00-Preface | 101.16 KB |
Preface
· This command reference describes IP multicast configuration commands. It covers the commands for configuring IPv4 multicast and IPv6 multicast. With these multicast configuration commands, you can implement efficient point-to-multipoint data transmission in your network.
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, and configuration files.
· FTP and TFTP.
· Software upgrade.
· Tcl and Python.
· Automatic configuration.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
