| 01-VXLAN commands | 489.74 KB |
bandwidth (Ethernet service instance view)
display hardware-resource vxlan
display ipv6 nd suppression vsi
display l2vpn drni arp suppression
display l2vpn drni mac-address
display l2vpn drni nd suppression
display l2vpn mac-address mac-move
display l2vpn service-instance
display vxlan tunnel-interface
flooding disable (Ethernet service instance view)
mac-address mac-learning priority
reset l2vpn mac-address mac-move
selective-flooding mac-address
statistics enable (Ethernet service instance view)
statistics enable (tunnel interface view)
vxlan invalid-udp-checksum discard
vxlan invalid-vlan-tag discard
vxlan ipv6 default-decapsulation
arp distributed-gateway dynamic-entry synchronize
display interface vsi-interface
ipv6 nd distributed-gateway dynamic-entry synchronize
reset counters interface vsi-interface
vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
ovsdb server bootstrap ca-certificate
VXLAN commands
Basic VXLAN commands
ac statistics enable
Use ac statistics enable to enable packet statistics for Ethernet service instances of a VLAN.
Use undo ac statistics enable to disable packet statistics for Ethernet service instances of a VLAN.
The packet statistics feature is disabled for Ethernet service instances of a VLAN.
VLAN view
This command enables packet statistics for the Ethernet service instances automatically created for VLAN-based VXLAN assignment.
Before you enable this feature, you must use the vxlan vlan-based command to enable VLAN-based VXLAN assignment.
# Map VLAN 10 to VXLAN 100, and enable packet statistics for Ethernet service instances of VLAN 10.
[Sysname] vxlan vlan-based
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
[Sysname-vlan10] ac statistics enable
reset l2vpn statistics ac
vxlan vlan-based
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
ARP flood suppression is disabled.
VSI view
ARP flood suppression reduces ARP request broadcasts.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM or unicast the ARP request. If no match is found, the VTEP floods the request to both local and remote sites or drops the ARP request.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
arp suppression mode
display arp suppression vsi
reset arp suppression vsi
Use arp suppression mode to set the ARP flood suppression mode.
Use undo arp suppression mode to restore the default.
arp suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
NOTE: This command is supported only in Release 6635 and later. |
If ARP flood suppression is enabled, the default ARP flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the ARP requests that are not targeted at the device and do not match any ARP flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device replies to the ARP request on behalf of the target IP address. The ARP reply carries the following information:
· Sender IP address—Target IP address in the ARP request.
· Sender MAC address—MAC address in the matching ARP flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device acts as follows:
1. Replaces the target MAC address in the ARP request with the MAC address in the entry.
2. Unicasts the ARP request.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an ARP request that is not targeted at the device and does not match any ARP flood suppression entry. If you do not specify this keyword, the device will broadcast such an ARP request.
The device does not forward ARP requests in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ARP entry learning errors caused by the delay in refreshing ARP flood suppression entries at the expense of high system resource usage.
# Enable ARP flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression mode unicast-forward
Use bandwidth to set the bandwidth limit for an Ethernet service instance.
bandwidth bandwidth
undo bandwidth
No bandwidth limit is set for an Ethernet service instance.
bandwidth: Specifies a bandwidth limit in kbps. The value range for this argument is 64 to 4194303.
The bandwidth limit takes effect only on incoming traffic. An Ethernet service instance drops excess incoming traffic when its bandwidth limit is reached.
If you use the bandwidth command for both an Ethernet service instance and its mapped VSI, the Ethernet service instance bandwidth is limited exclusively from the VSI bandwidth. For example, VSI vsi1 has AC 1, AC 2, AC 3, and Tunnel 1. The bandwidth limit of VSI vsi1 is 500 kbps, and the bandwidth limit of AC 1 is 120 kbps. The total bandwidth of AC 2, AC 3, and Tunnel 1 is limited to 500 kbps.
# Set the bandwidth limit to 10240 kbps for Ethernet service instance 200.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] service-instance 200
[Sysname-Twenty-FiveGigE1/0/1-srv200] encapsulation s-vid 200
[Sysname-Twenty-FiveGigE1/0/1-srv200] bandwidth 10240
bandwidth (VSI view)
Use bandwidth to set the bandwidth limit for a VSI.
bandwidth bandwidth
undo bandwidth
No bandwidth limit is set for a VSI.
VSI view
bandwidth: Specifies a bandwidth limit in kbps. The value range for the bandwidth argument is 64 to 104857599.
This command limits the total bandwidth of the incoming traffic on all ACs and VXLAN tunnels mapped to a VSI. A VSI drops excess incoming traffic when its bandwidth limit is reached.
If you use both the restrain and bandwidth commands on a VSI, the following rules apply:
· If the restraint bandwidth is 0, the restrain command takes effect.
· If the restraint bandwidth is not 0, the bandwidth command takes effect.
# Set the bandwidth limit to 10240 kbps for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] bandwidth 10240
display l2vpn vsi
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays entries on the master device.
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address MAC address VSI name Link ID Aging(min)
1.1.1.2 000f-e201-0101 vsi1 0x70000 14
1.1.1.3 000f-e201-0202 vsi1 0x80000 18
1.1.1.4 000f-e201-0203 vsi2 0x90000 10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID |
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI. |
Aging(min) |
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted. |
Use display hardware-resource vxlan to display the VXLAN hardware resource mode.
display hardware-resource [ vxlan ]
vxlan: Specifies the VXLAN hardware resource mode. If you do not specify this keyword, the command displays all hardware resource modes.
# Display the VXLAN hardware resource mode.
<Sysname> display hardware-resource vxlan
Vxlan resource(vxlan), all supported modes:
l2gw L2 gateway--underlay/overlay 64K/0K
l3gw L3 gateway--underlay/overlay 24K/40K
48k-l3gw L3 gateway--underlay/overlay 16K/48K
Default Current Next
l2gw l3gw l3gw
Vxlan resource(vxlan), all supported modes |
VXLAN hardware resource modes supported by the device. · l2gw—Layer 2 gateway mode. · l3gw—Layer 3 gateway mode. · 48k-l3gw—Layer 3 gateway mode with 48K of overlay resources. This mode is supported only in Release 6635 and later. |
Default |
The default VXLAN hardware resource mode. |
Current |
The current VXLAN hardware resource mode. |
Next |
The VXLAN hardware resource mode for the next startup. |
display igmp host group
Use display igmp host group to display information about the multicast groups that contain IGMP host-enabled interfaces.
display igmp host group [ group-address | interface interface-type interface-number ] [ verbose ]
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays multicast group information for all interfaces.
verbose: Displays detailed multicast group information. If you do not specify this keyword, the command displays brief multicast group information.
For the VXLAN multicast source interface of a multicast-mode VXLAN to join its VXLAN multicast group, enable the IGMP host feature on the interface. The VXLAN multicast source interface provides the source IP address for multicast VXLAN packets.
Use this command to verify the following information:
· Multicast group information for VXLANs.
· Group membership status of VXLAN multicast source interfaces.
# Display brief information about all multicast groups that contain IGMP host-enabled interfaces.
<Sysname> display igmp host group
IGMP host groups in total: 2
Vlan-interface10(1.1.1.20):
Group address Member state Expires
225.1.1.1 Idle Off
225.1.1.2 Idle Off
# Display detailed information about all multicast groups that contain IGMP host-enabled interfaces.
<Sysname> display igmp host group verbose
Group: 225.1.1.1
Group mode: Exclude
Member state: Idle
Expires: Off
Source list (sources in total: 0):
Group: 225.1.1.2
Group mode: Exclude
Member state: Idle
Expires: Off
IGMP host groups in total |
Total number of multicast groups that contain IGMP host-enabled interfaces. |
Vlan-interface10(1.1.1.20) |
Name and IP address of the IGMP host-enabled interface. |
Total number of multicast groups on the interface. |
Group address/Group |
Address of the multicast group. |
Member state |
Member state: · Delay—The interface has joined the multicast group, and it has started the delay timer for sending IGMP reports. · Idle—The interface has joined the multicast group, but it has not started the delay timer for sending IGMP reports. The delay timer is not user configurable. |
Expires |
Remaining delay time for the interface to send an IGMP report. This field displays Off if the delay timer is disabled. |
Group mode |
Multicast source filtering mode: · Include. · Exclude. |
Source list |
Multicast sources of the multicast group. |
sources in total |
Total number of multicast sources. |
NOTE: For more information about the command output, see IGMP in IP Multicast Configuration Guide. |
igmp host enable
Use display ipv6 nd suppression vsi to display ND flood suppression entries.
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
count: Displays the number of ND flood suppression entries that match the command.
# Display ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi
IPv6 address MAC address VSI name Link ID Aging (min)
1000::2 000f-e201-0101 vsi1 0x70000 5
1000::3 000f-e201-0202 vsi1 0x80000 5
1000::4 000f-e201-0203 vsi2 0x90000 5
# Display the number of ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
Link ID |
Aging (min) |
Remaining lifetime (in minutes) of the ND flood suppression entry. When the timer expires, the entry is deleted. |
ipv6 nd suppression enable
reset ipv6 nd suppression vsi
Use display l2vpn drni arp to display L2VPN ARP entries on a DR member device.
display l2vpn drni arp [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ count | ip-address ] ]
NOTE: This command is supported only in Release 6616 and later. |
local: Specifies locally learned L2VPN ARP entries.
remote: Specifies DRNI-synchronized L2VPN ARP entries.
count: Displays the number of L2VPN ARP entries. If you do not specify this keyword, the command displays detailed information about L2VPN ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all L2VPN ARP entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and DRNI-synchronized L2VPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays L2VPN ARP entries for the public instance and all VPN instances.
# Display all L2VPN ARP entries on the local DR member device.
<Sysname> display l2vpn drni arp
Flags: D – Dynamic L - Local R – Remote S – Static I - Invalid
VPN instance: vpn1 Interface: Vsi-interface1
IP address MAC address VSI index Link ID Flags
10.1.1.1 0003-0003-0003 0 0x1 DL
10.1.1.11 0001-0001-0001 0 0x1 DL
10.1.1.12 0001-0001-0011 0 0x2 DR
10.1.1.13 0001-0001-0021 0 0x2 DR
10.1.1.101 0001-0011-0101 0 0x1 SL
10.1.1.102 0001-0011-0102 0 0x1 SL
Public instance Interface: Vsi-interface2
11.1.1.1 0033-0033-0033 0 0x1 DL
11.1.1.11 0011-0011-0011 0 0x1 DL
# Display the total number of L2VPN ARP entries on the local DR member device.
<Sysname> display l2vpn drni arp count
Total number of entries: 8
Table 5 Command output
VSI interface. |
Link ID |
Flags |
ARP entry type: · D—The entry is a valid dynamically learned entry. · L—The entry is a valid local entry. · R—The entry is a valid DRNI-synchronized entry. · S—The entry is a valid static entry. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Use display l2vpn drni arp suppression to display L2VPN ARP flood suppression entries on a DR member device.
display l2vpn drni arp suppression [ local | remote ] [ count | vsi vsi-name [ count | ip-address ] ]
local: Specifies L2VPN ARP flood suppression entries that are learned locally.
remote: Specifies L2VPN ARP flood suppression entries that are synchronized by DRNI.
count: Displays the number of L2VPN ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about L2VPN ARP flood suppression entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN ARP flood suppression entries for all VSIs.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all L2VPN ARP flood suppression entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and DRNI-synchronized L2VPN ARP flood suppression entries.
