H3C S3100V3-EI Switch Series Harware Information and Specifications-6W107
HomeSupportSwitchesS3100V3-EI SeriesProduct LiteratureHardware Information & SpecificationsH3C S3100V3-EI Switch Series Harware Information and Specifications-6W107
01-Harware Information and Specifications
01-Harware Information and Specifications 1.19 MB
1 Product models and technical specifications
Product models
This document is applicable to the S3100V3-EI switch series. Table1-1 describes the S3100V3-EI switch series models.
Table1-1 S3100V3-EI switch series models
Switch model
Product code (PID)
S3100V3-10TP-EI
LS-3100V3-10TP-EI
LS-3100V3-10TP-EI-GL
LS-3100V3-10TP-EI-H1
S3100V3-18TP-EI
LS-3100V3-18TP-EI
LS-3100V3-18TP-EI-GL
LS-3100V3-18TP-EI-H1
S3100V3-18TP-EI-DC
LS-S3100V3-18TP-EI-DC
S3100V3-28TP-EI
LS-3100V3-28TP-EI
LS-3100V3-28TP-EI-GL
LS-3100V3-28TP-EI-H1
LS-3100V3-28TP-EI-T
S3100V3-28TP-EI-DC
LS-S3100V3-28TP-EI-DC
S3100V3-52TP-EI
LS-3100V3-52TP-EI
LS-3100V3-52TP-EI-GL
LS-3100V3-52TP-EI-H1
S3100V3-10TP-PWR-EI
LS-3100V3-10TP-PWR-EI
LS-3100V3-10TP-PWR-EI-GL
LS-3100V3-10TP-PWR-EI-H1
S3100V3-20TP-PWR-EI
LS-3100V3-20TP-PWR-EI
LS-3100V3-20TP-PWR-EI-GL
LS-3100V3-20TP-PWR-EI-H1
S3100V3-20TP-PWR-EI-DC
LS-S3100V3-20TP-PWR-EI-DC
S3100V3-28TP-PWR-EI
LS-3100V3-28TP-PWR-EI
LS-3100V3-28TP-PWR-EI-GL
S3100V3-28TP-PWR-EI-AC
LS-3100V3-28TP-PWR-EI-AC
Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel.
Technical specifications
Non-PoE switch models
Table1-2 Technical specifications for non-PoE switch models (1)
Item
S3100V3-10TP-EI
S3100V3-18TP-EI
S3100V3-18TP-EI-DC
Dimensions (H × W × D)
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 1.5 kg (3.31 lb)
≤ 1.5 kg (3.31 lb)
Console port
1 × serial console port
10/100BASE-T autosensing Ethernet port
4
8
8
10/100/1000BASE-T autosensing Ethernet port
4
8
8
SFP port
2
2
2
Input voltage
·     AC input (not supported by the S3100V3-18TP-EI-DC switch)
¡     Rated voltage: 100 VAC to 240 VAC @ 50 or 60 Hz
¡     Max voltage: 90 VAC to 264 VAC @ 47 to 63 Hz
·     DC input from a 48 VDC power source in the equipment room or an H3C RPS1600-A (supported only by the S3100V3-18TP-EI-DC switch)
¡     Rated voltage: –48 VDC to 60 VDC
¡     Max voltage: –36 VDC to 72 VDC
Minimum power consumption
Models with product code LS-3100V3-10TP-EI: 6.5 W
Models with product code S3100V3-10TP-EI-H1: 8 W
7 W
19 W
Maximum power consumption
Models with product code LS-3100V3-10TP-EI: 11 W
Models with product code S3100V3-10TP-EI-H1: 14 W
15 W
25 W
Chassis leakage current compliance
UL 62368-1/EN 62368-1/IEC 62368-1/UL 60950-1/EN 60950-1/IEC 60950-1/GB4943.1
Melting current of power module fuse
2 A/250 V
2 A/250 V
3.15 A/250 V
Cooling system
Natural cooling without fan trays
Operating temperature
–5°C to +45°C (23°F to 113°F)
Operating humidity
5% to 95%, noncondensing
Fire resistance compliance
Table1-3 Technical specifications for non-PoE switch models (2)
Item
S3100V3-28TP-EI
S3100V3-28TP-EI-DC
S3100V3-52TP-EI
43.6 × 440 × 160 mm (1.72 × 17.32 × 6.30 in)
43.6 × 440 × 230 mm (1.72 × 17.32 × 9.06 in)
