01-Fundamentals Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-8C Switch Command References-Release 66xx-6W10301-Fundamentals Command Reference
08-Preprovisioning commands
08-Preprovisioning commands 50.25 KB
display provision failed-config
Use display provision failed-config to display preprovisioned-commands application failure records.
A preprovisioned command cannot be applied if it conflicts with the running configuration.
Use this command to verify the application result of preprovisioned commands except for the following commands:
·     duplex
·     speed
·     sflow
To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands.
# Display preprovisioned-commands application failure records.
<Sysname> display provision failed-config
Configuration applied at: Sat Jun 14 06:06:00 2014
Slot information: slot 1
Commands that failed to be applied:
interface HundredGigE 1/1/1
 speed 100000
provision
reset provision failed-config
provision
Use provision to enable preprovisioning.
Use undo provision to disable preprovisioning.
provision subslot subslot-number model model
undo provision subslot subslot-number model
Preprovisioning is disabled.
Slot view
subslot subslot-number: Specifies a subslot by its subslot number.
model model: Specifies the subcard model to be preprovisioned. To obtain available models, enter a question mark (?) for the model argument.
CAUTION
CAUTION:
When you disable preprovisioning on a subslot, the device removes preconfigured settings for the subslot.
This command allows you to enable preprovisioning on offline modules, including subcards.
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command will not display these interfaces until the module comes online.
# Enable preprovisioning for the LSW1D16H subcard on a slot.
[Sysname] slot 1
[Sysname-slot-1] provision subslot 1 model LSW1D16H
slot
Use reset provision failed-config to clear preprovisioned-commands application failure records.
Preprovisioned modules that repeatedly come online and go offline might leave in memory a large number of commands that were not applied. To release the occupied memory space, execute the reset provision failed-config command.
# Clear preprovisioned-commands application failure records.
<Sysname> reset provision failed-config
provision
slot
Use slot to select a slot to provision and enter slot view.
slot slot-number
slot-number: Specifies the slot number of the device, which is fixed at 1.
# Enter the view of a slot.
[Sysname] slot 1
[Sysname-slot-1]
provision
