08-ACL and QoS Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6805 & S6825 & S6850 & S9850 Command References-Release 66xx-6W10308-ACL and QoS Command Reference
03-Data buffer commands
03-Data buffer commands 150.91 KB
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
Basic data buffer commands
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to restore the default.
buffer apply
undo buffer apply
For data buffer settings to take effect, you must execute this command after configuring data buffer settings.
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
This command might cause the PFC function to be on longer in effect or to operate incorrectly. For information about PFC configuration commands, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer packet-drop alarm enable
Use buffer packet-drop alarm enable to enable packet-drop alarms.
Use undo buffer packet-drop alarm enable to disable packet-drop alarms.
Packet-drop alarms are disabled.
The device generates and reports packet-drop alarms to a network management system (such as IMC) for displaying the data buffer usage.
This command does not take effect only on the Headroom buffer.
# Enable packet-drop alarms.
[Sysname] buffer packet-drop alarm enable
buffer usage threshold queue (interface view)
buffer usage threshold queue (system view)
buffer packet-drop alarm interval
Use buffer packet-drop alarm interval to set the interval for sending packet-drop alarms.
Use undo buffer packet-drop alarm interval to restore the default.
buffer packet-drop alarm interval interval
The interval for sending packet-drop alarms is 5 seconds.
interval: Specifies the interval for sending packet-drop alarms, in the range of 0 to 60 seconds. The value of 0 indicates that packet-drop alarms are sent immediately after they are generated.
This command takes effect only when packet-drop alarms are enabled.
# Set the interval for sending packet-drop alarms to 20 seconds.
[Sysname] buffer packet-drop alarm interval 20
buffer queue guaranteed (system view)
Use buffer queue guaranteed to set the fixed-area space for a queue.
Use undo buffer queue guaranteed to delete the fixed-area space setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id guaranteed ratio ratio
undo buffer egress [ slot slot-number ] cell queue queue-id guaranteed
The fixed-area ratio for a queue is 13%.
egress: Specifies the egress buffer.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command applies to all IRF member devices.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 1 to 100.
By default, all queues have an equal share of the fixed area. You can set the fixed-area ratio for a queue. The other queues equally share the remaining part.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of fixed-area space configured for all queues cannot exceed the total fixed-area space. Otherwise, the configuration fails.
# Configure queue 0 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 guaranteed ratio 20
buffer queue guaranteed (interface view)
Use buffer queue guaranteed to set the fixed-area ratio or size for a queue.
Use undo buffer queue guaranteed to delete the fixed-area ratio or size setting of a queue.
buffer egress cell queue queue-id guaranteed ratio ratio
undo buffer egress cell queue queue-id guaranteed
Interface view
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 0 to 100.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of the fixed-area ratios configured for all queues cannot exceed 100%. The queue that causes the sum of the fixed-area ratios to exceed 100% fails to be configured and still uses the default setting.
# Configure queue 0 on Twenty-FiveGigE 1/0/1 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] buffer egress cell queue 0 guaranteed ratio 20
buffer queue map-to service-pool
Use buffer queue map-to service-pool to map a queue to a service pool.
Use undo buffer queue map-to service-pool to restore the default.
buffer { egress | ingress } queue queue-id map-to service-pool sp-id
undo buffer { egress | ingress } queue queue-id map-to
All queues are mapped to service pool 0.
Interface view
ingress: Specifies the ingress buffer.
service-pool sp-id: Specifies a service pool by its ID. The value range for the sp-id argument is 1 to 3.
Before configuring this command, use the buffer service-pool shared command to set the maximum shared-area ratio for the service pool.
For the ingress buffer, the queue ID specified represents the 802.1p priority. The actual queue ID mapped to the service pool is determined by the dot1p-lp priority map.
# Map queue 1 on Twenty-FiveGigE 1/0/1 to service pool 1.
[Sysname-Twenty-FiveGigE1/0/1] buffer egress queue 1 map-to service-pool 1
buffer queue shared (system view)
Use buffer queue shared to set the maximum shared-area ratio for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id shared { ratio ratio | size }
undo buffer egress [ slot slot-number ] cell queue queue-id shared
The maximum shared-area ratio for a queue is 20%.
ratio ratio: Specifies the maximum shared-area space ratio, in percentage. The value range for ratio is 0 to 100.
size: Specifies the maximum shared-area space, in the number of 100 to 132105 cell resources.