Weight
2.5 kg (5.51 lb)
2.5 kg (5.51 lb)
3.5 kg (7.72 lb)
Console port
16
16
32
8
8
16
SFP port
4
4
4
Input voltage
·     AC input (not supported by the S3100V3-28TP-EI-DC switch)
·     Rated voltage: 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage: 90 VAC to 264 VAC @ 47 to 63 Hz
·     DC input from a 48 VDC power source in the equipment room or an H3C RPS1600-A (supported only by the S3100V3-28TP-EI-DC switch)
9 W
20 W
18 W
19 W
27 W
33 W
2 A/250 V
3.15 A/125 V
3.15 A/250 V
Cooling system
Using fixed fan trays to draw ambient air in from the left side and right side and exhaust heated air from the power module side
Operating humidity
PoE switch models
Table1-4 Technical specifications for PoE switch models
Item
S3100V3-10TP-PWR-EI
S3100V3-20TP-PWR-EI
S3100V3-28TP-PWR-EI
43.6 × 330 × 230 mm (1.72 × 12.99 × 9.06 in)
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
Weight
≤ 3 kg (6.61 lb)
≤ 3 kg (6.61 lb)
≤ 2.5 kg (5.51 lb)
≤ 4.5 kg (9.92 lb)
≤ 4.5 kg (9.92 lb)
Console port
4
8
8
16
16
4
8
8
12 (The rightmost four 10/100/1000BASE-T autosensing Ethernet ports each form a combo interface with its corresponding SFP port.)
SFP port
2
4
4
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
Input voltage
·     AC input (not supported by an S3100V3-20TP-PWR-EI-DC switch):
·     H3C RPS1600-A input (supported only by an S3100V3-28TP-PWR-EI switch)
¡     Rated voltage: –54 VDC to –57 VDC
¡     Max voltage:
Single DC input: –44 VDC to –60 VDC
AC and DC inputs: –54 VDC to –57 VDC
·     DC input from a DC power supply system or an H3C RPS1600-A (supported only by an S3100V3-20TP-PWR-EI-DC switch):
¡     Rated voltage: –52 VDC to –57 VDC
¡     Max voltage: –44 VDC to –60 VDC
Maximum PoE power per port
30 W
30 W
30 W
30 W
The combo copper ports do not support PoE power output.
30 W
Total PoE power
125 W
185 W
185 W
AC: 370 W
DC: 740 W
370 W
13 W
Models with product code LS-3100V3-20TP-PWR-EI: 18 W
Models with product code LS-3100V3-20TP-PWR-EI-H1: 15 W
21 W
AC: 23 W
DC: 16 W
15 W
Maximum power consumption (including PoE power consumption)
150 W
Models with product code LS-3100V3-20TP-PWR-EI: 220 W
Models with product code LS-3100V3-20TP-PWR-EI-H1: 235 W
220 W
AC: 439 W
DC: 788 W
443 W
6.3 A/250 V
6.3 A/250 V
3.15 A/125 V
15 A/250 V
15 A/250 V
Cooling system
Using fixed fan trays to draw ambient air in from the left side and exhaust heated air from the right side
Using fixed fan trays to draw ambient air in from the left side and the port side and exhaust heated air from the right side
Operating humidity
2 Chassis views
S3100V3-10TP-EI
Figure2-1 Front panel
(1) 10/100BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port
(3) 10/100BASE-T autosensing Ethernet port LED
(4) SFP port LED
(5) System status LED (SYS)
(6) 10/100/1000BASE-T autosensing Ethernet port LED
(7) Console port
(8) SFP port
Figure2-2 Rear panel
(1) Grounding screw
(2) AC-input power receptacle
S3100V3-18TP-EI
Figure2-3 Front panel
(4) 10/100/1000BASE-T autosensing Ethernet port LED
(5) SFP port LED
(6) System status LED (SYS)
