11-ACL and QoS Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6728-6W10111-ACL and QoS Configuration Guide
02-QoS configuration
02-QoS configuration 798.42 KB
QoS overview·· 1
QoS service models· 1
Best-effort service model 1
IntServ model 1
DiffServ model 1
QoS techniques in a network· 1
QoS processing flow in a device· 2
QoS configuration approaches· 3
Configuring a QoS policy· 4
About QoS policies· 4
QoS policy tasks at a glance· 4
Defining a traffic class· 4
Defining a traffic behavior 5
Defining a QoS policy· 5
Configuring policy nesting· 5
Applying the QoS policy· 6
Application destinations· 6
Restrictions and guidelines for applying a QoS policy· 7
Applying the QoS policy to an interface· 7
Applying the QoS policy to a PVC· 7
Applying the QoS policy globally· 8
Applying the QoS policy to a control plane· 8
Applying the QoS policy to a user profile· 9
Setting the QoS policy-based traffic rate statistics collection period for an interface· 10
Display and maintenance commands for QoS policies· 10
Configuring priority mapping· 13
About priority mapping· 13
About priorities· 13
Priority maps· 13
Priority mapping configuration methods· 14
Priority mapping process· 14
Priority mapping tasks at a glance· 16
Configuring a priority map· 17
Configuring a port to trust packet priority for priority mapping· 18
Changing the port priority of an interface· 19
Display and maintenance commands for priority mapping· 20
Priority mapping configuration examples· 21
Example: Configuring a priority trust mode· 21
Example: Configuring priority mapping tables and priority marking· 22
Configuring traffic policing, GTS, and rate limit 26
About traffic policing, GTS, and rate limit 26
Traffic evaluation and token buckets· 26
Traffic policing· 27
GTS· 28
Rate limit 29
Restrictions: Hardware compatibility withtraffic policing, GTS, and rate limit 30
Configuring traffic policing· 30
Traffic policing configuration approaches· 30
Configuring traffic policing by using the MQC approach· 31
Configuring CAR-list-based traffic policing· 32
Configuring CAR-list-based dynamic traffic policing· 33
Configuring ACL-based traffic policing· 34
Configuring traffic policing for all traffic· 34
Configuring traffic policing for a user profile· 35
Configuring traffic policing for a tunnel 36
Configuring GTS· 36
GTS configuration approaches· 36
Configuring GTS by using the MQC approach· 37
Configuring ACL-based GTS· 38
Configuring GTS for all traffic· 38
Configuring the rate limit 39
Configuring the rate limit for an interface· 39
Configuring the rate limit for a PW·· 39
Including the physical layer header in calculating the packet length for rate limiting· 40
Display and maintenance commands for traffic policing, GTS, and rate limit 42
Traffic policing, GTS, and rate limit configuration examples· 42
Example: Configuring traffic policing· 42
Example: Configuring per-IP-address traffic policing· 45
Configuring congestion management 46
About congestion management 46
Cause, negative results, and countermeasure of congestion· 46
Congestion management methods· 46
FIFO·· 47
PQ·· 47
CQ·· 48
WFQ·· 49
CBQ·· 50
RTPQ·· 51
Congestion management technique comparison· 51
Restrictions: Hardware compatibility with congestion management 53
Setting the FIFO queue size· 53
Setting the FIFO queue size for an interface· 53
Setting the FIFO queue size for a PVC· 54
Setting the FIFO queue size for a PW·· 54
Configuring PQ·· 55
About configuring PQ·· 55
Restrictions and guidelines· 55
Configuring PQ for an interface· 55
Configuring PQ for a PVC· 56
Example: Configuring PQ·· 57
Configuring CQ·· 58
About configuring CQ·· 58
Restrictions and guidelines· 58
Configuring CQ for an interface· 58
Configuring CQ for a PVC· 59
Configuring WFQ·· 60
Restrictions and guidelines· 60
Configuring WFQ for an interface· 60
Configuring WFQ for a PVC· 60
Configuring WFQ for a PW·· 60
Configuring CBQ·· 61
About CBQ·· 61
Restrictions and guidelines for CBQ configuration· 62
Configure AF and the minimum guaranteed bandwidth· 62
Configuring EF and the maximum bandwidth· 64
Configuring SP· 65
Configuring WFQ·· 66
Setting the maximum available interface bandwidth· 67
Setting the maximum reserved bandwidth as a percentage of available bandwidth for an interface· 68
Setting the maximum reserved bandwidth as a percentage of available bandwidth for a PVC· 68
Example: Configuring CBQ·· 68
Configuring RTPQ·· 70
Restrictions and guidelines· 70
Configuring RTPQ on an interface· 70
Configuring RTPQ on a PVC· 70
Enabling packet information pre-extraction· 71
Displaying and maintaining congestion management 71
Configuring congestion avoidance· 73
About congestion avoidance· 73
Tail drop· 73
RED and WRED·· 73
Relationship between WRED and queuing mechanisms· 74
WRED parameters· 74
Configuring WRED parameters on an interface· 75
Restrictions and guidelines· 75
Procedure· 75
Example: Configuring WRED on an interface· 75
Configuring WRED parameters on a PVC· 76
Display and maintenance commands for WRED·· 76
Configuring traffic filtering· 78
About traffic filtering· 78
Restrictions and guidelines: Traffic filtering configuration· 78
Procedure· 78
Traffic filtering configuration examples· 79
Example: Configuring traffic filtering· 79
Configuring priority marking· 81
About priority marking· 81
Priority marking configuration examples· 82
Example: Configuring priority marking· 82
Configuring traffic redirecting· 85
About traffic redirecting· 85
Restrictions: Hardware compatibility with traffic redirecting· 85
Restrictions and guidelines: Traffic redirecting configuration· 87
Procedure· 87
Traffic redirecting configuration examples· 88
Example: Configuring traffic redirecting· 88
Appendixes· 90
Appendix A Acronyms· 90
Appendix B Default priority maps· 91
Appendix C Introduction to packet precedence· 92
IP precedence and DSCP values· 92
802.1p priority· 94
EXP values· 94
QoS overview
In data communications, Quality of Service (QoS) provides differentiated service guarantees for diversified traffic in terms of bandwidth, delay, jitter, and drop rate, all of which can affect QoS.
QoS manages network resources and prioritizes traffic to balance system resources.
The following section describes typical QoS service models and widely used QoS techniques.
QoS service models
This section describes several typical QoS service models.
The best-effort model is a single-service model. The best-effort model is not as reliable as other models and does not guarantee delay-free delivery.
The best-effort service model is the default model for the Internet and applies to most network applications. It uses the First In First Out (FIFO) queuing mechanism.
IntServ model
The integrated service (IntServ) model is a multiple-service model that can accommodate diverse QoS requirements. This service model provides the most granularly differentiated QoS by identifying and guaranteeing definite QoS for each data flow.
In the IntServ model, an application must request service from the network before it sends data. IntServ signals the service request with the RSVP. All nodes receiving the request reserve resources as requested and maintain state information for the application flow.
The IntServ model demands high storage and processing capabilities because it requires all nodes along the transmission path to maintain resource state information for each flow. This model is suitable for small-sized or edge networks. However, it is not suitable for large-sized networks, for example, the core layer of the Internet, where billions of flows are present.
DiffServ model
The differentiated service (DiffServ) model is a multiple-service model that can meet diverse QoS requirements. It is easy to implement and extend. DiffServ does not signal the network to reserve resources before sending data, as IntServ does.
The QoS techniques include the following features:
·     Traffic classification.
·     Traffic policing.
·     Traffic shaping.
·     Rate limit.
·     Congestion management.
·     Congestion avoidance.
The following section briefly introduces these QoS techniques.
All QoS techniques in this document are based on the DiffServ model.
Figure 1 Position of the QoS techniques in a network
As shown in Figure 1, traffic classification, traffic shaping, traffic policing, congestion management, and congestion avoidance mainly implement the following functions:
·     Traffic classification—Uses match criteria to assign packets with the same characteristics to a traffic class. Based on traffic classes, you can provide differentiated services.
·     Traffic policing—Polices flows and imposes penalties to prevent aggressive use of network resources. You can apply traffic policing to both incoming and outgoing traffic of a port.
·     Traffic shaping—Adapts the output rate of traffic to the network resources available on the downstream device to eliminate packet drops. Traffic shaping usually applies to the outgoing traffic of a port.
·     Congestion management—Provides a resource scheduling policy to determine the packet forwarding sequence when congestion occurs. Congestion management usually applies to the outgoing traffic of a port.
·     Congestion avoidance—Monitors the network resource usage. It is usually applied to the outgoing traffic of a port. When congestion worsens, congestion avoidance reduces the queue length by dropping packets.
Figure 2 briefly describes how the QoS module processes traffic.
1.     Traffic classifier identifies and classifies traffic for subsequent QoS actions.
2.     The QoS module takes various QoS actions on classified traffic as configured, depending on the traffic processing phase and network status. For example, you can configure the QoS module to perform the following operations:
¡     Traffic policing for incoming traffic.
¡     Traffic shaping for outgoing traffic.
¡     Congestion avoidance before congestion occurs.
¡     Congestion management when congestion occurs.
Figure 2 QoS processing flow
You can configure QoS by using the MQC approach or non-MQC approach.
In the modular QoS configuration (MQC) approach, you configure QoS service parameters by using QoS policies. A QoS policy defines QoS actions to take on different classes of traffic and can be applied to an object (such as an interface) to control traffic.
In the non-MQC approach, you configure QoS service parameters without using a QoS policy. For example, you can use the rate limit feature to set a rate limit on an interface without using a QoS policy.
Some features support both approaches, but some support only one.
About QoS policies
A QoS policy has the following components:
·     Traffic class—Defines criteria to match packets.
·     Traffic behavior—Defines QoS actions to take on matching packets.
By associating a traffic class with a traffic behavior, a QoS policy can perform the QoS actions on matching packets.
A QoS policy can have multiple class-behavior associations.
Support for ATM interfaces depends on the device model. For more information, see the installation guide and interface module manual of the device.
PWs are not supported on the following routers:
·     MSR810-LMS.
·     MSR810-LUS.
·     MSR810-SI.
·     MSR810-LM-SI.
·     MSR3600-28-SI.
·     MSR3600-28-SI-GL.
·     MSR3600-51-SI.
To configure a QoS policy, perform the following tasks:
1.     Defining a traffic class
2.     Defining a traffic behavior
3.     Defining a QoS policy
4.     (Optional.) Configuring policy nesting
5.     Applying the QoS policy
¡     Applying the QoS policy to an interface
¡     Applying the QoS policy to a PVC
¡     Applying the QoS policy to a control plane
¡     Applying the QoS policy to a user profile
6.     (Optional.) Setting the QoS policy-based traffic rate statistics collection period for an interface
2.     Create a traffic class and enter traffic class view.
3.     Configure a match criterion.
if-match [ not ] match-criteria
By default, no match criterion is configured.
For more information, see the if-match command in ACL and QoS Command Reference.
If an action in a traffic behavior cannot take effect, all other actions in the traffic behavior do not take effect.
2.     Create a traffic behavior and enter traffic behavior view.
3.     Configure an action in the traffic behavior.
By default, no action is configured for a traffic behavior.
For more information about configuring an action, see the subsequent chapters for traffic policing, traffic filtering, priority marking, class-based accounting, and so on.
2.     Create a QoS policy and enter QoS policy view.
qos policy policy-name
3.     Associate a traffic class with a traffic behavior to create a class-behavior association in the QoS policy.
classifier classifier-name behavior behavior-name [ insert-before before-classifier-name ]
By default, a traffic class is not associated with a traffic behavior.
Repeat this step to create more class-behavior associations.
A QoS policy configuration can contain a parent policy and a child policy.
Policy nesting allows you to create a child policy in the view of a traffic behavior of the parent policy.
You can nest a QoS policy in a traffic behavior to reclassify the traffic class associated with the behavior. Then the system performs the actions defined in the QoS policy on the reclassified traffic. The QoS policy nested in the traffic behavior is called the child policy. The QoS policy that nests the behavior is called the parent policy.
When you configure policy nesting, follow these restrictions and guidelines:
·     If class-based queuing (CBQ) is configured in a child policy, make sure the following requirements are met:
¡     GTS is configured in the parent policy.
¡     The CIR specified in GTS is greater than or equal to CBQ bandwidth.
·     If the CIR in GTS is specified as a percentage for a parent policy, configure the CBQ bandwidth as a percentage for the child policy.
·     If the CIR in GTS is specified in kbps for a parent policy, configure the CBQ bandwidth as a percentage or in kbps for the child policy.
·     GTS cannot be configured in the child policy.
Before configuring policy nesting, define a child policy (see "Defining a QoS policy").
2.     Define a traffic class for the parent policy.
a.     Create a traffic class for the parent policy and enter traffic class view.
b.     Configure a match criterion.
