02-System Management Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S9825 & S9855 Switch Series Configuration Guides-R9126Pxx-6W10002-System Management Configuration Guide
03-Hardware resource management configuration
03-Hardware resource management configuration 147.01 KB
Managing hardware resources· 1
Hardware resource management tasks at a glance· 1
Monitoring CPU usage· 2
Configuring CPU usage alarm·· 2
Configuring CPU usage tracking· 3
Displaying CPU usage monitoring information· 3
Monitoring memory usage· 4
Setting memory alarm thresholds· 4
Displaying memory usage monitoring information· 5
Monitoring resource usage· 6
Configuring resource monitoring· 6
Displaying resource monitoring information· 7
Monitoring device temperature· 7
Setting the temperature alarm thresholds· 7
Displaying device temperature information· 8
Monitoring fans· 8
Displaying fan information· 8
Setting the port status detection timer 8
Verifying and diagnosing transceiver modules· 8
Verifying transceiver modules· 8
Diagnosing transceiver modules· 9
Managing 400-GE transceiver modules· 9
Enabling lanes on 400-GE transceiver modules· 9
Setting the frequency for a transceiver optical channel 10
Setting the transmit power for a transceiver optical channel 10
Setting a power mode for 400-GE transceiver modules· 11
Configuring pre-cursor, post-cursor, and amplitude· 11
Displaying 400-GE transceiver module information· 12
Resetting 400-GE transceiver modules· 12
Specifying a diagnostic selector for a transceiver module· 12
Enabling loopback testing on a transceiver module lane· 13
Specifying the signal mode and PRBS pattern for a transceiver module lane· 13
Configuring transceiver monitoring· 14
Displaying device hardware information· 14
Displaying device hardware electronic label information· 14
Displaying device hardware alarm information· 14
This chapter describes routine device hardware resource management tasks, including monitoring CPU and memory usage, displaying power supply and fan operating status, and configuring basic device operating parameters.
All hardware resource management tasks are optional. You can perform any of the tasks in any order.
·     Monitoring CPU usage
¡     Configuring CPU usage alarm
¡     Configuring CPU usage tracking
¡     Displaying CPU usage monitoring information
·     Monitoring memory usage
¡     Setting memory alarm thresholds
¡     Displaying memory usage monitoring information
·     Monitoring resource usage
¡     Configuring resource monitoring
¡     Displaying resource monitoring information
·     Monitoring device temperature
¡     Setting the temperature alarm thresholds
¡     Displaying device temperature information
·     Monitoring fans
·     Setting the port status detection timer
·     Verifying and diagnosing transceiver modules
¡     Verifying transceiver modules
¡     Diagnosing transceiver modules
·     Managing 400-GE transceiver modules
¡     Enabling lanes on 400-GE transceiver modules
¡     Setting the frequency for a transceiver optical channel
¡     Setting the transmit power for a transceiver optical channel
¡     Setting a power mode for 400-GE transceiver modules
¡     Configuring pre-cursor, post-cursor, and amplitude
¡     Displaying 400-GE transceiver module information
¡     Resetting 400-GE transceiver modules
·     Specifying a diagnostic selector for a transceiver module
·     Enabling loopback testing on a transceiver module lane
·     Specifying the signal mode and PRBS pattern for a transceiver module lane
·     Configuring transceiver monitoring
·     Displaying device hardware information
·     Displaying device hardware electronic label information
·     Displaying device hardware alarm information
The device samples CPU usage at 1-minute intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
The device supports the following CPU usage thresholds:
·     Minor threshold—If the CPU usage increases to or above the minor threshold but is less than the severe threshold, the CPU usage enters minor alarm state. The device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
·     Severe threshold—If the CPU usage increases above the severe threshold, the CPU usage enters severe alarm state. The device sends severe alarms periodically until the severe alarm is removed.
·     Recovery threshold—If the CPU usage decreases below the recovery threshold, the CPU usage enters recovered state. The device sends a recovery notification.
