15-EVPN Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R36xx)-6W10115-EVPN Command Reference
Table of Contents
Related Documents
01-EVPN commands
01-EVPN commands 299.79 KB
EVPN commands
ac interface
Use ac interface to map an interface or Ethernet service instance to a cross-connect.
Use undo ac interface to delete the mapping between a cross-connect and an interface or Ethernet service instance.
ac interface interface-type interface-number [ service-instance instance-id ] [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-15> ]
undo ac interface interface-type interface-number [ service-instance instance-id ]
No interface or Ethernet service instance is mapped to a cross-connect.
Cross-connect view
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096.
access-mode: Specifies an access mode. The default access mode varies by AC type.
·     If the AC is a Layer 3 interface, the default access mode is Ethernet.
·     If the AC is an Ethernet service instance, the default access mode depends on the frame match criterion that the Ethernet service instance uses.
¡     The default access mode is VLAN if the frame match criterion is configured by using the encapsulation s-vid vlan-id command.
¡     The default access mode is Ethernet if the frame match criterion is configured by using one of the following commands:
-     encapsulation s-vid vlan-id-list.
-     encapsulation s-vid vlan-id-list c-vid vlan-id-list.
-     encapsulation { default | untagged }.
The vlan-id-list argument specifies multiple VLAN IDs.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
track track-entry-number&<1-15>: Specifies a space-separated list of up to 15 track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
After you execute this command, packets received from the mapped Layer 3 interface or Ethernet service instance are forwarded to the PW or another AC bound to the cross-connect.
To configure this command for an Ethernet service instance, you must first use the encapsulation command to configure a frame match criterion for the Ethernet service instance.
The access mode determines how the PE treats the VLAN tag in Ethernet frames received from the AC. It also determines how the PE forwards Ethernet frames out of the AC.
·     VLAN access mode—Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The VLAN tag is called a P-tag, which is assigned by the service provider. Ethernet frames sent out of the AC must also carry the P-tag.
·     Ethernet access mode—If Ethernet frames from the AC have a VLAN tag in the header, the VLAN tag is called a U-tag, and the PE ignores it. Ethernet frames sent out of the AC do not carry the P-tag.
# Map HundredGigE 1/0/1 to cross-connect aaa in cross-connect group vpna.
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] connection aaa
[Sysname-xcg-vpna-aaa] ac interface hundredgige 1/0/1
# Map Ethernet service instance 200 that matches traffic of VLAN 200 on HundredGigE 1/0/1 to cross-connect actopw in cross-connect group vpn1.
[Sysname-HundredGigE1/0/1] service-instance 200
[Sysname-HundredGigE1/0/1-srv200] encapsulation s-vid 200
[Sysname-HundredGigE1/0/1-srv200] quit
[Sysname-HundredGigE1/0/1] quit
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1] connection actopw
[Sysname-xcg-vpn1-actopw] ac interface hundredgige 1/0/1 service-instance 200
connection (MPLS Command Reference)
display l2vpn interface (MPLS Command Reference)
display l2vpn service-instance (MPLS Command Reference)
encapsulation (MPLS Command Reference)
pw-type (MPLS Command Reference)
address-family l2vpn evpn
Use address-family l2vpn evpn to create the BGP EVPN address family and enter its view, or enter the view of the existing BGP EVPN address family.
Use undo address-family l2vpn evpn to delete the BGP EVPN address family and all settings in BGP EVPN address family view.
The BGP EVPN address family does not exist.
BGP instance view
Configuration made in BGP EVPN address family view takes effect only on routes and peers of the BGP EVPN address family that are on the public network.
# Create the BGP EVPN address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
arp forwarding-conversational-learning
Use arp forwarding-conversational-learning to enable conversational learning for remote ARP entries.
Use undo arp forwarding-conversational-learning to disable conversational learning for remote ARP entries.
This command is supported only in R3608 and later.
arp forwarding-conversational-learning [ aging aging-time ]
Conversational learning is disabled for remote ARP entries.
aging aging-time: Specifies an aging timer in minutes for remote ARP entries, in the range of 60 to 1440. The default value is 60.
Use this command only on an EVPN network.
By default, the device issues a remote ARP entry to the hardware after the ARP information is advertised to the local site by BGP EVPN routes. This feature enables the device to issue a remote ARP entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
After you enable this feature, the device periodically examines whether the ARP entries are used for packet forwarding. An ARP entry is deleted if its aging timer expires.
When a large number of remote ARP entries exist, set an appropriate aging timer to avoid traffic interruption caused by the aging of ARP entries. As a best practice, set the aging timer value higher than or equal to the number of remote ARP entries divided by 200.
# Enable conversational learning for remote ARP entries and set the entry aging timer to 80 minutes.
[Sysname] arp forwarding-conversational-learning aging 80
arp mac-learning disable
Use arp mac-learning disable to disable an EVPN instance from learning MAC addresses from ARP information.
Use undo arp mac-learning disable to restore the default.
An EVPN instance learns MAC addresses from ARP information.
VSI EVPN instance view
The MAC information and ARP information advertised by a remote device overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable an EVPN instance from learning MAC addresses from ARP information.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation mpls
[Sysname-vsi-aaa-evpn-mpls] arp mac-learning disable
arp-advertising disable
Use arp-advertising disable to disable ARP information advertisement for an EVPN instance.
Use undo arp-advertising disable to restore the default.
ARP information advertisement is enabled for an EVPN instance.
# Disable ARP information advertisement for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-mpls] arp-advertising disable
display bgp l2vpn evpn
Use display bgp l2vpn evpn to display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | route-distinguisher route-distinguisher [ route-type { auto-discovery | es | imet | ip-prefix | mac-ip } ] [ evpn-route route-length [ advertise-info ] ] | route-type { auto-discovery | es | imet | ip-prefix | mac-ip } | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP EVPN routes for the default BGP instance.
peer { ipv4-address | ipv6-address }: Specifies a peer by its IPv4 or IPv6 address.
advertised-routes: Specifies the routes advertised to the specified peer.
received-routes: Specifies the routes received from the specified peer.
statistics: Displays BGP EVPN route statistics.
route-distinguisher route-distinguisher: Specifies a route distinguisher (RD), a string of 3 to 21 characters. The RD can use one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
route-type: Specifies a route type.
auto-discovery: Specifies Ethernet auto-discovery routes.
es: Specifies Ethernet segment (ES) routes.
imet: Specifies inclusive multicast Ethernet tag (IMET) routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
evpn-route: Specifies a BGP EVPN route, a case-insensitive string of 1 to 512 characters.
route-length: Specifies the route length in bits, in the range of 0 to 65535.
evpn-prefix: Specifies a BGP EVPN route in the format of evpn-route/route-length, a case-insensitive string of 1 to 512 characters.
advertise-info: Displays advertisement information about BGP EVPN routes.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
mac-address: Specifies a MAC address in MAC/IP advertisement routes. If you specify the route-type keyword, to use this argument, you must also specify the mac-ip keyword.
If you do not specify any parameter, this command displays brief information about all BGP EVPN routes.
# Display brief information about all BGP EVPN routes.
<Sysname> display bgp l2vpn evpn
 Status codes: * - valid, > - best, d - dampened, h - history
               a - additional-path
 Total number of routes from all PEs: 3
 Route distinguisher: 1:1(vpna)
 Total number of routes: 3
* >  Network : [2][0][48][521f-b814-0106][0][0.0.0.0]/104
     NextHop : 0.0.0.0                                  LocPrf    : 100
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: i
* >  Network : [2][0][48][521f-b814-0106][32][10.1.1.10]/136
     MED     : 0
     Path/Ogn: i
* >i Network : [2][0][48][522b-3c6a-0406][32][10.1.1.20]/136
     NextHop : 3.3.3.3                                  LocPrf    : 100
     MED     : 0
     Path/Ogn: i
Status codes
Route status codes:
·     * - valid—Valid route.