# Display all L2VPN ARP flood suppression entries on the local DR member device.
<Sysname> display l2vpn drni arp suppression
Flags: D - Dynamic L – Local R – Remote S - Static I – Invalid
VSI name: vpna
IP address MAC address Link ID Flags
10.1.1.12 0002-0002-0002 0x1 DL
10.1.1.13 0002-0002-0002 0x2 RI
10.1.1.101 0001-0011-0101 0x2 SR
# Display the total number of L2VPN ARP flood suppression entries on the local DR member device.
<Sysname> display l2vpn drni arp suppression count
Total number of entries: 3
Table 6 Command output
Link ID |
Flags |
ARP flood suppression entry type: · D—The entry is a valid dynamically learned entry. · L—The entry is a valid local entry. · R—The entry is a valid DRNI-synchronized entry. · S—The entry is a valid static entry. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Use display l2vpn drni mac-address to display L2VPN MAC address entries on a DR member device.
display l2vpn drni mac-address [ local | remote ] [ count | vsi vsi-name [ count | mac-address ] ]
local: Specifies L2VPN MAC address entries that are learned locally.
remote: Specifies L2VPN MAC address entries that are synchronized by DRNI.
count: Displays the number of L2VPN MAC address entries. If you do not specify this keyword, the command displays detailed information about L2VPN MAC address entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN MAC address entries for all VSIs.
mac-address: Specifies a MAC address. The MAC address is in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command displays all L2VPN MAC address entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and DRNI-synchronized L2VPN MAC address entries.
# Display all L2VPN MAC address entries on the local DR member device.
<Sysname> display l2vpn drni mac-address
VSI name: bbb
MAC address Link ID Interface Flags
0000-0000-000a 0x1 BAGG10 DL
0000-0000-0009 0x1 Tunnel1 DL
# Display the total number of L2VPN MAC address entries on the local DR member device.
<Sysname> display l2vpn drni mac-address count
Total number of entries: 2
Table 7 Command output
Link ID |
Outgoing interface. |
Flags |
MAC address entry type: · D—The entry is a valid dynamically learned entry. · L—The entry is a valid local entry. · R—The entry is a valid DRNI-synchronized entry. · S—The entry is a valid static entry. |
Use display l2vpn drni nd to display L2VPN ND entries on a DR member device.
display l2vpn drni nd [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ ipv6-address | count ] ]
local: Specifies locally learned L2VPN ND entries.
remote: Specifies DRNI-synchronized L2VPN ND entries.
count: Displays the number of L2VPN ND entries. If you do not specify this keyword, the command displays detailed information about L2VPN ND entries.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all L2VPN ND entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and DRNI-synchronized L2VPN ND entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays L2VPN ND entries for the public instance and all VPN instances.
# Display all L2VPN ND entries on the local DR member device.
<Sysname> display l2vpn drni nd
Flags: D - Dynamic L – Local R – Remote S - Static I - Invalid
VPN instance: vpna Interface: Vsi-interface1
IPv6 address : 20::2
MAC address : 0001-0001-0001 Flags : DL
VSI index : 0 Link ID : 0x1
# Display the total number of L2VPN ND entries on the local DR member device.
<Sysname> display l2vpn drni nd count
Total number of entries: 1
Table 8 Command output
VSI interface. |
Flags |
ND entry type: · D—The entry is a valid dynamically learned entry. · L—The entry is a valid local entry. · R—The entry is a valid DRNI-synchronized entry. · S—The entry is a valid static entry. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Link ID |
Use display l2vpn drni nd suppression to display L2VPN ND flood suppression entries on a DR member device.
display l2vpn drni nd suppression [ local | remote ] [ count | vsi vsi-name [ ipv6-address | count ] ]
local: Specifies L2VPN ND flood suppression entries that are learned locally.
remote: Specifies L2VPN ND flood suppression entries that are synchronized by DRNI.
count: Displays the number of L2VPN ND flood suppression entries. If you do not specify this keyword, the command displays detailed information about L2VPN ND flood suppression entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN ND flood suppression entries for all VSIs.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all L2VPN ND flood suppression entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and DRNI-synchronized L2VPN ND flood suppression entries.
# Display all L2VPN ND flood suppression entries on the local DR member device.
[Sysname]display l2vpn drni nd suppression
VSI name: vpna
IPv6 address MAC address Link ID Flags
11::8 72cb-ce9b-0a06 0x1 DL
11::9 0001-0001-0001 0x2 SR
# Display the total number of L2VPN ND flood suppression entries on the local DR member device.
<Sysname> display l2vpn drni nd suppression count
Table 9 Command output
Link ID |
Flags |
ND flood suppression entry type: · D—The entry is a valid dynamically learned entry. · L—The entry is a valid local entry. · R—The entry is a valid DRNI-synchronized entry. · S—The entry is a valid static entry. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
· Dynamic remote- and local-MAC entries.
· Remote-MAC entries advertised through BGP EVPN.
· Manually added static remote- and local-MAC entries.
· Remote-MAC entries issued through OpenFlow.
· Remote-MAC entries issued through OVSDB.
count: Displays the number of MAC address entries.
verbose: Displays detailed information about MAC address entries.
If you do not specify the count or verbose keyword, this command displays brief information about MAC address entries.
# Display brief information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address : 5237-a625-0e06
VSI Name : vpna
State : Dynamic
Link ID/Name Aging
Tunnel1 Aging
MAC Address : 52f6-bc1e-0d06
VSI Name : vpna
State : Dynamic
Link ID/Name Aging
WGE1/0/1 Aging
--- 2 mac address(es) found ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
Table 10 Command output
VSI Name |
VSI name in one of the following formats: · vsi-name—VSI name for the MAC address entry. · vsi1 (vsi2)—The MAC address belongs to vsi1 and has been issued to vsi2 by the controller. |
State |
Entry state: · Dynamic—Local- or remote-MAC entry dynamically learned in the data plane. · Static—Static local- and remote-MAC entry. · EVPN—Remote-MAC entry advertised through BGP EVPN. · OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow. · OVSDB—Remote-MAC entry issued by a remote controller through OVSDB. |
Link ID/Name |
For a local MAC address, this field displays the name of the interface that hosts the Ethernet service instance for the MAC address. For a remote MAC address, this field displays the tunnel interface name. |
Aging |
Entry aging state: · Aging. · NotAging. |
# Display detailed information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name : vpn1
VXLAN ID : 123
Interface : WGE1/0/1
Link ID : 1
State : Dynamic
Aging : Aging
Table 11 Command output
VSI Name |
Link ID |
State |
Entry state: · Dynamic—Local- or remote-MAC entry dynamically learned in the data plane. · Static—Static local- or remote-MAC entry. · EVPN—Remote-MAC entry advertised through BGP EVPN. · OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow. · OVSDB—Remote-MAC entry issued by a remote controller through OVSDB. |
Aging |
Use display l2vpn mac-address mac-move to display MAC move records for VSIs.
display l2vpn mac-address mac-move [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays MAC move records on the master device.
When a MAC address frequently moves between two interfaces, Layer 2 loops might occur in the network. To discover and locate loops, you can view the MAC address move records.
An IRF member device can generate a maximum of 200 MAC address move records.
# Display MAC move records for all VSIs.
<Sysname> display l2vpn mac-address mac-move
MAC address : 0000-4900-03e7 VSI name : 3
Current port: WGE1/0/1 srv2 Source port: WGE1/0/2 srv3
Last time : 2019-02-19 20:44:15 Move count : 1
--- 1 MAC address moving records found ---
Table 12 Command output
Current port |
Interface to which the MAC address was moved. |
Source port |
Interface from which the MAC address was moved. |
Last time |
Last time when the MAC address was moved. |
Move count |
Number of times that the MAC address has moved. |
Use display l2vpn service-instance to display information about Ethernet service instances.
interface interface-type interface-number: Specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface by its interface type and number. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
verbose: Displays detailed information about Ethernet service instances. If you do not specify this keyword, the command displays brief information about Ethernet service instances.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 2, 2 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface ID Owner LinkID State Type
WGE1/0/1 3 vsi12 1 Up VSI
WGE1/0/1 4 vsi13 1 Up VSI
Table 13 Command output
Total number of ACs |
Total number of attachment circuits (ACs) and the number of ACs in each state (up or down). |
Name of a Layer 2 Ethernet interface or Layer 2 aggregate interface. |
ID |
Ethernet service instance ID. |
Owner |
VSI name. This field is empty if an Ethernet service instance is not mapped to any VSI. |
