20-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R838x-6W10020-Network Management and Monitoring
07-HH3C-NQA-MIB
07-HH3C-NQA-MIB 239.92 KB
HH3C-NQA-MIB
About this MIB
Use this MIB to implement the following functions:
Configure the extended attributes for NQA operations.
Display the statistical results of the NQA operations.
Display the extended results of the jitter operations.
Configure TCP/UDP server properties.
Save the statistical results of an operation in a certain period and save multiple statistics groups.
Save a certain number of history records for an operation.
Configure the start and end time for each operation.
Display the statistical results and history records in a certain period.
MIB file name
hh3c-nqa.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cNqa(3)
Scalar objects
hh3cNqaMIBVersion (1.3.6.1.4.1.25506.8.3.1.1)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
OCTET STRING (0..255)
MIB version.
As per the MIB.
hh3cNqaAgentEnable (1.3.6.1.4.1.25506.8.3.1.5)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
Enable(1), disable(2)
Enables or disables the NQA client.
As per the MIB.
hh3cNqaServerEnable (1.3.6.1.4.1.25506.8.3.1.8)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
Enables or disables the NQA server.
As per the MIB.
hh3cNqaStatsMaxGroupNumber (1.3.6.1.4.1.25506.8.3.1.9)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Maximum number of statistics groups that can be saved.
As per the MIB.
Tabular objects
hh3cNqaCtlTable
About this table
This table configures the NQA operations.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table indexes are pingCtlOwnerIndex and pingCtlTestName.
Object (OID)
Access
Value range
Implementation
hh3cNqaCtlTargetPort (1.3.6.1.4.1.25506.8.3.1.2.1.1)
read-create
Integer32
Integer32 (0..65536)
Destination port.
Value range: 0 to 65535.
If pingCtlType uses value pingUdpEcho or pingTcpConnectionAttempt, this object value must be 7. If pingCtlType uses value hh3cNqaUdpEcho or hh3cNqaTcpConnect, this object value cannot be 7.
hh3cNqaCtlSourcePort (1.3.6.1.4.1.25506.8.3.1.2.1.2)
read-create
Integer32
Source port.
hh3cNqaCtlTTL (1.3.6.1.4.1.25506.8.3.1.2.1.3)
read-create
Integer32
TTL for a NQA operation.
Value range: 1 to 255.
hh3cNqaCtlJitterAdminInterval (1.3.6.1.4.1.25506.8.3.1.2.1.4)
read-create
Integer32
Integer32 (0..60000)
Time interval between two continuous probes in a jitter operation.
Value range: 0 to 60000.
hh3cNqaCtlJitterAdminNumPackets (1.3.6.1.4.1.25506.8.3.1.2.1.5)
read-create
Integer32
Number of packets in a jitter operation.
For ICMP jitter and UDP jitter operations, the value range is 10 to 1000 and the default value is 10.
For voice operations, the value range is 10 to 60000 and the default value is 1000.
The object is applicable to only ICMP jitter, voice, and UDP jitter operations.
hh3cNqaCtlHttpOperationType (1.3.6.1.4.1.25506.8.3.1.2.1.6)
read-create
INTEGER
get(1),
post(2),
raw(3)
HTTP operation type.
As per the MIB.
hh3cNqaCtlHttpOperationString (1.3.6.1.4.1.25506.8.3.1.2.1.7)
read-create
DisplayString
OCTET STRING (0..1023)
HTTP operation string.
If hh3cNqaCtlHttpOperationType uses value raw(3), the URL length is 0 to 1023.
If hh3cNqaCtlHttpOperationType uses value get(1) or post(2), the following information applies: The object contains resource and HTTP version, and the resource is part of the URL. The common format of URL is http://host/resource.
The length of the resource is 0 to 246 and the resource is case sensitive.
The HTTP version is case insensitive and supports HTTP/1.0 and HTTP/1.1.
The default HTTP version is v1.0.
The object value must contain and only contain one space that separates the resource and HTTP version.
If the object value is a zero-length string, the default resource and HTTP version are used.
hh3cNqaCtlFtpOperationType (1.3.6.1.4.1.25506.8.3.1.2.1.8)
read-create
INTEGER
get(1),
put(2)
FTP operation type.
As per the MIB.
hh3cNqaCtlFtpUsername (1.3.6.1.4.1.25506.8.3.1.2.1.9)
read-create
DisplayString
OCTET STRING (0..32)
FTP username.
As per the MIB.
hh3cNqaCtlFtpPassword (1.3.6.1.4.1.25506.8.3.1.2.1.10)
read-create
DisplayString
FTP password.
As per the MIB.
hh3cNqaCtlFtpOperationString (1.3.6.1.4.1.25506.8.3.1.2.1.11)
read-create
DisplayString
File name transmitted between the FTP client and server.
If hh3cNqaCtlFtpOperationType uses value put(2), the length of the object is 1 to 200.
If hh3cNqaCtlFtpOperationType uses value get(1), the length of the object is 1 to 247.
hh3cNqaCtlVPNInstance (1.3.6.1.4.1.25506.8.3.1.2.1.12)
read-create
DisplayString
VPN name.
The length of the object is 0 to 31.
The object is not configurable if the device does not support VPN.
hh3cNqaCtlHistoryKeptTime (1.3.6.1.4.1.25506.8.3.1.2.1.13)
read-create
Integer32
Integer32 (1..1440)
Lifetime of history records.