·     > - best—Optimal route.
·     d - dampened—Dampened route.
·     h - history—History route.
·     i - internal—Internal route.
·     e - external—External route.
·     s - suppressed—Suppressed route.
·     S - stale—Stale route.
·     a - additional-path—Add-Path optimal route.
Origin
Origin of the route:
·     i – IGP—Originated in the AS. The origin of routes advertised by using the network command is IGP.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete.
Network
BGP EVPN route/route length. BGP EVPN routes are as follows:
·     [1][ESI][EthernetTagID]
¡     1—Ethernet auto-discovery route.
¡     ESI—Ethernet segment identifier (ESI).
¡     EthernetTagID—Ethernet tag ID.
·     [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress]
¡     2—MAC/IP advertisement route.
¡     MACLength—MAC address length.
¡     MAC—MAC address.
¡     IPAddressLength—IP address length.
¡     IPAddress—IP address.
·     [3][EthernetTagID][IPAddressLength][IPAddress]
¡     3—IMET route.
¡     IPAddress—IP address of the originating router.
·     [4][ESI][IPAddressLength][IPAddress]
¡     4—ES route.
¡     ESI—ESI.
·     [5][EthernetTagID][IPAddressLength][IPAddress]
¡     5—IP prefix advertisement route.
NextHop
Next hop IP address.
LocPrf
Local precedence.
PrefVal
Preferred value.
OutLabel
Outgoing label.
MED
Multi-Exit Discriminator (MED) attribute.
Path/Ogn
AS_PATH and ORIGIN attributes of the route.
# Display detailed information about BGP EVPN route [1][0001.0203.0405.0607.0809][5]/120 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][0001.0203.0405.0607.0809][5] 120
 BGP local router ID: 172.16.250.133
 Local AS number: 100
 Route distinguisher: 1.1.1.1:100
 Total number of routes: 1
 Paths:   1 available, 1 best
 BGP routing table information of [1][0001.0203.0405.0607.0809][5]/120:
 Rely nexthop    : 10.1.1.2
 Original nexthop: 10.1.1.2
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: MPLS >, <ESI Label: Flag 0,
                   Label 1>, <EVPN Layer 2 Attributes: MTU 1500, Control Flags 0x02>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet auto-discovery route
 ESI             : 0001.0203.0405.0607.0809
 Ethernet tag ID : 5
 MPLS label      : 10
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes.
From
IP address of the BGP peer that advertised the route.
Rely nexthop
Next hop after route recursion. If no next hop is found, this field displays not resolved.
Original nexthop
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message.
OutLabel
Outgoing label of the route.
Ext-Community
Extended community attributes:
·     RT.
·     Encapsulation Type.
·     ESI Label.
·     EVPN Layer 2 Attributes.
·     E-Tree Leaf Label—E-tree Leaf flag and label.
RxPathID
Add-Path ID value of the received route.
This field is not supported by the BGP EVPN address family.
TxPathID
Add-Path ID value of the sent route.
AS-path
AS_PATH attribute of the route. This attribute records the ASs the route has passed and avoids routing loops.
Origin
·     igp—Originated in the AS. The origin of routes advertised by using the network command is IGP.
·     egp—Learned through EGP.
·     incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete.
Attribute value
Attributes of the route:
·     MED—MED value for the destination network.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Route preference value.
Current state of the route:
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
·     delay—The route will be delayed for optimal route selection. This field is displayed only in the detailed command output.
·     bgp-rib-only—The route will not be flushed to the routing table. This field is displayed only in the detailed command output.
IP precedence
IP precedence in the range of 0 to 7. N/A indicates that the IP precedence is invalid.
QoS local ID
QoS local ID in the range of 1 to 4095. N/A indicates that the QoS local ID is invalid.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the traffic index is invalid.
MPLS label
MPLS label. The current software version does not support this field.
# Display detailed information about BGP EVPN route [2][5][48][0001-0203-0405][32][4.5.5.5]/136 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
 BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
                   >, <Encapsulation Type: MPLS>, <Router's Mac: 0006-0708-0910
                   >, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : MAC/IP advertisement route
 Ethernet tag ID : 5
 MAC address     : 0001-0203-0405
 IP address      : 5.5.5.5/32
 MPLS label1     : 10
 MPLS label2     : 0
Ext-Community
·     RT.
·     Router's Mac.
·     MAC Mobility—MAC mobility.
¡     Flag—Indicates whether the MAC address can move. A value of 1 indicates that the MAC address cannot move, and a value of 0 indicates that the MAC address can move.
¡     SeqNum—Identifies the most recent move of the MAC address.
·     Default GateWay—Route for the default gateway.
MPLS label1
MPLS label.
MPLS label2
L3 VXLAN ID used for Layer 3 forwarding. This field is not supported in the current software version.
# Display detailed information about BGP EVPN route [3][0][32][5.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
 BGP routing table information of [3][0][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: MPLS>
 RxPathID        : 0x0
 TxPathID        : 0x0
 PMSI tunnel     : Flag 0, TunnelType 6, Label 10, EndPointAddress 10.1.1.2
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0,pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Inclusive multicast Ethernet tag route
 Ethernet tag ID : 0
 Origin address  : 5.5.5.5/32
Ext-Community
·     RT.
PMSI tunnel
P-Multicast Service Interface (PMSI) tunnel information:
·     Flag—Flags. This field is fixed at 0 in the current software version.
·     TunnelType—Tunnel type. This field is fixed at 6 in the current software version, which represents a head-end replication tunnel.
·     Label—VXLAN ID.
·     EndPointAddress—Tunnel destination address.
Origin address
# Display detailed information about BGP EVPN route [4][0000.0000.0000.0000.000a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][0000.0000.0000.0000.000a][32][4.5.5.5] 128
 BGP routing table information of [4][0000.0000.0000.0000.000a][32][4.5.5
.5]/128:
 OutLabel        : 0
 Ext-Community   : <ES-Import RT: 0000-0000-0000>, <Encapsulation Type: MPLS>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet segment route
 ESI             : 0000.0000.0000.0000.000a
 Origin address  : 4.5.5.5/32
Table 5 Command output
Ext-Community
·     RT.
·     ES-Import RT.
Origin address
# Display detailed information about BGP EVPN route [5][10][32][4.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
 BGP routing table information of [5][10][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: MPLS>, <Router's Mac:
                   0006-0708-0910>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 Ethernet tag ID : 10
 IP address      : 4.5.5.5/32
 Gateway address : 0.0.0.0
 MPLS Label      : 1
Table 6 Command output
Ext-Community
·     RT.
·     Router's Mac.
IP address
IP address and prefix length.
MPLS Label
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][0000.0000.0000.0000.000a][32][4.5.5.5] 128 advertise-info
 Paths:   1 best
 BGP routing table information of [4][0000.0000.0000.0000.000a][32][4.5.5.5]/128:
    10.2.1.2
Table 7 Command output
Paths
Peers to whom the route has been advertised and the number of the peers.
 OutLabel        : NULL
                   0006-0708-0910>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MPLS Label      : 1
 Re-origination  : Enable
 Route distinguisher: 2.2.2.2:100
 OutLabel        : 0
                   0006-0708-0910>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 State           : valid, external, best, reoriginated, remoteredist
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 MPLS Label      : 20
Table 8 Command output
Ext-Community
·     RT.
