10-High Availability Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R36xx)-6W10110-High Availability Command Reference
13-S-Trunk commands
13-S-Trunk commands 128.07 KB
S-Trunk commands
description
Use description to configure a description for a smart trunk.
description text-string
A smart trunk does not have any description.
Smart trunk view
# Configure a description for smart trunk 10.
[Sysname] s-trunk id 10
[Sysname-s-trunk10] description strunk10
display s-trunk brief
Use display s-trunk brief to display brief smart trunk information.
# Display brief smart trunk information.
<Sysname> display s-trunk brief
Total: 1       Primary: 1       Secondary: 0       Init: 0
UDP port: 1025
Trunk ID      DevRole      DestIP          SrcIP
1             Primary      1.1.1.1         2.2.2.2
Total
Total number of smart trunks.
Primary
Number of the smart trunks in which the local device is assigned the Primary role.
Secondary
Number of the smart trunks in which the local device is assigned the Secondary role.
Init
Number of the smart trunks in which the local device is assigned the Init role.
UDP port
Destination UDP port number of S-Trunk protocol packets.
DevRole
Role of the device in a smart trunk:
·     Init.
·     Primary.
·     Secondary.
DestIP
Destination IP address of S-Trunk protocol packets.
SrcIP
Source IP address of S-Trunk protocol packets.
display s-trunk member role-change
Use display s-trunk member role-change to display the ten most recent role change records for a smart trunk member interface.
display s-trunk member role-change interface interface-type interface-number
interface interface-type interface-number: Specifies a member interface of a smart trunk by the interface type and interface number.
# Display the ten most recent role change records for Bridge-Aggregation 1.
<Sysname> display s-trunk member role-change interface bridge-aggregation 10
Time                   LastRole    CurrentRole    Trigger
2018-09-23 10:41:30    Secondary   Primary        PEER_MEMBER_DOWN
2018-09-23 10:30:29    Primary     Secondary      MANUAL_SECONDARY
# Display the ten most recent role change records for Route-Aggregation 1.
<Sysname> display s-trunk member role-change interface route-aggregation 10
Time
Time when the role change occurred.
LastRole
Role before the change:
·     Primary.
·     Secondary.
CurrentRole
Role after the change:
·     Primary.
·     Secondary.
Trigger
Reason for the role change:
·     MANUAL_SECONDARY—The member interface role was set to Secondary.
·     MANUAL_PRIMARY—The member interface role was set to Primary.
·     STRUNK_INIT—The member interface role was set to Auto, but the S-Trunk system was initializing.
·     AUTO_SECONDARY—The member interface role was set to Auto, and the actual role of the interface was automatically set to Secondary based on the device role.
·     AUTO_PRIMARY—The member interface role was set to Auto, and the actual role of the interface was automatically set to Primary based on the device role.
·     PEER_MEMBER_DOWN—The local device received a packet that reported the down state of the peer member interface.
·     PEER_MEMBER_UP—The local device received a packet that reported the up state of the peer member interface.
display s-trunk packet-statistics
Use display s-trunk packet-statistics to display packet statistics about smart trunks.
display s-trunk packet-statistics [ s-trunk-id ]
s-trunk-id: Specifies a smart trunk ID in the range of 1 to 128. The smart trunk ID must already exist. If you do not specify a smart trunk ID, this command displays packet statistics about all smart trunks.
# Display packet statistics about all smart trunks.
<Sysname> display s-trunk packet-statistics
Global statistics:
 Received packets                                  : 0
 Dropped received packets                          : 0
 Sent packets                                      : 0
 Dropped sent packets                              : 0
 Received packets with invalid packet type         : 0
 Received packets with invalid packet length       : 0
 Received packets with invalid bridge MAC address  : 0
 Received packets with invalid timeout             : 0
 Received packets with invalid interval            : 0
 Received packets with invalid smart trunk ID      : 0
 Received packets of nonexistent smart trunk       : 0
Trunk ID: 1
 Sent packets                                      : 0
 Received packets without IPs or VPN instance      : 0
 Received packets with incorrect IPs               : 0
 Received packets with incorrect VPN instance      : 0
 Received packets with incorrect packet type       : 0
 Received packets with incorrect sequence number   : 0
 Received packets that failed authentication       : 0
Number of the received S-Trunk protocol packets with an invalid S-Trunk protocol packet timeout.
Number of the received S-Trunk protocol packets with an invalid S-Trunk protocol packet transmission interval.