As per the MIB.
hh3cNqaCtlHistoryEnable (1.3.6.1.4.1.25506.8.3.1.2.1.14)
read-create
INTEGER
enabled(1), disabled(2)
Enablement status of saving history records.
As per the MIB.
hh3cNqaCtlICPIFAdvFactor (1.3.6.1.4.1.25506.8.3.1.2.1.15)
read-create
Integer32
Value of the advantage factor.
Value range: 0 to 20.
hh3cNqaCtlCodecType (1.3.6.1.4.1.25506.8.3.1.2.1.16)
read-create
INTEGER
notDefined(1), g711Alaw(2), g711Ulaw(3),
g729A(4), icmpTimestamp(5)
Code type for jitter operations.
The object is valid only if pingCtlType uses hh3cNqajitter.
For UDP jitter operations, pingCtlType uses hh3cNqajitter and this object uses value notDefined.
For voice operations, pingCtlType uses hh3cNqajitter and this object uses value g711Alaw, g711Ulaw, or g729A.
For ICMP jitter operations, pingCtlType uses hh3cNqajitter and this object uses value icmpTimestamp.
If this object uses another value to indicate a new operation type, the system performs the following tasks:
Delete the entries of the old operation type.
Use the default settings to create entries for the new operation type.
Currently, the values notDefined, g711Alaw, g711Ulaw, g729A, and icmpTimestamp are supported.
hh3cNqaResultsTable
About this table
This table displays the saved configuration of the NQA operations.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cNqaResultsRttNumDisconnects (1.3.6.1.4.1.25506.8.3.1.3.1.1)
read-only
Unsigned32
Number of disconnections by the peer.
As per the MIB.
hh3cNqaResultsRttTimeouts (1.3.6.1.4.1.25506.8.3.1.3.1.2)
read-only
Unsigned32
Number of timeout occurrences in an operation.
As per the MIB.
hh3cNqaResultsRttBusies (1.3.6.1.4.1.25506.8.3.1.3.1.3)
read-only
Unsigned32
Number of probe failures due to the reached upper limit.
Not supported
hh3cNqaResultsRttNoConnections (1.3.6.1.4.1.25506.8.3.1.3.1.4)
read-only
Unsigned32
Number of failures to connect with the peer.
As per the MIB.
hh3cNqaResultsRttDrops (1.3.6.1.4.1.25506.8.3.1.3.1.5)
read-only
Unsigned32
Number of failures to allocate the system resources.
As per the MIB.
hh3cNqaResultsRttSequenceErrors (1.3.6.1.4.1.25506.8.3.1.3.1.6)
read-only
Unsigned32
Number of failures due to out-of-sequence packets.
As per the MIB.
hh3cNqaResultsRttStatsErrors (1.3.6.1.4.1.25506.8.3.1.3.1.7)
read-only
Unsigned32
Number of failures due to other errors.
As per the MIB.
hh3cNqaResultsMaxDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.8)
read-only
Unsigned32
Maximum delay from source to destination.
As per the MIB.
hh3cNqaResultsMaxDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.9)
read-only
Unsigned32
Maximum delay from destination to source.
As per the MIB.
hh3cNqaResultsLostPacketRatio (1.3.6.1.4.1.25506.8.3.1.3.1.10)
read-only
Unsigned32
Packet loss ratio.
This object value reflects the packet loss ratio for all operations in DISMAN-PING-MIB and HH3C-NQA-MIB.
hh3cNqaResultsPacketLateArrival (1.3.6.1.4.1.25506.8.3.1.3.1.11)
read-only
Unsigned32
Number of packets arrived after the timeout.
As per the MIB.
hh3cNqaResultsRttSum (1.3.6.1.4.1.25506.8.3.1.3.1.12)
read-only
Unsigned32
Sum of round-trip time.
As per the MIB.
hh3cNqaResultsNumOfDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.13)
read-only
Unsigned32
Number of delays from source to destination.
As per the MIB.
hh3cNqaResultsMinDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.14)
read-only
Unsigned32
Minimum delay from source to destination.
As per the MIB.
hh3cNqaResultsSumDelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.15)
read-only
Unsigned32
Sum of delays from source to destination.
As per the MIB.
hh3cNqaResultsSum2DelaySD (1.3.6.1.4.1.25506.8.3.1.3.1.16)
read-only
Unsigned32
Square sum of delays from source to destination.
As per the MIB.
hh3cNqaResultsNumOfDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.17)
read-only
Unsigned32
Number of delays from destination to source.
As per the MIB.
hh3cNqaResultsMinDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.18)
read-only
Unsigned32
Minimum delay from destination to source.
As per the MIB.
hh3cNqaResultsSumDelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.19)
read-only
Unsigned32
Sum of delays from destination to source.
As per the MIB.
hh3cNqaResultsSum2DelayDS (1.3.6.1.4.1.25506.8.3.1.3.1.20)
read-only
Unsigned32
Square sum of delays from destination to source.
As per the MIB.
hh3cNqaJitterStatsTable
About this table
This table displays the saved jitter operations.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cNqaJitterStatsNumOfRTT (1.3.6.1.4.1.25506.8.3.1.4.1.1)
read-only
Counter32
Number of received response packets.
As per the MIB.
hh3cNqaJitterStatsMinOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.2)
read-only
Gauge32
Minimum positive jitter from source to destination.
