12-FC and FCoE Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Command Reference-6W10212-FC and FCoE Command Reference
01-FC and FCoE commands
01-FC and FCoE commands 894.99 KB
FC and FCoE commands· 1
FCoE mode commands· 1
display fcoe-mode· 1
fcoe-mode· 2
FC interface commands· 3
bandwidth (FC interface view) 3
default (FC interface view) 3
description (FC interface view) 4
display interface fc· 5
fc mode (FC interface view) 12
fcb2bcredit 12
fcb2bcredit recovery enable· 13
fill-word· 14
interface fc· 14
port-type· 15
reset counters interface fc· 16
shutdown (FC interface view) 17
speed· 17
using· 18
VFC interface commands· 19
bandwidth (VFC interface view) 19
bind interface· 20
default (VFC interface view) 22
description (VFC interface view) 22
display interface vfc· 23
fc mode (VFC interface view) 26
interface vfc· 27
reset counters interface vfc· 27
shutdown (VFC interface view) 28
FC link aggregation commands· 28
bandwidth (FC aggregate interface view) 28
default (FC aggregate interface view) 29
description (FC aggregate interface view) 30
display interface san-aggregation· 30
display san-aggregation· 33
fc mode (FC aggregate interface view) 36
interface san-aggregation· 37
reset counters interface san-aggregation· 37
san-aggregation group· 38
san-aggregation load-sharing mode local-first 39
shutdown (FC aggregate interface view) 40
FCoE commands· 40
display fcoe· 40
display fcoe vlan· 41
fcoe enable· 42
fcoe fcf-priority· 43
fcoe fcmap· 43
fcoe fka-adv-period· 44
fcoe global fcf-priority· 46
VSAN commands· 47
display vsan port-member 47
display vsan status· 48
port 48
port access vsan· 49
port trunk mode· 50
port trunk vsan· 51
vsan· 52
working-mode· 53
Fabric building commands· 54
allowed-domain-id· 54
display fc domain· 55
display fc domain-list 56
display fc ess· 57
display fc login· 59
display fc name-service database· 60
display fc port-bind-area· 63
display fc scr-table· 64
display fc switch-wwn· 65
display fc timer 65
display fcid allocation· 66
display fcid persistent 67
display rdp database· 68
display rdp request-polling-interval 73
display smartsan status· 74
domain auto-reconfigure enable· 74
domain configure enable· 75
domain restart 75
domain-id· 76
fabric-name· 77
fc domain rcf-reject 78
fc login-limit 79
fc name-service auto-discovery· 80
fc port-bind-area enable· 80
fc timer distributed-services· 81
fc timer error-detect 82
fc timer resource-allocation· 83
fc wwn default-fc4-type· 83
fcid persistent enable· 84
priority· 85
rdp request-polling-interval 86
reset fcid persistent 87
rscn aggregation enable· 87
rscn aggregation timer 88
smartsan enable· 88
snmp-agent trap enable fc-fabric· 89
snmp-agent trap enable fc-name-service· 90
timer distributed-services· 91
timer error-detect 92
timer resource-allocation· 92
wwn fcid· 93
FC routing and forwarding commands· 94
display fc exchange· 94
display fc fib· 96
display fc routing-table· 98
display fspf graceful-restart 101
display fspf lsdb· 102
display fspf neighbor 103
display fspf statistics· 104
fc route-static· 106
fspf cost 107
fspf dead-interval 108
fspf enable· 108
fspf graceful-restart 109
fspf graceful-restart helper 110
fspf graceful-restart interval 110
fspf hello-interval 111
fspf min-ls-arrival 112
fspf min-ls-interval 113
fspf retransmit-interval 113
fspf silent 114
fspf spf-hold-time· 115
reset fspf counters· 115
FC zone commands· 116
delete zone database all 116
display zone· 117
display zone member 118
display zone statistics· 120
display zone status· 121
display zone-alias· 122
display zoneset 124
display zoneset active· 125
member (zone alias view) 127
member (zone set view) 129
member (zone view) 129
pairwise-zoning enable· 131
reset zone statistics· 132
snmp-agent trap enable fc-zone· 133
zone clone· 133
zone default-zone permit 134
zone hard-zoning enable· 135
zone merge-control restrict 136
zone mode enhanced· 137
zone name· 138
zone rename· 138
zone-alias clone· 139
zone-alias name· 140
zone-alias rename· 140
zoneset activate· 141
zoneset clone· 142
zoneset distribute· 143
zoneset distribute full 143
zoneset name· 144
zoneset rename· 145
zone-type peer-zone· 146
NPV commands· 147
display fc nport 147
display npv login· 148
display npv status· 149
display npv traffic-map· 151
npv auto-load-balance enable· 152
npv auto-load-balance-interval 152
npv load-balance disruptive· 153
npv traffic-map· 154
FIP snooping commands· 154
display fip-snooping enode· 155
display fip-snooping fcf 155
display fip-snooping flushing-rules· 156
display fip-snooping rules· 157
display fip-snooping sessions· 158
fip-snooping enable· 159
fip-snooping fc-map· 159
fip-snooping port-mode· 160
Port security commands· 161
any-wwn· 161
display fc-port-security database· 162
display fc-port-security statistics· 163
display fc-port-security status· 164
display fc-port-security violation· 165
fc-port-security· 166
fc-port-security database copy· 167
fc-port-security enable· 167
nwwn· 168
pwwn· 169
reset fc-port-security database· 171
reset fc-port-security statistics· 171
snmp-agent trap enable fc-port-security· 172
swwn· 173
FCS commands· 174
display fcs database· 174
display fcs discovery status· 175
display fcs ie· 176
display fcs port 178
fcs discovery start 181
fcs discovery stop· 182
FDMI commands· 182
display fdmi database· 182
FC ping commands· 188
fcping· 188
FC tracert commands· 189
fctracert 189
The S6800-2C and S6800-4C switches support FC after the LSWM124XG2QFC or LSWM116FC interface module is installed. The S6800-2C-FC switch supports FC after the LSWM18G24FC interface module is installed. The S6820-4C switch supports FC after the LSWM124XG2QFC interface module is installed.
The LSWM124XG2QFC and LSWM18G24FC interface modules provide FC interfaces operating at up to 8 Gbps. The LSWM116FC interface module provides FC interfaces operating at up to 32 Gbps.
FC and FCoE require a license to run on the device. For more information about licensing, see license management in Fundamentals Configuration Guide.
For FC and FCoE to work, the device must operate in advanced or expert mode. The S6800 and S6860 switch series support the expert mode, and the S6820 and S6861 switch series do not. For more information about system operating modes, see device management in Fundamentals Configuration Guide.
FCoE mode commands
display fcoe-mode
Use display fcoe-mode to display the FCoE mode of the switch.
display fcoe-mode
# Display the FCoE mode of the switch.
<Sysname> display fcoe-mode
The FCoE mode is NONE.
The FCoE mode is mode.
The mode can be one of the following:
·     FCF.
·     FCF-NPV.
·     NPV.
·     TRANSIT.
·     NONE (non-FCoE mode).
fcoe-mode
fcoe-mode
Use fcoe-mode to configure an FCoE mode for the switch.
Use undo fcoe-mode to restore the default.
fcoe-mode { fcf | fcf-npv | npv | transit }
undo fcoe-mode
A switch operates in non-FCoE mode.
fcf: Specifies the FCF mode.
fcf-npv: Specifies the FCF-NPV mode.
npv: Specifies the NPV mode.
transit: Specifies the Transit mode.
An FC and FCoE-capable switch can operate in non-FCoE mode or in one of the following FCoE modes:
·     FCF mode—When the switch operates in this mode, it is an FCF switch and supports E_Ports and F_Ports. An FCF switch can connect to the following elements:
¡     An E_Port on another FCF switch through its E_Port.
¡     An N_Port or NP_Port through its F_Port.
·     NPV mode—When the switch operates in this mode, it is an NPV switch and supports F_Ports and NP_Ports. An NPV switch can connect to the following elements:
¡     An F_Port through its NP_Port.
·     FCF-NPV mode—When the switch operates in this mode, it is an FCF-NPV switch. A VSAN on an FCF-NPV switch can operate in either of the following modes:
¡     FCF mode—When a VSAN operates in this mode, the VSAN acts as an FCF switch.
¡     NPV mode—When a VSAN operates in this mode, the VSAN acts as an NPV switch.
·     Transit mode—When the switch operates in this mode, it is a Transit switch.
You can configure Ethernet interfaces on a Transit switch to operate in ENode or FCF mode. An Ethernet interface in ENode mode can receive traffic from only an ENode. An Ethernet interface in FCF mode can receive traffic from only an FCF switch.
The switch can only convert from non-FCoE mode to one FCoE mode, or vice versa. It cannot convert directly among FCoE modes. To convert among FCoE modes, first convert the switch to non-FCoE mode. Converting the switch to non-FCoE mode also clears all FC- and FCoE-related settings in the original FCoE mode except FC interfaces, FC aggregate interfaces, and VFC interfaces.
# Configure the switch to operate in FCF mode.
[Sysname] fcoe-mode fcf
# Convert the switch operating in FCF mode to NPV mode.
[Sysname] undo fcoe-mode
All current FC configuration will be lost. Continue? [Y/N]:y
[Sysname] fcoe-mode npv
display fcoe-mode
The commands in this section are supported only on FCF, FCF-NPV, and NPV switches.
Use bandwidth to set the expected bandwidth for an FC interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) of an FC interface is the interface baud rate divided by 1000.
FC interface view
The expected bandwidth of an interface affects the link costs in FSPF. You can control the route selection by setting the expected bandwidth.
# Set the expected bandwidth to 50 kbps for FC 1/0/1.
[Sysname] interface fc 1/0/1
[Sysname-Fc1/0/1] bandwidth 50
Use default to restore the default settings for an FC interface.
default
FC interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for FC 1/0/1.
[Sysname-Fc1/0/1] default
This command will restore the default settings. Continue? [Y/N]:y
The description of an FC interface is interface name Interface, for example, Fc1/0/1 Interface.
FC interface view
The description helps users identify the role of an interface.
# Configure the description of FC 1/0/1 as FCport1.
[Sysname-Fc1/0/1] description FCport1
Use display interface fc to display FC interface information.
display interface [ fc [ interface-number ] ] [ brief [ description | down ] ]
fc [ interface-number ]: Specifies FC interfaces. If you do not specify the fc keyword, this command displays information about all interfaces supported by the device. If you specify the fc keyword but not the interface-number argument, this command displays information about all FC interfaces.
brief: Displays brief information about interfaces. If you do not specify this keyword, the command displays detailed information about interfaces.
down: Displays information about the interfaces in physically down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about FC 1/0/1.
<Sysname> display interface fc 1/0/1
Fc1/0/1
Current state: UP
Line protocol state: UP
Description: Fc1/0/1 Interface
Bandwidth: 4000000kbps
Maximum transmission unit: 2112
4000Mbps-speed mode
Link layer protocol is FC
Fill word is idle-idle
Port WWN is 66:66:66:62:65:34:30:39
FC mode is F, state is F
BB_Credit Recovery is enabled
Transmit B2B Credit is 15
Receive B2B Credit is 15
Support the VSAN protocol
VSAN tagging mode is Non tagging
EVFP common VSAN : 1
Media type is not sure,port hardware type is UNKNOWN_SFP
Port priority: 0
4Gbps-speed mode, Link speed type is autonegotiation, Flow-control is enabled
The maximum frame length is 10000
Last link flapping: 1 hours 12 minutes 25 seconds
Peak input rate: 0 bytes/sec, at 2016-12-06 00:31:08
Peak output rate: 0 bytes/sec, at 2016-12-06 00:31:08
Last 300 second input: 0 packets/sec 0 bytes/sec 0%
Last 300 second output: 0 packets/sec 0 bytes/sec 0%
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
Output (normal): 0 packets, 0 bytes
          0 lost carrier, - no carrier
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
4000Mbps-speed mode
The interface is operating at 4000 Mbps.
The interface is not assigned an IP address and cannot process IP packets.
Fill word
Fill word mode of the interface:
·     idle-idle.
·     idle-arbff.
FC mode
Mode of the interface.
state
Operating mode of the interface through negotiation.