LinkID |
Ethernet service instance's link ID on the VSI. |
State |
Ethernet service instance state: · Up. · Down. |
Type |
L2VPN type of the Ethernet service instance: · VSI. · VPWS. |
# Display detailed information about all Ethernet service instances on Twenty-FiveGigE 1/0/1.
<Sysname> display l2vpn service-instance interface twenty-fivegige 1/0/1 verbose
Interface: WGE1/0/1
Service Instance: 1
Type : Manual
Encapsulation : s-vid 16
Bandwidth : Unlimited
VSI Name : vsi10
Link ID : 1
State : Up
DF state : BDF
Statistics : Enabled
Input Statistics:
Octets :0
Packets :0
Output Statistics:
Octets :0
Packets :0
Table 14 Command output
Service Instance |
Type |
Type and traffic match mode of the Ethernet service instance: · Dynamic (MAC-based)—Dynamic Ethernet service instance in MAC-based traffic match mode. · Dynamic (VLAN-based)—Dynamic Ethernet service instance in VLAN-based traffic match mode. · Manual—Static Ethernet service instance in VLAN-based traffic match mode. |
Encapsulation |
Frame match criterion of the Ethernet service instance. If the Ethernet service instance does not contain a frame match criterion, the command does not display this field. |
Bandwidth |
Bandwidth limit in kbps. If no bandwidth limit is set for the Ethernet service instance, Unlimited is displayed. |
Link ID |
State |
DF state |
Whether the device is the designated forwarder for the AC at a multihomed EVPN site: · BDF—The device is a backup designated forwarder. · DF—The device is the designated forwarder. This field is not displayed if no Ethernet segment identifier is configured on the interface. |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the Ethernet service instance. · Disabled—The packet statistics feature is disabled for the Ethernet service instance. |
Input Statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. |
Output Statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. |
service-instance
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name VSI Index MTU State
vpna 0 1500 Up
Table 15 Command output
MTU |
MTU on the VSI. |
State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Admin down—The VSI has been manually shut down by using the shutdown command. |
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Broadcast Restrain : Unlimited
Multicast Restrain : Unlimited
Unknown Unicast Restrain: Unlimited
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Input statistics:
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Output statistics:
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Gateway Interface : VSI-interface 100
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel1 0x5000001 Up Manual Disabled
Tunnel2 0x5000002 Up Manual Disabled
MTunnel0 0x6002710 Up Auto Disabled
ACs:
AC Link ID State Type
WGE1/0/1 srv1000 0 Up Manual
Table 16 Command output
VSI Description |
Description of the VSI. If the VSI does not have a description, the command does not display this field. |
VSI State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Administratively down—The VSI has been manually shut down by using the shutdown command. |
MTU |
MTU on the VSI. |
Bandwidth |
Bandwidth limit in kbps. If no bandwidth limit is set for the VSI, Unlimited is displayed. |
Broadcast Restrain |
Broadcast restraint bandwidth (in kbps). If the broadcast restraint bandwidth is not set, Unlimited is displayed. |
Multicast Restrain |
Unknown multicast restraint bandwidth (in kbps). If the unknown multicast restraint bandwidth is not set, Unlimited is displayed. |
Unknown Unicast Restrain |
Unknown unicast restraint bandwidth (in kbps). If the unknown unicast restraint bandwidth is not set, Unlimited is displayed. |
MAC Learning |
State of the MAC learning feature. |
MAC Table Limit |
This field is not supported in the current software version. Maximum number of MAC address entries on the VSI. |
Drop Unknown |
This field is not supported in the current software version. Action on source MAC-unknown frames received after the maximum number of MAC entries is reached. |
Flooding |
State of the VSI's flooding feature: · Enabled—Flooding is enabled on the VSI. · Disabled—Flooding is disabled on the VSI. |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the VSI. · Disabled—The packet statistics feature is disabled for the VSI. |
Input statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
Output statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
Gateway Interface |
VSI interface name. |
State |
Tunnel state: · Up—The tunnel is operating correctly. · Blocked—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly. · Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP. · Down—The tunnel interface is down. |
Type |
Tunnel assignment method: · Auto—The tunnel was automatically assigned to the VXLAN: ¡ For an EVPN network, VXLAN tunnels are automatically assigned to VXLANs. ¡ For a multicast-mode VXLAN, the tunnel (MTunnel) was automatically created and assigned to the VXLAN to transmit flood traffic. · Manual—The tunnel was manually assigned to the VXLAN. |
Flood proxy |
Flood proxy state: · Enabled—Flood proxy is enabled. The VTEP sends broadcast, multicast, and unknown unicast traffic to a flood proxy server through the tunnel. The flood proxy server replicates and forwards flood traffic to remote VTEPs. · Disabled—Flood proxy is disabled. |
ACs |
ACs that are bound to the VSI. |
Link ID |
AC's link ID on the VSI. |
State |
AC state: · Up. · Down. |
Type |
Type and traffic match mode of the Ethernet service instance: · Dynamic (DRNI)—Dynamic Ethernet service instance in VLAN-based traffic match mode on the IPL. · Dynamic (MAC-based)—Dynamic Ethernet service instance in MAC-based traffic match mode. · Dynamic (VLAN-based)—Dynamic Ethernet service instance in VLAN-based traffic match mode. · Manual—Static Ethernet service instance in VLAN-based traffic match mode. |
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id: Specifies a VXLAN ID. The value range for this argument is 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
Total number of VXLAN tunnels: 2
VXLAN ID: 10, VSI name: vpna, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
Tunnel name Source Destination State Type Flood proxy Out VNI
Tun10 1.1.1.1 2.2.2.2 Up Manual Disabled -
Tun20 1.1.1.2 2.2.2.3 Up Manual Disabled -
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
Table 17 Command output
Total number of VXLAN tunnels |
This field is supported only in Release 6616 and later. Total number of VXLAN tunnels assigned to the VXLAN. |
Source |
This field is supported only in Release 6616 and later. Tunnel source address. |
Destination |
This field is supported only in Release 6616 and later. Tunnel destination address. |
Link ID |
Tunnel's link ID in the VXLAN. |
State |
Type |
Flood proxy |
Out VNI |
This field is supported only in Release 6616 and later. Remote VXLAN ID in outgoing packets, which can be configured by using one of the following commands: · mapping vni · tunnel tunnel-number remote-vni vxlan-id If no remote VXLAN ID is configured, this field displays a hyphen (-). |
tunnel
vxlan
Use display vxlan tunnel-interface to display information about VXLAN tunnel interfaces.
display vxlan tunnel-interface [ tunnel number [ verbose ] ]
tunnel number: Specifies an existing tunnel interface number. If you do not specify a VXLAN tunnel interface, this command displays information about all VXLAN tunnel interfaces.
verbose: Displays detailed information about VXLAN tunnel interfaces. If you do not specify this keyword, the command displays brief information about VXLAN tunnel interfaces.
# Display brief information about all VXLAN tunnel interfaces.
<Sysname> display vxlan tunnel-interface
Tunnel name Source Destination State Type Uptime
Tunnel1 3::3 4::4 Up Manual 06:19:03
Tunnel2 1.1.1.1 2.2.2.4 Down Manual -
# Display detailed information about VXLAN tunnel interface 2.
<Sysname> display vxlan tunnel-interface tunnel 2 verbose
Tunnel name : Tunnel2
Source : 1.1.1.1
Destination : 2.2.2.4
State : Down
Type : Manual
MAC learning : Disabled
Down reason : Resources not enough
Uptime : -
Table 18 Command output
Source |
Destination |
State |
Tunnel interface state: · Up. · Down. |
Type |
Tunnel assignment method: · Auto—The tunnel was automatically assigned to VXLANs by EVPN. · Manual—The tunnel was manually assigned to VXLANs. |
MAC learning |
Remote-MAC address learning state: · Enabled. · Disabled. |
Uptime |
Uptime of the VXLAN tunnel: · hh:mm:ss—The tunnel has been up for less than 24 hours. · xxxxhxxm—The tunnel has been up for more than 24 hours and less than 9999 hours. · ****hxxm—The tunnel has been up for more than 9999 hours. · -—The tunnel is down. |
tunnel
vxlan
emulate-ping vxlan
Use emulate-ping vxlan to test the reachability of a remote VM.
emulate-ping vxlan [ -c count | -m interval | -s packet-size | -t time-out ] * vxlan-id vxlan-id source-mac mac-address destination-mac mac-address
-c count: Specifies the number of ICMP echo requests to be sent. The value range is 1 to 4294967295, and the default value is 5.
-m interval: Specifies the interval for sending ICMP echo requests. The value range is 1 to 65535 milliseconds, and the default value is 200 milliseconds.
-s packet-size: Specifies the length of ICMP echo quests (IP and ICMP headers not included). The value range is 20 to 8100 bytes, and the default value is 56 bytes.
-t time-out: Specifies the ICMP echo reply timeout period. The value range is 0 to 65535 milliseconds, and the default value is 2000 milliseconds. If the device does not receive an ICMP echo reply within the timeout period after sending an ICMP echo request, the device determines that the ICMP echo reply times out.
vxlan-id vxlan-id: Specifies a VXLAN ID. The value range for the vxlan-id argument is 0 to 16777215.
source-mac mac-address: Specifies the source MAC address of ICMP echo requests. The MAC address must be a local VM address in the MAC address table of the specified VXLAN.
destination-mac mac-address: Specifies the destination MAC address of ICMP echo requests. The MAC address must be a remote VM address in the MAC address table of the specified VXLAN.
The emulate-ping vxlan command enables the device to test the reachability of a remote VM by simulating a local VM to send ICMP echo requests. The requests are encapsulated in Layer 2 data frames and then sent to the remote VM in the specified VXLAN. The device determines the reachability of the remote VM based on the response time and number of received ICMP echo replies. You can view the packet transmission statistics in the command output.
The emulate-ping vxlan command is not supported if EVPN distributed relay is configured on the device. For more information about EVPN distributed relay, see EVPN Configuration Guide.
# Simulate local VM 1ea3-c0be-0206 to test the reachability of remote VM 1ea3-b77b-0106 in VXLAN 100.
<Sysname> emulate-ping vxlan vxlan-id 100 source-mac 1ea3-c0be-0206 destination-mac 1ea3-b77b-0106
Emulate ping in VXLAN 100: source MAC 1ea3-c0be-0206, destination MAC 1ea3-b77b-0106, 56 data bytes.
Press CTRL_C to break.
56 bytes from 100.1.2.1: ICMP_seq=0 time=1.114 ms
56 bytes from 100.1.2.1: ICMP_seq=1 time=1.073 ms
56 bytes from 100.1.2.1: ICMP_seq=2 time=1.123 ms
56 bytes from 100.1.2.1: ICMP_seq=3 time=1.781 ms
56 bytes from 100.1.2.1: ICMP_seq=4 time=0.933 ms
--- Ping statistics for VXLAN 100 ---
round-trip min/avg/max/std-dev = 0.000/0.200/1.000/0.400 ms
Table 19 Command output
56 bytes from 100.1.2.1: ICMP_seq=0 time=1.114 ms |
Statistics about the received ICMP echo reply from the VM at 100.1.2.1. If no reply is received within the timeout period, nothing is displayed. · bytes—Number of bytes in the ICMP echo reply. · ICMP_seq—Sequence number, used to determine whether a request is lost, disordered, or repeated. · time—Response time. |
5 packet(s) transmitted |
Number of transmitted ICMP echo requests. |
5 packet(s) received |
Number of received ICMP echo replies. |
0.0% packet loss |
Percentage of unacknowledged requests. |
round-trip min/avg/max/std-dev=0.933/1.205/1.781/0.296 ms |
Minimum/average/maximum/standard deviation response time in milliseconds. |
encapsulation
Use encapsulation to configure a frame match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid vlan-id [ c-vid { vlan-id-list | all } | only-tagged ]
encapsulation s-vid vlan-id-list c-vid vlan-id-list
encapsulation { default | tagged | untagged }
undo encapsulation
An Ethernet service instance does not contain a frame match criterion.
s-vid: Matches frames that are tagged with the specified outer 802.1Q VLAN IDs.
c-vid: Matches frames that are tagged with the specified inner 802.1Q VLAN IDs.
vlan-id: Specifies an 802.1Q VLAN ID in the range of 1 to 4094.
vlan-id-list: Specifies a space-separated list of up to eight VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. You must specify a consecutive inner VLAN range.
only-tagged: Matches tagged frames. If the outer 802.1Q VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer 802.1Q VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
· To match only PVID-tagged frames, specify the only-tagged keyword.
· To match both untagged frames and PVID-tagged frames, do not specify the only-tagged keyword.
all: Specifies all 802.1Q VLAN IDs.
default: Specifies the default match criterion. On an interface, you can configure this criterion only in one Ethernet service instance. The device matches frames with the frame match criteria (including the default criterion) in the Ethernet service instances on the interface in the order as described in the usage guidelines. The Ethernet service instance that uses the default match criterion matches any frames if it is the only instance on the interface.
tagged: Matches any frames that have an 802.1Q VLAN tag.
untagged: Matches any frames that do not have an 802.1Q VLAN tag.
Make sure the VLANs that each Ethernet service instance matches have been created and the site-facing interface where the Ethernet service instance is configured has been assigned to the VLANs.
When you configure the encapsulation default command for an Ethernet service instance on a Layer 2 Ethernet interface or Layer 2 aggregate interface, follow these restrictions:
· If the Ethernet service instance uses the VLAN access mode, the device uses the following order to match frames on the interface to an Ethernet service instance:
a. encapsulation untagged.
b. encapsulation default.
c. encapsulation s-vid vlan-id-list [ c-vid vlan-id | only-tagged ].
· If the Ethernet service instance uses the Ethernet access mode, the device uses the following order to match frames on the interface to an Ethernet service instance:
a. encapsulation s-vid vlan-id-list [ c-vid vlan-id | only-tagged ].
b. encapsulation untagged.
a. encapsulation default.
With Release 6635 or later, you can execute the encapsulation command multiple times to modify the frame match criterion of an Ethernet service instance in the following scenarios:
· If you have configured the encapsulation s-vid { vlan-id | vlan-id-list } frame match criterion, you can repeat the encapsulation s-vid { vlan-id | vlan-id-list } command to add outer VLAN IDs.