CPU usage alarms and notifications can be sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information about NETCONF and SNMP, see Network Management and Monitoring Configuration Guide. For more information about information center, see "Configuring the information center."
Figure 1 CPU alarms and alarm-removed notifications
2.     Set the CPU usage alarm thresholds.
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
By default, the CPU usage alarm threshold is 99%.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal service processing will be affected.
3.     Set the CPU usage alarm resending intervals.
By default, the minor CPU usage alarm resending interval and severe CPU usage alarm resending interval are 300 seconds and 60 seconds, respectively.
After you enable CPU usage tracking, the system samples CPU usage at intervals and saves the samples to a buffer. You can use the display cpu-usage history command to view the recent CPU usage.
2.     Set the sampling interval for CPU usage tracking.
By default, the sampling interval for CPU usage tracking is 1 minute.
3.     Enable CPU usage tracking.
By default, CPU usage tracking is enabled.
·     Display CPU usage monitoring settings.
·     Display the current CPU usage statistics.
display cpu-usage [ control-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] [ core { core-number | all } ] ]
·     Display the historical CPU usage statistics in a coordinate system.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space reaches the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules and processes.
You can use the display memory command to display memory usage information.
As shown in the following table and figure, the system supports the following free-memory thresholds:
As shown in Table 1 and Figure 2, the system supports the following free-memory thresholds:
·     Normal state threshold.
·     Minor alarm threshold.
·     Severe alarm threshold.
·     Critical alarm threshold.
Table 1 Memory alarm notifications and memory alarm-removed notifications
Notification
Triggering condition
Remarks
Minor alarm notification
The amount of free memory space decreases to or below the minor alarm threshold.
After generating and sending a minor alarm notification, the system does not generate and send any additional minor alarm notifications until the minor alarm is removed.
Severe alarm notification
The amount of free memory space decreases to or below the severe alarm threshold.
After generating and sending a severe alarm notification, the system does not generate and send any additional severe alarm notifications until the severe alarm is removed.
Critical alarm notification
The amount of free memory space decreases to or below the critical alarm threshold.
After generating and sending a critical alarm notification, the system does not generate and send any additional critical alarm notifications until the critical alarm is removed.
Critical alarm-removed notification
The amount of free memory space increases above the severe alarm threshold.
N/A
Severe alarm-removed notification
The amount of free memory space increases above the minor alarm threshold.
N/A
Minor alarm-removed notification
The amount of free memory space increases above the normal state threshold.
N/A
Figure 2 Memory alarm notifications and alarm-removed notifications
2.     Set the memory usage threshold.
By default, the memory usage threshold is 100%.
3.     Set the free-memory thresholds.
memory-threshold [ slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value
The default settings are as follows:
¡     Minor alarm threshold—256 MB.
¡     Severe alarm threshold—192 MB.
¡     Critical alarm threshold—128 MB.
¡     Normal state threshold—320 MB.
·     Display memory usage information.
·     Display memory alarm thresholds and statistics.
The resource monitoring feature enables the device to monitor the available amounts of types of resources, for example, the space for ARP entries. The device samples the available amounts periodically and compares the samples with resource depletion thresholds to identify the resource depletion status.
The device supports a minor resource depletion threshold and a severe resource depletion threshold for each supported resource type.
·     If the available amount is equal to or less than the minor resource depletion threshold but greater than the severe resource depletion threshold, the resource type is in minor alarm state.
·     If the available amount is equal to or less than the severe resource depletion threshold, the resource type is in severe alarm state.
·     If the available amount increases above the minor resource depletion threshold, the resource type is in recovered state.
When a resource type enters severe alarm state, the device issues a severe alarm. If the resource type stays in severe alarm state, the device resends severe alarms periodically.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
Resource depletion alarms can be sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information about NETCONF and SNMP, see Network Management and Monitoring Configuration Guide. For more information about information center, see "Configuring the information center."