·     Router's Mac.
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
·     reoriginated—Reoriginated route.
·     localredist—IP prefix advertisement route generated based on a local route.
·     remoteredist—IP prefix advertisement route generated based on a remote route.
IP address
MPLS Label
Re-origination
State of route reorigination:
·     Enable.
·     Disable.
display evpn auto-discovery
Use display evpn auto-discovery to display information about peers that are automatically discovered through BGP.
display evpn auto-discovery { ethernet-ad mpls [ peer ip-address] [ vsi vsi-name ] | { imet | mac-ip } [ mpls ] [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
ethernet-ad: Specifies Ethernet auto-discovery routes.
imet: Specifies peers discovered through IMET routes.
mpls: Specifies the EVPN VPLS network.
peer ip-address: Specifies a peer by its IP address. If you do not specify this option, the command displays information about all automatically discovered peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays peer information about all VSIs.
macip-prefix: Specifies peers discovered through MAC/IP advertisement and IP prefix advertisement routes.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays peer information about all next hops.
count: Displays the number of peers. If you do not specify this keyword, the command displays detailed peer information.
# Display information about peers discovered through Ethernet auto-discovery routes for EVPN VPLS.
<Sysname> display evpn auto-discovery ethernet-ad mpls
Total number of automatically discovered peers: 1
VSI name: vpnb
Destination IP  In/Out label    Tunnel Mode
7.7.7.7         1420/-          PW
Table 9 Command output
In/Out label
Incoming and outgoing labels for the PW. If the labels are invalid, this field displays a hyphen (-).
Tunnel Mode
Tunnel mode, which can only be PW.
# Display information about peers discovered through IMET routes for EVPN VPLS.
<Sysname> display evpn auto-discovery imet
VSI name: vpna
RD                    PE_address      In/Out label    Tunnel mode
1:1                   1.1.1.1         1151/1151       PW
Table 10 Command output
PE_address
Identifier of the remote device on the VSI.
Tunnel mode
In/Out label
# Display information about IPv4 peers discovered through MAC/IP advertisement routes for EVPN VPLS.
<Sysname> display evpn auto-discovery mac-ip
VSI name: vpnb
7.7.7.7         1420/1419       PW
Table 11 Command output
Tunnel mode
In/Out label
display evpn es
Use display evpn es to display EVPN ES information.
display evpn es { local [ vsi vsi-name  | xconnect-group group-name ] [ esi esi-id ] [ verbose ] | remote [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ] [ nexthop next-hop ] }
local: Specifies local ES information.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ES information about all VSIs.
esi esi-id: Specifies an ES by its ESI in XXXX.XXXX.XXXX.XXXX.XXXX format. Each X represents a hexadecimal digit. The ESI must begin with 00 and cannot be all zeros. If you do not specify this option, the command displays information about all ESs.
verbose: Displays detailed ES information. If you do not specify this keyword, the command displays brief ES information.
remote: Specifies remote ES information.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays ES information received from all next hops.
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays EVPN local or remote ES information about all cross-connect groups.
# Display brief information about local ESs of VSI vpna.
<Sysname> display evpn es local vsi vpna
Redundancy mode: A – All-active, S – Single-active
VSI name : vpna
ESI                         Tag ID      DF address      Mode  State ESI label
0001.0002.0002.0002.0002    -           1.1.1.1         A     Up    1000
0001.0002.0003.0004.0005    -           1.1.1.1         A     Up    1001
0003.0003.0003.0003.0003    2           2.2.2.2         A     Up    1002
# Display brief information about local ESs of cross-connect group vpna.
<Sysname> display evpn es local xconnect-group vpna
Xconnect group name: vpna
0001.0002.0002.0002.0002    -           1.1.1.1         A     Up    -
0001.0002.0003.0004.0005    -           1.1.1.1         A     Up    -
0003.0003.0003.0003.0003    2           2.2.2.2         A     Up    -
Table 12 Command output
Xconnect group name
Cross-connect group name.
Tag ID
Ethernet tag ID.
DF address
Router ID of the device elected as the DF.
Mode
Redundancy mode of the ES:
·     A—All-active mode.
·     S—Single-active mode.
State of the ES:
·     Up.
·     Down.
ESI label
ESI label. For EVPN VPWS, this field is invalid and displays a hyphen (-).
# Display detailed information about local ESs of all VSIs.
<Sysname> display evpn es local verbose
VSI name : v1
  ESI                      : 0003.0003.0003.0003.0003
  Interface                : HundredGigE1/0/1
  Redundancy mode          : All-active
  State                    : Up
  AD-delay remaining time  : 10
  ACs                      :
    Link ID     Service instance ID   Tag ID      DF address        ESI label
    0           1                     1           1.1.1.1           1001
    1           3                     3           3.3.3.3           1002
    2           10                    10          2.2.2.2           1003
VSI name : vpna
  ESI                      : 0001.0002.0002.0002.0002
  Interface                : HundredGigE1/0/2
  State                    : Up
  ACs                      :
    1           -                     -           1.1.1.1           -
Xconnect group name : vpna
 Connection name           : aa
  AC                       : HGE1/0/5 srv1
  State                    : Up
  Link ID                  : 0
  Tag ID                   : 10
  DF address               : 1.1.1.1
Table 13 Command output
Xconnect group name
Connection name
Cross-connect name.
AC
AC name:
·     A Layer 3 interface name.
·     A Layer 2 interface name and an Ethernet service instance name.
Redundancy mode
State of the ES:
·     Up.
·     Down.
If the ES is not manually assigned an ESI, a hyphen (-) is displayed.
Remaining time of the advertisement delay timer for Ethernet auto-discovery routes, in seconds.
ACs
The VSI's ACs on the ES.
Link ID
The AC's link ID on the VSI.
Service instance ID
Ethernet service instance ID.
Tag ID
Ethernet tag ID.
DF address
Router ID of the device elected as the DF. If the device is not the DF of an AC, a hyphen (-) is displayed.
ESI label
# Display information about remote ESs of all VSIs.
<Sysname> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
VSI name : v1
  A-D per ES routes       :
    Peer IP             Remote Redundancy mode
    1.1.1.1             All-active
  A-D per EVI routes      :
    Tag ID      Peer IP
    1           1.1.1.1
    3           1.1.1.1
    10          1.1.1.1
VSI name : vpna
  ESI                     : 0001.0000.0000.0000.0001
  Ethernet segment routes :
    1.1.1.1
    3.3.3.3
  A-D per ES routes       :
    1.1.1.1             All-active
    3.3.3.3             All-active
    Tag ID      Peer IP
    -           1.1.1.1
    -           3.3.3.3
  ESI                     : 0001.0002.0003.0004.0005
    1.1.1.1
  A-D per ES routes       :
    1.1.1.1             All-active
    Tag ID      Peer IP
    -           1.1.1.1
Xconnect group name : a
    123.123.123.123
    3.3.3.3
  A-D per ES routes       :
    123.123.123.123     All-active
    3.3.3.3             All-active
    Tag ID      Peer IP          Control Flags
    2           3.3.3.3          P
    4           123.123.123.123  PC
  ESI                     : 0001.0000.0000.0000.0002
    123.123.123.123
    3.3.3.3
  A-D per ES routes       :
    123.123.123.123     Single-active
    3.3.3.3             All-active
    2           3.3.3.3          PC
    4           123.123.123.123  P
# Display remote ES information received from next hop 3.3.3.3 for VSI vpna.
<Sysname> display evpn es remote vsi vpna nexthop 3.3.3.3
VSI name : vpna
    3.3.3.3
  A-D per ES routes       :
    3.3.3.3
    Tag ID      Peer IP
    -           3.3.3.3
Table 14 Command output
Xconnect group name
Ethernet segment routes for the ES.