For more information about configuring match criteria, see ACL and QoS Command Reference.
c.     Return to system view.
3.     Nest the child QoS policy in the traffic behavior of the parent policy.
a.     Create a traffic behavior for the parent policy and enter traffic behavior view.
b.     Nest the child QoS policy.
traffic-policy policy-name
By default, policy nesting is not configured.
4.     Create the parent policy and enter parent policy view.
5.     Associate the class with the behavior in the parent policy.
By default, a class is not associated with a behavior.
You can apply a QoS policy to the following destinations:
·     Interface—The QoS policy can be applied to the traffic sent or received on an interface.
·     PVC—The QoS policy can be applied to the traffic sent or received on a PVC. For information about PVCs, see Layer 2—WAN Access Configuration Guide.
·     Globally—The QoS policy can be applied to the traffic sent or received on all ports.
·     Control plane—The QoS policy can be applied only to the traffic received on the control plane.
·     User profile—The QoS policy can be applied to the traffic sent or received by the online users of the user profile.
You can modify traffic classes, traffic behaviors, and class-behavior associations in a QoS policy even after it is applied (except that it is applied to a user profile). If a traffic class uses an ACL for traffic classification, you can delete or modify the ACL.
A QoS policy configured with a preorder-value is executed before a QoS policy that is not configured with a preorder-value.
For multiple QoS policies with the same action type applied to the same direction of an interface, the behavior in the QoS policy applied with the preorder preorder-value option is executed
The QoS policy applied to the outgoing traffic on an interface does not regulate local packets. Local packets refer to critical protocol packets sent by the local system for operation maintenance. The most common local packets include link maintenance, RIP, LDP, and SSH packets.
2.     Enter interface view.
3.     Apply the QoS policy to the interface.
qos apply policy policy-name { inbound | outbound } [ preorder preorder-value ]
By default, no QoS policy is applied to an interface.
A QoS policy can be applied to multiple PVCs. However, only one QoS policy can be applied to one direction (inbound or outbound) of a PVC.
The QoS policy applied to the outgoing traffic on a PVC does not regulate local packets. Local packets refer to critical protocol packets sent by the local system for operation maintenance. The most common local packets include link maintenance, routing, LDP, RSVP, and SSH packets.
2.     Execute the following commands in sequence to enter PVC view:
interface atm interface-number
pvc vpi/vci
3.     Apply the QoS policy to the PVC.
By default, no QoS policy is applied to a PVC.
You can apply a QoS policy globally to the inbound or outbound direction of all Layer 3 interfaces.
When you apply a QoS policy globally, the QoS policy is applied on all interface cards. If the hardware resources of an interface card are insufficient, applying a QoS policy globally might fail on the interface card. The system does not automatically roll back the QoS policy configuration already applied to other interface cards. To ensure consistency, you must use the undo qos apply policy global command to manually remove the QoS policy configuration applied to them.
2.     Apply the QoS policy globally.
By default, no QoS policy is applied globally.
A device provides the user plane and the control plane.
·     User plane—The units at the user plane are responsible for receiving, transmitting, and switching (forwarding) packets, such as various dedicated forwarding chips. They deliver super processing speeds and throughput.
·     Control plane—The units at the control plane are processing units running most routing and switching protocols. They are responsible for protocol packet resolution and calculation, such as CPUs. Compared with user plane units, the control plane units allow for great packet processing flexibility but have lower throughput.
When the user plane receives packets that it cannot recognize or process, it transmits them to the control plane. If the transmission rate exceeds the processing capability of the control plane, the control plane will be busy handling undesired packets. As a result, the control plane will fail to handle legitimate packets correctly or timely. As a result, protocol performance is affected.
To address this problem, apply a QoS policy to the control plane to take QoS actions, such as traffic filtering or traffic policing, on inbound traffic. This ensures that the control plane can correctly receive, transmit, and process packets.
A predefined control plane QoS policy uses the protocol type or protocol group type to identify the type of packets sent to the control plane. You can use protocol types or protocol group types in if-match control-plane commands in traffic class view for traffic classification. Then you can reconfigure traffic behaviors for these traffic classes as required. You can use the display qos policy control-plane pre-defined command to display predefined control plane QoS policies.
2.     Enter control plane view.
In standalone mode:
control-plane
In IRF mode:
3.     Apply the QoS policy to the control plane.
By default, no QoS policy is applied to a control plane.
When a user profile is configured, you can perform traffic policing based on users. After a user passes authentication, the authentication server sends the name of the user profile associated with the user to the device. The QoS policy configured in user profile view takes effect only when users come online.
You can apply a QoS policy to multiple user profiles. In one direction of each user profile, only one policy can be applied. To modify a QoS policy already applied to a direction, first remove the applied QoS policy.
2.     Enter user profile view.
user-profile profile-name
3.     Apply the QoS policy to the user profile.
By default, no QoS policy is applied to a user profile.
Parameter
inbound
Applies a QoS policy to the incoming traffic (traffic received by the device from online users).
outbound
Applies a QoS policy to the outgoing traffic (traffic sent by the device to online users).
You can enable collection of per-class traffic statistics over a period of time, including the average forwarding rate and drop rate. For example, if you set the statistics collection period to n minutes, the system performs the following operations:
·     Collects traffic statistics for the most recent n minutes.
·     Refreshes the statistics every n/5 minutes.
You can use the display qos policy interface command to view the collected traffic rate statistics.
When you set the QoS policy-based traffic rate statistics collection period, follow these restrictions and guidelines:
·     A subinterface uses the statistics collection period configured on the main interface.
·     A PVC uses the statistics collection period configured on the ATM main interface.
3.     Set the traffic rate statistics collection period for the interface.
qos flow-interval interval
The default setting is 5 minutes.
Display QoS policy configuration.
In standalone mode:
display qos policy { system-defined | user-defined } [ policy-name [ classifier classifier-name ] ]
In IRF mode:
display qos policy { system-defined | user-defined } [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
Display QoS policies applied to hub-spoke tunnels on a tunnel interface.
display qos policy advpn tunnel number [ ipv4-address | ipv6-address ] [ outbound ]
Display information about QoS policies applied to the control plane.
In standalone mode:
In IRF mode:
Display information about the predefined QoS policy applied to the control plane.
In standalone mode:
In IRF mode:
Display information about QoS policies applied globally.
In standalone mode:
display qos policy global [ inbound | outbound ]
In IRF mode:
Display information about QoS policies applied to interfaces.
In standalone mode:
display qos policy interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] [ inbound | outbound ]
In IRF mode:
display qos policy interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] [ slot slot-number  ] [ inbound | outbound ]
Display information about QoS policies applied to PWs.
display qos policy l2vpn-pw [ peer ip-address pw-id pw-id ] [ outbound ]
Display information about QoS policies applied to user profiles.
In standalone mode:
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ inbound | outbound ]
In IRF mode:
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
Display traffic behavior configuration.
In standalone mode:
display traffic behavior { system-defined | user-defined } [ behavior-name ]
In IRF mode:
display traffic behavior { system-defined | user-defined } [ behavior-name ] [ slot slot-number ]
Display traffic class configuration.
In standalone mode:
display traffic classifier { system-defined | user-defined } [ classifier-name ]
In IRF mode:
display traffic classifier { system-defined | user-defined } [ classifier-name ] [ slot slot-number ]
Clear the statistics for the QoS policy applied to the control plane.
In standalone mode:
reset qos policy control-plane
In IRF mode:
Clear the statistics for QoS policies applied to hub-spoke tunnels on a tunnel interface.
reset qos policy advpn tunnel number [ ipv4-address | ipv6-address ] [ outbound ]
Clear the statistics for a QoS policy applied globally.
When a packet arrives, a device assigns a set of QoS priority parameters to the packet based on either of the following:
·     A priority field carried in the packet.
·     The port priority of the incoming port.
This process is called priority mapping. During this process, the device can modify the priority of the packet according to the priority mapping rules. The set of QoS priority parameters decides the scheduling priority and forwarding priority of the packet.
Priority mapping is implemented with priority maps and involves the following priorities:
·     802.11e priority.
·     802.1p priority.
·     DSCP.
·     EXP.
·     IP precedence.
·     Local precedence.
·     Drop priority.
About priorities
Priorities include the following types: priorities carried in packets, and priorities locally assigned for scheduling only.
Packet-carried priorities include 802.1p priority, DSCP precedence, IP precedence, and EXP. These priorities have global significance and affect the forwarding priority of packets across the network. For more information about these priorities, see "Appendix C Introduction to packet precedence."
Locally assigned priorities only have local significance. They are assigned by the device only for scheduling. These priorities include the local precedence, drop priority, and user priority, as follows:
·     Local precedence—Used for queuing. A local precedence value corresponds to an output queue. A packet with higher local precedence is assigned to a higher priority output queue to be preferentially scheduled.
·     Drop priority—Used for making packet drop decisions. Packets with the highest drop priority are dropped preferentially.
·     User priority—Precedence that the device automatically extracts from a priority field of the packet according to its forwarding path. It is a parameter for determining the scheduling priority and forwarding priority of the packet. The user priority represents the following items:
¡     The 802.1p priority for Layer 2 packets.
¡     The IP precedence for Layer 3 packets.
¡     The EXP for MPLS packets.
Priority maps
The device provides various types of priority maps. By looking through a priority map, the device decides which priority value to assign to a packet for subsequent packet processing.
The default priority maps (as shown in Appendix B Default priority maps) are available for priority mapping. They are adequate in most cases. If a default priority map cannot meet your requirements, you can modify the priority map as required.
You can configure priority mapping by using any of the following methods:
·     Configuring priority trust mode—In this method, you can configure a port to look up a trusted priority type (802.1p, for example) in incoming packets in the priority maps. Then, the system maps the trusted priority to the target priority types and values.
·     Changing port priority—If no packet priority is trusted, the port priority of the incoming port is used. By changing the port priority of a port, you change the priority of the incoming packets on the port.
On receiving an Ethernet packet on a port, the switch marks the scheduling priorities (local precedence and drop precedence) for the Ethernet packet. This procedure is done according to the priority trust mode of the receiving port and the 802.1Q tagging status of the packet, as shown in Figure 3.
Figure 3 Priority mapping process for an Ethernet packet
The switch marks a received MPLS packet with a scheduling priority based on the priority trust mode and the packet EXP value, as shown in Figure 4.
Figure 4 Priority mapping process for an MPLS packet
For information about priority marking, see "Configuring priority marking."
To configure priority mapping, perform the following tasks:
1.     (Optional.) Configuring a priority map
2.     Configuring a priority mapping method:
¡     Configuring a port to trust packet priority for priority mapping
¡     Changing the port priority of an interface
Hardware and feature compatibility
The following matrix shows the compatibility of hardware and this feature:
Hardware
Remarks
·     Fixed Layer 2 Ethernet ports on the following routers:
¡     MSR610
¡     MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-LM-GL, MSR810-W-LM, MSR810-W-LM-GL, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
¡     MSR810-LMS, MSR810-LUS
¡     MSR810-SI, MSR810-LM-SI
¡     MSR810-LMS-EA, MSR810-LME
¡     MSR1004S-5G
¡     MSR2600-6-X1, MSR2600-6-X1-GL, MSR2600-15-X1, MSR2600-15-X1-T
¡     MSR2600-10-X1
¡     MSR3600-28, MSR3600-51, MSR3600-28-SI, MSR3600-28-SI-GL, MSR3600-51-SI
¡     MSR3600-28-X1, MSR3600-28-X1-DP, MSR3600-51-X1, MSR3600-51-X1-DP
¡     MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
¡     MSR810-W-WiNet, MSR810-LM-WiNet
¡     MSR830-4LM-WiNet
¡     MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-6EI-GL, MSR830-10BEI-WiNet, MSR830-10EI-GL
¡     MSR830-6BHI-WiNet, MSR830-6HI-GL, MSR830-10BHI-WiNet, MSR830-10HI-GL
¡     MSR1004S-5G-GL
¡     MSR2600-6-WiNet, MSR2600-10-X1-WiNet
¡     MSR3600-28-WiNet
¡     MSR2630-XS, MSR3600-28-XS, MSR3610-I-XS, MSR3610-IE-XS
·     Layer 2 interface modules installed on routers.
For information about the support of the routers for Layer 2 interface modules, see H3C MSR Router Series Comware 7 Interface Module Guide.
2.     Enter priority map view.
qos map-table { dot11e-lp | dot1p-lp | dscp-lp | lp-dot11e | lp-dot1p | lp-dscp }
3.     Configure mappings for the priority map.
By default, the default priority maps are used. For more information, see "Appendix B Default priority maps."
You can configure the device to trust a particular priority field carried in packets for priority mapping on ports or globally. When you configure the trusted packet priority type on an interface, use the following available keywords:
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
Hardware
Remarks
¡     MSR610
¡     MSR1004S-5G
¡     MSR2600-10-X1
¡     MSR830-4LM-WiNet
¡     MSR1004S-5G-GL
¡     MSR3600-28-WiNet
3.     Configure the trusted packet priority type.
qos trust { dot1p | dscp }
By default, no trusted packet priority type is configured.
