20-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(E5611)-5W10120-Network Management and Monitoring Command Reference
11-UCC commands
11-UCC commands 100.61 KB
UCC commands
display ucc profile
Use display ucc profile to display configuration information for UCC profiles.
display ucc profile [ profile-name ]
profile-name: Specifies a UCC profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a UCC profile, this command displays configuration information for all UCC profiles.
# Display configuration information for all UCC profiles.
<Sysname> display ucc profile
UCC profile information:
  UCC profile name: ssidcompany1
    SIP: Enabled
    Skype4B: Disabled
      App sharing DSCP priority   : 2
      App sharing 802.1p priority : 2
      Video DSCP priority         : 2
      Video 802.1p priority       : 2
      Voice DSCP priority         : 2
      Voice 802.1p priority       : 2
Total UCC profiles: 1
SIP
Status of SIP-based UCC for the UCC profile:
·     Enabled.
·     Disabled.
Skype4B
Status of Skype4B-based UCC for the UCC profile:
·     Enabled.
·     Disabled.
DSCP priority for Skype4B application sharing packets.
802.1p priority for Skype4B application sharing packets.
Video DSCP priority
DSCP priority for Skype4B video packets.
802.1p priority for Skype4B video packets.
Voice DSCP priority
DSCP priority for Skype4B voice packets.
802.1p priority for Skype4B voice packets.
sip enable
skype4b enable
display ucc table
Use display ucc table to display UCC entries.
display ucc table
# Display UCC entries.
<Sysname> display ucc table
UCC tuple5 entry info:
  Source IP/port           : 2.1.1.2/11111
  Destination IP/port      : 2.1.1.3/22222
  Transport layer protocol : UDP
  Flow type                : SIP
  Media type               : Audio
  Lifetime                 : 280
  Source IP/port           : 2.1.1.4/11113
  Destination IP/port      : 2.1.1.5/22224
  Flow type                : SIP
  Media type               : Video
  Lifetime                 : 260
UCC tuple3 entry info:
  Client IP/port           : 10.1.1.145/13454
  Transport layer protocol : TCP
  Flow type                : SKYPE4B
  Media type               : App-Share
  Lifetime                 : 62
  Client IP/port           : 10.1.1.155/8020
  Flow type                : SKYPE4B
  Lifetime                 : 62
Total tuple5 entries found : 2
Total tuple3 entries found : 2
Total entries found: 4
5-tuple entry information for UCC.
Source IP/port
Source IP address and port number in a UCC entry.
Destination IP/port
Destination IP address and port number in the UCC entry.
Flow type
Flow type:
·     App-Share.
·     SIP.
·     SKYPE4B.
Media type
Media type:
·     Audio.
·     Video.
Lifetime
Lifetime of the UCC entry, in seconds.
Triple entry information for UCC.
Client IP/port
Client IP address and port number in a UCC entry.
reset ucc table
sip enable
ucc profile
ucc-profile
reset ucc table
Use reset ucc table to clear UCC entries.
reset ucc table [ sip | skype4b ]
sip: Specifies the SIP protocol.
skype4b: Specifies the Skype4B protocol.
If you do not specify any keywords, this command clears all UCC entries.
# Clear all UCC entries.
<Sysname> reset ucc table
display ucc table
sip enable
Use sip enable to enable SIP-based UCC.
Use undo sip enable to disable SIP-based UCC.
sip enable
undo sip enable
SIP-based UCC is disabled.
UCC profile view
This command enables the service template or Layer 3 interface bound to a UCC profile to preferentially forward audio and video traffic, providing high-quality audio and video services.
This command takes effect only on audio and video services for wireless clients.
# Enable SIP-based UCC.
[Sysname] ucc profile ssidcompany
[Sysname-ucc-profile-ssidcompany] sip enable
ucc profile
skype4b app-share remark
Use skype4b app-share remark to configure priority marking for Skype4B application sharing packets.