Transmit B2B Credit
Buffer-to-buffer credit (BB_Credit) value of the local end.
This field is displayed only after the link comes up.
Receive B2B Credit
BB_Credit value of the remote end.
Support VSAN Protocol
The interface supports the VSAN protocol after negotiation.
VSAN tagging mode
VSAN tagging mode of the interface after the Exchange Virtual Fabrics Protocol (EVFP) negotiation: Tagging or Non tagging.
EVFP common VSAN
Common VSANs in up state through the EVFP negotiation.
This field is displayed if the speed auto command is configured.
Link speed type is force link
This field is displayed if a specific rate is configured by using the speed command.
Flow-control
Flow control function status of the FC interface:
·     enabled.
·     not enabled.
MTU of the FC interface.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the interface statistics were last cleared by using the reset counters interface fc command. Never indicates that the interface statistics have never been cleared since switch startup.
Peak value of input
Peak incoming traffic rate on the FC interface.
Peak value of output
Peak outgoing traffic rate on the FC interface.
Last 300 seconds input:  0 packets/sec 9 bytes/sec 0%
Average incoming traffic rate on the FC interface in the last 300 seconds and the percentage of the actual rate to the maximum interface rate (configured by using the speed command).
A hyphen (-) indicates that the statistics item is not supported.
Last 300 seconds output:  0 packets/sec 9 bytes/sec 0%
Average outgoing traffic rate on the FC interface in the last 300 seconds and the percentage of the actual rate to the maximum interface rate (configured by using the speed command).
A hyphen (-) indicates that a statistics item is not supported.
Input (total):  142 packets, 13596 bytes
          142 unicasts, 0 broadcasts,  0 multicasts, 0 pauses
Total numbers of frames and bytes received on the FC interface, including normal frames, error frames, and pause frames.
·     unicasts—Number of frames received that are destined to unicast addresses.
·     broadcasts—Number of frames received that are destined to broadcast addresses.
·     multicasts—Number of frames received that are destined to multicast addresses.
·     pauses—Number of pause frames received.
Input (normal):  142 packets, - bytes
Total number of normal frames received on the FC interface and total number of bytes of these frames, including normal frames and pause frames.
·     unicasts—Number of normal frames received that are destined to unicast addresses.
·     broadcasts—Number of normal frames received that are destined to broadcast addresses.
·     multicasts—Number of normal frames received that are destined to multicast addresses.
input errors
Total number of error frames received on the FC interface.
runts
Number of frames received that meet the following requirements:
·     Smaller than 64 bytes.
·     In correct format.
·     Have valid CRC values.
giants
Number of jumbo frames received. Jumbo frames are frames larger than the maximum allowed frame size.
For an FC interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an FC interface that permits jumbo frames, the maximum Ethernet frame length is configured when you configure jumbo frame support on the interface.
throttles
Number of times the switch shuts down the FC interface due to buffer or CPU overload.
CRC
Number of incoming frames that had a valid length but contained CRC errors.
frame
Number of incoming frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of incoming frames dropped because the input rate of the FC interface exceeded the queuing capability.
aborts
Total number of illegal incoming frames:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames larger than the maximum frame allowed size on the FC interface (with an integral or non-integral length).
¡     For an FC interface that does not permit jumbo frames, the maximum allowed frame size is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an FC interface that permits jumbo frames, the maximum allowed frame size is configured when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained at least one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of incoming frames dropped because the receiving buffer of the port ran low.
parity errors
Number of incoming frames with parity errors.
Output (total):  139 packets, 13748 bytes
          139 unicasts, 0 broadcasts,  0 multicasts, 0 pauses
Total numbers of frames and bytes sent on the FC interface, including normal frames, error frames, and pause frames.
·     unicasts—Number of frames sent that are destined to unicast addresses.
·     broadcasts—Number of frames sent that are destined to broadcast addresses.
·     multicasts—Number of frames sent that are destined to multicast addresses.
·     pauses—Number of pause frames sent.
Output (normal):  139 packets, - bytes
Total number of normal frames sent on the FC interface and total number of bytes of these frames, including normal frames and pause frames.
·     unicasts—Number of normal frames sent that are destined to unicast addresses.
·     broadcasts—Number of normal frames sent that are destined to broadcast addresses.
·     multicasts—Number of normal frames sent that are destined to multicast addresses.
output errors
Total number of error frames sent on the FC interface.
underruns
Number of outgoing frames dropped because the output rate of the FC interface exceeded the queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of frames dropped due to insufficient transmitting buffer resources.
aborts
Total number of frames that are not successfully sent for various reasons, for example, collisions.
deferred
Number of frames that are delayed for transmission because collisions are detected before they are sent.
collisions
Number of frames that the FC interface stopped transmitting because collisions were detected during transmission.
late collisions
Number of frames that the FC interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the FC interface failed to detect the carrier when attempting to send frames. This counter increases by one each time the FC interface failed to detect the carrier, and applies to serial WAN interfaces.
# Display brief information about FC 1/0/1.
<Sysname> display interface fc 1/0/1 brief
Brief information on FC interface(s):
Admin Mode: auto - auto; E - e port; F - f port; NP - n port proxy
Oper Mode: E - e port; F - f port; NP - n port proxy;
           TE - trunking e port; TF - trunking f port;
           TNP - trunking n port proxy
Interface  VSAN Admin Admin Oper Oper   Status SAN-Aggregation
                Mode  Trunk Mode Speed
                      Mode
Fc1/0/1    2    F     off   F    4G     UP     SAGG23
Name of the interface.
VSAN
Access VSAN of the interface.
Admin Mode
User-configured interface mode:
·     auto.
·     E.
·     F.
·     NP.
Admin Trunk Mode
User-configured trunk mode for the interface:
·     auto.
·     on.
·     off.
Oper Mode
Negotiated mode (link layer negotiation) in which the interface is operating:
·     E—The interface is operating in E mode as an access port.
·     F—The interface is operating in F mode as an access port.
·     NP—The interface is operating in NP mode as an access port.
·     TE—The interface is operating in E mode as a trunk port.
·     TF—The interface is operating in F mode as a trunk port.
·     TNP—The interface is operating in NP mode as a trunk port.
If negotiation is not initiated or fails, this field displays two hyphens (--).
Oper Speed
Interface rate in bps after physical layer negotiation is performed and the data link layer comes up.
Status
Negotiated state (link layer negotiation) for the interface:
·     UP.
·     DOWN.
SAN-Aggregation
FC aggregation group to which the interface belongs.
This field is empty when the interface is not assigned to an FC aggregation group.
# Display the descriptions of FC interfaces.
<Sysname> display interface fc brief description
Interface    Description
Fc1/0/2      Fc1/0/2 Interface
Fc1/0/3      Fc1/0/3 Interface
# Display brief information about the FC interfaces in physically down state.
<Sysname> display interface fc brief down
Brief information on interface(s) under bridge mode:
Fc1/0/1              ADM  Administratively
Brief information about Layer 2 interfaces.
Interface name.
Link
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Not connected—No physical connection exists (possibly because the optical fiber is disconnected or faulty).
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
Use fc mode to set the mode of an FC interface.
Use undo fc mode to restore the default.
fc mode { auto | e | f | np }
undo fc mode
On an FCF switch, the mode of an FC interface is auto.
On an NPV or FCF-NPV switch, the mode of an FC interface is F.
FC interface view
auto: Specifies the auto mode, so that the FC interface can operate in F mode or E mode through dynamic negotiation.
e: Specifies the E mode.
f: Specifies the F mode.
np: Specifies the NP mode.
FC interfaces on an FCF switch support only auto, E, and F modes. FC interfaces on an NPV switch support only F and NP modes. FC interfaces on an FCF-NPV switch support only E, F, and NP modes.
On an FCF-NPV switch, if the mode of an FC interface does not match the mode of a VSAN of the interface, the mode does not take effect in the VSAN.
# Set the mode to F for FC 1/0/1.
[Sysname-Fc1/0/1] fc mode f
working-mode
fcb2bcredit
Use fcb2bcredit to set the BB_Credit value for an FC interface.
Use undo fcb2bcredit to restore the default.
fcb2bcredit credit-value
undo fcb2bcredit
The BB_Credit value for an FC interface is 15.
FC interface view
credit-value: Specifies the number of packets that the FC interface can continuously receive. The value range for this argument is 1 to 500 on LSWM116FC cards and 1 to 15 on other cards .
The BB_Credit is a flow control mechanism used to ensure that an FC interface does not drop packets.
The BB_Credit value is configurable. Typically, you do not need to change the default value.
# Set the BB_Credit value to 10 for FC 1/0/1.
[Sysname-Fc1/0/1] fcb2bcredit 10
Use fcb2bcredit recovery enable to enable BB_Credit recovery for an FC interface.
Use undo fcb2bcredit recovery enable to disable BB_Credit recovery for an FC interface.
BB_Credit recovery is disabled for an FC interface.
FC interface view
This command allows two FC interfaces to recover the connection when BB_Credits are lost.
For the feature to take effect, you must configure the command on both FC interfaces.
# Enable BB_Credit recovery for FC 1/0/1.
[Sysname-Fc1/0/1] fcb2bcredit recovery enable
fill-word
Use fill-word to set the fill word mode for an 8-Gbps FC interface.
Use undo fill-word to restore the default.
fill-word { idle-arbff | idle-idle }
undo fill-word
An 8-Gbps FC interface uses the idle-arbff mode.
FC interface view
idle-arbff: Specifies the idle-arbff mode. This mode uses the idle primitive signal in the link initialization phase and uses the ARBff primitive signal as the fill word.
idle-idle: Specifies the idle-idle mode. This mode uses the idle primitive signal in the link initialization phase and uses the idle primitive signal as the fill word.
This command is available only for 8-Gbps FC interfaces. 2-Gbps and 4-Gbps FC interfaces support only the idle-idle mode.
For two 8-Gbps FC interfaces to communicate correctly, make sure the fill word is the same on them.
To make the fill word mode setting take effect, execute the shutdown and undo shutdown commands on the FC interface.
# Set the fill word mode to idle-idle for FC 1/0/1.
[Sysname-Fc1/0/1] speed 8000
[Sysname-Fc1/0/1] fill-word idle-idle
speed
interface fc
Use interface fc to enter FC interface view.
interface fc interface-number
interface-number: Specifies an FC interface by its number.
# Enter the view of FC 1/0/1.
[Sysname-Fc1/0/1]
port-type
Use port-type to configure the port type.
In Layer 2 Ethernet interface view:
port-type fc
In FC interface view:
port-type ethernet
The interfaces on the LSWM124XG2QFC and LSWM18G24FC interface modules are Layer 2 Ethernet interfaces. The interfaces on the LSWM116FC interface module are FC interfaces.
FC interface view
ethernet: Changes an FC interface back to a Layer 2 Ethernet interface.
fc: Changes a Layer 2 Ethernet interface to an FC interface.
The 10-GE Layer 2 Ethernet interfaces on the following interface modules can be changed to 8-Gbps FC interfaces: LSWM124XG2QFC installed on the S6800-2C or S6800-4C switch, LSWM18G24FC installed on the S6800-2C-FC switch, and LSWM124XG2QFC installed on the S6820-4C switch. When you execute the port-type command on a Layer 2 Ethernet interface, other interfaces are not affected. To change a Layer 2 Ethernet interface to an FC interface, use the port-type fc command in Layer 2 Ethernet interface view. To change an FC interface back to a Layer 2 Ethernet interface, use the port-type ethernet command in FC interface view.
If an LSWM116FC card is installed on an S6800-2C switch, the FC interfaces on the card can operate at up to 32 Gpbs and can be changed to 10-GE Ethernet interfaces.
If an LSWM116FC card is installed on an S6800-4C switch, the FC interfaces on the card can operate at up to 32 Gpbs and FC interfaces 14 and 16 cannot be split or changed to Ethernet interfaces. When the device is operating in standard mode, the interfaces on the LSWM116FC card are Ethernet interfaces and interfaces numbered 13 through 16 are unusable.
A 32-Gbps FC interface can be changed to two 10-GE Layer 2 Ethernet interfaces or two 16-Gbps FC interfaces in the view of the 32-Gbps FC interface. For example, you can change interface FC 1/1/2 to interfaces Ten-GigabitEthernet 1/1/1 and Ten-GigabitEthernet 1/1/2 or FC interfaces FC 1/1/1 and FC 1/1/2 in the view of FC 1/1/2.
