14-IP Tunnel and VPN
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10014-IP Tunnel and VPN
Table of Contents
Related Documents
01-HH3C-TUNNEL-MIB
01-HH3C-TUNNEL-MIB 65.12 KB
HH3C-TUNNEL-MIB
About this MIB
Use this MIB to configure and obtain tunnel settings for various encapsulation protocols.
MIB file name
hh3c-tunnel.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTunnel (53)
Scalar objects
hh3cTunnelVxlanUdpPort
Object (OID)
Access
Value range
Implementation
hh3cTunnelVxlanUdpPort (1.3.6.1.4.1.25506.2.53.1.1.8.1)
read-write
Integer32
Unsigned32(1..65535)
UDP port number for VXLAN tunnels.
As per the MIB.
hh3cTunnelVxlanDropWrongCksmPkt
Object (OID)
Access
Value range
Implementation
hh3cTunnelVxlanDropWrongCksmPkt (1.3.6.1.4.1.25506.2.53.1.1.8.2)
read-write
TruthValue
true(1), false(2)
Whether to drop the VXLAN packets with checksum errors.
As per the MIB.
hh3cTunnelVxlanDropVlanTagPkt
Object (OID)
Access
Value range
Implementation
hh3cTunnelVxlanDropVlanTagPkt (1.3.6.1.4.1.25506.2.53.1.1.8.3)
read-write
TruthValue
true(1), false(2)
Whether to drop VXLAN packets with inner VLAN tags.
As per the MIB.
Tabular objects
hh3cTunnelEviTable
About this table
This table contains EVI tunnel configuration.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cTunnelEviTunnNum.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.53.1.1.4.1.1)
not-accessible
Integer32
1..2147483647
Tunnel number.
As per the MIB.
hh3cTunnelEviIfIndex
(1.3.6.1.4.1.25506.2.53.1.1.4.1.2)
read-only
Integer32
 (1..2147483647)
Tunnel interface index.
As per the MIB.
hh3cTunnelEviStatus
(1.3.6.1.4.1.25506.2.53.1.1.4.1.3)
read-create
INTEGER
active(1),
createAndGo(4),
destroy(6)
Row status.
As per the MIB.
hh3cTunnelEviAddressType
(1.3.6.1.4.1.25506.2.53.1.1.4.1.4)
read-create
INTEGER
ipv4(1),
ipv6(2)
IP address type.
Only supports IPv4.
hh3cTunnelEviLocalAddr (1.3.6.1.4.1.25506.2.53.1.1.4.1.5)
read-create
InetAddress
OCTET STRING (0..255)
Address of the local end of the tunnel.
As per the MIB.
hh3cTunnelEviNetworkID
(1.3.6.1.4.1.25506.2.53.1.1.4.1.6)
read-create
Integer32
Integer32 (0..16777215 )
Network ID of the tunnel.
As per the MIB.
hh3cTunnelEviKeepaliveInterval
((1.3.6.1.4.1.25506.2.53.1.1.4.1.7)
read-create
Integer32
Integer32 (1..32767)
Keepalive interval of the tunnel.
As per the MIB.
hh3cTunnelEviKeepaliveTimes
((1.3.6.1.4.1.25506.2.53.1.1.4.1.8)
read-create
Integer32
Integer32(1..255)
Maximum number of consecutive keepalive failures that are allowed.
As per the MIB.
hh3cTunnelEviLinkTable
About this table
This table provides EVI-link interface information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cTunnelEviTunnNum and hh3cTunnelEviLinkNum.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.53.1.1.5.1.1)
not-accessible
Integer32
Unsigned32(1..2147483647)
EVI-Link number.
As per the MIB.
hh3cTunnelEviLinkIfIndex
(1.3.6.1.4.1.25506.2.53.1.1.5.1.2)
read-only
Integer32
 Integer32(1..2147483647)
EVI-Link interface index.
As per the MIB.
hh3cTunnelEviLinkAddressType
(1.3.6.1.4.1.25506.2.53.1.1.5.1.3)
read-only
Integer32
ipv4(1),
ipv6(2)
IP address type.
As per the MIB.
hh3cTunnelEviLinkRemoteAddr
(1.3.6.1.4.1.25506.2.53.1.1.5.1.4)
read-only
 InetAddress
Address of the remote end of the tunnel.
