01-Fundamentals
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10101-Fundamentals
04-HH3C-UI-MAN-MIB
04-HH3C-UI-MAN-MIB 53.00 KB
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to define alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUIMgt(2)
Scalar objects
hh3cTerminalUserName
Object (OID)
Access
Value range
Implementation
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1)
accessible-for-notify
DisplayString
Standard MIB values.
Name of a login user.
As per the MIB.
hh3cTerminalSource
Object (OID)
Access
Value range
Implementation
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2)
DisplayString
Login method, including Console, AUX, TTY, and VTY.
As per the MIB.
hh3cTerminalUserAuthFailureReason
Object (OID)
Access
Value range
Implementation
hh3cTerminalUserAuthFailureReason (1.3.6.1.4.1.25506.2.2.1.1.2.3)
INTEGER
exceedRetries(1)
authTimeout(2)
otherReason(3)
Failure reason for user authentication.
As per the MIB.
Notifications
The following information describes the notifications included in the HH3C-UI-MAN-MIB module.
hh3cLogIn
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.1
User login
Informational
ON
This notification is generated when a user logs in to the system.
Status control
This alarm cannot be cleared.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName)
Username.
No
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource)
User line, including console, AUX, TTY, and VTY.
No
DisplayString
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cLogOut
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.2
User logout
Informational
ON
This notification is generated when a user logs out of the system.
Status control
Objects
OID (object name)
Index
Value range
Username.
No
DisplayString
User line, including AUX, TTY, and VTY.
No
DisplayString
Recommended action
hh3cLogInAuthenFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.3
User authentication failed
Informational
ON
This notification is generated when a user failed to log in to the system.
Status control
Objects
OID (object name)
Index
Value range
Username.
No
DisplayString
No
DisplayString
1.3.6.1.4.1.25506.2.2.1.1.2.3 (hh3cTerminalUserAuthFailureReason)
No
INTEGER
exceedRetries(1)
authTimeout(2)
otherReason(3)
Recommended action