You can change the two 16-Gbps breakout FC interfaces to two 10-GE Layer 2 Ethernet interfaces in the view of either breakout interface. For example, you can change breakout interfaces FC 1/1/1 and FC 1/1/2 to interfaces Ten-GigabitEthernet 1/1/1 and Ten-GigabitEthernet 1/1/2 in the view of FC 1/1/1 or FC 1/1/2.
You can also change the two 10-GE breakout Ethernet interface to one 32-Gbps FC interface in the view of either breakout interface. For example, you can change breakout interfaces Ten-GigabitEthernet 1/1/1 and Ten-GigabitEthernet 1/1/2 to FC interface FC 1/1/2 in the view of Ten-GigabitEthernet 1/1/1 or Ten-GigabitEthernet 1/1/2.
When the port type of an interface is changed, the original interface is deleted and a new interface is created.
To view the interface rate after changing, use the display interface command.
# Change Ten-GigabitEthernet 1/0/1 to FC 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port-type fc
[Sysname-Fc1/0/1]
# Change Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to FC interfaces. .
The interfaces Ten-GigabitEthernet1/0/1 and Ten-GigabitEthernet1/0/2 will be deleted. Continue? [Y/N]:y
[Sysname-Fc1/0/1]
Use reset counters interface fc to clear statistics for FC interfaces.
reset counters interface [ fc [ interface-number ] ]
fc [ interface-number ]: Specifies FC interfaces. If you do not specify the fc keyword, this command clears statistics for all interfaces. If you specify the fc keyword but not the interface-number argument, this command clears statistics for all FC interfaces.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
# Clear statistics for FC 1/0/1.
<Sysname> reset counters interface fc 1/0/1
Use shutdown to shut down an FC interface.
Use undo shutdown to bring up an FC interface.
shutdown
An FC interface is up.
FC interface view
# Shut down FC 1/0/1.
[Sysname-Fc1/0/1] shutdown
speed
Use speed to set the rate for an FC interface.
Use undo speed to restore the default.
speed { 1000 | 2000 | 4000 | 8000 | 16000 | 32000 | auto }
undo speed
The rate of an FC interface is autonegotiated.
FC interface view
1000: Specifies 1000 Mbps.
2000: Specifies 2000 Mbps.
4000: Specifies 4000 Mbps.
8000: Specifies 8000 Mbps.
16000: Specifies 16000 Mbps.
32000: Specifies 32000 Mbps.
auto: Configures the interface to negotiate its rate with the peer.
32-Gbps FC interfaces support the following speed settings:
·     8000 Mbps.
·     16000 Mbps.
·     32000 Mbps.
·     Autonegotiation.
16-Gbps FC interfaces support the following speed settings:
·     8000 Mbps.
·     16000 Mbps.
·     Autonegotiation.
8-Gbps FC interfaces support the following speed settings:
·     2000 Mbps.
·     4000 Mbps.
·     8000 Mbps.
·     Autonegotiation.
For an FC interface on an LSWM116FC card to operate at 16000 Mbps or 32000 Mbps, set the interface rate to 16000 Mbps or 32000 Mbps.
# Set the rate to 8000 Mbps for FC 1/0/1.
using
Use using to split a 32-Gbps FC interface into two 16-Gbps FC breakout interfaces or combine two 16-Gbps FC breakout interfaces back into a 32-Gbps FC interface.
using { sixteengigfc | thirty-twogigfc }
An FC interface is a 32-Gbps interface.
FC interface view
sixteengigfc: Splits a 32-Gbps FC interface into two 16-Gbps FC breakout interfaces.
thirty-twogigfc: Combines two 16-Gbps FC breakout interfaces split from a 32-Gbps FC interface into a 32-Gbps FC interface.
This command is supported only when an LSWM116FC card is installed in an S6800-2C or S6800-4C switch.
To improve port density, reduce costs, and improve network flexibility, you can split a 32-Gbps FC interface into two 16-Gbps breakout interfaces. The 16-Gbps breakout interfaces support the same configuration and attributes as common 16-Gbps FC interfaces.
To get higher bandwidth on a single interface, you can combine two 16-Gbps FC breakout interfaces back into a 32-Gbps FC interface in the view of either 16-Gbps FC breakout interface. The 32-Gbps FC interface supports the same configuration and attributes as common 32-Gbps FC interfaces.
You can use the display this command in FC interface view to identify 32-Gbps FC interfaces and 16-Gbps FC breakout interfaces. If the using thirty-twogigfc attribute appears, the interface is a 32-Gbps FC interface. If the using sixteengigfc attribute appears, the interface is a 16-Gbps FC breakout interface.
# Split 32-Gbps FC interface FC 1/0/2 into two 16-Gbps FC breakout interfaces.
<System> system-view
[System] interface fc 1/0/2
[System-Fc1/0/2] using sixteengigfc
The interface 32G FC1/0/2 will be deleted. Continue? [Y/N]:y
# Combine two 16-Gbps FC breakout interfaces FC 1/0/1 and FC 1/0/2 back into a 32-Gbps FC interface.
[System] interface fc 1/0/1
[System-Fc1/0/1] using thirty-twogigfc
The interfaces 16G FC1/0/1 and 16G FC1/0/2 will be deleted. Continue? [Y/N]:y
Use bandwidth to set the expected bandwidth for a VFC interface.
undo bandwidth
The expected bandwidth (in kbps) of a VFC interface is the interface baud rate divided by 1000.
VFC interface view
The expected bandwidth determines the cost of the interface, which is used for route calculation.
The default baud rate of a VFC interface is 10 Gbps.
# Set the expected bandwidth to 50 kbps for VFC 1.
[Sysname] interface vfc 1
[Sysname-Vfc1] bandwidth 50
bind interface
Use bind interface to bind a VFC interface to an interface.
Use undo bind interface to restore the default.
bind interface interface-type interface-number [ mac mac-address ]
undo bind interface
A VFC interface is not bound to an interface.
VFC interface view
interface-type interface-number: Specifies an interface by its type and number. The interface type can be Layer 2 Ethernet interface, Layer 2 aggregate interface, S-channel interface, or S-channel aggregate interface.
mac mac-address: Specifies the peer FCoE MAC address, six bytes in the format of XXXX-XXXX-XXXX.
To make a VFC interface work, bind it to an interface. The VFC interface then sends and receives packets through the interface.
To use one physical link to carry multiple VFC interfaces, you must bind these VFC interfaces to different peer FCoE MAC addresses. However, you can bind them to the same interface. The FCoE MAC address identifies the device that communicates with a VFC interface. For a point-to-multipoint network, the FCoE MAC address is required. For a point-to-point network, the FCoE MAC address is optional.
You can use the display fcoe command to display the FCoE MAC address of a switch. You can display the FCoE MAC address of an ENode through some software or the NMS.
A VFC interface can be bound to only one interface and one FCoE MAC address.
An interface can be bound to multiple VFC interfaces, but an FCoE MAC address can be bound to only one VFC interface.
To successfully bind a VFC interface to a Layer 2 Ethernet interface, make sure the Layer 2 Ethernet interface is FCoE capable.
When you bind a VFC interface to a Layer 2 aggregate interface, follow these restrictions and guidelines:
·     To successfully bind a VFC interface to a Layer 2 aggregate interface, make sure all member ports of the Layer 2 aggregate interface are FCoE capable. Also, make sure new member ports of the Layer 2 aggregate interface are FCoE capable. Otherwise, FCoE traffic might be blocked.
·     The binding to a Layer 2 aggregate interface does not take effect when you perform the following tasks:
¡     Bind one VFC interface to the Layer 2 aggregate interface.
¡     Bind another VFC interface to a member port of the Layer 2 aggregate interface.
Enabling EVB on a Layer 2 Ethernet interface or Layer 2 aggregate interface disables the interface from forwarding FCoE traffic. To enable such an interface to forward FCoE traffic, you must create an S-channel interface or S-channel aggregate interface and bind a VFC interface to the created interface. When you bind a VFC interface to an S-channel interface or S-channel aggregate interface, follow these restrictions and guidelines:
·     To successfully bind a VFC interface to an S-channel interface or S-channel aggregate interface, make sure the switch is operating in expert mode. For information about system operating modes, see Fundamentals Configuration Guide. For information about S-channel interfaces and S-channel aggregate interfaces, see EVB Configuration Guide.
·     To successfully bind a VFC interface to an S-channel interface, make sure the Layer 2 Ethernet interface associated with the S-channel interface has FCoE over S-channel capabilities.
·     To successfully bind a VFC interface to an S-channel aggregate interface, make sure all member ports of the Layer 2 Ethernet aggregate interface associated with the S-channel aggregate interface have FCoE over S-channel capabilities. Also, make sure new member ports of the Layer 2 Ethernet aggregate interface have FCoE over S-channel capabilities. Otherwise, FCoE traffic might be blocked. For FCoE-capable cards and cards that have FCoE over S-channel capabilities, see the product manual.
·     The binding to an S-channel aggregate interface does not take effect when you perform the following tasks:
¡     Bind one VFC interface to the S-channel aggregate interface.
¡     Bind another VFC interface to a member port of the Layer 2 aggregate interface associated with the S-channel aggregate interface.
·     FCoE over S-channel can be used only between an EVB-capable switch and a server.
# Bind VFC 1 to Ten-GigabitEthernet 1/0/1 and FCoE MAC address 000c-2999-eacd.
[Sysname-Vfc1] bind interface ten-gigabitethernet 1/0/1 mac 000c-2999-eacd
# Bind VFC 2 to Bridge-aggregation 1 and FCoE MAC address 000c-2888-eacd.
[Sysname] interface vfc 2
[Sysname-Vfc2] bind interface bridge-aggregation 1 mac 000c-2888-eacd
# Bind VFC 3 to S-Channel 1/0/1:10 and FCoE MAC address 000c-2777-eacd.
[Sysname]interface vfc 3
[Sysname-Vfc3] bind interface s-channel 1/0/1:10 mac 000c-2777-eacd
# Bind VFC 4 to Schannel-Aggregation 1:10 and FCoE MAC address 000c-2666-eacd.
[Sysname]interface vfc 4
[Sysname-Vfc4] bind interface schannel-aggregation 1:10 mac 000c-2666-eacd
display fcoe
Use default to restore the default settings for a VFC interface.
default
VFC interface view
CAUTION
CAUTION:
# Restore the default settings for VFC 1.
[Sysname-Vfc1] default
The description of a VFC interface is interface name Interface, for example, Vfc 1 Interface.
VFC interface view
# Configure the description of VFC 1 as VFCport1.
[Sysname-Vfc1] description VFCport1
Use display interface vfc to display VFC interface information.
display interface [ vfc [ interface-number ] ] [ brief [ description | down ] ]
vfc [ interface-number ]: Specifies VFC interfaces. If you do not specify the vfc keyword, this command displays information about all interfaces supported by the device. If you specify the vfc keyword but not the interface-number argument, this command displays information about all VFC interfaces.
# Display detailed information about VFC 1.
<Sysname> display interface vfc 1
Vfc1
Current state: UP
Description: Vfc1 Interface
Bandwidth: 10000000kbps
Port WWN is 66:66:66:63:66:64:61:30
VSAN tagging mode is Tagging
EVFP common VSAN: 1
Bound interface is Ten-GigabitEthernet1/0/1, Bound MAC is 000c-2933-eacd
VSAN of physical-UP state: 1
Table 5 Command output
Current state
Line protocol state
Bandwidth
FC mode
state
Indicates the interface supports the VSAN protocol.
VSAN tagging mode
Link type of the interface: Trunk (Tagging) or Access (Non tagging).
VFC interfaces support only Tagging.
EVFP common VSAN
Indicates that the common VSANs are in up state through the EVFP negotiation.
Bound interface
Physical interface bound to the interface.
Bound MAC
FCoE MAC address bound to the interface.
List of VSANs that are physically up.
Time when the interface statistics were last cleared by using the reset counters interface vfc command. Never indicates that the interface statistics have never been cleared since device startup.