(7) Console port
(8) SFP port
Figure2-4 Rear panel
(1) Grounding screw
S3100V3-18TP-EI-DC
Figure2-5 Front panel
(5) SFP port LED
(7) Console port
(8) SFP port
Figure2-6 Rear panel
(1) DC-input power receptacle
(2) Grounding screw
S3100V3-28TP-EI
Figure2-7 Front panel
(5) SFP port LED
(7) Console port
(8) SFP port
Figure2-8 Rear panel
(1) Grounding screw
S3100V3-28TP-EI-DC
Figure2-9 Front panel
(5) SFP port LED
(7) Console port
(8) SFP port
Figure2-10 Rear panel
(1) Grounding screw
(2) DC-input power receptacle
S3100V3-52TP-EI
Figure2-11 Front panel
(2) 10/100BASE-T autosensing Ethernet port LED
(3) 10/100/1000BASE-T autosensing Ethernet port
(5) Console port
(7) SFP port
(8) SFP port LED
Figure2-12 Rear panel
(1) Grounding screw
S3100V3-10TP-PWR-EI
Figure2-13 Front panel
(4) SFP port LED
(6) Mode LED (MODE)
(7) 10/100/1000BASE-T autosensing Ethernet port LED
(8) Port LED mode switching button
(9) Console port
(10) SFP port
Figure2-14 Rear panel
(1) AC-input power receptacle
(2) Grounding screw
S3100V3-20TP-PWR-EI
Figure2-15 Front panel
(5) SFP port LED
(7) Mode LED (MODE)
(9) Console port
(10) SFP port
Figure2-16 Rear panel
(2) Grounding screw
Figure2-17 Front panel
(5) SFP port LED
(7) Mode LED (MODE)
(9) Console port
(10) SFP port
Figure2-18 Rear panel
(2) Grounding screw
S3100V3-28TP-PWR-EI
Figure2-19 Front panel
(4) System status LED (SYS)
(5) RPS status LED (RPS)
(6) Mode LED (MODE)
(7) SFP port LED
(8) 10/100/1000BASE-T autosensing Ethernet port LED
(9) Port LED mode switching button
(10) Console port
(11) SFP port
Figure2-20 Rear panel
(1) Grounding screw
(3) DC-input power receptacle
Figure2-21 Front panel
(5) Mode LED (MODE)
(6) SFP port LED
(9) Console port
(10) SFP port
Figure2-22 Rear panel
(1) Grounding screw
3 Ports and LEDs
Ports
Console port
Table3-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local PC running terminal emulation program.
Table3-2 10/100BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Interface attributes
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     MDI/MDI-X autosensing
Max transmission distance
100 m (328.08 ft)
Transmission medium
Category-5 (or above) twisted pair cable
Compatible standards
·     IEEE 802.3i
·     802.3u
·     802.3ab
Table3-3 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1000 Mbps, full duplex
100 m (328.08 ft)
Transmission medium
·     IEEE 802.3i
·     802.3u
·     802.3ab
SFP port
The S3100V3-EI switches provide SFP ports. SFP transceiver modules and cables available for the SFP ports vary by switch model, as shown in Table3-4.
Table3-4 SFP transceiver modules and cables available for the switches
Switch model
Available SFP transceiver modules and cables
Restrictions
S3100V3-10TP-EI
S3100V3-18TP-EI
S3100V3-18TP-EI-DC
S3100V3-10TP-PWR-EI
S3100V3-28TP-EI
S3100V3-28TP-EI-DC
GE SFP transceiver modules and cables in Table3-5
To use transceiver modules with the maximum transmission distance greater than or equal to 80 km (49.71 miles), make sure the operating temperature is lower than or equal to 40°C (104°F).