· If you have configured the encapsulation s-vid { vlan-id | vlan-id-list } c-vid { vlan-id | vlan-id-list } frame match criterion, you can repeat the encapsulation s-vid { vlan-id | vlan-id-list } c-vid { vlan-id | vlan-id-list } command to add outer VLAN IDs. You cannot change the matching inner VLAN IDs.
To change the frame match criterion in other scenarios, first execute the undo encapsulation command to remove the original criterion. When you remove the frame match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
To change a frame match criterion in Release 6607, Release 6616, and Release 6616P01, first execute the undo encapsulation command to remove the original criterion. When you remove the frame match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
# Configure Ethernet service instance 1 on Twenty-FiveGigE 1/0/1 to match frames that have an outer 802.1Q VLAN ID of 111.
[Sysname-Twenty-FiveGigE1/0/1] service-instance 1
[Sysname-Twenty-FiveGigE1/0/1-srv1] encapsulation s-vid 111
Use flooding disable to confine the flood traffic of an Ethernet service instance.
Use undo flooding disable to restore the default.
flooding disable source-port
An Ethernet service instance sends flood traffic to the other Ethernet service instances of the same VSI.
source-port: Disables flooding to the other Ethernet service instances of the same VSI on the local port.
To prevent broadcast storms, use this command to confine the flood traffic of Ethernet service instances.
# Disable Ethernet service instance 10 from flooding traffic to the other Ethernet service instances of the same VSI on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] service-instance 10
[Sysname-Twenty-FiveGigE1/0/1-srv10] flooding disable source-port
flooding disable (VSI view)
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction | dci ]
Flooding is enabled for a VSI.
VSI view
all: Specifies broadcast, unknown unicast, and unknown multicast traffic.
broadcast: Specifies broadcast traffic.
unknown-multicast: Specifies unknown multicast traffic.
unknown-unicast: Specifies unknown unicast traffic.
all-direction: Disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If you do not specify this keyword, the command only disables flooding traffic received from ACs to VXLAN tunnel interfaces of the VSI.
dci: Disables flooding only to VXLAN-DCI tunnel interfaces. If you do not specify this keyword, the command disables flooding to both VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
By default, the device floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
· All site-facing interfaces except for the incoming interface.
· All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, use this command to disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
If VXLAN-DCI is configured, flood traffic is also sent out of VXLAN-DCI tunnel interfaces. To confine flood traffic to the site-facing interfaces and VXLAN tunnels within a data center, you can specify the dci keyword to disable flooding only to VXLAN-DCI tunnel interfaces.
The all-direction keyword disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If VXLAN-DCI is configured, this keyword also disables flooding between VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
# Disable flooding of local broadcast traffic to remote sites for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
group
Use group to assign a VXLAN a multicast group address for flood traffic, and specify a source IP address for multicast VXLAN packets.
Use undo group to restore the default.
group group-address source source-address
undo group group-address source source-address
A VXLAN uses unicast mode (head-end replication) for flood traffic. No multicast group address or source IP address is specified for multicast VXLAN packets.
VXLAN view
group-address: Specifies a multicast address in the range of 224.0.1.0 to 239.255.255.255. In Release 6635 and later, the multicast IP address cannot be included in the following multicast IP addresses:
· Default group address configured by using the default-group command in MVXLAN IPv4 address family view.
· Data group address range configured by using the data-group command in MVXLAN IPv4 address family view.
source source-address: Specifies a source IP address for multicast VXLAN packets.
To reduce traffic sent to the transport network, use multicast mode if the network has dense flood traffic or many VTEPs.
The multicast mode supports the following multicast methods:
· PIM—VTEPs and transport network devices run PIM to generate multicast forwarding entries. On a VTEP, you can use the IP address of a loopback interface as the source IP address for multicast VXLAN packets. If the VTEP has multiple transport-facing interfaces, PIM dynamically selects the outgoing interfaces for multicast VXLAN packets.
· IGMP host—VTEPs and transport network devices run PIM and IGMP to generate multicast forwarding entries.
¡ Transport-facing interfaces of VTEPs act as IGMP hosts.
¡ Transport network devices connected to a VTEP run IGMP.
¡ All transport network devices run PIM.
On a VTEP, you must use the IP address of the transport-facing interface as the source IP address for multicast VXLAN packets. If the VTEP has multiple transport-facing interfaces, multicast VXLAN packets are sent to the transport network through the interface that provides the source IP address for multicast VXLAN packets.
VTEPs in a multicast-mode VXLAN can use different multicast methods.
To forward multicast traffic correctly, you must use the source IP address of an up VXLAN tunnel as the source IP address for multicast VXLAN packets.
For multicast-mode VXLANs, transport network devices must maintain multicast group and forwarding information. To reduce the multicast forwarding entries maintained by transport network devices, assign a multicast group address to multiple VXLANs. The VTEP separates traffic between VXLANs by VXLAN IDs.
NOTE: For VXLANs that use the same multicast group address, you must configure the same source IP address for their multicast VXLAN packets. |
If you execute the group command multiple times for a VXLAN, the most recent configuration takes effect.
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] group 233.1.1.1 source 2.1.1.1
data-group (EVPN Command Reference)
default-group (EVPN Command Reference)
igmp host enable
pim dm (IP Multicast Command Reference)
pim sm (IP Multicast Command Reference)
Use hardware-resource vxlan to set the VXLAN hardware resource mode.
Use undo hardware-resource vxlan to restore the default.
hardware-resource vxlan { l2gw | l3gw | 48k-l3gw }
The VXLAN hardware resource mode is Layer 2 gateway.
l2gw: Specifies the Layer 2 gateway mode.
l3gw: Specifies the Layer 3 gateway mode.
48k-l3gw: Specifies the Layer 3 gateway mode with 48K of overlay resources. This keyword is supported only in Release 6635 and later.
Set the hardware resource mode for VXLAN based on the role of the device.
· l2gw—Applies to VTEPs that perform only Layer 2 forwarding.
· l3gw—Applies to VXLAN IP gateways.
# Set the VXLAN hardware resource mode to Layer 2 gateway mode.
[Sysname] hardware-resource vxlan l2gw
igmp host enable
Use igmp host enable to enable the IGMP host feature on an interface.
Use undo igmp host enable to disable the IGMP host feature on an interface.
igmp host enable
The IGMP host feature is disabled on an interface.
Interface view
You must configure an interface as an IGMP host if its IP address is the source IP address of multicast VXLAN packets. The IGMP host feature enables the interface to send IGMP reports in response to IGMP queries before it can receive traffic from a multicast group.
For this command to take effect, you must use the multicast routing command to enable IP multicast routing.
# Enable IP multicast routing, and then enable the IGMP host feature on VLAN-interface 10.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-Vlan-interface10] igmp host enable
group
multicast routing (IP Multicast Command Reference)
Use ipv6 nd suppression enable to enable ND flood suppression.
Use undo ipv6 nd suppression enable to disable ND flood suppression.
ND flood suppression is disabled.
VSI view
ND flood suppression reduces ND request multicasts by enabling the VTEP to reply to ND requests on behalf of user terminals.
This feature snoops ND packets to populate the ND flood suppression table with local and remote MAC addresses. If an ND request has a matching entry, the VTEP replies to the request on behalf of the user terminal or unicast the ND request. If no match is found, the VTEP floods the request to both local and remote sites or drops the ND request.
# Enable ND flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
ipv6 nd suppression mode
Use ipv6 nd suppression mode to set the ND flood suppression mode.
Use undo ipv6 nd suppression mode to restore the default.
ipv6 nd suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ND flood suppression is enabled, the default ND flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the NS packets that are not targeted at the device and do not match any ND flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device replies to the NS packet on behalf of the target IP address. The replied NA packet carries the following information:
· Sender IP address—Target IP address in the NS packet.
· Sender MAC address—MAC address in the matching ND flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device acts as follows:
1. Replaces the target MAC address in the NS packet with the MAC address in the entry.
2. Unicasts the NS packet.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an NS packet that is not targeted at the device and does not match any ND flood suppression entry. If you do not specify this keyword, the device will broadcast such an NS packet.
The device does not forward NS packets in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ND entry learning errors caused by the delay in refreshing ND flood suppression entries at the expense of high system resource usage.
# Enable ND flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] nd suppression mode unicast-forward
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn statistics interval
Use l2vpn statistics interval to set the L2VPN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The L2VPN statistics collection interval is 15 minutes.
Interval: Sets the L2VPN statistics collection interval in seconds, in the range of 5 to 65535.
# Set the L2VPN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
learning mode disable
Use learning mode disable to disable MAC address learning on an Ethernet service instance or tunnel interface.
Use undo learning mode to enable MAC address learning on an Ethernet service instance or tunnel interface.
undo learning mode
MAC address learning is enabled on an Ethernet service instance or tunnel interface.
Ethernet service instance view
VXLAN tunnel interface view
VXLAN-DCI tunnel interface view
When you enable MAC address learning on an Ethernet service instance, make sure MAC address learning is enabled on the VSI to which the Ethernet service instance is mapped. To enable MAC address learning for a VSI, use the mac-learning enable command.
When MAC address learning is disabled on an Ethernet service instance, it can use only the static local-MAC address entries added by using the mac-address static command.
When MAC address learning is disabled on a tunnel interface, the device no longer learns MAC address entries from the packets received on that tunnel interface.
# Disable MAC address learning on Ethernet service instance 200.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] mac-learning enable
[Sysname-vsi-vpn1] quit
[Sysname-Twenty-FiveGigE1/0/1-srv200] learning mode disable
mac-address mac-learning priority
Use mac-address mac-learning priority to set the MAC learning priority of an Ethernet service instance.
Use undo mac-address mac-learning priority to restore the default.
mac-address mac-learning priority { high | low }
The MAC learning priority of an Ethernet service instance is low.
high: Specifies high MAC learning priority.
low: Specifies low MAC learning priority.
This setting takes effect only after the Ethernet service instance is mapped to a VSI.
A VSI uses the MAC learning priority to control MAC address learning of its Ethernet service instances. An Ethernet service instance with high MAC learning priority takes precedence over an Ethernet service instance with low MAC learning priority when they learn the same MAC address. For example:
· A MAC address entry of a high-priority Ethernet service instance can be overwritten only when the MAC address is learned on another high-priority Ethernet service instance.
· A MAC address entry of a low-priority Ethernet service instance is overwritten when the MAC address is learned on a high-priority Ethernet service instance or another low-priority Ethernet service instance.
# Set the MAC learning priority to high for Ethernet service instance 1 on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1-srv1] mac-address mac-learning priority high
mac-address static vsi
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove a static MAC address entry for a VXLAN VSI.
mac-address static mac-address { interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number } vsi vsi-name
undo mac-address static [ mac-address ] [ interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number ] vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface interface-type interface-number service-instance instance-id: Specifies an Ethernet service instance on an interface. The interface-type interface-number argument specifies the interface by its type and number. The instance-id argument specifies the Ethernet service instance by its ID in the range of 1 to 4096. This option applies to local MAC addresses.
interface tunnel tunnel-number: Specifies a VXLAN or VXLAN-DCI tunnel interface by its tunnel interface number. The tunnel interface must already exist. This option applies to remote MAC addresses.
A local MAC address is the MAC address of a VM in the local site. Local MAC entries include manually added entries and dynamically learned entries.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through BGP EVPN.
