- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-License management commands
- 05-Device management commands
- 06-FTP and TFTP commands
- 07-File system management commands
- 08-Configuration file management commands
- 09-Software upgrade commands
- 10-ISSU commands
- 11-Tcl commands
- 12-Python commands
- 13-MAC learning through a Layer 3 device commands
11-Tcl commands | 43.49 KB |
Tcl commands
cli
Use cli to enable a Comware command to be executed in Tcl configuration view when it conflicts with a Tcl command.
cli command
context-admin
command: Specifies the commands to be executed. They must be complete command lines.
In Tcl configuration view, if a Comware command conflicts with a Tcl command, the Tcl command will be executed. To execute the Comware command when a conflict occurs, execute the cli command.
# Perform the following steps to execute a Comware command that conflicts with a Tcl command in Tcl configuration view.
1. Execute a Comware command in Tcl configuration view. The output shows that the Comware command cannot be executed because it conflicts with a Tcl command.
<Sysname> tclsh
<Sysname-tcl> system-view
[Sysname-tcl] route-policy 1 permit node 10
[Sysname-tcl-route-policy-1-10] apply cost 10
can't interpret "cost" as a lambda expression
2. Configure the cli command to execute the Comware command again.
[Sysname-tcl-route-policy-1-10] cli apply cost 10
# Execute multiple Comware commands in one operation to enter OSPF area view.
Method 1:
[Sysname-tcl] cli "ospf 100 ; area 0"
[Sysname-tcl-ospf-100-area-0.0.0.0]
Method 2:
[Sysname-tcl] cli ospf 100 ; cli area 0
tclquit
Use tclquit to return from Tcl configuration view to user view.
tclquit
context-admin
To return from Tcl configuration view to user view, you can also use the quit command.
To return to the upper-level view after you execute Comware commands to enter system view or a Comware feature view, use the quit command.
# Return from Tcl configuration view to user view.
<Sysname-tcl> tclquit
<Sysname>
tclsh
tclsh
Use tclsh to enter Tcl configuration view from user view.
tclsh
context-admin
In Tcl configuration view, you can execute the following commands:
· All Tcl 8.5 commands.
· Comware commands. The Tcl configuration view is equivalent to the user view. You can use Comware commands in Tcl configuration view in the same way they are used in user view.
# Enter Tcl configuration view from user view.
<Sysname> tclsh
<Sysname-tcl>
tclquit