The dscp keyword is supported only on the following ports:
Hardware
Keyword and port compatibility
MSR610
Fixed Layer 2 Ethernet ports.
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK.
MSR810-EI, MSR810-LM-EA, MSR810-LM-EI, MSR810-SI, MSR810-LM-SI
MSR2600-6-X1, MSR2600-10-X1
MSR2600-15-X1-T
MSR3600-28, MSR3600-51, MSR3600-28-SI, MSR3600-51-SI
Routers installed with an Ethernet switching module
Layer 2 Ethernet ports on the following modules:
·     HMIM-8GSW.
·     HMIM-8GSWF.
·     HMIM-24GSW.
·     HMIM-24GSW-PoE.
·     SIC-4GSW.
·     SIC-4GSWF.
·     SIC-4GSWP.
For more information about the support of the routers for these modules, see H3C MSR Router Series Comware 7 Interface Module Guide.
4.     Return to system view.
If an interface does not trust any packet priority, the device uses its port priority to look for priority parameters for the incoming packets. By changing port priority, you can prioritize traffic received on different interfaces.
The following matrix shows the compatibility of hardware and port priority:
Hardware
Remarks
¡     MSR610
¡     MSR1004S-5G
¡     MSR2600-10-X1
¡     MSR830-4LM-WiNet
¡     MSR1004S-5G-GL
¡     MSR3600-28-WiNet
3.     Set the port priority of the interface.
qos priority priority-value
The default setting is 0.
Display priority map configuration.
display qos map-table [ dot11e-lp | dot1p-lp | dscp-lp | lp-dot11e | lp-dot1p | lp-dscp ]
Display the trusted packet priority type on a port.
As shown in Figure 5:
·     The 802.1p priority of traffic from Device A to Device C is 3.
·     The 802.1p priority of traffic from Device B to Device C is 1.
Configure Device C to preferentially process packets from Device A to the server when GigabitEthernet 1/0/3 of Device C is congested.
Figure 5 Network diagram
(Method 1) Configure Device C to trust packet priority
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trust the 802.1p priority for priority mapping.
<DeviceC> system-view
[DeviceC-GigabitEthernet1/0/1] qos trust dot1p
[DeviceC-GigabitEthernet1/0/2] qos trust dot1p
(Method 2) Configure Device C to trust port priority
# Assign port priority to GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2. Make sure the following requirements are met:
·     The priority of GigabitEthernet 1/0/1 is higher than that of GigabitEthernet 1/0/2.
·     No trusted packet priority type is configured on GigabitEthernet 1/0/1 or GigabitEthernet 1/0/2.
[DeviceC-GigabitEthernet1/0/1] qos priority 3
[DeviceC-GigabitEthernet1/0/2] qos priority 1
As shown in Figure 6:
·     The Marketing department connects to GigabitEthernet 1/0/1 of Device, which sets the 802.1p priority of traffic from the Marketing department to 3.
·     The R&D department connects to GigabitEthernet 1/0/2 of Device, which sets the 802.1p priority of traffic from the R&D department to 4.
·     The Management department connects to GigabitEthernet 1/0/3 of Device, which sets the 802.1p priority of traffic from the Management department to 5.
Configure port priority, 802.1p-to-local mapping table, and priority marking to implement the plan as described in Table 1.
Table 1 Configuration plan
Traffic destination
Traffic priority order
Queuing plan
Traffic source
Output queue
Queue priority
Public servers
R&D department > Management department > Marketing department
R&D department
6
High
4
Medium
2
Low
Internet
Management department > Marketing department > R&D department
R&D department
2
Low
6
High
4
Medium
Figure 6 Network diagram
1.     Configure trusting port priority:
# Set the port priority of GigabitEthernet 1/0/1 to 3.
[Device-GigabitEthernet1/0/1] qos priority 3
# Set the port priority of GigabitEthernet 1/0/2 to 4.
[Device-GigabitEthernet1/0/2] qos priority 4
# Set the port priority of GigabitEthernet 1/0/3 to 5.
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] qos priority 5
[Device-GigabitEthernet1/0/3] quit
2.     Configure the 802.1p-to-local mapping table to map 802.1p priority values 3, 4, and 5 to local precedence values 2, 6, and 4.
This guarantees the R&D department, Management department, and Marketing department decreased priorities to access the public servers.
[Device-maptbl-dot1p-lp] quit
3.     Configure priority marking to mark the packets from Management department, Marketing department, and R&D department to the Internet with 802.1p priority values 4, 5, and 3.
This guarantees the Management department, Marketing department, and R&D department decreased priorities to access the Internet.
# Create ACL 3000, and configure a rule to match HTTP packets.
[Device] acl advanced 3000
[Device-acl-adv-3000] quit
# Create a traffic class named http, and use ACL 3000 as a match criterion.
[Device-classifier-http] quit
# Create a traffic behavior named admin, and configure a marking action for the Management department.
[Device-behavior-admin] remark dot1p 4
[Device-behavior-admin] quit
# Create a QoS policy named admin, and associate traffic class http with traffic behavior admin in QoS policy admin.
[Device] qos policy admin
[Device-qospolicy-admin] quit
# Apply QoS policy admin to the inbound direction of GigabitEthernet 1/0/3.
[Device-GigabitEthernet1/0/3] qos apply policy admin inbound
# Create a traffic behavior named market, and configure a marking action for the Marketing department.
[Device-behavior-market] remark dot1p 5
[Device-behavior-market] quit
# Create a QoS policy named market, and associate traffic class http with traffic behavior market in QoS policy market.
[Device] qos policy market
[Device-qospolicy-market] classifier http behavior market
# Apply QoS policy market to the inbound direction of GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] qos apply policy market inbound
# Create a traffic behavior named rd, and configure a marking action for the R&D department.
[Device] traffic behavior rd
[Device-behavior-rd] remark dot1p 3
[Device-behavior-rd] quit
# Create a QoS policy named rd, and associate traffic class http with traffic behavior rd in QoS policy rd.
[Device] qos policy rd
[Device-qospolicy-rd] classifier http behavior rd
[Device-qospolicy-rd] quit
# Apply QoS policy rd to the inbound direction of GigabitEthernet 1/0/2.
[Device-GigabitEthernet1/0/2] qos apply policy rd inbound
Traffic limit helps assign network resources (including bandwidth) and increase network performance. For example, you can configure a flow to use only the resources committed to it in a certain time range. This avoids network congestion caused by burst traffic.
Traffic policing, Generic Traffic Shaping (GTS), and rate limit control the traffic rate and resource usage according to traffic specifications. You can use token buckets for evaluating traffic specifications.
Token bucket features
A token bucket is analogous to a container that holds a certain number of tokens. Each token represents a certain forwarding capacity. The system puts tokens into the bucket at a constant rate. When the token bucket is full, the extra tokens cause the token bucket to overflow.
Evaluating traffic with the token bucket
A token bucket mechanism evaluates traffic by looking at the number of tokens in the bucket. If the number of tokens in the bucket is enough for forwarding the packets:
·     The traffic conforms to the specification (called conforming traffic).
·     The corresponding tokens are taken away from the bucket.
Otherwise, the traffic does not conform to the specification (called excess traffic).
A token bucket has the following configurable parameters:
·     Mean rate at which tokens are put into the bucket, which is the permitted average rate of traffic. It is usually set to the committed information rate (CIR).
·     Burst size or the capacity of the token bucket. It is the maximum traffic size permitted in each burst. It is usually set to the committed burst size (CBS). The set burst size must be greater than the maximum packet size.
Each arriving packet is evaluated.
Complicated evaluation
You can set two token buckets, bucket C and bucket E, to evaluate traffic in a more complicated environment and achieve more policing flexibility. The following are main mechanisms used for complicated evaluation:
·     Single rate two color—Uses one token bucket and the following parameters:
¡     CIR—Rate at which tokens are put into bucket C. It sets the average packet transmission or forwarding rate allowed by bucket C.
¡     CBS—Size of bucket C, which specifies the transient burst of traffic that bucket C can forward.
When a packet arrives, the following rules apply:
¡     If bucket C has enough tokens to forward the packet, the packet is colored green.
¡     Otherwise, the packet is colored red.
·     Single rate three color—Uses two token buckets and the following parameters:
¡     EBS—Size of bucket E minus size of bucket C, which specifies the transient burst of traffic that bucket E can forward. The EBS cannot be 0. The size of E bucket is the sum of the CBS and EBS.
¡     If bucket C has enough tokens, the packet is colored green.
¡     If bucket C does not have enough tokens but bucket E has enough tokens, the packet is colored yellow.
¡     If neither bucket C nor bucket E has sufficient tokens, the packet is colored red.
·     Two rate three color—Uses two token buckets and the following parameters:
¡     PIR—Rate at which tokens are put into bucket E, which specifies the average packet transmission or forwarding rate allowed by bucket E.
¡     EBS—Size of bucket E, which specifies the transient burst of traffic that bucket E can forward.
Traffic policing
A typical application of traffic policing is to supervise the specification of traffic entering a network and limit it within a reasonable range. Another application is to "discipline" the extra traffic to prevent aggressive use of network resources by an application. For example, you can limit bandwidth for HTTP packets to less than 50% of the total. If the traffic of a session exceeds the limit, traffic policing can drop the packets or set the precedence of the packets. Figure 7 shows an example of policing outbound traffic on an interface.
Figure 7 Traffic policing
Traffic policing can classify the policed traffic and take predefined policing actions on each packet depending on the evaluation result:
·     Forwarding the packet.
·     Dropping the packet.
·     Forwarding the packet with its precedence re-marked.
·     Delivering the packet to next-level traffic policing with its precedence re-marked.
GTS
GTS limits the traffic rate by buffering exceeding traffic. You can use GTS to adapt the traffic output rate on a device to the input traffic rate of its connected device to avoid packet loss.
The differences between traffic policing and GTS are as follows:
·     Packets to be dropped with traffic policing are retained in a buffer or queue with GTS, as shown in Figure 8. When enough tokens are in the token bucket, the buffered packets are sent at an even rate.
·     GTS can result in additional delay and traffic policing does not.
Figure 8 GTS
For example, in Figure 9, Device B performs traffic policing on packets from Device A and drops packets exceeding the limit. To avoid packet loss, you can perform GTS on the outgoing interface of Device A so that packets exceeding the limit are cached in Device A. Once resources are released, GTS takes out the cached packets and sends them out.
Figure 9 GTS application
Rate limit
The rate limit of an interface specifies the maximum rate for forwarding packets (excluding critical packets).
Rate limit also uses token buckets for traffic control. When rate limit is configured on an interface, a token bucket handles all packets to be sent through the interface for rate limiting. If enough tokens are in the token bucket, packets can be forwarded. Otherwise, packets are put into QoS queues for congestion management. In this way, the traffic passing the interface is controlled.
Figure 10 Rate limit implementation
The token bucket mechanism limits traffic rate when accommodating bursts. It allows bursty traffic to be transmitted if enough tokens are available. If tokens are scarce, packets cannot be transmitted until efficient tokens are generated in the token bucket. It restricts the traffic rate to the rate for generating tokens.
Rate limit controls the total rate of all packets on an interface. It is easier to use than traffic policing in controlling the total traffic rate.
·     MSR810-LMS.
·     MSR810-LUS.
·     MSR810-SI.
·     MSR810-LM-SI.
·     MSR3600-28-SI.
·     MSR3600-28-SI-GL.
·     MSR3600-51-SI.
You can configure traffic policing by using the MQC approach or the non-MQC approach. If both approaches are used, the MQC configuration takes effect.
You can configure the following types of traffic policing by using the non-MQC approach:
·     CAR-list-based traffic policing.
·     ACL-based traffic policing.
·     Traffic policing for all traffic.
·     Traffic policing for a user profile.
·     Traffic policing for a tunnel.
If traffic policing is configured by using both the MQC approach and non-MQC approach, the configuration in MQC approach takes effect.
A traffic policing action takes effect only when a QoS policy is applied to the following application destinations:
·     Interface.
·     PVC.
·     VLANs.
·     Globally.
·     Control plane.
·     Control-plane management view.
·     User profile.
2.     (Optional.) Execute the following command in sequence to set the packet compensation length for outbound traffic policing:
a.     interface interface-type interface-number
b.     qos overhead compensation-length length
c.     quit
This function takes effect only outgoing IPsec P2MP tunnel traffic.
3.     Define a traffic class.
a.     Create a traffic class and enter traffic class view.
For more information about the if-match command, see ACL and QoS Command Reference.
4.     Define a traffic behavior.
a.     Create a traffic behavior and enter traffic behavior view.
b.     Configure a traffic policing action.