As per the MIB.
hh3cNqaJitterStatsMaxOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.3)
read-only
Gauge32
Maximum positive jitter from source to destination.
As per the MIB.
hh3cNqaJitterStatsNumOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.4)
read-only
Gauge32
Number of positive jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsSumOfPositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.5)
read-only
Gauge32
Sum of positive jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsSum2PositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.6)
read-only
Gauge32
Square sum of positive jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsMinOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.7)
read-only
Gauge32
Minimum absolute value among negative jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsMaxOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.8)
read-only
Gauge32
Maximum absolute value among negative jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsNumOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.9)
read-only
Gauge32
Number of negative jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsSumOfNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.10)
read-only
Gauge32
Sum of negative jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsSum2NegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.11)
read-only
Gauge32
Square sum of negative jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsMinOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.12)
read-only
Gauge32
Minimum positive jitter from destination to source.
As per the MIB.
hh3cNqaJitterStatsMaxOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.13)
read-only
Gauge32
Maximum positive jitter from destination to source.
As per the MIB.
hh3cNqaJitterStatsNumOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.14)
read-only
Gauge32
Number of positive jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsSumOfPositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.15)
read-only
Gauge32
Sum of positive jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsSum2PositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.16)
read-only
Gauge32
Square sum of positive jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsMinOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.17)
read-only
Gauge32
Minimum absolute value among negative jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsMaxOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.18)
read-only
Gauge32
Maximum absolute value among negative jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsNumOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.19)
read-only
Gauge32
Number of negative jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsSumOfNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.20)
read-only
Gauge32
Sum of absolute values of negative jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsSum2NegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.21)
read-only
Gauge32
Square sum of negative jitters from destination to source.
As per the MIB.
hh3cNqaJitterStatsPacketLossSD (1.3.6.1.4.1.25506.8.3.1.4.1.22)
read-only
Gauge32
Number of lost packets from source to destination.
As per the MIB.
hh3cNqaJitterStatsPacketLossDS (1.3.6.1.4.1.25506.8.3.1.4.1.23)
read-only
Gauge32
Number of lost packets from destination to source.
As per the MIB.
hh3cNqaJitterStatsAvePositivesSD (1.3.6.1.4.1.25506.8.3.1.4.1.24)
read-only
Gauge32
Average positive jitter from source to destination.
If the time difference between two consecutive packets from source to destination is positive, the statistical time is added by 1 and the sum of jitters is added by the time difference.
Average positive jitter = Sum of jitters / statistical time
hh3cNqaJitterStatsAveNegativesSD (1.3.6.1.4.1.25506.8.3.1.4.1.25)
read-only
Gauge32
Average negative jitter from source to destination.
If the time difference between two consecutive packets from source to destination is negative, the statistical time is added by 1 and the sum of jitters is added by the absolute value of the time difference.
Average negative jitter = Sum of jitters / statistical time
hh3cNqaJitterStatsAvePositivesDS (1.3.6.1.4.1.25506.8.3.1.4.1.26)
read-only
Gauge32
Average positive jitter from destination to source.
If the time difference between two consecutive packets from destination to source is positive, the statistical time is added by 1 and the sum of jitters is added by the time difference.
hh3cNqaJitterStatsAveNegativesDS (1.3.6.1.4.1.25506.8.3.1.4.1.27)
read-only
Gauge32
Average negative jitter from destination to source.
If the time difference between two consecutive packets from destination to source is negative, the statistical time is added by 1 and the sum of jitters is added by the absolute value of the time difference.
hh3cNqaJitterStatsPktLossUnknown (1.3.6.1.4.1.25506.8.3.1.4.1.28)
read-only
Gauge32
Number of lost packets for unknown reasons.
hh3cNqaJitterStatsOperOfICPIF (1.3.6.1.4.1.25506.8.3.1.4.1.29)
read-only
Gauge32
ICPIF value of the operation.
Supports only voice operations.
hh3cNqaJitterStatsOperOfMOS (1.3.6.1.4.1.25506.8.3.1.4.1.30)
read-only
Gauge32
MOS value of the operation.
Supports only voice operations. The object value is 100 times the actual value.
hh3cNqaJitterStatsAveSD (1.3.6.1.4.1.25506.8.3.1.4.1.31)
read-only
Gauge32
Average jitters from source to destination.
As per the MIB.
hh3cNqaJitterStatsAveDS (1.3.6.1.4.1.25506.8.3.1.4.1.32)
read-only
Gauge32
Average jitters from destination to source.
As per the MIB.
hh3cNqaTcpServerTable
About this table
This table configures the TCP server.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cNQATcpServerIpAddress and h3cNQATcpServerPort.
Object (OID)
Access
Value range
Implementation
hh3cNqaTcpServerIpAddress (1.3.6.1.4.1.25506.8.3.1.6.1.1)
not-accessible
InetAddress
IP address of the TCP server.
Supports both IPv4 and IPv6 addresses.
hh3cNqaTcpServerPort (1.3.6.1.4.1.25506.8.3.1.6.1.2)
not-accessible
Integer32
Port number of the TCP server.
Value range: 1 to 65535.
hh3cNqaTcpServerRowStatus (1.3.6.1.4.1.25506.8.3.1.6.1.3)
read-create
RowStatus
Row status.
Supports only values active(1), createAndgo(4), and destroy(6).
hh3cNqaUdpServerTable
About this table
This table configures the UDP server.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cNQAUdpServerIpAddress and h3cNQAUdpServerPort.