Number of the received S-Trunk protocol packets that do not contain IP addresses or VPN instance name.
Number of the received S-Trunk protocol packets whose IP addresses do not match the IP addresses of S-Trunk protocol packets configured on the local device.
Number of the received S-Trunk protocol packets whose VPN instance does not match the VPN instance configured on the local device.
Number of the received S-Trunk protocol packets with a sequence number same as a previously received packet.
reset s-trunk packet-statistics
displays-trunk verbose
Use display s-trunk verbose to display detailed information about a smart trunk.
display s-trunk verbose s-trunk-id
# Display detailed information about smart trunk 1.
<Sysname> display s-trunk verbose 1
                            Trunk-wide info and statistics
S-Trunk ID: 1
Revert: Enabled                       Revert-delay(s): 120
Local bridge MAC: 0af9-271a-a800      Peer bridge MAC: 0a02-4ccc-4400
Local priority: 100                   Peer priority: 150
DevRole (Trigger): Primary (PRIORITY)
DestIP: 2.2.2.2                       SrcIP: 1.1.1.1
Local hello interval(100ms): 10       Local hello timeout(100ms): 200
InStrunkPDUs: 2605                    OutStrunkPDUs: 2869
InDrops: 0                            OutDrops: 0
Peer hello interval(100ms): 10        Peer hello timeout(100ms): 200
Sequence number check: Enabled
BFD session: -
VPN instance: vpn1
Description: -
                            Trunk member info
Local    LinkState   ConfigRole    OperRole (Trigger)            Peer
BAGG1    Up          Auto          Primary (AUTO_PRIMARY)        BAGG1
Revert
Whether the smart trunk can be reverted to the primary interface on its recovery:
·     Disabled.
·     Enabled.
Revert-delay(s)
Reversion delay in seconds.
Local bridge MAC
Bridge MAC address of the local device in the smart trunk.
Peer bridge MAC
Bridge MAC address of the peer device in the smart trunk.
Local priority
Priority of the local device.
Peer priority
Priority of the peer device.
DevRole (Trigger)
Role of the local device:
·     Init.
·     Primary.
·     Secondary.
·     INIT—The S-Trunk system was initializing.
·     PRIORITY—The device role was determined based on the role priority.
·     TIMEOUT—The local device did not receive any protocol packets before the S-Trunk protocol packet timeout expired.
·     BFD_DOWN—BFD detected that the link to the peer device was down.
·     PEER-TIMEOUT—The local device received a packet that reported expiration of the peer S-Trunk protocol packet timeout.
·     PEER_BFD_DOWN—The local device received a message about the link down event detected by BFD on the peer device.
DestIP
SrcIP
Local S-Trunk protocol packet transmission interval, in 100 milliseconds.
Local S-Trunk protocol packet timeout, in 100 milliseconds.
InStrunkPDUs/OutStrunkPDUs
Number of S-Trunk protocol packets sent/received by the interface.
InDrops/OutDrops
Number of dropped incoming and outgoing S-Trunk protocol packets on the interface.
Peer S-Trunk protocol packet transmission interval, in 100 milliseconds.
Peer S-Trunk protocol packet timeout, in 100 milliseconds.
Whether sequence number check is enabled for the smart trunk:
·     Disabled.
·     Enabled.
BFD session
Name of the BFD session associated with the smart trunk. If no BFD session association is configured, the system displays a hyphen (-).
VPN instance
Name of the VPN instance to which S-Trunk protocol packets belong.
Description of the smart trunk.
Local
Abbreviated name of the local smart trunk member interface.
LinkState
Link state of the local smart trunk member interface:
·     Up—The interface is up if it is the primary member interface.
·     Down—The interface is down if it is the secondary member interface.
ConfigRole
Role of the interface in the smart trunk:
·     Auto—The role of the interface is automatically assigned.
·     Secondary—The role of the interface is fixed at secondary.
·     Primary—The role of the interface is fixed at primary.
OperRole (Trigger)
Actual role of the member interface:
·     Primary.
·     Secondary.
Reason for the role change of the member interface:
Peer
Abbreviated name of the peer smart trunk member interface.
lacp system-mac
Use lacp system-mac to configure the LACP system MAC address.
Use undo lacp system-mac to restore the default.
lacp system-mac mac-address
The LACP system MAC address is not configured.
mac-address: Specifies a MAC address in the H-H-H format. The MAC address cannot be a multicast MAC address, all-zero MAC address, or all-F MAC address.