# Display brief information about VFC 1.
<Sysname> display interface vfc 1 brief
Brief information on VFC interface(s):
Admin Mode: E - e port; F - f port; NP - n port proxy
Oper Mode: TE - trunking e port; TF - trunking f port;
Interface  Admin Admin Oper Status Bind
           Mode  Trunk Mode        Interface
                 Mode
Vfc1       F     on    TF   UP     XGE1/0/1 000c-2933-eacd
Table 6 Command output
Admin Mode
·     E.
·     F.
·     NP.
Admin Trunk Mode
User-configured trunk mode for the interface: on.
Oper Mode
Status
·     UP.
·     DOWN.
Bind Interface
Ethernet interface and FCoE MAC address bound to the interface.
This field is empty when the interface does not have bound Ethernet interface or FCoE MAC address.
# Display the descriptions of VFC interfaces.
<sysname> display interface vfc brief description
Vfc1         Vfc1 Interface
Vfc2         Vfc2 Interface
# Display brief information about the VFC interfaces in physically down state.
<Sysname> display interface vfc brief down
Vfc1                 ADM  Administratively
Table 7 Command output
Interface name.
Link
Cause
Use fc mode to set the mode of a VFC interface.
fc mode { e | f | np }
undo fc mode
The mode of a VFC interface is F.
VFC interface view
VFC interfaces on an FCF switch support only E and F modes. VFC interfaces on an NPV switch support only F and NP modes. VFC interfaces on an FCF-NPV switch support E, F, and NP modes.
On an FCF-NPV switch, if the mode of a VFC interface does not match the mode of a VSAN of the interface, the mode does not take effect in the VSAN.
# Set the mode to F for VFC 1.
[Sysname-Vfc1] fc mode f
working-mode
interface vfc
Use interface vfc to create a VFC interface and enter its view, or enter the view of an existing VFC interface.
Use undo interface vfc to delete a VFC interface.
interface vfc interface-number
undo interface vfc interface-number
No VFC interfaces exist.
interface-number: Specifies a VFC interface number. The value range for this argument is 1 to 1024.
A VFC interface is a logical interface manually created on the FCF switch to simulate the function of a physical FC interface.
# Create VFC 1 and enter its view.
[Sysname-Vfc1]
Use reset counters interface vfc to clear statistics for VFC interfaces.
reset counters interface [ vfc [ interface-number ] ]
vfc [ interface-number ]: Specifies VFC interfaces. If you do not specify the vfc keyword, this command clears statistics for all interfaces. If you specify the vfc keyword but not the interface-number argument, this command clears statistics for all VFC interfaces.
# Clear statistics for VFC 1.
<Sysname> reset counters interface vfc 1
Use shutdown to shut down a VFC interface.
Use undo shutdown to bring up a VFC interface.
shutdown
A VFC interface is up.
VFC interface view
# Shut down VFC 1.
[Sysname-Vfc1] shutdown
Use bandwidth to set the expected bandwidth for an FC aggregate interface.
undo bandwidth
The expected bandwidth (in kbps) of an FC aggregate interface is the interface baud rate divided by 1000.
The baud rate of an FC aggregate interface is the sum of the speed of each Selected member interface in the FC aggregation group.
The expected bandwidth of an FC aggregate interface affects the link costs in FSPF. You can control the route selection by setting the expected bandwidth.
# Set the expected bandwidth to 1000 kbps for FC aggregate interface 1.
[Sysname] interface san-aggregation 1
[Sysname-SAN-Aggregation1] bandwidth 1000
Use default to restore the default settings for an FC aggregate interface.
default
CAUTION
CAUTION:
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for FC aggregate interface 1.
[Sysname-SAN-Aggregation1] default
The description of an FC aggregate interface is interface name Interface, for example, SAN-Aggregation1 Interface.
# Configure the description of FC aggregate interface 1 as SAGG-interface.
[Sysname-SAN-Aggregation1] description SAGG-interface
Use display interface san-aggregation to display FC aggregate interface information.
display interface [ san-aggregation [ interface-number ] ] [ brief [ description | down ] ]
san-aggregation [ interface-number ]: Specifies FC aggregate interfaces. If you do not specify the san-aggregation keyword, this command displays information about all interfaces supported by the device. If you specify the san-aggregation keyword but not the interface-number argument, this command displays information about all FC aggregate interfaces.
# Display detailed information about FC aggregate interface 1.
<Sysname> display interface san-aggregation 1
SAN-Aggregation1
Current state: UP
Description: SAN-Aggregation1 Interface
Bandwidth: 1000kbps
Port WWN is 24:01:70:ba:ef:6c:e0:15
EVFP common VSAN: 100
Table 8 Command output
Current state
Line protocol state
Bandwidth
Expected bandwidth of the interface. This field is not displayed when its value is 0.
FC mode
state
Operating state of the interface through negotiation.
VSAN tagging mode
EVFP common VSAN
Time when the interface statistics were last cleared by using the reset counters interface san-aggregation command. Never indicates that the interface statistics have never been cleared since device startup.
# Display brief information about FC aggregate interface 1.
<Sysname> display interface san-aggregation 1 brief
Brief information on SAN-Aggregation interface(s):
                      Mode
SAGG1      37   F     auto  F    4G     UP
Table 9 Command output
VSAN
Admin Mode
·     auto.
·     E.
·     F.
·     NP.
Admin Trunk Mode
·     auto.
·     on.
·     off.
Oper Mode
Oper Speed
Status
·     UP.
·     DOWN.
# Display the descriptions of FC aggregate interfaces.
<sysname> display interface san-aggregation brief description
SAGG1        SAGG1 Interface
SAGG2        SAGG2 Interface
# Display brief information about the FC aggregate interfaces in physically down state.
<Sysname> display interface san-aggregation brief down
SAGG1                ADM  Administratively
Table 10 Command output
Brief information about Layer 2 FC aggregate interfaces.
Interface name.
Link
Cause
Use display san-aggregation to display information about FC aggregation groups corresponding to existing FC aggregate interfaces.
display san-aggregation [ verbose ] [ interface san-aggregation interface-number ]
verbose: Displays detailed information about FC aggregation groups. If you do not specify this keyword, the command displays brief information about FC aggregation groups.
interface san-aggregation interface-number: Specifies an FC aggregate interface by its number. The value range for the interface-number argument is 1 to 1024. If you do not specify an FC aggregate interface, this command displays information about all FC aggregation groups corresponding to existing FC aggregate interfaces.
# Display brief information about all FC aggregation groups corresponding to existing FC aggregate interfaces.
<Sysname> display san-aggregation
* indicates the member port is selected.
Interface        State   Mode   Speed     Member port
SAGG1            UP      F      8Gbps    *Fc1/0/1
                                          Fc1/0/2
SAGG2            DOWN    -      -         -
Table 11 Command output
Match criteria
Abbreviated FC aggregate interface name.
Physical state of the FC aggregate interface:
·     DOWN—The physical state of the interface is down and the FC aggregate interface contains no Selected member interface.
·     UP—The physical state of the interface is up and the FC aggregate interface contains Selected member interfaces.
Mode
Operating mode of the FC aggregate interface:
·     E—E mode.
·     F—F mode.
·     NP—NP mode.
When the physical state of the FC aggregate interface is down, a hyphen (-) is displayed for this field.
Speed
Speed of the FC aggregate interface.
It is the sum of the speed of each Selected member interface. When the physical state of the FC aggregate interface is down, a hyphen (-) is displayed for this field.
Member port
Member interfaces of the FC aggregation group corresponding to the FC aggregate interface. A member interface marked with an asterisk (*) is a Selected member interface.
When the FC aggregation group does not contain any member interfaces, a hyphen (-) is displayed for this field.
# Display detailed information about all FC aggregation groups corresponding to existing FC aggregate interfaces.
<Sysname> display san-aggregation verbose
Interface SAN-Aggregation1:
State                : UP
Mode                 : F
Speed                : 8Gbps
Member port number   : 2
Selected port number : 1
  Member port        State   Mode   Speed   Selected
  Fc1/0/1            UP      F      8Gbps   Y
  Fc1/0/2            UP      F      4Gbps   N
Interface SAN-Aggregation2:
State                : DOWN
Mode                 : N/A
Speed                : N/A
Selected port number : 0
  Fc1/0/3             DOWN    -      -       N
  Fc1/0/4             DOWN    -      -       N
Table 12 Command output
Match criteria
Mode
·     E—E mode.
·     F—F mode.
·     NP—NP mode.
When the physical state of the FC aggregate interface is down, N/A is displayed for this field.
Speed
It is the sum of the speed of each Selected member interface. When the physical state of the FC aggregate interface is down, N/A is displayed for this field.
Member port number
Number of member interfaces in the FC aggregation group corresponding to the FC aggregate interface.
Number of Selected member interfaces in the FC aggregation group corresponding to the FC aggregate interface.
Member port
When the FC aggregation group does not contain any member interfaces, this field is empty.
Link layer state of the FC aggregate interface:
·     DOWN—The link layer protocol of the interface is down.
·     UP—The link layer protocol of the interface is up.
Mode
Operating mode of the member interface:
·     E—E mode.
·     F—F mode.
·     NP—NP mode.
When the member interface is down at the link layer, a hyphen (-) is displayed for this field.
Speed
Speed of the member interface.
Selected
Selected state of the member interface:
·     N—Unselected.
·     Y—Selected.
Use fc mode to set the mode of an FC aggregate interface.
undo fc mode
On an FCF switch, the mode of an FC aggregate interface is auto.
On an NPV or FCF-NPV switch, the mode of an FC aggregate interface is F.
auto: Specifies the auto mode, so that the FC aggregate interface can operate in F mode or E mode through dynamic negotiation.
FC aggregate interfaces on an FCF switch support only auto, E, and F modes. FC aggregate interfaces on an NPV switch support only F and NP modes. FC aggregate interfaces on an FCF-NPV switch support only E, F, and NP modes.
On an FCF-NPV switch, if the mode of an FC aggregate interface does not match the mode of a VSAN of the interface, the mode does not take effect in the VSAN.
# Set the mode to F for FC aggregate interface 1.
[Sysname-SAN-Aggregation1] fc mode f
working-mode
Use interface san-aggregation to create an FC aggregate interface and enter its view, or enter the view of an existing FC aggregate interface.
undo interface san-aggregation interface-number
No FC aggregate interfaces exist.
interface-number: Specifies the number of the FC aggregate interface. The value range for this argument is 1 to 1024.
# Create FC aggregate interface 1 and enter its view.
Use reset counters interface san-aggregation to clear statistics for FC aggregate interfaces.
reset counters interface [ san-aggregation [ interface-number ] ]
san-aggregation [ interface-number ]: Specifies FC aggregate interfaces. If you do not specify the san-aggregation keyword, this command clears statistics for all interfaces. If you specify the san-aggregation keyword but not the interface-number argument, this command clears statistics for all FC aggregate interfaces.
# Clear statistics for FC aggregate interface 1.
<Sysname> reset counters interface san-aggregation 1
Use san-aggregation group to assign an FC interface to an FC aggregation group.
Use undo san-aggregation group to remove an FC interface from an FC aggregation group.
san-aggregation group group-id
An FC interface is not assigned to any FC aggregation group.
FC interface view
group-id: Specifies an FC aggregation group by its group number. An FC aggregation group uniquely corresponds to an FC aggregate interface, and they are numbered the same. The value range for this argument is 1 to 1024.
An FC interface can be assigned to only one FC aggregation group.
After an FC interface is assigned to an FC aggregation group, its operating mode, trunk mode, trunk VSAN, and access VSAN settings are cleared. Also, you cannot configure these settings for a member port. After the FC interface is removed from the FC aggregation group, these settings are not restored, and the default settings are used.
The maximum number of member interfaces that an FC aggregation group supports is 8.
# Assign FC 1/0/1 to FC aggregation group 1.
[Sysname-Fc1/0/1] san-aggregation group 1
The FC mode, trunk mode, trunk VSAN, and access VSAN settings of the FC interface will be lost. Continue? [Y/N]:y
Use san-aggregation load-sharing mode local-first to enable local-first load sharing.
Use undo san-aggregation load-sharing mode local-first to disable local-first load sharing.
Local-first load sharing is enabled.
Local-first load sharing takes effect immediately after it is enabled, and it might cause traffic loss.