Object (OID)
Access
Value range
Implementation
hh3cNqaUdpServerIpAddress (1.3.6.1.4.1.25506.8.3.1.7.1.1)
not-accessible
InetAddress
IP address of the UDP server.
hh3cNqaUdpServerPort (1.3.6.1.4.1.25506.8.3.1.7.1.2)
not-accessible
Integer32
Port number of the UDP server.
hh3cNqaUdpServerRowStatus (1.3.6.1.4.1.25506.8.3.1.7.1.3)
read-create
RowStatus
Row status.
hh3cNqaStatisticsCtlTable
About this table
This table configures the collection of NQA operation statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cNqaCtlStatisticsInterval (1.3.6.1.4.1.25506.8.3.1.10.1.1)
read-create
Unsigned32
Statistics collection interval, in minutes.
Value range: 1 to 35791394. Default: 60.
hh3cNqaCtlStatisticsGroupNumber (1.3.6.1.4.1.25506.8.3.1.10.1.2)
read-create
Unsigned32
Maximum number of statistics groups.
Value range: 0 to the value of hh3cNqaStatsMaxGroupNumber.
Default: 2. If the object value is 0, no statistics collection will be enabled.
hh3cNqaCtlStatisticsKeptTime (1.3.6.1.4.1.25506.8.3.1.10.1.3)
read-create
Unsigned32
Unsigned32 (1..1440)
Statistics lifetime, in minutes.
Value range: 1 to 1440. Default: 120.
hh3cNqaCtlBeginTime (1.3.6.1.4.1.25506.8.3.1.10.1.4)
read-create
DateAndTime
Start time for saving statistics.
Obeys the time format. Available year range: 2000 to 2035.
hh3cNqaCtlLifeTime (1.3.6.1.4.1.25506.8.3.1.10.1.5)
read-create
Unsigned32
Operation lifetime, in seconds.
Value range: 1 to 2147483647. The value 4294967295 indicates that the operation will never stop.
hh3cNqaStatisticsResultsTable
About this table
This table displays NQA operation statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pingCtlOwnerIndex, pingCtlTestName, and h3cNQAStatResIndex.
Object (OID)
Access
Value range
Implementation
hh3cNqaStatResIndex (1.3.6.1.4.1.25506.8.3.1.11.1.1)
not-accessible
Unsigned32
Unsigned32 (1..4294967295)
Statistics table index.
As per the MIB.
hh3cNqaStatResIpTargetAddressType (1.3.6.1.4.1.25506.8.3.1.11.1.2)
read-only
InetAddressType
Type of destination IP address.
As per the MIB.
hh3cNqaStatResIpTargetAddress (1.3.6.1.4.1.25506.8.3.1.11.1.3)
read-only
InetAddress
Destination IP address.
As per the MIB.
hh3cNqaStatResMinRtt (1.3.6.1.4.1.25506.8.3.1.11.1.4)
read-only
Gauge32
Minimum round-trip time.
As per the MIB.
hh3cNqaStatResMaxRtt (1.3.6.1.4.1.25506.8.3.1.11.1.5)
read-only
Gauge32
Maximum round-trip time.
As per the MIB.
hh3cNqaStatResAverageRtt (1.3.6.1.4.1.25506.8.3.1.11.1.6)
read-only
Gauge32
Average round-trip time.
As per the MIB.
hh3cNqaStatResProbeResponses (1.3.6.1.4.1.25506.8.3.1.11.1.7)
read-only
Counter32
Number of received packets.
As per the MIB.
hh3cNqaStatResSentProbes (1.3.6.1.4.1.25506.8.3.1.11.1.8)
read-only
Counter32
Number of sent probe packets.
As per the MIB.
hh3cNqaStatResRttSumOfSquares (1.3.6.1.4.1.25506.8.3.1.11.1.9)
read-only
Counter32
Square sum of round-trip time.
As per the MIB.
hh3cNqaStatResStartTime (1.3.6.1.4.1.25506.8.3.1.11.1.10)
read-only
DateAndTime
Start time of the statistics.
As per the MIB.
hh3cNqaStatResInterval (1.3.6.1.4.1.25506.8.3.1.11.1.11)
read-only
Gauge32
End time of the statistics.
As per the MIB.
hh3cNqaStatResRttNumDisconnects (1.3.6.1.4.1.25506.8.3.1.11.1.12)
read-only
Counter32
As per the MIB.
hh3cNqaStatResRttTimeouts (1.3.6.1.4.1.25506.8.3.1.11.1.13)
read-only
Counter32
As per the MIB.
hh3cNqaStatResRttBusies (1.3.6.1.4.1.25506.8.3.1.11.1.14)
read-only
Counter32
Number of failures due to the busy system.
As per the MIB.
hh3cNqaStatResRttNoConnections (1.3.6.1.4.1.25506.8.3.1.11.1.15)
read-only
Counter32
As per the MIB.
hh3cNqaStatResRttDrops (1.3.6.1.4.1.25506.8.3.1.11.1.16)
read-only
Counter32
As per the MIB.
hh3cNqaStatResRttSequenceErrors (1.3.6.1.4.1.25506.8.3.1.11.1.17)
read-only
Counter32
As per the MIB.
hh3cNqaStatResRttErrors (1.3.6.1.4.1.25506.8.3.1.11.1.18)
read-only
Counter32
As per the MIB.
hh3cNqaStatResLostPacketRatio (1.3.6.1.4.1.25506.8.3.1.11.1.19)
read-only
Gauge32
Packet loss ratio.
