H3C SecCenter SMP
Release time:2022-07-07
HomeSupportSecurityH3C SecCenter SMPSoftware DownloadSecCenter SMP
Download
SecCenterSMP-E1704P02 Release Notes
Introduction· 1
Version information· 1
Version number 1
Version history· 1
Hardware and software compatibility matrix· 1
Upgrade restrictions and guidelines· 2
Hardware feature updates· 2
Software feature updates· 2
MIB updates· 2
Operation changes· 2
Restrictions and cautions· 2
Licensing· 3
About licensing· 3
Registering and installing licenses· 3
Open problems and workarounds· 3
List of resolved problems· 4
Resolved problems in SecCenterSMP-E1704P02· 4
Resolved problems in SecCenterSMP-E1704P01· 5
Resolved problems in SecCenterSMP-E1704· 5
Troubleshooting resources· 5
Related documentation· 5
Documentation set 5
Obtaining documentation· 5
Technical support 6
Appendix A Feature list 7
Hardware features· 7
Software features· 7
Appendix B Upgrading software· 9
List of tables
Table 1 Compatibility matrix. 1
Table 2 Software features of SMP. 7
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version SecCenterSMP-E1704P01. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with the documents listed in Related documentation.
Version information
Version number
Version history
Version number
Last version
Release date
Release type
Remarks
2022/06/28
ESS
Fixed bugs.
SecCenterSMP-E1704
2022/04/22
ESS
Fixed bugs.
SecCenterSMP-E1704
SecCenterSMP-E1110P06
2021/06/29
ESS
Fixed bugs.
CAUTION:
To avoid an upgrade failure, use the following to verify the hardware and software compatibility before performing an upgrade.
Item
H3C SecCenterSMP series
Model
SecCenterSMP
Installation file
SecCenterSMP_E1704P02_EN.iso (package for virtualized deployment)
Server version
H3Linux 1.1.1
Installation host OS
N/A
Browsers
Google Chrome 57 or higher
Remarks
N/A
Initial deployment version for the SMP English edition. Upgrade is not supported.
SMP is a software product and contains no hardware features.
N/A.
MIB updates
N/A
Operation changes
N/A
For browsers
To get better display, use browsers Google Chrome 57 or higher.
For the operating system
Set the time zone in the operating system to Shanghai East 8 district.
For device version compatibility
·            Compatible device versions are D032 and D045.
·            Configure the device to use the local time in the log timestamp. If you configure the device to use the standard GMT, the log timestamp displayed on the SMP will be different from that on the device.
·            The system supports receiving a maximum of 10000 log messages per second from devices. Exceeding logs will be dropped.
Licensing
About licensing
H3C offers licensing options for you to deploy features and expand resource capacity on an as needed basis. To use license-based features, purchase licenses from H3C and install the licenses.
To register and transfer licenses, access H3C license services at http://www.h3c.com/en/License.
For information about registering licenses, installing activation files, and transferring licenses, see 《H3C SecCenter SMP Licensing Guide-5W100》。
202103301207
·            Symptom: The area collector drop-down list contains no options sometimes, resulting in area creation failure.
·            Condition:None.
·            Workaround: Restart the cloudops service in the CLI.
202010261209
·            Symptom: You cannot delete, edit, or redeploy the IPS whitelist entries that failed to be deployed due to exceeding the maximum number of entries allowed.
·            Condition:None.
·            Workaround: None.
202104230453
·            Symptom: When you add or edit a security zone, if you change the device after interfaces are selected, the interface list for the security zone retains the interfaces previously selected.
·            Condition:None.
·            Workaround: None.
202009160688
·            Symptom: Create vulnerability and virus subrules for a correlation rule. The subrules require full match. Construct logs that match the subrules. The generated security events contain only vulnerability logs.
·            Condition:None.
·            Workaround: None.
202004070875
·            Symptom: Bulk synchronize assets. During the synchronization, the asset CPU usage and memory usage are not displayed. After you restart the cloudops service, the SMP cannot obtain the CPU usage and memory usage of some assets.
·            Condition:None.
·            Workaround: None.
202003060735
·            Symptom: When you import a license that contains hierarchical management authorization, the cloudops service will restart. In this case, you are unable to log in to the system, and the webpage prompts “Failed to obtain license information” or “Please import the correct license.” If you import other licenses, the licenses cannot be activated.
·            Condition:None.
·            Workaround: Include one hierarchical management license in the first license file imported to system. Do not include a hierarchical management license in subsequent imports of licenses.
202204221243
·            Symptom: System leave some chinese chracters to be translated.
·            Condition:None.
·            Workaround: None.
202206140791
·            Symptom: Some Belt and Road Initiative countries are not available in the country list for SMP license registration.
·            Condition: This symptom occurs when you request and register the SMP license.
202205251156
·            Symptom: The H3Linux interface displays information in Chinese when you install the English version SMP system by using an ISO file.
·            Condition: This symptom occurs when you install English version SMP system by using an ISO file.
202106290415
·            Symptom: For initial import of licenses to the platform, if the licenses imported include the hierarchical management license, the number of the hierarchical management license generated in the platform is greater than 1, and the license cannot be activated. For additional import of licenses to the platform, if the licenses imported include the hierarchical management license, the platform prompts that you should import the correct license.
·            Condition: None.
202106281458
·            Symptom: The cumulative number of licenses in the SMP platform is incorrect. It records only one Additional 1 Node License.
·            Condition: None.
To obtain troubleshooting resources for the product:
1.      Access Technical Documents at http://www.h3c.com/en/Technical_Documents.
2.      Select the device category and model.
3.      Select the Maintain or Maintenance menu.
Documentation set
·            H3C SecCenter SMP Web Configuration Guides(E1704)-5W100
·            H3C SecCenter SMP Configuration Examples (E1704)-5W100
·            H3C SecCenter SMP FAQ(E1704)-5W100
·            H3C SecCenter SMP Troubleshooting Guide(E1704)-5W100
To obtain related documents from the H3C website at
https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/
Technical support
To obtain technical assistance, contact H3C by using one of the following methods:
·            Email:
h3cts@h3c.com (countries and regions except Hong Kong, China)
service_hk@h3c.com (Hong Kong, China)
·            Technical support hotline number. To obtain your local technical support hotline number, go to the H3C Service Hotlines website: https://www.h3c.com/en/Support/Online_Help/Service_Hotlines/
To access documentation, go to the H3C website at http://www.h3c.com/en/.
Hardware features
Software features
Categories
Features
Dashboard
CPU Usage
Memory Usage
Session Trend
IPS Attack Destination IPs
IPS Attack Source and Destination IPs
IPS Blocked Events
Attack Trend Chart
Device Log Receiving Trend Chart
Alarm Events
Alarm Events
Alarm Rules
Alarm Notification Policies
Alarm Notification Records
Log Audit
Vulnerability Attack Log
Virus Attack Log
NAT Session Log
NAT444 Port Block Log
NAT444 Session Log
Application Audit Logs
Security Analysis
Security Event Analysis
Reports
Report Files
Report Tasks
Report Templates
O&M
Areas
Device Groups
Monitored Assets
Security Services
Signature Libraries
System Settings
Global Settings
System Monitoring
Roles & Privileges
Logging
Customization
System Info
Licenses
Hierarchy
The SMP English edition supports only virtualized deployment by using an ISO package. Upgrade is not supported.
