H3C MSR5680-X3 Router Hardware Information and Specifications-5W100
HomeSupportResource CenterRoutersMSR5600 SeriesMSR5600 SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C MSR5680-X3 Router Hardware Information and Specifications-5W100
03-LEDs
03-LEDs 2.84 MB
3 LEDs
MSU LEDs
Figure 3-1 MSU-100 LEDs
(1) Management Ethernet copper port LED
(1) System status LED (SYS)
(3) MSU active/standby status LED (ACT)
(4) Fan tray status LED (FAN)
Figure 3-2 MSU-200 LEDs
(1) SFP+ fiber port LED
(2) GE port LED
(3) SFP fiber port LED
(4) Management Ethernet copper port LED
(5) System status LED (SYS)
(6) MSU active/standby status LED (ACT)
(7) Fan tray status LED (FAN)
Figure 3-3 MSU-400-G LEDs
(2) SFP+ fiber port LED
(3) GE port LED
(4) Cloud cluster management SFP+ fiber port LED
Table 3-1 MSU LED description
LED
Status
System LED (SYS)
Flashing green (8 Hz)
The device is in BootWare stage.
Steady green
The device is in Kernel stage, including Eshell stage.
Flashing green (1 Hz)
The Comware system is starting up or is operating correctly.
Flashing yellow (1 Hz)
Memory test failed in BootWare stage.
Flashing yellow (8 Hz)
The extended BootWare segment does not exist.
Steady yellow
The boot.bin file does not exist.
Off
No power input, or an exception has occurred.
(Applicable to the MSU-100/MSU-200)
Steady green
The MSU is in active mode.
Off
The MSU is in standby mode.
(Applicable to the MSU-400-G)
Steady green
Bulk backup in progress.
Off
Steady green
Both fan trays are operating correctly.
One fan tray is operating correctly and the other one is not present.
Steady yellow
A minimum of one fan try is faulty.
Off
Both fan trays are not present.
SFP+ fiber port LED
Steady green
A 10 Gbps link is present on the port.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A 1000 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 1000 Mbps.
Off
No link is present on the port.
SFP fiber port LED
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 100 Mbps.
Off
GE port LED/Management Ethernet copper port LED
Steady green
Flashing green
Steady yellow
A 10 or 100 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 10 or 100 Mbps.
Off
Interface module LEDs
For more information about SIC and XMIM interface modules, see H3C MSR Router Series Interface Module Guide.
Power supply LEDs
Figure 3-4 PSR250-12A AC power supply LEDs
(1) Status LED
Figure 3-5 PSR450-12A AC power supply LEDs
(1) Status LED
Figure 3-6 PSR450-12D-F DC power supply LEDs
(1) Status LED
Table 3-2 Power supply LED description
LED
Status
Status LED
Steady green
The power supply is operating correctly.
Flashing green
The power supply has normal power input but has not been turned on.
Steady red
The power supply is faulty.
Flashing red/green
An alarm is present on the power supply.
Flashing red
This power supply does not have power input but the other power supply has power input.
Off
No power is present.
Fan tray status LEDs
Figure 3-7 FAN-80B-2-C fan tray LEDs
(1) Status LED
Table 3-3 Fan tray status LED description
LED
LED status
RUN
Steady green
The fan tray is operating correctly.
Steady yellow
The fan tray is faulty.
Off
No fan tray is present or no power is present on the fan tray.
  • Become a Partner
  • Partner Resources