CAUTION
CAUTION:
Changing the LACP system MAC address might cause interface flapping or incorrect operation of smart trunks. As a best practice, perform this task before configuring smart trunks.
This command takes effect on an aggregate interface after it is assigned to a smart trunk.
The LACP system MAC address uniquely identifies an S-Trunk system on the network. For the S-Trunk member devices to be identified as one device, you must configure the same LACP system MAC address on them. As a best practice to avoid MAC address collision, use the bridge MAC address of one S-Trunk member device as the LACP system MAC address.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
lacp system-number
Use lacp system-number to configure the LACP system number.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not configured.
number: Specifies an LACP system number in the range of 1 to 3.
You must assign different LACP system numbers to the member devices in an S-Trunk system. The devices will generate different interface indexes for the smart trunk member interfaces with the same interface number.
The LACP system number configured by using this command takes effect only on aggregate interfaces in smart trunks. Aggregate interfaces not in smart trunks do not use the configured LACP system number in LACPDUs. To view the LACP system number in LACPDUs, examine the Index field in the output from the display link-aggregation verbose command.
You can use the display link-aggregation verbose command to view the Index field of an LACP packet.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
display link-aggregation verbose (Layer 2—LAN Switching Command Reference)
Use reset s-trunk packet-statistics to clear packet statistics about smart trunks.
reset s-trunk packet-statistics [ s-trunk-id ]
s-trunk-id: Specifies a smart trunk ID in the range of 1 to 128. The smart trunk ID must already exist. If you do not specify a smart trunk ID, the system clears the packet statistics about all smart trunks.
# Clear packet statistics about smart trunk 10.
<Sysname> reset s-trunk packet-statistics 10
s-trunk
Use s-trunk to assign an interface to a smart trunk.
Use undo s-trunk to restore the default.
s-trunk s-trunk-id [ peer peer-interface-number ]
undo s-trunk
An interface is not assigned to any smart trunks.
peer peer-interface-number: Specifies a peer aggregate interface number in the range of 1 to 65535. If you do not specify a peer aggregate interface number, the peer aggregate interface has the same number as the local aggregate interface.
An interface can be assigned to only one smart trunk.
You must configure the same ID for the same smart trunk on the member devices in an S-Trunk system.
The member interfaces in a smart trunk can have the same or different interface numbers. When you use this command to assign interfaces with different interface numbers to a smart trunk, you must specify the peer aggregate interface number.
Make sure the aggregate interfaces in a smart trunk meet the following requirements:
·     They have the same aggregation mode and aggregate interface type.
·     Their aggregation member ports have the same operational key and attribute configurations.
# Assign Bridge-Aggregation 1 to smart trunk 10.
[Sysname-Bridge-Aggregation1] s-trunk 10
# Assign Route-Aggregation 1 to smart trunk 10.
[Sysname-Route-Aggregation1] s-trunk 10
link-aggregation mode dynamic
s-trunk authentication key
Use s-trunk authentication key to enable S-Trunk protocol packet authentication and configure an authentication key.
Use undo s-trunk authentication key to disable S-Trunk protocol packet authentication.
s-trunk authentication key { cipher | simple } string
S-Trunk protocol packet authentication is disabled.
Smart trunk view
cipher: Specifies a ciphertext key.
simple: Specifies a plaintext key. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies a case-sensitive key string. A plaintext key is a string of 1 to 32 characters, and a ciphertext key is a string of 1 to 73 characters.
To prevent S-Trunk system setup failure caused by tampered packets, enable S-Trunk protocol packet authentication on the PEs in an S-Trunk system. The PEs will calculate the message digest based on the authentication key and S-Trunk protocol packets to verify validity of the S-Trunk protocol packets.
To avoid authentication failure, you must configure the same authentication key for a smart trunk on the S-Trunk member devices.
# Enable S-Trunk protocol packet authentication and configure the authentication key as abcdefg for smart trunk 10.
[Sysname-s-trunk10] s-trunk authentication key simple abcdefg
s-trunk bfd-session
Use s-trunk bfd-session to associate a smart trunk with a BFD session.
Use undo s-trunk bfd-session to restore the default.
s-trunk bfd-session bfd-session-name
No BFD session is associated with a smart trunk.
Smart trunk view
bfd-session-name: Specifies a BFD session name, a case-sensitive string of 1 to 15 characters.
