| 01-SR-MPLS commands | 240.85 KB |
display bgp egress-engineering ipv4
display bgp segment-routing label-range
display bgp segment-routing prefix-sid-map
display isis segment-routing adjacency
display isis segment-routing global-block
display isis segment-routing prefix-sid-map
display mpls static-sr-mpls prefix
display ospf segment-routing global-block
display ospf segment-routing prefix-sid-map
display segment-routing label-block
display segment-routing mapping-server prefix-sid-map
fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay
isis fast-reroute ti-lfa disable
ospf fast-reroute ti-lfa disable
segment-routing adjacency enable
segment-routing label-advertise
segment-routing mapping-server advertise-local
segment-routing mapping-server receive
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
SR-MPLS commands
Use display bgp egress-engineering ipv4 to display BGP EPE segment information.
display bgp [ instance instance-name ] egress-engineering ipv4 [ ipv4-address ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information about the default BGP instance.
ipv4-address: Specifies the IPv4 address of an existing peer. If you do not specify this argument, the command displays information about all peers and peer groups.
# Display BGP EPE segment information.
<Sysname> display bgp egress-engineering ipv4
BGP peering segment type: Set
Nexthop : 192.168.1.2
Local AS number : 1
Remote AS number : 2
Local router ID : 1.1.1.3
Remote router ID : 1.1.1.4
OriginNextHop : 192.168.1.2
RelyNextHop : 192.168.1.2
Interface : GE2/0/1
Label : 24002
# Display BGP EPE segment information for a peer.
<Sysname> display bgp egress-engineering ipv4 192.168.1.2
BGP peering segment type: Node
Local AS number : 1
Remote Asnumber : 2
Label : 24002
<Sysname> display bgp egress-engineering ipv4 192.168.1.5
BGP peering segment type: Adjacency
NextHop : 192.168.1.5
Local AS number : 1
Remote router ID : 1.1.1.5
OriginNextHop : 192.168.1.5
RelyNextHop : 192.168.1.5
Interface : GE2/0/5
Label : 24002
Interface on which the neighborship is established. |
OriginNextHop |
Original next hop. |
RelyNextHop |
Recursive next hop. |
Use display bgp segment-routing label-range to display BGP SR label ranges.
display bgp [ instance instance-name ] segment-routing label-range
# Display BGP SR label ranges.
<Sysname> display bgp segment-routing label-range
BGP peering segment labels:
24001-69631
Prefix labels:
16000-24000
Use display bgp segment-routing prefix-sid-map to display BGP SR prefix-SID mappings.
display bgp [ instance instance-name ] segment-routing prefix-sid-map [ ip-address mask-length | verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP SR prefix-SID mappings of the default BGP instance.
ip-address mask-length: Specifies a range of prefixes by an IP address and a mask length. The mask-length argument is in the range of 1 to 32.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display the BGP SR prefix-SID mapping for prefix 1.1.1.1/32.
<Sysname> display bgp segment-routing prefix-sid-map 1.1.1.1 32
Prefix SID index
1.1.1.1/32 10
# Display brief information about BGP SR prefix-SID mappings for all prefixes.
Number of mappings: 2
Prefix SID index Range
1.1.1.1/32 10 100
2.2.2.2/32 256 520
# Display detailed information about BGP SR prefix-SID mappings for all prefixes.
<Sysname> display bgp segment-routing prefix-sid-map verbose
Prefix: 1.1.1.1/32
SID index : 10
Range : 100
Last prefix : 1.1.1.100/32
Last SID index: 109
Prefix: 2.2.2.2/32
SID index : 256
Range : 520
Last prefix : 2.2.4.9/32
Last SID index: 775
SID index |
Start SID index value. |
Range |
Number of consecutive SIDs assigned. |
Use display isis segment-routing adjacency to display IS-IS SR adjacency segment information.
display isis segment-routing adjacency [ process-id ]
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays SR adjacency segment information about all IS-IS processes.
# Display SR adjacency segment information about IS-IS process 1.
<Sysname> display isis segment-routing adjacency 1
Segment routing adjacency path information for IS-IS(1)
SystemID Interface Nexthop Label Type
0000.0000.0011 GE2/0/1 10.123.110.21 24122 L1
0000.0000.0012 GE2/0/2 192.168.56.21 24121 L1
SystemID |
System ID of the neighbor. |
Interface connected to the neighbor. |
Nexthop |
Next hop of the adjacency segment. |
Label |
Incoming label. |
Type |
Link adjacency type of the interface. |
Use display isis segment-routing global-block to display IS-IS SRGB information.
display isis segment-routing global-block [ level-1 | level-2 ] [ process-id ]
level-1: Specifies Level-1 SRGB.
level-2: Specifies Level-2 SRGB.
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the SRGBs of all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, the command displays information about both the Level-1 SRGB and Level-2 SRGB.
# Display information about the SRGBs for IS-IS process 1.
<Sysname> display isis segment-routing global-block 1
Segment routing global block information for IS-IS(1)
Level-1 SRGB
System ID Base Range
0000.0000.0011 16666 5557
0000.0000.0012 18012 4001
System ID |
Base |
Minimum label value of the SRGB. |
Range |
Number of labels in the SRGB. |
Use display isis segment-routing prefix-sid-map to display IS-IS SR prefix-SID mappings.
display isis segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
active-policy: Displays active prefix-SID mappings.
backup-policy: Displays backup prefix-SID mappings.
process-id: Specifies an IS-IS process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all IS-IS processes.
If you do not specify the active-policy or backup-policy keyword, the command displays information about both active and backup prefix-SID mappings.
