB connector
USB 2.0/3.0
Connects the following devices:
·     USB flash drive.
·     USB keyboard or mouse.
·     USB optical drive for operating system installation.
Type-C
Connects a Type-C to USB adapter cable, which connects to a USB Wi-Fi adapter.
The server supports only Xiaomi USB Wi-Fi adapters.
Rear panel
Rear panel view
Figure 9 Rear panel components
Table 9 Rear panel description
Item
1
PCIe riser bay 1: PCIe slots 1 through 3
2
PCIe riser bay 2: PCIe slots 4 through 6
3
PCIe riser bay 3: PCIe slots 7 and 8
4
PCIe riser bay 4: PCIe slots 9 and 10
5
Power supply 2
6
Power supply 1
7
OCP 3.0 network adapter/Serial & DSD module (in slot 17) (optional)
8
VGA connector
9
Two USB 3.0 connectors
10
HDM dedicated network port (1Gbps, RJ-45, default IP address 192.168.1.2/24)
11
OCP 3.0 network adapter (in slot 16) (optional)
LEDs
Figure 10 Rear panel LEDs
(1) Power supply LED for power supply 2
(2) Power supply LED for power supply 1
(3) Activity LED of the Ethernet port
(4) Link LED of the Ethernet port
(5) UID LED
Table 10 LEDs on the rear panel
LED
Status
Power supply LED
·     Steady green—The power supply is operating correctly.
·     Flashing green (0.33 Hz)—The power supply is in standby state and does not output power.
·     Flashing green (2 Hz)—The power supply is updating its firmware.
·     Steady amber—Either of the following conditions exists:
¡     The power supply is faulty.
¡     The power supply does not have power input, but another power supply has correct power input.
·     Flashing amber (1 Hz)—An alarm has occurred on the power supply.
·     Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown.
·     Flashing green (1 Hz)—The port is receiving or sending data.
·     Off—The port is not receiving or sending data.
·     Steady green—A link is present on the port.
·     Off—No link is present on the port.
UID LED
¡     Enable UID LED from HDM.
·     Flashing blue:
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for 8 seconds.
Ports
Table 11 Ports on the rear panel
Port
VGA connector
DB-15
BIOS serial port
DB-9
The BIOS serial port is used for the following purposes:
·     Log in to the server when the remote network connection to the server has failed.
·     Establish a GSM modem or encryption lock connection.
USB connector
USB 3.0
·     USB flash drive.
RJ-45
Establishes a network connection to manage HDM from its Web interface.
Power receptacle
Standard single-phase
Connects the power supply to the power source.
System board
Figure 11 System board components
Table 12 System board components
No.
Mark
1
PCIe riser connector 2 (for processor 2)
RISER3 PCIe X16
2
Fan connector 2 for the OCP 3.0 network adapter
3
OCP 3.0 network adapter connector/Serial & DSD module connector
OCP2&DSD&UART CARD
4
PCIe riser connector 1 (for processor 1)
RISER1 PCIe X16
5
Server management module slot
BMC
6
Fan connector 1 for the OCP 3.0 network adapter
OCP1 FAN
7
OCP 3.0 network adapter connector 1
OCP1
8
SlimSAS connector 4 (x4 SATA)
SATA PORT4
9
SlimSAS connector 3 (x4 SATA)
SATA PORT3
10
SlimSAS connector 2 (x4 SATA)
SATA PORT2
11
SlimSAS connector 1 (x4 SATA or M.2 SSD)
M.2&SATA PORT1
12
M.2 SSD AUX connector
M.2 AUX
13
Front I/O connector
RIGHT EAR
14
Fan connector 4
J245
15
Liquid leakage detection module connector
LEAKDET
16
LCD smart management module connector
DIAG LCD
17
MCIO connector C1-P4A (for processor 1)
C1-P4A
18
MCIO connector C1-P4C (for processor 1)
C1-P4C
19
Fan connector 3
J104
20
MCIO connector C1-P3C (for processor 1)
C1-P3C
21
MCIO connector C1-P3A (for processor 1)
C1-P3A
22
Power connector 3 for front drive backplane
PWR3
23
Power connector 2 for front drive backplane
PWR2
24
Power connector 1 for front drive backplane
PWR1
25
Connector for the thermal sensor module at the air inlet
26
Fan connector 2
J94
27
MCIO connector C2-P4A (for processor 2)
C2-P4A
28
AUX connector 3 for front drive backplane
AUX3
29
MCIO connector C2-P4C (for processor 2)
C2-P4C
30