Associate a BFD session with a smart trunk for fast primary device failure detection and failover. If the BFD session is disconnected, the S-Trunk system splits and both member devices become primary devices. For more information about BFD, see High Availability Configuration Guide.
A smart trunk can be associated only with one static BFD session. To ensure correct collaboration between S-Trunk and BFD, do not specify an interface for the BFD session when you create it.
To modify the BFD session association for a smart trunk, you must first remove the existing BFD session association.
# Associate BFD session bfd1 with smart trunk 10.
[Sysname-s-trunk10] s-trunk bfd-session bfd1
s-trunk id
Use s-trunk id to create a smart trunk and enter its view or enter the view of an existing smart trunk.
Use undo s-trunk id to delete a smart trunk.
s-trunk id s-trunk-id
undo s-trunk id s-trunk-id
No smart trunk exists.
# Create smart trunk 10 and enter its view.
[Sysname-s-trunk10]
s-trunk interval
Use s-trunk interval to set the S-Trunk protocol packet transmission interval.
Use undo s-trunk interval to restore the default.
s-trunk interval interval
The S-Trunk protocol packet transmission interval is 1000 milliseconds.
Smart trunk view
interval: Specifies a value in the range of 5 to 100, in units of 100 milliseconds.
For successful S-Trunk system setup, make sure the S-Trunk member devices have the same S-Trunk protocol packet transmission interval.
# Set the S-Trunk protocol packet transmission interval to 2000 milliseconds.
[Sysname-s-trunk10] s-trunk interval 20
s-trunk timeout multiplier
s-trunk ip
Use s-trunk ip to configure S-Trunk protocol packet parameters.
Use undo s-trunk ip to restore the default.
s-trunk ip destination des-ipv4-address source source-ipv4-address [ vpn-instance vpn-instance-name ]
undo s-trunk ip
No S-Trunk protocol packet parameters are configured.
Smart trunk view
destination des-ipv4-address: Specifies an IP address on the peer device as the destination IP address of S-Trunk protocol packets.
source source-ipv4-address: Specifies an IP address on the local device as the source IP address of S-Trunk protocol packets.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the S-Trunk protocol packets belong to the public network, do not specify a VPN instance.
For two S-Trunk member devices to exchange S-Trunk protocol packets, you must use this command to specify the source and destination IP addresses and VPN instance of S-Trunk protocol packets on the devices.
# Specify the destination and source IP addresses of S-Trunk protocol packets as 192.168.68.125 and 192.168.68.100, respectively.
[Sysname-s-trunk10] s-trunk ip destination 192.168.68.125 source 192.168.68.100
s-trunk port-role
Use s-trunk port-role to configure the role of an aggregate interface in a smart trunk.
Use undo s-trunk port-role to restore the default.
s-trunk port-role { auto | primary | secondary }
The role of a smart trunk member interface is auto.
auto: Automatically sets the interface role.
secondary: Fixes the role of the interface at secondary.
primary: Fixes the role of the interface at primary.
For successful configuration, execute this command on an aggregate interface that has been assigned to a smart trunk.
For a member interface with the Auto role in a smart trunk, its actual role is set based on the S-Trunk role of the local device and state of the peer member interface.
·     If the local device is the primary device, the local member interface is assigned the primary role.
·     If the local device is the secondary device, the following rules apply:
¡     If the peer member interface is down, the local member interface is assigned the primary role.
¡     If the peer member interface is up, the local member interface is assigned the secondary role.
A member interface whose role is fixed at primary in a smart trunk retains the role even when it is down.
A member interface whose role is fixed at secondary in a smart trunk retains the role even when the peer member interface is down.
# Assign the primary role to Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] s-trunk port-role primary
# Assign the primary role to Route-Aggregation 1.
[Sysname-Route-Aggregation1] s-trunk port-role primary
s-trunk revert disable
Use s-trunk revert disable to disable reversion to the primary interface for a smart trunk.
Use undo s-trunk revert-delay disable to enable reversion to the primary interface for a smart trunk.
undo s-trunk revert disable
Reversion to the primary interface is enabled for a smart trunk.
Smart trunk view
Traffic loss might occur when a smart trunk reverts to the original primary interface on its recovery. To avoid traffic loss, you can disable reversion to the primary interface.
# Disable reversion to the primary interface for smart trunk 10.
[Sysname-s-trunk10] s-trunk revert disable
Use s-trunk revert-delay to set the reversion delay for a smart trunk.
Use undo s-trunk revert-delay to restore the default.
s-trunk revert-delay delay-value
The reversion delay is 120 seconds.