# Display active IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map active-policy
ISIS 1 - Active policy
Number of mappings: 5
Prefix SID index Range Flags
2.2.2.2/32 10 10 -
3.3.3.3/32 300 1 -
8.8.8.8/32 600 20 -
11.11.11.11/32 100 10 -
12.12.12.1/32 44 3 -
# Display detailed information about active IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map active-policy verbose
Prefix 1.1.1.1 32
Source : Local
Router ID : 1010.1020.1030
Level : Not set
SID index : 100
Range : 1
Last prefix : 1.1.1.1/32
Last SID index: 100
Flags : -
Prefix 2.2.2.2 32
Source : Remote
Router ID : 1010.1020.1040
Level : L1
SID index : 200
Range : 1
Last prefix : 2.2.2.2/32
Last SID index: 200
Flags : -
# Display backup IS-IS SR prefix-SID mappings.
<Sysname> display isis segment-routing prefix-sid-map backup-policy
ISIS 1 - Backup policy
Number of mappings: 4
2.2.2.2/32 200 30 -
8.8.8.8/32 600 20 -
2.2.2.2/32 10 10 -
# Display all IS-IS SR prefix-SID mappings.
ISIS 1 – Both active policy and backup policy
Number of mappings: 9
2.2.2.2/32 10 10 -
2.2.2.2/32 10 10 -
2.2.2.2/32 200 30 -
3.3.3.3/32 300 1 -
8.8.8.8/32 600 20 -
8.8.8.8/32 600 20 -
Table 5 Command output
SID index |
Range |
Flags |
Mapping flags. The A flag indicates that the peer specified by the prefix is directly connected to the device. If no flags are set, this field display a hyphen (-). |
Source |
Source of the prefix-SID mapping: · Local—The mapping is configured on the local device. · Remote—The mapping is configured on the remote device. |
Router ID |
ID of the route advertiser. |
Level |
Level of the route advertiser: · L1—Level-1 IS-IS route. · L2—Level-2 IS-IS route. · Not set—The route was locally advertised. |
Use display mpls static-sr-mpls to display static SRLSP and adjacency segment information.
display mpls static-sr-mpls { lsp [ lsp-name ] | adjacency [ adjacency-path-name ] }
lsp: Displays static SRLSP information.
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this argument, the command displays information about all static SRLSPs.
adjacency: Displays static adjacency segment information.
adjacency-path-name: Specifies a static adjacency segment by its name, a case-sensitive string of 1 to 15 characters. If you do not specify this argument, the command displays information about all static adjacency segments.
# Display information about all static SRLSPs.
<Sysname> display mpls static-sr-mpls lsp lsp1
Type : LSP
In-Label : -
Out-Label : 60,70,80
Out-Interface : -
Nexthop : -
State : Up
Table 6 Command output
Name |
Name of the static SRLSP or adjacency segment. |
Type |
Information type: · LSP—Static SRLSP information. · Adjacency—Adjacency segment information. |
In-Label |
Incoming label. |
Out-Label |
Outgoing label. |
Out-Interface |
Output interface. |
Nexthop |
Next hop address. |
State |
Status of the static SRLSP or adjacency segment: · Down—The static SRLSP or adjacency segment is not available. · Up—The static SRLSP or adjacency segment is available. |
static-sr-mpls adjacency
static-sr-mpls lsp
Use display mpls static-sr-mpls prefix to display static prefix segment information.
display mpls static-sr-mpls prefix [ path lsp-name | destination ip-address [ mask | mask-length ] ]
path lsp-name: Displays static prefix segment information for the specified static SRLSP. The lsp-name argument specifies a static SRLSP by its name, a case-sensitive string of 1 to 15 characters.
destination ip-address: Displays static prefix segment information for the specified destination address. The ip-address argument specifies a destination address.
mask: Specifies the destination address mask.
mask-length: Specifies the mask length, in the range of 0 to 32.
If you do not specify any parameters, this command displays information about all static prefix segments.
# Display information about all static prefix segments.
<Sysname> display mpls static-sr-mpls prefix
Prefix Name : prefixname
Destination : 2.2.2.2/32
In-Label : 1024
Active : Yes(1)
Out-Interface : GE2/0/1
Nexthop : 10.0.0.2
Out-Label : 600000
Status : up
Out-Interface : GE2/0/2
Nexthop : 11.0.0.2
Out-Label : 600002
Status : down(No Route)
Out-Interface : GE2/0/3
Nexthop : 12.0.0.2
Out-Label : 600001
Status : down(No Mpls)
Table 7 Command output
Prefix Name |
Name of the prefix segment. |
Destination |
Destination IP address of the prefix segment. |
In-Label |
Incoming label of the prefix segment. |
Active |
Status of the prefix segment: · Yes(count)—The prefix segment is active. The value of count represents the number of egresses in up status. · No—The prefix segment is inactive. |
Out-Interface |
Outgoing interface of the prefix segment. |
Nexthop |
Next hop of the prefix segment. |
Out-Label |
Outgoing label of the prefix segment. |
Status |
Status of the egress: · down—The egress is inactive. The cause is displayed in brackets, which can be No Route or No Mpls. No Route means that the device has no route to reach the destination IP address over the outgoing interface. No Mpls means that MPLS is disabled on the output interface. · up—The egress is active. · duplicate—An egress conflict has occurred because the output interface is already used by another prefix segment. |
Use display ospf segment-routing global-block to display OSPF SRGB information.
display ospf [ process-id ] [ area area-id ] segment-routing global-block
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the SRGBs of all OSPF processes.
area area-id: Specifies an area by its ID. The area ID can be a value in dotted decimal notation or a decimal value in the range of 0 to 4294967295. If you specify a decimal value, the system automatically transforms it to a value in dotted decimal notation. If you do not specify this option, the command displays the SRGBs of all areas.
# Display the SRGBs of all OSPF processes.
<Sysname> display ospf segment-routing global-block
Segment Routing Global Block
Area: 0.0.0.0
Router ID Min SID Max SID Total
1.1.1.1 16000 24000 8001
2.2.2.2 18000 18999 1000
3.3.3.3 16000 24000 8001
4.4.4.4 17000 17999 1000
5.5.5.5 16000 16999 1000
Table 8 Command output
Router ID |
Router ID of the device or the neighbor. |
Min SID |
Max SID |
Maximum label value of the SRGB. |
Total |
Use display ospf segment-routing prefix-sid-map to display OSPF SR prefix-SID mappings.
display ospf segment-routing prefix-sid-map [ active-policy | backup-policy ] [ process-id ] [ verbose ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPF processes.