MCIO connector C2-P3C (for processor 2)
C2-P3C
31
Fan connector 1
J96
32
AUX connector 2 for front drive backplane
AUX2
33
AUX connector 1 for front drive backplane
AUX1
34
MCIO connector C2-P3A (for processor 2)
C2-P3A
35
Chassis-open alarm module connector
INTRUDER
36
Front VGA and USB 2.0 connector
LEFT EAR
37
Power connector 4 for rear drive backplane
PWR4
38
Power connector 5 for rear drive backplane
PWR5
39
MCIO connector C2-P2C (for processor 2)
C2-P2C
40
AUX connector 4 for rear drive backplane
AUX4
41
MCIO connector C2-P2A (for processor 2)
C2-P2A
42
MCIO connector C2-P1C (for processor 2)
C2-P1C
43
MCIO connector C2-P1A (for processor 2)
C2-P1A
44
AUX connector 5 for rear drive backplane
AUX5
45
Riser card AUX connector 8
AUX8
46
NVMe VROC module connector
NVMe RAID KEY
47
TPM/TCM connector
TPM
48
Embedded USB 2.0 connector
INTERNAL USB2.0
49
System battery
50
MCIO connector C1-P2C (for processor 1)
C1-P2C
51
MCIO connector C1-P2A (for processor 1)
C1-P2A
X
MAINTENANCE SW
Figure 12 shows the system maintenance switch. Table 13 describes how to use the maintenance switch.
Figure 12 System maintenance switch
Table 13 System maintenance switch description
Item
Remarks
1
·     Off (default)—HDM login requires the username and password of a valid HDM user account.
·     On—HDM login requires the default username and password.
For security purposes, turn off the switch after you complete tasks with the default username and password as a best practice.
5
·     Off (default)—Normal server startup.
·     On—Restores the default BIOS settings.
To restore the default BIOS settings, turn on and then turn off the switch. The server starts up with the default BIOS settings at the next startup.
CAUTION CAUTION:
The server cannot start up when the switch is turned on. To avoid service data loss, stop running services and power off the server before turning on the switch.
6
·     On—Clears all passwords from the BIOS at server startup.
If this switch is on, the server will clear all the passwords at each startup. Make sure you turn off the switch before the next server startup if you do not need to clear all the passwords.
2, 3, 4, 7, and 8
Reserved for future use.
N/A
DIMM slots
The system board provides eight DIMM channels per processor, and 16 channels in total, as shown in Figure 13. Each channel contains two DIMM slots.
Figure 13 System board DIMM slot layout
For components compatible with the server and detailed component information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR5-4800-32G-1Rx4 memory model represents memory module labels including UN-DDR5-4800-32G-1Rx4-R, UN-DDR5-4800-32G-1Rx4-F, and UN-DDR5-4800-32G-1Rx4-S, which have different prefixes and suffixes.
DIMMs
The server provides eight DIMM channels per processor and each channel has two DIMM slots. If the server has one processor, the total number of DIMM slots is 16. If the server has two processors, the total number of DIMM slots is 32. For the physical layout of DIMM slots, see "DIMM slots."
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DIMM, use the label attached to the DIMM, as shown in Figure 14. The meaning of the DDR DIMM rank classification labels are similar and this section uses the label of a DDR5 DIMM as an example.
Figure 14 DDR DIMM rank classification label
Table 14 DIMM rank classification label description
Callout
Remarks
1
Capacity
Options include:
·     8GB.
·     16GB.
·     32GB.
2
Number of ranks
Options include:
·     1R—One rank (Single-Rank).
·     2R—Two ranks (Dual-Rank). A 2R DIMM is equivalent to two 1R DIMMs.
·     4R—Four ranks (Quad-Rank). A 4R DIMM is equivalent to two 2R DIMMs
·     8R—Eight ranks (8-Rank). An 8R DIMM is equivalent to two 4R DIMMs.
3
Data width
Options include:
·     ×4—4 bits.
·     ×8—8 bits.
4
DIMM generation
DDR5
5
Data rate
Options include:
·     2666V—2666 MHz.
·     2933Y2933 MHz.
·     3200AA3200 MHz.
·     48004800 MHz.
6
DIMM type
Options include:
·     L—LRDIMM.
·     R—RDIMM.