A-D per Ethernet segment routes
A-D per Ethernet segment routes for the ES.
A-D per EVI routes
A-D per EVI routes for the ES.
Tag ID
Ethernet tag ID.
Peer IP
IP address of the remote peer.
Redundancy mode of the remote ES:
·     All-active.
·     Single-active.
Control Flags
Layer 2 attributes control flags of the remote route:
·     P—Primary flag.
·     B—Backup flag.
·     C—Control word flag. This value is not supported in the current software version.
display evpn route arp
Use display evpn route arp to display EVPN ARP entries.
display evpn route arp [ local | remote ] [ vpn-instance vpn-instance-name ] [ count ]
local: Specifies local ARP entries.
remote: Specifies remote ARP entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays EVPN ARP entries for all VPN instances.
count: Displays the number of ARP entries. If you do not specify this keyword, the command displays detailed information about ARP entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP entries.
# Display all EVPN ARP entries.
<Sysname> display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping        I - Invalid
VPN instance:abc                             Interface:Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  a0ce-7e40-0400  0           GL
10.1.1.11       0001-0001-0001  a0ce-7e40-0400  0           DL
10.1.1.12       0001-0001-0011  a0ce-7e41-0401  0           B
10.1.1.13       0001-0001-0021  a0ce-7e42-0402  0           B
10.1.1.101      0001-0011-0101  a0ce-7e40-0400  0           SL
10.1.1.102      0001-0011-0102  0011-9999-0000  0           BS
Public instance                             Interface:Vsi-interface2
11.1.1.1        0033-0033-0033  a0ce-7e40-0400  0           GL
11.1.1.11       0011-0011-0011  a0ce-7e40-0400  0           DL
# Display the total number of EVPN ARP entries.
<Sysname> display evpn route arp count
Total number of entries: 6
Table 15 Command output
VSI interface.
Flags
ARP entry type:
·     D—The entry is dynamically learned.
·     B—The entry is learned from BGP EVPN routes.
·     L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active.
·     G—The entry for the gateway is active.
·     S—The static entry is active.
·     M—The entry from a remote VXLAN mapped to a local VXLAN is active. This type is not supported in the current software version.
·     I—The entry is invalid. Reasons:
¡     The VSI has been administratively shut down by using the shutdown command.
¡     The outgoing tunnel interface does not exist.
display evpn route arp suppression
Use display evpn route arp suppression to display EVPN ARP flood suppression entries.
display evpn route arp suppression [ mpls ] [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local ARP flood suppression entries.
remote: Specifies remote ARP flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ARP flood suppression entries for all VSIs.
count: Displays the number of ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about ARP flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP flood suppression entries.
# Display all ARP flood suppression entries for EVPN VPLS.
<Sysname> display evpn route arp suppression
VSI name: vpna
IP address      MAC address       Flags           Encap
10.1.1.12       0002-0002-0002    B               MPLS
10.1.1.13       0002-0002-0002    BI              MPLS
10.1.1.101      0001-0011-0101    BS              MPLS
10.1.1.102      0001-0011-0102    DL              MPLS
# Display the total number of ARP flood suppression entries.
<Sysname> display evpn route arp suppression count
Total number of entries: 1
Table 16 Command output
Flags
ARP flood suppression entry type:
Encap
Packet encapsulation type, which can only be MPLS.
display evpn route mac
Use display evpn route mac to display EVPN MAC address entries.
display evpn route mac [ mpls ] [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local MAC address entries.
remote: Specifies remote MAC address entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays MAC address entries for all VSIs.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
If you do not specify the mpls keyword, this command displays EVPN MAC address entries for EVPN VPLS. If you do not specify the local or remote keyword, this command displays both local and remote EVPN MAC address entries.
# Display all MAC address entries for EVPN VPLS.
<Sysname> display evpn route mac
       E – Multihoming ES sync    F - Leaf
VSI name: bbb
MAC address     Link ID/Name   Flags   Encap           Next hop
0001-2000-5000  9              BF      MPLS            4.4.4.4
# Display the total number of EVPN MAC address entries.
<Sysname> display evpn route mac count
Total number of entries: 2
Table 17 Command output
Link ID/Name
For a local MAC address, this field displays the AC's link ID on the VSI.
For a remote MAC address, this field displays the tunnel interface name.
Flags
MAC address entry type:
·     E—The entry is synchronized between devices at a multihomed site.
·     F—The entry is from a leaf AC of EVPN E-tree.
Encap
Next hop
IP address of the remote device. If the MAC address entry is a local entry, a hyphen (-) is displayed.
display evpn route nd
Use display evpn route nd to display EVPN ND entries.
display evpn route nd [ local | remote ] [ vpn-instance vpn-instance-name ] [ count ]
local: Specifies local ND entries.
remote: Specifies remote ND entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays EVPN ND entries for all VPN instances.
count: Displays the number of ND entries. If you do not specify this keyword, the command displays detailed information about ND entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ND entries.
# Display all EVPN ND entries.
<Sysname> display evpn route nd
VPN instance: vpn1                            Interface: Vsi-interface1
IPv6 address :   AD80:0300:1000:0050:0200:0300:0100:0012
MAC address  :   0001-0001-0001       Router MAC   :   a0ce-7e40-0400
VSI index    :   0                    Flags        :   GL
IPv6 address :   AD10:0300:1000:0020:0200:0300:0100:0022
MAC address  :   0001-0001-0002       Router MAC   :   a0ce-7e40-0411
Public instance                               Interface: Vsi-interface1
IPv6 address :   BC80:0300:1000:0050:0200:0300:0100:0033
MAC address  :   0002-0002-0001       Router MAC   :   a0ce-7e40-0422
IPv6 address :   BC10:0300:1000:0020:0200:0300:0100:0034
MAC address  :   0002-0002-0002       Router MAC   :   a0ce-7e40-0433
# Display the total number of EVPN ND entries.
<Sysname>display evpn route nd count
Table 18 Command output
VSI interface.
Flags
ND entry type:
display evpn routing-table
Use display evpn routing-table to display the EVPN routing table for a VPN instance.
display evpn routing-table [ ipv6 ] vpn-instance vpn-instance-name [ count ]
ipv6: Specifies IPv6 information. If you do not specify this keyword, the command displays IPv4 information.
count: Displays the number of entries in the routing table. If you do not specify this keyword, the command displays detailed information about the routing table.
# Display the EVPN IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI   A – A-D ready   L - Local ES exists
VPN instance:vpna                            Local L3VNI:111
IP address       Nexthop          Outgoing interface    NibID       Flags
10.0.0.2         2.2.2.2          Vsi-interface111      0x18000000  EAL
10.0.0.3         3.3.3.3          Vsi-interface111      0x18000001  EA
20.0.0.2         3.3.3.3          Vsi-interface111      0x18000001  -
# Display the number of EVPN route entries in the IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1 count
# Display the EVPN IPv6 routing table for VPN instance vpna.
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna                              Local L3VNI: 7
Nexthop             :      1.1.1.1
Outgoing interface  :      Vsi-interface3
NibID               :      0x18000000
IPv6 address        :      BC10:0300:1000:0020:0200:0300:0100:0035
Nexthop             :      2.2.2.2
NibID               :      0x18000001
Table 19 Command output
Local L3VNI
L3 VXLAN ID associated with the VPN instance or the public instance. This field is not supported in the current software version.
