03-Interface Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(E2587P03)-5W10003-Interface Command Reference
02-Ethernet interface commands
02-Ethernet interface commands 161.79 KB
Common Ethernet interface commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
# Set the expected bandwidth of GigabitEthernet 1/0/1 to 1000 kbps.
[Sysname-GigabitEthernet1/0/1] bandwidth 1000
speed
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to disable broadcast suppression.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
# Set the broadcast suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
multicast-suppression
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
Do not enable the dampening function on an interface with spanning tree protocols enabled.
After an interface in down state is dampened, the interface state displayed through the display interface command, MIB, or Web is always down.
# Enable interface dampening on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dampening
# Enable interface dampening on GigabitEthernet 1/0/1, and set the following parameters:
·     Half life time to 2 seconds.
·     Reuse value to 800.
·     Suppression threshold to 3000.
·     Maximum suppression interval to 5 seconds.
[Sysname-GigabitEthernet1/0/1] dampening 2 800 3000 5
display interface
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] default
This command will restore the default settings. Continue? [Y/N]:y
description
The description of an interface is the interface name plus Interface (for example, GigabitEthernet1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of GigabitEthernet 1/0/1 to lan-interface.
[Sysname-GigabitEthernet1/0/1] description lan-interface
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
GE1/0/1                       100                 100                   0           0
GE1/0/2                  Overflow            Overflow            Overflow    Overflow
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
‌Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow when any of the following conditions exist:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
GE1/0/1                     0             0                --               --
 Overflow: More than 14 digits.
       --: Not supported.
Usage (%)
Bandwidth usage (in percentage) of the interface for the last statistics polling interval.
Total (pps)
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval.
Broadcast (pps)
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval.
Multicast (pps)
‌Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval. .
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
# Display the Ethernet module statistics.
<Sysname> display ethernet statistics
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
Table 3 Output description
Statistics about the Ethernet packets received by the Ethernet module:
·     Totalnum—Total number of received packets.
·     ETHIINum—Number of packets encapsulated by using Ethernet II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISISNum—Number of packets encapsulated by using ISIS. This field is not supported in the current software version.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets.
·     MPLS—Number of MPLS packets. This field is not supported in the current software version.
·     ISIS—Number of IS-IS packets. This field is not supported in the current software version.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS. This field is not supported in the current software version.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces. This field is not supported in the current software version.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.‌ ‌ ‌
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module:
·     MbufRelayNum—Number of packets transparently sent.
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQoSTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
reset ethernet statistics
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPP in Network Connectivity Configuration Guide.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display detailed information about Layer 2 interface GigabitEthernet 1/0/1.
<Sysname> display interface gigabitethernet 1/0/1
Current state: DOWN
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Flow-control is not enabled
Maximum frame length: 1600
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last hardware down reason: PHY line side is down
Last clearing of counters:  14:34:09 Tue 11/01/2011
Current system time:2017-12-09 10:59:08
Last time when physical state changed to up:-
Last time when physical state changed to down:2017-12-09 10:59:07
 Last 300 second input:  0 packets/sec 0 bytes/sec -%
 Last 300 second output:  0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, 0 bytes
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output (normal): 0 packets, 0 bytes
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command.
·     mac-address moving down—The interface has been shut down by the MAC address move suppression feature.
·     STP DOWN—The interface has been shut down by the BPDU guard feature.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
·     DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include:
¡     LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports.
The peer line protocol state is DOWN(Bit-error down)
Bit errors occur on the peer interface, so the data link layer state of the interface is down.
This field is displayed when the local interface receives bit error messages from the peer interface.
Bandwidth
Expected bandwidth of the interface.
Maximum transmission unit
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IPv4 packet framing format.
hardware address
MAC address of the interface.
Port priority
Port priority of the interface.
Loopback is not set
No loopback test is running on the interface. This field depends on your configuration.