Figure 3 Resource depletion alarms and alarm-removed notifications
2.     Set resource depletion thresholds.
The default varies by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
3.     Specify destinations for resource depletion alarms.
By default, resource depletion alarms are sent to NETCONF, SNMP, and the information center.
4.     Enable resending of minor resource depletion alarms.
resource-monitor minor resend enable
By default, resending of minor resource depletion alarms is enabled.
To display resource monitoring information, execute the following command in any view:
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
The device monitors its temperature based on the following thresholds:
·     Low-temperature threshold.
·     High-temperature warning threshold.
·     High-temperature alarming threshold.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
2.     Configure the temperature alarm thresholds.
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
The high-temperature alarming threshold must be higher than the high-temperature warning threshold, and the high-temperature warning threshold must be higher than the low-temperature threshold.
To display device temperature information, execute the following command in any view:
Monitoring fans
·     Display fan tray operating status information.
display fan [ slot slot-number [ fan-id ] ]
·     Display electronic label information for a fan tray.
display device manuinfo slot slot-number fan fan-id
The device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
2.     Set the port status detection timer.
shutdown-interval time
By default, the port status detection timer is 30 seconds.
You can use one of the following methods to verify the genuineness of a transceiver module:
·     Display the key parameters of a transceiver module, including its transceiver type, connector type, central wavelength of the transmit laser, transfer distance, and vendor name.
·     Display its electronic label. The electronic label is a profile of the transceiver module and contains the permanent configuration, including the serial number, manufacturing date, and vendor name. The data was written to the transceiver module or the device's storage component during debugging or testing of the transceiver module or device.
The device regularly checks transceiver modules for their vendor names. If a transceiver module does not have a vendor name or the vendor name is not H3C, the device repeatedly outputs traps and log messages. For information about logging rules, see "Configuring the information center."
To verify transceiver modules, execute the following commands in any view:
·     Display the key parameters of transceiver modules.
·     Display the electrical label information of transceiver modules.
The device provides the alarm and digital diagnosis functions for transceiver modules. When a transceiver module fails or is not operating correctly, you can perform the following tasks:
·     Check the alarms that exist on the transceiver module to identify the fault source.
·     Examine the key parameters monitored by the digital diagnosis function, including the temperature, voltage, laser bias current, TX power, and RX power.
To diagnose transceiver modules, execute the following commands in any view:
·     Display transceiver alarms.
·     Display the current values of the digital diagnosis parameters on transceiver modules.
·     Display key optical parameters for transceiver modules.
display transceiver optics interface [ interface-type interface-number ]
Only the QSFPDD-400G-ZR transceiver module supports this command.
·     Display the versatile diagnostics monitoring (VDM) information of a transceiver module.
display transceiver vdm interface interface-type interface-number vdm-id vdm-id
This command is available only for 400G transceiver modules that support CMIS 4.0.
Use this task only to verify that a transceiver module is normal.
Disabling a lane on a transceiver module will stop signal transmission on the lane.
The lane enablement setting is saved in a register on the transceiver module. It is not saved to the configuration file.
2.     Enter Ethernet interface view.
3.     Enable a lane on the transceiver module.
transceiver lane lane-number enable
By default, the lanes on the transceiver module are enabled.
Perform this task to set the frequency and the frequency grid for a transceiver optical channel.
Only the QSFPDD-400G-ZR transceiver module supports this task.
Before performing this task, calculate the frequency for a transceiver optical channel based on the grid and the reference frequency of 193100000 MHz. If the frequency is calculated incorrectly, the configuration by this command will fail. To calculate the frequency for a transceiver optical channel:
Frequency for a transceiver optical channel = 193100000 MHz ± Frequency grid for a transceiver optical channel × n. The value for n is an integer.
3.     Set the frequency and the frequency grid for a transceiver optical channel.
transceiver optical-channel optical-channel-number frequency frequency-value [ grid grid-value ]
The default varies by transceiver module model.