When you add a local MAC address entry, make sure the specified Ethernet service instance has been mapped to the VSI. When you add a remote MAC address entry, make sure the VSI's VXLAN has been specified on the VXLAN or VXLAN-DCI tunnel.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
· EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
· EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
# Add MAC address 000f-e201-0102 of Ethernet service instance 1 to VSI vsi1. Specify Twenty-FiveGigE 1/0/1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0102 interface twenty-fivegige 1/0/1 service-instance 1 vsi vsi1
mac-based ac
Use mac-based ac to enable MAC-based traffic match mode for dynamic Ethernet service instances on an interface.
Use undo mac-based ac to disable MAC-based traffic match mode for dynamic Ethernet service instances on an interface.
mac-based ac
undo mac-based ac
MAC-based traffic match mode is disabled for dynamic Ethernet service instances. Dynamic Ethernet service instances use VLAN-based traffic match mode.
The 802.1X or MAC authentication feature can use the authorization VSI, the guest VSI, the Auth-Fail VSI, and the critical VSI to control the access of users to network resources. When assigning a user to a VSI, 802.1X or MAC authentication sends the VXLAN feature the VSI information and the user's access information, including access interface, VLAN, and MAC address. Then the VXLAN feature creates a dynamic Ethernet service instance for the user and maps it to the VSI.
A dynamic Ethernet service instance supports the following traffic match modes:
· VLAN-based mode—Matches frames by VLAN ID.
· MAC-based mode—Matches frames by VLAN ID and source MAC address.
To use MAC-based traffic match mode for dynamic Ethernet service instances, you must enable MAC authentication or 802.1X authentication that uses MAC-based access control.
This command takes effect only on dynamic Ethernet service instances. Static Ethernet service instances created by using the service-instance command match traffic only by the VLAN IDs specified by using the encapsulation command.
You cannot change the traffic match mode when dynamic Ethernet service instances already exist on an interface.
# Enable MAC-based traffic match mode for dynamic Ethernet service instances on Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] mac-based ac
overlay oam enable
Use overlay oam enable to enable overlay OAM.
Use undo overlay oam enable to disable overlay OAM.
overlay oam enable
NOTE: This command is supported only in Release 6635 and later. |
Overlay OAM is disabled.
You must enable overlay OAM on the tunnel destination device for a VXLAN tunnel before you can use the ping vxlan or tracert vxlan command to test reachability of the VXLAN tunnel on the tunnel source device. To specify the -r 3 parameter in the ping vxlan or tracert vxlan command on the tunnel source device, you must also enable overlay OAM on the tunnel source device.
# Enable overlay OAM.
[Sysname] overlay oam enable
ping vxlan
tracert vxlan
ping vxlan
Use ping vxlan to ping a VXLAN tunnel destination.
ping vxlan [ -a inner-src-address | -c count | -m interval | -r reply-mode | -t timeout | -tos tos-value ] * vxlan-id vxlan-id tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-a inner-src-address: Specifies the source IP address in the inner IP header of VXLAN echo requests. If you do not specify this option, the primary IP address of the outgoing interface is used as the source IP address in the inner IP header of VXLAN echo requests. Make sure the tunnel destination device can reach this source IP address. For example, you can specify the tunnel source address as the source IP address in the inner IP header of VXLAN echo requests.
-c count: Specifies the number of VXLAN echo requests to send, in the range of 1 to 4294967295. The default value is 5.
-m interval: Specifies the interval for sending VXLAN echo requests, in milliseconds. The value range for the interval argument 1 to 10000, and the default is 200 milliseconds.
-r reply-mode: Sets the reply mode used by the receiver to reply to VXLAN echo requests. The value of the reply-mode argument can be 1, 2, or 3.
· 1—Do not reply.
· 2—Look up the IP forwarding table for the destination IP address.
· 3—Perform VXLAN encapsulation.
-t timeout: Specifies the timeout time for receiving VXLAN echo replies, in milliseconds. The value range for the timeout argument is 0 to 65535, and the default is 2000 milliseconds.
-tos tos-value: Specifies the ToS value in the outer IP header of VXLAN echo requests. The value range for the tos-value argument is 0 to 255, and the default is 0.
vxlan-id vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215.
tunnel-source source-address: Specifies a VXLAN tunnel source IPv4 address.
tunnel-destination dest-address: Specifies a VXLAN tunnel destination IPv4 address.
destination-udpport dest-port: Specifies the destination UDP port number in the inner header of VXLAN echo requests. The value range for the dest-port argument is 1 to 65535, and the default is 50001. Specify this parameter if a specific port number is required to be used as the inner destination UDP port number.
vxlan-source-address vxlan-source-address: Specifies the source IPv4 address in the outer IP header of VXLAN echo requests. If you do not specify this option, the source IPv4 address is the address specified with the tunnel-source source-address parameter. On a DR member device, specify the source IPv4 address as the local VTEP IP address.
load-balance: Configures load balancing parameters. If you do not specify this keyword, the command tests only one of the multiple paths to the VXLAN tunnel destination.
vxlan-source-udpport vxlan-source-udpport end-vxlan-src-udpport: Specifies a source UDP port range for VXLAN echo requests. The value range for UDP port numbers is 49152 to 65535. The default start UDP port number is 4789. If you do not specify an end UDP port number, the end UDP port number is the start UDP port number.
source-address lb-src-address: Specifies the source IPv4 address used for load balancing calculation.
destination-address lb-dest-address: Specifies the destination IPv4 address used for load balancing calculation.
protocol: Specifies the protocol used for load balancing calculation.
udp: Specifies UDP.
lb-protocol-id: Specifies a protocol number in the range of 1 to 255.
source-port lb-src-port: Specifies a source port number used for load balancing calculation, in the range of 1 to 65535.
destination-port lb-dest-port: Specifies a destination port number used for load balancing calculation, in the range of 1 to 65535.
source-mac lb-source-mac: Specifies a source MAC address used for load balancing calculation.
destination-mac lb-destination-mac: Specifies a destination MAC address used for load balancing calculation.
Use this command to test the connectivity of a VXLAN tunnel in a VXLAN or EVPN VXLAN network when the tunnel has traffic loss or interruption issues.
Before you execute this command for a VXLAN tunnel, you must enable overlay OAM on the tunnel destination device by using the overlay oam enable command.
The VTEP can distribute VXLAN echo requests among multiple paths to the destination based on the source UDP port. When a VXLAN tunnel has multiple paths on the transport network, you can configure load sharing parameters to ensure accuracy of the test result. You can use one of the following methods to configure source UDP ports for VXLAN echo requests:
· Specify a source UDP port range. The device will send VXLAN echo requests sourced from each UDP port in the UDP port range. You need to execute the ping vxlan command only once.
· Specify load balancing parameters such as source and destination MAC addresses, source and destination IP addresses, and protocol for the VTEP to calculate a source UDP port number. You need to execute the ping vxlan command multiple times to test connectivity of all paths.
The load balancing parameters change only the source UDP port number of VXLAN echo requests. Other fields of the requests will not be changed.
If you specify the vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] parameters, the number of VXLAN echo requests sourced from each UDP port in the UDP port range is determined by the -c count parameter.
# Test connectivity of VXLAN 1 that is sourced from 11.11.11.11 and destined for 22.22.22.22.
<Sysname> ping vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Ping VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
Press CTRL+C to break.
40 bytes from 30.0.0.2: sequence=1 time=6 ms
40 bytes from 30.0.0.2: sequence=2 time=4 ms
40 bytes from 30.0.0.2: sequence=3 time=3 ms
40 bytes from 30.0.0.2: sequence=4 time=3 ms
40 bytes from 30.0.0.2: sequence=5 time=2 ms
--- Ping statistics for VXLAN 1 source 11.11.11.11 destination 22.22.22.22 ---
Round-trip min/avg/max = 2/3/6 ms
Table 20 Command output
Press CTRL+C to break |
Press escape key Ctrl+C to abort the ping operation. |
40 bytes from 30.0.0.2: sequence=1 time=6 ms |
Received VXLAN echo replies from a device. If no echo reply is received within the timeout period, no information is displayed. · bytes—Number of bytes in the VXLAN echo reply. · sequence—Packet sequence number used to determine whether a packet is lost, disordered, or repeated. · time—Response time. |
Return code |
Return code: · 0—No return code. · 1—Echo request error. · 2—The VXLAN does not exist. · 3—The VXLAN does not have up tunnels. The number in parentheses is a sub code fixed at 0. |
Ping statistics for VXLAN 1 source 11.11.11.11 destination 22.22.22.22 |
Statistics about the data received and sent in the ping operation. |
packets transmitted |
Number of sent VXLAN echo requests. |
packets received |
Number of received VXLAN echo replies. |
packet loss |
Percentage of unacknowledged requests to the total requests sent. |
Round-trip min/avg/max |
Minimum/average/maximum deviation response time, in milliseconds. |
overlay oam enable
tracert vxlan
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
reset arp suppression vsi
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
arp suppression enable
display arp suppression vsi
reset ipv6 nd suppression vsi
Use reset ipv6 nd suppression vsi to clear ND flood suppression entries on VSIs.
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ND flood suppression entries on all VSIs.
# Clear ND flood suppression entries on all VSIs.
<Sysname> reset ipv6 nd suppression vsi
display ipv6 nd suppression vsi
reset l2vpn mac-address
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
reset l2vpn mac-address mac-move
Use reset l2vpn mac-address mac-move to clear MAC move records for all VSIs.
# Clear MAC move records for all VSIs.
<Sysname> reset l2vpn mac-address mac-move
reset l2vpn statistics ac
Use reset l2vpn statistics ac to clear packet statistics on ACs.
reset l2vpn statistics ac [ interface interface-type interface-number [ service-instance instance-id ] ]
interface interface-type interface-number service-instance instance-id: Specifies an Ethernet service instance on an interface. The interface-type and interface-number arguments specify the interface type and number. The instance-id argument specifies an Ethernet service instance ID in the range of 1 to 4096.
If you do not specify any parameters, this command clears packet statistics on all ACs.
# Clear packet statistics for Ethernet service instance 1 on Twenty-FiveGigE 1/0/1.
<Sysname> reset l2vpn statistics ac interface twenty-fivegige 1/0/1 service-instance 1
ac statistics enable
display l2vpn service-instance verbose
statistics enable (Ethernet service instance view)
reset l2vpn statistics vsi
Use reset l2vpn statistics vsi to clear packet statistics on VSIs.
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on all VSIs.
# Clear packet statistics on all VSIs.
<Sysname> reset l2vpn statistics vsi
statistics enable (VSI view)
restrain
Use restrain to set broadcast, unknown multicast, or unknown unicast restraint bandwidth for a VSI.
Use undo restrain to restore the default.
restrain { broadcast | multicast | unknown-unicast } bandwidth
undo restrain { broadcast | multicast | unknown-unicast }
A VSI's broadcast restraint bandwidth, unknown multicast restraint bandwidth, and unknown unicast restraint bandwidth are not set.
VSI view
broadcast: Specifies the broadcast restraint bandwidth.
multicast: Specifies the unknown multicast restraint bandwidth.
unknown-unicast: Specifies the unknown unicast restraint bandwidth. Unknown unicast packets refer to the unicast packets whose destination MAC addresses are not in the MAC address table of the VSI.
bandwidth: Specifies the broadcast, unknown multicast, or unknown unicast restraint bandwidth in kbps. The value for the bandwidth argument can be 0 or in the range of 64 to 104857599. If you set this argument to 0, the command disables the specified kind of flood traffic.