10Mbps-speed mode
The interface is operating at 10 Mbps. This field depends on your configuration and the link parameter negotiation result.
100Mbps-speed mode
The interface is operating at 100 Mbps. This field depends on your configuration and the link parameter negotiation result.
1000Mbps-speed mode
The interface is operating at 1000 Mbps. This field depends on your configuration and the link parameter negotiation result.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
half-duplex mode
The interface is operating in half duplex mode. This field depends on your configuration and the link parameter negotiation result.
full-duplex mode
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command.
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result.
Maximum length of Ethernet frames allowed to pass through the interface.
The interface allows jumbo frames to pass through.
Broadcast max-
This field is not supported in the current software version. Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration
Multicast max-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
This field is not supported in the current software version. Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
MDI type
MDIX mode of the interface, automdix, mdi, or mdix.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
VLAN Passing
VLANs whose packets can be forwarded by the port. The VLANs must have been created.
VLAN permitted
VLANs whose packets are permitted by the port.
Trunk port encapsulation
Encapsulation protocol type for the trunk port.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS format.
Last time when physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has not changed to up.
Last time when physical state of the interface changed to down.
A hyphen (-) indicates that the physical state of the interface has not changed to down.
Last 300 second input:  0 packets/sec 0 bytes/sec 0%
Last 300 second output:  0 packets/sec 0 bytes/sec 0%
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
‌The four fields on the second line represent:
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
‌Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
‌Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
# Display brief information about all interfaces.
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP      Description
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   UP       --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
GE1/0/2              DOWN auto    A      A    1
GE1/0/3              UP   1G(a)   F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about GigabitEthernet 1/0/1, including the complete description of the interface.
<Sysname> display interface gigabitethernet 1/0/1 brief description
Speed: (a) - auto
GE1/0/1              UP   1G(a)   F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
Vlan2                DOWN Not connected
GE1/0/2              DOWN Not connected
Table 5 Command output
Brief information about Layer 3 interfaces.
Interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Brief information of interfaces in bridge mode:
Brief information about Layer 2 interfaces.
Type: A - access; T - trunk; H – hybrid
Link type options for interfaces.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
display interface link-info
Use display interface link-info to display the status and packet statistics of interfaces.
# Display status and statistics of all interfaces.
<Sysname> display interface link-info
Protocol: (s) - spoofing
Interface                    Link Protocol  InUsage OutUsage   InErrs  OutErrs
GE1/0/1                      UP   UP         10.09%       0%        0        0
NULL0                        UP   UP(s)          0%       0%        0        0
BAGG11                       ADM  DOWN           --       --       --       --
  GE1/0/2                    DOWN DOWN           --       --       --       --
RAGG11                       ADM  DOWN           --       --       --       --
  GE1/0/3                    DOWN DOWN           --       --       --       --
 Overflow: More than 7 digits.
       --: Not supported.
Table 6 Command output
The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
Link
Protocol
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces.
InUsage
Inbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average inbound speed of the interface within the most recent statistics polling interval/interface bandwidth. When the usage is smaller than 0.01%, 0.01% is displayed. To set the statistics polling interval, use the flow-interval command.
OutUsage
Outbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average outbound speed of the interface within the most recent statistics polling interval/interface bandwidth. When the usage is smaller than 0.01%, 0.01% is displayed. To set the statistics polling interval, use the flow-interval command.
InErrs
Number of error packets received.
OutErrs
Number of error packets sent.
The data length of a statistical item value is greater than 7 decimal digits.
--: Not supported.
A hyphen (-) indicates that the corresponding statistical item is not supported.
flow-interval
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full | half }
undo duplex
Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
half: Configures the interface to operate in half duplex mode. In this mode, the interface can only receive or transmit packets at a given time.
# Configure GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
interface
Use interface to enter interface view.
# Enter the view of GigabitEthernet 1/0/1.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within 1600 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value for this argument is 1600 bytes.