The size argument is supported only in Release 6616 and later.
The buffer egress [ slot slot-number ] cell queue queue-id shared size command must be used together with PFC. If you do not use PFC, do not execute this command. For more information about PFC, see Ethernet interface configuration in Layer 2—LAN Switching Configuration Guide.
By default, all queues have an equal share of the shared area. You can set the shared-area ratio for a queue. The unconfigured queues use the default setting. The shared-area space for each queue is finally determined by the chip based on your configuration and the number of packets to be received and sent.
# Configure queue 0 to use up to 10% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 shared ratio 10
buffer queue shared (interface view)
Use buffer queue shared to set the maximum shared-area ratio or size for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio or size setting of a queue.
buffer egress cell queue queue-id shared { ratio ratio | size }
undo buffer egress cell queue queue-id shared
Interface view
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 100.
The buffer egress cell queue queue-id shared size command must be used together with PFC. If you do not use PFC, do not execute this command. For more information about PFC, see Ethernet interface configuration in Layer 2—LAN Switching Configuration Guide.
# Configure queue 0 on Twenty-FiveGigE 1/0/1 to use 20% shared-area space of cell resources in the egress buffer.
[Sysname-Twenty-FiveGigE1/0/1] buffer egress cell queue 0 shared ratio 20
Use buffer service-pool shared to set the maximum shared-area ratio or size for a service pool.
Use undo buffer service-pool shared to delete the maximum shared-area ratio or size setting of a service pool.
buffer { egress | ingress } [ slot slot-number ] cell service-pool sp-id shared ratio ratio
undo buffer { egress | ingress } [ slot slot-number ] cell service-pool sp-id shared
All of the shared area is reserved for service pool 0.
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 99.
This command takes effect after you executed the buffer apply command.
If you specify the slot slot-number option, this command applies to the specified slot. If you do not specify the option, this command applies to all slots. The configuration for a slot have higher priority over the configuration for all slots.
# Configure service pool 1 to use up to 50% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell service-pool 1 shared ratio 50
buffer apply
buffer threshold alarm enable
Use buffer threshold alarm enable to enable threshold-crossing alarms.
Use undo buffer threshold alarm enable to disable threshold-crossing alarms.
buffer threshold alarm { egress | headroom | ingress } enable
undo buffer threshold alarm { egress | headroom | ingress } enable
Threshold-crossing alarms are disabled.
headroom: Specifies the Headroom buffer.
The device generates and reports threshold-crossing alarms to a network management system (such as IMC) for displaying the data buffer usage.
# Enable threshold-crossing alarms.
[Sysname] buffer threshold alarm ingress enable
buffer usage threshold headroom
buffer usage threshold headroom queue
buffer threshold alarm interval
Use buffer threshold alarm interval to set the interval for sending threshold-crossing alarms.
Use undo buffer threshold alarm interval to restore the default.
buffer threshold alarm { egress | headroom | ingress } interval interval
undo buffer threshold alarm { egress | headroom | ingress } interval
The interval for sending threshold-crossing alarms is 5 seconds.
interval: Specifies the interval for sending threshold-crossing alarms, in the range of 0 to 60 seconds. 0 indicates that threshold-crossing alarms are sent immediately after they are generated.
This command takes effect only when threshold-crossing alarms are enabled.
# Set the interval for sending threshold-crossing alarms to 20 seconds.
[Sysname] buffer threshold alarm ingress interval 20
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to delete the total shared-area ratio setting.
buffer egress [ slot slot-number ] cell total-shared ratio ratio
undo buffer egress [ slot slot-number ] cell total-shared
The total shared-area ratio is 100%.
ratio ratio: Specifies the ratio of the shared area, in percentage. The value range for ratio is 0 to 100.
After you set the shared-area ratio, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 50% space of cell resources in the egress buffer.
[Sysname] buffer egress cell total-shared ratio 50
Use buffer usage threshold to set a per-interface buffer usage threshold.
Use undo buffer usage threshold to restore the default.
buffer usage threshold slot slot-number ratio ratio
undo buffer usage threshold slot slot-number
The per-interface buffer usage threshold is 100%.
slot slot-number: Specifies an IRF member device by its member ID.
ratio ratio: Specifies the buffer usage threshold in percentage, in the range of 1 to 100.