¡     In absolute value:
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
¡     In percentage:
car cir percent cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ green action | red action | yellow action ] *
car cir percent cir-percent [ cbs cbs-time ] pir percent pir-percent [ ebs ebs-time ] [ green action | red action | yellow action ] *
By default, no traffic policing action is configured.
5.     Define a QoS policy.
a.     Create a QoS policy and enter QoS policy view.
b.     Associate the traffic class with the traffic behavior in the QoS policy.
6.     Apply the QoS policy.
For more information, see "Applying the QoS policy."
By default, no QoS policy is applied.
2.     Configure a CAR list.
qos carl carl-index { dscp dscp-list | mac mac-address | mpls-exp mpls-exp-value | precedence precedence-value | { destination-ip-address | source-ip-address } { range start-ip-address to end-ip-address | subnet ip-address mask-length } [ per-address [ shared-bandwidth ] ] }
Support for the object-group object-group-name and time-range time-range-name options depends on the device model. For more information, see the command reference.
3.     Enter interface view.
4.     (Optional.) Set the packet compensation length for outbound traffic policing.
By default, the packet compensation length is not set for outbound traffic policing.
5.     Apply a CAR-list-based CAR policy to the interface.
qos car { inbound | outbound } carl carl-index cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } carl carl-index cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
¡     In percentage:
qos car { inbound | outbound } carl carl-index percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } carl carl-index percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ] [ green action | red action | yellow action ] *
By default, no CAR policy is applied to an interface.
Dynamic traffic policing allows you to dynamically adjust the bandwidth allowed per IP address on an interface to improve bandwidth usage.
When the following conditions exist, the dynamic traffic policing feature is activated on an interface:
·     The per-address parameter is specified in the CAR list.
·     Only one CAR policy is applied to the same direction of an interface, and the max-cir parameter is specified.
The traffic on an interface can be classified as traffic subject to traffic policing and traffic not subject to traffic policing. The dynamic traffic policing feature updates the allowed CIR for each IP address at the interval configured in the qos car bandwidth-refresh-interval command.
·     If the traffic rate does not exceed the maximum bandwidth threshold and the updated CIR is smaller than the maximum CIR, the updated CIR applies.
·     If the traffic rate exceeds the maximum bandwidth threshold or the updated CIR is greater than the maximum CIR, the CIR remains unchanged.
·     If a new flow is added on the interface, the new flow receives the same allowed CIR as other flows.
qos carl carl-index { destination-ip-address | source-ip-address } { object-group object-group-name | range start-ip-address to end-ip-address | subnet ip-address mask-length } per-address [ shared-bandwidth ] [ time-range time-range-name ]
3.     (Optional.) Set the bandwidth update interval.
qos car bandwidth-refresh-interval interval
The default setting is 600 seconds.
4.     Enter interface view.
5.     (Optional.) Set the packet compensation length for outbound traffic policing.
6.     (Optional.) Set the maximum bandwidth threshold in percentage.
qos car bandwidth-utilization-threshold high-percent
The default setting is 80%.
7.     Apply a CAR-list-based CAR policy to the interface.
qos car { inbound | outbound } carl carl-index cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] max-cir max-committed-information-rate [ green action | red action | yellow action ] *
3.     (Optional.) Set the packet compensation length for outbound traffic policing.
4.     Configure an ACL-based CAR policy on the interface.
qos car { inbound | outbound } acl [ ipv6 ] acl-number cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } acl [ ipv6 ] acl-number cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
¡     In percentage:
qos car { inbound | outbound } acl [ ipv6 ] acl-number percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } acl [ ipv6 ] acl-number percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ] [ green action | red action | yellow action ] *
By default, no CAR policy is configured on an interface.
4.     Configure a CAR policy for all traffic on the interface.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
¡     In percentage:
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ] [ green action | red action | yellow action ] *
When a user profile is configured, you can perform traffic policing based on users. After a user passes authentication, the authentication server sends the name of the user profile associated with the user to the device. When any user of the user profile logs in, the authentication server automatically applies the CAR parameters configured for the user profile to the user. When the user logs off, the system automatically removes the CAR configuration without manual intervention.
3.     Configure a CAR policy for the user profile.
By default, no CAR policy is configured for a user profile.
After an IPsec P2MP tunnel is set up, the application module can authorize a user profile to the tunnel to police the traffic of the tunnel. You can also configure packet compensation in the user profile to achieve more accurate traffic policing.
Packet compensation compensates for the stripped packet header in policing traffic. The packet compensation configuration also takes effect on traffic policing statistics.
As shown in Figure 11, traffic policing is configured on Device A:
·     For inbound traffic policing, the device has obtained the link layer header length when decapsulating an incoming tunnel packet. Therefore, the traffic policing result is accurate, and you do not need to configure packet compensation.
·     For outbound traffic policing, the device has not obtained the link layer header length when policing traffic. To ensure accurate traffic policing, you can configure packet compensation.
Figure 11 Tunnel-based traffic policing
The packet compensation configuration takes effect only on outbound traffic.
4.     Configure a CAR policy for the user profile.
qos car { inbound | outbound } { acl [ ipv6 ] acl-number | any } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } { acl [ ipv6 ] acl-number | any } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
Configuring GTS
You can configure GTS by using either the MQC approach or non-MQC approach.
You can configure the following types of GTS by using the non-MQC approach:
·     ACL-based GTS.
·     GTS for all traffic.
If GTS is configured by using both the MQC approach and non-MQC approach, the configuration in MQC approach takes effect.
The device supports the following application destinations for GTS:
·     Interface.
·     PVC.
·     Control plane.
·     User profile.
2.     Define a traffic class.
For configurable match criteria, see the if-match command in ACL and QoS Command Reference.
3.     Define a traffic behavior.
b.     Configure a GTS action.
-     In absolute value:
gts cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
-     In percentage:
gts percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ queue-length queue-length ]
By default, no GTS action is configured.
4.     Define a QoS policy.
b.     Associate the class with the traffic behavior in the QoS policy.
5.     Apply the QoS policy.
ACL-based GTS takes effect only on outbound traffic.
Prodecure
3.     Configure ACL-based GTS on the interface.
qos gts acl [ ipv6 ] acl-number cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts acl [ ipv6 ] acl-number cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
By default, GTS is not configured on an interface.
GTS for all traffic takes effect only on outbound traffic.
Prodecure
3.     Configure GTS on the interface.
qos gts any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
3.     Configure the rate limit for the interface.
qos lr { inbound | outbound } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
Support for the inbound keyword depends on the device model. For more information, see the command reference.
By default, no rate limit is configured on an interface.
2.     Enter PW view.
¡     Execute the following commands in sequence to enter cross-connect PW view:
xconnect-group group-name
connection connection-name
peer ip-address pw-id pw-id [ in-label label-value out-label label-value ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
¡     Execute the following commands in sequence to enter VSI LDP PW view:
vsi vsi-name [ hub-spoke ]
pwsignaling ldp
peer ip-address [ pw-id pw-id ] [ hub | no-split-horizon ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
¡     Execute the following commands in sequence to enter VSI static PW view:
pwsignaling static
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * ]
3.     Configure the rate limit for the PW.
By default, no rate limit is configured for a PW.
By default, the device calculates the packet length for rate limiting based on the data link layer frame. This feature allows the device to include a 24-byte physical layer header in calculating the packet length for rate limiting.
Hardware
Feature compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
No
No
No
MSR1004S-5G
No
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
No
MSR 2630
No
No
No
No
MSR3600-28-G-DP, MSR3600-51-G-DP
No
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
No
MSR3640-X1-HI
Yes
Hardware
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
This feature takes effect only on Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces.
2.     Include the physical layer header in calculating the packet length for rate limiting.
qos overhead layer physical
Display CAR configuration and statistics on an interface.
display qos car interface [ interface-type interface-number ]
Display CAR list information.
In standalone mode:
display qos carl [ carl-index ]
In IRF mode:
display qos carl [ carl-index ] [ slot slot-number ]
Display GTS configuration and statistics for interfaces.
Display rate limit configuration and statistics.
display qos lr { interface [ interface-type interface-number ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
In standalone mode:
display traffic behavior user-defined [ behavior-name ]
In IRF mode:
Network requirements
As shown in Figure 12:
·     The server, Host A, and Host B can access the Internet through Device A and Device B.
·     The server, Host A, and GigabitEthernet 1/0/1 of Device A are in the same network segment.
·     Host B and GigabitEthernet 1/0/2 of Device A are in the same network segment.
Perform traffic control for the packets that GigabitEthernet 1/0/1 of Device A receives from the server and Host A using the following guidelines:
·     Limit the rate of packets from the server to 10240 kbps. When the traffic rate is below 10240 kbps, the traffic is forwarded. When the traffic rate exceeds 10240 kbps, the excess packets are marked with DSCP value 0 and then forwarded.
·     Limit the rate of packets from Host A to 2560 kbps. When the traffic rate is below 2560 kbps, the traffic is forwarded. When the traffic rate exceeds 2560 kbps, the excess packets are dropped.
Perform traffic control on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 of Device B using the following guidelines:
·     Limit the incoming traffic rate on GigabitEthernet 1/0/1 to 20480 kbps, and the excess packets are dropped.
·     Limit the outgoing traffic rate on GigabitEthernet 1/0/2 to 10240 kbps, and the excess packets are dropped.
Figure 12 Network diagram
1.     Configure Device A:
# Configure ACL 2001 and ACL 2002 to permit the packets from the server and Host A, respectively.
[DeviceA] acl basic 2001
[DeviceA-acl-ipv4-basic-2001] rule permit source 1.1.1.1 0
[DeviceA] acl basic 2002
[DeviceA-acl-ipv4-basic-2002] rule permit source 1.1.1.2 0
[DeviceA-acl-ipv4-basic-2002] quit
# Create a traffic class named server, and use ACL 2001 as the match criterion.
[DeviceA] traffic classifier server
[DeviceA-classifier-server] if-match acl 2001
[DeviceA-classifier-server] quit
# Create a traffic class named host, and use ACL 2002 as the match criterion.
[DeviceA] traffic classifier host
[DeviceA-classifier-host] if-match acl 2002
[DeviceA-classifier-host] quit
# Create a traffic behavior named server, and configure a traffic policing action (CIR 10240 kbps).
[DeviceA] traffic behavior server
[DeviceA-behavior-server] car cir 10240 red remark-dscp-pass 0
[DeviceA-behavior-server] quit
# Create a traffic behavior named host, and configure a traffic policing action (CIR 2560 kbps).
[DeviceA] traffic behavior host
[DeviceA-behavior-host] car cir 2560
[DeviceA-behavior-host] quit
# Create a QoS policy named car, and associate traffic classes server and host with traffic behaviors server and host in QoS policy car, respectively.
[DeviceA] qos policy car
[DeviceA-qospolicy-car] classifier server behavior server
[DeviceA-qospolicy-car] classifier host behavior host
[DeviceA-qospolicy-car] quit
# Apply QoS policy car to the inbound direction of GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] qos apply policy car inbound
2.     Configure Device B:
# Create ACL 3001, and configure a rule to match HTTP packets.
[DeviceB] acl advanced 3001
[DeviceB-acl-adv-3001] rule permit tcp destination-port eq 80
[DeviceB-acl-adv-3001] quit
# Create a traffic class named http, and use ACL 3001 as a match criterion.
[DeviceB] traffic classifier http
[DeviceB-classifier-http] if-match acl 3001
[DeviceB-classifier-http] quit
# Create a traffic class named class, and configure the traffic class to match all packets.
[DeviceB] traffic classifier class
[DeviceB-classifier-class] if-match any
[DeviceB-classifier-class] quit
# Create a traffic behavior named car_inbound, and configure a traffic policing action (CIR 20480 kbps).
[DeviceB] traffic behavior car_inbound
[DeviceB-behavior-car_inbound] car cir 20480
[DeviceB-behavior-car_inbound] quit
# Create a traffic behavior named car_outbound, and configure a traffic policing action (CIR 10240 kbps).
[DeviceB] traffic behavior car_outbound
[DeviceB-behavior-car_outbound] car cir 10240
[DeviceB-behavior-car_outbound] quit
# Create a QoS policy named car_inbound, and associate traffic class class with traffic behavior car_inbound in QoS policy car_inbound.
[DeviceB] qos policy car_inbound
[DeviceB-qospolicy-car_inbound] classifier class behavior car_inbound
[DeviceB-qospolicy-car_inbound] quit
# Create a QoS policy named car_outbound, and associate traffic class http with traffic behavior car_outbound in QoS policy car_outbound.