NibID
Next hop ID.
Flags
Flags of the route:
·     E—The route carries a valid ESI.
·     A—All Ethernet auto-discovery routes are received. The ECMP routes for the next hop can be issued.
·     L—An active local ESI exists. Remote routes are not issued.
·     -—The MAC/IP advertisement route does not have a valid ESI. ECMP routes are not supported.
display evpn vsi
Use display evpn vsi to display VSI information.
display evpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information about all VSIs.
verbose: Displays detailed VSI information. If you do not specify this keyword, the command displays brief VSI information.
# Display brief information about all VSIs.
<Sysname> display evpn vsi
Total number of VSIs: 2
VSI name                        VSI index
vpna                            0
vpnb                            1
# Display detailed information about all VSIs.
<Sysname> display evpn vsi verbose
VSI name: vpna
  VSI index                          : 0
  Encapsulation                      : MPLS
  Route distinguisher                : 1:1
  Export VPN targets                 : 1:1 2:2 3:3
  Import VPN targets                 : 1:1 2:2 3:3
  MAC advertisement                  : Disabled
  ARP advertisement                  : Disabled
  ARP-based MAC learning             : Disabled
  ND-based MAC learning              : Disabled
  MPLS label                         : 1150
  IMET MPLS label                    : 1149
  Tunnel policy                      : policy1
  PW class                           : class1
  Control word                       : Disabled
  E-Tree                             : Disabled
  PW type                            : Ethernet
  Sequencing                         : Both
  Flow label                         : Both
Table 20 Command output
Encapsulation
EVPN encapsulation type, which can only be MPLS.
MAC advertisement
Status of MAC address advertisement:
·     Enabled.
·     Disabled.
ARP advertisement
Status of ARP advertisement:
·     Enabled.
·     Disabled.
Whether EVPN learns MAC addresses from ARP information:
·     Enabled.
·     Disabled.
Whether EVPN learns MAC addresses from ND information:
·     Enabled.
·     Disabled.
MPLS label
MPLS label in MAC/IP advertisement routes.
IMET MPLS label
MPLS label in IMET routes.
Tunnel policy
Tunnel policy used by the EVPN instance.
PW class
PW class used by the EVPN instance.
Control word
Status of the control word feature:
·     Enabled.
·     Disabled.
E-Tree
Status of EVPN E-tree:
·     Enabled.
·     Disabled.
PW type
PW type:
·     Ethernet.
·     VLAN.
Sequencing
Sequencing on the PW. The value is Both.
A hyphen (-) in this field indicates that sequencing is disabled on the PW.
Flow label
Flow label capability:
·     Both—Flow label sending and receiving capabilities.
·     Send—Flow label sending capability.
·     Recv—Flow label receiving capability.
This field displays a hyphen (-) if the flow label feature is disabled.
evpn encapsulation
vsi
display evpn route xconnect-group
Use display evpn route xconnect-group to display EVPN information about cross-connects.
display evpn route xconnect-group [ name group-name [ connection connection-name ] ] [ count ]
name group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays EVPN information about all cross-connect groups.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters excluding hyphens (-). If you do not specify a cross-connect, this command displays EVPN information about all cross-connects in the specified cross-connect group.
count: Displays the number of EVPN cross-connects. If you do not specify this keyword, the command displays detailed EVPN information.
If you do not specify any parameters, this command displays detailed EVPN information about all cross-connects.
# Display detailed EVPN information about all cross-connects.
<Sysname> display evpn route xconnect-group
Xconnect group name: aa
 Connection name: aaa
  Local service ID    : 16777215
  Remote service ID   : 16777214
  In label            : 502
  Local MTU           : 1500
  AC State            : Up
  PW type             : VLAN
    Nexthop          ESI                       Out label  Flags  MTU    state
    192.123.123.123  0001.0002.0002.0002.0001  1299       PC     1500   Up
    192.1.1.1        0001.0002.0002.0002.0001  1026       B      1500   Down
 Connection name: aab
  ESI                 : 0000.0000.0000.0000.0000
  Remote service ID   : 2
  In label            : 323
  Local MTU           : 1500
  AC State            : Up
  PW type             : VLAN
    192.1.1.1        0002.0002.0002.0002.0001  1234       P      1500   Up
    192.2.1.2        0002.0002.0002.0002.0001  603        P      1500   Up
 Connection name: aac
  Local service ID    : 3
  Remote service ID   : 4
  Control word        : Enabled
  In label            : -
  Local MTU           : 1500
  AC State            : Up
  PW type             : Ethernet
    192.1.1.3        0000.0000.0000.0000.0000  555        P      1500   Idle
# Display the total number of EVPN cross-connects.
<Sysname> display evpn route xconnect-group count
Table 21 Command output
Xconnect group name
Connection name
Cross-connect name.
In label
PW incoming label.
Local MTU
Local MTU in bytes.
AC State
AC state:
·     Up.
·     Down.
This field displays a hyphen (-) if no AC is configured.
PW type
PW data encapsulation type:
·     Ethernet.
·     VLAN.
Nexthop
Remote PE address.
Out label
PW outgoing label.
Flags
PW attribute flags:
·     P—The received route has the primary flag. A primary PW needs to be set up.
·     B—The received route has the backup flag. A backup PW needs to be set up.
·     C—The received route has the control word flag, which indicates that control word is enabled on the peer. For the EVPN PWs to come up, you must enable control word on the local device. This value is not supported in the current software version.
MTU
MTU in the received route, in bytes.
state
EVPN PW state:
·     Up.
·     Down.
·     Idle—The incoming or outgoing label is not available.
display l2vpn forwarding evpn
Use display l2vpn forwarding evpn to display forwarding information about VSIs of EVPN VPLS and EVPN VPWS.
display l2vpn forwarding evpn [ vsi [ name vsi-name ] [ verbose ] ] slot slot-number
vsi: Specifies VSI forwarding information. If you do not specify this keyword, the command displays both VSI and cross-connect forwarding information about EVPN.
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays forwarding information about all VSIs.
verbose: Displays detailed forwarding information. If you do not specify this keyword, the command displays brief forwarding information.
slot slot-number: Specifies a card by its slot number.
# Display brief forwarding information about all VSIs of EVPN VPLS on slot 1.
<Sysname> display l2vpn forwarding evpn vsi slot 1
VSI name                       VSI index
vpls1                          0
# Display detailed forwarding information about all VSIs of EVPN VPLS on slot 1.
<Sysname> display l2vpn forwarding evpn vsi verbose slot 1
VSI name: vpls1
  VSI index                         : 0
  MPLS label                        : 1150
  Control word                      : disabled
  PW type                           : Ethernet
  Sequencing                        : Both
  Flow label                        : Both
Table 22 Command output
Encapsulation
EVPN encapsulation type. MPLS represents MPLS encapsulation.
MPLS label
IMET MPLS label
Control word
·     enabled.
·     disabled.
PW type
PW type:
·     Ethernet.
·     VLAN.
Sequencing
Flow label
evpn encapsulation
vsi
display l2vpn forwarding evpn split-horizon
Use display l2vpn forwarding evpn split-horizon to display site-facing interfaces excluded from traffic forwarding by split horizon.
display l2vpn forwarding evpn split-horizon ac interface interface-type interface-number service-instance instance-id [ slot slot-number ]
ac interface interface-type interface-number service-instance instance-id: Specifies an Ethernet service instance on a Layer 2 interface. The interface-type interface-number argument specifies the interface by its type and number. The instance-id argument specifies the Ethernet service instance by its ID in the range of 1 to 4096. These parameters apply to EVPN VPLS.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information on the active MPU.
