| 01-Text | 657.33 KB |
Mounting the AP on a junction box
Connecting a local power source
Connecting the AP to the network
3 Appendix A Technical specifications
1 Preparing for installation
Safety recommendations
WARNING! Only professional technical personnel can install and remove the AP and its accessories. You must read all safety instructions carefully before working with the AP. |
To avoid possible bodily injury and equipment damage, read the following safety recommendations before installing the AP. Note that the recommendations do not cover every possible hazardous condition.
· To avoid bodily injury and device damage, take adequate safety measures.
· Place the AP in a dry and flat location and take anti-slip measures.
· Keep the AP clean and dust-free.
· Do not place the AP in a moist area and avoid liquid intrusion.
· Keep the AP and installation tools away from walkways.
Site preparation
Before installing the AP, examine the installation site and ensure that the AP will operate in a favorable environment. Make sure the temperature and humidity at the installation site meet the requirements in Table1-1.
Table1-1 Temperature and humidity requirements
Item |
Specification |
Operating temperature |
0°C to 40°C (32°F to 104°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Installation accessories
Figure1-1 Accessories provided with the AP
Installation tools
When installing the AP, you might need the following tools. Prepare the installation tools yourself as required.
Figure1-2 Installation tools
2 Installing the AP
Installation flowchart
Figure2-1 Installation flowchart
Pre-installation tasks
Before installing the AP, perform the following tasks:
· Power on the AP and connect the AP to the network. Examine the LEDs to verify that the AP is operating correctly. For information about the LEDs, see "LEDs."
· Record the MAC address and serial number of the AP for future use.
1. As shown in Figure2-2, use M4 screws to attach the mounting bracket to a junction box.
Figure2-2 Attaching the mounting bracket to a junction box
2. As shown in Figure2-3, connect cables to the pass-through port and uplink/PoE in port on the rear of the AP.
The pass-through ports on the rear and bottom of the AP are standard RJ-45 ports. You can connect phone cables or Ethernet cables to the pass-through ports as needed.
3. Secure the AP to the mounting bracket, as shown in Figure2-4.
a. Align the mounting peg on the mounting bracket with the installation slot in the rear of the AP and insert the peg into the slot.
b. Slide down the AP so that it sits securely on the peg.
c. Fasten the M3 × 4 screw on the side panel of the AP.
Figure2-4 Securing the AP to the mounting bracket
Mounting the AP on a wall
1. Place the mounting bracket against the wall and mark the installation holes on the wall.
Figure2-5 Marking the installation holes on the wall
2. Drill three holes with a diameter of 6 mm (0.24 in) and a depth of 30 mm (1.18 in) at the marked locations, as shown in Figure2-6.
Figure2-6 Drilling holes in the wall
3. Use a rubber hammer to tap a screw anchor into each hole until it is all flush with the wall surface, as shown in Figure2-7.
Figure2-7 Hammering the screw anchor into the wall
4. Insert the screws through the installation holes in the mounting bracket into the holes in the wall. Fasten the screws to secure the mounting bracket to the wall, as shown in Figure2-8.
Figure2-8 Securing the mounting bracket to the wall
5. As shown in Figure2-9, connect cables to the pass-through port and uplink/PoE in port on the rear of the AP.
6. Attach the AP to the mounting bracket. The procedure is the same as wall mounting and junction box mounting. For more information, see "Mounting the AP on a junction box."
Powering the AP
You can supply power to the AP by using a local power source or through 802.3af/802.at PoE as required. Before powering the AP, make sure the local power source or the power sourcing equipment (PSE) is reliably grounded.
Connecting a PoE power source
To power the AP through PoE, use an Ethernet cable to connect an Ethernet port on a PoE switch to the uplink/PoE in port on the AP.
Figure2-10 Powering the AP through PoE
You can use an AC/DC power adapter to connect the AP to a local power source. No power adapter is provided with the AP. Prepare one yourself as required. Table2-1 describes the power adapter specifications.
Table2-1 Power adapter specifications
Item |
Specification |
Input |
100 VAC to 240 VAC |
Output |
Figure2-11 Using a power adapter to connect the AP to a local power source
Check after power-on
Examine the LEDs on the AP after you power on it to verify that the AP is operating correctly. For more information about the LEDs, see "LEDs."
