- 14-WLAN Command Reference (Fat AP)
- 01-Compatibility of hardware and AP functionality
- 02-Radio management commands
- 03-Band navigation commands
- 04-WLAN access commands
- 05-WLAN security commands
- 06-WLAN authentication commands
- 07-WLAN QoS commands
- 09-Cloud connection commands
- 09-WLAN multicast optimization commands
- 10-WLAN load balancing commands
| 04-WLAN access commands | 237.60 KB |
display wlan ap all client-number
display wlan ap all radio client-number
display wlan client online-duration
display wlan statistics client
display wlan statistics connect-history
display wlan statistics service template
reset wlan statistics service-template
snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit
wlan client keep-alive interval
wlan client reauthentication-period
wlan dynamic-blacklist lifetime
wlan static-blacklist mac-address
wlan web-server max-client-entry
The term "AP" in this document refers to MSR routers that offer WLAN services as fat APs. For more information, see "Compatibility of hardware and AP functionality."
access-control acl
Use access-control acl to specify an ACL for ACL-based access control.
Use undo access-control acl to restore the default.
access-control acl acl-number
No ACL is specified.
Service template view
acl-number: Specifies the number of a Layer 2 ACL, in the range of 4000 to 4999.
This feature controls client access by using the specified ACL rules. When the device receives an association request, it performs the following actions:
· Allows the client to access the WLAN if the MAC address of the client matches the MAC address attribute or MAC address OUI attribute in a rule and the rule action is permit. If multiple clients match the OUI attribute, all these clients are allowed to access the WLAN.
· Denies the client's access to the WLAN if no match is found or the matched rule has a deny statement.
When you configure this feature, follow these restrictions and guidelines:
· If the specified ACL contains a deny statement, configure a permit statement for the ACL to permit all clients. If you do not do so, no clients can come online.
· ACL-based access control configuration takes precedence over whitelist and blacklist configuration.
· You can specify only one ACL. If you execute this command multiple times, the most recent configuration takes effect.
# Create ACL 4000 and create ACL rules to permit the client with MAC address 000e-35b2-000e and clients with the specified OUI. Specify ACL 4000 for service template service1.
[Syname] acl mac 4000
[Syname-acl-mac-4000] rule 0 permit source-mac 000e-35b2-000e ffff-ffff-ffff
[Syname-acl-mac-4000] rule 1 permit source-mac 000e-35b2-000f ffff-ff00-0000
[Syname-acl-mac-4000] rule 2 deny
[Syname-acl-mac-4000] quit
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] access-control acl 4000
beacon ssid-hide
Use beacon ssid-hide to disable advertising of the Service Set Identifier (SSID) in beacon frames.
Use undo beacon ssid-hide to restore the default.
beacon ssid-hide
The SSID is advertised in beacon frames.
This command disables a radio from carrying SSIDs in the beacon frames and responding to probe requests after the specified service template is bound to the radio.
# Disable advertising the SSID in beacon frames.
[Sysname-wlan-st-service1] beacon ssid-hide
client max-count
Use client max-count to set the maximum number of associated clients for a service template.
Use undo client max-count to restore the default.
client max-count max-number
The number of associated clients for a service template is not limited.
max-number: Specifies the maximum number of clients in the range of 1 to 512.
With this feature configured, new clients cannot access the WLAN and the SSID is hidden when the maximum number is reached.
# Set the maximum number of associated clients to 38 for service template service1.
[Sysname-wlan-st-service1] client max-count 38
beacon ssid-hide
customlog format wlan
Use customlog format wlan to enable the device to generate client logs in the specified format.
Use undo customlog format wlan to restore the default.
customlog format wlan { normal | sangfor }
The device generates client logs only in H3C format.
normal: Specifies normal format.
sangfor: Specifies sangfor format.
By default, the device generates client logs only in H3C format that logs AP name, radio ID, client MAC address, SSID, BSSID, and client online status.
You can configure the device to generate client logs in one of the following formats:
· Normal—Logs AP MAC address, AP name, client IP address, client MAC address, SSID, and BSSID.
· Sangfor—Logs AP MAC address, client IP address, and client MAC address.
This feature does not affect the generation of client logs in H3C format.
# Enable the device to generate client logs in sangfor format.
[Sysname] customlog format wlan sangfor
description
Use description to configure a description for a service template.
No description is configured for a service template.
text: Specifies a description, a case-sensitive string of 1 to 64 characters.
# Configure a description for service template service1.
[Sysname-wlan-st-service1] description wlanst
display interface wlan-radio
Use display interface wlan-radio to display WLAN radio interface information.
display interface wlan-radio [ interface-number ] [ brief ]
interface-number: Specifies a WLAN radio interface by its number. If you do not specify this argument, the command displays information about all WLAN radio interfaces.
# Display detailed information about WLAN-Radio 0/0.
<Sysname> display interface wlan-radio 0/0
WLAN-Radio0/0
Current state: UP
Description: WLAN-Radio0/0 Interface
IP Packet Frame Type: PKTFMT_IEEE_802.11, Hardware Address: d461-fe59-4d20
current mode: 802.11ac, current channel: 36
Last link flapping: 0 hours 31 minutes 6 seconds
Current system time:2016-01-01 00:31:19
Last time when physical state changed to up:2016-01-01 00:00:13
Last time when physical state changed to down:2016-01-01 00:00:13
Input (total): 0 packets, 0 bytes
Input (normal): 0packets, 0bytes
0 management, 0 control, 0 data
Input (error): 0 total, 0 CRC, 0 decrypt errors
0 mic failures, 0 phy errors, 0 other errors
Output (normal): Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 packets
Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 bytes
Output (bcn&probe): 0 packets, 0 bytes
Output (error): 0 total, 0 discard, 0 buffer failures
0 ack failures, 0 rts successed, 0 rts failures
Current state |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface was shut down with the shutdown command. To bring up the interface, execute the undo shutdown command. · Stby—The interface is a backup interface. |
IP Packet Frame Type |
This field displays PKTFMT_IEEE_802.11, which indicates that the frame is 802.11 encapsulated. |
Hardware Address |
Interface MAC address. |
current mode |
Current radio mode. |
current channel |
Current working channel. |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Current system time |
Current system time in the YYYY/MM/DD HH:MM:SS format. If a time zone is specified, this field displays the system time in the HH:MM:SS UTC±HH:MM:SS format. |
Last time when physical state changed to up |
Last time when the physical link state of the interface changed to up. This field displays - if the physical link state has never been changed. |
Last time when physical state changed to down |
Last time when the physical link state of the interface changed to down. This field displays - if the physical link state has never been changed. |
Input(total): 0 packets, 0 bytes |
Inbound packet statistics (in packets and bytes) for the interface. All inbound normal packets and abnormal packets were counted. |
Input (normal): 0packets, 0bytes 0 management, 0 control, 0 data |
Inbound normal packet statistics (in packets and bytes) for the interface. All normal inbound management, control, and data packets were counted. |
Input (error) |
Inbound error packet statistics for the interface. |
Output (total): 0 packets, 0 bytes |
Outbound packet statistics (in packets and bytes) for the interface. All outbound normal packets and abnormal packets were counted. |
Output (normal): Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 packets Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 bytes 0 management, 0 control, 0 data |
Outbound normal packet statistics (in packets and bytes) for the interface. All normal outbound management, control, and data packets were counted. Q[n] represents an AC queue, where n represents the queue ID. |
Output (bcn&probe) |
Outbound beacon and probe frame statistics (in packets and bytes) for the interface. |