As per the MIB.
hh3cNqaStatResPacketLateArrival (1.3.6.1.4.1.25506.8.3.1.11.1.20)
read-only
Counter32
As per the MIB.
hh3cNqaStatResRttSum (1.3.6.1.4.1.25506.8.3.1.11.1.21)
read-only
Counter32
As per the MIB.
hh3cNqaStatResNumOfDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.22)
read-only
Counter32
As per the MIB.
hh3cNqaStatResMinDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.23)
read-only
Gauge32
As per the MIB.
hh3cNqaStatResMaxDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.24)
read-only
Gauge32
As per the MIB.
hh3cNqaStatResSumDelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.25)
read-only
Counter32
As per the MIB.
hh3cNqaStatResSum2DelaySD (1.3.6.1.4.1.25506.8.3.1.11.1.26)
read-only
Counter32
As per the MIB.
hh3cNqaStatResNumOfDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.27)
read-only
Counter32
As per the MIB.
hh3cNqaStatResMaxDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.29)
read-only
Gauge32
As per the MIB.
hh3cNqaStatResSumDelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.30)
read-only
Counter32
As per the MIB.
hh3cNqaStatResSum2DelayDS (1.3.6.1.4.1.25506.8.3.1.11.1.31)
read-only
Counter32
As per the MIB.
hh3cNqaGroupStatsJitterTable
About this table
This table displays jitter operation statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are pingCtlOwnerIndex, pingCtlTestName, and h3cNQAStatJitterIndex.
Object (OID)
Access
Value range
Implementation
hh3cNqaStatJitterIndex (1.3.6.1.4.1.25506.8.3.1.12.1.1)
not-accessible
Unsigned32
Statistics table index for a jitter operation.
As per the MIB.
hh3cNqaStatJitterMinOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.2)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterMaxOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.3)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterNumOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.4)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterSumOfPosSD (1.3.6.1.4.1.25506.8.3.1.12.1.5)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterSumOfSquarePosSD (1.3.6.1.4.1.25506.8.3.1.12.1.6)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterMinOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.7)
read-only
Gauge32
Minimum negative jitter from source to destination.
As per the MIB.
hh3cNqaStatJitterMaxOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.8)
read-only
Gauge32
Maximum negative jitter from source to destination.
As per the MIB.
hh3cNqaStatJitterNumOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.9)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterSumOfNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.10)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterSumOfSquareNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.11)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterMinOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.12)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterMaxOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.13)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterNumOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.14)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterSumOfPosDS (1.3.6.1.4.1.25506.8.3.1.12.1.15)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterSumOfSquarePosDS (1.3.6.1.4.1.25506.8.3.1.12.1.16)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterMinOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.17)
read-only
Gauge32
Minimum negative jitter from destination to source.
As per the MIB.
hh3cNqaStatJitterMaxOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.18)
read-only
Gauge32
Maximum negative jitter from destination to source.
As per the MIB.
hh3cNqaStatJitterNumOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.19)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterSumOfNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.20)
read-only
Counter32
Sum of negative jitters from destination to source.
As per the MIB.
hh3cNqaStatJitterSumOfSquareNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.21)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterPacketLossSD (1.3.6.1.4.1.25506.8.3.1.12.1.22)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterPacketLossDS (1.3.6.1.4.1.25506.8.3.1.12.1.23)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterAvePosSD (1.3.6.1.4.1.25506.8.3.1.12.1.24)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterAveNegSD (1.3.6.1.4.1.25506.8.3.1.12.1.25)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterAvePosDS (1.3.6.1.4.1.25506.8.3.1.12.1.26)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterAveNegDS (1.3.6.1.4.1.25506.8.3.1.12.1.27)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterPktLossUnknown (1.3.6.1.4.1.25506.8.3.1.12.1.28)
read-only
Counter32
As per the MIB.
hh3cNqaStatJitterMaxOfICPIF (1.3.6.1.4.1.25506.8.3.1.12.1.29)
read-only
Gauge32
Maximum ICPIF value.
hh3cNqaStatJitterMinOfICPIF (1.3.6.1.4.1.25506.8.3.1.12.1.30)
read-only
Gauge32
Minimum ICPIF value.
hh3cNqaStatJitterMaxOfMOS (1.3.6.1.4.1.25506.8.3.1.12.1.31)
read-only
Gauge32
Maximum MOS value.
hh3cNqaStatJitterMinOfMOS (1.3.6.1.4.1.25506.8.3.1.12.1.32)
read-only
Gauge32
Minimum MOS value.
hh3cNqaStatJitterAveSD (1.3.6.1.4.1.25506.8.3.1.12.1.33)
read-only
Gauge32
As per the MIB.
hh3cNqaStatJitterAveDS (1.3.6.1.4.1.25506.8.3.1.12.1.34)
read-only
Gauge32
As per the MIB.
hh3cNqaReactionTable
About this table
This table configures reaction entries for NQA operations.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cNqaReactOwnerIndex, h3cNqaReactTestName, and h3cNqaReactItemIndex.