# Display active OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map active-policy
OSPF 1 - Active policy
Flags: IA - Inter-Area, L – Local, R - Remote
1.1.1.11/32 10 10 L/-
1.1.1.22/32 20 20 R/-
# Display detailed information about active OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map active-policy verbose
Prefix 1.1.1.11
Source : Local
Router ID : 10.1.1.1
Area ID : Not set
LS ID : Not set
SID index : 10
Range : 10
Last prefix : 1.1.1.20
Last SID index: 19
Flags : -
Prefix 1.1.1.22
Source : Remote
Router ID : 10.2.1.1
Area ID : 0.0.0.1
LS ID : 7.0.0.0
SID index : 20
Range : 20
Last prefix : 1.1.1.41
Last SID index: 39
Flags : -
# Display backup OSPF SR prefix-SID mappings.
<Sysname> display ospf segment-routing prefix-sid-map backup-policy
OSPF 1 - Backup policy
Number of mappings: 1
1.1.1.33/32 30 30 R/IA
# Display all OSPF SR prefix-SID mappings.
OSPF 1 - Both active policy and backup policy
Number of mappings: 3
Table 9 Command output
SID index |
Range |
Flags |
Mapping flags: · IA—The prefix was from another area. · L—The mapping is a local mapping. · R—The mapping is a remote mapping. If no flags are set, this field display a hyphen (-). |
Source |
Router ID |
Area ID |
Area ID. If the mapping is a local mapping, this field displays Not set. |
LS ID |
Link state ID. If the mapping is a local mapping, this field displays Not set. |
Use display segment-routing label-block to display SR label block information.
display segment-routing label–block [ protocol { isis | ospf } ]
protocol: Specifies a protocol. If you do not specify this keyword, the command displays SR label block information about all protocols.
isis: Displays IS-IS SR label block information.
ospf: Displays OSPF SR label block information.
# Display SR label block information about all protocols.
<Sysname> display segment-routing label-block
Default label block:
SRLB: 15000-15999
SRGB: 16000-55999
Configurate label block:
SRLB: 200000-210000
SRGB: 16000-17000
Type Protocol Process-ID Label range State
SRLB Global - 200000-210000 Active
SRGB Global - 16000-17000 Active
Table 10 Command output
Type |
Label block type, SRGB or SRLB. |
Protocol to which the label block belongs: · ISIS—A IS-IS process. · OSPF—An OSPF process. · Global—The label block is the global SRGB or SRLB, which is configured in segment routing view.. |
Process-ID |
ID of the protocol process that owns the label block. If label block is the global SRGB or SRLB, this field displays a hyphen (-). |
State |
Whether the label block is available for use: · Active—The label block is available for use. · Inactive—The label block is not available for use. |
Use display segment-routing mapping-server prefix-sid-map to display prefix-SID mappings.
display segment-routing mapping-server prefix-sid-map [ ip-address mask-length | verbose ]
ip-address: Specifies an IPv4 address prefix in dotted decimal notation.
mask-length: Specifies the mask length, in the range of 1 to 32.
verbose: Displays detailed information about all configured prefix-SID mappings.
If you do not specify any parameters, this command displays brief information about all configured prefix-SID mappings.
# Display the prefix-SID mapping for prefix 1.1.1.1.
<Sysname> display segment-routing mapping-server prefix-sid-map 1.1.1.1 32
SRMS mappings
Prefix SID index Flags
1.1.1.1/32 10 A
# Display all configured prefix-SID mappings.
SRMS mappings
1.1.1.1/32 10 100 A
2.2.2.2/32 256 520 -
# Display detailed information about all configured prefix-SID mappings.
<Sysname> display segment-routing mapping-server prefix-sid-map verbose
SRMS mappings
Prefix 1.1.1.1/32
SID index : 10
Range : 100
Last prefix : 1.1.1.100/24
Last SID index: 109
Flags : A
Prefix 2.2.2.2/32
SID index : 256
Range : 520
Last prefix : 2.2.4.9/24
Last SID index: 775
Flags : -
Table 11 Command output
SID index |
Range |
Flags |
Last Prefix |
Final prefix. |
Last SID index |
SID assigned to the final prefix. |
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance.
In IS-IS IPv4 unicast address family view:
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
In OSPF view:
FRR microloop avoidance is disabled.
OSPF view
level-1: Specifies FRR microloop avoidance for IS-IS Level-1.
level-2: Specifies FRR microloop avoidance for IS-IS Level-2.
Use this command only on the source node.
On an network configured with TI-LFA FRR, if a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. However, if a device along the backup path has not finished route convergence, traffic will be looped between the device and the source node (the node prior to the node or link that failed) until the device finishes route convergence.
To resolve this problem, configure microloop avoidance on the source node. Then, when a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. The source node waits for a period of time for other devices to finish route convergence. After the delay time elapses, the source node starts route convergence.
If you do not specify the level-1 or level-2 keyword, the command enables or disables FRR microloop avoidance on all IS-IS levels.
# Enable FRR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance enable
# Enable FRR microloop avoidance for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance enable
Use fast-reroute microloop-avoidance rib-update-delay to set the FRR microloop avoidance RIB-update-delay time.
Use undo fast-reroute microloop-avoidance rib-update-delay to restore the default.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
In OSPF view:
The FRR microloop avoidance RIB-update-delay time is 5000 ms.
OSPF view
delay-time: Specifies the FRR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-2.
If you do not specify the level-1 or level-2 keyword, the command sets the FRR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for Level-1 of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute microloop-avoidance rib-update-delay 6000 level-1
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute microloop-avoidance rib-update-delay 6000
fast-reroute ti-lfa
Use fast-reroute ti-lfa to enable Topology-Independent Loop-Free Alternate Fast Re-Route (TI-LFA FRR).