All AP settings are configured on the AC. To verify network connectivity of the AP, execute the display wlan ap all command on the AC. If the AP status is R/M, the AP has been connected to the network.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 128
Remaining AP licenses: 127
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run M = Master, B = Backup
AP name AP ID State Model Serial ID
ap1 1 R/M WA6320H 219801A2978199E00001
Table3-1 Technical specifications
Item |
Specification |
Dimensions (H × W × D) |
30 × 160 × 86 mm (1.18 × 6.30 × 3.39 in) |
Weight |
0.25 kg (0.55 lb) |
Antenna |
Internal antennas |
· ≤ 12.95 W without a USB device attached · ≤ 15.45 W without a USB device attached |
IEEE standards |
IEEE802.11a/b/g/n/ac/ax |
4 Appendix B Ports and LEDs
Ports
The AP provides the following ports:
· One console port
· Four 10/100/1000M Ethernet copper ports
· One power port
· Two pass-through ports
· One uplink/PoE in port
· One USB port
It provides also a reset button (RST) and a security screw hole.
Figure4-1 Ports on the AP
(1) 10/100/1000M Ethernet copper ports |
(2) Pass-through port |
(1) Power port |
(2) Security screw hole |
(1) Reset button (RST) |
(2) Console port |
(3) USB port |
(1) Pass-through port |
(2) Uplink/PoE in port |
Table4-1 Port descriptions
Port |
Standards and protocols |
Console port |
RS/EIA-232 |
Used by technical personnel only for device configuration and management. |
10/100/1000M Ethernet copper port (1 to 4) |
· IEEE802.3 · IEEE802.3u |
Represented by interface number GE1/0/2 to GE1/0/5 in the MAP file and GigabitEthernet 2 to GigabitEthernet 5 on the AC. |
Uplink/PoE in port (10/100/1000M Ethernet copper port) |
· IEEE802.3 · IEEE802.3u · IEEE802.3af · IEEE802.3at |
Used for connecting the AP to an uplink device for Internet or MAN access. It can also receive PoE power from the uplink device. It is represented by interface number GE1/0/1 in the MAP file and GigabitEthernet 1 on the AC. |
Power port (54 V) |
N/A |
Used for receiving +54 VDC power from a local power source. |
Pass-through port (2 in total) |
Use for connecting a phone cable or RJ-45 cable. |
USB port |
USB 2.0 |
Used for charging as well as data reading or writing. |
Reset button |
N/A |
· To reset the AP, press and hold the button for no more than 5 seconds. · To restore the factory default, press and hold the button for more than 5 seconds. |
LEDs
Figure4-2 LEDs on the AP
(1) Power status LED |
(2) Radio status LED |
(3) Uplink port status LED |
(4) Ethernet port status LEDs |
LED |
Status |
Power status LED |
Off |
No power is present or the LED has been disabled. |
Steady yellow |
The device is initializing or an initialization exception has occurred. |
Flashing yellow at 1 Hz |
No radio cards have been detected. |
Flashing yellow at 2 Hz |
The Ethernet interfaces are down and no mesh links are established. |
Steady green |
The AP has started up and registered to an AC, and is in standby state. |
Flashing green at 0.5 Hz |
The AP has started up but has not registered to any AC. |
Flashing green at 2 Hz |
The AP is upgrading the image. |
Radio status LED |
Off |
The radios do not have associated clients, or the LED has been turned off from the CLI. |
Flashing green at 1 Hz |
Only the 2.4G radio has associated clients. |
Only the 5G radio has associated clients. |
Alternating between green and blue at 1 Hz |
Both the 2.4G and 5G radios have associated clients. |
Off |
No power is present. |
Steady yellow |
The port has been auto-negotiated to operate at 10/100 Mbps. |
Flashing yellow |
The port is sending or receiving data at 10/100 Mbps. |
Steady green |
The port has been auto-negotiated to operate at 1000 Mbps. |
Flashing green |
The port is sending or receiving data at 1000 Mbps. |
Ethernet port status LED |
Off |
No link is present on the port. |
Steady yellow |
Flashing yellow |
Steady green |
Flashing green |