# Allow jumbo frames to pass through GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] jumboframe enable
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
# Set the multicast storm suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] multicast-suppression kbps 10000
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces except VA interfaces. For more information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for GigabitEthernet 1/0/1.
<Sysname> reset counters interface gigabitethernet 1/0/1
display counters interface
display counters rate interface
display interface
Use reset ethernet statistics to clear the Ethernet module statistics.
# Clear the Ethernet module statistics.
<Sysname> reset ethernet statistics
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
An Ethernet interface or subinterface is up.
CAUTION
CAUTION:
Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution.
Some interface configurations might require an interface restart before taking effect.
# Shut down and then bring up GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
shutdown all-physical-interface
Use shutdown all-physical-interfaces to shut down all physical interfaces.
Use undo shutdown all-physical-interfaces to bring up all physical interfaces.
Physical interfaces are up.
With the shutdown all-physical-interfaces command, you can shut down all physical interfaces on the device. Physical interfaces shut down by using this command are in ADM state.
To shut down all physical interfaces or the specified interface, execute the shutdown all-physical-interfaces command in system view or execute the shutdown command in interface view.
To bring up a shutdown interface, execute the undo shutdown all-physical-interfaces command in system view and execute the undo shutdown command in interface view.
# Shut down all physical interfaces.
[Sysname] shutdown all-physical-interfaces
shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 2500 | auto }
undo speed
An Ethernet interface autonegotiates its speed.
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
2500: Sets the interface speed to 2500 Mbps.
The following compatibility matrix shows the support of hardware platforms for this keyword:
Series
Models
Compatibility
WA6500A series
WA6520
WA6520-C
WA6520-HI
WA6520H
WA6520H-EGPON
WA6520S-C
WA6520S-E
WA6522
WA6520XS-LI
WA6522-C
WA6522H-HI
WA6522H-LI
WA6526
WA6526E
WA6526H
WA6530
WA6530-LI
WA6520: Yes
WA6520-C: No
WA6520-HI: Yes
WA6520H: Yes
WA6520H-EGPON: No
WA6520S-C: No
WA6520S-E: No
WA6522: Yes
WA6520XS-LI: No
WA6522-C: Yes
WA6522H-HI: No
WA6522H-LI: No
WA6526: Yes
WA6526E: Yes
WA6526H: Yes
WA6530: Yes
WA6530-LI: No
WA6500-E series
WA6520-E
WA6520H-E
WA6520X-E
WA6520-E: Yes
WA6520H-E: Yes
WA6520X-E: No
WAP912 series
WAP912X
No
WAP952 series
WAP952
WAP952E
WAP952H
WAP952: No
WAP952E: No
WAP952H: No
WAP953 series
WAP953
No
Series
Models
Compatibility
WA6100 series
WA6126
WA6120
WA6120H
WA6120X
WA6126: Yes
WA6120: No
WA6120H: No
WA6120X: No
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface. Support of copper ports for keywords of this command varies by copper port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a copper port, the copper port supports this speed. Otherwise, the copper port does not support this speed.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module. Support of fiber ports for keywords of this command varies by fiber port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a fiber port, the fiber port supports this speed. Otherwise, the fiber port does not support this speed.
Additionally, you must select a speed for a fiber port according to the transceiver module installed to ensure that the transceiver module can be used properly. If the transceiver module installed in a fiber port does not support the speed for the fiber port, the transceiver module cannot be used. For example, the transceiver module cannot be used if either of the following conditions exists:
·     The transceiver module installed in an SFP+ fiber port is an SFP GE transceiver module and the speed 10000 command is executed on the fiber port.
·     The transceiver module installed in an SFP+ fiber port is a 10-GE transceiver module and the speed 1000 command is executed on the fiber port.
# Configure GigabitEthernet 1/0/1 to autonegotiate the speed.
[Sysname-GigabitEthernet1/0/1] speed auto