# Display site-facing interfaces excluded from traffic forwarding for AC HundredGigE 1/0/1.
<Sysname> display l2vpn forwarding evpn split-horizon ac interface hundredgige 1/0/1
Interface name  : HundredGigE1/0/1
AC link ID              : 0
Service instance ID     : 100
PW count                : 2
VSI name        PW link ID         ESI label
vpna            8                  775128
vpna            9                  775128
esi
Use esi to assign an ESI to an interface.
Use undo esi to restore the default.
esi esi-id
undo esi
No ESI is assigned to an interface.
Interface view
An ESI uniquely identifies an ES. The links on interfaces with the same ESI belong to the same ES. Traffic of the ES can be distributed among the links for load sharing.
To modify the ESI of an interface, first use the undo esi command to delete the original ESI.
# Assign ESI 0000.0001.0002.0003.0004 to HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] esi 0000.0001.0002.0003.0004
evpn encapsulation
Use evpn encapsulation to create an EVPN instance and enter its view, or enter the view of an existing EVPN instance.
Use undo evpn encapsulation to restore the default.
In VSI view:
In cross-connect group view:
No EVPN instance is created.
VSI view
Cross-connect group view
mpls: Specifies MPLS encapsulation.
Before you can configure EVPN settings for a VSI or cross-connect group, you must create an EVPN instance on it.
# Create an EVPN instance on VSI aaa, specify MPLS encapsulation, and enter VSI EVPN instance view.
[Sysname] vsi aaa
evpn frr remote
Use evpn frr remote enable to enable remote FRR on an EVPN instance.
Use evpn frr remote disable to disable remote FRR on an EVPN instance and delete existing backup PWs.
Use undo evpn frr remote to restore the default.
evpn frr remote [ disable | enable ]
An EVPN instance uses the global remote FRR configuration of EVPN VPWS.
Cross-connect group EVPN instance view
Remote FRR enables two PEs on an EVPN VPWS network to set up a primary PW and a backup PW between them to ensure high availability. The PEs use the primary PW to forward traffic as long as it is available. When the primary PW fails, the PEs switch traffic to the backup PW.
On an EVPN instance, EVPN instance-specific remote FRR configuration takes precedence over global remote FRR configuration.
# Enable remote FRR on the EVPN instance of cross-connect group xcga.
[Sysname] xconnect-group xcga
[Sysname-xcg-xcga] evpn encapsulation mpls
[Sysname-xcg-xcga-evpn-mpls] evpn frr remote enable
evpn vpws-frr remote
evpn local-service-id remote-service-id
Use evpn local-service-id remote-service-id to create an EVPN PW.
Use undo evpn local-service-id remote-service-id to delete an EVPN PW.
evpn local-service-id local-service-id remote-service-id remote-service-id [ tunnel-policy tunnel-policy-name ] [ pw-class class-name ]
undo evpn local-service-id local-service-id remote-service-id remote-service-id
No EVPN PWs exist.
Cross-connect view
local-service-id: Specifies a local service ID in the range of 1 to 16777215.
remote-service-id: Specifies a remote service ID in the range of 1 to 16777215.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the PW uses the default tunnel policy.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW data encapsulation type for the PW. If you do not specify a PW class, the PW data encapsulation type is determined by the link type of the interface.
You can use the evpn local-service-id remote-service-id command to concatenate two EVPN PWs on the same cross-connect.
To modify an EVPN PW, first use the undo evpn local-service-id remote-service-id command to delete the original EVPN PW.
You cannot use this command and the peer command together in cross-connect view.
# Create an EVPN PW, and specify tunnel policy aaa and PW class bbb for it.
[Sysname] xconnect-group aaa
[Sysname-xcg-aaa] connection ac2pw
[Sysname-xcg-aaa- ac2pw] evpn local-service-id 2 remote-service-id 4 tunnel-policy aaa pw-class bbb
evpn mpls routing-enable
Use evpn mpls routing-enable to enable EVPN to advertise the routes of a VPN instance.
Use undo evpn mpls routing-enable to disable EVPN from advertising the routes of a VPN instance.
EVPN does not advertise the routes of VPN instances.
VPN instance IPv4 address family view
VPN instance IPv6 address family view
This command enables devices to exchange the routes of a VPN instance by using IP prefix advertisement routes with MPLS encapsulation. After you execute this command for a VPN instance, the device advertises the routes of the VPN instance through IP prefix advertisement routes. When receiving IP prefix advertisement routes with MPLS encapsulation, the device adds the routes that belong to the VPN instance to the routing table.
For EVPN to add MPLS encapsulation to IP prefix advertisement routes, you must execute the peer advertise encap-type mpls command in BGP EVPN address family view.
# Enable EVPN to advertise the IPv4 routes of VPN instance vpna.
[Sysname-vpn-instance-vpna] address-family ipv4
[Sysname-vpn-ipv4-vpna] evpn mpls routing-enable
evpn multihoming advertise disable
Use evpn multihoming advertise disable to disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
Use undo evpn multihoming advertise disable to restore the default.
The device advertises EVPN multihoming routes.
EVPN multihoming routes include Ethernet auto-discovery routes and Ethernet segment routes.
In a multihomed EVPN network, execute this command on a redundant PE before you reboot it. This operation allows other devices to refresh their EVPN routing table to prevent traffic interruption caused by the reboot.
# Disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
[Sysname] evpn multihoming advertise disable
evpn multihoming advertise ignore-ethernet-tag
Use evpn multihoming advertise ignore-ethernet-tag to enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
Use undo evpn multihoming advertise ignore-ethernet-tag to restore the default.
By default, the device advertises Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags.
This command is available only in the EVPN VPLS multihoming scenario. Use this command on the redundant PEs at a dualhomed site.
This command enables the device to do the following:
·     Withdraw the Ethernet auto-discovery routes and MAC/IP advertisement routes that have been advertised.
·     Set the Ethernet tag to 0 for the Ethernet auto-discovery routes and MAC/IP advertisement routes and re-advertise them.
After you configure ESIs for ACs on the redundant edge devices at a dualhomed site, the edge devices advertise Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags. If the remote peers are unable to identify Ethernet tags, you must execute this command on the redundant edge devices to enable communication with the peers.
When you use this command, follow these restrictions and guidelines:
·     After you assign an ESI to a Layer 2 Ethernet or aggregate interface, you must map the Ethernet service instances created on the interface to different VSIs. If two interfaces use the same ESI, you must map the Ethernet service instances created on them to different VSIs.
·     After you assign an ESI to a Layer 3 main interface, its subinterfaces inherit the ESI if they do not have one. In addition, you must map two subinterfaces to different VSIs if the subinterfaces have the same ESI.
# Enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
[Sysname] evpn multihoming advertise ignore-ethernet-tag
esi
evpn multihoming timer df-delay
Use evpn multihoming timer df-delay to set the DF election delay.
Use undo evpn multihoming timer df-delay to restore the default.
evpn multihoming timer df-delay delay-value
The DF election delay is 3 seconds.
delay-value: Specifies the DF election delay, in the range of 1 to 1200 seconds.
DF election delay defines the minimum interval allowed between two DF elections.
The DF election can be triggered by site-facing interface status changes, redundant PE membership changes, and interface ESI changes. To prevent frequent DF elections from degrading network performance, set the DF election delay.
# Set the DF election delay to 5 seconds.
[Sysname] evpn multihoming timer df-delay 5
evpn multihoming vpws-frr local
Use evpn multihoming vpws-frr local to enable local FRR globally for EVPN VPWS.
