| 02-Removable Component Views and Technical Specifications | 3.03 MB |
2 Removable component views and technical specifications
MSUs
MSU-100
Figure2-1 MSU-100 front panel
(1) Captive screw |
(2) DIAG button |
(3) USB port |
(4) Management Ethernet port |
(5) Reset button (RESET) |
(6) Console port |
(7) Handle |
MSU-200
Figure2-2 MSU-200 front panel
(1) Captive screw |
(2) SIC slot |
(3) DIAG button |
(4) SFP+ port SFP+10 |
(5) SFP+ port SFP+11 |
(6) GE copper ports GE2 to GE9 |
(7) GE copper port GE1 |
(8) GE fiber port SFP0 |
(9) GE fiber port SFP1 |
(10) USB port |
(11) Management Ethernet port |
(12) Reset button (RESET) |
(13) Console port |
(14) Handle |
(15) GE copper port GE0 |
MSU-400-G
Figure2-3 MSU-400-G front panel
(1) Captive screw |
(2) Management Ethernet port |
(3) SFP+ ports SFP+8 to SFP+17 |
(4) GE copper ports GE0 to GE7 |
(5) Cloud cluster management SFP+ fiber port |
(6) USB port |
(7) Reset button (RESET) |
(8) Ejector lever |
(9) Console port |
(10) DIAG button |
Interface modules
The device supports SIC and XMIM interface modules. For more information about the interface modules, see H3C MSR Router Series Interface Module Guide.
Power supplies
AC power supplies
Figure2-4 PSR250-12A power supply front panel
(1) Latch |
(2) Handle |
(3) Power receptacle |
Figure2-5 PSR450-12A power supply front panel
(1) Latch |
(2) Handle |
DC power supplies
Figure2-6 PSR450-12D-F power supply front panel
(1) Latch |
(2) Handle |
Fan trays
Figure2-7 FAN-80B-2-C front panel
(1) Handle |
Technical specifications
MSUs
Table2-1 MSU specifications
Item |
MSU-100 |
MSU-200 |
MSU-400-G |
Console port |
1 |
1 |
1 |
GE management port |
1 |
1 |
1 |
GE copper port |
N/A |
8 |
8 |
Combo port |
N/A |
2 (SFP0/GE0 and SFP1/GE1) |
N/A |
SFP+ fiber port |
N/A |
2 |
11 (including one cloud cluster management port) |
USB port |
1 |
1 |
1 |
Memory |
4 GB DDR4 |
4 GB DDR4 |
8 GB DDR4 |
DIAG button |
1 |
1 |
1 |
Flash |
4 GB |
4 GB |
4 GB |
SIC slot |
N/A |
1 |
N/A |
Interface modules
For the technical specifications of SIC and XMIM interface modules, see H3C MSR Router Series Interface Module Guide.
Power supplies
The device supports AC power supplies, DC power supplies, and mix of AC and DC power supplies. The power supplies can be hot swapped and configured in redundancy. In AC or DC power supply mode, you can install only one power supply, or two or three power supplies for 1+1 or 1+2 power supply redundancy respectively. In mixed power supply mode, you can install two power supplies, or three power supplies for 2+1 power supply redundancy.
The device supports only mix of 450 W AC and DC power supplies.
AC power supplies
Table2-2 AC power supply specifications
Model |
Rated input voltage range |
Maximum input current |
Maximum power |
PSR250-12A |
100 VAC to 240 VAC @ 50/60 Hz |
4 A |
250 W |
PSR450-12A |
6 A |
450 W |
DC power supplies
Table2-3 DC power supply specifications
Model |
Maximum power |
PSR450-12D-F |
–48 VDC to –60 VDC |
10 to 12 A |
450 W |
Fan trays
Table2-4 FAN-80B-2-C specifications
Item |
Specifications |
Maximum rotating speed |
13800 RPM |
Maximum air flow rate |
135.15 CFM |
Number of fans |
2 |
Automatic speed adjustment |
Yes |
Anti-misinsertion |
Yes |
Hot swappable |
Yes |