[DeviceB] qos policy car_outbound
[DeviceB-qospolicy-car_outbound] classifier http behavior car_outbound
[DeviceB-qospolicy-car_outbound] quit
# Apply QoS policy car_inbound to the inbound direction of GigabitEthernet 1/0/1.
[DeviceB-GigabitEthernet1/0/1] qos apply policy car_inbound inbound
# Apply QoS policy car_outbound to the outbound direction of GigabitEthernet 1/0/2.
[DeviceB-GigabitEthernet1/0/2] qos apply policy car_outbound outbound
Example: Configuring per-IP-address traffic policing
As shown in Figure 13, configure a CAR-list-based CAR policy on GigabitEthernet 1/0/2 to meet the following requirements:
·     Limit the rate of incoming packets from each IP address in the range of 2.1.1.1 to 2.1.1.100 to 5 kbps.
·     Allow all IP addresses in the range to share the remaining bandwidth.
Figure 13 Network diagram
# Configure per-IP-address rate limiting on GigabitEthernet 1/0/2 to meet the following requirements:
·     Limit the rate of each host on the network segment 2.1.1.1 through 2.1.1.100.
·     Allow all IP addresses in the network segment to share the remaining bandwidth.
[Device] qos carl 1 source-ip-address range 2.1.1.1 to 2.1.1.100 per-address shared-bandwidth
[Device-GigabitEthernet1/0/2] qos car inbound carl 1 cir 500 cbs 1875 ebs 0 green pass red discard
Configuring congestion management
About congestion management
Cause, negative results, and countermeasure of congestion
Congestion occurs on a link or node when traffic size exceeds the processing capability of the link or node. It is typical of a statistical multiplexing network and can be caused by link failures, insufficient resources, and various other causes. Figure 14 shows common congestion scenarios.
Figure 14 Traffic congestion causes
Congestion can introduce the following negative results:
·     Increased delay and jitter during packet transmission.
·     Decreased network throughput and resource use efficiency.
·     Network resource (memory, in particular) exhaustion and system breakdown.
Congestion is unavoidable in switched networks or multiuser application environments. To improve the service performance of your network, implement congestion management policies.
For example, congestion management defines a resource dispatching policy to prioritize packets for forwarding when congestion occurs.
Congestion management methods
Congestion management involves queue creating, traffic classification, packet enqueuing, and queue scheduling.
Queuing is a common congestion management technique. It classifies traffic into queues and picks out packets from each queue by using an algorithm. Various queuing algorithms are available, and each addresses a particular network traffic problem. Your choice of algorithm significantly affects bandwidth assignment, delay, and jitter.
The device supports the following queuing mechanisms:
·     FIFO.
·     PQ.
·     CQ.
·     WFQ.
·     CBQ.
·     RTPQ.
FIFO
Figure 15 FIFO queuing
As shown in Figure 15, the first in first out (FIFO) uses a single queue and does not classify traffic or schedule queues. FIFO delivers packets in their arrival order. The packet that arrives earlier is scheduled first. The only concern of FIFO is queue length, which affects delay and packet loss rate. On a device, resources are assigned to packets depending on their arrival order and load status of the device. The best-effort service model uses FIFO queuing.
FIFO does not address congestion problems. If only one FIFO output/input queue exists on a port, you cannot ensure timely delivery of mission-critical or delay-sensitive traffic or smooth traffic jitter. If malicious traffic occupies bandwidth aggressively, the problems increase. To control congestion and prioritize forwarding of critical traffic, use other queue scheduling mechanisms, where multiple queues can be configured. Within each queue, FIFO is still used.
PQ
Figure 16 Priority queuing (PQ)
PQ is designed for mission-critical applications. Mission-critical applications require preferential treatment to reduce the response delay when congestion occurs. PQ can flexibly determine the order of forwarding packets by network protocol (for example, IP and IPX), incoming interface, packet length, source/destination address, and so on. Priority queuing classifies packets into four queues (top, middle, normal, and bottom queues, in descending priority order). By default, packets are assigned to the normal queue. Each of the four queues is a FIFO queue.
PQ schedules the four queues in descending order of priority. It sends packets in the queue with the highest priority first. When the queue with the highest priority is empty, it sends packets in the queue with the second highest priority. To make sure mission-critical packets are always served first, assign the mission-critical packets to the highest-priority queue. The common service packets that are assigned to the low-priority queues are transmitted when the high-priority queues are empty.
However, packets in the lower-priority queues cannot be transmitted when congestion occurs if packets exist in the higher-priority queues for a long time.
CQ
Figure 17 Custom queuing (CQ)
CQ provides 16 queues, numbered from 1 to 16, as shown in Figure 17. You can define traffic classification rules and divide bandwidth across queues by specifying the byte count for each queue.
During a cycle of queue scheduling, CQ schedules the 16 queues in a round robin way. It sends a certain number of bytes out of each queue in the ascending order of queue 1 to queue 16. CQ guarantees a certain amount of bandwidth to common packets, and ensures that mission-critical packets are assigned more bandwidth. The bandwidth ratio for each queue is the byte count configured for that queue divided by the total byte count configured for all queues.
CQ can assign free bandwidth of idle queues to busy queues. Even though it performs round robin queue scheduling, CQ does not assign fixed time slots to the queues. If a queue is empty, CQ immediately moves to the next queue. When a class does not have packets, the bandwidth for other classes increases.
WFQ
Figure 18 Weighted fair queuing (WFQ)
FQ is designed to equally allocate network resources to reduce the delay and jitter of each traffic flow as much as possible. FQ follows these principles:
·     Different queues have fair dispatching opportunities for delay balancing among flows.
·     Short packets and long packets are equally scheduled. If long packets and short packets exist in queues, statistically the short packets are scheduled preferentially to reduce the jitter between packets.
WFQ considers weights when determining the queue scheduling order. Statistically, WFQ gives high-priority traffic more scheduling opportunities than low-priority traffic. To balance the delay of every traffic flow, WFQ performs the following operations:
·     Automatically classifies traffic according to the "session" information of traffic.
·     Attempts to provide as many queues as possible for traffic flows.
The session information of traffic includes the following information:
·     Protocol type.
·     TCP or UDP source/destination port numbers.
·     Source/destination IP addresses.
·     IP precedence bits in the ToS field.
When dequeuing packets, WFQ assigns the outgoing interface bandwidth to each traffic flow by precedence. The higher precedence value a traffic flow has, the more bandwidth it gets.
For example, five flows exist in the current interface with precedence 0, 1, 2, 3, and 4, respectively. The total bandwidth quota is the sum of all the (precedence value + 1)s, 1 + 2 + 3 + 4 + 5 = 15.
The bandwidth percentage assigned to each flow is (precedence value of the flow + 1)/total bandwidth quota. The bandwidth percentages for flows are 1/15, 2/15, 3/15, 4/15, and 5/15, respectively.
Because WFQ can balance the delay and jitter of each flow when congestion occurs, it is suitable for handling special situations. For example, WFQ is used in the assured forwarding (AF) services of the RSVP, and WFQ is used to schedule buffered packets in GTS.
CBQ
Figure 19 CBQ
Class-based queuing (CBQ) extends WFQ by supporting user-defined classes. When network congestion occurs, CBQ uses user-defined traffic match criteria to enqueue packets. Before packets are enqueued, congestion avoidance actions, such as tail drop or WRED and bandwidth restriction check, are performed. When being dequeued, packets are scheduled by WFQ.
CBQ provides the following queues:
·     Emergency queue—Enqueues emergent packets. The emergency queue is a FIFO queue without bandwidth restriction.
·     Strict priority (SP) queuing—SP queuing is designed for mission-critical applications. Mission-critical applications require preferential treatment to reduce the response delay when congestion occurs. With SP queuing, CBQ can provide strict priority service. A maximum of 64 SP queues are supported.
·     Low Latency Queuing (LLQ)—An EF queue. Because packets are fairly treated in CBQ, delay-sensitive flows like video and voice packets might not be transmitted timely. To solve this problem, LLQ combines PQ and CBQ to preferentially transmit delay-sensitive flows like voice packets. When defining traffic classes for LLQ, you can configure a class of packets to be preferentially transmitted. The packets of all priority classes are assigned to the same priority queue. Bandwidth restriction on each class of packets is checked before the packets are enqueued. During the dequeuing operation, packets in the priority queue are transmitted first. To reduce the delay of the other queues except the priority queue, LLQ assigns the maximum available bandwidth to each priority class. The bandwidth value polices traffic during congestion. When no congestion is present, a priority class can use more than the bandwidth assigned to it. During congestion, the packets of each priority class exceeding the assigned bandwidth are discarded.
·     Bandwidth queuing (BQ)—An AF queue. The BQ provides guaranteed bandwidth for AF traffic, and schedules the AF classes proportionally. The system supports up to 64 AF queues.
·     Default queue—A WFQ queue. The default queue transmits the BE traffic by using the remaining interface bandwidth.
The system matches packets with classification rules in the following order:
·     Match packets with priority classes and then the other classes.
·     Match packets with priority classes in the configuration order.
·     Match packets with other classes in the configuration order.
·     Match packets with classification rules in a class in the configuration order.
RTPQ
RTP queuing (RTPQ) is designed for delay-sensitive, real-time traffic (such as voice and video). You can assign voice or video packets to a high-priority queue by specifying a UDP port range as the match criterion. These packets are given strict priority service and are sent before packets in other queues are sent.
Figure 20 RTPQ
Congestion management technique comparison
Congestion management techniques offer different QoS capabilities to meet different application requirements, as explained in Table 2.
Table 2 Congestion management technique comparison
Number of queues
Advantages
Disadvantages
FIFO
1
·     No need to configure, easy to use.
·     Easy to operate, low delay.
·     All packets are treated equally. The available bandwidth, delay and drop probability are determined by the arrival order of packets.
·     No restriction on traffic from connectionless protocols (protocols without any flow control mechanism, UDP, for example). This problem results in bandwidth loss for traffic of connection-oriented protocols (TCP, for example).
·     No delay guarantee for time-sensitive real-time applications, such as VoIP.
PQ
4
Provides strict priority service for mission-critical applications and guarantees low delay for real-time traffic, such as voice traffic.
·     Need to configure, low processing speed.
·     If packets always exist in high-priority queues, packets in low-priority queues cannot be sent.
CQ
16
·     Bandwidth assignment in percentages for different applications.
·     Bandwidth reassignment to increase bandwidth for each class when packets of certain classes are not present.
WFQ
Configurable
·     Easy to configure.
·     Bandwidth guarantee for packets from cooperative (interactive) sources (such as TCP packets).
·     Reduces jitter.
·     Reduces the delay for interactive applications with a small amount of data.
·     Bandwidth assignment based on traffic priority.
·     Automatic bandwidth reassignment to increase bandwidth for each class when the number of traffic classes decreases.
The processing speed is slower than FIFO.
CBQ
Configurable (0 to 64)
·     Flexible traffic classification based on rules and differentiated queue scheduling mechanisms for EF, AF and BE services.
·     Highly precise bandwidth guarantee and queue scheduling on the basis of AF service weights for various AF services.
·     Absolute preferential queue scheduling for the EF service to meet the delay requirement of real-time data.
·     Overcomes the PQ disadvantage where some low-priority queues are not serviced by restricting the high-priority traffic.
·     WFQ scheduling for best-effort traffic (the default class).
The system overheads are large.
RTPQ
1
·     Provides preferential treatment for real-time applications.
·     Performs traffic policing before enqueuing packets to prevent other queues from being starved.
Applicable only to delay-sensitive applications, such as voice and video.
Restrictions: Hardware compatibility with congestion management
Support for ATM interfaces depends on the device model. For more information, see the installation guide and interface module manual of the device.
PWs are not supported on the following routers:
·     MSR810-LMS.
·     MSR810-LUS.
·     MSR810-SI.
·     MSR810-LM-SI.
·     MSR3600-28-SI.
·     MSR3600-28-SI-GL.
·     MSR3600-51-SI.
Setting the FIFO queue size
FIFO is the default queue scheduling mechanism for an interface, and the FIFO queue size is configurable. Queue length can affect delay and packet loss ratio.
Setting the FIFO queue size for an interface
For the FIFO queuing feature to take effect on a subinterface, you must configure the rate limit on the subinterface.
2.     Enter interface view.
3.     Set the FIFO queue size for the interface.
qos fifo queue-length queue-length
The default setting is 75.
If the burst traffic is too heavy, increase the queue length to make queue scheduling more accurate.
Setting the FIFO queue size for a PVC
2.     Execute the following commands in sequence to enter PVC view:
interface atm interface-number
pvc vpi/vci
3.     Set the FIFO queue size for the PVC.
Setting the FIFO queue size for a PW
2.     Enter PW view.
pwsignaling ldp
pwsignaling static
3.     Set the FIFO queue size for the PW.
Configuring PQ
About configuring PQ
You can define a set of assignment rules in a PQ list and then apply the PQ list to an interface or PVC. An assignment rule assigns a packet that meets a specific match criterion to a queue.
When a packet arrives, it is examined against match criteria in their configuration order.
·     When a match is found, the packet is assigned to the corresponding queue, and the matching process ends.
·     If no match is found, the packet is assigned to the default queue.
·     You must configure the rate limit for the PQ feature to take effect on the following interfaces:
¡     Tunnel interfaces.