Output (error) |
Outbound error packet statistics for the interface. |
# Display brief information about WLAN-Radio 0/0.
<Sysname> display interface wlan-radio 0/0 brief
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
WLAN-Radio0/0 UP -- -- -- --
Brief information on interfaces in bridge mode |
Brief information about Layer 2 interfaces. |
Link |
Physical link state of the interface: · ADM—The interface was shut down with the shutdown command. To restore the physical state of the interface, execute the undo shutdown command. · Stby—The interface is a backup interface. To display the primary interface, use the display interface-backup state command. |
Speed |
Speed of the interface, in Mbps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays -- for WLAN radio interfaces. |
Duplex |
Duplex mode of the interface: · (a)/A—Autonegotiation. · H—Half duplex. · F—Full duplex. This field displays -- for WLAN radio interfaces. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. This field displays -- for WLAN radio interfaces. |
PVID |
Use display wlan ap all client-number to display the number of online clients at the 2.4 GHz band and the 5 GHz band.
# Display the number of online clients at both the 2.4 GHz and 5 GHz bands.
<System> display wlan ap all client-number
AP name Clients 2.4GHz 5GHz
fatap 2 2 0
Clients |
Total number of online clients. |
2.4GHz |
Number of online clients at the 2.4 GHz band. |
5GHz |
Number of online clients at the 5 GHz band. |
Use display wlan ap all radio client-number to display the number of online clients and channel information for each radio.
# Display the number of online clients and channel information for each radio.
<Sysname> display wlan ap all radio client-number
AP name RID Channel Clients
fatap 1 44 12
fatap 2 11 4
display wlan blacklist
Use display wlan blacklist to display blacklist entries.
display wlan blacklist { dynamic | static }
dynamic: Specifies the dynamic blacklist.
static: Specifies the static blacklist.
# Display static blacklist entries.
<Sysname> display wlan blacklist static
Total number of clients: 3
MAC addresses:
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
# Display dynamic blacklist entries.
<Sysname> display wlan blacklist dynamic
MAC address APID Lifetime (s) Duration (hh:mm:ss)
000f-e2cc-0001 1 300 00:02:11
000f-e2cc-0002 2 300 00:01:17
000f-e2cc-0003 3 300 00:02:08
MAC address |
Client MAC address. |
APID |
ID of the AP that detects the rogue client. |
Lifetime (s) |
Lifetime of the entry in seconds. |
Duration (hh:mm:ss) |
Duration for the entry since the entry was added to the dynamic blacklist. |
display wlan bss
Use display wlan bss to display basic service set (BSS) information.
display wlan bss { all | bssid bssid } [ verbose ]
all: Displays all BSSs.
bssid bssid: Specifies a BSS by its ID. The value is a 48-bit hexadecimal number in the format of H-H-H.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
# Display brief information about all BSSs.
<Sysname> display wlan bss all
Total number of BSSs: 4
AP name RID SSID BSSID
fatap 1 SSID1 001c-f08f-f804
fatap 2 SSID1 001c-f08f-f806
# Display detailed information about the BSS with ID 001c-f08f-f804.
<Sysname> display wlan bss bssid 001c-f08f-f804 verbose
AP name : fatap
BSSID : 001c-f08f-f804
Radio ID : 1
Service template name : servcie1
SSID : SSID1
VLAN ID : 1
AKM mode : Not configured
User authentication mode : Bypass
Table 5 Command output
AKM mode |
AKM mode: · 802.1X. · PSK. · Not configured. |
User authentication mode |
User authentication mode: · Bypass—No client authentication. · MAC. · 802.1X. · OUI. |
display wlan client
Use display wlan client to display client information.
display wlan client [ interface wlan-radio interface-number | mac-address mac-address | service-template service-template-name | vlan vlan-id ] [ verbose ]
interface wlan-radio interface-number: Displays information about clients that are connected to the specified radio interface.
mac-address mac-address: Specifies a client by its MAC address.
service-template service-template-name: Displays information about clients that are associated with the specified service template. The service template name is a case-insensitive string of 1 to 63 characters.
vlan vlan-id: Displays information about clients in the specified VLAN. The VLAN ID is in the range of 1 to 4094.
