06-High Availability Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath IPS Comware 7 Command References (R8560 R8660)-6W60006-High Availability Command Reference
01-High availability group commands
01-High availability group commands 143.02 KB
adjust-cost enable
Use adjust-cost enable to enable the HA group to adjust the link cost for the specified routing protocol on the standby device.
Use undo adjust-cost enable to disable the HA group from adjusting the link cost for the specified routing protocol on the standby device.
adjust-cost { ospf | ospfv3 } enable { absolute [ absolute-cost ] | increment [ increment-cost ] }
undo adjust-cost { ospf | ospfv3 } enable
The HA group does not adjust the link cost for the specified routing protocol on the standby device.
HA group view
ospf: Specifies the OSPF protocol.
ospfv3: Specifies the OSPFv3 protocol.
absolute [ absolute-cost ]: Specifies an absolute cost in the range of 1 to 65535. The default value is 65500. If you specify this option, the standby device will advertise an absolute link cost for the specified routing protocol.
increment [ increment-cost ]: Specifies an increment cost in the range of 1 to 65535. The default value is 100. If you specify this option, the standby device will advertise the original link cost plus this increment cost for the specified routing protocol.
In an HA group, the routing protocols on the HA group member devices advertise link cost according to their respective operation mechanisms. This command allows you to enable the routing protocols to advertise link cost modified as configured. The active device still uses the original link cost advertisement method.
To ensure switchover of both uplink and downlink traffic to the new active device, configure this command with the same parameters on both HA group member devices.
In dual-active mode, both devices advertise link cost according to the operation mechanisms of the running routing protocols. When one device is faulty and becomes the standby device, it will advertise link cost modified as configured.
To enable the feature for multiple routing protocols, execute this command multiple times by specifying the protocols.
If you execute the command multiple times for a specific routing protocol, the most recent configuration takes effect.
# Enable the HA group to adjust OSPF link cost on the standby device by specifying an absolute value of 6000.
[Sysname] remote-backup group
[Sysname-remote-backup-group] adjust-cost ospf enable absolute 6000
backup-mode
Use backup-mode to configure the HA mode.
Use undo backup-mode to restore the default.
backup-mode dual-active
undo backup-mode
The HA mode is active/standby.
HA group view
The HA group supports active/standby mode and dual-active mode. In active/standby mode, only the active device processes services. In dual-active mode, both devices process services.
Changing the dual-active mode to active/standby mode might affect services. Make sure you understand the potential impact before performing the operation.
# Configure the dual-active mode.
[Sysname-remote-backup-group] backup-mode dual-active
configuration auto-sync enable
Use configuration auto-sync enable to enable automatic configuration synchronization.
Use undo configuration auto-sync enable to disable automatic configuration synchronization.
Automatic configuration synchronization is enabled.
HA group view
The automatic configuration synchronization feature synchronizes existing configuration on the primary device in bulk to the secondary device. Consequent synchronization for added, deleted, or modified configuration will be performed in real time.
If the amount of configuration to be synchronized is large, bulk synchronization might take one to two hours.
# Enable automatic configuration synchronization.
[Sysname-remote-backup-group] configuration auto-sync enable
configuration manual-sync
Use configuration manual-sync to manually synchronize the configuration of the primary device to the secondary device.
HA group view
This command takes effect only on the primary device.
This command does not take effect when bulk configuration backup is in progress. To view the backup progress, execute the display remote-backup-group status command.
# Manually synchronize the configuration of the primary device to the secondary device.
[Sysname-remote-backup-group] configuration manual-sync
configuration manual-sync-check
Use configuration manual-syn-check to perform a one-off configuration consistency check.
HA group view
This command allows you to perform a one-off configuration consistency check as needed. If the system detects configuration inconsistency, it generates a log for you to manually synchronize configuration. To view the check result, execute the display remote-backup-group sync-check command.
# Perform a one-off configuration consistency check.
[Sysname-remote-backup-group] configuration manual-sync-check
configuration sync-check
Use configuration sync-check to enable configuration consistency check.
Use undo configuration sync-check to restore the default.
configuration sync-check [ interval interval ]
Configuration consistency check is enabled.
HA group view
interval interval: Specifies the configuration consistency check interval, in the range of 1 to 168 hours. The default value is 24.
The HA group verifies configuration consistency between the primary and secondary devices to avoid service interruption upon active/standby switchover. If a device detects configuration inconsistency, it generates a log for you to manually synchronize configuration.