When the bandwidth of incoming broadcast, unknown multicast, or unknown unicast traffic on VXLAN tunnels of a VSI exceeds the configured restraint bandwidth, the VSI drops the exceeding traffic.
If you use both the restrain and bandwidth commands on a VSI, the following rules apply:
· If the restraint bandwidth is 0, the restrain command takes effect.
· If the restraint bandwidth is not 0, the bandwidth command takes effect.
# Set the broadcast restraint bandwidth, unknown multicast restraint bandwidth, and unknown unicast restraint bandwidth to 100 kbps for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] restrain broadcast 100
[Sysname-vsi-vpn1] restrain multicast 100
[Sysname-vsi-vpn1] restrain unknown-unicast 100
display l2vpn vsi
selective-flooding mac-address
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
service-instance
Use service-instance to create an Ethernet service instance and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance.
undo service-instance instance-id
No Ethernet service instances exist.
instance-id: Specifies an Ethernet service instance ID in the range of 1 to 4096.
# On Layer 2 Ethernet interface Twenty-FiveGigE 1/0/1, create Ethernet service instance 1 and enter Ethernet service instance view.
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are up.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
Use statistics enable to enable packet statistics for an Ethernet service instance.
Use undo statistics enable to disable packet statistics for an Ethernet service instance.
statistics enable
The packet statistics feature is disabled for an Ethernet service instance.
For this command to take effect, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. If you modify the frame match criterion or VSI mapping, packet statistics of the instance is cleared.
# Enable packet statistics for Ethernet service instance 200 on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] service-instance 200
[Sysname-Twenty-FiveGigE1/0/1-srv200] statistics enable
Related command
statistics enable (tunnel interface view)
Use statistics enable to enable packet statistics for a manually created VXLAN or VXLAN-DCI tunnel.
Use undo statistics enable to disable packet statistics for a manually created VXLAN or VXLAN-DCI tunnel.
statistics enable
The packet statistics feature is disabled for a manually created VXLAN or VXLAN-DCI tunnel.
# Enable packet statistics for VXLAN tunnel interface Tunnel 0.
[Sysname] interface tunnel 0 mode vxlan
[Sysname-Tunnel0] statistics enable
display interface tunnel (Layer 3—IP Services Command Reference)
reset counters interface tunnel (Layer 3—IP Services Command Reference)
tunnel statistics vxlan auto
Use statistics enable to enable packet statistics for a VSI.
Use undo statistics enable to disable packet statistics for a VSI.
statistics enable
The packet statistics feature is disabled for a VSI.
VSI view
# Enable packet statistics for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
tracert vxlan
Use tracert vxlan to trace the path to a VXLAN tunnel destination.
tracert vxlan [ -a inner-src-address | -h ttl-value | -r reply-mode | -t timeout ] * vxlan-id vxlan-id tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-h ttl-value: Specifies the maximum TTL value in the outer IP header of VXLAN echo requests. The value range for the ttl-value argument is 1 to 255, and the default is 30.
· 1—Do not reply.
udp: Specifies UDP.
Use this command to locate failed nodes on the path for a VXLAN tunnel that has traffic loss or interruption issues in a VXLAN or EVPN VXLAN network.
# Trace the path for VXLAN 1 that is sourced from 11.11.11.11 and destined for 22.22.22.22.
<Sysname> tracert vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Tracert VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
TTL Replier Time InBound OutBound
1 20.0.0.1 2 ms WGE1/0/1 WGE1/0/2
2 30.0.0.2 4 ms WGE1/0/1 --
Table 21 Command output
TTL |
Number of hops. |
Replier |
Node IP address. |
Time |
Response time in milliseconds. |
InBound |
Incoming interface for the VXLAN echo request. |
OutBound |
Outgoing interface for the VXLAN echo request. |
Return code |
overlay oam enable
ping vxlan
tunnel
Use tunnel to assign VXLAN tunnels to a VXLAN.
Use undo tunnel to remove VXLAN tunnels from a VXLAN.
tunnel { tunnel-number [ backup-tunnel tunnel-number | flooding-proxy ] | all }
undo tunnel { tunnel-number | all }
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The tunnel must be an existing VXLAN tunnel.
backup-tunnel tunnel-number: Specifies a backup tunnel by its tunnel interface number. The tunnel must be an existing VXLAN tunnel.
flooding-proxy: Enables flood proxy on the tunnel for the VTEP to send flood traffic to the flood proxy server. The flood proxy server replicates and forwards flood traffic to remote VTEPs. If you do not specify this keyword, flood proxy is disabled on the tunnel.
all: Specifies all VXLAN tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
To assign a pair of primary and backup VXLAN tunnels to the VXLAN, specify the backup-tunnel tunnel-number option. When the primary VXLAN tunnel is operating correctly, the backup VXLAN tunnel does not forward traffic. When the primary VXLAN tunnel goes down, traffic is switched to the backup VXLAN tunnel.
On a VSI, you can enable flood proxy on multiple VXLAN tunnels. The first tunnel that is enabled with flood proxy works as the primary proxy tunnel to forward broadcast, multicast, and unknown unicast traffic. Other proxy tunnels are backups that do not forward traffic when the primary proxy tunnel is operating correctly.
To change a flood proxy tunnel for a VXLAN, perform the following tasks:
· Use the undo tunnel command to remove the flood proxy tunnel.
· Use the tunnel command to enable flood proxy on another tunnel and assign the tunnel to the VXLAN.
You cannot use the tunnel all command for VXLAN-DCI tunnel assignment. Please assign VXLAN-DCI tunnels to a VXLAN one by one.
If you assign VXLAN tunnels to a VXLAN one by one, you cannot remove all the VXLAN tunnels by using the undo tunnel all command.
If you assign all VXLAN tunnels to a VXLAN by using the tunnel all command, you cannot remove the VXLAN tunnels one by one. You can only use the undo tunnel all command to remove all the VXLAN tunnels.
As a best practice, use the tunnel all command only when batch VXLAN tunnel assignment is necessary.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel bfd enable
Use tunnel bfd enable to enable BFD on a VXLAN tunnel interface.
Use undo tunnel bfd enable to disable BFD on a VXLAN tunnel interface.
tunnel bfd enable destination-mac mac-address
BFD is disabled on a VXLAN tunnel interface.
destination-mac mac-address: Specifies a destination MAC address in H-H-H format for BFD control packets. The MAC address must be a remote VTEP address or a multicast address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
Enable BFD on both ends of a VXLAN tunnel for quick link connectivity detection. The VTEPs periodically send BFD single-hop control packets to each other through the VXLAN tunnel. A VTEP sets the tunnel state to Defect if it has not received control packets from the remote end for 5 seconds. In this situation, the tunnel interface state is still Up. The tunnel state will change from Defect to Up if the VTEP can receive BFD control packets again.
For BFD sessions to come up, you must reserve a VXLAN by using the reserved vxlan command.
Do not use BFD together with uRPF. When uRPF is enabled, BFD sessions cannot come up. For more information about uRPF, see Security Configuration Guide.
# Enable BFD on VXLAN tunnel interface Tunnel 9, and specify 1-1-1 as the destination MAC address for BFD control packets.
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when executing the undo tunnel global source-address command, the command deletes the global source IPv4 address for VXLAN tunnels.
IMPORTANT: For correct VXLAN deployment and VTEP management, do not manually specify tunnel-specific source addresses for VXLAN tunnels if OVSDB is used. |
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (VXLAN-DCI tunnels not included).
IPv4 VXLAN tunnels use the global source IPv4 address and IPv6 VXLAN tunnels use the global source IPv6 addresses.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
Use tunnel statistics vxlan auto to enable packet statistics for automatically created VXLAN tunnels.
Use undo tunnel statistics vxlan auto to disable packet statistics for automatically created VXLAN tunnels.
tunnel statistics vxlan auto [ destination ipv4-address ]
undo tunnel statistics vxlan auto [ destination ipv4-address ]
The packet statistics feature is disabled for automatically created VXLAN tunnels.
destination ipv4-address: Specifies a tunnel destination address. If you do not specify this option, the command enables packet statistics for all automatically created VXLAN tunnels.
This command enables the device to collect packet statistics for all automatically created VXLAN tunnels or a group of automatically created VXLAN tunnels that are destined for the specified address. This command takes effect on both existing VXLAN tunnels and VXLAN tunnels created after execution of this command.
VXLAN tunnels can be automatically created by EVPN or OVSDB.
# Enable packet statistics for automatically created VXLAN tunnels.
[Sysname] tunnel statistics vxlan auto
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan default-decapsulation
Use vxlan default-decapsulation to enable default IPv4 VXLAN decapsulation.
Use undo vxlan default-decapsulation to restore the default.
vxlan default-decapsulation source interface interface-type interface-number
undo vxlan default-decapsulation source interface
Default IPv4 VXLAN decapsulation is disabled.
source interface interface-type interface-number: Specifies an interface by its type and number.
If an IPv4 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv4 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional IPv4 VXLAN tunnel, enable default IPv4 VXLAN decapsulation on the interface whose IPv4 address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IPv4 address of that interface.
This command takes effect only when the specified interface has an IPv4 address.
The IP address of the specified interface must meet the following requirements:
· It is the destination address of a unidirectional VXLAN tunnel.
· It is the source address of a minimum of one up VXLAN tunnel.
Default IPv4 VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for an IPv4 VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
# Enable default IPv4 VXLAN decapsulation.
[Sysname] vxlan default-decapsulation source interface twenty-fivegige 1/0/1
vxlan invalid-udp-checksum discard
Use vxlan invalid-udp-checksum discard to enable the device to drop the VXLAN packets that fail UDP checksum check.
Use undo vxlan invalid-udp-checksum discard to restore the default.
The device does not check the UDP checksum of VXLAN packets.
This command enables the device to check the UDP checksum of VXLAN packets.
The device always sets the UDP checksum of VXLAN packets to 0. For compatibility with third-party devices, a VXLAN packet can pass the check if its UDP checksum is 0 or correct. If its UDP checksum is incorrect, the VXLAN packet fails the check and is dropped.
# Enable the device to drop the VXLAN packets that fail UDP checksum check.
[Sysname] vxlan invalid-udp-checksum discard
vxlan invalid-vlan-tag discard
Use vxlan invalid-vlan-tag discard to enable the device to drop the VXLAN packets that have 802.1Q VLAN tags in the inner Ethernet header.
Use undo vxlan invalid-vlan-tag discard to restore the default.
The device does not check whether a VXLAN packet has 802.1Q VLAN tags in the inner Ethernet header.
If a remote VTEP uses the Ethernet access mode, its VXLAN packets might contain 802.1Q VLAN tags. To prevent the local VTEP from dropping the VXLAN packets, do not execute the vxlan invalid-vlan-tag discard command on the local VTEP.
To configure the access mode, use the xconnect vsi command.
# Enable the device to drop VXLAN packets that have 802.1Q VLAN tags.
[Sysname] vxlan invalid-vlan-tag discard
xconnect vsi
vxlan ipv6 default-decapsulation
Use vxlan ipv6 default-decapsulation to enable default IPv6 VXLAN decapsulation.
Use undo vxlan ipv6 default-decapsulation to disable default IPv6 VXLAN decapsulation.
vxlan ipv6 default-decapsulation source interface interface-type interface-number
undo vxlan ipv6 default-decapsulation source interface
Default IPv6 VXLAN decapsulation is disabled.