# Display brief information about all clients.
<Sysname> display wlan client
MAC address Username AP name RID IP address VLAN
000f-e265-6400 N/A fatap 1 1.1.1.1 100
000f-e265-6401 user fatap 1 3.0.0.3 200
84db-ac14-dd08 N/A fatap 1 5.5.5.3 1
Table 6 Command output
MAC address |
Username |
Client username: · The field displays the client username if the client uses 802.1X or MAC authentication. · The field displays N/A if the client does not use 802.1X or MAC authentication. NOTE: If the client uses portal authentication, this field does not display the portal username of the client. |
AP name |
Name of the AP that the client is associated with. |
RID |
ID of the radio that the client is associated with. |
IP address |
IPv4 address of the client. |
VLAN ID |
ID of the VLAN to which the client belongs. |
# Display detailed information about the client with MAC address 000f-e265-6400.
<Sysname> display wlan client mac-address 000f-e265-6400 verbose
Total number of clients: 1
MAC address : 000f-e265-6400
IPv4 address : 10.1.1.114
IPv6 address : 2001::1234:5678:0102:0304
Username : N/A
AID : 1
Radio ID : 1
SSID : office
BSSID : 0026-3e08-1150
VLAN ID : 3
Sleep count : 3
Wireless mode : 802.11gn
Channel bandwidth : 20MHz
SM power save : Enabled
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
STBC RX capability : Not supported
STBC TX capability : Not supported
LDPC RX capability : Not supported
Block Ack : TID 0 In
Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14,
15
Supported rates : 1, 2, 5.5, 6, 9, 11,
12, 18, 24, 36, 48, 54 Mbps
QoS mode : WMM
Listen interval : 10
RSSI : 62
Rx/Tx rate : 130/195 Mpbs
Authentication method : Open system
Security mode : PRE-RSNA
Cipher suite : N/A
Authorization ACL ID : 3001(Not effective)
Authorization user profile : N/A
Roam status : N/A
Key derivation : SHA1
PMF status : Enabled
Forwarding policy name : Not configured
Online time : 0days 0hours 1minutes 13seconds
FT status : Inactive
Table 7 Command output
MAC address |
IPv4 address |
Client IPv4 address. |
IPv6 address |
Client IPv6 address. |
Username |
AID |
Association ID. |
Radio ID |
SSID |
SSID with which the client is associated. |
VLAN ID |
Sleep count |
Client sleep times. |
Wireless mode |
Wireless mode: · 802.11a. · 802.11b. · 802.11g. · 802.11gn. · 802.11an. · 802.11ac. · 802.11gac. |
Channel bandwidth |
Channel bandwidth: · 20 MHz. · 40 MHz. · 80 MHz. · 160 MHz. |
20/40 BSS Coexistence Management |
Whether the client supports 20/40MHz channel bandwidth coexistence. |
SM Power Save |
SM Power Save status: · Enabled—Only one antenna of a client operates in active state, and others operate in sleep state to save power. · Disabled. |
Short GI for 20MHz |
Whether the client supports short GI when its channel bandwidth is 20 MHz: · Supported. · Not supported. |
Short GI for 40MHz |
Whether the client supports short GI when its channel bandwidth is 40 MHz: · Supported. · Not supported. |
Short GI for 80MHz |
Whether the client supports short GI when its channel bandwidth is 80 MHz: · Supported. · Not supported. |
Short GI for 160/80+80MHz |
Whether the client supports short GI when its channel bandwidth is 160 MHz or 80 + 80 MHz: · Supported. · Not supported. |
STBC Rx Capability |
Client STBC receive capability; · Not Supported. · Supported. |
STBC Tx Capability |
Client STBC transmission capability: · Not Supported. · Supported. |
LDPC Rx capability |
Client LDPC receive capability; · Not Supported. · Supported. |
SU beamformee capability |
Client SU beamformee capability: · Not Supported. · Supported. |
MU beamformee capability |
Client MU beamformee capability: · Not Supported. · Supported. |
Beamformee STS capability |
Supported spatial stream quantity if the client is a beamformee receiver, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee receiver. |
Number of Sounding Dimensions |
Supported spatial stream quantity if the client is a beamformee transmitter, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee transmitter. |
Block Ack |
Negotiation result of Block ACK with TID: · TID 0 In—Sends Block ACK for inbound traffic. · TID 0 Out—Sends Block ACK for outbound traffic. · TID 0 Both—Sends Block ACK for both inbound and outbound traffic. · N/A—Does not send Block ACK for both inbound and outbound traffic. |
Supported VHT-MCS set |
VHT-MCS supported by the client. |
Supported HT MCS set |
QoS mode |
QoS mode: · N/A—WMM is not supported. · WMM—WMM is supported. WMM information negotiation is carried out between an AP and a client that both support WMM. |
Listen interval |
Interval at which the client wakes up to listen for beacon frames. It is counted by beacon interval. |
RSSI |
Received signal strength indication. This value indicates the client signal strength detected by the AP. |
Rx/Tx rate |
Sending and receiving rates of data, management, and control frames. |
Authentication method |
Authentication method: · Open system. · Shared key. |
Security mode |
Security mode: · RSN—Beacons and probe responses carry RSN IE. · WPA—Beacons and probe responses carry WPA IE. · PRE-RSNA—Beacons and probe responses do not carry RSN IE or WPA IE. |
AKM mode |
Cipher suite |
Cipher suite: · N/A. · WEP40. · WEP104. · WEP128. · CCMP. · TKIP. |
Authorization ACL ID |
Authorized ACL number: · This field displays the ACL number if the authorized ACL takes effect. · This field displays ACL number(Not effective) if the authorized ACL does not take effect. · This field displays N/A if the authentication server is configured without any authorized ACL. |
Authorization user profile |
Name of the authorized user profile: · This field displays the authorized user profile name if the authorized user profile takes effect. · This field displays authorized user profile name + Not effective if the authorized user profile does not take effect. · This field displays N/A if the authentication server is configured without any authorized user profile. |
Roam status |
This field is not supported in the current software version. Roam status: · Roaming in progress. · Inter-AC roam. · Inter-MA roam. · Intra-AC roam. · Intra-MA roam. · This field displays N/A if the client stays in one BSS after coming online. |
Key derivation |
Key derivation type: · SHA1—Uses the HMAC-SHA1 hash algorithm. · SHA256—Uses the HMAC-SHA256 hash algorithm. · N/A—No key derivation algorithm is involved for the authentication type. |
PMF status |
PMF status: · Enabled—Management frame protection is enabled. · Disabled—Management frame protection is disabled. · N/A—Management frame protection is not involved. |
Forwarding policy name |
WLAN forwarding policy name: · Not configured. · Policy-name. |
Online time |
Client online duration. |
FT status |
This field is not supported in the current software version. Fast BSS transition (FT): · Active—FT is enabled. · Inactive—FT is disabled. |
display wlan client ipv6
Use display wlan client ipv6 to display information about client IPv6 addresses.
# Display brief status information about the specified client.
<Sysname> display wlan client ipv6
MAC address AP name RID IPv6 address VLAN
84db-ac14-dd08 fatap 1 1::2:0:0:3 300
Table 8 Command output
MAC address |
RID |
Radio ID |
IPv6 address |
Use display wlan client online-duration to display client online duration.
display wlan client online-duration [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about client online duration.