# Enable configuration consistency check and set the check interval to 120 hours.
<Sysname>system-view
[Sysname-remote-backup-group] configuration sync-check interval 120
data-channel
Use data-channel to configure an HA data channel.
Use undo data-channel to restore the default.
data-channel interface interface-type interface-number
undo data-channel
No HA data channel is configured.
HA group view
interface interface-type interface-number: Specifies an interface by its type and number to set up a data channel between the primary and secondary devices.
The primary and secondary devices use the interface specified in the command to set up an HA data channel. The data channel transmits only backup packets and the packets that require transparent transmission.
The data channel is a Layer 2 channel that can transverse only Layer 2 switches.
# Set up an HA data channel using interface GigabitEthernet 1/0/1.
[Sysname-remote-backup-group] data-channel interface gigabitethernet 1/0/1
delay-time
Use delay-time to enable traffic switchover upon failure recovery.
Use undo delay-time to disable traffic switchover upon failure recovery.
delay-time delay-time
undo delay-time
Traffic switchover upon failure recovery is disabled.
HA group view
delay-time: Specifies the switchover delay time in the range of 1 to 1440 minutes.
After an active/standby switchover in an HA group, if the original active device recovers, traffic will not be switched back by default. Perform this task to enable traffic switchover to the original active device upon failure recovery. You can set a delay timer to ensure smooth service switchover.
In dual-active mode, you must configure this command to ensure that both devices can operate after the failure is recovered.
# Enable traffic switchover upon failure recovery and set the switchover delay time to two minutes.
[Sysname-remote-backup-group] delay-time 2
device-role
Use device-role to configure the HA role.
Use undo device-role to restore the default.
device-role { primary | secondary }
undo device-role
The HA role is not configured.
HA group view
primary: Assigns the primary role to the device.
secondary: Assigns the secondary role to the device.
The HA group backs up important configuration from the primary device to the secondary device to prevent service interruption when an active/standby switchover occurs. The configuration on the secondary device is overwritten. The unidirectional backup mechanism avoids configuration conflicts, especially in dual-active mode, and ensures configuration consistency on the primary and secondary devices.
Each HA group member device adds a prefix to the view prompt to identify its HA role.
·     The primary device adds the RBM_P prefix, RBM_P<Sysname> for example.
·     The secondary device adds the RBM_S prefix, RBM_S<Sysname> for example.
After you assign HA roles to the HA group member devices, both devices add the RBM_P prefix to their view prompts. The devices display view prompt prefixes according to their HA roles after they set up the HA control channel.
The HA group must contain one primary device and one secondary device.
As a best practice, configure service features on the primary device.
# Assign the primary role to the device.
[Sysname-remote-backup-group] device-role primary
RBM_P[Sysname-remote-backup-group]
Use display remote-backup-group status to display HA group status information.
context-admin
context-operator
# Display HA group status information on the default context.
<Sysname> display remote-backup-group status
Remote backup group information:
  Backup mode: Dual-active
  Device management role: Primary
  Device running status: Active
  Data channel interface: GigabitEthernet1/0/1
  Local IP: 1.1.1.1
  Remote IP: 1.1.1.2    Destination port: 1028
  Control channel status: Connected
  Keepalive interval: 1s
  Keepalive count: 10
  Configuration consistency check interval: 24 hour
  Configuration consistency check result: Consistent
  Configuration backup status: Batch backup (Do not operate
the device at will, such as board insertion and removal.)
  Session backup status: Hot backup enabled
  Delay-time: 1 min
  Remaining switchover delay time: 3 minutes, 32 seconds
  Uptime since last switchover: 0 days, 0 hours, 11 minutes
  Switchover records:
    Time                        Status change         Cause
    2021-06-22 13:33:33      Initial to Standby   Local device rebooted
    2021-06-22 14:34:34      Initial to Active    Peer device rebooted
# Display HA group status information on non-default contexts.
  Configure channel status: Disconnected
Backup mode
HA mode:
·     Dual-active.
·     Active/standby.
HA role of the device:
·     Primary.
·     Secondary.
Running status of the device.
·     Active.
·     Standby.
·     Initial—The local IP address, peer IP address, or HA role is not configured.
Interface used to set up the data channel.
Local IP
Local IP address used by control channel packets. This field is not displayed if the parameter is not configured.