Local-first load sharing reduces the influence of traffic on the links between IRF physical interfaces. For example, in an IRF fabric, an IRF member device forwards traffic out of an FC aggregate interface with member interfaces distributed on multiple IRF member devices. The system processes the traffic as follows based on the settings on the IRF member device.
·     When local-first load sharing is enabled on the IRF member device, the following rules apply:
¡     If the IRF member device has Selected member interfaces, traffic is load shared among the Selected interfaces of the IRF member device.
¡     If the IRF member device does not have any Selected member interfaces, traffic is load shared among all Selected member interfaces on all IRF member devices.
·     When local-first load sharing is disabled on the IRF member device, the traffic is load shared among all Selected member interfaces on all IRF member devices.
For more information about IRF, see Virtual Technologies Configuration Guide.
# Enable local-first load sharing.
[Sysname] san-aggregation load-sharing mode local-first
Use shutdown to shut down an FC aggregate interface.
Use undo shutdown to bring up an FC aggregate interface.
shutdown
An FC aggregate interface is up.
# Shut down FC aggregate interface 1.
[Sysname-SAN-Aggregation1] shutdown
FCoE commands
display fcoe
Use display fcoe to display global FCoE settings.
display fcoe
Only FCF and NPV switches support this command.
# Display global FCoE settings.
Global FCoE information:
  FCoE MAC    : 0000-1234-0202
  FC-MAP      : 0x0efc25
  FCF Priority: 128
  FKA period  : 8 seconds
Table 13 Command output
FCoE MAC
FCoE MAC address of the switch.
FC-MAP
FC-MAP value.
FCF Priority
System FCF priority.
FKA period
Interval at which a VFC interface sends Discovery Solicitations and unsolicited Discovery Advertisements.
fcoe fcmap
fcoe fka-adv-period
display fcoe vlan
Use display fcoe vlan to display the FCoE settings of a VLAN.
display fcoe vlan vlan-id
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
Only FCF-NPV switches support this command.
# Display the FCoE settings of VLAN 10.
<Sysname> display fcoe vlan 10
FCoE information of VLAN 10:
  FCoE MAC    : 0000-2345-0202
  FC-MAP      : 0x0efc01
  FCF Priority: 128
Table 14 Command output
FCoE MAC
FC-MAP
FC-MAP value.
FCF Priority
FKA period
fcoe fcmap
fcoe fka-adv-period
fcoe enable
Use fcoe enable to enable FC and FCoE in a VLAN and map the VLAN to a VSAN.
Use undo fcoe enable to disable FC and FCoE in a VLAN.
fcoe enable [ vsan vsan-id ]
undo fcoe enable
FC and FCoE is disabled in a VLAN.
VLAN view
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command maps the VLAN to a VSAN with the same ID as the VLAN. For VLANs 3840 to 4094, you must specify VSANs to be mapped. Otherwise, an error message appears.
Only FCF, FCF-NPV, and NPV switches support this command.
FC and FCoE cannot be enabled in VLAN 1.
VSANs are mapped to VLANs on a one-to-one basis.
After FC and FCoE is enabled in a VLAN, the following rules apply:
·     The VLAN allows only FCoE traffic.
·     All member ports in the VLAN are isolated and will not form loops. For this reason, you do not need to enable STP or other loop detection protocols in the VLAN. Otherwise, FCoE links might be blocked.
·     A Layer 2 protocol enabled in the VLAN runs only on Ethernet interfaces in the VLAN that are not bound to VFC interfaces.
When you use an FC interface to transmit packets, you must map used VSANs to VLANs and enable FC and FCoE for the VLANs. The VSAN used on the two ends can be mapped to the same VLAN or different VLANs.
When you use a VFC interface to transmit packets, the interface bound to the VFC interface might allow multiple VLANs. You must enable FC and FCoE for each of these VLANs and map each VLAN to a different VSAN. Then, the packets from a VSAN are tagged with the mapped VLAN tag and transmitted within the mapped VLAN.
# Enable FC and FCoE in VLAN 4 and map VLAN 4 to VSAN 6.
[Sysname] vlan 4
[Sysname-vlan4] fcoe enable vsan 6
fcoe fcf-priority
Use fcoe fcf-priority to set the FCF priority for a VFC interface.
Use undo fcoe fcf-priority to restore the default.
fcoe fcf-priority priority
The FCF priority of a VFC interface is 128.
VFC interface view
priority: Specifies the FCF priority in the range of 0 to 255. The smaller the value, the higher the priority.
This command takes effect only on VFC interfaces operating in F mode. You can configure this command on VFC interfaces operating in E or NP mode, but it does not take effect.
The VFC interface FCF priority is used in the fcf priority field in a solicited Discovery Advertisement.
An ENode selects the FCF switch with the highest priority from the FCF switches sending Discovery Advertisements and sends a FLOGI request to it for login.
# Set the FCF priority to 12 for VFC 1.
[Sysname-Vfc1] fcoe fcf-priority 12
fcoe fcmap
Use fcoe fcmap to set an FC-MAP value.
Use undo fcoe fcmap to restore the default.
fcoe fcmap fc-map
undo fcoe fcmap
The FC-MAP value is 0x0efc00.
VLAN view
fc-map: Specifies a hexadecimal FC-MAP value in the range of 0efc00 to 0efcff.
Only FCF, FCF-NPV, and NPV switches support this command. On FCF or NPV switches, you can set an FC-MAP value only in system view. On FCF-NPV switches, you can set an FC-MAP value only in VLAN view.
An FC-MAP value identifies an FCoE network. Switches in the same FCoE network must have the same FC-MAP value.
After an FC-MAP value is set, VFC interfaces perform a FIP renegotiation.
# Set the FC-MAP value to 0x0efcff on an FCF or NPV switch.
[Sysname] fcoe fcmap 0efcff
Changing the FC-MAP will flap all VFC interfaces. Continue? [Y/N]:y
# Set the FC-MAP value to 0x0efcff in VLAN 2 on an FCF-NPV switch.
[Sysname] vlan 2
[Sysname-vlan2] fcoe fcmap 0efcff
Changing the FC-MAP will flap all VFC interfaces in current VLAN. Continue? [Y/N]:y
fcoe fka-adv-period
Use fcoe fka-adv-period to set an FKA advertisement interval.
Use undo fcoe fka-adv-period to restore the default.
fcoe fka-adv-period fka-adv-period
The FKA advertisement interval is 8 seconds.
VLAN view
fka-adv-period: Specifies an FKA advertisement interval in the range of 4 to 600 seconds.
Only FCF, FCF-NPV, and NPV switches support this command. On FCF or NPV switches, you can set an FKA advertisement interval value only in system view. On FCF-NPV switches, you can set an FKA advertisement interval value only in VLAN view.
When setting the FKA advertisement interval on an FCF or NPV switch, use Table 15 as a reference to avoid service disruption.
Table 15 Recommended values for different application scenarios
Recommended value
Application scenarios
Remarks
Less than 90 seconds
Connected to servers, storage devices, or third-party switches.
According to FC-BB-5, the upper limit of the FKA advertisement interval is 90 seconds. In this scenario, a single-MPU FCF switch or NPV switch will experience FCoE traffic disruption during an ISSU reboot for the following reasons:
·     The ISSU reboot takes more than 225 (2.5*90) seconds.
·     The peer deletes the virtual link for failing to receive unsolicited Discovery Advertisements within 225 seconds.
You must adjust the FKA advertisement interval on the upstream FCF switch to ensure service continuity in either of the following situations:
·     An active/standby switchover on a dual-MPU NPV switch.
·     An ISSU reboot on a dual-MPU NPV switch.
The preceding steps are required for the following reasons:
·     The FKA advertisement interval configured on the NPV switch affects only its VFC interfaces in F mode and connected ENodes.
·     The VFC interfaces in NP mode of the NPV switch use the FKA advertisement interval learned from the upstream FCF switch.
60–90 seconds
Active/standby switchover on a dual-MPU switch takes more than 2.5 x 60 seconds because of the amount of FCoE configuration.
ISSU reboot on a dual-MPU switch takes more than 2.5 x 60 seconds because of the amount of FCoE configuration.
For more information about ISSU, see Fundamentals Configuration Guide.
300–600 seconds
ISSU reboot on a single-MPU switch to which no nodes are attached.
During an ISSU reboot on a single-MPU switch, the switch cannot send unsolicited Discovery Advertisements or keepalive frames.
# Set the FKA advertisement interval to 20 seconds on an FCF or NPV switch.
[Sysname] fcoe fka-adv-period 20
# Set the FKA advertisement interval to 20 seconds in VLAN 2 on an FCF-NPV switch.
[Sysname] vlan 2
[Sysname-vlan2] fcoe fka-adv-period 20
fcoe global fcf-priority
Use fcoe global fcf-priority to set the system FCF priority.
Use undo fcoe global fcf-priority to restore the default.
fcoe global fcf-priority priority
The system FCF priority is 128.
VLAN view
priority: Specifies the system FCF priority in the range of 0 to 255. The smaller the value, the higher the priority.
This command takes effect on all VFC interfaces operating in F mode.
Only FCF, FCF-NPV, and NPV switches support this command. On FCF or NPV switches, you can set the system FCF priority only in system view. On FCF-NPV switches, you can set the system FCF priority only in VLAN view.
The system FCF priority is used in the fcf priority field in an unsolicited Discovery Advertisement.
# Set the system FCF priority to 12 on an FCF or NPV switch.
[Sysname] fcoe global fcf-priority 12
# Set the system FCF priority to 12 in VLAN 2 on an FCF-NPV switch.
[Sysname] vlan 2
[Sysname-vlan2] fcoe global fcf-priority 12
VSAN commands
display vsan port-member
Use display vsan port-member to display the member interfaces of a VSAN.
display vsan [ vsan-id ] port-member
vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the member interfaces of each VSAN.
# Display the member interfaces of each VSAN.
<Sysname> display vsan port-member
VSAN 1:
  Access Ports:
    Fc1/0/1              Fc1/0/2
  Trunk Ports:
    Vfc1                 Vfc2              Vfc3
VSAN 2:
  Access Ports:
  Trunk Ports:
    Vfc1
VSAN 10:
  Access Ports:
  Trunk Ports:
VSAN 100:
  Access Ports:
  Trunk Ports:
    Vfc1                 Vfc2              Vfc3
display vsan status
Use display vsan status to display the operating modes of VSANs.
display vsan [ vsan-id ] status
vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the operating mode of each VSAN.
# Display the operating mode of each VSAN.
<Sysname> display vsan status
VSAN 1:
  Working mode: FCF
VSAN 10:
  Working mode: NPV
vsan
working-mode
port
Use port to assign a list of interfaces to a VSAN as access ports in batch.
Use undo port to remove a list of access ports from a VSAN in batch.
port interface-list
undo port interface-list
An interface belongs to VSAN 1 as an access port.
VSAN view
interface-list: Specifies a space-separated list of up to 10 interface items. Each item specifies an interface or a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for interface-number2 must be greater than or equal to the value for interface-number1. The interface type can be FC interface or FC aggregate interface.
To assign a single interface to a VSAN, use the port access vsan command. If you assign one interface to different VSANs by using the port command and the port access vsan command, the new configuration for the interface overwrites the previous configuration.
# Assign FC 1/0/1 through FC 1/0/5 to VSAN 10 as access ports in batch.
[Sysname] vsan 10
[Sysname-vsan10] port fc 1/0/1 to fc 1/0/5
port access vsan
port access vsan
Use port access vsan to assign an interface to a VSAN as an access port.
Use undo port access vsan to restore the default.
port access vsan vsan-id
FC interface view
FC aggregate interface view
vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. Make sure the VSAN already exists on the device. Otherwise, this command fails.
To assign multiple interfaces to a VSAN as access ports in batch, use the port command. If you assign one interface to different VSANs by using the port command and the port access vsan command, the new configuration for the interface overwrites the previous configuration.
# Create VSAN 10, and assign FC 1/0/1 to VSAN 10 as an access port.
[Sysname] vsan 10
[Sysname-vsan10] quit
[Sysname] interface fc 1/0/1
[Sysname-Fc1/0/1] port access vsan 10
port
port trunk mode
Use port trunk mode to set the trunk mode for an interface.
