01-AP management commands | 58.50 KB |
region-code
Use region-code to specify a region code.
region-code code
undo region-code
The region code is CN.
Global configuration view
code: Specifies a region code. For more information about region codes, see Table 1.
Table 1 Region code information
Country |
Code |
Country |
Code |
Andorra |
AD |
Korea, Republic of Korea |
KR |
United Arab Emirates |
AE |
Kenya |
KE |
Albania |
AL |
Kuwait |
KW |
Armenia |
AM |
Kazakhstan |
KZ |
Australia |
AU |
Lebanon |
LB |
Argentina |
AR |
Liechtenstein |
LI |
Australia |
AT |
Sri Lanka |
LK |
Azerbaijan |
AZ |
Lithuania |
LT |
Bosnia and Herzegovina |
BA |
Luxembourg |
LU |
Belgium |
BE |
Latvia |
LV |
Bulgaria |
BG |
Libyan |
LY |
Bahrain |
BH |
Morocco |
MA |
Brunei Darussalam |
BN |
Monaco |
MC |
Bolivia |
BO |
Moldova |
MD |
Brazil |
BR |
Macedonia |
MK |
Bahamas |
BS |
Macau |
MO |
Belarus |
BY |
Martinique |
MQ |
Belize |
BZ |
Malta |
MT |
Canada |
CA |
Mauritius |
MU |
Switzerland |
CH |
Mexico |
MX |
Cote d'ivoire |
CI |
Malay Archipelago |
MY |
Chile |
CL |
Namibia |
NA |
China |
CN |
Nigeria |
NG |
Colombia |
CO |
Nicaragua |
NI |
Costarica |
CR |
Netherlands |
NL |
Serbia |
RS |
Norway |
NO |
Cyprus |
CY |
New Zealand |
NZ |
Czech Republic |
CZ |
Oman |
OM |
Germany |
DE |
Panama |
PA |
Denmark |
DK |
Peru |
PE |
Dominica |
DO |
Poland |
PL |
Algeria |
DZ |
Philippines |
PH |
Ecuador |
EC |
Pakistan |
PK |
Estonia |
EE |
Puerto Rico |
PR |
Egypt |
EG |
Portugal |
PT |
Spain |
ES |
Paraguay |
PY |
Faroe Islands |
FO |
Qatar |
QA |
Finland |
FI |
Romania |
RO |
France |
FR |
Russian Federation |
RU |
Britain |
GB |
Saudi Arabia |
SA |
Georgia |
GE |
Sweden |
SE |
Gibraltar |
GI |
Singapore |
SG |
Greenland |
GL |
Slovenia |
SI |
Guadeloupe |
GP |
Slovak |
SK |
Greece |
GR |
San Marino |
SM |
Guatemala |
GT |
Salvador |
SV |
Guam |
GU |
Syrian |
SY |
Guyana |
GY |
Thailand |
TH |
Honduras |
HN |
Tunisia |
TN |
Hong Kong |
HK |
Turkey |
TR |
Croatia |
HR |
Trinidad and Tobago |
TT |
Hungary |
HU |
, China |
TW |
Iceland |
IS |
Ukraine |
UA |
India |
IN |
United States of America |
US |
Indonesia |
ID |
Uruguay |
UY |
Ireland |
IE |
Uzbekistan |
UZ |
Israel |
IL |
The Vatican City State |
VA |
Iraq |
IQ |
Venezuela |
VE |
Italy |
IT |
Virgin Islands |
VI |
Jamaica |
JM |
Vietnam |
VN |
Jordan |
JO |
Yemen |
YE |
Japan |
JP |
South Africa |
ZA |
Democratic People's Republic of Korea |
KP |
Zimbabwe |
ZW |
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring the AP.
# Specify US as the global region code.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] region-code US
region-code-lock
region-code-ie
Use region-code-ie to include or exclude region codes in beacon frames and probe responses and specify the installation environment type.
Use undo region-code-ie to restore the default.
region-code-ie { disable | enable { any | indoor | outdoor } }
undo region-code-ie
Beacon frames and probe responses contain region codes and the installation environment type is any.
Service template view
disable: Excludes region codes in beacon frames and probe responses.
enable: Includes region codes in beacon frames and probe responses.
any: Specifies APs that can be installed both indoors and outdoors.
indoor: Specifies APs that can only be installed indoors.
outdoor: Specifies APs that can only be installed outdoors.
If you bind different service templates to radios of the AP, make sure the service templates are specified with the same installation environment type.
# Include region codes in beacon frames and probe responses and specify the type of installation environment as indoor.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] region-code-ie enable indoor
region-code
region-code-lock
Use region-code-lock enable to lock the region code.
Use region-code-lock disable to unlock the region code.
Use undo region-code-lock to restore the default.
region-code-lock { disable | enable }
The region code is not locked.
A locked region code cannot be changed.
# Lock the global region code.
[Sysname-wlan-global-configuration] region-code-lock enable
region-code
usb
Use usb enable to enable the USB interface on the AP.
Use undo usb to restore the default.
usb enable
undo usb enable
The USB interface is disabled.
This command takes effect only when the input power level of the AP is middle or high.
If the input power level is middle, the MIMO mode can only be 1×1 or 2×2 with the USB interface enabled. With the USB interface disabled, the MIMO mode can reach 4×4.
# Enable the USB interface.
[Sysname] usb enable
wlan led-mode
Use wlan led-mode to set the LED lighting mode.
Use undo wlan led-mode to restore the default.
wlan led-mode { always-on | awake | normal | quiet }
undo wlan led-mode
The LED lighting mode is normal.
always-on: Specifies the always-on mode. In this mode, all LEDs are steady on.
awake: Specifies the awake mode. In this mode, all the LEDs flash once every minute.
normal: Specifies the normal mode.
quiet: Specifies the quiet mode. In this mode, all the LEDs are off.
# Set the LED lighting mode to awake.
[Sysname] wlan led-mode awake