If an IPv6 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv6 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional IPv6 VXLAN tunnel, enable default IPv6 VXLAN decapsulation on the interface whose IPv6 address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IPv6 address of that interface.
This command takes effect only when the specified interface has an IPv6 address.
Default IPv6 VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for an IPv6 VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
# Enable default IPv6 VXLAN decapsulation.
[Sysname] vxlan ipv6 default-decapsulation source interface twenty-fivegige 1/0/1
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to report the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
vxlan vlan-based
Use vxlan vlan-based to enable VLAN-based VXLAN assignment.
Use undo vxlan vlan-based to disable VLAN-based VXLAN assignment.
vxlan vlan-based
VLAN-based VXLAN assignment is disabled.
You can assign customer traffic to a VXLAN by using one of the following methods:
· Ethernet service instance-to-VSI mapping—This method uses the frame match criterion of an Ethernet service instance to match a list of VLANs on a site-facing Layer 2 interface. The VTEP assigns customer traffic to a VXLAN by mapping the Ethernet service instance to a VSI.
· VLAN-based VXLAN assignment—This method maps a VLAN to a VXLAN. When a VLAN is mapped to a VXLAN and VLAN-based VXLAN assignment is enabled, the device automatically performs the following operations:
b. Creates an Ethernet service instance that uses the VLAN ID as its instance ID on each interface in the VLAN. The matching outer VLAN ID of the Ethernet service instances is the VLAN ID.
c. Maps the Ethernet service instances to the VSI of the VXLAN.
Do not configure both Ethernet service instance-to-VSI mapping and VLAN-based VXLAN assignment.
# Enable VLAN-based VXLAN assignment.
[Sysname] vxlan vlan-based
vxlan vni
Use vxlan vni to map a VLAN to a VXLAN.
Use undo vxlan vni to remove the VXLAN mapping for a VLAN.
vxlan vni vxlan-id
undo vxlan vni
A VLAN is not mapped to a VXLAN.
VLAN view
vxlan-id: Specifies a VXLAN ID. The value range for this argument is 0 to 16777215.
Before you map VLANs to VXLANs, enable VLAN-based VXLAN assignment by using the vxlan vlan-based command.
You cannot map VLAN 1 to any VXLAN.
Do not map a VLAN to the L3 VXLAN ID of EVPN.
If you map a VLAN to a nonexistent VXLAN, the configuration takes effect after the VXLAN is created.
# Map VLAN 10 to VXLAN 100.
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
vxlan vlan-based
vxlan-over-vxlan enable
Use vxlan-over-vxlan enable to enable VXLAN over VXLAN on an interface.
Use undo vxlan-over-vxlan enable to disable VXLAN over VXLAN on an interface.
VXLAN over VXLAN is disabled on an interface.
An interface enabled with VXLAN over VXLAN does not de-encapsulate incoming VXLAN packets. Do not enable this feature on a transport-facing interface.
By default, the device de-encapsulates an incoming VXLAN packet if the packet's destination UDP port number is the VXLAN destination UDP port number (configured by using vxlan udp-port). For VXLAN packets received from a non-transport-facing interface on the device to traverse the VXLAN network through VXLAN tunnels, perform the following tasks on the interface:
· Enable VXLAN over VXLAN.
· Configure Ethernet service instance and VSI settings for matching the VXLAN packets.
When receiving VXLAN packets on the interface, the device adds a second layer of VXLAN encapsulation to the packets and forwards them over VXLAN tunnels.
# Enable VXLAN over VXLAN on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] vxlan-over-vxlan enable
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo xconnect vsi
An AC is not mapped to any VSI.
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
To monitor the status of an AC, associate it with track entries.
To configure this command for an Ethernet service instance, you must first use the encapsulation command to add a frame match criterion to the service instance.
For traffic that matches the Ethernet service instance, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
· VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡ For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡ For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
· Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡ For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡ For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
# On Twenty-FiveGigE 1/0/1, configure Ethernet service instance 200 to match frames with an outer 802.1Q VLAN tag of 200, and map the instance to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-Twenty-FiveGigE1/0/1-srv200] encapsulation s-vid 200
[Sysname-Twenty-FiveGigE1/0/1-srv200] xconnect vsi vpn1
encapsulation
vsi
VXLAN IP gateway commands
arp distributed-gateway dynamic-entry synchronize
Use arp distributed-gateway dynamic-entry synchronize to enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Use undo arp distributed-gateway dynamic-entry synchronize to disable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Dynamic ARP entry synchronization is disabled for distributed VXLAN IP gateways.
When local proxy ARP is enabled on distributed VXLAN IP gateways, each gateway learns ARP information independently. A gateway does not forward ARP packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ARP entries, you must enable dynamic ARP entry synchronization.
A controller or the EVPN feature can also synchronize ARP entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ARP entry synchronization.
# Enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
[Sysname] arp distributed-gateway dynamic-entry synchronize
distributed-gateway local
local-proxy-arp enable (Layer 3—IP Services Command Reference)
arp send-rate
Use arp send-rate to set an ARP packet sending rate limit for a VSI interface.
Use undo arp send-rate to remove the ARP packet sending rate limit for a VSI interface.
arp send-rate pps
undo arp send-rate
The ARP packet sending rate is not limited for a VSI interface.
VSI interface view
pps: Specifies a rate limit in the range of 1 to 500 pps.
VMs have limited capacity to process packets. To prevent packet processing from degrading VM performance, limit the ARP packet sending rate of the VSI interface for VMs. The VTEP will drop excess ARP packets if the rate limit is exceeded. This limit applies only to the ARP request packets sourced from the VSI interface.
# Set the ARP packet sending rate limit to 50 pps for VSI-interface 1.
<Sysname> system
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] arp send-rate 50
bandwidth
Use bandwidth to set the expected bandwidth for a VSI interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) of a VSI interface equals the interface baud rate divided by 1000.
VSI interface view
# Set the expected bandwidth to 10000 kbps for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
default
Use default to restore the default settings for a VSI interface.
default
VSI interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
1. Use the display this command in interface view to identify these commands.
2. Use their undo forms or follow the command reference to restore their default settings.
3. If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VSI-interface 100.
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to configure the description of a VSI interface.
The description of a VSI interface is interface-name plus Interface (for example, Vsi-interface100 Interface).
VSI interface view
# Configure the description as gateway for VXLAN 10 for VSI-interface 100.
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface
Use display interface vsi-interface to display information about VSI interfaces.
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]: Specifies VSI interfaces. If you specify a VSI interface, this command displays information about the specified interface. If you specify only the vsi-interface keyword, this command displays information about all VSI interfaces. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command displays information about all interfaces. Make sure the specified VSI interfaces have been created on the device.
brief: Display brief interface information. If you do not specify this keyword, the command displays detailed interface information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of interface descriptions.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
# Display information about VSI-interface 100.
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
Input (total): 0 packets, 0 bytes
Table 22 Command output
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface: · UP—The data link layer protocol is up. · UP(spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-Allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · Cellular-Allocated—IP address allocated through the modem manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2—WAN Access Configuration Guide. · MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address. |
IPv6 packet frame type |
IPv6 packet framing format. |
Physical |
Physical type of the interface, which is fixed at Unknown. |
baudrate |
Interface baudrate in kbps. |
Last clearing of counters |
Last time when the reset counters interface vsi-interface command was used to clear interface statistics. This field displays Never if the reset counters interface vsi-interface command has never been used on the interface since the device startup. |
Input (total): 0 packets, 0 bytes |
Incoming traffic statistics on the interface: · Number of incoming packets. · Number of incoming bytes. |
Output (total): 0 packets, 0 bytes |
Outgoing traffic statistics on the interface: · Number of outgoing packets. · Number of outgoing bytes. |
# Display brief information about all VSI interfaces.
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Vsi100 DOWN DOWN --
# Display brief information and complete description for VSI-interface 100.
<Sysname> display interface vsi-interface 100 brief description
Vsi100 UP UP 1.1.1.1 VSI-interface100
# Displays interfaces that are physically down and the down reason.
Interface Link Cause
Vsi100 DOWN Administratively
Vsi200 DOWN Administratively
Table 23 Command output
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · UP (s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. · DOWN—The data link layer protocol of the interface is down. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—The interface is not mapped to any VSI, or the mapped VSI does not have any AC or VXLAN tunnel. |
Use distributed-gateway local to specify a VSI interface as a distributed gateway to provide services for the local site.
Use undo distributed-gateway local to restore the default.
A VSI interface is not a distributed gateway.
VSI interface view
If a VXLAN uses distributed gateway services, you must assign the same IP address to the VXLAN's VSI interfaces on different VTEPs. To avoid IP address conflicts, you must specify the VSI interface on each VTEP as a distributed gateway.
# Specify VSI-interface 100 as a distributed gateway.
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet
Use gateway subnet to assign a subnet to a VSI.
Use undo gateway subnet to remove a subnet from a VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
No subnet is assigned to a VSI.
VSI view
ipv4-address: Specifies an IPv4 subnet address in dotted-decimal notation.
wildcard-mask: Specifies a wildcard mask in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in a packet's IP address are identical to the "do care" bits in the specified subnet address, the packet is assigned to the VSI. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
ipv6-address prefix-length: Specifies an IPv6 subnet address and the address prefix length in the range of 1 to 128.
You must configure this command on VSIs that share a gateway interface. This command enables the VSI interface to identify the VSI of a packet.
You can assign a maximum of eight IPv4 and IPv6 subnets to a VSI.
You must specify a gateway interface for a VSI before you can assign subnets to the VSI. If you remove the gateway interface from the VSI, the VSI's subnet settings are automatically deleted.
For VSIs that share a gateway interface, the subnets must be unique.
# Assign subnet 100.0.10.0/24 to VSI vxlan.
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface
Use gateway vsi-interface to specify a gateway interface for a VSI.
Use undo gateway vsi-interface to restore the default.
gateway vsi-interface vsi-interface-id
No gateway interface is specified for a VSI.
VSI view
vsi-interface-id: Specifies a VSI interface by its number. The VSI interface must already exist.
When you delete a VSI interface by using the undo interface vsi-interface command, the gateway interface setting of the VSI interface is also deleted.
A VSI can have only one gateway interface. Multiple VSIs can share a gateway interface.
# Specify VSI-interface 100 as the gateway interface for VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
Use interface vsi-interface to create a VSI interface and enter its view, or enter the view of an existing VSI interface.
Use undo interface vsi-interface to delete a VSI interface.
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
No VSI interfaces exist.
vsi-interface-id: Specifies a VSI interface number. The value range for this argument is 0 to 16777215.
# Create VSI-interface 100 and enter VSI interface view.
ipv6 nd distributed-gateway dynamic-entry synchronize
Use ipv6 nd distributed-gateway dynamic-entry synchronize to enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Use undo ipv6 nd distributed-gateway dynamic-entry synchronize to disable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Dynamic ND entry synchronization is disabled for distributed VXLAN IP gateways.
When local ND proxy is enabled on distributed VXLAN IP gateways, each gateway learns ND information independently. A gateway does not forward ND packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ND entries, you must enable dynamic ND entry synchronization.
A controller or the EVPN feature can also synchronize ND entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ND entry synchronization.
# Enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
[Sysname] ipv6 nd distributed-gateway dynamic-entry synchronize
local-proxy-nd enable (Layer 3—IP Services Command Reference)
mac-address
Use mac-address to assign a MAC address to a VSI interface.