¡     Subinterfaces.
¡     Layer 3 aggregate interfaces.
¡     HDLC link bundle interfaces.
¡     VT and dialer interfaces configured with PPPoE, PPPoA, PPPoEoA, PPPoFR, or MPoFR. (To configure MPoFR, make sure the Frame Relay interface in MPoFR is not enabled with FRTS.)
For information about the rate limit function, see "Configuring the rate limit."
·     If you apply multiple PQ lists to an interface or PVC, the PQ list last applied takes effect.
Configuring PQ for an interface
2.     Configure a PQ list.
¡     Configure a protocol-based PQ list.
qos pql pql-index protocol { ip | ipv6 } [ queue-key key-value ] queue { bottom | middle | normal | top }
¡     Configure an interface-based PQ list.
qos pql pql-index inbound-interface interface-type interface-number queue { bottom | middle | normal | top }
¡     Configure a local-precedence-based PQ list.
qos pql pql-index local-precedence local-precedence-list queue { bottom | middle | normal | top }
¡     Configure an MPLS-EXP-based PQ list.
qos pql pql-index protocol mpls exp exp-list queue { bottom | middle | normal | top }
3.     (Optional.) Configure a queue as the default queue for the PQ list.
qos pql pql-index default-queue { bottom | middle | normal | top }
By default, the normal queue is the default queue.
The default queue enqueues packets that do not match any criteria in a PQ list.
4.     (Optional.) Set the maximum queue length for a queue in the PQ list.
qos pql pql-index queue { bottom | middle | normal | top } queue-length queue-length
By default:
¡     The maximum top queue length is 20.
¡     The maximum middle queue length is 40.
¡     The maximum normal queue length is 60.
¡     The maximum bottom queue length is 80.
5.     Enter interface view.
6.     Apply the PQ list to the interface.
qos pq pql pql-index
By default, FIFO is used.
Configuring PQ for a PVC
By default:
5.     Execute the following commands in sequence to enter PVC view:
pvc vpi/vci
6.     Apply the PQ list to the PVC.
Example: Configuring PQ
As shown in Figure 21, both the server and Host A send data to Host B through Device A. The server sends critical packets, and Host A sends non-critical packets.
Configure PQ on GigabitEthernet 1/0/2 of Device A, so that the critical packets from the server are transmitted preferentially when congestion occurs.
Figure 21 Network diagram
# Configure two ACLs to match packets from the server and Host A.
# Configure a PQ list to assign the packets from the server to the top queue when congestion occurs.
[DeviceA] qos pql 1 protocol ip acl 2001 queue top
# Configure a PQ list to assign the packets from Host A to the bottom queue when congestion occurs.
[DeviceA] qos pql 1 protocol ip acl 2002 queue bottom
# Set the maximum queue size of the top queue to 50 and that of the bottom queue to 100 in the PQ list.
[DeviceA] qos pql 1 queue top queue-length 50
[DeviceA] qos pql 1 queue bottom queue-length 100
# Apply PQ list 1 to GigabitEthernet 1/0/2.
[DeviceA-GigabitEthernet1/0/2] qos pq pql 1
Configuring CQ
About configuring CQ
You can configure a CQ list that contains up to 16 queues. The CQ list specifies the following information:
·     The queue where a packet is placed in.
·     The maximum length of each queue.
·     The number of bytes sent from the queue during a cycle of round robin scheduling.
·     If you apply multiple CQ lists to an interface or PVC, the CQ list last applied takes effect.
·     You must configure the rate limit for the CQ feature to take effect on the following interfaces:
¡     Subinterfaces.
Configuring CQ for an interface
2.     Configure a CQ list.
¡     Configure a protocol-based CQ list.
qos cql cql-index protocol { ip | ipv6 } [ queue-key key-value ] queue queue-id
qos cql cql-index inbound-interface interface-type interface-number queue queue-id
¡     Configure a local-precedence-based CQ list.
qos cql cql-index local-precedence local-precedence-list queue queue-id
¡     Configure an MPLS-EXP-based CQ list.
qos cql cql-index protocol mpls exp exp-list queue queue-id
3.     (Optional.) Configure a queue as the default queue for the CQ list.
qos cql cql-index default-queue queue-id
By default, queue 1 is the default queue.
The default queue enqueues packets that do not match any criteria in a CQ list.
4.     (Optional.) Set the maximum length of a queue in the CQ list.
qos cql cql-index queue queue-id queue-length queue-length
The default setting is 20.
5.     (Optional.) Configure the number of bytes sent from a queue during a cycle of round robin scheduling in the CQ list.
qos cql cql-index queue queue-id serving byte-count
The default setting is 1500 bytes.
6.     Enter interface view.
7.     Apply the CQ list to the interface.
qos cq cql cql-index
Configuring CQ for a PVC
¡     Configure an interface-based CQ list.
6.     Execute the following commands in sequence to enter PVC view:
pvc vpi/vci
7.     Apply the CQ list to the PVC.
Configuring WFQ
¡     Subinterfaces.
·     On an interface or PVC that is not enabled with WFQ, the qos wfq command can enable WFQ and configure WFQ-related parameters. If WFQ has been enabled for the interface or PVC, the qos wfq command can modify the WFQ-related parameters.
Configuring WFQ for an interface
3.     Configure WFQ for the interface.
qos wfq [ dscp | precedence ] [ queue-length max-queue-length | queue-number total-queue-number ] *
By default, WFQ is not configured for an interface.
Configuring WFQ for a PVC
pvc vpi/vci
3.     Configure WFQ for the PVC.
By default, WFQ is not configured for a PVC.
Configuring WFQ for a PW
2.     Enter PW view.
pwsignaling ldp
pwsignaling static
3.     Configure WFQ for the PW.
By default, WFQ is not configured for a PW.
Configuring CBQ
About CBQ
The system predefines the following classes, traffic behaviors, and policies:
Predefined classes
The system predefines some classes and defines general rules for the classes. You can use the following predefined classes when defining a policy:
·     default-class—Matches the default traffic.
·     ef, af1, af2, af3, af4—Matches IP DSCP value ef, af1, af2, af3, af4, respectively.
·     ip-prec0, ip-prec1, …ip-prec7—Matches IP precedence value 0, 1, …7, respectively.
·     mpls-exp0, mpls-exp1, …mpls-exp7—Matches MPLS EXP value 0, 1, …7, respectively.
Predefined traffic behaviors
The system predefines some traffic behaviors and defines QoS features for the behaviors.
·     ef—Assigns a class of packets to the EF queue and assigns 20% of the available interface or PVC bandwidth to the class of packets.
·     af—Assigns a class of packets to the AF queue and assigns 20% of the available interface or PVC bandwidth to the class of packets.
·     be—Defines no features.
·     be-flow-based—Assigns a class of packets to a WFQ queue and specifies the drop policy as WRED. By default, 256 WFQ queues exist, and WRED is an IP precedence-based drop policy.
Predefined QoS policy
The system predefines a QoS policy, specifies a predefined class for the policy and associates a predefined behavior with the class. The policy is named default, with the default CBQ action.
The policy default is defined as follows:
·     Associates the predefined class ef with the predefined traffic behavior ef.
·     Associates predefined classes af1 through af4 with the predefined traffic behavior af.
·     Associates the predefined class default-class with the predefined traffic behavior be.
Restrictions and guidelines for CBQ configuration
When you configure CBQ, follow these restrictions and guidelines:
·     Only one of the following queuing actions can be configured in the same behavior:
¡     AF.
¡     EF.
¡     SP.
¡     WFQ.
·     To configure queue af for multiple classes of a policy, you must configure them in one of the following units:
¡     Bandwidth in kbps.
¡     Percentage of the available bandwidth.
¡     Percentage of the remaining bandwidth.
·     In a QoS policy, if AF is configured in percentage of the remaining bandwidth, EF can be configured in absolute value or in percentage.
·     In a QoS policy, if AF is configured in absolute value or in percentage, EF can be configured in absolute value or in percentage.
·     You must configure the rate limit on a subinterface for the CBQ feature to take effect on the subinterface.
·     The default class cannot be associated with a traffic behavior including EF or SP.
·     You can associate the traffic behavior that contains a WFQ action only with the default class.
·     RTPQ and CBQ are mutually exclusive. CBQ can use LLQ to provide priority service for real-time traffic.
Configure AF and the minimum guaranteed bandwidth
·     The undo queue af command also cancels the queue-length command configuration and all WRED-related settings.
·     The wred and queue-length commands are mutually exclusive in a traffic behavior.
·     The undo wred [ dscp | ip-precedence ] command also cancels all other WRED-related settings.
·     A QoS policy that contains an AF action can be applied to the outbound direction of an interface or the inbound direction for a user profile. To modify a QoS policy applied to a user profile, follow these steps:
a.     Remove the QoS policy from the user profile.
b.     Configure a new QoS policy.
c.     Apply the new QoS policy to the user profile.
b.     Configure a match criterion.
if-match [ not ] match-criteria
By default, no match criterion is configured.
For more information about configuring match criteria, see ACL and QoS Command Reference.
c.     Return to system view.
b.     Configure AF and the minimum guaranteed bandwidth.
queue af bandwidth { bandwidth | pct percentage | remaining-pct remaining-percentage }
By default, AF is not configured.
c.     (Optional.) Set the maximum queue size.
The default setting is 64 packets.
d.      Enable WRED.
By default, WRED is not enabled.
e.     Set the exponent for WRED to calculate the average queue size.
wred weighting-constant exponent
The default setting is 9.
f.     Set the lower limit, upper limit, and drop probability denominator for a DSCP value in WRED
wred dscp dscp-value low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
By default, the lower limit is 10, the upper limit is 30, and the drop probability denominator is 10.
You must enable DSCP-based WRED by using the wred dscp command before you configure this command.
g.     Set the lower limit, upper limit, and drop probability denominator for an IP precedence in WRED.
wred ip-precedence precedence low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
h.     Return to system view.
qos policy policy-name
b.     Associate a traffic behavior with a class in the policy.
classifier classifier-name behavior behavior-name
By default, a class is not associated with a behavior.
Configuring EF and the maximum bandwidth
A QoS policy that contains an EF action can be applied to the outbound direction of an interface or the inbound direction for a user profile. To modify a QoS policy applied to a user profile, follow these steps:
1.     Remove the QoS policy from the user profile.
2.     Configure a new QoS policy.
3.     Apply the new QoS policy to the user profile.
b.     Configure EF and the maximum bandwidth.
queue ef bandwidth { bandwidth [ cbs burst ] | pct percentage [ cbs-ratio ratio] }
By default, EF is not configured.
Configuring SP
A QoS policy that contains an SP action can be applied to the outbound direction of an interface or the inbound direction for a user profile. To modify a QoS policy applied to a user profile, follow these steps:
b.     Configure SP.
queue sp
By default, SP is not configured.
Configuring WFQ
·     The undo queue wfq command also cancels the queue-length command configuration and all WRED-related settings.
·     A QoS policy that contains a WFQ action can be applied to the outbound direction of an interface or the inbound direction for a user profile. To modify a QoS policy applied to a user profile, follow these steps:
b.     Configure WFQ.
queue wfq [ queue-number total-queue-number ]
By default, WFQ is not configured.
c.     Set the maximum queue size.
d.     Enable WRED.
Setting the maximum available interface bandwidth
·     The maximum available interface bandwidth refers to the maximum interface bandwidth used for bandwidth check when CBQ enqueues packets. It is not the actual bandwidth of the physical interface.
·     As a best practice, set the maximum available interface bandwidth to be smaller than the actual available bandwidth of the physical interface or logical link.
·     On subinterfaces, you must configure the bandwidth command to provide base bandwidth for CBQ calculation.
¡     If no maximum available bandwidth is set for an interface, the following bandwidth is used for CBQ calculation:
¡     The actual baud rate or rate if the interface is a physical one.
¡     0 kbps if the interface is a virtual interface, for example, tunnel interface, Layer 3 aggregate interface, or HDLC link bundle interface.
3.     Set the maximum available bandwidth of the interface.
bandwidth bandwidth-value
For more information about this command, see Interface Command Reference.
Setting the maximum reserved bandwidth as a percentage of available bandwidth for an interface
3.     Set the maximum reserved bandwidth as a percentage of available bandwidth.
qos reserved-bandwidth pct percent
The default setting is 80.
Typically, the maximum reserved bandwidth should not be greater than 80% of available bandwidth. As a best practice, use the default setting.
Setting the maximum reserved bandwidth as a percentage of available bandwidth for a PVC
pvc vpi/vci
Example: Configuring CBQ
As shown in Figure 22, configure a QoS policy on Device A to meet the following requirements:
·     Traffic from Device C is classified into three classes based on DSCP values. Perform AF for traffic with DSCP values of AF11 and AF21, and set a minimum guaranteed bandwidth percentage of 5% for the traffic.