As per the MIB.
hh3cTunnelVxlanIfTable
About this table
This table contains VXLAN tunnel interface configuration.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cTunnelVxlanIfTunnNum.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.53.1.1.7.1.1)
not-accessible
INTEGER
INTEGER (1..2147483647)
Tunnel number.
As per the MIB.
hh3cTunnelVxlanTunnIfIndex (1.3.6.1.4.1.25506.2.53.1.1.7.1.2)
read-only
Integer32
As per the MIB.
hh3cTunnelVxlanIfAddressType (1.3.6.1.4.1.25506.2.53.1.1.7.1.3)
read-create
INTEGER
ipv4(1),
ipv6(2)
IP address type.
As per the MIB.
hh3cTunnelVxlanIfLocalAddr (1.3.6.1.4.1.25506.2.53.1.1.7.1.4)
read-create
OCTET STRING
As per the MIB.
hh3cTunnelVxlanIfRemoteAddr
(1.3.6.1.4.1.25506.2.53.1.1.7.1.5)
read-create
OCTET STRING
As per the MIB.
hh3cTunnelVxlanIfStatus
(1.3.6.1.4.1.25506.2.53.1.1.7.1.6)
read-create
INTEGER
active(1),
createAndGo(4),
destroy(6)
Row status.
As per the MIB.
hh3cTunnelTotalNumTable
About this table
Use this table to get the total number of tunnels of a specific tunnel mode.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is hh3cTunnelEncapsMethod.
Object (OID)
Access
Value range
Implementation
hh3cTunnelEncapsMethod (1.3.6.1.4.1.25506.2.53.1.1.10.1.1)
not-accessible
Hh3cTunnelType
Standard MIB values.
Tunnel mode (encapsulation method used by the tunnel).
As per the MIB.
hh3cTunnelTotalNum (1.3.6.1.4.1.25506.2.53.1.1.10.1.2)
read-only
Unsigned32
Total number of tunnels of this tunnel mode.
As per the MIB.
hh3cTunnelNvgreIfTable
About this table
This table contains the NVGRE tunnel interface configuration.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cTunnelNvgreIfTunnNum.
Object (OID)
Access
Value range
Implementation
hh3cTunnelNvgreIfTunnNum (1.3.6.1.4.1.25506.2.53.1.1.11.1.1)
not-accessible
Integer32
Tunnel number.
As per the MIB.
hh3cTunnelNvgreTunnIfIndex (1.3.6.1.4.1.25506.2.53.1.1.11.1.2)
read-only
Integer32
Integer32 (1..2147483647)
As per the MIB.
hh3cTunnelNvgreIfAddressType (1.3.6.1.4.1.25506.2.53.1.1.11.1.3)
read-create
 InetAddressType
ipv4(1),
ipv6(2)
IP address type.
As per the MIB.
hh3cTunnelNvgreIfLocalAddr (1.3.6.1.4.1.25506.2.53.1.1.11.1.4)
read-create
InetAddressType
OCTET STRING (SIZE (0..255))
As per the MIB.
hh3cTunnelNvgreIfRemoteAddr
(1.3.6.1.4.1.25506.2.53.1.1.11.1.5)
read-create
OCTET STRING
As per the MIB.
hh3cTunnelNvgreIfStatus (1.3.6.1.4.1.25506.2.53.1.1.11.1.6)
read-create
INTEGER
active(1),
createAndGo(4),
destroy(6)
Row status.
As per the MIB.
hh3cTunnelDestinationTable
About this table
This table contains tunnel destination address information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are hh3cTunnelDestinationDstAddr, hh3cTunnelDestinationDstType, and hh3cTunnelDestinationTunNum.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.53.1.1.12.1)
not-accessible
OCTET STRING
(0..255)
Destination address of a tunnel.
As per the MIB.
hh3cTunnelDestinationDstAddrType
(1.3.6.1.4.1.25506.2.53.1.1.12.2)
not-accessible
INTEGER
ipv4(1),
ipv6(2)
Destination address type.
As per the MIB.
(1.3.6.1.4.1.25506.2.53.1.1.12.3)
not-accessible
Unsigned32
Tunnel number.
The value range varies by product.
hh3cTunnelDestinationTunIfindex
 (1.3.6.1.4.1.25506.2.53.1.1.12.4)
read-only
OCTET STRING
As per the MIB.
