14-WLAN Configuration Guide (AC)
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810[830][2600][3600] Routers Configuration Guides(V7)-R0821-6W50114-WLAN Configuration Guide (AC)
12-Channel scanning configuration
12-Channel scanning configuration 108.96 KB
Configuring channel scanning
About channel scanning
Channel scanning enables APs to scan channels and capture wireless packets. The device analyzes the captured wireless packets to obtain wireless service information, including interferences, error bit rate, and wireless signal strength. Channel scanning provides data for WLAN RRM and WIPS, and enhances wireless service quality.
The term "AC" in this document refers to MSR routers that can function as ACs. For more information, see "Compatibility of hardware and AC functionality."
Basic concepts
·     Scanning period—In this period, an AP only scans a channel and does not provide wireless services.
·     Service period—In this period, an AP scans its working channel and provides wireless services simultaneously for a time period that is the same as the scanning period. After that, the AP only provides wireless services.
Work mechanism
An AP scans each channel on the channel scanning list in turn regardless of whether the AP provides wireless services, and each channel is scanned for a scanning period. If the AP does not provide wireless services, it starts scanning periods consecutively. If the AP provides wireless services, it starts service periods and scanning periods alternatively.
For example, Figure 1 shows the channel scanning mechanism for an AP when the AP works on channel 6 and the channel scanning list contains channels 1, 6, and 11.
Figure 1 Channel scanning mechanism
Restrictions: Hardware compatibility with channel scanning
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
Restrictions and guidelines: Channel scanning configuration
You can configure APs by using the following methods:
·     Configure APs one by one in AP view.
·     Assign APs to an AP group and configure the AP group in AP group view.
·     Configure all APs in global configuration view.
For an AP, the settings made in these views for the same parameter take effect in descending order of AP view, AP group view, and global configuration view.
Channel scanning tasks at a glance
To configure channel scanning, perform the following tasks:
·     Setting the scanning period
·     Setting the maximum service period
·     Setting the service idle timeout timer
·     (Optional.) Configuring the channel scanning blacklist or whitelist
·     (Optional.) Configuring all-channel scanning
·     (Optional.) Scanning only the working channel
The scanning period defines the time period in which an AP scans a channel. In a service period, an AP scans its working channel and provides wireless services simultaneously for a time period that is the same as the scanning period.
The scanning period cannot be greater than the maximum service period.
2.     Enter AP view or an AP group's AP model view.
¡     Enter AP view.
wlan ap ap-name
¡     Execute the following commands in sequence to enter an AP group's AP model view:
wlan ap-group group-name
ap-model ap-model
3.     Enter radio view.
radio radio-id
4.     Set the scanning period.
scan scan-time scan-time
By default:
¡     In radio view, a radio uses the configuration in an AP group's radio view.
¡     In an AP group's radio view, the scanning period is 100 milliseconds.
To ensure both scanning and service quality, you can set the maximum service period. When the maximum service period is reached, the AP starts a scanning period regardless of whether it has traffic to forward. To ensure wireless service quality, you can configure the AP to not limit the service period. The AP does not start a scanning period unless the service idle timeout timer expires.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Set the maximum service period.
scan max-service-time { max-service-time | no-limit }
By default:
¡     In an AP group's radio view, the maximum service period 5000 milliseconds.
During a service period, an AP does not begin a new scanning period until the current service period exceeds the scanning period even if the specified service idle timeout timer expires.
The service idle timeout timer cannot be greater than the maximum service period.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Set the service idle timeout timer.
scan idle-time idle-time
By default:
¡     In radio view, a radio uses the configuration in an AP group's radioview.
¡     In an AP group's radioview, the service idle timeout timer is 100 milliseconds.
If you configure the blacklist for an AP, the AP will not scan non-working channels in the blacklist. If you configure the whitelist for an AP, the AP will scan only channels in the whitelist and the working channel.
You cannot configure both the channel scanning blacklist and whitelist for the same AP.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Choose one option as needed:
¡     Configure the channel scanning blacklist.
scan channel blacklist channel-list
¡     Configure the channel scanning whitelist.
scan channel whitelist channel-list
By default:
¡     In an AP group's radioview, no channel scanning blacklist or whitelist is configured.
An AP alternatively scans 2.4 GHz channels and 5 GHz channels at the specified interval when all-channel scanning is enabled. When all-channel scanning is disabled, an AP scans only channels of the configured band.
This feature is applicable only to dual-band radios.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.     Configure all-channel scanning.
scan mode all { disable | enable }
By default:
¡     In an AP group's radioview, all-channel scanning is disabled.
5.     Set the interval for the radio to scan all channels.
scan mode all interval interval-value
By default:
¡     In an AP group's radioview, the interval for radios to scan all channels is 3000 milliseconds.
Enable this feature to enable an AP to scan only the working channel.
¡     Enter AP view.
wlan ap ap-name
ap-model ap-model
3.     Enter Radio view.
radio radio-id
4.     Enable the radio to scan only the working channel.
scan work-channel-only { disable | enable }
By default:
¡     In an AP group's radio view, a radio scans all supported channels in turn.
Channel scanning configuration examples
Example: Configuring relative forwarding preferred channel scanning
To ensure both channel scanning and wireless service quality, configure channel scanning and set the maximum service period for AP 1, as shown in Figure 2.
Figure 2 Network diagram
# Create a manual AP and specify the model and serial ID.
<AC> system-view
[AC] wlan ap ap1 model WA4320i-ACN
[AC-wlan-ap-ap1] serial-id 219801A0CNC138011454
# Enter radio view of radio 1.
[AC-wlan-ap-ap1] radio 1
# Set the scanning period to 200 milliseconds.
[AC-wlan-ap-ap1-radio-1] scan scan-time 200
# Set the maximum service period to 5000 milliseconds.
[AC-wlan-ap-ap1-radio-1] scan max-service-time 5000
# Set the service idle timeout timer to 100 milliseconds.
[AC-wlan-ap-ap1-radio-1] scan idle-time 100
Example: Configuring absolute forwarding preferred channel scanning
To ensure wireless service quality, configure channel scanning and configure AP 1 to not limit the service period, as shown in Figure 3.
Figure 3 Network diagram
<AC> system-view
# Enter radio view.
# Set the scanning period to 100 milliseconds.
[AC-wlan-ap-ap1-radio-1] scan scan-time 100
# Configure the radio to not limit the service period.
[AC-wlan-ap-ap1-radio-1] scan max-service-time no-limit