HDDs and SSDs
Drive numbering
The server provides different drive numbering schemes for different drive configurations at the server front and rear.
Figure 15 Drive numbering for front 25SFF drive configuration
Figure 16 Drive numbering for front 12LFF drive configuration
Figure 17 Drive numbering for front 8LFF drive configuration
Figure 18 Drive numbering for rear 4LFF+4SFF drive configuration
Figure 19 Drive numbering for rear 2SFF+2SFF+4SFF drive configuration
Figure 20 Drive numbering for 8E1.S drive configuration
Drive LEDs
The server supports SAS, SATA, and NVMe (including E1.S) drives, of which SAS and SATA drives support hot swapping and NVMe drives support hot insertion and managed hot removal. You can use the LEDs on a drive to identify its status after it is connected to a storage controller.
For more information about OSs that support hot insertion and managed hot removal of NVMe drives, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Figure 21 shows the location of the LEDs on a drive.
Figure 21 LFF&SFF drive LEDs
(1) Fault/UID LED
(2) Present/Active LED
Figure 22 E1.S drive LEDs
(1) Fault/UID LED
To identify the status of a SAS or SATA drive, use Table 15. To identify the status of an NVMe drive, use Table 16.
Table 15 SAS/SATA drive LED description
Fault/UID LED status
Present/Active LED status
Flashing amber (0.5 Hz)
Steady green/Flashing green (4.0 Hz)
A drive failure is predicted. As a best practice, replace the drive before it fails.
Steady amber
The drive is faulty. Replace the drive immediately.
Steady blue
The drive is operating correctly and is selected by the RAID controller.
Off
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive.
Off
Steady green
The drive is present but no data is being read or written to the drive.
Off
Off
The drive is not securely installed.
Table 16 NVMe drive LED description
Flashing amber (4 Hz)
Off
The drive is in hot insertion process.
Steady amber
Steady blue
The drive is operating correctly and selected by the RAID controller.
Off
Off
Steady green
Off
Off
Drive backplanes
The server supports the following types of drive backplanes:
·     SAS/SATA drive backplanesSupport only SAS/SATA drives.
·     UniBay drive backplanesSupport both SAS/SATA and NVMe drives. You must connect both SAS/SATA and NVMe data cables. The number of supported drives varies by drive cabling.
·     X SAS/SATA+Y UniBay drive backplanesSupport SAS/SATA drives in all slots and support NVMe drives in certain slots.
¡     X: Number of slots supporting only SAS/SATA drives.
¡     Y: Number of slots supporting both SAS/SATA and NVMe drives.
For UniBay drive backplanes and X SAS/SATA+Y UniBay drive backplanes:
·     The two drive types are supported only when both SAS/SATA and NVMe data cables are connected.
·     The number of supported SAS/SATA drives and the number of supported NVMe drives vary by cable connection.
The PCA-BP-8SFF-2U-G6 8SFF SAS/SATA drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA drives.
Figure 23 8SFF SAS/SATA drive backplane
(1) x8 SlimSAS connector (SAS PORT1)
(2) AUX connector (AUX)
(3) Power connector (PWR)
The PCA-BP-8UniBay-2U-G6 8SFF UniBay drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA/NVMe drives.
Figure 24 8SFF UniBay drive backplane
(1) x8 SlimSAS connector (SAS PORT)
(2) AUX ( AUX)
(3) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4)
(4) Power connector (POWER)
(5) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe B1/B2)
(6) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4)
(7) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2)
PCIe5.0 x8 description:
·     PCIe5.0: Fifth-generation signal speed.
·     x8: Bus bandwidth.
The PCA-BP-8LFF-2U-G6 8LFF SAS/SATA drive backplane can be installed at the server front to support eight 3.5-inch SAS/SATA drives.
Figure 25 8LFF SAS/SATA drive backplane
(1) X8 Mini-SAS-HD connector (SAS PORT)
(2) Power connector (PWR)
(3) AUX connector (AUX)
The PCA-BP-12LFF-2U-G6 12LFF SAS/SATA drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA drives.
Figure 26 12LFF SAS/SATA drive backplane
(1) x4 SlimSAS connector (SAS PORT 2), managing the last four SAS/SATA drives on the backplane
(2) Power connector 2 (PWR 2)
(4) Power connector 1 (PWR 1)
(5) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane
The PCA-BP-12LFF-4NVMe-2U-G6 12LFF drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives, including eight SAS/SATA drives and four SAS/SATA/NVMe drives.