Remote IP
Peer IP address used by control channel packets. This field is not displayed if the parameter is not configured.
Local IPv6
Local IPv6 address used by control channel packets. This field is not displayed if the parameter is not configured.
Remote IPv6
Peer IPv6 address used by control channel packets. This field is not displayed if the parameter is not configured.
Destination port
Peer port number used by control channel packets.
·     Connected.
·     Disconnected.
Status of the configuration information channel for non-default contexts:
·     Connected.
·     Disconnected.
This filed is displayed only for non-default contexts. If the configuration information channel is disconnected, the device cannot synchronize configuration of non-default contexts.
Keepalive interval
Interval for sending HA keepalive packets.
Keepalive count
Maximum number of HA keepalive attempts.
Configuration consistency check interval in hours. This field is displayed only when configuration consistency check is enabled.
Result of the configuration consistency check:
·     Consistent.
·     Inconsistent.
·     Checking.
·     Not Performed.
Status of configuration backup:
·     Batch backup in progress (Do not operate the device at will, such as board insertion and removal.).
·     Auto sync enabled.
·     Auto sync disabled.
Status of session entry backup:
·     Batch backup in progress.
·     Hot backup enabled.
·     Hot backup disabled.
Delay-time
Delay time for traffic switchover back to the original active device in minutes. If the delay time is not configured, this switchover feature is disabled for the HA backup group.
Remaining delay time for traffic switchover back to the original active device in minutes. This field is not displayed if traffic switchover is disabled.
Use display remote-backup-group sync-check to display the configuration consistency check result for the HA group.
Use this command when the primary and secondary devices have inconsistent configuration. You can view the inconsistent configuration only after the configuration consistency check is finished.
The command displays detailed inconsistency information for only the service features supported by the HA group. For a feature not supported by the HA group, the command displays only the interface where configuration inconsistency exists.
# Display the configuration consistency check result for the HA group. (The configuration consistency check has not been performed.)
<Sysname> display remote-backup-group sync-check
No configuration consistency checks have been performed.
# Display the configuration consistency check result for the HA group. (No inconsistent configuration exists.)
# Display the configuration consistency check result for the HA group. (Inconsistent configuration exists.)
Configuration on secondary device:
security-policy ip
 rule 0 name abc
  source-zone trust
  destination-zone untrust
Configuration on primary device:
security-policy ip
 rule 0 name abc
  source-zone dmz
  destination-zone trust
Context 2
security-policy ip
 rule 0 name 10
security-policy ip
Context 3
object-group ipv6 address d
security-policy ipv6
 rule 0 name d
  source-ip d
 rule 0 name d
hot-backup enable
Use hot-backup enable to enable service entry hot backup.
Use undo hot-backup enable to disable service entry hot backup.
hot-backup enable
Service entry hot backup is enabled.
HA group view
This command enables the active device in the HA group to back up service entries to the standby device in real time. This prevents service interruption when an active/standby switchover occurs.
# Enable service entry hot backup.
[Sysname-remote-backup-group] hot-backup enable
hot-backup protocol enable
Use hot-backup protocol enable to enable hot backup for the session entries of application layer protocols.
Use undo hot-backup protocol enable to disable hot backup for the session entries of application layer protocols.
hot-backup protocol { dns | http } * enable
undo hot-backup protocol { dns | http } * enable
The HA group performs hot backup for the session entries of application layer protocols.
HA group view
dns: Specifies DNS.
http: Specifies HTTP.
For this command to take effect, first execute the hot-backup enable command.
Enable HTTP and DNS backup if asymmetric-path traffic traverses the HA group. HTTP and DNS backup ensures that a flow and its return traffic are processed correctly on the HA group members.
If HA active/standby mode is used or only symmetric-path traffic traverses the HA group, disabling HTTP and DNS backup can improve performance of the HA group members at the expense of delayed data synchronization. When you disable HTTP and DNS backup, make sure you are fully aware of the impact on the network. A device removes a DNS or HTTP connection if packet exchange is inactive. When a switchover interrupts a connection, the DNS or HTTP client re-initiates the connection immediately, which has little impact on user services.
The HA group backs up the sessions created for other application protocols as long as service entry backup is enabled.
# Disable hot backup for the session entries of application layer protocols.
[Sysname-remote-backup-group] undo hot-backup protocol dns enable
hot-backup enable
keepalive count
Use keepalive count to set the maximum number of HA keepalive attempts.