<Sysname> display wlan client online-duration
Total number of online clients: 2
MAC address IPv4 address Online duration
a4c1-5b79-fa5b-1d62 192.168.11.123 0days 0hours 2minutes 23seconds
22d3-c5b7-a4b5-96fa 192.168.11.234 0days 0hours 5minutes 34seconds
Table 9 Command output
MAC address |
IPv4 address |
Online duration |
display wlan client status
Use display wlan client status to display client status information.
display wlan client status [ mac-address mac-address ] [ verbose ]
mac-address mac-address: Specifies a client by its MAC address in the format of H-H-H. If you do not specify this option, the command displays status information about all clients.
verbose: Displays detailed client status information. If you do not specify this keyword, the command displays brief client status information.
<Sysname> display wlan client status mac-address 001c-f08f-f804
MAC address Access time RSSI Rx/Tx rate Discard AP name RID
001c-f08f-f804 41ms 0 39/117Mbps 0.00 fatap 2
# Display brief status information about all clients.
Total number of clients: 2
000b-c002-9d09 41ms 65 39/117Mbps 0.00% fatap 2
000f-e265-6401 10ms 62 130/195Mbps 0.00% fatap 1
Table 10 Command output
MAC address |
Access time |
Time the client took to associate with the WLAN. |
RSSI |
RSSI of the client. |
Rx/Tx rate |
Rates at which the client receives and sends data, management packets, and control packets. |
Discard |
Ratio of packets discarded by the client. |
AP name |
Name of the AP with which the client is associated. |
RID |
ID of the radio with which the client is associated. |
# Display detailed status information about the specified client.
<Sysname> display wlan client status mac-address 001c-f08f-f804 verbose
MAC address : 001c-f08f-f804
Radio ID : 2
Access time : 41 ms
RSSI : 0
Rx/Tx rate : 39/117 Mbps
Received:
Retransmitted packets : 84
Retransmitted packet ratio : 64.12%
Sent:
Retransmitted packets : 0
Retransmitted packet ratio : 0.00%
Discarded:
Discarded packets : 0
Discarded packet ratio : 0.00%
Table 11 Command output
MAC address |
AP name |
Radio ID |
Access time |
RSSI |
Rx/Tx rate |
Received |
Received packet statistics: · Retransmitted packets. · Retransmitted packet ratio. |
Sent |
Sent packet statistics: · Retransmitted packets. · Retransmitted packet ratio. |
Discarded |
Discarded packet statistics: · Discarded packets. · Discarded packet ratio. |
display wlan service-template
Use display wlan service-template to display service template information.
display wlan service-template [ service-template-name ] [ verbose ]
service-template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command displays information about all service templates.
verbose: Displays detailed service template information.
# Display brief information about all service templates.
[Sysname] display wlan service-template
Total number of service templates: 2
Service template name SSID Status
1 2333 Enabled
2 3222 Enabled
# Display detailed information about all service templates.
<Sysname> display wlan service-template verbose
Service template name : service1
Description : Not configured
SSID : wuxianfuwu
SSID-hide : Disabled
User-isolation : Disabled
Service template status : Disabled
Maximum clients per BSS : 64
Frame format : Dot3
Seamless roam status : Disabled
Seamless roam RSSI threshold : 50
Seamless roam RSSI gap : 20
VLAN ID : 1
AKM mode : PSK
Security IE : RSN
Cipher suite : CCMP
WEP key ID : 1
TKIP countermeasure time : 100 sec
PTK lifetime : 43200 sec
PTK rekey : Enabled
GTK rekey : Enabled
GTK rekey method : Time-based
GTK rekey time : 86400 sec
GTK rekey client-offline : Enabled
Intrusion protection : Disabled
Intrusion protection mode : Temporary-block
Temporary block time : 180 sec
Temporary service stop time : 20 sec
Fail VLAN ID : 1
802.1X handshake : Enabled
802.1X handshake secure : Disabled
802.1X domain : my-domain
MAC-auth domain : Not configured
Max 802.1X users per BSS : 4096
Max MAC-auth users per BSS : 4096
802.1X re-authenticate : Enabled
Authorization fail mode : Online
Accounting fail mode : Online
Authorization : Permitted
PMF status : Optional
Hotspot policy number : Not configured
Forwarding policy status : Disabled
Forwarder : AP
FT status : Disabled
QoS trust : Port
QoS priority : 0
Table 12 Command output
SSID |
SSID of the service template. |
SSID-hide |
Whether the SSID is hidden in beacons: · Disabled. · Enabled. |
User-isolation |
This field is not supported in the current software version. Use isolation: · Disabled. · Enabled. |
Service template status |
Service template status: · Disabled. · Enabled. |
Maximum clients per BSS |
Maximum number of clients that the BSS supports. |
Frame format |
Client data frame encapsulation format: · Dot3—802.3 format. · Dot11—802.11 format. |
Seamless roam status |
This field is not supported in the current software version. Seamless roaming status: · Disabled. · Enabled. |
Seamless roam RSSI threshold |
This field is not supported in the current software version. Seamless roaming RSSI threshold. |
Seamless roam RSSI gap |
This field is not supported in the current software version. Seamless roaming RSSI gap. |
VLAN ID |
ID of the VLAN to which clients belong after they come online through the service template. |
AKM mode |
AKM mode: · 802.1X. · PSK. |
Security IE |
Security IE: · RSN. · WPA. |
Cipher suite |
Cipher suite: · WEP40. · WEP104. · WEP128. · TKIP. · CCMP. |
TKIP countermeasure time |
TKIP countermeasure time. The value 0 indicates no countermeasures are taken. |
PTK rekey |
Whether PTK rekey is enabled: · Enabled. · Disabled. |
GTK rekey |
Whether GTK rekey is enabled: · Enabled. · Disabled. |
GTK rekey method |
GTK rekey method: · Time-based. · Packet-based. |
GTK rekey time |
GTK rekey interval. |
GTK rekey packets |
Number of packets that can be transmitted before the GTK is refreshed. |
GTK rekey client-offline |
Whether client-off GTK rekey is enabled: · Enabled. · Disabled. |
Authentication mode: · Bypass—No authentication. · MAC. · MAC-or-802.1X—MAC authentication is performed first. If MAC authentication fails, 802.1X authentication is performed. · 802.1X. · 802.1X-or-MAC—802.1X authentication is performed first. If 802.1X authentication fails, MAC authentication is performed. · OUI-or-802.1X—OUI authentication is performed first. If OUI authentication fails, 802.1X authentication is performed. |