Object (OID)
Access
Value range
Implementation
hh3cNqaReactOwnerIndex (1.3.6.1.4.1.25506.8.3.1.13.1.1)
accessible-for-notify
SnmpAdminString
OCTET STRING(0..32)
Administrator index.
As per the MIB.
hh3cNqaReactTestName (1.3.6.1.4.1.25506.8.3.1.13.1.2)
SnmpAdminString
OCTET STRING(0..32)
Operation tag.
As per the MIB.
hh3cNqaReactItemIndex (1.3.6.1.4.1.25506.8.3.1.13.1.3)
Unsigned32
Unsigned32 (1..10)
A reaction entry is identified by its ID uniquely for an NQA operation.
As per the MIB.
hh3cNqaReactCheckedElement (1.3.6.1.4.1.25506.8.3.1.13.1.4)
read-create
INTEGER
probetime(1)
probefailure(2)
jitterrtt(3)
jitterpacketloss(4)
jittersd(5)
jiterds(6)
icpif(7)
mos(8)
jitterOwdSD(9)
jitterOwdDS(10)
testfailure(11)
testresultchangge(12)
Monitored performance metric.
As per the MIB.
hh3cNqaReactThresholdUpperLimit (1.3.6.1.4.1.25506.8.3.1.13.1.5)
read-create
Unsigned32
Upper limit of the threshold.
If hh3cNqaReactCheckedElement uses value icpif, the value range of this object is 1 to 100.
If hh3cNqaReactCheckedElement uses value mos, the value range of this object is 1 to 500.
If hh3cNqaReactCheckedElement uses value jittersd, jitterds, jitterOwdSD, jitterOwdDS, jitterrtt, or probetime, the value range of this object is 0 to 3600000 milliseconds.
If hh3cNqaReactCheckedElement uses value testfailure or testresultchangge, the value range of this object is 1 to 15.
In other cases, the value of this object should not be set.
hh3cNqaReactThresholdLowerLimit (1.3.6.1.4.1.25506.8.3.1.13.1.6)
read-create
Unsigned32
Lower limit of the threshold.
hh3cNqaReactThresholdType (1.3.6.1.4.1.25506.8.3.1.13.1.7)
read-create
INTEGER
invalid(0), average(1), consecutive(2), accumulative(3)
Threshold type.
If hh3cNqaReactCheckedElement uses value jittersd or jitterds, this object value can be average or accumulative.
If hh3cNqaReactCheckedElement uses value jitterpacketloss, this object value can be accumulative.
If hh3cNqaReactCheckedElement uses value probetime, this object value can be average, consecutive, or accumulative.
If hh3cNqaReactCheckedElement uses value probefailure, this object value can be consecutive or accumulative.
If hh3cNqaReactCheckedElement uses value jitterrtt, this object value can be average or ccumulative.
hh3cNqaReactThresholdConsecNum (1.3.6.1.4.1.25506.8.3.1.13.1.8)
read-create
Unsigned32
Consecutive threshold limit.
If the threshold type is not set to consecutive, this object is meaningless.
If hh3cNqaReactCheckedElement uses value probetime, probefailure, or test-failure, the value range of this object is 1 to 16.
hh3cNqaReactThresholdAccumNum (1.3.6.1.4.1.25506.8.3.1.13.1.9)
read-create
Unsigned32
Accumulative threshold limit.
If the threshold type is not set to accumulate, this object is meaningless.
If hh3cNqaReactCheckedElement uses value jittersd or jitterds and the operation type is set to ICMP-jitter or UDP-jitter, the value range of this object is 1 to 14999.
If hh3cNqaReactCheckedElement uses value jittersd or jitterds and the operation type is set to voice, the value range of this object is 1 to 59999.
If hh3cNqaReactCheckedElement uses value jitterpacketloss or jitterrtt and the operation type is set to ICMP-jitter or UDP-jitter, the value range of this object is 1 to 15000.
If hh3cNqaReactCheckedElement uses value jitterpacketloss or jitterrtt and the operation type is set to voice, the value range of this object is 1 to 60000.
If hh3cNqaReactCheckedElement uses value probetime or probefailure, the value range of this object is 1 to 15.
hh3cNqaReactActionType (1.3.6.1.4.1.25506.8.3.1.13.1.10)
read-create
INTEGER
none(0), trapOnly(1), triggerOnly(2), trapAndTrigger(3)
Sets the action for the threshold violation event. By default, no action is specified for the threshold violation event.
The supported action type depends on the monitored performance metric.
hh3cNqaReactCurrentStatus (1.3.6.1.4.1.25506.8.3.1.13.1.11)
read-only
INTEGER
invalid(1),overThreshold(2),belowThreshold(3),overUpperThreshold(4),belowLowerThreshold(5)
Obtain the alarm status for the threshold violation event.
As per the MIB.
hh3cNqaReactRowStatus (1.3.6.1.4.1.25506.8.3.1.13.1.12)
read-create
RowStatus
An indication of the creation and deletion of reaction entries.
As per the MIB.
hh3cNqaReactCheckedNum (1.3.6.1.4.1.25506.8.3.1.13.1.13)
read-only
Unsigned32
Number of targets that have been monitored for data collection.
As per the MIB.
hh3cNqaReactThresholdNum (1.3.6.1.4.1.25506.8.3.1.13.1.14)
read-only
Unsigned32
Number of threshold violations.