Use fast-reroute ti-lfa to disable TI-LFA FRR.
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
undo fast-reroute ti-lfa [ level-1 | level-2 ]
In OSPF view:
TI-LFA FRR is disabled.
OSPF view
level-1: Specifies TI-LFA FRR for IS-IS Level-1.
level-2: Specifies TI-LFA FRR for IS-IS Level-2.
per-prefix: Calculates backup information for each advertising source of a route. Specify this keyword only if routes are advertised by multiple sources. If you do not specify this keyword, the device calculates backup information for each route.
route-policy route-policy-name: Enables TI-LFA FRR for prefixes identified by the routing policy. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
host: Enables TI-LFA for host routes.
TI-LFA FRR provides link and node protection for SR tunnels. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
Before configuring TI-LFA FRR, you must execute the following commands in IS-IS IPv4 unicast address family view or OSPF view:
· segment-routing mpls
· fast-reroute lfa
TI-LFA FRR takes effect only after you enable LFA FRR.
TI-LFA FRR operates in a level only after you enable LFA FRR for the level.
If you do not specify the level-1 or level-2 keyword, the command enables or disables TI-LFA FRR for all IS-IS levels.
If you do not specify the route-policy route-policy-name option or the host keyword, the device calculates backup information for all routes.
# Enable TI-LFA FRR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute ti-lfa
# Enable TI-LFA FRR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute ti-lfa
fast-reroute (Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
global-block
Use global-block to configure the global MPLS SRGB.
Use undo global-block to restore the default.
global-block minimum-value maximum-value
undo global-block
The global MPLS SRGB is from 16000 to 24000.
Segment routing view
minimum-value: Specifies the minimum label value. The value range is 10241 to 1048574.
maximum-value: Specifies the maximum label value. The value range is 10242 to 1048575.
The global MPLS SRGB is used for prefix segments and BGP prefix SIDs. If no MPLS SRGB is configured for a protocol process, the process uses the global MPLS SRGB.
If you have configured prefix SIDs when you configure the global MPLS SRGB, the global MPLS SRGB must contain the configured prefix SIDs.
# Configure the global MPLS SRGB to be from 200000 to 220000.
[Sysname] segment-routing
[Sysname-segment-routing] global-block 200000 220000
isis adjacency-sid
Use isis adjacency-sid to assign an IS-IS adjacency SID to an IS-IS adjacency.
Use undo isis adjacency-sid to reclaim an IS-IS adjacency SID.
isis adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo isis adjacency-sid { absolute absolute-value | index index-value }
An IS-IS adjacency does not have an adjacency SID.
Interface view
absolute absolute-value: Specifies an absolute value as the adjacency SID. The value range for the absolute-value argument is 10241 to 1048575.
index index-value: Specifies an adjacency SID index value. The value range for the index-value argument is 0 to 1038334.
nexthop nexthop-address: Specifies a next hop by its IP address. If the network type of the interface is broadcast, you must specify this option. If the network type of the interface is P2P, you cannot specify this option.
After you enable SR-MPLS adjacency label allocation, the device randomly allocates adjacency SIDs to the links to its IGP neighbors. If the link to an IGP neighbor flaps, the adjacency SID of the link keeps changing. For a link to always use the same adjacency SID, use this command to assign a specific adjacency SID to the link.
You can assign adjacency SID by using absolute values or index values. If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
Before assigning adjacency SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as adjacency SIDs. Make sure the labels are in Idle state. A label that is not in Idle state is being used by another protocol. If you assign it to a link as an adjacency SID, the adjacency SID is not available even if the status of the label changes to Idle later. To use the adjacency SID, you must remove the adjacency SID assignment and assign the adjacency SID again.
Before executing the isis adjacency-sid command on an interface, you must complete the following tasks:
· Enable IS-IS on the interface.
· Execute the segment-routing mpls and segment-routing adjacency enable commands.
If you execute the isis adjacency-sid command multiple times on an interface of the P2P network type, the most recent configuration takes effect.
If you execute the isis adjacency-sid command multiple times on an interface of the broadcast network type, the effective configuration varies depending on how you specify the next hop address:
· If you specify a different next hop address each time, all configurations take effect.
· If you specify the same next hop address each time, the most recent configuration takes effect.
To change the network type of an interface, execute the isis circuit-type p2p command before executing the isis adjacency-sid command on the interface. To change the network type of an interface after assigning an adjacency SID to the interface, you must remove the assignment first.
If you execute this command on an interface after enabling SR-MPLS adjacency label allocation for an IGP, the interface prefers the assigned adjacency SID.
# Set the absolute value of the adjacency SID to 20000 on interface GigabitEthernet 2/0/1. Specify 1.1.1.1 as the next hop.
[Sysname-GigabitEthernet2/0/1] isis enable 1
[Sysname-GigabitEthernet2/0/1] isis adjacency-sid absolute 20000 nexthop 1.1.1.1
display mpls label (MPLS Command Reference)
isis circuit-type p2p (Layer 3—IP Routing Command Reference)
isis enable (Layer 3—IP Routing Command Reference)
Use isis fast-reroute ti-lfa disable to disable an IS-IS interface from participating in TI-LFA calculation.
Use undo isis fast-reroute ti-lfa disable to enable an IS-IS interface to participate in TI-LFA calculation.
isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
undo isis fast-reroute ti-lfa disable [ level-1 | level-2 ]
An IS-IS interface participates in TI-LFA calculation.
Interface view
level-1: Specifies TI-LFA calculation on IS-IS Level-1.
level-2: Specifies TI-LFA calculation on IS-IS Level-2.
Disable the output interface to the primary next hop from participating in TI-LFA calculation.
If you do not specify the level-1 or level-2 keyword, the command disables or enables the interface to participate in TI-LFA calculation in any level.
# Disable interface GigabitEthernet 2/0/1 from participating in TI-LFA calculation.
[Sysname-GigabitEthernet2/0/1] isis fast-reroute ti-lfa disable
fast-reroute ti-lfa
isis prefix-sid
Use isis prefix-sid to configure an IS-IS prefix SID.