Intrusion protection |
Whether intrusion protection is enabled: · Enabled. · Disabled. |
Intrusion protection mode |
Intrusion protection mode: · Temporary-block—Temporarily adds intruders to the block list. · Service-stop—Stops all services provided by the BSS that receives illegal packets until it resets. · Temporary-service-stop—Temporarily stops the access service provided by the BSS that receives illegal packets. |
Temporary block time |
Temporary block time in seconds. |
Temporary service stop time |
Temporary service stop time in seconds. |
Fail VLAN ID |
ID of the VLAN to which clients are added if they cannot pass the authentication when the authentication server can be reached. This field displays Not configured if the fail VLAN ID is not configured. |
Critical VLAN ID |
ID of the VLAN to which clients are added if they cannot pass the authentication because the authentication server cannot be reached. This field displays Not configured if the critical VLAN ID is not configured. |
802.1X handshake |
Whether 802.1X handshake is enabled: · Enabled. · Disabled. |
802.1X handshake secure |
Whether secure 802.1X handshake is enabled: · Enabled. · Disabled. |
802.1X domain |
802.1X authentication domain. This field displays Not configured if the domain is not configured. |
MAC-auth domain |
MAC authentication domain. This field displays Not configured if the domain is not configured. |
Max 802.1X users per BSS |
Maximum number of supported 802.1X users in a BSS. |
Max MAC-auth users per BSS |
Maximum number of supported users that pass the MAC authentication in a BSS. |
802.1X re-authenticate |
Whether 802.1X reauthentication is enabled: · Enabled. · Disabled. |
Authorization fail mode |
Authorization fail mode: · Offline—Clients are logged off when authorization fails. · Online—Clients are not logged off when authorization fails. |
Accounting fail mode |
Accounting fail mode: · Offline—Clients are logged off when accounting fails. · Online—Clients are not logged off when accounting fails. |
Authorization |
Authorization information: · Permitted—Applies the authorization information issued by the RADIUS server or the local device. · Ignored—Ignores the authorization information issued by the RADIUS server or the local device. |
Key derivation |
Key derivation type: · SHA1—Uses the HMAC-SHA1 hash algorithm. · SHA256—Uses the HMAC-SHA256 hash algorithm. · SHA1-AND-SHA256—Uses the HMAC SHA1 and SHA256 hash algorithm. |
PMF status |
PMF status: · Disabled—Management frame protection is disabled. · Optional—Management frame protection in optional mode is enabled. · Mandatory—Management frame protection in mandatory mode is enabled. |
Hotspot policy number |
This field is not supported in the current software version. Hotspot 2.0 policy number. |
Forwarding policy status |
WLAN forwarding policy status: · Disabled. · Enabled. |
Forward policy name |
WLAN forwarding policy name: · Not configured—No WLAN forwarding policy is configured. · policy-name. |
Forwarder |
Client traffic forwarder: AP. |
FT status |
This field is not supported in the current software version. FT status: · Disabled. · Enabled. |
FT method |
This field is not supported in the current software version. FT method: · over-the-air. · over-the-ds. |
FT reassociation deadline |
This field is not supported in the current software version. FT reassociation timeout timer in seconds. |
QoS trust |
QoS priority trust mode: · Port—Port priority trust mode. · Dot11e—802.11e priority trust mode. |
QoS priority |
Port priority in the range of 0 to 7. |
Use display wlan statistics client to display client statistics.
display wlan statistics client [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays statistics for all clients.
# Display statistics for all clients.
<Sysname> display wlan statistics client
MAC address : 0014-6c8a-43ff
AP name : fatap
Radio ID : 1
SSID : office
BSSID : 000f-e2ff-7700
RSSI : 31
Sent frames:
Back ground : 0/0 (frames/bytes)
Best effort : 9/1230 (frames/bytes)
Video : 0/0 (frames/bytes)
Voice : 2/76 (frames/bytes)
Received frames:
Best effort : 18/2437 (frames/bytes)
Voice : 7/468 (frames/bytes)
Discarded frames:
Best effort : 0/0 (frames/bytes)
Voice : 5/389 (frames/bytes)
Table 13 Command output
SSID |
MAC address |
Back ground |
AC-BK queue. |
Best effort |
AC-BE queue. |
Video |
AC-VI queue. |
Voice |
AC-VO queue. |
Use display wlan statistics connect-history to display client connection history.
display wlan statistics service-template service-template-name connect-history
service-template service-template-name: Specifies a service template by its name.
# Display the connection history for service template 1.
<Sysname> display wlan statistics service-template 1 connect-history
AP name : fatap
Radio ID : 1
Associations : 132
Association failures : 3
Reassociations : 30
Rejections : 12
Abnormal disassociations : 2
Current associations : 57
Use display wlan statistics service-template to display service template statistics.
# Display statistics for service template 1.
AP name : fatap
Radio ID : 1
Received:
Frame count : 1713
Frame bytes : 487061
Data frame count : 1683
Data frame bytes : 485761
Association request count : 2
Sent:
Frame count : 62113
Frame bytes : 25142076
Data frame count : 55978
Data frame bytes : 22626600
Association response count : 2
display wlan whitelist
Use display wlan whitelist to display whitelist entries.
# Display whitelist entries.
<Sysname> display wlan whitelist
MAC addresses:
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
Use interface wlan-radio to enter WLAN radio interface view.
interface-number: Specifies the WLAN radio interface ID.
# Enter interface view of WLAN-Radio 0/0.
[Sysname] interface wlan-radio 0/0
[Sysname-WLAN-Radio0/0]
nas-id
Use nas-id to set the network access server identifier (NAS ID).
nas-id nas-id
undo nas-id
No NAS ID is specified.
Global configuration view
nas-id: Specifies a NAS ID, a case-sensitive string of 1 to 63 characters.
After coming online, a client sends a RADIUS request that carries the NAS ID to the RADIUS server to indicate its network access server.
