Built-in capability of UIS cloud backup
The UIS hyper converged infrastructure has built-in VM backup function, supporting intra-cluster and inter-cluster backup. The backup library/directory supports local storage, shared file system, external storage, and FTP server. It can provide backup to the entire machine and a single disk, support agent-free mode, and enable both regular backup and manual backup.
1) Intra-cluster backup
For small-scale backup (VM data volume less than 1 TB and less than 3 backup VMs), you can use UIS built-in intra-cluster backup function directly without additional cost, providing logical error correction backup capability based on distributed storage with high reliability.
2) Inter-cluster backup
It protects backup files based on different failure domains. Each cluster is responsible for carrying both business and backup capacities, and the two clusters back up mutually for flexible resource allocation and improved resource utilization.
UIS cloud backup all-in-one machine
UIS hyper converged cloud backup all-in-one machine is oriented for the cloud-native architecture. It meets the backup needs of critical data for big cloud solutions and hyper converged scenarios to protect the business. With carefully designed hardware and software integration configuration, it can be put in operation immediately, which greatly reduces the difficulty of a cloud backup solution implementation.
UIS hyper converged cloud backup all-in-one machine is closely integrated with the cloud management platform. It optimizes the backup efficiency of cloud and hyper converged scenarios, achieves the maximum rate of 4GB/s for single node of VM agent-free backup, and takes only 42 minutes to complete full backup of 10 TB data. It also supports incremental backup and de-duplication compression to balance the performance and cost.
UIS Cloud Backup Interface
Big cloud backup solution
With the UIS cloud backup all-in-one machine, the big cloud solution provides an automated backup solution deeply integrated with the cloud platform to enhance the reliability and security of cloud services.
Highlights of UIS cloud backup solution