Use undo isis prefix-sid to restore the default.
isis prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
No IS-IS prefix SID is configured.
Loopback interface view
absolute absolute-value: Specifies an absolute value as the prefix SID. The value range for the absolute-value argument is 10241 to 1048575.
index index-value: Specifies an index value in the range of 0 to 1038334.
n-flag-clear: Sets the Node-SID flag bit of the prefix SID to 0 to use the prefix SID for a group of SR nodes. If you do not specify this keyword, the flag bit is 1 and the prefix SID is used for a single SR node.
explicit-null: Sets the Explicit-null flag bit of the prefix SID to 1. This setting requires that the upstream neighbor uses an explicit null label to replace the prefix SID. If you do not specify this keyword, the flag bit is 0 and the upstream neighbor continues to forward the packet based on the prefix SID. For more information about the explicit null label, see MPLS basics configuration in MPLS Configuration Guide.
no-php: Sets the P-flag bit of the prefix SID to 1 so the penultimate hop does not pop out the SID. If you do not specify this keyword, the P-flag bit is 0 and the penultimate hop pops out the SID.
An absolute value used as the prefix SID must be in the SRGB of the node.
If you specify an index value, the sum of the index value and the SRGB base value is used as the prefix SID. The prefix SID must be in the SRGB of the node.
To use a prefix SID for a group of SR nodes in anycast scenarios, specify the n-flag-clear keyword to set the Node-SID flag bit of the prefix SID to 0.
To configure an IS-IS prefix SID, you must enable an IS-IS process on the loopback interface.
If you execute this command on an interface multiple times, the most recent configuration takes effect.
# Set the IS-IS prefix SID index value to 20 on loopback interface 1.
[Sysname] interface loopback 1
[Sysname-LoopBack1] isis enable 1
[Sysname-LoopBack1] isis prefix-sid index 20
local-block
Use local-block to configure the SRLB.
Use undo local-block to restore the default.
local-block minimum-value maximum-value
undo local-block
The MPLS SRLB is from 15000 to 15999.
The segment routing local block (SRLB) is the range of local labels dedicated for SR-MPLS adjacency SIDs.
Before executing this command, use the display mpls label command to display MPLS label usage information. Make sure that all labels in the specified range are idle. If a label in the range is not idle, the MPLS SRLB takes effect only after you save the running configuration and reboot the device.
# Configure the SRLB to be from 200000 to 220000.
[Sysname-segment-routing] local-block 200000 220000
Use mapping-server prefix-sid-map to configure a prefix-SID mapping.
Use undo mapping-server prefix-sid-map to delete a prefix-SID mapping.
mapping-server prefix-sid-map ip-address mask-length start-value [ range range-value ] [ attached ]
undo mapping-server prefix-sid-map ip-address mask-length
No prefix-SID mappings exist.
ip-address: Specifies an IPv4 address prefix to be mapped or specifies the start IP prefix for a range of prefix-SID mappings, in dotted decimal notation.
start-value: Specifies the index value of the SID to be mapped to the specified prefix, or specifies the index value of the start SID for a range of prefix-SID mappings. The value range for this argument is 0 to 1038333.
range range-value: Specifies the number of prefix-SID mappings, in the range of 1 to 1038334. Specify this option if you want to configure more than one mapping by using a single command. The system creates the specified number of mappings, starting from the start IP prefix and SID index value. The increment step for the prefix and SID index value is 1.
attached: Specifies that the specified prefixes represent local networks.
The specified prefixes must not belong to any existing prefix-SID mappings.
Before you configure prefix-SID mappings in bulk, plan the number of mappings. Make sure there are enough mappings to use.
If you specify a value greater than 65535 for the range-value argument, the prefix-SID mappings cannot be advertised through IS-IS or OSPF.
# Map prefix 1.1.1.1/32 to SID index value 100.
[Sysname-segment-routing] mapping-server prefix-sid-map 1.1.1.1 32 100
# Configure two prefix-SID mappings, starting from prefix 10.1.1.1/32 and SID index value 200.
[Sysname-segment-routing] mapping-server prefix-sid-map 10.1.1.1 32 200 range 2
In the first mapping, the prefix is 10.1.1.1/32 and the SID is 200. In the second mapping, the prefix is 10.1.1.2/32 and the SID is 201.
mpls te static-sr-mpls
Use mpls te static-sr-mpls to bind a static SRLSP to an MPLS TE tunnel interface.
Use undo mpls te static-sr-mpls to unbind a static SRLSP from an MPLS TE tunnel interface.
mpls te static-sr-mpls lsp-name [ backup ]
undo mpls te static-sr-mpls lsp-name
An MPLS TE tunnel interface does not use any static SRLSPs.
Tunnel interface view
lsp-name: Specifies a static SRLSP by its name, a case-sensitive string of 1 to 15 characters. The specified static SRLSP must be already created by using the static-sr-mpls lsp command.
backup: Specifies the backup static SRLSP. If you do not specify this keyword, this command specifies the main static SRLSP.
Execute this command only on the ingress node of a static SRLSP.
This command takes effect only if you have configured the mpls te signaling static command in tunnel interface view.
You can specify the backup keyword to bind a backup static SRLSP only if both the main and backup SRLSPs are established by using the adjacency segment method.
If you execute both the mpls te static-sr-mpls and mpls te static-cr-lsp commands on the device, only the mpls te static-cr-lsp command takes effect. For the mpls te static-sr-mpls command to take effect, execute the undo mpls te static-cr-lsp command.
# Bind static SRLSP static-sr-3 to MPLS TE tunnel interface 0.
[Sysname] interface tunnel 0 mode mpls-te
[Sysname-Tunnel0] mpls te static-sr-mpls static-sr-3
display mpls te tunnel-interface (MPLS Command Reference)
mpls te signaling (MPLS Command Reference)
mpls te static-cr-lsp (MPLS Command Reference)
static-sr-mpls lsp
ospf adjacency-sid
Use ospf adjacency-sid to assign an OSPF adjacency SID to an OSPF adjacency.