Figure 27 8SAS/SATA+4UniBay drive backplane
(1) MCIO connector A3 (PCIe5.0 x4)(NVMe-A3), supporting NVMe drive 9
(2) x4 SlimSAS connector (SAS PORT 2), managing the last four SAS/SATA drives on the backplane
(3) Power connector 2 (PWR 2)
(4) AUX connector 1(AUX 1)
(5) Power connector 1 (PWR 1)
(6) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane
(7) MCIO connector A4 (PCIe5.0 x4)(NVMe-A4), supporting NVMe drive 8
(8) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe-A1/A2), supporting NVMe drives 10 and 11
For more information about drive numbering, see "Drive numbering."
The PCA-BP-12LFF-EXP-2U-G6 12LFF drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives, including four SAS/SATA drives and eight SAS/SATA/NVMe drives. The drive backplane integrates an Expander chip to manage 12 SAS/SATA drives through an x8 SlimSAS connector. The drive backplane also provides three downlink interfaces to connect to other drive backplanes and support more drives.
Figure 28 4SAS/SATA+8UniBay drive backplane
(1) x8 SlimSAS uplink interface (SAS PORT), managing all drives on the backplane
(2) x4 SlimSAS downlink interface 3 (SAS EXP3)
(3) Power connector 2 (PWR2)
(4) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe-B1/B2), supporting NVMe drives 6 and 7
(5) Power connector 1 (PWR1)
(6) x8 SlimSAS downlink interface 2 (SAS EXP2)
(7) x4 SlimSAS downlink interface 1 (SAS EXP1)
(8) AUX connector (AUX)
(9) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4), supporting NVMe drives 4 and 5
(10) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4), supporting NVMe drives 8 and 9
(11) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2), supporting NVMe drives 10 and 11
The PCA-BP-12LFF-UniBay-2U-G6 12LFF UniBay drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives.
Figure 29 12LFF UniBay drive backplane
(3) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe-B1/B2)
(4) Power connector 2 (PWR 2)
(5) AUX connector 1 (AUX 1)
(6) MCIO connector C1 (PCIe5.0 x4)(NVMe-C1)
(7) Power connector 1 (PWR 1)
(8) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane
(9) MCIO connector C3/C4 (PCIe5.0 x8)(NVMe-C3/C4)
(10) MCIO connector C2 (PCIe5.0 x4)( NVMe-C2)
(11) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe-B3/B4)
(12) MCIO connector A4 (PCIe5.0 x4)(NVMe-A4)
(13) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe-A1/A2)
The PCA-BP-25SFF-2U-G6 25SFF drive backplane can be installed at the server front to support twenty-five 2.5-inch SAS/SATA/NVMe drives, including 17 SAS/SATA drives and 8 SAS/SATA/NVMe drives. The drive backplane can use an x8 SlimSAS connector to manage 25 SAS/SATA drives. The drive backplane also integrates an Expander chip and three downlink interfaces to connect to other drive backplanes and support more drives.
Figure 30 17SAS/SATA+8UniBay drive backplane
(1) x4 SlimSAS downlink interface 3 (SAS EXP 3)
(2) x8 SlimSAS uplink interface (SAS PORT), managing all drives on the backplane
(3) x8 SlimSAS downlink interface 2 (SAS EXP 2)
(4) x4 SlimSAS downlink interface 1 (SAS EXP 1)
(6) Power connector 2 (PWR 2)
(7) MCIO connector 4 (PCIe5.0 x8)(NVMe 4), supporting NVMe drives 17 and 18
(9) MCIO connector 3 (PCIe5.0 x8)(NVMe 3), supporting NVMe drives 19 and 20
(10) MCIO connector 2 (PCIe5.0 x8)(NVMe 2), supporting NVMe drives 21 and 22
(11) Power connector 3 (PWR 3)
(12) MCIO connector 1 (PCIe5.0 x8)(NVMe 1), supporting NVMe drives 23 and 24
The PCA-BP-2LFF-2U-G6 2LFF SAS/SATA drive backplane is installed at the server rear to support two 3.5-inch SAS/SATA drives.