Use undo skype4b app-share remark to restore the default.
skype4b app-share remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b app-share remark { dscp | dot1p }
Priority marking is not configured for Skype4B application sharing packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B application sharing packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B application sharing packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B application sharing packets.
# Mark DSCP priority 6 for Skype4B application sharing packets.
[Sysname-ucc-profile-ssidcompany] skype4b app-share remark dscp 6
skype4b enable
Use skype4b enable to enable Skype4B-based UCC.
Use undo skype4b enable to disable Skype4B-based UCC.
skype4b enable
undo skype4b enable
Skype4B-based UCC is disabled.
UCC profile view
This command enables the service template or Layer 3 interface bound to a UCC profile to preferentially forward audio, video, and application sharing traffic, providing high-quality audio, video, and application sharing services.
This command takes effect only on audio, video, and application sharing services for wireless clients.
# Enable Skype4B-based UCC.
[Sysname-ucc-profile-ssidcompany] skype4b enable
display ucc profile
ucc profile
skype4b listener
Use skype4b listener to enable the device to communicate with the Skype4B server and specify the port number.
Use undo skype4b listener to disable the device from communicating with the Skype4B server.
skype4b listener { http-port http-port-num | https-port https-port-num ssl-policy ssl-policy-name }
undo skype4b enable { http-port | https-port }
The device is disabled from communicating with the Skype4B server.
http-port http-port-num: Specifies the HTTP service port number in the range of 1025 to 55535.
https-port https-port-num: Specifies the HTTPS service port number in the range of 1025 to 55535.
ssl-policy ssl-policy-name: Specifies an SSL server policy name, a case-insensitive string of 1 to 31 characters.
# Enable the device to communicate with the Skype4B server and specify the port number as 3000.
[Sysname] skype4b listener http-port 3000
ssl server-policy (Security Command Reference)
skype4b video remark
Use skype4b video remark to configure priority marking for Skype4B video packets.
Use undo skype4b video remark to restore the default.
skype4b video remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b video remark { dscp | dot1p }
The DSCP value is 34 and the 802.1p priority is 4 for Skype4B video packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B video packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B video packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B video packets.
# Mark DSCP priority 6 for Skype4B video packets.
[Sysname-ucc-profile-ssidcompany] skype4b video remark dscp 6
skype4b voice remark
Use skype4b voice remark to configure priority marking for Skype4B voice packets.
Use undo skype4b voice remark to restore the default.
skype4b voice remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b voice remark { dscp | dot1p }
The DSCP value is 46 and the 802.1p priority is 6 for Skype4B voice packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B voice packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B voice packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B voice packets.
# Mark DSCP priority 6 for Skype4B voice packets.
[Sysname-ucc-profile-ssidcompany] skype4b voice remark dscp 6
ucc profile
Use ucc profile to create a UCC profile and enter its view, or enter the view of an existing UCC profile.
Use undo ucc profile to delete a UCC profile.
ucc profile profile-name
undo ucc profile profile-name
No UCC profiles exist.
profile-name: Specifies the name of a UCC profile, a case-insensitive string of 1 to 31 characters. The UCC profile name can contain hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create UCC profile ssidcompany and enter its view.
display ucc profile
ucc-profile
ucc-profile
Use ucc-profile to bind a UCC profile.
Use undo ucc-profile to remove the binding of a UCC profile.
ucc-profile profile-name
undo ucc-profile
No UCC profile is bound.
Service template view
Layer 3 interface view
If the client traffic forwarder is the AC and the clients are in different subnets, bind a UCC profile to both a service template and a Layer 3 interface.
If the client traffic forwarder is an AP, bind a UCC profile to a service template.
# Bind UCC profile ssidcompany to service template service.
[Sysname-ucc-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] ucc-profile ssidcompany
# Bind UCC profile ssidcompany to VLAN-interface 2.
[Sysname-Vlan-interface2] ucc-profile ssidcompany
sip enable
ucc profile