Use undo ospf adjacency-sid to reclaim an OSPF adjacency SID.
ospf adjacency-sid { absolute absolute-value | index index-value } [ nexthop nexthop-address ]
undo ospf adjacency-sid { absolute absolute-value | index index-value }
An OSPF adjacency does not have an adjacency SID.
Interface view
index index-value: Specifies an adjacency SID index value in the range of 0 to 1038334.
nexthop nexthop-address: Specifies a next hop by its IP address. If the network type of the interface is not P2P, you must specify this option. If the network type of the interface is P2P, you cannot specify this option.
You can assign adjacency SID by using absolute values or index values. If you If you use index values, the adjacency SID of a link is the base value of the SRLB plus the index value for the link.
The ospf adjacency-sid command takes effect only after you execute the segment-routing mpls and segment-routing adjacency enable commands.
If you execute the ospf adjacency-sid command on an interface after enabling SR-MPLS adjacency label allocation for an IGP, the interface prefers the assigned adjacency SID.
If you execute the ospf adjacency-sid command multiple times on an interface of the P2P network type, the most recent configuration takes effect.
If you execute the ospf adjacency-sid command multiple times on an interface of the broadcast network type, the effective configuration varies depending on how you specify the next hop address:
To change the network type of an interface, execute the ospf network-type command.
# Set the absolute value of the adjacency ID to 20000 on interface GigabitEthernet 2/0/1. Specify 1.1.1.1 as the next hop.
[Sysname-GigabitEthernet2/0/1] ospf adjacency-sid absolute 20000 nexthop 1.1.1.1
ospf network-type (Layer 3—IP Routing Command Reference)
Use ospf fast-reroute ti-lfa disable to disable an OSPF interface from participating in TI-LFA calculation.
Use undo ospf fast-reroute ti-lfa disable to enable an OSPF interface to participate in TI-LFA calculation.
An OSPF interface participates in TI-LFA calculation.
Interface view
On the source node, the route's output interface to the primary next hop might not be on the backup path calculated by TI-LFA. Disable TI-LFA on the interface to prevent it from participating in TI-LFA calculation.
[Sysname-GigabitEthernet2/0/1] ospf fast-reroute ti-lfa disable
fast-reroute ti-lfa (OSPF view)
ospf prefix-sid
Use ospf prefix-sid to configure an OSPF prefix SID.
Use undo ospf prefix-sid to restore the default.
ospf process-id prefix-sid { absolute absolute-value | index index-value } [ n-flag-clear | { explicit-null | no-php } ] *
undo ospf process-id prefix-sid
No OSPF prefix SID is configured.
The configured OSPF prefix SID takes effect only if the OSPF process enabled on the loopback interface is the same as the OSPF process associated with the prefix SID.
# Set the OSPF prefix SID index value to 20 on loopback interface 1.
[Sysname-LoopBack1] ospf 1 prefix-sid index 20
peer egress-engineering
Use peer egress-engineering to enable BGP EPE for a peer or peer group and specify a routing policy to assign a label (SID) to the peer or peer group.
Use undo peer egress-engineering to restore the default for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } egress-engineering [ adjacency | set ] [ route-policy policy-name ]
undo peer { group-name | ipv4-address [ mask-length ] } egress-engineering
BGP EPE is disabled.
BGP instance view
group-name: Specifies an existing peer group by its name, a case-sensitive string of 1 to 47 characters.
mask-length: Specifies the mask length, in the range of 0 to 32. This argument and the ipv4-address argument together specify a subnet. If you specify this argument, the command applies to dynamic peers on the specified subnet.
adjacency: Assigns a Peer-Adjacency-SID.
set: Assigns a Peer-Set-SID.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the device assigns SIDs to neighbors randomly.
If you do not specify the adjacency or set keyword, the device assigns a Peer-Node-SID.
You cannot assign the same SID to multiple BGP peers or peer groups.
You can specify the same routing policy for different BGP peers or peer groups only when you assign Peer-Set-SIDs to the BGP peers or peer groups.
You can use if-match interface as a filtering condition only when you assign Peer-Adjacency-SIDs to BGP peers or peer groups.
Before assigning BGP-EPE SIDs, execute the display mpls label command to display the usage status of the labels that you want to assign as BGP-EPE SIDs. Make sure the labels are in Idle state. A label that is not in Idle state is being used by another protocol. If you assign it as a BGP-EPE SID, the BGP-EPE SID is not available even if the status of the label changes to Idle later. To use the BGP-EPE SID, you must remove the BGP-EPE SID assignment and assign the BGP-EPE SID again.
# Enable BGP EPE for peer 1.1.1.1 and assign a Peer-Node-SID to the peer.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 egress-engineering
segment-routing
Use segment-routing to enable segment routing and enter segment routing view.
Use undo segment-routing to disable segment routing.
segment-routing
Segment routing is disabled.
To configure the Segment Routing Mapping Server (SRMS) features, you must execute this command on the SRMS. The SRMS is an entity that advertises prefix-SID mappings in an IGP. By deploying an SRMS, you can allocate SIDs to devices that do not support SR-MPLS, allowing for SR-MPLS and LDP interworking.
# Enable segment routing and enter segment routing view.
Use segment-routing adjacency enable to enable SR-MPLS adjacency label allocation.
Use undo segment-routing adjacency enable to disable SR-MPLS adjacency label allocation.
SR-MPLS adjacency label allocation is disabled.
OSPF view
For this command to take effect, you must enable SR-MPLS.
# Enable SR-MPLS adjacency label allocation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing adjacency enable
# Enable SR-MPLS adjacency label allocation for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing adjacency enable
Use segment-routing global-block to configure the MPLS SRGB.
Use undo segment-routing global-block to restore the default.
segment-routing global-block minimum-value maximum-value
The MPLS SRGB is from 16000 to 24000.
IS-IS view
OSPF view
minimum-value: Specifies the minimum label value, in the range of 10241 to 1048574.
maximum-value: Specifies the maximum label value, in the range of 10242 to 1048575.