# Set the global NAS ID to abc123.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] nas-id abc123
quick-association enable
Use quick-association to enable quick association.
Use undo quick-association to disable quick association.
undo quick-association enable
Quick association is disabled.
This command disables APs from performing load balancing or band navigation on clients associated with the specified service template.
# Enable quick association for service template service1.
[Sysname-wlan-st-service1]quick-association enable
region-code
Use region-code to specify a region code.
Use undo region-code to restore the default.
region-code code
undo region-code
The region code is CN.
code: Specifies a region code. For more information about region codes, see Table 14.
Table 14 Region code information
Country |
Code |
Country |
Code |
Andorra |
AD |
Korea, Republic of Korea |
KR |
United Arab Emirates |
AE |
Kenya |
KE |
Albania |
AL |
Kuwait |
KW |
Armenia |
AM |
Kazakhstan |
KZ |
Australia |
AU |
Lebanon |
LB |
Argentina |
AR |
Liechtenstein |
LI |
Australia |
AT |
Sri Lanka |
LK |
Azerbaijan |
AZ |
Lithuania |
LT |
Bosnia and Herzegovina |
BA |
Luxembourg |
LU |
Belgium |
BE |
Latvia |
LV |
Bulgaria |
BG |
Libyan |
LY |
Bahrain |
BH |
Morocco |
MA |
Brunei Darussalam |
BN |
Monaco |
MC |
Bolivia |
BO |
Moldova |
MD |
Brazil |
BR |
Macedonia |
MK |
Bahamas |
BS |
Macau |
MO |
Belarus |
BY |
Martinique |
MQ |
Belize |
BZ |
Malta |
MT |
Canada |
CA |
Mauritius |
MU |
Switzerland |
CH |
Mexico |
MX |
Cote d'ivoire |
CI |
Malay Archipelago |
MY |
Chile |
CL |
Namibia |
NA |
China |
CN |
Nigeria |
NG |
Colombia |
CO |
Nicaragua |
NI |
Costarica |
CR |
Netherlands |
NL |
Serbia |
RS |
Norway |
NO |
Cyprus |
CY |
New Zealand |
NZ |
Czech Republic |
CZ |
Oman |
OM |
Germany |
DE |
Panama |
PA |
Denmark |
DK |
Peru |
PE |
Dominica |
DO |
Poland |
PL |
Algeria |
DZ |
Philippines |
PH |
Ecuador |
EC |
Pakistan |
PK |
Estonia |
EE |
Puerto Rico |
PR |
Egypt |
EG |
Portugal |
PT |
Spain |
ES |
Paraguay |
PY |
Faroe Islands |
FO |
Qatar |
QA |
Finland |
FI |
Romania |
RO |
France |
FR |
Russian Federation |
RU |
Britain |
GB |
Saudi Arabia |
SA |
Georgia |
GE |
Sweden |
SE |
Gibraltar |
GI |
Singapore |
SG |
Greenland |
GL |
Slovenia |
SI |
Guadeloupe |
GP |
Slovak |
SK |
Greece |
GR |
San Marino |
SM |
Guatemala |
GT |
Salvador |
SV |
Guyana |
GY |
Syrian |
SY |
Honduras |
HN |
Thailand |
TH |
Hong Kong |
HK |
Tunisia |
TN |
Croatia |
HR |
Turkey |
TR |
Hungary |
HU |
Trinidad and Tobago |
TT |
Iceland |
IS |
, China |
TW |
India |
IN |
Ukraine |
UA |
Indonesia |
ID |
United States of America |
US |
Ireland |
IE |
Uruguay |
UY |
Israel |
IL |
Uzbekistan |
UZ |
Iraq |
IQ |
The Vatican City State |
VA |
Italy |
IT |
Venezuela |
VE |
Iran |
IR |
Virgin Islands |
VI |
Jamaica |
JM |
Vietnam |
VN |
Jordan |
JO |
Yemen |
YE |
Japan |
JP |
South Africa |
ZA |
Democratic People's Republic of Korea |
KP |
Zimbabwe |
ZW |
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring an AP.
# Specify US as the global region code.
[Sysname-wlan-global-configuration] region-code US
region-code-lock
region-code-lock
Use region-code-lock enable to lock the region code.
Use region-code-lock disable to unlock the region code.
Use undo region-code-lock to restore the default.
region-code-lock { disable | enable }
The region code is not locked.
A locked region code cannot be changed.
# Lock the global region code.
[Sysname-wlan-global-configuration] region-code-lock enable
region-code
reset wlan client
Use reset wlan client to log off a client or all clients.
reset wlan client { all | mac-address mac-address }
View
all: Specifies all clients.
# Log off all clients.
<Sysname> reset wlan client all
display wlan client
reset wlan dynamic-blacklist
Use reset wlan dynamic-blacklist to remove the specified client or all clients from the dynamic blacklist.
reset wlan dynamic-blacklist [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command removes all clients from the dynamic blacklist.
# Remove all clients from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist
# Remove the specified client from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist mac-address b8ca-32a2-df69
reset wlan statistics client
Use reset wlan statistics client to clear client statistics.
reset wlan statistics client { all | mac-address mac-address }
View
# Clear statistics about all clients.
<Sysname> reset wlan statistics client all
Use reset wlan statistics service-template to clear service template statistics.
reset wlan statistics service-template service-template-name
View
# Clear statistics about service template service1.
<Sysname> reset wlan statistics service-template service1
service-template
Use service-template to bind a service template to a radio interface.
Use undo service-template to unbind a service template from a radio interface.
undo service-template service-template-name
In radio interface view, no service template is bound to a radio interface.
Radio interface view
Before you bind a service template to a radio or a radio interface, you must create the service template.
# Bind service template service1 to interface WLAN-Radio 0/0.
[Sysname-WLAN-Radio0/0] service-template service1
service-template enable
Use service-template enable to enable a service template.
Use undo service-template enable to disable a service template.
A service template is disabled.
If the number of BSSs on a device exceeds the limit, you cannot enable a new service template.
# Enable service template service1.
[Sysname-wlan-st-service1] service-template enable
Use snmp-agent trap enable wlan client to enable SNMP notification for client access.
Use undo snmp-agent trap enable wlan client to disable SNMP notification for client access.
SNMP notification is disabled for client access.