Use undo keepalive count to restore the default.
keepalive count counts
The maximum number of HA keepalive attempts is 10.
HA group view
times: Sets the maximum number of HA keepalive attempts, in the range of 1 to 255.
If the value for the maximum number of HA keepalive attempts is too small, network latency will cause incorrect switchovers. If this issue occurs, increase the value of this parameter.
The device periodically sends HA keepalive packets to the HA peer over the HA control channel. If the device has not received any responses from the peer when the maximum number of HA keepalive attempts is reached, the HA control channel is disconnected.
# Set the maximum number of HA keepalive attempts to 6.
[Sysname-remote-backup-group] keepalive count 6
keepalive interval
keepalive interval
Use keepalive interval to set the interval for sending HA keepalive packets.
Use undo keepalive interval to restore the default.
keepalive interval interval
The device sends HA keepalive packets at one-second intervals.
HA group view
interval: Sets the interval for sending HA keepalive packets in seconds, in the range of 1 to 60.
# Set the interval for sending HA keepalive packets to 2 seconds.
[Sysname-remote-backup-group] keepalive interval 2
keepalive count
local-ip
Use local-ip to configure the local IPv4 address for setting up the HA control channel.
Use undo local-ip to restore the default.
local-ip ipv4-address
undo local-ip
The local IPv4 address is not configured for setting up the HA control channel.
HA group view
ipv4-address: Specifies the local IPv4 address for setting up the HA control channel. The IP address cannot be an all-zero, loopback, or multicast address.
The HA group compares the specified local and peer IP address to determine the device role for setting up the control channel. The device with higher IP address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
You can configure a local IPv4 address or a local IPv6 address, but not both.
# Configure the local IPv4 address as 1.1.1.2 for setting up the HA control channel.
[Sysname-remote-backup-group] local-ip 1.1.1.2
local-ipv6
remote-ip
local-ipv6
Use local-ipv6 to configure the local IPv6 address for setting up the HA control channel.
Use undo local-ipv6 to restore the default.
local-ipv6 ipv6-address
undo local-ipv6
The local IPv6 address is not configured for setting up the HA control channel.
HA group view
ipv6-address: Specifies the local IPv6 address for setting up the HA control channel. The IP address cannot be an all-zero address, loopback address, multicast address, or IPv6 address with an embedded IPv4 address.
The HA group compares the specified local and peer IPv6 address to determine the device role for setting up the control channel. The device with higher IPv6 address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
# Configure the local IPv6 address as 2019::1 for setting up the HA control channel.
[Sysname-remote-backup-group] local-ipv6 2019::1
local-ip
remote-ipv6
remote-backup group
Use remote-backup group command to enter HA group view.
Use undo remote-backup group to remove all settings of the HA group.
remote-backup group
The HA group provides backup for important configuration and service entries between devices. It collaborates with VRRP to implement hot backup that enables smooth master/backup switchover upon link failures for service continuity.
# Enter HA group view.
remote-ip
Use remote-ip to configure the peer IPv4 address for setting up the HA control channel.
Use undo remote-ip to restore the default.
remote-ip ipv4-address [ port port-number ]
undo remote-ip ipv4-address
The peer IPv4 address is not configured for setting up the HA control channel.
HA group view
ipv4-address: Specifies the peer IPv4 address for setting up the HA control channel. The IP address cannot be an all-zero, loopback, or multicast address.
port port-number: Specifies a port by its number used for establishing TCP connection. The value range for the port-number argument is 1024 to 65535, and the default value is 60064.
The HA control channel transmits data by using packets, including HA group status packets, configuration consistency check packets, and configuration synchronization packets. Each member device compares the specified local and peer IP address to determine the device role for setting up the control channel. The device with higher IP address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
If the port number is configured on the server, the port provides services for the client. If the port number is configured on the client, the port serves as the destination port to establish TCP connection to the server. The source port is randomly generated on the client.
You can specify only one peer IP address with the same port number on the primary and secondary devices.
You can configure a remote IPv4 address or a remote IPv6 address, but not both.
# Configure the peer IPv4 address and port number as 1.1.1.1 and 4456 for setting up the HA control channel.
[Sysname-remote-backup-group] remote-ip 1.1.1.1 port 4456
local-ip
remote-ipv6
remote-ipv6
Use remote-ipv6 to configure the peer IPv6 address for setting up the HA control channel.