Use undo port trunk mode to restore the default.
port trunk mode { auto | off | on }
The trunk mode is auto for interfaces on an FCF switch. The trunk mode is off for interfaces on an NPV switch or FCF-NPV switch.
FC interface view
auto: Specifies the auto mode.
off: Specifies the off mode.
on: Specifies the on mode.
The two interfaces of a link use the EVFP protocol to negotiate whether to support VSAN tagging according to their trunk modes.
An FCF switch supports three trunk modes: auto (default), off, and on. An NPV switch or FCF-NPV switch supports two trunk modes: off (default) and on.
If the switch connects to a node through an FC interface or FC aggregate interface, as a best practice, assign the interface to a VSAN as an access port. If you assign the interface to a VSAN as a trunk port, node login might be affected.
# Set the trunk mode to on for FC 1/0/1.
[Sysname-Fc1/0/1] port trunk mode on
port trunk vsan
Use port trunk vsan to assign an interface to the specified VSANs as a trunk port.
Use undo port trunk vsan to remove an interface from the specified VSANs.
port trunk vsan vsan-id-list
undo port trunk vsan vsan-id-list
An interface is not assigned to any VSANs as a trunk port.
FC interface view
VFC interface view
vsan-id-list: Specifies a space-separated list of up to 10 VSAN items. Each item specifies a VSAN ID or a range of VSAN IDs in the format of vsan-id1 to vsan-id2. The value range for the vsan-id argument is 1 to 3839. The value for vsan-id2 must be greater than or equal to the value for vsan-id1.
As a best practice, do not include both FCF-mode VSANs and NPV-mode VSANs on an FCF-NPV switch in a VSAN list. If you do so, the following events occur during trunk mode negotiation:
·     An E_Port selects only FCF-mode VSANs.
·     An NP_Port selects only NPV-mode VSANs.
An FC interface or FC aggregate interface exchanges messages with the peer interface in the access VSAN to perform VSAN mode negotiation. Therefore, you must map the access VSAN to a VLAN in addition to configuring the trunk VSAN. By default, the access VSAN of an FC interface or FC aggregate interface is VSAN 1.
# Assign FC 1/0/1 to VSANs 1, 2, 10, and 20 through 100.
[Sysname-Fc1/0/1] port trunk vsan 1 to 2 10 20 to 100
# Assign VFC 1 to VSANs 1, 2, 10, and 20 through 100.
[Sysname-Vfc1] port trunk vsan 1 to 2 10 20 to 100
working-mode
vsan
Use vsan to create a VSAN and enter its view, or enter the view of an existing VSAN.
Use undo vsan to restore the name of a VSAN to the default or delete a VSAN.
vsan vsan-id [ name vsan-name ]
undo vsan vsan-id [ name ]
Only the default VSAN (VSAN 1) exists, and the name of VSAN 1 is VSAN0001.
vsan vsan-id: Specifies a VSAN ID in the range of 1 to 3839.
name vsan-name: Specifies a name for the VSAN, a case-sensitive string of 1 to 32 characters. The name must start with a letter and can contain letters, numbers, and special symbols in Table 16.
Table 16 Special symbols
Name
Symbol
Caret
Dollar sign
Minus sign
Underscore
_
If you do not specify a VSAN name, the default VSAN name is VSAN plus a four-digit VSAN ID. For example, the default name of VSAN 10 is VSAN0010.
You cannot delete the default VSAN (VSAN 1).
You can create a maximum of 32 VSANs (including VSAN 1).
If you specify the name keyword, the undo vsan command restores the VSAN name to its default. If you do not specify the name keyword, the undo vsan command deletes the VSAN.
# Create VSAN 10 and enter its view.
[Sysname] vsan 10
[Sysname-vsan10]
# Change the name of VSAN 10 from its default to FCF-VSAN.
[Sysname] vsan 10 name FCF-VSAN
[Sysname-vsan10]
# Create VSAN 11 with a name of FCF-VSAN, and enter the view of VSAN 11.
[Sysname] vsan 11 name FCF-VSAN
[Sysname-vsan11]
# Restore the name of VSAN 11 to its default.
[Sysname] undo vsan 11 name
# Delete VSAN 11.
display vsan status
working-mode
Use working-mode to set the operating mode for a VSAN.
Use undo working-mode to restore the default.
working-mode { fcf | npv }
undo working-mode
The operating mode of a VSAN is NPV.
VSAN view
fcf: Specifies the FCF mode.
npv: Specifies the NPV mode
A VSAN operating in FCF mode acts as an FCF switch. A VSAN operating in NPV mode acts as an NPV switch.
The access VSAN and trunk VSANs of an FC interface or FC aggregate interface must be configured with the same operating mode.
# Set the operating mode to FCF for VSAN 10.
[Sysname] vsan 10
[Sysname-vsan10] working-mode fcf
display vsan status
fc mode
Fabric building commands
allowed-domain-id
Use allowed-domain-id to configure an allowed domain ID list for a VSAN.
Use undo allowed-domain-id to delete an allowed domain ID list of a VSAN.
allowed-domain-id domain-id-list
undo allowed-domain-id domain-id-list
The allowed domain ID list for a VSAN includes domain IDs 1 to 239.
VSAN view
domain-id-list: Specifies a space-separated list of up to 8 domain items. Each item specifies a domain ID or a range of domain IDs in the format of domain-id1 to domain-id2. The value for domain-id2 must be greater than or equal to the value for domain-id1. The value range for the domain-id argument is 1 to 239.
Only FCF switches and VSANs operating in FCF mode support this command.
To successfully configure an allowed domain ID list on the principal switch, make sure all assigned and locally configured domain IDs are included in the list. After you configure an allowed domain ID list, the principal switch assigns only domain IDs available in the allowed list.
To successfully configure an allowed domain ID list on a non-principal switch, make sure the runtime domain ID of the switch is included in the allowed list. After you configure an allowed domain ID list on a non-principal switch, the following rules apply:
·     The locally configured domain ID must be included in the allowed list. Otherwise, the domain ID configuration fails.
·     The principal switch must assign a domain ID that is included in the allowed list of the non-principal switch. Otherwise, the non-principal switch refuses the assigned domain ID and isolates its interface connected to the principal switch.
As a best practice, configure the same allowed domain ID list on all switches in a VSAN.
# Configure VSAN 1 to allow domains 3 through 10.
[Sysname] vsan 1
[Sysname-vsan1] allowed-domain-id 3 to 10
display fc domain
Use display fc domain to display the domain information for VSANs.
display fc domain [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the domain information for all VSANs. On an FCF-NPV switch, this command displays the domain information for only VSANs operating in FCF mode.
Only FCF and FCF-NPV switches support this command.
The displayed domain information includes runtime and configuration information of the local switch and runtime information of the principal switch.
# Display the domain information for VSAN 1.
<Sysname> display fc domain vsan 1
Domain Information of VSAN 1:
    Running time information:
        State: Stable
        Switch WWN: 41:6e:64:69:61:6d:6f:21
        Fabric name: 41:6e:64:69:61:6d:6f:21
        Priority: 2
        Domain ID: 100
    Configuration information:
        Domain configure: Enabled
        Domain auto-reconfigure: Disabled
        Priority: 128
        Domain ID: 100 (static)
    Principal switch running time information:
        Priority: 2
    Path               Interface
    Downstream         Vfc1
    Downstream         Vfc2
    Downstream         Vfc4
Table 17 Command output
Running status:
·     Stable—The configuration is finished.
·     Unstable—The configuration is not finished.
Switch WWN
WWN of the local switch.
Fabric name
Name of the fabric.
Priority
Running priority of the local switch.
Domain ID
Runtime domain ID of the local switch.
Configuration of the local switch.
Domain configure
State of the fabric configuration feature:
·     Enabled.
·     Disabled.
State of the automatic reconfiguration feature:
·     Enabled.
·     Disabled.
Fabric name
Fabric name configured on the switch.
Priority
Locally configured priority of the switch.
Domain ID
Locally configured domain ID. The field in the parentheses can be one of the following:
·     static.
·     preferred.
Runtime information of the principal switch.
Priority
Running priority of the principal switch.
Path
Path type of the interface:
·     Upstream—Upstream principal link.
·     Downstream—Downstream principal link.
Local interface.
display fc domain-list
Use display fc domain-list to display the list of domain IDs dynamically assigned in VSANs.
display fc domain-list [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the lists of domain IDs dynamically assigned in all VSANs. On an FCF-NPV switch, this command displays the lists of domain IDs dynamically assigned in only VSANs operating in FCF mode.
For a dynamically built fabric, this command displays the list of domain IDs dynamically assigned in a VSAN and includes the following information:
·     The total number of domains.
·     Mappings between domain IDs and switch WWNs.
# Display the list of domain IDs dynamically assigned in VSAN 1.
<Sysname> display fc domain-list vsan 1
Domain list of VSAN 1:
  Number of domains: 3
  Domain ID    WWN
  0xc8(200)    20:01:00:05:30:00:47:df [Principal]
  0x63(99)     20:01:00:0d:ec:08:60:c1 [Local]
  0x61(97)     50:00:53:0f:ff:f0:10:06
Table 18 Command output
Domain list of VSAN
Domain ID list of the VSAN.
Number of domains
Total number of domains.
WWN
WWN of the switch. Principal indicates a principal switch, and Local indicates a local switch.
domain configure enable
display fc ess
Use display fc ess to display the Exchange Switch Support (ESS) negotiation result, including the following information:
·     The capabilities of the local switch after the ESS negotiation.
·     The capabilities of the remote switch after the ESS negotiation.
display fc ess [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the ESS negotiation results for all VSANs. On an FCF-NPV switch, this command displays the ESS negotiation results for only VSANs operating in FCF mode.
# Display the ESS negotiation result for VSAN 2.
<Sysname> display fc ess vsan 2
ESS info of VSAN 2:
  Domain: 57
    Directory Server Capability:
      Accept large name server objects: Yes
      Accept small name server objects: No
      Accept large + FC-4 Features name server objects: No
      Accept small + FC-4 Features name server objects: No
      Support receiving ACCept with 0 length: Yes
    Fabric Controller Capability:
     Support receiving the SW_RSCN Request: Yes
    Fabric Configuration Server Capability:
      Support basic configuration services: Yes
      Support platform configuration services: No
      Support topology discovery configuration services: Yes
      Support enhanced configuration services: Yes
    Enhanced Zone Server Capability:
      Support enhanced zoning management: Yes
  Domain: 224
Table 19 Command output
Domain
Domain ID of the switch.
List of directory server capabilities.
Indicates whether the switch supports accepting large name server objects.
A large name server object contains the symbolic name of the N_Port and the symbolic name of the node in addition to the information of a small name server object.
Indicates whether the switch supports accepting small name server objects.
A small name server object contains only the basic information, and does not contain the symbolic name of the N_Port, the symbolic name of the node, or information about supported FC-4 features.
Indicates whether the switch supports accepting large + FC-4-feature name server objects.
Indicates whether the switch supports accepting small + FC-4-feature name server objects.
Indicates whether the switch supports accepting an ACCEPT reply whose payload is 0.
List of fabric controller capabilities.
Indicates whether the switch supports accepting an SW_RSCN (Registered State Change Notification) request.
Indicates whether the switch supports enhanced zoning.
display fc login
Use display fc login to display the node login information for VSANs.
display fc login [ vsan vsan-id ] [ count ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the node login information for all VSANs. On an FCF-NPV switch, this command displays the node login information for only VSANs operating in FCF mode.
count: Displays the total number of logged-in nodes.
# Display the node login information for VSAN 1.
<Sysname> display fc login vsan 1
Interface VSAN FCID     Node WWN                Port WWN
Vfc1      1    0x010000 21:01:00:1b:32:a0:fa:18 21:01:00:1b:32:a0:fa:17
# Display the number of logged-in nodes for VSAN 1.
<Sysname> display fc login vsan 1 count
Total entries: 1
# Display the number of logged-in nodes for each VSAN and the total number of logged-in nodes.
<Sysname> display fc login count
VSAN        Entries
1           1
2           1
Total entries: 2
Table 20 Command output
Interface on the switch connected to the node.
FCID
FC address assigned by the switch to the node.
Port WWN
WWN of the port connecting the node to the switch.
Entries
Number of logged-in nodes for a VSAN.