Figure 31 2LFF SAS/SATA drive backplane
(1) x4 Mini-SAS-HD connector (SAS PORT1)
(2) AUX connector (AUX1)
(3) Power connector (PWR1)
The PCA-BP-4LFF-2U-G6 4LFF SAS/SATA drive backplane is installed at the server rear to support four 3.5-inch SAS/SATA drives.
Figure 32 4LFF SAS/SATA drive backplane
(1) AUX connector (AUX)
(3) x4 Mini-SAS-HD connector (SAS PORT)
The PCA-BP-2SFF-2U-G6 2SFF SAS/SATA drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA drives.
Figure 33 2SFF SAS/SATA drive backplane
(1) Power connector (PWR)
(2) x4 Mini-SAS-HD connector (SAS PORT)
The PCA-BP-2SFF-2UniBay-2U-G6 2SFF UniBay drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA/NVMe drives.
Figure 34 2SFF UniBay drive backplane
(3) SlimSAS connector (PCIe4.0 x8)(NVME)
(4) AUX connector (AUX)
PCIe4.0 x8 description:
·     PCIe4.0: Fifth-generation signal speed.
The PCA-BP-4SFF-2U-G6 4SFF SAS/SATA drive backplane is installed at the server rear to support four 2.5-inch SAS/SATA drives.
Figure 35 4SFF SAS/SATA drive backplane
(1) x4 Mini-SAS-HD connector (SAS PORT)
The PCA-BP-4SFF-4UniBay-2U-G6 4SFF UniBay drive backplane is installed at the server rear to support four 2.5-inch SAS/SATA/NVMe drives.
Figure 36 4SFF UniBay drive backplane
(3) MCIO connector B1/B2 (PCIe5.0 x8)(NVME-B1/B2)
(4) MCIO connector B3/B4 (PCIe5.0 x8)(NVME-B3/B4)
(5) x4 Mini-SAS-HD connector (SAS PORT)
The PCA-BP-8E1S-2U-G6 8E1.S drive backplane is installed at the server rear to support eight 15 mm E1.S drives.
Figure 37 E1.S drive backplane
(2) MCIO connector A1/A2 (PCIe5.0 x8)( EDSFF-A1/A2)
(3) Power connector (PWR 1)
(4) MCIO connector A3/A4 (PCIe5.0 x8)( EDSFF-A3/A4)
(5) MCIO connector B1/B2 (PCIe5.0 x8)(EDSFF-B1/B2)
(6) MCIO connector B3/B4 (PCIe5.0 x8)(EDSFF-B3/B4)
Riser cards
To expand the server with PCIe modules, install riser cards on the PCIe riser connectors.
Each PCIe slot in a riser card can supply a maximum of 75 W of power to the PCIe module. You must connect a separate power cord to the PCIe module if it requires more than 75 W of power.
If a processor is faulty or absent, the PCIe slots connected to it are unavailable.
The slot number of a PCIe slot varies by the PCIe riser connector that holds the riser card. For example, slot 1/4 represents PCIe slot 1 if the riser card is installed on connector 1 and represents PCIe slot 4 if the riser card is installed on connector 2. For information about PCIe riser connector locations, see "Rear panel view."
RC-3FHFL-2U-G6
Figure 38 RC-3FHFL-2U-G6 (1)
(1) PCIe5.0 x16 (16,8,4,2,1) slot 2/5
(2) PCIe5.0 x16 (16,8,4,2,1) slot 3/6
(3) GPU module power connector
(4) PCIe5.0 x16 (16,8,4,2,1) slot 1/4*
PCIe5.0 x16 (16,8,4,2,1) description:
·     x16: Connector bandwidth.
·     (16,8,4,2,1): Compatible bus bandwidth, including x16, x8, x4, x2, and x1.
slot 1/4: When the riser card is installed in PCIe riser card slot 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser card slot 2, this slot corresponds to PCIe slot 4. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
Figure 39 RC-3FHFL-2U-G6 (2)
(5) MCIO connector 2-C
(6) MCIO connector 2-A
(7) MCIO connector 1-A
(8) MCIO connector 1-C
RC-3FHHL-2U-G6
Figure 40 RC-3FHHL-2U-G6 (1)
(1) PCIe5.0 x16 (8,4,21) slot 2/5
(2) PCIe5.0 x16 (8,4,2,1) slot 3/6
(3) PCIe5.0 x16 (16,8,4,2,1) slot 1/4*
slot 1/4: When the riser card is installed in PCIe riser connector 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser connector 2, this slot corresponds to PCIe slot 4. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
Figure 41 RC-3FHHL-2U-G6 (2)
(4) MCIO connector 1-A
(5) MCIO connector 1-C
RC-FHHL-2U-G6
Figure 42 RC-FHHL-2U-G6
(1) PCIe5.0 x16 (16,8,4,2,1) slot 7 slot 3/6*
(2) Rear 2SFF SAS/SATA drive backplane
·     slot 3/6: When the riser card is installed in PCIe riser connector 1, this slot corresponds to PCIe slot 3. When the riser card is installed in PCIe riser connector 2, this slot corresponds to PCIe slot 6. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
·     For more information about the rear 2SFF SAS/SATA drive backplane, see "Rear 2SFF SAS/SATA drive backplane."