As per the MIB.
hh3cNqaStatisticsReactionTable
About this table
This table records the number of monitored targets and number of threshold violations in a certain time period.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are h3cNqaStatReactOwnerIndex, h3cNqaStatReactTestName, h3cNqaStatReactIndex, and h3cNqaStatReactItemIndex.
Object (OID)
Access
Value range
Implementation
hh3cNqaStatReactOwnerIndex (1.3.6.1.4.1.25506.8.3.1.14.1.1)
not-accessible
SnmpAdminString
OCTET STRING(0..32)
As per the MIB.
hh3cNqaStatReactTestName (1.3.6.1.4.1.25506.8.3.1.14.1.2)
not-accessible
SnmpAdminString
OCTET STRING(0..32)
Operation tag.
As per the MIB.
hh3cNqaStatReactIndex (1.3.6.1.4.1.25506.8.3.1.14.1.3)
not-accessible
Unsigned32
As per the MIB.
hh3cNqaStatReactItemIndex (1.3.6.1.4.1.25506.8.3.1.14.1.4)
not-accessible
Unsigned32
Number of monitored h3cNqaReactCheckedElement in a time period.
As per the MIB.
hh3cNqaStatReactCheckedNum (1.3.6.1.4.1.25506.8.3.1.14.1.5)
read-only
Counter32
As per the MIB.
hh3cNqaStatReactThresholdNum (1.3.6.1.4.1.25506.8.3.1.14.1.6)
read-only
Counter32
Number of monitored threshold violations in a time period.
As per the MIB.
hh3cNqaTcpServerExtendTable
About this table
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cNqaTcpServerExtIpAddress, h3cNqaTcpServerExtPort, h3cNqaTcpServerExtVPNType, and h3cNqaTcpServerExtVPNInstance.
Object (OID)
Access
Value range
Implementation
hh3cNqaTcpServerExtIpAddress (1.3.6.1.4.1.25506.8.3.1.15.1.1)
not-accessible
InetAddress
As per the MIB.
hh3cNqaTcpServerExtPort (1.3.6.1.4.1.25506.8.3.1.15.1.2)
not-accessible
Integer32
hh3cNqaTcpServerExtVPNType (1.3.6.1.4.1.25506.8.3.1.15.1.3)
not-accessible
VpnInstanceType
VPN instance type of the TCP server.
Supports only values public(1) and VPN(2).
hh3cNqaTcpServerExtVPNInstance
(1.3.6.1.4.1.25506.8.3.1.15.1.4)
not-accessible
OCTET STRING
OCTET STRING (0..31)
VPN instance of the TCP server.
For the set operation:
If the NQA server listens on a public network, the hh3cNqaTcpServerExtVPNType object must use value public(1) and the object value can be set to any non-printable string.
If the NQA server listens on a dedicated network, the hh3cNqaTcpServerExtVPNType object must use value VPN(2) and the object value can be set to any non-printable string.
For the get operation:
If the NQA server listens on a public network, the object value can be public.
hh3cNqaTcpServerExtDSField (1.3.6.1.4.1.25506.8.3.1.15.1.5)
read-create
Unsigned32
Unsigned32 (0..256)
ToS value of the TCP server.
As per the MIB.
hh3cNqaTcpServerExtRowStatus (1.3.6.1.4.1.25506.8.3.1.15.1.6)
read-create
RowStatus
Row status.
hh3cNqaUdpServerExtendTable
About this table
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are h3cNqaUdpServerExtIpAddress, h3cNqaUdpServerExtPort, h3cNqaUdpServerExtVPNType, and h3cNqaUdpServerExtVPNInstance.
Object (OID)
Access
Value range
Implementation
hh3cNqaUdpServerExtIpAddress (1.3.6.1.4.1.25506.8.3.1.16.1.1)
not-accessible
InetAddress
As per the MIB.
hh3cNqaUdpServerExtPort (1.3.6.1.4.1.25506.8.3.1.16.1.2)
not-accessible
Integer32
hh3cNqaUdpServerExtVPNType (1.3.6.1.4.1.25506.8.3.1.16.1.3)
not-accessible
VpnInstanceType
VPN instance type of the UDP server.
hh3cNqaUdpServerExtVPNInstance
 (1.3.6.1.4.1.25506.8.3.1.16.1.4)
not-accessible
OCTET STRING
VPN instance of the UDP server.
If the NQA server listens on a public network, the hh3cNqaUdpServerExtVPNType must use value public(1) and the object value can be set to any non-printable string.
If the NQA server listens on a dedicated network, the hh3cNqaUdpServerExtVPNType must use value VPN(2) and the object value can be set to any non-printable string.
hh3cNqaUdpServerExtDSField (1.3.6.1.4.1.25506.8.3.1.16.1.5)
read-create
Unsigned32
Unsigned32 (0..256)
ToS value of the UDP server.
As per the MIB.
hh3cNqaUdpServerExtRowStatus (1.3.6.1.4.1.25506.8.3.1.16.1.6)
read-create
RowStatus
Row status.
Notifications
hh3cNqaProbeTimeOverThreshold
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.3.3.1
Threshold violation of the probe duration.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
For average or consecutive threshold type, this notification is generated if the threshold status changed when a operation was completed.
For accumulative threshold type, this notification is generated if the threshold status changed when a probe was completed.
System impact
No impact on services.
Status control
ON
CLI: Use the reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.8.3.1.13.1.1 (hh3cNqaReactOwnerIndex)
Administrator name of an operation.