When this feature is enabled, the device sends a client status change notification to an NMS every time the status of a client changes. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client access.
[Sysname] snmp-agent trap enable wlan client
Use snmp-agent trap enable wlan client-audit to enable SNMP notification for client audit.
Use undo snmp-agent trap enable wlan client-audit to disable SNMP notification for client audit.
SNMP notification is disabled for client audit.
When this feature is enabled, the device sends a client status change notification to an NMS when a client comes online, goes offline, roams to another AP, or obtains an IP address. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client audit.
[Sysname] snmp-agent trap enable wlan client-audit
ssid
Use ssid to set an SSID for a service template.
Use undo ssid to restore the default.
ssid ssid-name
undo ssid
No SSID is configured for a service template.
ssid-name: Specifies an SSID name, a case-sensitive string of 1 to 32 characters.
Disable the service template before you execute this command.
# Set the SSID to lynn for service template service1.
[Sysname-wlan-st-service1] ssid lynn
unknown-client
Use unknown-client to set the way that an AP processes traffic from unknown clients.
Use undo unknown-client to restore the default.
unknown-client { deauthenticate | drop }
undo unknown-client
An AP drops packets from unknown clients and deauthenticates these clients.
deauthenticate: Drops packets from unknown clients and deauthenticates these clients.
drop: Drops packets from unknown clients.
# Configure APs that use service template example to drop packets from unknown clients but not deauthenticate these clients.
[Sysname] wlan service-template example
[Sysname-wlan-st-example] unknown-client drop
vlan
Use vlan to assign clients coming online through a service template to the specified VLAN.
Use undo vlan to restore the default.
vlan vlan-id
undo vlan
Clients are assigned to VLAN 1 after coming online through a service template.
vlan-id: Specifies a VLAN by its VLAN ID, in the range of 1 to 4094. If the specified VLAN does not exist, this command creates the VLAN when clients come online.
# Assign clients coming online through service template service1 to VLAN 2.
[Sysname-wlan-st-service1] vlan 2
wlan association optimization
Use wlan association optimization to set the index for optimizing client association ratios.
Use undo wlan association optimization to restore the default.
wlan association optimization value
The index is 0. The device does not optimize client association ratios.
value: Specifies the index for optimizing client association ratios, in the range of 900 to 1000. The smaller the index is, the smaller the calculated association success ratio will be and the larger the calculated congestion ratio and abnormal disassociation ratio will be.
This feature enables the device to recalculate the client association success ratio, association congestion ratio, and abnormal disassociation ratio by using the specified index to get smaller ratio values.
The client association success ratio is the number of successful client associations divided by the total number of client association attempts. The client association congestion ratio is the number of failed client associations caused by AP overloading divided by the total number of client association attempts. The client abnormal disassociation ratio is the number of abnormal disassociations divided by the sum of successful associations and online clients.
# Set the index for optimizing client association ratios to 950.
[Sysname] wlan association optimization 950
wlan broadcast-probe reply
Use wlan broadcast-probe reply to enable the AP to respond to broadcast probe requests.
Use undo wlan broadcast-probe reply to disable the AP from responding to broadcast probe requests.
The AP responds to broadcast probe requests.
# Disable the AP from responding to broadcast probe requests.
[Sysname] undo wlan broadcast-probe reply
wlan client idle-timeout
Use wlan client idle-timeout to set the client idle timeout timer.
Use undo wlan client idle-timeout to restore the default.
wlan client idle-timeout timeout
The client idle timeout timer is 3600 seconds.
timeout: Specifies the client idle timeout timer in the range of 60 to 86400 seconds.
If an online client does not send any frames to the associated AP before the client idle timeout timer expires, the AP logs off the client.
# Set the client idle timeout timer to 2000 seconds.
[Sysname] wlan client idle-timeout 2000
Use wlan client keep-alive enable to enable client keepalive.
Use undo wlan client keep-alive to disable client keepalive.
Client keepalive is disabled.
This feature enables the AP to send keepalive packets to clients at the specified intervals to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
# Enable client keepalive.
[Sysname] wlan client keep-alive enable
Use wlan client keep-alive interval to set the client keepalive interval.
Use undo wlan client keep-alive interval to restore the default.
wlan client keep-alive interval interval
The client keepalive interval is 300 seconds.
interval: Specifies the client keepalive interval in the range of 3 to 1800 seconds.
Enable client keepalive on the fat AP before you execute this command.
This feature enables an AP to send keepalive packets to clients at the client keepalive interval to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
# Set the client keepalive interval to 1000 seconds.
[Sysname] wlan client keep-alive interval 1000
Use wlan client reauthentication-period to set the idle period before client reauthentication.
Use undo wlan client reauthentication-period to restore the default.
wlan client reauthentication-period [ period-value ]
The idle period is not configured.
period-value: Specifies the idle period in the range of 1 to 3600 seconds. By default, the idle period is 10 seconds.
When URL redirection for WLAN MAC authentication is enabled, an AP redirects clients whose information is not recorded on the RADIUS server to the specified URL for Web authentication. Clients passing Web authentication are logged off and must perform MAC reauthentication to come online. However, MAC reauthentication fails if the IP addresses assigned to the clients have not expired.
Perform this task to add these clients to the dynamic blacklist for the specified idle period after they pass Web authentication to reduce reauthentication failures.
# Set the idle period before client reauthentication to 100 seconds.
[Sysname] wlan client reauthentication-period 100
Use wlan dynamic-blacklist lifetime to set the aging time for dynamic blacklist entries.
Use undo wlan dynamic-blacklist lifetime to restore the default.
wlan dynamic-blacklist lifetime lifetime
The aging time is 300 seconds for dynamic blacklist entries.
lifetime: Specifies the aging time in the range of 1 to 3600 seconds.
The configured aging time takes effect only on entries added to the dynamic blacklist after this command is executed.
The aging time for dynamic blacklist entries only applies to rogue client entries.
# Set the aging time for dynamic blacklist entries to 3600 seconds.
[Sysname] wlan dynamic-blacklist lifetime 3600
wlan link-test
Use wlan link-test to test wireless link quality.
wlan link-test mac-address
mac-address: Specifies the client MAC address in the H-H-H format.
Wireless link quality detection enables an AP to test the quality of the link to a wireless client. The AP sends empty data frames to the client at each supported rate. Then it calculates link quality information such as RSSI, packet retransmissions, and RTT based on the responses from the client.