After you configure this command, the switch automatically records buffer usage for each interface. When a queue on an interface uses more buffer space than the set threshold, the system counts one threshold violation for the queue.
To display the buffer usage statistics for interfaces, use the display buffer usage interface command.
# Set the per-interface buffer usage threshold to 50% for IRF member device 1.
[Sysname] buffer usage threshold slot 1 ratio 50
Use buffer usage threshold headroom to set the global per-queue alarm threshold for the Headroom buffer.
Use undo buffer usage threshold headroom to restore the default.
buffer usage threshold headroom slot slot-number ratio ratio
undo buffer usage threshold headroom slot slot-number ratio
The global per-queue alarm threshold for the Headroom buffer is 100%.
ratio ratio: Specifies the alarm threshold in percentage, in the range of 1 to 100.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global alarm threshold for the Headroom buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
#  Set the global per-queue alarm threshold to 50% for slot 1.
[Sysname] buffer usage threshold headroom slot 1 ratio 50
Use buffer usage threshold headroom queue to set the Headroom buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold headroom queue to restore the default.
buffer usage threshold headroom queue queue-id ratio ratio
undo buffer usage threshold headroom queue queue-id ratio
The global per-queue alarm threshold for the Headroom buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the Headroom buffer alarm threshold to 50% for queue 1 on Twenty-FiveGigE 1/0/1.
[Sysname–Twenty-FiveGigE1/0/1] buffer usage threshold headroom queue 1 ratio 50
Use buffer usage threshold queue to set the ingress or egress buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold queue to restore the default.
buffer { egress | ingress } usage threshold queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold queue queue-id ratio
The global per-queue alarm threshold for the ingress or egress buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold for the ingress or egress buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the ingress buffer alarm threshold to 50% for queue 1 on Twenty-FiveGigE 1/0/1.
[Sysname–Twenty-FiveGigE1/0/1] buffer ingress usage threshold queue 1 ratio 50
Use buffer usage threshold queue to set the global ingress or egress buffer alarm threshold for a queue.
buffer { egress | ingress } usage threshold slot slot-number  queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold slot slot-number queue queue-id ratio
The global ingress or egress buffer alarm threshold for a queue is 100%.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global ingress or egress alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
#  Set the global ingress alarm threshold to 50% for queue 1 in slot 1.
[Sysname] buffer ingress usage threshold slot 1 queue 1 ratio 50
buffer usage threshold service-pool
Use buffer usage threshold service-pool to set the alarm threshold for a service pool.
Use undo buffer usage threshold service-pool to restore the default.
buffer { egress | ingress } usage threshold service-pool sp-id slot slot-number ratio ratio
undo buffer { egress | ingress } usage threshold service-pool sp-id slot slot-number ratio
The alarm threshold for a service pool is 100%.
service-pool sp-id: Specifies a service pool by its ID. The value range for the sp-id argument is 0 to 3.
This command takes effect only when threshold-crossing alarms are enabled. When the usage of a service pool exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the alarm threshold to 50% for a service pool in slot 1.
[Sysname] buffer egress usage threshold service-pool 0 slot 1 ratio 50
buffer queue shared
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·     Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·     Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·     Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
The default data buffer settings will be changed after the Burst feature is enabled. You can display the data buffer settings by using the display buffer command.
Disabling the Burst feature after enabling it might cause the PFC function to be on longer in effect or to operate incorrectly. For information about PFC configuration commands, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer size settings for all IRF member devices.
queue queue-id: Specifies a queue by its number in the range of 0 to 7. If you specify a queue, this command displays the fixed-area ratio and shared-area ratio for the specified queue. If you specify the queue keyword without the queue-id argument, this command displays the fixed-area ratio and shared-area ratio for each queue. If you do not specify the queue keyword, this command displays the total shared-area ratio.
# Display buffer size settings.
<Sysname> display buffer
Slot  Type    Eg(Total-shared)
1     cell    100
          Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
        Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for the queues.
<Sysname> display buffer queue
Slot  Queue        Type    Eg(Guaranteed , Shared)
1     0-7          cell    13 , 20
  Guaranteed: Size of the minimum guaranteed buffer per queue
      Shared: Size of the maximum shared buffer per queue
        Unit: Ratio
Resource type.