·     Perform EF for traffic with a DSCP value of EF and set the maximum bandwidth percentage for the traffic to 30%.
Before configuring the QoS policy, make sure the following requirements are met:
·     The route from Device C to Device D through Device A and Device B is reachable.
·     The DSCP fields have been set for the traffic before the traffic enters Device A.
Figure 22 Network diagram
# Define three classes to match the IP packets with the DSCP values AF11, AF21, and EF, respectively.
[DeviceA] traffic classifier af11_class
[DeviceA-classifier-af11_class] if-match dscp af11
[DeviceA-classifier-af11_class] quit
[DeviceA]traffic classifier af21_class
[DeviceA-classifier-af21_class] if-match dscp af21
[DeviceA-classifier-af21_class] quit
[DeviceA] traffic classifier ef_class
[DeviceA-classifier-ef_class] if-match dscp ef
[DeviceA-classifier-ef_class] quit
# Define two traffic behaviors, and enable AF and set a minimum guaranteed bandwidth percentage of 5% in each traffic behavior.
[DeviceA] traffic behavior af11_behav
[DeviceA-behavior-af11_behav] queue af bandwidth pct 5
[DeviceA-behavior-af11_behav] quit
[DeviceA] traffic behavior af21_behav
[DeviceA-behavior-af21_behav] queue af bandwidth pct 5
[DeviceA-behavior-af21_behav] quit
# Define a traffic behavior, and enable EF and set a maximum bandwidth percentage of 30% in the traffic behavior. Both bandwidth and delay are guaranteed for EF traffic.
[DeviceA] traffic behavior ef_behav
[DeviceA-behavior-ef_behav] queue ef bandwidth pct 30
[DeviceA-behavior-ef_behav] quit
# Define a QoS policy and associate the configured traffic behaviors with classes in the QoS policy.
[DeviceA] qos policy dscp
[DeviceA-qospolicy-dscp] classifier af11_class behavior af11_behav
[DeviceA-qospolicy-dscp] classifier af21_class behavior af21_behav
[DeviceA-qospolicy-dscp] classifier ef_class behavior ef_behav
[DeviceA-qospolicy-dscp] quit
# Apply the QoS policy to the outgoing traffic of GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 1.1.1.1 255.255.255.0
[DeviceA-GigabitEthernet1/0/1] qos apply policy dscp outbound
The configuration enables EF traffic to be forwarded preferentially when congestion occurs.
Configuring RTPQ
¡     Subinterfaces.
Configuring RTPQ on an interface
3.     Configure RTPQ.
qos rtpq start-port first-rtp-port-number end-port last-rtp-port-number bandwidth bandwidth [ cbs cbs ]
By default, RTPQ is not configured.
Configuring RTPQ on a PVC
pvc vpi/vci
3.     Configure RTPQ.
Enabling packet information pre-extraction
The IP packets received on the physical interface for a tunnel interface might have been processed by the tunnel interface. For example, if the tunnel interface has used GRE to encapsulate packets, the GRE-encapsulated packets enter the QoS module for processing on the physical interface. As a result, the QoS module cannot get the IP information of the original packets.
To process the original IP packets with QoS on the physical interface for a tunnel interface, configure packet information pre-extraction on the tunnel interface.
For more information about tunnel interfaces, see Layer 3—IP Services Configuration Guide.
2.     Enter tunnel interface view.
interface tunnel number [ mode { ds-lite-aftr | gre [ ipv6 ] | ipv4-ipv4 | ipv6 | ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ] | mpls-te } ]
3.     Enable packet information pre-extraction.
qos pre-classify
By default, packet information pre-extraction is disabled.
Displaying and maintaining congestion management
Display the configuration of CQ lists.
display qos cql [ cql-index ]
Display QoS policy configuration.
display qos policy { system-defined | user-defined } [ policy-name [ classifier classifier-name ] ]
Display information about QoS policies applied to interfaces or PVCs.
In standalone mode:
display qos policy interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] [ inbound | outbound ]
In IRF mode:
display qos policy interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] [ slot slot-number ] [ inbound | outbound ]
Display the configuration of PQ lists.
display qos pql [ pql-index ]
Display the CBQ configuration and statistics for interfaces, PVCs, or PWs.
display qos queue cbq { interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
Display the CQ configuration and statistics for interfaces or PVCs.
display qos queue cq interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
Display the FIFO configuration and statistics for interfaces, PVCs, or PWs.
display qos queue fifo { interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
Display queuing configuration and statistics for interfaces or PVCs.
display qos queue interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
Display queuing configuration and statistics for PWs.
display qos queue l2vpn-pw [ peer ip-address pw-id pw-id ]
Display the PQ configuration and statistics for interfaces or PVCs.
display qos queue pq interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
Display the RTPQ configuration and statistics for interfaces or PVCs.
display qos queue rtpq interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
Display the WFQ configuration and statistics for interfaces, PVCs, or PWs.
display qos queue wfq { interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
Display traffic behavior configuration.
display traffic behavior { system-defined | user-defined } [ behavior-name ]
Display class configuration.
display traffic classifier { system-defined | user-defined } [ classifier-name ]
Clear QoS statistics for PWs.
reset qos statistics l2vpn-pw [ peer ip-address pw-id pw-id ]
Configuring congestion avoidance
About congestion avoidance
Avoiding congestion before it occurs is a proactive approach to improving network performance. As a flow control mechanism, congestion avoidance:
·     Actively monitors network resources (such as queues and memory buffers).
·     Drops packets when congestion is expected to occur or deteriorate.
When dropping packets from a source end, congestion avoidance cooperates with the flow control mechanism at the source end to regulate the network traffic size. The combination of the local packet drop policy and the source-end flow control mechanism implements the following functions:
·     Maximizes throughput and network use efficiency.
·     Minimizes packet loss and delay.
Tail drop
Congestion management techniques drop all packets that are arriving at a full queue. This tail drop mechanism results in global TCP synchronization. If packets from multiple TCP connections are dropped, these TCP connections go into the state of congestion avoidance and slow start to reduce traffic. However, traffic peak occurs later. Consequently, the network traffic jitters all the time.
RED and WRED
You can use Random Early Detection (RED) or Weighted Random Early Detection (WRED) to avoid global TCP synchronization.
Both RED and WRED avoid global TCP synchronization by randomly dropping packets. When the sending rates of some TCP sessions slow down after their packets are dropped, other TCP sessions remain at high sending rates. Link bandwidth is efficiently used, because TCP sessions at high sending rates always exist.
The RED or WRED algorithm sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
·     When the queue size is shorter than the lower threshold, no packet is dropped.
·     When the queue size reaches the upper threshold, all subsequent packets are dropped.
·     When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
If the current queue size is compared with the upper threshold and lower threshold to determine the drop policy, burst traffic is not fairly treated. To solve this problem, WRED compares the average queue size with the upper threshold and lower threshold to determine the drop probability.
The average queue size reflects the queue size change trend but is not sensitive to burst queue size changes, and burst traffic can be fairly treated.
When WFQ queuing is used, you can set the following parameters for packets with different precedence values to provide differentiated drop policies:
·     Exponent for average queue size calculation.
·     Upper threshold.
·     Lower threshold.
·     Drop probability.
When FIFO, PQ, or CQ is used, you can set the following parameters for each queue to provide differentiated drop policies:
·     Upper threshold.
·     Lower threshold.
·     Drop probability.
Relationship between WRED and queuing mechanisms
Figure 23 Relationship between WRED and queuing mechanisms
Through combining WRED with WFQ, the flow-based WRED can be realized. Each flow has its own queue after classification.
·     A flow with a smaller queue size has a lower packet drop probability.
·     A flow with a larger queue size has a higher packet drop probability.
In this way, the benefits of the flow with a smaller queue size are protected.
WRED parameters
Determine the following parameters before configuring WRED:
·     Upper threshold and lower threshold—When the average queue size is smaller than the lower threshold, packets are not dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue, the higher the drop probability. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
·     Drop precedence—A parameter used for packet drop. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. Red packets are dropped preferentially.
·     Exponent for average queue size calculation—The greater the exponent, the less sensitive the average queue size is to real-time queue size changes. The formula for calculating the average queue size is:
Average queue size = ( previous average queue size x (1 – 2–n) ) + (current queue size x 2–n), where n is the exponent.
·     Denominator for drop probability calculation—The greater the denominator, the smaller the calculated drop probability. (Applicable when you configure WRED parameters on an interface or PVC.)
·     Drop probability—Drop probability in percentage. The greater the value, the higher the drop probability. (Applicable when you configure a WRED table on an interface.)
Configuring WRED parameters on an interface
To enable WRED on an interface, you must first enable WFQ on the interface.
3.     Enable WRED.
qos wred [ dscp | ip-precedence ] enable
By default, tail drop is adopted.
4.     (Optional.) Set the WRED exponent for average queue size calculation.
qos wred weighting-constant exponent
5.     (Optional.) Set the drop-related parameters for a precedence value.
qos wred { ip-precedence ip-precedence | dscp dscp-value } low-limit low-limit high-limit high-limit discard-probability discard-prob
Repeat this command to configure more precedence values.
Example: Configuring WRED on an interface
·     Enable IP precedence-based WRED on GigabitEthernet 1/0/1.
·     Set the following parameters for packets with IP precedence 3: lower threshold 20, upper threshold 40, and drop probability denominator 15.
·     Set the exponent for average queue size calculation to 6.
# Enter system view.
# Enter interface view.
# Enable IP precedence-based WRED.
[Sysname-GigabitEthernet1/0/1] qos wred ip-precedence enable
# Set the following parameters for packets with IP precedence value 3: lower threshold 20, upper threshold 40, and drop probability 1/15.
[Sysname-GigabitEthernet1/0/1] qos wred ip-precedence 3 low-limit 20 high-limit 40 discard-probability 15
# Set the exponent for average queue size calculation to 6.
[Sysname-GigabitEthernet1/0/1] qos wred weighting-constant 6
Configuring WRED parameters on a PVC
To enable WRED on a PVC, you must first enable WFQ on the PVC before configuring the qos wred enable command.
pvc vpi/vci
3.     Enable WRED.
Display and maintenance commands for WRED
Display WRED configuration and statistics for an interface or PVC.
display qos wred interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
Display the configuration of a WRED table or all WRED tables.
In standalone mode:
display qos wred table [ name table-name ]
In IRF mode:
Configuring traffic filtering
About traffic filtering
You can filter in or filter out traffic of a class by associating the class with a traffic filtering action. For example, you can filter packets sourced from an IP address according to network status.
Restrictions and guidelines: Traffic filtering configuration
The device supports the following application destinations for traffic filtering:
·     Interface.
·     PVC.
·     Control plane.
a.     Create a traffic class and enter traffic class view.
a.     Create a traffic behavior and enter traffic behavior view.
b.     Configure the traffic filtering action.
filter { deny | permit }
By default, no traffic filtering action is configured.
If a traffic behavior has the filter deny action, all other actions in the traffic behavior except class-based accounting do not take effect.
By default, a traffic class is not associated with a traffic behavior.
6.     (Optional.) Display the traffic filtering configuration.
In standalone mode:
In IRF mode:
This command is available in any view.
Traffic filtering configuration examples
Example: Configuring traffic filtering
As shown in Figure 24, configure traffic filtering on GigabitEthernet 1/0/1 to deny the incoming packets with destination port number 21.
Figure 24 Network diagram
# Create advanced ACL 3000, and configure a rule to match packets with destination port number 21.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 permit tcp destination-port eq 21
# Create a traffic class named classifier_1, and use ACL 3000 as the match criterion in the traffic class.
# Create a traffic behavior named behavior_1, and configure the traffic filtering action to drop packets.
# Create a QoS policy named policy, and associate traffic class classifier_1 with traffic behavior behavior_1 in the QoS policy.
[Device] qos policy policy
[Device-qospolicy-policy] classifier classifier_1 behavior behavior_1
[Device-qospolicy-policy] quit
# Apply QoS policy policy to the incoming traffic of GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] qos apply policy policy inbound
Configuring priority marking
About priority marking
Priority marking sets the priority fields or flag bits of packets to modify the priority of packets. For example, you can use priority marking to set IP precedence or DSCP for a class of IP packets to control the forwarding of these packets.
To configure priority marking to set the priority fields or flag bits for a class of packets, perform the following tasks:
1.     Configure a traffic behavior with a priority marking action.
2.     Associate the traffic class with the traffic behavior.
Priority marking can be used together with priority mapping. For more information, see "Configuring priority mapping."
The device supports the following application destinations for priority marking:
·     Interface.
·     PVC.
·     Control plane.
For more information about the if-match command, see ACL and QoS Command Reference.
b.     Configure a priority marking action.
For configurable priority marking actions, see the  remark commands in ACL and QoS Command Reference.
a.     Create a QoS policy and enter QoS policy view.
b.     Associate the traffic class with the traffic behavior in the QoS policy.