Perform this task to set the transmit power for a transceiver optical channel.
This device does not save this task setting to the configuration file but to the transceiver internal register. If the transceiver module is hot swapped or reset, you must reconfigure this task for it to take effect.
2.     Enter 400-GE Ethernet interface view and its breakout interface view.
3.     Set the transmit power for an optical channel.
transceiver optical-channel optical-channel-number tx-power power-value
By default, the transmit power of an optical channel is –10 dBm.
A transceiver module generally operates in high power mode. If the transceiver module does not work for a long time, you can switch the transceiver module to low power mode to reduce power consumption. In low power mode, the transceiver module does not transmit signals unless you switch the transceiver to high power mode.
The power mode setting is saved in a register on the transceiver module. It is not saved to the configuration file.
3.     Set a power mode for the transceiver module.
transceiver power-mode { high | low }
The default settings vary by transceiver module model.
Use this task for debugging and testing on high speed signals to achieve optimal link status. The default settings are generally applied. To change the default settings, contact professional engineers to avoid transceiver module exceptions.
As a best practice, do not perform this task when the interface is transmitting traffic. This command enables the device to automatically disable and then enable the transceiver module, which affects traffic transmission.
The configuration is saved in a register on the transceiver module. It is not saved to the configuration file.
3.     Configure the pre-cursor and post-cursor equalizers, and amplitude for the transceiver module.
transceiver lane [ lane-number ] equalization { precursor precursor-value | postcursor postcursor-value | amplitude amplitude-value }
Perform all display tasks in in any view.
·     Display the active control information of 400-GE transceiver modules.
display transceiver active-control interface [ interface-type interface-number ]
·     Display the advertising information of 400-GE transceiver modules.
display transceiver advertising interface [ interface-type interface-number ]
·     Display application related information for 400-GE transceiver modules.
display transceiver application interface [ interface-type interface-number ]
·     Display 400-GE transceiver module status information.
display transceiver status interface [ interface-type interface-number ]
Use this feature only when you cannot troubleshoot transceiver modules by using other methods.
This feature will restart transceiver modules.
To reset 400-GE transceiver modules, execute the following command in user view:
reset transceiver interface [ interface-type interface-number]
This task allows you to specify a diagnostic selector for a transceiver module and displays specified diagnostic information.
This task is available only for 400G transceiver modules that support CMIS 4.0.
This task settings will be saved in a register of the transceiver module. If the transceiver module has a power loss, the task settings will be cleared. You must reconfigure the task after a power recovery.
2.     Enter interface view.
3.     Specify a diagnostic selector for the transceiver module and display the specified diagnostic information.
transceiver diagnostic selector selector-id
By default, no diagnostic selector is specified for a transceiver module.
This task allows you to enable loopback testing on a transceiver module lane and specify the loopback testing mode.
This task tests whether messages can be forwarded correctly between the designated transmitter and receiver and helps identify the point of failure when the transceiver module fails to forward messages.
3.     Enable loopback testing on a transceiver module lane and specify a loopback testing mode.
transceiver lane [ lane-number ] loopback loopback-mode
By default, loopback testing is disabled for transceiver module lanes.
3.     Specify the signal mode and PRBS pattern for a transceiver module lane.
transceiver lane [ lane-number ] pattern [ host-checker | host-generator media-checker | media-generator ] prbs-pattern
The default setting varies by transceiver module model.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log to notify users.
2.     Enable transceiver monitoring.
transceiver monitor enable [ grey | tunable ]
By default, transceiver monitoring is disabled.
3.     Set the transceiver monitoring interval.
transceiver monitor interval interval
By default, the transceiver monitoring interval is 600 seconds.
To display device hardware information, execute the following command in any view:
display device [ flash | usb ] [ slot slot-number | verbose ]
To display hardware electronic label information for the device, execute the following command in any view:
To display device hardware alarm information, execute the following command in any view:
display alarm [ slot slot-number ]