The timeout timer for wireless link quality detection is 10 seconds. If wireless link detection is not completed within the timeout timer, test results cannot be obtained.
# Test the quality of the wireless link to the client with MAC address 60a4-4cda-eff0.
<Sysname> wlan link-test 60a4-4cda-eff0
Testing link to 60a4-4cda-eff0. Press CTRL + C to break.
Link Status
MAC address: 60a4-4cda-eff0
VHT-MCS Rate(Mbps) Tx packets Rx packets RSSI Retries RTT(ms)
NSS = 1
0 32.5 5 5 54 0 0
1 65 5 5 51 0 0
2 97.5 5 5 49 0 0
3 130 5 5 47 0 0
4 195 5 5 45 0 0
5 260 5 5 45 0 0
6 292.5 5 5 44 0 0
7 325 5 5 44 0 0
8 390 5 5 44 0 0
9 433.3 5 5 43 0 0
NSS = 2
0 65 5 5 44 0 0
1 130 5 5 44 0 0
2 195 5 5 44 0 0
3 260 5 5 44 0 0
4 390 5 5 44 0 0
5 520 5 5 44 0 0
6 585 5 5 43 0 0
7 650 5 5 43 0 0
8 780 5 5 43 0 0
9 866.7 5 5 43 0 0
<Sysname> wlan link-test 784f-43b6-077c
Testing link to 784f-43b6-077c. Press CTRL + C to break.
Link Status
MAC address: 784f-43b6-077c
0 6.5 5 5 54 0 0
1 13 5 5 51 0 0
2 19.5 5 5 49 0 0
3 26 5 5 47 0 0
4 39 5 5 45 0 0
5 52 5 5 45 0 0
6 58.5 5 5 44 0 0
7 72.2 5 5 44 0 0
8 13 5 5 44 0 0
9 26 5 5 43 0 0
10 39 5 5 44 0 0
11 52 5 5 44 0 0
12 78 5 5 44 0 0
13 104 5 5 44 0 0
14 117 5 5 44 0 0
15 144.4 5 5 44 11 0
Table 15 Command output
No./MCS/VHT-MCS |
· No.—Rate number for link quality test on 802.11a, 802.11b, or 802.11g clients. · MCS—MCS index for link quality test on 802.11n clients. · VHT-MCS—VHT-MCS index for link quality test on 802.11ac clients. |
Rate(Mbps) |
Rate at which the AP sends wireless link quality detection frames. |
Tx packets |
Number of wireless link quality detection frames sent by the AP. |
Rx packets |
Number of responses received by the AP. |
RSSI |
RSSI of the client detected by the AP. |
Retries |
Number of wireless link quality retransmission frames sent by the AP. |
RTT(ms) |
Round trip time for link quality test frames from the AP to the client. |
NSS |
Number of spatial streams for link quality test on 802.11n or 802.11ac clients. |
Use wlan service-template to create a service template and enter its view, or enter the view of an existing service template.
Use undo wlan service-template to delete a service template.
wlan service-template service-template-name
undo wlan service-template service-template-name
No service template exists.
You cannot delete a service template that has been bound to a radio.
# Create service template service1 and enter its view.
Use wlan static-blacklist mac-address to add a client to the static blacklist.
Use undo wlan static-blacklist mac-address to remove a client from the static blacklist.
wlan static-blacklist mac-address mac-address
undo wlan static-blacklist [ mac-address mac-address ]
No clients exist in the static blacklist.
If you add an online client to the static blacklist, the command logs off the client.
You cannot add a client to both the whitelist and the static blacklist.
The undo form of the command removes all clients from the static blacklist if you do not specify the mac-address mac-address option.
Do not add multicast or broadcast MAC addresses to the static blacklist.
# Add MAC address 001c-f0bf-9c92 to the static blacklist.
[Sysname] wlan static-blacklist mac-address 001c-f0bf-9c92
wlan web-server api-path
Use wlan web-server api-path to specify the path of the Web server to which client information is reported.
Use undo wlan web-server api-path to restore the default.
wlan web-server api-path path
The path of the Web server is not specified.
path: Specifies a path, a case-sensitive string of 1 to 256 characters.
The Web server accepts client information only when the server's host name, port number, and path are specified.
# Specify the path of the Web server as /wlan/dev-cfg.
[Sysname] wlan web-server api-path /wlan/dev-cfg
wlan web-server host
Use wlan web-server host to specify the host name and port number of the Web server to which client information is reported.
Use undo wlan web-server host to restore the default.
wlan web-server host host-name port port-number
The host name and port number of the Web server are not specified.
host host-name: Specifies a host name, a case-insensitive string of 3 to 127 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.).
port port-number: Specifies a port number in the range of 1 to 65534.
Client information changes are reported to the Web server in real time.
# Specify the host name and port number of the Web server as www.abc.com and 668, respectively.
[Sysname] wlan web-server host www.abc.com port 668
Use wlan web-server max-client-entry to set the maximum number of client entries that can be reported at a time.
Use undo wlan web-server max-client-entry to restore the default.
wlan web-server max-client-entry number
A maximum of ten client entries can be reported at a time.
number: Specifies a maximum number of client entries that can be reported at a time, in the range of 1 to 25.
# Set the maximum of client entries that can be reported at a time to 12.
[Sysname] wlan web-server max-client-entry 12
wlan whitelist mac-address
Use wlan whitelist mac-address to add a client to the whitelist.
Use undo wlan whitelist mac-address to remove a client from the whitelist.
wlan whitelist mac-address mac-address
undo wlan whitelist [ mac-address mac-address ]
No clients exist in the whitelist.
When you add the first client to the whitelist, the system asks you whether to disconnect all online clients. Enter Y at the prompt to configure the whitelist.
If you remove an online client from the whitelist, the command logs off the client. If you remove all clients from the whitelist, online clients will not be logged off.
The undo form of the command removes all clients from the whitelist if you do not specify the mac-address mac-address option.
Do not add multicast or broadcast MAC addresses to the whitelist.
# Add MAC address 001c-f0bf-9c92 to the whitelist.
[Sysname] wlan whitelist mac-address 001c-f0bf-9c92
This command will disconnect all clients. Continue? [Y/N]:
