H3C MSR5680-X3 Router Hardware Information and Specifications-5W100
HomeSupportResource CenterRoutersMSR5600 SeriesMSR5600 SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C MSR5680-X3 Router Hardware Information and Specifications-5W100
01-Chassis Views and Technical Specifications
01-Chassis Views and Technical Specifications 687.70 KB
1 Chassis views and technical specifications
Chassis views
The figures in this section are for illustration only.
"MSU" in this document refers to the main-control and service-processing unit.
MSR5680-X3
Figure1-1 Front panel
(1) XMIM interface module slot 2
(2) XMIM interface module slot 4
(3) XMIM interface module slot 3
(4) XMIM interface module slot 5
(5) MSU slot 0
(6) MSU slot 1
(7) Power supply slot PWR2
(8) Power supply slot PWR1
(9) Power supply slot PWR0
(10) XMIM interface module slot 7
(11) XMIM interface module slot 9
(12) XMIM interface module slot 6
(13) XMIM interface module slot 8
Figure1-2 Rear panel
(1) Fan tray slot 0
(2) Fan tray slot 1
(3) Grounding screw
Technical specifications
MSR5680-X3 technical specifications
Table1-1 MSR5680-X3 technical specifications
Item
MSR5680-X3
MSU slot
2
8
Fan tray slot
2
Power supply slot
3
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
Weights, dimensions, and power consumptions
Chassis
The MSUs, SIC interface modules, and XMIM interface modules are collectively called modules when you do not need to distinguish specific module types.
The device uses modular design. Its weight includes the chassis (including mounting brackets and filler panels), modules, power supplies, fan trays, and other removable components. The total weight varies by the numbers and types of the removable components.
Table1-2 Chassis weights and dimensions
Device model
Weight (chassis only, including mounting brackets and filler panels)
Weight (fully configured)
Dimensions (H × W × D) (excluding rubber feet and mounting brackets)
MSR5680-X3
10.62 kg (23.41 lb)
22.5 kg (49.60 lb)
175 × 440 × 330 mm (6.89 × 17.32 × 12.99 in)
Modules
Table1-3 Module weights, dimensions, and power consumptions
Module model
Net weight
Max power consumption
RT-MSU-100
1.54 kg (3.40 lb)
24.60 W
42.6 × 375 × 227 mm (1.68 × 14.76 × 8.94 in)
RT-MSU-200
1.72 kg (3.79 lb)
45.00 W
RT-MSU-400-G
2.2 kg (4.85 lb)
121.30 W
RT-SIC-5G
0.19 kg (0.42 lb)
7.60 W
19.8 × 80 × 138 mm (0.78 × 3.15 × 5.43 in)
RT-XMIM-8GEE-R
0.64 kg (1.41 lb)
8.80 W
19.8 × 186 × 228 mm (0.78 × 7.32 × 8.98 in)
RT-XMIM-8GEF-R
0.65 kg (1.43 lb)
17.16 W
RT-XMIM-1POS
0.62 kg (1.37 lb)
9.70 W
RT-XMIM-2POS
0.64 kg (1.41 lb)
10.30 W
RT-XMIM-4POS
0.66 kg (1.46 lb)
15.00 W
RT-XMIM-2E1
0.6 kg (1.32 lb)
5.00 W
RT-XMIM-4E1
0.62 kg (1.37 lb)
5.40 W
RT-XMIM-8E1
0.64 kg (1.41 lb)
6.10 W
Module dimensions are expressed in the Height (H) × Width (W) × Depth (D) format:
·     H—Height of the front panel of the module.
·     W—Width of the front panel of the module.
·     D—Depth from the front panel of the module to the connector ends.
Power supplies
Table1-4 Power supply weights and dimensions
Power supply model
Net weight
PSR250-12A
0.64 kg (1.41 lb)
40 × 51 × 221 mm (1.57 × 2.01 × 8.70 in)
PSR450-12D-F
0.68 kg (1.50 lb)
PSR450-12A
0.65 kg (1.43 lb)
Fan trays
Table1-5 Fan tray weights and dimensions
Fan tray model
Net weight
Dimensions (H × W × D) (Lying flat on a workbench)
FAN-80B-2-C
1.06 kg (2.34 lb)
55 W
171 × 136 × 93 mm (6.73 × 5.35 × 3.66 in)
System power consumption
The system power consumption is the total power consumption of all modules and fan trays. It varies depending on the types and numbers of the removable components.
For example, if the device is installed with two RT-MSU-200 MSUs, two RT-XMIM-8GEE-R interface modules, two RT-XMIM-2POS interface modules, two RT-XMIM-4E1 interface modules, and two FAN-80B-2-C fan trays, the system power consumption is 2 × 45 + 2 × 8.8 + 2 × 10.3 + 2 × 5.4 + 2 × 55 = 249 W.
Heat dissipation
Heat dissipation is measured in BTU/h. 1 W equals 3.4121 BTU/h.
The heat dissipation of a router depends on its power consumption. To calculate heat dissipation of the device, assume 90% power consumption is converted to heat, and the power supply conversion efficiency is 90%. Heat dissipation of the router per hour is 0.9 × (total power consumption of all modules and fan trays)/0.9 × 3.4121.
  • Become a Partner
  • Partner Resources