Use undo evpn multihoming vpws-frr local to disable local FRR globally for EVPN VPWS and delete existing bypass PWs.
Local FRR is disabled globally for EVPN VPWS.
Local FRR enables two PEs at a multihomed EVPN VPWS network site to set up a bypass PW between them. This feature helps reduce the traffic loss caused by AC failure.
At a multihomed EVPN VPWS network site, CE 1 is dualhomed to PE 1 and PE 2, and PE 1 is the DF. When the AC on PE 1 fails, PE 1 advertises the local unreachable event to PE 2 and remote PEs for the remote PEs to switch traffic to the PWs to PE 2. In this situation, PE 1 drops the packets that the remote PEs send before they are notified of the local unreachable event. To resolve this issue, enable local FRR on PE 1 and PE 2. When receiving packets from the remote PEs after its AC fails, PE 1 forwards the packets to PE 2 over the bypass PW to prevent traffic loss.
# Enable local FRR globally for EVPN VPWS.
[Sysname] evpn multihoming vpws-frr local
evpn redundancy-mode
Use evpn redundancy-mode to set the redundancy mode on an interface.
Use undo evpn redundancy-mode to restore the default.
evpn redundancy-mode { all-active | single-active }
The all-active redundancy mode is used.
Interface view
all-active: Specifies the all-active mode.
single-active: Specifies the single-active mode.
This command is supported only by a multihomed EVPN VPWS network.
The redundant PEs at a dualhomed site each establish an EVPN PW to a remote PE. To use one PW as a backup of the other PW, use the single-active mode. To distribute traffic across the PWs for load sharing, use the all-active mode.
As a best practice, set the same redundancy mode on the interfaces that act as ACs or are configured with ACs on the redundant PEs at a multihomed site.
Make sure the interface where you execute this command is assigned an ESI.
# Set the redundancy mode to single-active on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] evpn redundancy-mode single-active
esi
evpn timer ad-delay
Use evpn timer ad-delay to set the advertisement delay timer for Ethernet auto-discovery routes.
Use undo evpn timer ad-delay to delete the advertisement delay setting for Ethernet auto-discovery routes.
evpn timer ad-delay delay-time
Advertisement of Ethernet auto-discovery routes is not delayed.
Interface view
delay-time: Specifies a delay value in the range of 3 to 1200 seconds.
The advertisement delay timer for Ethernet auto-discovery routes helps reduce the traffic loss caused by a PE reboot at a multihomed EVPN VPLS network site.
At a multihomed EVPN VPLS network site, CE 1 is dualhomed to PE 1 and PE 2 through an aggregate link or smart trunk, and PE 3 is at a remote site. PE 1 forwards all traffic sent from CE 1 to the remote site, and PE 3 forwards the traffic that the remote site sends to CE 1 to both PE 1 and PE 2. When PE 1 reboots, it advertises Ethernet auto-discovery routes that carry next hop information to PE 3. If PE 3 has not received the MAC/IP advertisement routes advertised by PE 2 when receiving the Ethernet auto-discovery routes, it will forward traffic to both PE 1 and PE 2. In this situation, PE 1 does not have MAC address entries for CE 1 and drops the traffic.
To resolve this issue, set the advertisement delay timer for Ethernet auto-discovery routes on the CE-facing interface of PE 1. This timer allows PE 3 to receive the MAC/IP advertisement routes advertised by PE 2 before the Ethernet auto-discovery routes advertised by PE 1 and update its MAC address table timely.
# On HundredGigE 1/0/1, set the advertisement delay timer for Ethernet auto-discovery routes to 300 seconds.
[Sysname-HundredGigE1/0/1] evpn timer ad-delay 300
evpn track peer
Use evpn track peer to enable the device to monitor the BGP peer status of another local edge device.
Use undo evpn track peer to restore the default.
evpn track peer peer-address
At a multihomed site, the device does not monitor the BGP peer status of the other edge devices.
Interface view
peer-address: Specifies a PE by its IPv4 address.
Use this command on the CE-facing interfaces of the edge devices multihomed to a site to prevent device reboots from causing inter-site forwarding failure.
This command excludes unavailable edge devices from DF election at a multihomed site. After an edge device recovers from failure and brings up its CE-facing interface, it starts a delay timer and checks the status of the BGP peer specified in this command. If the BGP peer comes up before the timer expires, the edge device advertises Ethernet segment routes to the peer. If the BGP peer is still down when the timer expires, the edge device does not advertise Ethernet segment routes to the peer. The edge devices then perform DF election based on the Ethernet segment routes they have received.
# On HundredGigE 1/0/1, enable the device to monitor the BGP peer at 1.1.1.1.
[Sysname-GigabitEthernet1/0/1] evpn tack peer 1.1.1.1
evpn track bfd
Use evpn track bfd to enable the device to monitor the status of a static BFD session on an AC-side interface for fast DF/BDF switchover.
Use undo evpn track bfd to restore the default.
evpn track bfd session-name
undo evpn track bfd
The device does not monitor the status of static BFD sessions.
session-name: Specifies a static BFD session name, a case-sensitive string of 1 to 15 characters.
Use this command on a BDF for fast DF/BDF switchover.
At a multihomed site of an EVPN VPWS network, a BDF cannot take over the DF role immediately when an AC on a DF fails, and traffic loss will occur as a result. To resolve this issue, set up a static BFD session between the DF and BDF. You must configure the static BFD session to monitor the status of the local AC on the DF and enable the BDF to monitor the status of the session. When the AC on the DF fails, the static BFD session goes down, and the BDF can fast take over the DF role to reduce traffic loss.
To modify the static BFD session monitored on an interface, first use the undo evpn track bfd command to remove the existing static BFD session configuration.
# Enable the device to monitor the status of static BFD session abc on HundredGigE 1/0/1 for fast DF/BDF switchover.
[Sysname-HundredGigE1/0/1] evpn tack bfd abc
bfd static (High Availability Command Reference)
Use evpn vpws-frr remote to enable remote FRR globally for EVPN VPWS.
Use undo evpn vpws-frr remote to disable remote FRR globally for EVPN VPWS and delete the existing backup PWs.
Remote FRR is disabled globally for EVPN VPWS.
If you have executed the evpn frr remote enable command on an EVPN instance, the undo evpn vpws-frr remote command does not delete the backup PWs of the EVPN instance.
# Enable remote FRR globally for EVPN VPWS.
[Sysname] evpn vpws-frr remote
evpn frr remote
export route-policy
Use export route-policy to apply an export routing policy to EVPN on a VPN instance.
Use undo export route-policy to restore the default.
No export routing policy is applied to EVPN on a VPN instance.
VPN instance EVPN view
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for EVPN.
EVPN can use an export routing policy specified in VPN instance view or in VPN instance EVPN view. Export routing policy configuration in VPN instance EVPN view takes precedence over that in VPN instance view.
# Apply export routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
route-policy (Layer 3—IP Routing Command Reference)
ignore-ac-state
Use ignore-ac-state enable to enable a VSI to ignore the state of ACs.
Use ignore-ac-state disable to disable a VSI from ignoring the state of ACs.
Use undo ignore-ac-state to restore the default.
ignore-ac-state { enable | disable }
A VSI uses the global AC state ignore configuration.
VSI view
Cross-connect view
This command helps reduce the traffic loss caused by AC failure at a multihomed EVPN VPLS or EVPN VPWS network site that uses single-active redundancy mode.
At a multihomed EVPN VPLS network site that uses single-active redundancy mode, CE 1 is dualhomed to PE 1 and PE 2 through a smart trunk. PE 1 is the primary PE, and PE 2 is the secondary PE. When the AC on PE 1 fails, PE 1 and PE 2 act as follows:
·     PE 1 withdraws advertised Ethernet auto-discovery routes.