For more information, see "Applying the QoS policy."
By default, no QoS policy is applied.
6.     (Optional.) Display the priority marking configuration.
In standalone mode:
In IRF mode:
Priority marking configuration examples
Example: Configuring priority marking
As shown in Figure 25, configure priority marking on the device to meet the following requirements:
Traffic source
Destination
Processing priority
Host A, B
Data server
High
Host A, B
Mail server
Medium
Host A, B
File server
Low
Figure 25 Network diagram
# Create advanced ACL 3000, and configure a rule to match packets with destination IP address 192.168.0.1.
[Device-acl-ipv4-adv-3000] rule permit ip destination 192.168.0.1 0
# Create advanced ACL 3001, and configure a rule to match packets with destination IP address 192.168.0.2.
[Device] acl advanced 3001
[Device-acl-ipv4-adv-3001] rule permit ip destination 192.168.0.2 0
# Create advanced ACL 3002, and configure a rule to match packets with destination IP address 192.168.0.3.
[Device] acl advanced 3002
[Device-acl-ipv4-adv-3002] rule permit ip destination 192.168.0.3 0
[Device-acl-ipv4-adv-3002] quit
# Create a traffic class named classifier_dbserver, and use ACL 3000 as the match criterion in the traffic class.
[Device] traffic classifier classifier_dbserver
[Device-classifier-classifier_dbserver] if-match acl 3000
[Device-classifier-classifier_dbserver] quit
# Create a traffic class named classifier_mserver, and use ACL 3001 as the match criterion in the traffic class.
[Device] traffic classifier classifier_mserver
[Device-classifier-classifier_mserver] if-match acl 3001
[Device-classifier-classifier_mserver] quit
# Create a traffic class named classifier_fserver, and use ACL 3002 as the match criterion in the traffic class.
[Device] traffic classifier classifier_fserver
[Device-classifier-classifier_fserver] if-match acl 3002
[Device-classifier-classifier_fserver] quit
# Create a traffic behavior named behavior_dbserver, and configure the action of setting the local precedence value to 4.
[Device] traffic behavior behavior_dbserver
[Device-behavior-behavior_dbserver] remark local-precedence 4
[Device-behavior-behavior_dbserver] quit
# Create a traffic behavior named behavior_mserver, and configure the action of setting the local precedence value to 3.
[Device] traffic behavior behavior_mserver
[Device-behavior-behavior_mserver] remark local-precedence 3
[Device-behavior-behavior_mserver] quit
# Create a traffic behavior named behavior_fserver, and configure the action of setting the local precedence value to 2.
[Device] traffic behavior behavior_fserver
[Device-behavior-behavior_fserver] remark local-precedence 2
[Device-behavior-behavior_fserver] quit
# Create a QoS policy named policy_server, and associate traffic classes with traffic behaviors in the QoS policy.
[Device] qos policy policy_server
[Device-qospolicy-policy_server] classifier classifier_dbserver behavior behavior_dbserver
[Device-qospolicy-policy_server] classifier classifier_mserver behavior behavior_mserver
[Device-qospolicy-policy_server] classifier classifier_fserver behavior behavior_fserver
[Device-qospolicy-policy_server] quit
# Apply QoS policy policy_server to the incoming traffic of GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] qos apply policy policy_server inbound
Configuring traffic redirecting
About traffic redirecting
Traffic redirecting redirects packets matching the specified match criteria to a location for processing.
You can redirect packets to the following destinations:
·     Interface.
Restrictions: Hardware compatibility with traffic redirecting
Hardware
Traffic redirecting compatibility
MSR610
Yes
Yes
MSR810-LMS, MSR810-LUS
Yes
MSR810-SI, MSR810-LM-SI
Yes
MSR810-LMS-EA, MSR810-LME
Yes
MSR1004S-5G
Yes
MSR2600-6-X1, MSR3610-X1-DP, MSR2600-15-X1, MSR2600-15-X1-T
Yes
MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
Yes
Yes
Yes
No
MSR3640-X1-HI
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
MSR2600-6-WiNet
Yes
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR860-6EI-XS
Yes
MSR860-6HI-XS
Yes
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
Restrictions and guidelines: Traffic redirecting configuration
·     The device supports the following application destinations for traffic redirecting:
¡     Interface.
¡     PVC.
¡     Control plane.
·     If you execute the redirect command multiple times, the most recent configuration takes effect.
·     For traffic redirecting to an Ethernet interface, the switch does not display the redirecting action after the interface module or interface expansion card that hosts the interface is removed. After the interface module or interface expansion card is reinserted, the switch can display the redirecting action.
By default, no match criterion is configured for a traffic class.
For more information about the match criteria, see the if-match command in ACL and QoS Command Reference.
b.     Configure a traffic redirecting action.
redirect interface interface-type interface-number [ track-oap ]
By default, no traffic redirecting action is configured for a traffic behavior.
6.     (Optional.) Display traffic redirecting configuration.
In standalone mode:
In IRF mode:
Traffic redirecting configuration examples
Example: Configuring traffic redirecting
As shown in Figure 26:
·     Device A is connected to Device B through two links. Device A and Device B are each connected to other devices.
·     GigabitEthernet 1/0/1 of Device A is a trunk port and belongs to VLAN 200 and VLAN 201.
·     GigabitEthernet 1/0/2 of Device A and GigabitEthernet 1/0/2 of Device B belong to VLAN 200.
·     GigabitEthernet 1/0/3 of Device A and GigabitEthernet 1/0/3 of Device B belong to VLAN 201.
·     On Device A, the IP address of VLAN-interface 200 is 200.1.1.1/24, and that of VLAN-interface 201 is 201.1.1.1/24.
·     On Device B, the IP address of VLAN-interface 200 is 200.1.1.2/24, and that of VLAN-interface 201 is 201.1.1.2/24.
Configure the actions of redirecting traffic to an interface to meet the following requirements:
·     Packets with source IP address 2.1.1.1 received on GigabitEthernet 1/0/1 of Device A are forwarded to GigabitEthernet 1/0/2.
·     Packets with source IP address 2.1.1.2 received on GigabitEthernet 1/0/1 of Device A are forwarded to GigabitEthernet 1/0/3.
·     Other packets received on GigabitEthernet 1/0/1 of Device A are forwarded according to the routing table.
Figure 26 Network diagram
# Create basic ACL 2000, and configure a rule to match packets with source IP address 2.1.1.1.
[DeviceA] acl basic 2000
[DeviceA-acl-ipv4-basic-2000] rule permit source 2.1.1.1 0
# Create basic ACL 2001, and configure a rule to match packets with source IP address 2.1.1.2.
[DeviceA-acl-ipv4-basic-2001] rule permit source 2.1.1.2 0
# Create a traffic class named classifier_1, and use ACL 2000 as the match criterion in the traffic class.
[DeviceA] traffic classifier classifier_1
[DeviceA-classifier-classifier_1] if-match acl 2000
[DeviceA-classifier-classifier_1] quit
# Create a traffic class named classifier_2, and use ACL 2001 as the match criterion in the traffic class.
[DeviceA] traffic classifier classifier_2
[DeviceA-classifier-classifier_2] if-match acl 2001
[DeviceA-classifier-classifier_2] quit
# Create a traffic behavior named behavior_1, and configure the action of redirecting traffic to GigabitEthernet 1/0/2.
[DeviceA] traffic behavior behavior_1
[DeviceA-behavior-behavior_1] redirect interface gigabitethernet 1/0/2
[DeviceA-behavior-behavior_1] quit
# Create a traffic behavior named behavior_2, and configure the action of redirecting traffic to GigabitEthernet 1/0/3.
[DeviceA] traffic behavior behavior_2
[DeviceA-behavior-behavior_2] redirect interface gigabitethernet 1/0/3
[DeviceA-behavior-behavior_2] quit
# Create a QoS policy named policy.
[DeviceA] qos policy policy
# Associate traffic class classifier_1 with traffic behavior behavior_1 in the QoS policy.
[DeviceA-qospolicy-policy] classifier classifier_1 behavior behavior_1
# Associate traffic class classifier_2 with traffic behavior behavior_2 in the QoS policy.
[DeviceA-qospolicy-policy] classifier classifier_2 behavior behavior_2
[DeviceA-qospolicy-policy] quit
[DeviceA-GigabitEthernet1/0/1] qos apply policy policy inbound
Appendixes
Appendix A Acronyms
Table 3 Appendix A Acronyms
Acronym
Full spelling
AF
Assured Forwarding
BE
Best Effort
BQ
Bandwidth Queuing
CAR
Committed Access Rate
CBS
Committed Burst Size
CBQ
Class Based Queuing
CE
Congestion Experienced
CIR
Committed Information Rate
CQ
Custom Queuing
DiffServ
Differentiated Service
DSCP
Differentiated Services Code Point
EBS
Excess Burst Size
ECN
Explicit Congestion Notification
EF
Expedited Forwarding
FIFO
First in First out
FQ
Fair Queuing
GMB
Guaranteed Minimum Bandwidth
GTS
Generic Traffic Shaping
IntServ
Integrated Service
ISP
Internet Service Provider
LLQ
Low Latency Queuing
LSP
Label Switched Path
MPLS
Multiprotocol Label Switching
PE
Provider Edge
PIR
Peak Information Rate
PQ
Priority Queuing
PW
Pseudowire
QoS
Quality of Service
QPPB
QoS Policy Propagation Through the Border Gateway Protocol
RED
RSVP
Resource Reservation Protocol
RTP
Real-Time Transport Protocol
SP
Strict Priority
ToS
Type of Service
VoIP
Voice over IP
VPN
Virtual Private Network
WFQ
Weighted Fair Queuing
WRED
WRR
Weighted Round Robin
Appendix B Default priority maps
Table 4 Default dot1p-lp priority map
dot1p
lp
0
2
1
0
2
1
3
3
4
4
5
5
6
6
7
7
Table 5 Default dot11e-lp priority map
dot11e
lp
0
2
1
0
2
1
3
3
4
4
5
5
6
6
7
7
Table 6 Default dscp-lp priority map
dscp
lp
0 to 7
0
8 to 15
1
16 to 23
2
24 to 31
3
32 to 39
4
40 to 47
5
48 to 55
6
56 to 63
7
Table 7 Default lp-dot1p, lp-dot11e, and lp-dscp priority maps
Input priority value
lp-dot1p map
lp-dot11e map
lp-dscp map
lp
dot1p
dot11e
dscp
0
1
1
0
1
2
2
8
2
0
0
16
3
3
3
24
4
4
4
32
5
5
5
40
6
6
6
48
7
7
7
56
Appendix C Introduction to packet precedence
IP precedence and DSCP values
Figure 27 ToS and DS fields
As shown in Figure 27, the ToS field in the IP header contains 8 bits. The first 3 bits (0 to 2) represent IP precedence from 0 to 7. According to RFC 2474, the ToS field is redefined as the differentiated services (DS) field. A DSCP value is represented by the first 6 bits (0 to 5) of the DS field and is in the range 0 to 63. The remaining 2 bits (6 and 7) are reserved.
Table 8 IP precedence
IP precedence (decimal)
IP precedence (binary)
0
000
Routine
1
001
priority
2
010
immediate
3
011
flash
4
100
flash-override
5
101
critical
6
110
internet
7
111
network
Table 9 DSCP values
DSCP value (decimal)
DSCP value (binary)
46
101110
ef
10
001010
af11
12
001100
af12
14
001110
af13
18
010010
af21
20
010100
af22
22
010110
af23
26
011010
af31
28
011100
af32
30
011110
af33
34
100010
af41
36
100100
af42
38
100110
af43
8
001000
cs1
16
010000
cs2
24
011000
cs3
32
100000
cs4
40
101000
cs5
48
110000
cs6
56
111000
cs7
0
000000
be (default)
802.1p priority
802.1p priority lies in the Layer 2 header. It applies to occasions where Layer 3 header analysis is not needed and QoS must be assured at Layer 2.
Figure 28 An Ethernet frame with an 802.1Q tag header
As shown in Figure 28, the 4-byte 802.1Q tag header contains the 2-byte tag protocol identifier (TPID) and the 2-byte tag control information (TCI). The value of the TPID is 0x8100. Figure 29 shows the format of the 802.1Q tag header. The Priority field in the 802.1Q tag header is called 802.1p priority, because its use is defined in IEEE 802.1p. Table 10 shows the values for 802.1p priority.
Figure 29 802.1Q tag header
Table 10 Description on 802.1p priority
802.1p priority (decimal)
802.1p priority (binary)
0
000
best-effort
1
001
background
2
010
spare
3
011
excellent-effort
4
100
controlled-load
5
101
video
6
110
voice
7
111
network-management
EXP values
The EXP field is in MPLS labels for MPLS QoS purposes. As shown in Figure 30, the EXP field is 3-bit long and is in the range of 0 to 7.
Figure 30 MPLS label structure