If you have configured prefix SIDs when you configure the SRGB, the SRGB must contain the configured prefix SIDs. If the SRGB does not contain the configured prefix SIDs, the configured prefix SIDs do not take effect.
In the following situations, the configured SRGB takes effect after a device reboot:
· The SRGB contains a label that is already used by another protocol. For example, the SRGB contains a label that is already used by LDP.
· The SRGB overlaps with the label range of another protocol. For example, the SRGB for OSPF process 1 overlaps with the SRGB for IS-IS process 1.
# Configure the MPLS SRGB to be from 17000 to 22000 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] segment-routing global-block 17000 22000
# Configure the MPLS SRGB to be from 17000 to 22000 for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing global-block 17000 22000
global-block
Use segment-routing label-advertise to specify the type of label for the device to advertise to the penultimate hop when the device acts as the egress in an SR-MPLS network.
Use undo segment-routing label-advertise to restore the default.
segment-routing label-advertise { explicit-null | non-null }
As egress, the device advertises an implicit null label of 3 to the penultimate hop.
BGP IPv4 unicast address family view
explicit-null: Advertises an explicit null label of 0 to the penultimate hop.
non-null: Advertises a non-null label to the penultimate hop.
As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels. In this case, the egress node assigns an SID to the penultimate hop based on the prefix SID information in the BGP IPv4 unicast route.
If you change the type of label for the device to advertise to the penultimate hop, the device will close all SRLSPs established based on BGP IPv4 unicast routes. Then, the device will re-establish SRLSPs, using the new label type.
Before executing the command, you must execute the segment-routing mpls command to enable SR-MPLS.
# Configure the device to advertise an explicit null label to the penultimate hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing label-advertise explicit-null
Use segment-routing mapping-server advertise-local to enable advertisement of locally configured prefix-SID mappings.
Use undo segment-routing mapping-server advertise-local to disable advertisement of locally configured prefix-SID mappings.
Advertisement is disabled for locally configured prefix-SID mappings.
OSPF view
In an SR to LDP interworking scenario, you must execute this command on the SRMS so the device advertises locally configured prefix-SID mappings to neighbors.
# Enable IS-IS to advertise locally configured prefix-SID mappings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing mapping-server advertise-local
# Enable OSPF to advertise locally configured prefix-SID mappings for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mapping-server advertise-local
Use segment-routing mapping-server receive to enable reception of prefix-SID mappings.
Use undo segment-routing mapping-server receive to disable reception of prefix-SID mappings.
Reception of prefix-SID mappings is enabled.
OSPF view
In an SR to LDP interworking scenario, you must execute this command on the SRMCs so they can identify the prefix-SID mappings advertised by the SRMS.
# Disable reception of prefix-SID mappings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] undo segment-routing mapping-server receive
# Disable reception of prefix-SID mappings for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] undo segment-routing mapping-server receive
mapping-server prefix-sid-map advertise-local
Use segment-routing microloop-avoidance enable to enable SR microloop avoidance.
Use undo segment-routing microloop-avoidance enable to disable SR microloop avoidance.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
undo segment-routing microloop-avoidance enable [ level-1 | level-2 ]
SR microloop avoidance is disabled.
level-1: Specifies SR microloop avoidance for IS-IS Level-1.
level-2: Specifies SR microloop avoidance for IS-IS Level-2.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of non-simultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
If you execute both this command and the fast-reroute microloop-avoidance enable command, this command takes effect.
If you do not specify the level-1 or level-2 keyword, the segment-routing microloop-avoidance enable command enables or disables SR microloop avoidance on all IS-IS levels.
# Enable SR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance enable
Use segment-routing microloop-avoidance rib-update-delay to set the SR microloop avoidance RIB-update-delay time.
Use undo segment-routing microloop-avoidance rib-update-delay to restore the default.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The SR microloop avoidance RIB-update-delay time is 5000 ms.
delay-time: Specifies the SR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the SR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the SR microloop avoidance RIB-update-delay time for IS-IS Level-2.
To leave sufficient time for IGP to finish route convergence, specify a proper value for the SR microloop avoidance RIB-update-delay timer. Before the timer expires, failure relevant devices will forward traffic along the specified path. After the timer expires, traffic will traverse the usual path.
If you do not specify the level-1 or level-2 keyword, this command sets the SR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the SR microloop avoidance RIB-update-delay time to 6000 ms for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing microloop-avoidance rib-update-delay 6000
Use segment-routing mpls to enable SR-MPLS.
Use undo segment-routing mpls to disable SR-MPLS.
SR-MPLS is disabled.
OSPF view
For SR-MPLS to take effect, perform the following tasks before configuring the IGP to support SR-MPLS:
· If the IGP is IS-IS, set the cost style to wide, compatible, or wide-compatible. For more information about the cost style, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
· If the IGP is OSPF, enable opaque LSA reception and advertisement capability. For more information about the capability, see OSPF configuration in Layer 3—IP Routing Configuration Guide.
# Enable SR-MPLS in IS-IS IPv4 unicast address family view of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1-ipv4] segment-routing mpls
# Enable SR-MPLS for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing mpls
# Enable SR-MPLS for the BGP IPv4 unicast address family.
[Sysname] bgp 100
[Sysname-bgp-default] address family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing mpls
cost-style (Layer 3—IP Routing Command Reference)
opaque-capability enable (Layer 3—IP Routing Command Reference)
Use segment-routing prefix-sid-map to enable prefix-SID mappings.
Use undo segment-routing prefix-sid-map to disable prefix-SID mappings.
Prefix-SID mappings are disabled.
After you execute this command on the SRMCs, the device will assign SIDs to prefixes based on prefix-SID mappings when it receives BGP IPv4 unicast routes from neighbors. The prefix-SID mappings are configured by using the mapping-server prefix-sid-map command.
If a BGP route contains an SID but there is a prefix-SID mapping for the prefix, the device assigns the SID in the mapping to the prefix.