RC-2HHHL-R4-2U-G6
Figure 43 RC-2HHHL-R4-2U-G6
(1) SLOT 2 cable
(2) AUX connector
(3) PCIe5.0 x16 (8,4,2,1) slot 8/10
(4) PCIe5.0 x16 (8,4,2,1) slot 7/9
(5) Power connector
(6) SLOT 1 cable
PCIe5.0 x16 (8,4,2,1) description:
·     (8,4,2,1): Compatible bus bandwidth, including x8, x4, x2, and x1.
slot 7/9: When the riser card is installed in PCIe riser connector 3, this slot corresponds to PCIe slot 7. When the riser card is installed in PCIe riser connector 4, this slot corresponds to PCIe slot 9. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
PCA-R4900-4GPU-G6
Figure 44 PCA-R4900-4GPU-G6 (1)
(1) PCIe5.0 x16 (8,4,2,1) slot 14
(2) PCIe5.0 x16 (8,4,2,1) slot 13
(3) PCIe5.0 x16 (8,4,2,1) slot 12
(4) PCIe5.0 x16 (8,4,2,1) slot 11
(5) GPU module power connector
(6) GPU module power connector
Figure 45 PCA-R4900-4GPU-G6 (2)
(7) GPU module power connector
(8) GPU module power connector
Figure 46 PCA-R4900-4GPU-G6 (3)
(9) PCIe5.0 x16 (16,8,4,2,1) slot 6
(10) PCIe5.0 x16 (16,8,4,2,1) slot 3
An LCD smart management module displays basic server information, operating status, and fault information, and provides diagnostics and troubleshooting capabilities. You can locate and troubleshoot component failures by using the LCD module in conjunction with the event logs generated in HDM.
Figure 47 LCD smart management module
Table 17 LCD smart management module description
No.
Item
1
Mini-USB connector
Used for upgrading the firmware of the LCD module.
2
LCD module cable
Connects the LCD module to the system board of the server. For information about the LCD smart management module connector on the system board, see "System board."
3
LCD module shell
Protects and secures the LCD screen.
4
LCD screen
Fan modules
The server supports four hot swappable fan modules. The server supports N+1 fan module redundancy. Figure 48 shows the layout of the fan modules in the chassis.
The server uses intelligent fan energy-saving and noise-reduction technology, which integrates multiple AI algorithms. It can monitor the temperature, power, and other status information of the device in real-time to obtain the optimal fan adjustment policy. Then, it dynamically adjusts the fan duty cycle configuration to meet the device's energy-saving and noise-reduction requirements.
Figure 48 Fan module layout
PCIe slot
The server supports installing installing riser cards and rear GPU modules. The PCIe slot numbers vary by configuration.
Figure 49 PCIe slot numbering when riser cards are installed at the server rear
Figure 50 PCIe slot numbering when rear GPU modules are installed
PCIe modules
Typically, the PCIe modules are available in the following standard form factors:
·     LP—Low profile.
·     FHHL—Full height and half length.
·     FHFL—Full height and full length.
·     HHHL—Half height and half length.
·     HHFL—Half height and full length.
The following PCIe modules require PCIe I/O resources: Storage controllers, FC HBAs, and GPU modules. Make sure the number of such PCIe modules installed does not exceed 11.
Storage controllers
The server supports the following types of storage controllers:
·     Embedded VROC controllerEmbedded in the server and does not require installation.
·     Standard storage controllerComes in a standard PCIe form factor and typically requires a riser card for installation.
For some storage controllers, you can order a power fail safeguard module to prevent data loss from power outages. This module provides a flash card and a supercapacitor. When a system power failure occurs, the supercapacitor provides power for a minimum of 20 seconds. During this interval, the storage controller can transfer data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data. If the storage controller contains a built-in flash card, you can order only a supercapacitor.
Item
Specifications
Embedded in PCH of the system board
Number of internal ports
16 internal SAS ports (compatible with SATA)
Connectors
Four onboard ×4 SlimSAS connectors
Drive interface
6 Gbps SATA 3.0
Supports drive hot swapping
PCIe interface
PCIe3.0 ×4
RAID levels
0, 1, 5, 10
Built-in cache memory
N/A
Built-in flash
N/A
Power fail safeguard module
Not supported
Firmware upgrade
Upgrade with the BIOS
Standard storage controllers
For more information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
NVMe VROC modules
Model
RAID levels
Compatible NVMe SSDs
NVMe-VROC-Key-S
0, 1, 10
All NVMe drives
NVMe-VROC-Key-P
0, 1, 5, 10
All NVMe drives
Figure 51 SATA M.2 expander module front view
(1) SATA data cable connector
(2) SATA M.2 SSD card slot 1
Figure 52 SATA M.2 expander module rear view
(1) SATA M.2 SSD card slot 2
Figure 53 NVMe M.2 expander module
(1) NVMe M.2 SSD card slot 1
(2) NVMe M.2 SSD card slot 2
The server management module is installed on the system board to provide I/O connectors and HDM out-of-band features for the server.
Figure 54 Server management module
(1) VGA connector
(2) Two USB 3.0 connectors
(3) HDM dedicated management interface
(4) UID LED
(5) HDM serial port
(6) iFIST module (optional)
(7) NCSI connector
Serial & DSD module
The serial & DSD module can be installed in the slot on the server rear panel. The module provides two SD slots and forms RAID 1 by default.
Figure 55 Serial & DSD module
Table 18 Component description
Item
1
SD card slot 1
2
SD card slot 2
3
Serial port
B/D/F information
You can obtain B/D/F information by using one of the following methods:
·     BIOS log—Search the dumpiio keyword in the BIOS log.
·     UEFI shell—Execute the pci command. For information about how to execute the command, execute the help pci command.
·     Operating system—The obtaining method varies by OS.
¡     For Linux, execute the lspci command.
If Linux does not support the lspci command by default, use the software package manager supported by the operating system to obtain and install the pci-utils package.
¡     For Windows, install the pciutils package, and then execute the lspci command.
¡     For VMware, execute the lspci command.
Before you begin
Before you perform a managed removal of an OCP network adapter, perform the following tasks:
·     Use the OS compatibility query tool at http://www.h3c.com/en/home/qr/default.htm?id=66 to obtain operating systems that support managed removal of OCP network adapters.
·     Make sure the BIOS version is 6.00.15 or higher, the HDM2 version is 1.13 or higher, and the CPLD version is V001 or higher.
This section uses an OCP network adapter in slot 16 as an example.
To perform a hot removal:
1.     Access the operating system.
2.     Execute the dmidecode -t 9 command to search for the bus address of the OCP network adapter. As shown in Figure 56, the bus address of the OCP network adapter in slot 16 is 0000:31:00.0.
Figure 56 Searching for the bus address of an OCP network adapter by slot number
3.     Execute the echo 0 > /sys/bus/pci/slots/slot number/power command, where slot number represents the number of the slot where the OCP network adapter resides.
Figure 57 Executing the echo 0 > /sys/bus/pci/slots/slot number/power command
4.     Identify whether the OCP network adapter has been disconnected:
¡     Observe the OCP network adapter LED. If the LED is off, the OCP network adapter has been disconnected.
¡     Execute the lspci vvv s 0000:31:00.0 command. If no output is displayed, the OCP network adapter has been disconnected.
Figure 58 Identifying OCP network adapter status
5.     Replace the OCP network adapter.
6.     Identify whether the OCP network adapter has been connected:
¡     Observe the OCP network adapter LED. If the LED is on, the OCP network adapter has been connected.
¡     Execute the lspci vvv s 0000:31:00.0 command. If an output is displayed, the OCP network adapter has been connected.
Figure 59 Identifying OCP network adapter status
7.     Identify whether any exception exists. If any exception occurred, contact H3C Support.
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than what is stated because of poor site cooling performance. In a real data center, the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
Item
Specifications
Minimum: 5°C (41°F)
Maximum: 45°C (113°F)
CAUTION CAUTION:
The maximum temperature varies by hardware option presence. For more information, see "Operating temperature requirements."