·     PE 2 brings up its AC and advertises Ethernet auto-discovery routes to remote PEs.
The remote PEs switch traffic to the paths to PE 2 only after receiving the Ethernet auto-discovery routes advertised by PE 2, and traffic loss occurs during path switchover. To resolve this issue, enable VSIs to ignore the state of ACs on PE 2. This feature allows PE 2 to advertise Ethernet auto-discovery routes to remote PEs regardless of the state of ACs and speeds up path switchover when the AC on PE 1 fails.
On a VSI, VSI-specific AC state ignore configuration takes precedence over global AC state ignore configuration.
For A-D per ES routes, if you enable AC state ignore on a cross-connect, the feature takes effect on the cross-connect group of the cross-connect.
# Enable VSI vpna to ignore the state of ACs.
[Sysname] vsi vpna
[Sysname-vsi-vpna] ignore-ac-state enable
l2vpn ignore-ac-state
import route-policy
Use import route-policy to apply an import routing policy to EVPN on a VPN instance.
Use undo import route-policy to restore the default.
No import routing policy is applied to EVPN on a VPN instance. The VPN instance accepts a route when the route targets of the route match local import route targets.
You can specify an import routing policy to filter received routes or modify their route attributes for EVPN.
EVPN can use an import routing policy specified in VPN instance view or in VPN instance EVPN view. Import routing policy configuration in VPN instance EVPN view takes precedence over that in VPN instance view.
# Apply import routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
Use l2vpn ignore-ac-state to enable VSIs to ignore the state of ACs globally.
Use undo l2vpn ignore-ac-state to disable VSIs from ignoring the state of ACs globally.
This command is supported only in R3608 and later.
VSIs does not ignore the state of ACs.
This command helps reduce the traffic loss caused by AC failure at a multihomed EVPN VPLS network site that uses single-active redundancy mode.
# Enable VSIs to ignore the state of ACs globally.
[Sysname] l2vpn ignore-ac-state
ignore-ac-state
mac-advertising disable
Use mac-advertising disable to disable MAC address advertisement and withdraw advertised MAC addresses.
Use undo mac-advertising disable to restore the default.
MAC address advertisement is enabled.
The MAC information and ARP information advertised by the device overlap. To avoid duplication, use this command to disable MAC address advertisement and withdraw the MAC addresses advertised to remote devices.
# Disable MAC address advertisement and withdraw advertised MAC addresses for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-mpls] mac-advertising disable
Use peer advertise encap-type mpls to enable MPLS encapsulation for the IP prefix advertisement routes advertised to a peer or peer group.
Use undo peer advertise encap-type mpls to disable MPLS encapsulation for the IP prefix advertisement routes advertised to a peer or peer group.
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
undo peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
IP prefix advertisement routes use VXLAN encapsulation.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv4-address: Specifies a peer by its IPv4 address. the peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
Use this command to enable the device to advertise IP prefix advertisement routes with MPLS encapsulation over an L3VPN network.
Execute this command on the edge nodes of the EVPN L3VPN network and RRs. On the edge nodes, you must use this command together with the evpn mpls routing-enable command.
# Enable MPLS encapsulation for the IP prefix advertisement routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
policy vpn-target
Use policy vpn-target to enable route target filtering for BGP EVPN routes.
Use undo policy vpn-target to disable route target filtering for BGP EVPN routes.
policy vpn-target
Route target filtering is enabled for BGP EVPN routes.
When route target filtering is enabled for BGP EVPN routes, the EVPN routing table accepts only BGP EVPN routes whose export route targets match the local import route targets. If the device must save all BGP EVPN routes, use the undo policy vpn-target command to disable route target filtering for BGP EVPN routes.
# Disable route target filtering for BGP EVPN routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
pw-class
Use pw-class to specify a PW class for a VSI EVPN instance.
Use undo pw-class to restore the default.
pw-class class-name
undo pw-class
No PW class is specified for a VSI EVPN instance.
This command is supported only by EVPN instances that use MPLS encapsulation.
The specified PW class will be used to establish all PWs on the VSI EVPN instance.
# Specify PW class pw100 for the EVPN instance on VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-aa] evpn encapsulation mpls
[Sysname-vsi-aa-evpn-mpls] pw-class pw100
route-distinguisher
Use route-distinguisher to configure an RD for an EVPN instance.
Use undo route-distinguisher to restore the default.
In cross-connect group EVPN instance view:
In VSI EVPN instance view:
route-distinguisher { route-distinguisher | auto router-id }
No RD is configured for an EVPN instance.
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD cannot be all zeros and can use one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
auto router-id: Automatically generates an RD based on the router ID in the Router ID:N format. The initial value of N is 1. If Router ID:N is already in use, the system increases the value of N by 1 until the RD is available.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic PE discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses the RD to differentiate BGP EVPN routes of different EVPN instances.
To modify an RD, first execute the undo route-distinguisher command to remove the original RD.
# Configure 22:1 as the RD of the EVPN instance on VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation mpls
[Sysname-vsi-aaa-evpn-mpls] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
An RR does not filter reflected BGP EVPN routes.
ext-comm-list-number: Specifies an extended community attribute list by its number in the range of 1 to 199.
ext-comm-list-name: Specifies an extended community attribute list by its name, a case-sensitive string of 1 to 63 characters.
This command enables an RR to reflect only received BGP EVPN routes that match the attributes in the specified extended community attribute list.
If a cluster contains multiple RRs, you can configure different reflection policies on the RRs for load sharing among the RRs.
For more information about the extended community attribute list, see Layer 3—IP Routing Configuration Guide.
# Configure a reflection policy for the device to reflect BGP EVPN routes that match extended community attribute list 10.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
tunnel-policy
Use tunnel-policy to specify a tunnel policy for a VSI EVPN instance.
Use undo tunnel-policy to restore the default.
undo tunnel-policy
No tunnel policy is specified for a VSI EVPN instance.
The PWs of the VSI EVPN instance use the specified tunnel policy to select public tunnels.
If you do not specify a tunnel policy or specify a nonexistent tunnel policy, the default tunnel policy applies. The default tunnel policy selects only one public tunnel for a PW in this order: LSP tunnel, GRE tunnel, CRLSP tunnel, and SRLSP tunnel.
# Specify tunnel policy policy1 for the EVPN instance on VSI aa.
[Sysname] vsi aa
[Sysname-vsi-aa-evpn-mpls] tunnel-policy policy1
vpn-route cross multipath
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
# Enable ECMP VPN route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for EVPN.
Use undo vpn-target to delete route targets for EVPN.
undo vpn-target { vpn-target&<1-8> | all } [ both | export-extcommunity | import-extcommunity ]
EVPN does not have route targets.
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets. Each route target is a string of 3 to 21 characters in one of the following formats:
both: Uses the specified route targets as both import and export targets. If you do not specify the both, export-extcommunity, or import-extcommunity keyword, the both keyword applies.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Specifies all route targets.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic PE discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses route targets to control the advertisement and acceptance of BGP EVPN routes.
A PE sets the export targets for BGP EVPN routes before advertising the routes to remote PEs. The PE checks the export targets of BGP EVPN routes from remote PEs and imports only BGP EVPN routes of which the export targets match the local import targets.
If you execute this command multiple times, all configured route targets take effect.
# Configure import route targets 10:1, 100:1, and 1000:1 for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-mpls] vpn-target 10:1 100:1 1000:1 import-extcommunity