Use undo remote-ipv6 to restore the default.
remote-ipv6 ipv6-address [ port port-number ]
undo remote-ipv6 ipv6-address
The peer IPv6 address is not configured for setting up the HA control channel.
HA group view
ipv6-address: Specifies the peer IPv6 address for setting up the HA control channel. The IP address cannot be an all-zero address, loopback address, multicast address, or IPv6 address with an embedded IPv4 address.
port port-number: Specifies a port by its number used for establishing TCP connection. The value range for the port-number argument is 1024 to 65535, and the default value is 60064. Make sure the port number is not in use.
The HA control channel transmits data by using packets, including HA group status packets, configuration consistency check packets, and configuration synchronization packets. Each member device compares the specified local and peer IPv6 address to determine the device role for setting up the control channel. The device with higher IPv6 address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
You can specify only one peer IPv6 address with the same port number on the primary and secondary devices.
# Configure the peer IPv6 address and port number as 2018::1 and 4456 for setting up the HA control channel.
[Sysname-remote-backup-group] remote-ipv6 2018::1 port 4456
local-ipv6
remote-ip
silent-backup-interface
Use silent-backup-interface to disable the standby device from sending or receiving protocol packets of a dynamic routing protocol.
Use undo silent-backup-interface to enable the standby device to send and receive protocol packets of a dynamic routing protocol.
silent-backup-interface { ospf | ospfv3 }
undo silent-backup-interface { ospf | ospfv3 }
The standby device can send and receive protocol packets of a dynamic routing protocol.
HA group view
ospf: Specifies OSPF.
ospfv3: Specifies OSPFv3.
This command disconnects the neighbor relationships for a dynamic routing protocol on the standby device. The active device can send and receive protocol packets of that dynamic routing protocol, and correctly process both uplink and downlink traffic.
You can execute this command multiple times to disable multiple dynamic routing protocols on the standby device.
You cannot use this command together with the adjust-cost enable command.
# Disable the standby device from sending or receiving OSPF protocol packets.
[Sysname-remote-backup-group] silent-backup-interface ospf
adjust-cost enable
switchover request
Use switchover request to perform an active/standby switchover.
switchover request
HA group view
If you want to replace components or upgrade software on the current active device, you can execute this command to switch services to the standby device.
This command applies only when the HA group operates in active/standby mode.
In an HA group and VRRP associated network, executing this command might cause temporary virtual IP address conflict in the VRRP group, which is considered a normal condition.
# Perform an active/standby switchover.
[Sysname-remote-backup-group] switchover request
track
Use track to associate the HA group with Track.
Use undo track to remove the association.
track track-entry-number
undo track track-entry-number
The HA group is not associated with Track.
HA group view
track-entry-number: Specifies a track entry by its ID in the range of 1 to 1024.
Use this command to associate the HA group with Track to monitor links. If one of the monitored track entries becomes Negative, the HA group performs an active/standby switchover and switches traffic to the new active device to ensure service continuity. For more information about Track, see Network Management and Monitoring Configuration Guide.
You can use the track interface and track commands in conjunction, but you cannot use these commands to monitor the same interfaces.
The track vlan and track commands are mutually exclusive. You cannot configure both of them.
To associate the HA group with multiple track entries, execute this command multiple times.
# Associate the HA group with track entries 1 and 2.
[Sysname-remote-backup-group] track 1
[Sysname-remote-backup-group] track 2
track (Network Management and Monitoring Command Reference)
track interface
Use track interface to enable the HA group to monitor an interface.
Use undo track interface to remove the configuration.
track interface interface-type interface-number
undo track interface [ interface-type interface-number ]
The HA group does not monitor any interfaces.
HA group view
interface-type interface-number: Specifies an interface by its type and number. You can specify a Layer 2 or Layer 3 Ethernet interface in the current software version. If you do not specify this argument, the undo form of the command removes the monitoring for all interfaces.
Use this command to enable the HA group to monitor the interfaces connecting the uplink and downlink devices. The monitored interfaces can forward packets only when they are all up. If any of the monitored interfaces goes down, none of them will be able to forward packets.
If the uplink and downlink interfaces of the HA group are Layer 3 Ethernet interfaces and the HA group is used with static routes, use the track interface command to monitor those interfaces.