Total Entries
Total number of logged-in nodes.
display fc name-service database
Use display fc name-service database to display the name service database information.
display fc name-service database [ vsan vsan-id [ fcid fcid ] ] [ verbose ]
display fc name-service database [ vsan vsan-id ] count
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the name service database information for all VSANs. On an FCF-NPV switch, this command displays the name service database information for only VSANs operating in FCF mode.
fcid fcid: Specifies an FC address in the range of 0x010000 to efffff (hexadecimal). If you do not specify an FC address, this command displays the name service entries of all FC addresses.
verbose: Displays detailed information about the name service database. If you do not specify this keyword, the command displays brief information about the name service database.
count: Displays the number of name service entries.
# Display brief information about the name service database for VSAN 1.
<Sysname> display fc name-service database vsan 1
VSAN 1:
  FCID     Type               PWWN(vendor)                      FC4-type:feature
  0x030001 0x01(N)            20:00:00:05:30:00:25:a3           SCSI-FCP
  0x030200 0x01(N)            20:00:00:49:c9:28:c7:01           NPV
  0x030300 0x01(N)            21:01:00:1b:32:a0:fa:00           NVMeoFC:Initiato
r/Target/Discovery
Table 21 Command output
FCID
FC address of the N_Port.
Port type registered by the node with the switch:
·     0x00(Unidentified)—No port type is registered.
·     0x01(N)—N_Port, which directly connects to the fabric.
·     0x02(NL)—NL_Port, which connects to the fabric through an arbitrated loop.
·     0x03(F/NL)—F_Port or NL_Port.
·     0x7f(Nx)—N_Port, NL_Port, or F_Port, or NL_Port.
·     0x81(F)—F_Port, which connects to an N_Port.
·     0x82(FL)—FL_Port, which connects to an NL_Port.
·     0x84(E)—E_Port, which connects to an E_Port or B_Port.
·     0x85(B)—B_Port. The ports on a bridge that connect two E_Ports are called B_Ports.
·     0xXX(Unknown)—Port types other than the preceding ones.
Typically, only N_Ports and NL_Ports will be registered by a node.
PWWN(vendor)
WWN of the N_Port (name of vendor).
FC4-type:feature
FC4 type feature entry (when this command displays brief information, up to two FC4 type feature entries are displayed):
·     FC4 type—Includes SCSI-FCP, LLC/SNAP, SW_ILS, SNMP, GS3, VI, NPV, and NVMeoFC.
·     Feature—Includes supporting Initiator, Target, Discovery, or any combination of the three features.
# Display detailed information about the name service database.
<Sysname> display fc name-service database verbose
VSAN:1     FCID:0x030001
  Port-WWN(vendor): 20:00:00:05:30:00:25:a3
  Node-WWN: 20:00:00:05:30:00:25:9e
  Class: 2,3
  Node-IP-addr: 192.168.0.52
  FC4-types(FC4_features): SCSI-FCP
  Symbolic-port-name:
  Symbolic-node-name:
  Port-type: 0x01(N)
  Fabric-port-WWN: 30:30:30:30:65:33:64:6b
  Hard-addr: 0x000000
VSAN:1     FCID:0x030200
  Port-WWN(vendor): 20:00:00:5a:c9:28:c7:01
  Node-WWN: 10:00:00:5a:c9:28:c7:01
  Class: 3
  FC4-types(FC4_features): NPV
  Symbolic-port-name: NPV-Sysname:Vfc1
  Symbolic-node-name: NPV-Sysname
  Port-type: 0x01(N)
  Fabric-port-WWN: 22:0a:00:05:30:00:26:1e
  Hard-addr: 0x000000
--- Total 2 entries ---
# Display the number of name service entries for VSAN 1.
<Sysname> display fc name-service database vsan 1 count
Total entries: 2
Table 22 Command output
FCID
Port-WWN(vendor)
Node-WWN
WWN of the node.
Class
Class of service.
Node-IP-addr
IP address of the node.
FC4-types(FC4 features)
FC4 type (feature) entries:
Symbolic-port-name
Symbolic name, which is used for describing an N_Port. For an NP_Port on an H3C NPV switch, it is in the form of system-name:port-name.
Symbolic-node-name
Symbolic name, which is used for describing a node. For an H3C NPV switch, it is the system-name.
Port-type
Fabric-port-WWN
WWN of the F_Port.
Hard-addr
Hardware address of the N_Port.
Total entries
Number of entries in the VSAN.
display fc port-bind-area
Use display fc port-bind-area to display information about the area ID-to-F_Port binding feature.
display fc port-bind-area [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays information about the area ID-to-F_Port binding feature for all VSANs. On an FCF-NPV switch, this command displays information about the area ID-to-F_Port binding feature for only VSANs operating in FCF mode.
# Display information about the area ID-to-F_Port binding feature for VSAN 1.
<Sysname> display fc port-bind-area vsan 10
FC port-bind-area function: Enabled
VSAN 10:
Interface    Area ID
Fc1/0/1      0xa0
Vfc1         0xa1
FC port-bind-area function: Disabled
Table 23 Command output
Area ID-to-F_Port binding feature status: Enabled or Disabled.
F_Port that has logged-in N_Ports.
Area ID
Area ID bound to the F_Port.
fc port-bind-area enable
display fc scr-table
Use display fc scr-table to display the State Change Registration (SCR) list of N_Ports in VSANs.
display fc scr-table [ vsan vsan-id ] [ count ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the SCR lists for all VSANs. On an FCF-NPV switch, this command displays the SCR lists for only VSANs operating in FCF mode.
count: Displays the number of SCR entries.
# Display the SCR list.
<Sysname> display fc scr-table
SCR table for VSAN 1:
FCID         REGISTERED FOR
0x1b0300     fabric detected rscns
0x010121     nx_port detected rscns
             fabric name change rscns
             peer zone change rscns
# Display the number of SCR entries in VSAN 1.
<Sysname> display fc scr-table vsan 1 count
Total entries: 2
Table 24 Command output
SCR table for VSAN
SCR list in a VSAN.
FCID
REGISTERED FOR
Type of Registered State Change Notification (RSCN) messages to accept:
·     fabric detected rscns—Accepts all RSCN messages sent by the switches in the fabric.
·     nx_port detected rscns—Accepts all RSCN messages sent by N_Ports.
·     fabric name change rscns—Accepts all RSCN messages sent for fabric name changes.
·     peer zone change rscns—Accepts all RSCN messages sent for peer zone changes.
·     full rscns—Accepts all RSCN messages.
Total entries
Number of SCR entries in the VSAN.
display fc switch-wwn
Use display fc switch-wwn to display the local switch WWN.
# Display the local switch WWN.
<Sysname> display fc switch-wwn
Switch WWN is 10:00:00:0d:ec:ff:a3:25
display fc timer
Use display fc timer to display fabric timers.
display fc timer [ distributed-services | error-detect | resource-allocation ] [ vsan vsan-id ]
distributed-services: Displays the distributed service timeout period, in milliseconds.
error-detect: Displays the error detection timeout period, in milliseconds.
resource-allocation: Displays the resource allocation timeout period, in milliseconds.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays global fabric timer information.
If you do not specify the distributed-services, error-detect, or resource-allocation keyword, this command displays all fabric timers.
# Display all the fabric timers for VSAN 1.
<Sysname> display fc timer vsan 1
Timer of VSAN 1:
  Distributed-services timer: 5000 ms
  Error-detect timer:         2000 ms
  Resource-allocation timer:  10000 ms
display fcid allocation
Use display fcid allocation to display FC address assignment information.
display fcid allocation [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays FC address assignment information for all VSANs. On an FCF-NPV switch, this command displays the FC address assignment information for only VSANs operating in FCF mode.
# Display FC address assignment information for VSAN 1.
<Sysname> display fcid allocation vsan 1
VSAN 1:
Free FCIDs: 0xef0000 to 0xef06ff
            0xef0701 to 0xef08ff
            0xef0901 to 0xefffff
Assigned FCIDs: 0xef0700
                0xef0900
Number of free FCIDs: 65534
Number of assigned FCIDs: 2
display fcid persistent
Use display fcid persistent to display persistent FC address entries.
display fcid persistent [ unused ] [ vsan vsan-id ]
unused: Specifies unused persistent FC address entries. If the bound WWN in a persistent FC address entry is not online, the persistent FC address entry is called an unused persistent FC address entry. If you do not specify this keyword, the command displays all persistent FC address entries.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays persistent FC address entries for all VSANs. On an FCF-NPV switch, this command displays the FC address entries for only VSANs operating in FCF mode.
# Display persistent FC address entries for all VSANs.
<Sysname> display fcid persistent
VSAN 1:
FCID persistence: Enabled
Total entries: 3
WWN                      FCID       Used   Assignment
10:00:00:00:c9:ef:39:5f  0x1e0002   Yes    Dynamic
10:00:00:00:c9:ef:39:60  0x1e1000   Yes    Static
10:00:00:00:c9:ef:39:68  0x1e000a   Yes    Dynamic
VSAN 2:
FCID persistence: Disabled
Total entries: 0
Table 25 Command output
Used
Indicates whether the FC address is used:
·     Yes—The FC address is used and the WWN is online.
·     No—The FC address is not used and the WWN is offline.
Assignment
FC address type:
·     Dynamic.
·     Static.
display rdp database
Use display rdp database to display RDP database information.
display rdp database [ port-name port-name ]
port-name port-name: Specifies a port by its name, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number. The port can be any port in the FC SAN. If you do not specify a port, this command displays RDP database information for all ports in the FC SAN.
RDP database information can be displayed only after Smart SAN is enabled for FC/FCoE.
The RDP database includes the RDP database information of the following ports:
·     N_Ports directly connected to the switch.
·     Ports on the switch.
·     N_Ports not directly connected to the switch and ports on other switches in the FC SAN.
For N_Ports, the RDP database includes information about only N_Ports that have registered with the device.
# Display the RDP database information for all ports in the FC SAN.
<Sysname> display rdp database port-name 10:00:00:00:c9:88:a4:9e
Port Name: 10:00:00:00:c9:88:a4:9d
  Node Name: 20:00:00:e0:fc:f1:e8:01
  Fabric Port Name: 20:00:00:50:c9:a3:c4:57
  Fabric Node Name: 20:64:00:e1:cf:25:09:01
  Port Speed:
    Port Speed Capabilities: 40 Gbps
    Port Operating Speed: 40 Gbps
  Link Error Status (FCoE):
      Link Failure Count: 1
      Virtual Link Failure Count: 2
      Missing FIP Keep Alive or Discovery Advertisement Count: 3
      Symbol Error During Carrier Count: 4
      Error Block Count: 5
      Frame Check Sequence Error Count: 6
  QSFP Diagnostics:
    Temperature:
      High Alarm: 127.99C    Low Alarm: -128.00C
      High Warning: 120.00C  Low Warning: -120.00C
      Current: 40.00C
      State: Normal
    Voltage:
      High Alarm: 6.3000V    Low Alarm: 3.7000V
      High Warning: 5.5000V  Low Warning: 4.5000V
      Current: 5.0000V
      State: Normal
    Lane 0 Bias Current:
      High Alarm: 120.0000mA    Low Alarm: 70.0000mA
      High Warning: 110.0000mA  Low Warning: 80.0000mA
      Current: 110.9000mA
      State: High Warning
    Lane 0 Tx Power:
      High Alarm: 6.5000mW    Low Alarm: 5.0000mW
      High Warning: 6.3000mW  Low Warning: 5.3000mW
      Current: 6.0000mW
      State: Normal
    Lane 0 Rx Power:
      Current: 6.0000mW
      State: Normal
    Lane 1 Bias Current:
      Current: 110.9000mA
      State: High Warning
    Lane 1 Tx Power:
      Current: 6.0000mW
      State: Normal
    Lane 1 Rx Power:
      Current: 6.0000mW
      State: Normal
    Lane 2 Bias Current:
      Current: 110.9000mA
      State: High Warning
    Lane 2 Tx Power:
      Current: 6.0000mW
      State: Normal
    Lane 2 Rx Power:
      Current: 6.0000mW
      State: Normal
    Lane 3 Bias Current:
      Current: 110.9000mA
      State: High Warning
    Lane 3 Tx Power:
      Current: 6.0000mW
      State: Normal
    Lane 3 Rx Power:
      Current: 6.0000mW
      State: Normal
  Tx Type: Short Wave Laser
  Optical Port: Yes
  Connector Type: QSFP
  FEC Active: Yes
  FEC Status:
  Corrected blocks: 3
  Uncorrected blocks: 1
  Buffer Credit:
    Receive B2B Credit:15
    Transmit B2B Credit: 15
    Nominal Port RTT: 10000ns
  Optical Product Data:
    Vendor Name: H3C
    Part Number:QSFP-40G-LR4-WDM1300
    Serial Number: AA05011023
    Revision: N
    Date: 260414
Port Name: 28:05:00:e0:fc:f1:58:2a
  Node Name: -
  Port Speed:
    Port Speed Capabilities: 2 Gbps, 4Gbps, 8Gbps, 16Gbps
    Port Operating Speed: 4 Gbps
  Link Error Status (FC):
    Loss-of-Synchronization Count: 2
    Loss-of-Signal Count: 3
    Primitive Sequence Protocol Errors: 2
    Invalid Transmission Words: 1
    Invalid CRC Count: 1
  SFP Diagnostics:
    Temperature:
    Current: 40C
    State: Normal
  Voltage:
    Current: 5.0000V
    State: Normal
  Bias Current:
    Current: 110.9000mA
    State: High Warning
  Tx Power:
    Current: 6.0000mW
    State: Normal
  Rx Power:
    Current: 6.0000mW
    State: Normal
    Optical Port: Yes
    Connector Type: SFP+
  FEC Active: No
  Buffer Credit:
    Receive B2B Credit: 15
    Vendor Name: H3C
    Part Number: SFP-XG-LX-SM1310
    Revision: N
    Date: -
  Node Name: -
Table 26 Command output
Port Name
Port WWN.