S3100V3-52TP-EI
S3100V3-20TP-PWR-EI
N/A
S3100V3-28TP-PWR-EI
GE SFP transceiver modules and cables in Table3-5 and FE SFP transceiver modules in Table3-6
N/A
Table3-5 GE SFP transceiver modules and cables available for the SFP ports
GE SFP transceiver module and cable
Central wavelength (nm)
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
SFP copper transceiver module
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP fiber transceiver module
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
Multi-mode, 62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 mm (2.76 in)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 mm (2.76 in)
SFP cable
SFP-STACK-Kit
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
Table3-6 FE SFP transceiver modules
Central wavelength
Connector
Fiber
SFP-FE-SX-MM1310-A
1310 nm
LC
·     50/125 µm, multimode
·     62.5/125 µm, multimode
2 km (1.24 miles)
SFP-FE-LX-SM1310-A
1310 nm
LC
9/125 µm, single mode
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310 nm
LC
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310 nm
LC
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550 nm
LC
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
You must use these two transceiver modules in pairs.
·     TX: 1310 nm
·     RX: 1550 nm
LC
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
·     TX: 1550 nm
·     RX: 1310 nm
LC
·     As a best practice, use H3C SFP transceiver modules and cables for the SFP ports.
·     The H3C SFP transceiver modules and cables available for the SFP ports are subject to change over time. For the most up-to-date list of H3C SFP transceiver modules and cables available for the SFP ports, contact your H3C sales representative or technical support engineer.
·     For the specifications for the H3C SFP transceiver modules and cables, see H3C Transceiver Modules User Guide.
Combo interface
The S3100V3-28TP-PWR-EI and S3100V3-28TP-PWR-EI-AC switches each provide four combo interfaces. Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports can operate at a time.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table3-7 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
RPS status LED
The S3100V3-28TP-PWR-EI switch supports RPS input and provides an RPS status LED on the front panel to indicate the RPS operating status.
Table3-8 RPS status LED description
LED mark
Status
RPS
Steady green
Both the RPS DC input and the AC input are normal.
Steady yellow
The RPS DC input is normal, but the AC input is disconnected or has failed.
Off
The RPS DC input has failed, or no RPS is connected.
Mode LED (MODE)
The S3100V3-EI PoE switches each provide a mode LED (MODE). The mode LED works in conjunction with the 10/100BASE-T or 10/100/1000BASE-T autosensing Ethernet port LEDs to indicate the operating state of the autosensing Ethernet ports and the switch.
You can use the LED mode switching button to change the indication of the mode LED.
Table3-9 Description for the mode LED
LED mark
Status
Mode LED (MODE)
Steady green
The autosensing Ethernet port LEDs are showing link state of the ports.
Flashing green (available only for PoE switches)
The autosensing Ethernet port LEDs are showing the PoE status of the ports.
Flashing yellow
The autosensing Ethernet port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green, the IRF member ID of the switch is 5.
SFP port LED
Table3-10 SFP port LED description
Status
Steady green
A link is present on the port.
Flashing green
The port is sending or receiving data.
Off
·     No link is present on the port.
·     The mode LED is operating in PoE mode (available only for PoE switch models)
10/100BASE-T and 10/100/1000BASE-T autosensing Ethernet port LEDs
·     On the S3100V3-EI PoE switches, the 10/100BASE-T and 10/100/1000BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the autosensing Ethernet ports and the switch from different aspects.
Table3-11 10/100BASE-T and 10/100/1000BASE-T autosensing Ethernet port LED description
Mode LED status
Ethernet port LED status
Steady green (Link/Active mode)
Steady green
Flashing green
Off
Flashing green (PoE mode, available only for PoE switches)
Steady green
PoE power supply is normal.
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or short-circuit occurs.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Flashing yellow (IRF mode)
Steady green
The autosensing Ethernet port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other port LEDs are off, the IRF member ID of the switch is 5.
·     The S3100V3-EI non-PoE switches do not have a mode LED. Table3-12 describes the 10/100BASE-T and 10/100/1000BASE-T autosensing Ethernet ports LEDs on these switches.
Table3-12 10/100BASE-T and 10/100/1000BASE-T autosensing Ethernet port LED description
LED status
Steady green
Flashing green
Off