Queue
Queue ID in the range of 0 to 7.
Eg
Egress buffer.
(Total-shared)
Total-shared indicates the total shared-area ratio.
·     Guaranteed indicates the fixed-area ratio of a queue.
·     Shared indicates the shared-area ratio of a queue.
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display buffer usage.
<Sysname> display buffer usage
Ingress total-shared cell buffer usage on slot 2 :
XPE 0
Total:   32768 KB
Used:       0 KB
Free:   32768 KB
Global_headroom:       0 KB
SP0_headroom_used:       0 KB
SP0_Headroom_peak:       0 KB
SP0_buffer_total:   32677 KB
SP0_buffer_used:       0 KB
SP0_buffer_peak:       0 KB
SP1_headroom_used:       0 KB
SP1_Headroom_peak:       0 KB
SP1_buffer_total:       0 KB
SP1_buffer_used:       0 KB
SP1_buffer_peak:       0 KB
SP2_headroom_used:       0 KB
SP2_Headroom_peak:       0 KB
SP2_buffer_total:       0 KB
SP2_buffer_used:       0 KB
SP2_buffer_peak:       0 KB
SP3_headroom_used:       0 KB
SP3_Headroom_peak:       0 KB
SP3_buffer_total:       0 KB
SP3_buffer_used:       0 KB
SP3_buffer_peak:       0 KB
Egress total-shared cell buffer usage on slot 2 :
XPE 0
Total:   32768 KB
Used:       0 KB
Free:   32768 KB
                       5sec   1min   5min
WGE2/0/1       XPE 0     0%     0%     0%
WGE2/0/2       XPE 0     0%     0%     0%
WGE2/0/3       XPE 0     0%     0%     0%
WGE2/0/4       XPE 0     0%     0%     0%
WGE2/0/5       XPE 0     0%     0%     0%
Usage of cell resources in the shared area on an IRF member device.
Unit
Chip number.
XPE
Type of the data buffer.
Total
Total size of the data buffer.
Used
Size of used data buffer.
Free
Size of free data buffer.
Global_headroom
Total headroom size.
SP
Service pool.
headroom_used
Headroom area usage in KB for the ingress buffer.
Headroom_peak
Peak used Headroom area in KB during the time between two executions of the display buffer usage command.
buffer_total
Total buffer size in KB.
buffer_used
Used buffer size in KB.
buffer_peak
Peak used buffer size in KB during the time between two executions of the display buffer usage command.
5sec
Percentage of the buffer that the port uses for the last 5 seconds.
1min
Percentage of the buffer that the port uses for the last 1 minute.
5min
Percentage of the buffer that the port uses for the last 5 minutes.
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ] [ verbose ]
interface-type [ interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
verbose: Displays detailed buffer usage statistics. If you do not specify this keyword, the command displays brief buffer usage statistics.
# Display brief buffer usage statistics for Twenty-FiveGigE 1/0/1.
<Sysname> display buffer usage interface twenty-fivegige 1/0/1
Interface              QueueID Total       Used        Threshold(%) Violations
WGE1/0/1               0       26214       0           70           0
                       1       26214       0           70           0
                       2       26214       0           70           0
                       3       26214       0           70           0
                       4       26214       0           70           0
                       5       26214       0           70           0
                       6       26214       0           70           0
                       7       26214       0           70           0
Total
Data buffer size (in the number of cell resources) allowed for a queue.
Used
Data buffer size (in the number of cell resources) that has been used by a queue.
Threshold(%)
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value.
Violations
Number of threshold violations for a queue.
The value of this field is reset upon a switch reboot.
# Display detailed buffer usage statistics for Twenty-FiveGigE 1/0/1.
[Sysname] display buffer usage interface twenty-fivegige 1/0/1 verbose
Ingress:
    QueueID: 0
      Total: 131078            Used: 0                  Threshold(%): 100
      Violations: 0            Shared: 0                Headroom: 0
      XoffThres: 131072        IsDynamic: 0
      Used(%): 0               Free: 131072             UsedPeak: 0
      HeadroomUsed(%): 0       HeadroomFree: 0          HeadroomPeak: 0
    QueueID: 1
    QueueID: 2
    QueueID: 3
    QueueID: 4
    QueueID: 5
    QueueID: 6
    QueueID: 7
  Egress:
    QueueID: 0
      Total: 26214             Used: 0                  Threshold(%): 100
      Violations: 0            TailDropThres: 26214     IsDynamic: 1
      DeadlockCount: 0         DeadlockRecover: 0
      Used(%): 0               Free: 26214              UsedPeak: 0
    QueueID: 1
    QueueID: 2
    QueueID: 3
    QueueID: 4
    QueueID: 5
    QueueID: 6
    QueueID: 7
Ingress
Usage statistics for the ingress buffer.