If the uplink and downlink interfaces of the HA group are Layer 2 Ethernet interfaces connected to peer Layer 3 interfaces, use the track interface command to monitor the Layer 2 Ethernet interfaces.
The track vlan and track interface commands are mutually exclusive. You cannot configure both of them.
To enable the HA group to monitor multiple interfaces, execute this command multiple times.
The HA group does not support monitoring member ports of aggregate interfaces.
# Enable the HA group to monitor interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[Sysname-remote-backup-group] track interface gigabitethernet 1/0/1
[Sysname-remote-backup-group] track interface gigabitethernet 1/0/2
track
track interface
track vlan
track vlan
Use track vlan to enable the HA group to monitor a VLAN.
Use undo track vlan to remove the configuration.
track vlan vlan-id
undo track vlan [ vlan-id ]
The HA group does not monitor any VLANs.
HA group view
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify this argument, the undo form of the command removes the monitoring for all VLANs.
Use this command to enable the HA group to monitor the VLANs of the uplink and downlink devices. The monitored VLANs are active and the member ports can forward packets only when the member ports are all up. If any of the member ports goes down, none of them will be able to forward packets, and all the monitored VLANs will become inactive.
In active/standby mode, the state of monitored VLANs is active on the primary device and inactive on the secondary device.
In dual-active mode, the state of monitored VLANs is active on both the primary and secondary devices.
Do not enable the HA group to monitor VLAN 1 (to which all access ports belong by default). This restriction prevents an unused interface in down state from interrupting operation of other interfaces in VLAN 1.
To enable the HA group to monitor multiple VLANs, execute this command multiple times.
The track vlan command is mutually exclusive with the track interface and track commands. You cannot use the track vlan command in conjunction with the track interface or track command.
# Enable the HA group to monitor VLAN 10.
[Sysname-remote-backup-group] track vlan 10
track
track interface
track vlan
transparent-transmit enable
Use transparent-transmit enable to enable transparent service traffic transmission between the remote backup group members.
Use undo transparent-transmit enable to disable transparent service traffic transmission between the remote backup group members.
Transparent service traffic transmission is enabled.
HA group view
Enable transparent service traffic transmission only when asymmetric-path traffic traverses the HA group operating in dual-active mode.
If an asymmetric-path flow traverses the HA group operating in dual-active mode, the flow and its return traffic are processed by different remote backup group members. This will degrade the traffic processing performance of modules such as NBAR, DPI, and load balancing. For example, the packet recognition rate of NBAR might drop. For an asymmetric-path flow and its return traffic to be processed by the same remote backup group member, enable transparent service traffic transmission. Transparent service traffic transmission is resource-intensive. Make sure you are fully aware of the impact of this feature when you use it on a live network.
# Enable transparent service traffic transmission between the remote backup group members.
[Sysname-remote-backup-group] transparent-transmit enable
vrrp ipv6 vrid
Use vrrp ipv6 vrid to create an IPv6 VRRP group and assign a virtual IPv6 address to it, or to assign a virtual IPv6 address to an existing IPv6 VRRP group.
Use undo vrrp ipv6 vrid to remove all configurations of an IPv6 VRRP group, or to remove a virtual IPv6 address from an IPv6 VRRP group.
vrrp ipv6 vrid virtual-router-id virtual-ip virtual-address [ prefix-length ] link-local { active | standby }
undo vrrp ipv6 vrid virtual-router-id [ virtual-ip [ virtual-address [ link-local ] ] ]
No IPv6 VRRP groups exist.
Interface view
context-admin
virtual-router-id: Specifies an IPv6 VRRP group by its virtual router ID in the range of 1 to 255.
virtual-ip virtual-address: Specifies a virtual IPv6 address. If you do not specify this option, the undo vrrp ipv6 vrid command removes all virtual IPv6 addresses from the specified IPv6 VRRP group.
prefix-length: Specifies the prefix length of the virtual IPv6 address, in the range of 1 to 128. If you do not specify this argument, the default value 128 applies.
link-local: Specifies a link-local address as the virtual IPv6 address.
active: Associates the IPv6 VRRP group with the HA group by adding the device to the IPv6 VRRP active group. The initial role of the device is master.
standby: Associates the IPv6 VRRP group with the HA group by adding the device to the IPv6 VRRP standby group. The initial role of the device is backup.