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
8% to 90%, noncondensing
Storage humidity
5% to 95%, noncondensing
Operating altitude
–60 m to +3000 m (–196.85 ft to +9842.52 ft)
The allowed maximum temperature decreases by 0.33°C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft)
Storage altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
General guidelines
The 8SFF drives installed in slots 0 to 7. For more information about drive slots, see "Drive numbering."
When a fan fails, the maximum server operating temperature decreases by 5°C (41°F). The GPU performance and performance of processors with a TDP of more than 165 W might decrease.
When CRPS-195mm 2000 W Platinum AC power supplies are configured, the maximum operating temperatures are 3°C (37.4°F) lower than those described in the table.
Drive configuration
Maximum operating temperature
Remarks
30°C
35°C
40°C
·     8LFF
·     8SFF (TOSHIBA SAS SFF HDDs not used)
·     16SFF
·     E1.S
All hardware options are supported.
·     The server does not support A40 GPUs.
·     With the 4GPU module configured, processors more than 270 W are not supported.
·     The server does not support GPUs.
·     The server does not support U.2 NVMe SSDs.
·     The server does not support rear drives.
·     The server does not support processors more than 165 W.
·     The server does not support Delta DPS-1600AB-13 R 1600 W Platinum AC power supplies.
Fan speed is not limited.
·     8SFF (TOSHIBA SAS SFF HDDs adpoted)
·     12LFF
·     25SFF
·     24SFF
·     The server does not suppoer the A40/A16 GPU.
·     The server does not support the A100-80G/A40/A16 GPU.
·     With drives (including HDDs, U.2/E1.S NVMe SSDs and excluding SATA/SAS SSDs) installed at the server rear, processors more than 300 W are not supported.
·     The server does not support Delta DPS-1600AB-13 R 1600W Platinum AC power supplies.
·     With the 4GPU module installed at the server rear, processors more than 270 W are not supported.
·     With the A2 GPU installed at the server rear, processors more than 250 W are not supported.
·     With E1.S NVMe drives more than 3.84 TB installed at the server rear, processors more than 250 W are not supported.
When 8SFF drvie configuration uses TOSHIBA SAS SFF HDDs, the fan speed is limited to 90% of the maximum power
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     E-mail: [email protected]
·     Website: http://www.h3c.com
Appendix F  Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
C
CPLD
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits.
G
GPU module
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance.
H
HDM
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
K
KVM
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server.
N
NVMe VROC module
A module that works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
S
Security bezel
A locking bezel mounted to the front of a server to prevent unauthorized access to modules such as hard drives.
U
U
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks.
A UniBay drive backplane supports both SAS/SATA and NVMe drives.
UniSystem
UniSystem provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools.
V
VMD
VMD provides hot removal, management and fault-tolerance functions for NVMe drives to increase availability, reliability, and serviceability.
Appendix G  Acronyms
Acronym
Full name
B
BIOS
Basic Input/Output System
C
CMA
Cable Management Arm
CPLD
Complex Programmable Logic Device
D
DCPMM
Data Center Persistent Memory Module
DDR
Double Data Rate
DIMM
Dual In-Line Memory Module
DRAM
Dynamic Random Access Memory
DVD
Digital Versatile Disc
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDD
Hard Disk Drive
HDM
I
IDC
Internet Data Center
iFIST
integrated Fast Intelligent Scalable Toolkit
K
KVM
Keyboard, Video, Mouse
L
LRDIMM
Load Reduced Dual Inline Memory Module
N
NCSI
Network Controller Sideband Interface
NVMe
Non-Volatile Memory Express
P
PCIe
Peripheral Component Interconnect Express
POST
Power-On Self-Test
R
RAID
Redundant Array of Independent Disks
RDIMM
Registered Dual Inline Memory Module
S
SAS
Serial Attached Small Computer System Interface
SATA
Serial ATA
SD
Secure Digital
SDS
Secure Diagnosis System
SFF
Small Form Factor
sLOM
Small form factor Local Area Network on Motherboard
SSD
Solid State Drive
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
U
UID
Unit Identification
UPI
Ultra Path Interconnect
UPS
Uninterruptible Power Supply
USB
Universal Serial Bus
V
VROC
Virtual RAID on CPU
VMD
Volume Management Device