Egress
Usage statistics for the egress buffer.
Total
Data buffer size allowed for a queue, in cell resources.
Used
Data buffer size that has been used by a queue, in cell resources.
Threshold(%)
Violations
Shared
Number of cell resources in the shared area used by a queue.
Headroom
Number of cell resources in the Headroom area used by a queue.
When a queue on an interface enabled with PFC enters PFC XOFF state, the interface sends XOFF frames to notify the peer interface to stop sending packets to that queue. Packets sent by the peer interface before it receives XOFF frames are stored in the Headroom area.
XoffThres
Back pressure frame triggering threshold in number of cell resources.
For commands to configure back pressure frame triggering thresholds, see Ethernet interface commands in Layer 2—LAN Switching Command Reference.
TailDropThres
Tail drop threshold, in the number of cell resources calculated according to the ratio value set in the buffer queue shared command.
IsDynamic
For the inbound direction, this field can be one of the following values:
·     0—Indicates a static back pressure frame triggering threshold.
·     1—Indicates a dynamic back pressure frame triggering threshold.
For the outbound direction, this field can only be 1, which indicates a dynamic tail drop threshold.
Used(%)
Buffer usage in percentage.
Free
Free buffer in cell resources.
UsedPeak
Peak used buffer in cell resources during the time between two executions of the display buffer usage interface command.
HeadroomUsed(%)
Headroom area usage in percentage for the ingress buffer.
HeadroomFree
Free Headroom area in number of cell resources for the ingress buffer.
HeadroomPeak
Peak used Headroom area in number of cell resources during the time between two executions of the display buffer usage interface command.
DeadlockCount
Number of times the device entered the PFC deadlock state in the egress buffer.
DeadlockRecover
Number of times the device released the PFC deadlock state in the egress buffer.
For more information about back pressure frame triggering thresholds and PFC deadlock, see Ethernet interface configuration in Layer 2—LAN Switching Configuration Guide.
TCB commands
buffer transient-capture enable
Use buffer transient-capture enable to enable and configure TCB.
Use undo buffer transient-capture enable to disable TCB.
System view:
buffer transient-capture global [ slot slot-number ] egress enable [ no-local-analysis ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ start-threshold start-threshold-value stop-threshold stop-threshold-value ] [ frozen-number frozen-number frozen-timer timer-value ] [ pre-sample-rate pre-sample-rate post-sample-rate post-sample-rate ] [ poll-frequency frequency-value ]
undo buffer transient-capture global [ slot slot-number ] enable
This command is supported only in Release 6616 and later.
Interface view:
buffer transient-capture { egress [ queue queue-id ] | ingress } enable [ no-local-analysis ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ start-threshold start-threshold-value stop-threshold stop-threshold-value ] [ frozen-number frozen-number frozen-timer timer-value ] [ pre-sample-rate pre-sample-rate post-sample-rate post-sample-rate ] [ poll-frequency frequency-value ]
TCB is disabled.
Interface view
global: Configures TCB globally. This keyword is supported only in system view.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command configures TCB for the master device.
queue-id: Specifies a queue by its ID in the range of 0 to 7. If you do not specify a queue, this command enables TCB for all queues. This argument is supported only in interface view.
ingress: Specifies the ingress buffer. This keyword is supported only in interface view.
no-local-analysis: Reports raw packet data and packet drop reason without performing local analysis. If you do not specify this parameter, local analysis is performed.
acl: Specifies an ACL. If you do not specify an ACL, this command enables TCB for all traffic.
·     ipv4-acl-number: Specifies an advanced IPv4 ACL by its number in the range of 3000 to 3999.