You can execute this command multiple times to assign multiple virtual IPv6 addresses to an IPv6 VRRP group. When you configure the HA group in collaboration with VRRP, you can assign a maximum of 4096 virtual IPv6 addresses to a VRRP group. If you specify the prefix length to assign a virtual IPv6 subnet, the subnet is recognized as one virtual IPv6 address.
The first virtual IPv6 address that you assign to an IPv6 VRRP group must be a link-local address, and it must be removed last.
An IPv6 VRRP group can have only one link-local address as its virtual IPv6 address. For an IPv6 VRRP group to work correctly, you must also assign it a global unicast address as a virtual IPv6 address.
The virtual IPv6 address of an IPv6 VRRP group and the downlink interface IPv6 address of the VRRP group members must be on the same subnet. Otherwise, the hosts on the subnet might fail to access external networks.
You cannot associate an IPv6 VRRP group operating in load balancing mode with the HA group.
When you configure the HA group in collaboration with VRRP, make sure the interfaces in an IPv6 VRRP group do not own the virtual IPv6 addresses.
You cannot associate an IPv6 VRRP group with both the HA group and Track.
To modify the settings for the command, first execute the undo form of the command, and then execute the vrrp ipv6 vrid command again.
# Create IPv6 VRRP group 1, assign virtual IPv6 address fe80::10 to the VRRP group, and assign the device to the VRRP active group. Then assign virtual IPv6 address 1::10 to the VRRP group.
[Sysname-GigabitEthernet1/0/1] vrrp ipv6 vrid 1 virtual-ip fe80::10 link-local active
[Sysname-GigabitEthernet1/0/1] vrrp ipv6 vrid 1 virtual-ip 1::10
vrrp vrid
Use vrrp vrid to create an IPv4 VRRP group and assign a virtual IP address to it, or to assign a virtual IP address to an existing IPv4 VRRP group.
Use undo vrrp vrid to remove all configurations of an IPv4 VRRP group, or to remove a virtual IP address from an IPv4 VRRP group.
vrrp vrid virtual-router-id virtual-ip virtual-address [ mask | mask-length ] { active | standby }
undo vrrp vrid virtual-router-id [ virtual-ip [ virtual-address ] ]
No IPv4 VRRP groups exist.
Interface view
context-admin
virtual-router-id: Specifies an IPv4 VRRP group by its virtual router ID in the range of 1 to 255.
virtual-ip virtual-address: Specifies a virtual IP address. You cannot specify the virtual IP address as any of the following IP addresses:
·     All-zero address (0.0.0.0).
·     Broadcast address (255.255.255.255).
·     Loopback address.
·     IP address of other than Class A, Class B, and Class C.
·     Invalid IP address (for example, 0.0.0.1).
If you do not specify the virtual-address argument, the undo vrrp vrid command removes all virtual IP addresses from the specified IPv4 VRRP group.
mask-length: Specifies a mask length in the range of 1 to 32. If you do not specify a subnet mask or a mask length, the default mask length 32 applies.
active: Associates the VRRP group with the HA group by adding the device to the VRRP active group. The initial role of the device is master.
standby: Associates the VRRP group with the HA group by adding the device to the VRRP standby group. The initial role of the device is backup.
You can execute this command multiple times to assign multiple virtual IP addresses to an IPv4 VRRP group. When you configure the HA group in collaboration with VRRP, you can assign a maximum of 4096 virtual IPv4 addresses to a VRRP group. If you specify the mask or mask length to assign a virtual IPv4 subnet, the subnet is recognized as one virtual IPv4 address.
The virtual IP address of an IPv4 VRRP group and the downlink interface IP addresses of the VRRP group members must be on the same subnet. Otherwise, the hosts on the subnet might fail to access external networks.
You cannot associate a VRRP group operating in load balancing mode with the HA group.
For VRRP to operate correctly, make sure a virtual IP address of an IPv4 VRRP group is not the IP address of any interface in the VRRP group.
When you configure the HA group in collaboration with VRRP, make sure the interfaces in an IPv4 VRRP group do not own the virtual IPv4 addresses.
You cannot associate a VRRP group with both the HA group and Track.
To modify the settings for the command, first execute the undo form of the command, and then execute the vrrp vrid command again.
# Create IPv4 VRRP group 1, assign virtual IP address 10.10.10.10 to the VRRP group, and assign the device to the VRRP active group.
[Sysname-GigabitEthernet1/0/1] vrrp vrid 1 virtual-ip 10.10.10.10 active
display vrrp