Use undo mac-address to restore the default.
undo mac-address
The MAC address of VSI interfaces is the default MAC address of Layer 3 Ethernet interfaces..
VSI interface view
mac-address: Specifies a MAC address in H-H-H format.
# Assign MAC address 0001-0001-0001 to VSI-interface 100.
[Sysname-Vsi-interface100] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VSI interface.
mtu size
undo mtu
The default MTU of a VSI interface is 1444 bytes.
VSI interface view
size: Specifies an MTU value in the range of in the range of 46 to 1500 bytes bytes.
# Set the MTU to 1430 bytes for VSI-interface 100.
[Sysname-Vsi-interface100] mtu 1430
Use reset counters interface vsi-interface to clear packet statistics on VSI interfaces.
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
vsi-interface [ vsi-interface-id ]: Specifies VSI interfaces. If you specify a VSI interface, this command clears packet statistics on the specified interface. If you specify only the vsi-interface keyword, this command clears packet statistics on all VSI interfaces. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command clears packet statistics on all interfaces. Make sure the specified VSI interfaces have been created on the device.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear packet statistics on VSI-interface 100.
<Sysname> reset counters interface vsi-interface 100
shutdown
Use shutdown to shut down a VSI interface.
Use undo shutdown to bring up a VSI interface.
shutdown
A VSI interface is up.
VSI interface view
CAUTION: If you shut down a VSI interface, the VXLAN network using this VSI interface as the gateway will be unable to communicate with other networks at Layer 3. Make sure you are fully aware of the impact of this command when you use it on a live network. |
# Shut down VSI-interface 100.
[Sysname-Vsi-interface100] shutdown
vtep group member local
Use vtep group member local to assign the local VTEP to a VTEP group.
Use undo vtep group member local to remove the local VTEP from a VTEP group.
vtep group group-ip member local member-ip
undo vtep group group-ip member local
A VTEP is not assigned to any VTEP group.
group-ip: Specifies a VTEP group by its group IP address. The IP address must already exist on the local VTEP.
member-ip: Specifies the member VTEP IP address for the local VTEP. The IP address must already exist on the local VTEP.
Member VTEPs in a VTEP group cannot use the group IP address or share an IP address.
# Assign the local VTEP to VTEP group 1.1.1.1, and specify 2.2.2.2 as the member VTEP IP address of the local VTEP.
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
vtep group member remote
Use vtep group member remote to specify a VTEP group and its member VTEPs.
Use undo vtep group member remote to remove a VTEP group and its member VTEPs.
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
No VTEP group is specified.
member-ip&<1-8>: Specifies a space-separated list of up to eight member VTEP IP addresses.
# Specify VTEP group 1.1.1.1 and its member VTEPs at 2.2.2.2, 3.3.3.3, and 4.4.4.4.
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
vxlan tunnel arp-learning disable
Use vxlan tunnel arp-learning disable to disable remote ARP learning for VXLANs.
Use undo vxlan tunnel arp-learning disable to enable remote ARP learning for VXLANs.
Remote ARP learning is enabled for VXLANs.
By default, the device learns ARP information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ARP learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel arp-learning disable command to enable remote ARP learning.
As a best practice, disable remote ARP learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ARP learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
Use vxlan tunnel nd-learning disable to disable remote ND learning for VXLANs.
Use undo vxlan tunnel nd-learning disable to enable remote ND learning for VXLANs.
Remote ND learning is enabled for VXLANs.
By default, the device learns ND information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ND learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel nd-learning disable command to enable remote ND learning.
As a best practice, disable remote ND learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ND learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel nd-learning disable
OVSDB commands
ovsdb server bootstrap ca-certificate
Use ovsdb server bootstrap ca-certificate to specify a CA certificate file for establishing OVSDB SSL connections.
Use undo ovsdb server bootstrap ca-certificate to restore the default.
ovsdb server bootstrap ca-certificate ca-filename
SSL uses the CA certificate file in the PKI domain.
ca-filename: Specifies the CA certificate file name, a case-insensitive string. The file name cannot contain the slot string.
For the specified certificate to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
If the specified CA certificate file does not exist, the device obtains a self-signed certificate from the controller. The obtained file uses the name specified for the ca-filename argument.
# Specify CA certificate file ca-new for establishing OVSDB SSL connections.
[Sysname] ovsdb server bootstrap ca-certificate ca-new
ovsdb server enable
ovsdb server pki domain
ovsdb server pssl
ovsdb server ssl
ovsdb server enable
Use ovsdb server enable to enable the OVSDB server.
Use undo ovsdb server enable to disable the OVSDB server.
ovsdb server enable
The OVSDB server is disabled.
To obtain configuration data from controllers, you must enable the OVSDB server.
Before you enable the OVSDB server, you must establish an OVSDB SSL or TCP connection with a minimum of one controller.
# Enable the OVSDB server.
Use ovsdb server pki domain to specify a PKI domain for establishing OVSDB SSL connections.
Use undo ovsdb bootstrap server pki domain to restore the default.
ovsdb server pki domain domain-name
undo ovsdb server pki domain
No PKI domain is specified for establishing OVSDB SSL connections.
domain-name: Specifies a PKI domain name, a case-sensitive string of 1 to 31 characters. The PKI domain must already exist and contain a complete certificate and key.
To communicate with controllers through SSL, you must specify a PKI domain.
For the specified PKI domain to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
For more information about PKI domains, see PKI in Security Configuration Guide.
# Specify PKI domain ovsdb_test for establishing OVSDB SSL connections.
[Sysname] ovsdb server pki domain ovsdb_test
ovsdb server enable
ovsdb server pssl
ovsdb server ssl
ovsdb server pssl
Use ovsdb server pssl to enable the device to listen for OVSDB SSL connection requests.
Use undo ovsdb server pssl to restore the default.
ovsdb server pssl [ port port-number ]
The device does not listen for OVSDB SSL connection requests.
port port-number: Specifies a port to listen for OVSDB SSL connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
Before you use this command, you must specify a PKI domain for SSL.
You can specify only one port to listen for OVSDB SSL connection requests. If you execute this command multiple times, the most recent configuration takes effect.
For the specified port setting to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
# Enable the device to listen for OVSDB SSL connection requests on port 6640.
[Sysname] ovsdb server pssl
ovsdb server enable
ovsdb server ssl
ovsdb server ptcp
Use ovsdb server ptcp to enable the device to listen for OVSDB TCP connection requests.
Use undo ovsdb server ptcp to restore the default.
ovsdb server ptcp [ port port-number ] [ acl acl-number ]
The device does not listen for OVSDB TCP connection requests.
port-number: Specifies a port to listen for OVSDB TCP connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
acl acl-number: Specifies a basic IPv4 ACL by its ACL number to filter OVSDB TCP connection requests. The value range for the acl-number argument is 2000 to 2999.
You can specify only one port to listen for OVSDB TCP connection requests. If you execute this command multiple times, the most recent configuration takes effect.
If you specify a basic IPv4 ACL for this command, the OVSDB server accepts only the OVSDB TCP connection requests that are permitted by the ACL. The OVSDB server rejects any OVSDB TCP connection requests that do not match the ACL or that are denied by the ACL.
The OVSDB server does not filter OVSDB TCP connection requests in any of the following situations:
· No IPv4 ACL is specified for this command.
· The specified IPv4 ACL does not exist.
· The specified IPv4 ACL does not have rules.
You can specify only one IPv4 ACL to filter OVSDB TCP connection requests. If you execute this command multiple times, the most recent configuration takes effect.
Modification to rules in the specified IPv4 ACL takes effect only on OVSDB TCP connection requests that are received after the modification. If you specify another IPv4 ACL, the IPv4 ACL also takes effect only on OVSDB TCP connection requests that are received after the modification.
# Enable the device to listen for OVSDB TCP connection requests on port 6640.
[Sysname] ovsdb server ptcp
ovsdb server enable
ovsdb server tcp
ovsdb server ssl
Use ovsdb server ssl to set up an active OVSDB SSL connection to a controller.
Use undo ovsdb server ssl to remove an OVSDB SSL connection from a controller.
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
The device does not have active OVSDB SSL connections to a controller.
ip ip-address: Specifies the destination IP address for the SSL connection.
port port-number: Specifies the destination port for the SSL connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active SSL connections.
To establish the connection, you must execute the ovsdb server enable command. You must disable and then re-enable the OVSDB server if it has been enabled.
# Set up an active SSL connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server pssl
ovsdb server tcp
Use ovsdb server tcp to set up an active OVSDB TCP connection to a controller.
Use undo ovsdb server tcp to remove an OVSDB TCP connection.
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
The device does not have active OVSDB TCP connections.
ip ip-address: Specifies the destination IP address for the TCP connection.
port port-number: Specifies the destination port for the TCP connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active OVSDB TCP connections.
# Set up an active OVSDB TCP connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server ptcp
vtep access port
Use vtep access port to specify a site-facing interface as a VTEP access port.
Use undo vtep access port to restore the default.
vtep access port
An interface is not a VTEP access port.
For controllers to manage a site-facing interface, you must specify the interface as a VTEP access port.
# Specify Twenty-FiveGigE 1/0/1 as a VTEP access port.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] vtep access port
vtep acl disable
Use vtep acl disable to disable the ACLs issued by the OVSDB controller.
Use undo vtep acl disable to enable the ACLs issued by the OVSDB controller.
vtep acl disable
The ACLs issued by the OVSDB controller are enabled on the device.
Before you use this command, you must use the vtep enable command to enable the OVSDB VTEP service.
Use the vtep acl disable command on a VTEP to disable all the ACLs issued by the OVSDB controller in order to save ACL resources on the VTEP.
# Disable the ACLs issued by the OVSDB controller.
[Sysname] vtep enable
[sysname] vtep acl disable
vtep enable
vtep enable
Use vtep enable to enable the OVSDB VTEP service.
Use undo vtep enable to disable the OVSDB VTEP service.
vtep enable
undo vtep enable
The OVSDB VTEP service is disabled.
# Enable the OVSDB VTEP service.
vxlan tunnel flooding-proxy
Use vxlan tunnel flooding-proxy to enable flood proxy on multicast VXLAN tunnels.
Use undo vxlan tunnel flooding-proxy to disable flood proxy on multicast VXLAN tunnels.
Flood proxy is disabled on multicast VXLAN tunnels.
Flood proxy is supported on multicast VXLAN tunnels only when the OVSDB controller is a NSX controller from VMware.
If you use a flood proxy server, you must enable flood proxy globally on multicast tunnels. Then the multicast tunnels are converted into flood proxy tunnels. The VTEP sends broadcast, multicast, and unknown unicast traffic for a VXLAN to the flood proxy server through the tunnels. The flood proxy server then replicates and forwards flood traffic to remote VTEPs.
After you enable flood proxy on multicast VXLAN tunnels, if the controller issues VSI configuration, the system automatically disables ARP flood suppression on all VSIs issued by the controller. If the controller does not issue VSI configuration, the system does not automatically change the state of ARP flood suppression.
If you do not enable flood proxy on multicast VXLAN tunnels, the system does not automatically change the state of ARP flood suppression regardless of whether the controller issues VSI configuration.
The vxlan tunnel flooding-proxy command and its undo form affect only VXLAN tunnels that are issued after the vxlan tunnel flooding-proxy command.
# Enable flood proxy on all multicast VXLAN tunnels.
<Sysname> system
[Sysname] vxlan tunnel flooding-proxy