·     name ipv4-acl-name: Specifies an advanced IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter.
start-threshold start-threshold-value: Specifies the queue length in bytes above which packet capturing will be started. The value range for the start-threshold-value argument is 1 to 67108352. The default is 2500. The value for the start-threshold-value argument must be greater than the value for the stop-threshold-value argument.
stop-threshold stop-threshold-value: Specifies the queue length in bytes below which packet capturing will be stopped. The value range for the stop-threshold-value argument is 1 to 67108352. The default is 1500. The value for the stop-threshold-value argument must be greater than the value for the start-threshold-value argument.
frozen-number frozen-number: Specifies the number of packets to be captured before the TCB state machine moves to the frozen state. The value range for the frozen-number argument is 3 to 1024. The default is 256.
frozen-timer timer-value: Specifies the capture timer for moving the TCB state machine to the frozen state. The value range for the timer-value argument is 1 to 500. The default is 500.
pre-sample-rate pre-sample-rate: Specifies the number of packets captured in the pre-trigger state. The value range for the pre-sample-rate argument is 1 to 16. The default is 16. If the value range is 1 to 16, the specified number of packets are sampled out of 16 packets. If you specify 16, all packets are captured.
post-sample-rate post-sample-rate: Specifies the number of packets captured in the post-trigger state. The value range for the post-sample-rate argument is 1 to 16. The default is 16. If the value range is 1 to 16, the specified number of packets are sampled out of 16 packets. If you specify 16, all packets are captured.
poll-frequency frequency-value: Specifies the number of times that data is reported per minute. The value range for the frequency-value argument is 1 to 600. The default is 20.
The TCB feature monitors packet drop events on queues. When a packet is dropped on a queue, the system collects the drop time, drop reason, packet metadata, and other information and reports them to an NMS through gRPC.
You can configure TCB in system view or interface view, but not in both views at the same time. For example, if you have configured TCB in system view, to configure TCB in interface view, you must first delete the TCB configuration in system view.
The TCB configuration in system view takes effect on all TCB-capable interfaces. The TCB configuration in interface view takes effect only on the specified interface.
In interface view, only one interface on the device can be configured with TCB.
If TCB is configured on a VTEP in a VXLAN network to monitor packets to site networks, it obtains outer header information instead of inner header information of VXLAN packets as the packet characteristics.
Configure TCB for slot 1.
[Sysname] buffer transient-capture global slot 1 egress enable no-local-analysis acl 3000 start-threshold 10000 stop-threshold 5000 frozen-number 1000 frozen-timer 500 pre-sample-rate 10 post-sample-rate 10 poll-frequency 30
# Configure TCB on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] buffer transient-capture egress enable no-local-analysis acl 3000 start-threshold 10000 stop-threshold 5000 frozen-number 1000 frozen-timer 500 pre-sample-rate 10 post-sample-rate 10 poll-frequency 30
display buffer transient-capture packet-drop
Use display buffer transient-capture packet-drop to display packet drop information.
IMPORTANT
IMPORTANT:
display buffer transient-capture packet-drop slot slot-number { ethernet | ipv4 | ipv6 }
ethernet: Displays packet drop information for Ethernet frames.
ipv4: Displays packet drop information for IPv4 packets.
ipv6: Displays packet drop information for IPv6 packets.
This command lists packet drop events in chronological order, including the number of packets dropped, drop time, dropped packet characteristics, queue and interface, and drop reason.
# Display IPv4 packet drop information for slot 1.
<Sysname> display buffer transient-capture packet-drop slot 1 ipv4
TCB STATUS: EgressPort WGE1/0/1
No.  Time  SMAC  DMAC  VLAN  SIP  DIP  SPort  DPort  Queue  IfName  Reason
Total Drop Packets in Ring Buffer of XPE 0: 10
0  8a44800  0010-9400-0005  0010-9400-0002  100  192.168.1.2  192.168.0.1  0  0  0  WGE1/0/1  2
Table 5 Command output
Time
Time when packets were dropped, in the form of UNIX timestamps (time since 00:00:00 01/01/1970).
Reason
Packet drop reason:
·     1—Dropped when enqueued.
·     2—Dropped when dequeued.
·     3—Dropped by WRED.
·     4—Dropped due to insufficient cell resources.
Total packets dropped on XPE0
Total number of packets dropped on XPE0. XPE is a data buffer type.