Before executing this command, execute the segment-routing mpls command to enable SR-MPLS.
# Enable prefix-SID mappings in BGP IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing prefix-sid-map
segment-routing sr-prefer
Use segment-routing sr-prefer to configure the device to prefer SRLSPs in traffic forwarding.
Use undo segment-routing sr-prefer to restore the default.
segment-routing sr-prefer [ prefix-list prefix-list-name ]
The device prefers LDP LSPs in traffic forwarding.
OSPF view
prefix-list prefix-list-name: Specifies an IP address prefix list by its name, a case-sensitive string of 1 to 63 characters. The device preferentially uses SRLSPs to forward traffic destined for addresses on the prefix list, and preferentially uses LDP LSPs to forward traffic destined for other addresses. If you do not specify an IP address prefix list, the device preferentially uses SRLSPs to forward all traffic.
This command determines whether the device prefers SRLSPs or LDP LSPs when both SRLSPs and LDP LSPs are available for traffic forwarding.
This command takes effect only when SR-MPLS is enabled and the SRLSPs use prefix SIDs.
# Configure the device to preferentially use SRLSPs established by OSPF to forward all traffic.
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing sr-prefer
# Configure the device to preferentially use SRLSPs established by OSPF to forward traffic that is identified by prefix list 8.
[Sysname] ip prefix-list 8 permit 4.4.4.4 32
[Sysname] ospf 1
[Sysname-ospf-1] segment-routing sr-prefer prefix-list 8
ip prefix-list (Layer 3—IP Routing Command Reference)
Use static-sr-mpls adjacency to configure an adjacency segment for static SR-MPLS.
Use undo static-sr-mpls adjacency to delete an adjacency segment.
static-sr-mpls adjacency adjacency-path-name in-label label-value { nexthop ip-address | outgoing-interface interface-type interface-number }
undo static-sr-mpls adjacency adjacency-path-name
No adjacency segments exist.
adjacency-path-name: Specifies the adjacency segment name, a case-sensitive string of 1 to 15 characters.
in-label label-value: Specifies the incoming label, in the range of 16 to 10240.
nexthop ip-address: Specifies the next hop address.
outgoing-interface interface-type interface-number: Specifies an output interface by its type and number. The output interface must be a P2P interface.
Execute this command on all nodes of a static SRLSP.
If you specify the next hop address, make sure the following requirements are met:
· The device has a route to reach the next hop address.
· MPLS is enabled on the output interface of the route.
If you specify an output interface, make sure the following requirements are met:
· The interface is up.
· The interface can receive direct routes.
· MPLS is enabled on the interface.
The incoming label specified by this command must be different than existing static LSPs, static PWs, and static CRLSPs. If not, the configured adjacency segment is unavailable. The adjacency segment cannot become available even if you change the incoming label of the static LSP, static PW, or static CRLSP. To resolve this problem, you must delete the existing adjacency segment and configure a new one with a different incoming label.
# Configure an adjacency segment named adj1. Set the incoming label to 100 and the next hop address to 12.2.1.2.
[Sysname] static-sr-mpls adjacency adj1 in-label 100 nexthop 12.2.1.2
display static-sr-mpls
static-sr-mpls lsp
static-sr-mpls lsp
Use static-sr-mpls lsp to configure a static SRLSP.
Use undo static-sr-mpls lsp to delete a static SRLSP.
static-sr-mpls lsp lsp-name out-label out-label-value&<1-n>
undo static-sr-mpls lsp lsp-name
No static SRLSPs exist.
lsp-name: Specifies the static SRLSP name, a case-sensitive string of 1 to 15 characters.
out-label out-label-value&<1-n>: Specifies a space-separated list of up to n outgoing labels, corresponding to the labels from top to bottom in the label stack. The value range for the out-label-value argument is 0, 3, and 16 to 1048575. The n is 15.
The outgoing labels represent an ordered list of labels allocated for the adjacencies or nodes that a static SRLSP traverses. The top label is the label that the ingress node allocates for the adjacency or destination prefix.
# Configure a static SRLSP named lsp1. Specify outgoing labels 100 and 200 for the SRLSP.
[Sysname] static-sr-mpls lsp lsp1 out-label 100 200
Use static-sr-mpls prefix to configure a prefix segment for static SR-MPLS.
Use undo static-sr-mpls prefix to delete a prefix segment.
static-sr-mpls prefix prefix-path-name destination ip-address { mask | mask-length } in-label in-label-value [ { nexthop ip-address | outgoing-interface interface-type interface-number } out-label out-label-value ]
undo static-sr-mpls prefix prefix-path-name [ destination ip-address { mask | mask-length } in-label in-label-value [ nexthop ip-address | outgoing-interface interface-type interface-number ] ]
No prefix segments exist.
prefix-path-name: Specifies the prefix segment name, a case-sensitive string of 1 to 15 characters.
destination ip-address: Specifies the destination IP address.
mask: Specifies the mask.
in-label label-value: Specifies the incoming label, in the range of 16000 to 24000.
out-label out-label-value: Specifies the outgoing label, in the range of 0, 3, and 16 to 1048575.
A prefix segment must use the next hop or output interface of the optimal route (non-BGP route) to the destination address of the prefix segment. You can configure multiple prefix segments to the destination address for load sharing if the optimal route has more than one next hops or output interfaces. To avoid configuration failure, make sure all prefix segments use the same prefix segment name, and incoming label.
If you specify only the prefix-path-name argument, the undo static-sr-mpls prefix command deletes all prefix segments with the specified name. If you specify all parameters, only the prefix segment that matches the specified name, destination IP address, and next hop or output interface is deleted.
# Configure a prefix segment named prefix1. Set the destination IP address, incoming label, outgoing label, and next hop to 2.2.2.2, 16000, 16001, and 10.0.0.2, respectively.
[Sysname] static-sr-mpls prefix prefix1 destination 2.2.2.2 32 in-label 16000 nexthop 10.0.0.2 out-label 16001