Smart trunk view
delay-value: Specifies a delay value in the range of 0 to 3600 seconds.
When the primary device recovers from failure in an S-Trunk system configured with MPLS L2VPN, its smart trunk member interface recovers earlier than a PW. In this situation, immediate reversion to the primary interface causes service interruption. To avoid traffic loss and frequent reversions, set the reversion delay.
# Set the reversion delay to 30 seconds.
[Sysname-s-trunk10] s-trunk revert-delay 30
s-trunk role priority
Use s-trunk role priority to set the role priority of the device in a smart trunk.
Use undo s-trunk role priority to restore the default.
s-trunk role priority priority
The role priority of the device in a smart trunk is 32768.
Smart trunk view
priority: Specifies a role priority in the range of 0 to 65535. The smaller the value, the higher the priority.
An S-Trunk member device is assigned the primary or secondary role based on its role priority. If the S-Trunk member devices use the same role priority, the device with a lower bridge MAC address is assigned the primary role.
As a best practice to avoid network flapping, do not modify the role priority of the S-Trunk member devices after the S-Trunk system is established.
# Set the role priority of the device to 1024 in smart trunk 10.
[Sysname-s-trunk10] s-trunk role priority 1024
s-trunk sequence enable
Use s-trunk sequence enable to enable sequence number check for a smart trunk.
Use undo s-trunk sequence enable to disable sequence number check for a smart trunk.
Sequence number check is disabled for a smart trunk.
Smart trunk view
When an S-Trunk member device is rebooted, the sequence numbers in the S-Trunk protocol packets sent and received by it are cleared. In this condition, if the other S-Trunk member device is operating correctly, the S-Trunk system might split for sequence number check failure. For the S-Trunk system to reunite, disable sequence number check and then re-enable it on the device that does not reboot.
When BFD detects a link failure or the S-Trunk protocol packet timeout expires on an S-Trunk member device, the sequence numbers in the S-Trunk protocol packets received by the device are cleared. In this condition, if the other S-Trunk member device is operating correctly, the S-Trunk system can provide services correctly.
After one S-Trunk member device reboots, the other S-Trunk member device might receive and accept the packets that are intercepted by an attacker before the reboot. As a best practice, change the  authentication key after an S-Trunk member device reboots.
# Enable sequence number check for smart trunk 10.
[Sysname-s-trunk10] s-trunk sequence enable
Use s-trunk timeout multiplier to set the multiplier for calculating the S-Trunk protocol packet timeout.
Use undo s-trunk timeout multiplier to restore the default.
s-trunk timeout multiplier multiplier
The multiplier for calculating the S-Trunk protocol packet timeout is 20.
Smart trunk view
multiplier: Specifies a multiplier in the range of 3 to 300.
The local device determines that the peer member interface of a smart trunk is down if it does not receive any S-Trunk protocol packets of the smart trunk within the S-Trunk protocol packet timeout. If the local smart trunk member interface is the secondary interface, it takes over the primary role when the S-Trunk protocol packet timeout expires.
An S-Trunk member device uses the S-Trunk protocol packet timeout in the S-Trunk protocol packets sent by the peer S-Trunk member device. The S-Trunk protocol packet timeout equals the S-Trunk protocol packet transmission interval multiplied by the multiplier set by using this command.
To avoid S-Trunk protocol flapping, make sure the S-Trunk protocol packet timeout is longer than the number of smart trunks multiplied by 200 milliseconds.
# Set the multiplier for calculating the S-Trunk protocol packet timeout to 10.
[Sysname-s-trunk10] s-trunk timeout multiplier 10
s-trunk interval
s-trunk udp-port
Use s-trunk udp-port to set the destination UDP port of S-Trunk protocol packets.
Use undo s-trunk udp-port to restore the default.
s-trunk udp-port port-number
The destination UDP port number of S-Trunk protocol packets is 1025.
port-number: Specifies a UDP port number in the range of 1024 to 65535.
S-Trunk member devices transmit S-Trunk protocol packets through UDP. If the destination UDP port of S-Trunk protocol packets conflicts with other protocols, use this command to modify the destination UDP port.
You can use the display udp command to view available UDP ports.
You must configure the same destination UDP port number for S-Trunk protocol packets on the S-Trunk member devices.
# Set the destination UDP port of S-Trunk protocol packets to 2048.
[Sysname] s-trunk udp-port 2048
display udp (Layer 3—IP Services Command Reference)