SnmpAdminString
OCTET STRING(0..32)
1.3.6.1.4.1.25506.8.3.1.13.1.2 (hh3cNqaReactTestName)
Operation tag of the operation.
SnmpAdminString
OCTET STRING(0..32)
1.3.6.1.4.1.25506.8.3.1.13.1.3 (hh3cNqaReactItemIndex)
Reaction entry number.
Unsigned32
Unsigned32 (1..10)
1.3.6.1.2.1.80.1.2.1.3 (pingCtlTargetAddressType)
Type of destination address.
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
1.3.6.1.2.1.80.1.2.1.4 (pingCtlTargetAddress)
Destination address.
pingCtlOwnerIndex
pingCtlTestName
InetAddress
1.3.6.1.2.1.80.1.2.1.16 (pingCtlType)
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
1.3.6.1.2.1.80.1.2.1.17 (pingCtlDescr)
Description of the operation.
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
OCTET STRING(0..255)
1.3.6.1.4.1.25506.8.3.1.13.1.7 (hh3cNqaReactThresholdType)
Threshold type.
INTEGER
invalid(0),, average(1),, consecutive(2),, accumulative(3)
1.3.6.1.4.1.25506.8.3.1.13.1.11 (hh3cNqaReactCurrentStatus)
Alarm status.
INTEGER
invalid(1),, overThreshold(2),, belowThreshold(3),                            overUpperThreshold(4),, belowLowerThreshold(5)
Recommended action
To resolve the issue:
1.Execute the display this command in NQA operation view to identify whether the destination address configuration is correct.
  - If the parameters are correctly configured, proceed to step 2.
  - If the parameter configuration is incorrect, execute the destination ip command in NQA operation view to change the destination address. Restart the operation, and check whether the notification is still generated.
If the notification is no longer generated, the issue is resolved.
If the notification is still generated, proceed to step 2.
2.Execute the ping command in NQA operation view to identify whether the route is reachable.
  - If the route is reachable, proceed to step 3.
  - If the route is unreachable, locate the cause for the reachability issue first. For example, you can execute the display ip routing-table command to display the routing table information and troubleshoot the route issue.
3.Execute the probe timeout command in NQA operation view to edit the timeout timer based on the network condition. Restart the operation, and check whether the notification is still generated.
  - If the notification is no longer generated, the issue is resolved.
  - If the notification is still generated, proceed to step 4.
4.Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element probe-duration command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
5.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaJitterRTTOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.2
Threshold violation of the probe round-trip time.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the round-trip time of test packets in a UDP-jitter or voice operation exceeds the specified threshold.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
OCTET STRING(0..32)
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
1.Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element rtt command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaProbeFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.3
Threshold violation of the probe failure.
Informational
Warning
N/A (N/A)
OFF
For consecutive threshold type, this notification is generated if the threshold status changed when an operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
invalid(1),, overThreshold(2),, belowThreshold(3),, overUpperThreshold(4),, belowLowerThreshold(5)
Recommended action
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaJitterPacketLoss
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.4
Threshold violation of the packet loss ratio.
Informational
Warning
N/A (N/A)
OFF
This notification is generated if the threshold status changed when a UDP jitter or voice operation for monitoring threshold violation of the packet loss ratio was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
1.Check the reason for packet loss on the link.
2.If the issue persists, contact H3C Support.
hh3cNqaJitterSDOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.5
Threshold violation of the one-way jitter from source to destination.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the threshold violation of the one-way jitter from source to destination for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element jitter-sd threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element jitter-sd threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
1.3.6.1.2.1.80.1.2.1.3 (PingCtlTargetAddressType)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
1.3.6.1.2.1.80.1.2.1.4 (PingCtlTargetAddress)
pingCtlOwnerIndex
pingCtlTestName
InetAddress
1.3.6.1.2.1.80.1.2.1.16 (PingCtlType)
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
1.3.6.1.2.1.80.1.2.1.17 (PingCtlDescr)
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
1.Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element { jitter-ds | jitter-sd } command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
hh3cNqaJitterDSOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.6
Threshold violation of the one-way jitter from destination to source.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the threshold violation of the one-way jitter from destination to source for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element jitter-ds threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element jitter-ds threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
hh3cNqaICPIFOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.7
Threshold violation of the ICPIF value.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the ICPIF value of a voice operation exceeds the threshold. This notification is generated if the threshold status changed when a voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Alarm status.
INTEGER
Recommended action
1.Check the reason why the ICPIF value changes on the probe link.
hh3cNqaMOSOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.8
Threshold violation of the MOS value.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the MOS value of a voice operation exceeds the threshold. This notification is generated if the threshold status changed when a voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element mos threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element mos threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Alarm status.
INTEGER
Recommended action
1.Check the reason why the MOS value changes on the probe link.
OwdSDNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.14
Threshold alarm for one-way delay (source-to-destination).
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the threshold violation of the one-way delay from source to destination for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element owd-sd threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI:
Use the reaction item-number checked-element owd-sd threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Object
OID (object name)
Index
Value range
SnmpAdminString
SnmpAdminString
Unsigned32
Unsigned32(1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
1.Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element { owd-ds | owd-sd } command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
OwdDSNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.15
Threshold alarm for one-way delay (destination-to-source).
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the threshold violation of the one-way delay from destination to source for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
SnmpAdminString
SnmpAdminString
Unsigned32
Unsigned32(1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