Node Name
This field displays the node WWN for an Nx_Port, a hyphen (-) for an F_Port or E_Port, and the WWN of the NPV switch for an NP_Port.
Fabric Port Name
WWN of the F_Port or NP_Port directly connected to the Nx_Port.
Fabric Node Name
WWN of the switch where the F_Port or NP_Port directly connected to the Nx_Port resides.
The supported speed can be one or more of the following options:
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     32 Gbps.
This field displays Unknown for speeds other than the preceding ones.
The current speed can only be one of the following options:
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     32 Gbps.
Link Error Status
Link error state:
·     Link Error Status (FCoE)—Link error state for the VFC interface directly connected to the Nx_Port.
·     Link Error Status (FC) —Link error state for the FC interface directly connected to the Nx_Port.
Link Failure Count
Number of link failures detected through physical link transition detection.
Number of link failures detected by the virtual link maintenance protocol.
Number of missing virtual link maintenance protocol frames.
Number of reception errors at the PHY layer that occur during frame reception.
Error Block Count
Cumulative count of the events counted by the 8-bit errored blocks counter.
Number of Ethernet frames received that are an integral number of octets in length and do not pass the FCS check.
Temperature
Internally measured transceiver temperature.
Voltage
Internally measured supply voltage.
Bias Current
Measured transmitter laser bias current.
Tx Power
Measured coupled TX output power.
Rx Power
Measured received optical power.
Lane
This field is displayed only when a multi-channel QSFP transceiver module is used.
Tx Type
Transmitter type of the Nx_Port:
·     Short Wave Laser.
·     Long Wave Laser LC 1310nm.
·     Long Wave Laser LL 1550nm.
Optical Port
Indicates whether the Nx_Port is an optical port: Yes or No.
FEC Active
Indicates whether Forward Error Correction (FEC) is active: Yes or No.
Corrected blocks
Number of FEC blocks corrected by hardware.
Uncorrected blocks
Number of FEC blocks not corrected by hardware.
Receive B2B Credit
B2B credit information of the local end.
Transmit B2B Credit
B2B credit information of the remote end.
Nominal Port RTT
Roundtrip time for the port to receiving and sending packets.
Unknown means that the roundtrip time is not obtained.
Revision
Vendor's revision level for the part number provided.
Date
Date when the product was manufactured.
display rdp request-polling-interval
Use display rdp request-polling-interval to display the interval for sending RDP request packets.
The interval for sending RDP request packets can be displayed only after Smart SAN is enabled for FC/FCoE.
# Display the interval for sending RDP request packets.
<Sysname> display rdp request-polling-interval
RDP request-polling-interval: 30 minutes
display smartsan status
Use display smartsan status to display the Smart SAN status.
# Display the Smart SAN status.
<Sysname> display smartsan status
Smart SAN Status:
  FC/FCoE: Enabled
  iSCSI: Disabled
domain auto-reconfigure enable
Use domain auto-reconfigure enable to enable automatic reconfiguration in a VSAN.
Use undo domain auto-reconfigure enable to disable automatic reconfiguration in a VSAN.
Automatic reconfiguration is disabled in a VSAN.
VSAN view
This command takes effect only when the fabric configuration feature is enabled.
A fabric reconfiguration triggers a principal switch selection phase.
A disruptive reconfiguration is automatically performed if the domain ID lists overlap when two fabrics are merged.
A nondisruptive reconfiguration is automatically performed when one of the following conditions exists:
·     When two fabrics are merged, the principal switch information of the two fabrics is different, and the domain ID lists are not empty and do not overlap.
·     A principal link in a fabric goes down.
# Enable the automatic reconfiguration feature in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain auto-reconfigure enable
Use domain configure enable to enable the fabric configuration feature in a VSAN.
Use undo domain configure enable to disable the fabric configuration feature in a VSAN.
The fabric configuration feature is enabled in a VSAN.
VSAN view
To dynamically build a fabric, you must enable the fabric configuration feature on switches. After you enable the fabric configuration feature on FCF switches, the switches exchange messages to select the principal switch. Then, the principal switch dynamically assigns domain IDs to all switches in the fabric.
To statically build a fabric, you must disable the fabric configuration feature on switches and manually set a unique domain ID for each switch. After you disable the fabric configuration feature on FCF switches, the switches will not select a principal switch and cannot obtain domain IDs dynamically.
# Enable the fabric configuration feature in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain configure enable
domain restart
Use domain restart to manually initiate a fabric reconfiguration in a VSAN.
domain restart [ disruptive ]
VSAN view
disruptive: Initiates a disruptive reconfiguration. If you do not specify this keyword, the command initiates a nondisruptive reconfiguration.
A fabric reconfiguration can be disruptive or nondisruptive.
·     Disruptive reconfiguration—Floods Reconfigure Fabric (RCF) frames throughout the fabric and notifies all switches to perform a disruptive reconfiguration. During the reconfiguration procedure, each switch clears all data and performs renegotiation, and data transmission in the fabric is disrupted.
·     Nondisruptive reconfiguration—Floods Build Fabric (BF) frames throughout the fabric and notifies all switches to perform a nondisruptive reconfiguration. During the reconfiguration procedure, each switch tries to save the last running data for its domain ID to remain unchanged. Thus, data transmission in the fabric is not disrupted.
For fabric settings that do not take effect immediately (for example, switch priority), you can perform a disruptive reconfiguration to make them take effect.
# Manually initiate a disruptive reconfiguration in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain restart disruptive
The command may cause traffic interruption. Continue? [Y/N]:y
domain-id
Use domain-id to set a domain ID in a VSAN.
Use undo domain-id to restore the default.
domain-id domain-id { preferred | static }
undo domain-id
The domain ID is 0 preferred in a VSAN.
VSAN view
domain-id: Specifies a domain ID in the range of 1 to 239.
preferred: Specifies the domain ID as preferred.
static: Specifies the domain ID as static.
The upper-layer protocol identifies only the WWNs, but FCF switches use domain IDs to route and forward packets. Domain IDs are assigned on a per-VSAN basis and have a default value of 0, which cannot distinguish devices. Therefore, you must statically configure or dynamically assign domain IDs for FCF switches.
In the static domain ID assignment method, the ID type configuration does not affect the assignment result.
In the dynamic domain ID assignment method, the principal switch assigns a domain ID to each switch in the fabric.
·     If a non-principal switch fails to get the configured preferred domain ID from the principal switch, it accepts any other domain ID assigned by the principal switch.
·     If a non-principal switch fails to get the configured static domain ID, it does not accept any other domain ID and isolates the upstream principal link.
As a best practice, configure domain IDs of the same type for all switches in a VSAN.
# Configure static domain ID 55 in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] domain-id 55 static
Nondisruptive reconfiguration might be performed or the switch might be isolated. Continue? [Y/N]:y
fabric-name
Use fabric-name to set a fabric name in a VSAN.
Use undo fabric-name to restore the default.
fabric-name name
undo fabric-name
The fabric name is the WWN of the switch.
VSAN view
name: Specifies a fabric name, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
An FCF switch supports assigning a fabric name to each VSAN, in the same format as the WWN (a 64-bit address).
Set fabric names only when you build a fabric statically. You must set the same fabric name on all switches in a VSAN. In a dynamically built fabric, each VSAN uses the WWN of the principal switch as the fabric name.
# Set the fabric name to 10:11:12:13:14:15:16:17 in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] fabric-name 10:11:12:13:14:15:16:17
fc domain rcf-reject
Use fc domain rcf-reject to configure an interface to reject the RCF requests received in a VSAN.
Use undo fc domain rcf-reject to configure an interface to accept the RCF requests received in a VSAN.
fc domain rcf-reject vsan vsan-id
undo fc domain rcf-reject vsan vsan-id
An interface does not reject the RCF requests received in a VSAN.
FC interface view
VFC interface view
In a stable fabric, to avoid unnecessary disruptive reconfigurations, you can configure an interface to reject the RCF requests received in a VSAN. With this feature, when the interface receives an RCF request in the VSAN, the switch replies with a reject message and isolates the interface.
# Configure FC 1/0/1 to reject the RCF requests received in VSAN 1.
[Sysname-Fc1/0/1] fc domain rcf-reject vsan 1
# Configure VFC 1 to reject the RCF requests received in VSAN 1.
[Sysname] interface vfc 1
[Sysname-Vfc1] fc domain rcf-reject vsan 1
fc login-limit
Use fc login-limit to set the maximum number of logged-in nodes allowed in a VSAN.
Use undo fc login-limit to restore the default.
fc login-limit max-number
undo fc login-limit
The number of logged-in nodes allowed in a VSAN is not limited.
VSAN view
max-number: Specifies the maximum number of logged-in nodes, in the range of 1 to 65535.
Logged-in nodes consume ACL resources. To save ACL resources, you can set the maximum number of logged-in nodes allowed in a VSAN. The number of logged-in nodes is the number of directly connected NPV switches plus the number of logged-in servers and disks.
If the number of nodes that have logged in exceeds the maximum number, no logged-in nodes will be logged out. However, any new nodes cannot log in. You can log out nodes by shutting down interfaces connected to these nodes.
The maximum number of logged-in nodes depends on both this command and hardware ACL resources. When hardware ACL resources are exhausted, any new nodes cannot log in.
# Configure VSAN 2 to allow up to 256 nodes to log in.
[Sysname] vsan 2
[Sysname-vsan2] fc login-limit 256
fc name-service auto-discovery
Use fc name-service auto-discovery to enable SCSI-FCP information autodiscovery.
Use undo fc name-service auto-discovery to disable SCSI-FCP information autodiscovery.
SCSI-FCP information autodiscovery is enabled.
VSAN view
In some situations, for example, when a node logs out and then logs back in, the node does not register SCSI-FCP support. As a result, the node does not have a Feature value. This might cause communication failure between the node and other nodes.
This command enables the switch to automatically obtain SCSI-FCP support and the Feature value by sending a PRLI packet to the node logging in. Then, the switch stores the SCSI-FCP information in the name service database.
After this command is configured, nodes with older-model HBAs might not actively register name service information with the switch.
# Enable SCSI-FCP information autodiscovery in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fc name-service auto-discovery
Use fc port-bind-area enable to enable area ID-to-F_Port binding.
Use undo fc port-bind-area enable to disable area ID-to-F_Port binding.
Area ID-to-F_Port binding is disabled.
This command affects the area ID assignment for N_Ports on all F_Ports and the mask length of related direct routes.
After this command is configured, the switch logs out all N_Ports that have logged in to an F_Port and deletes the persistent FC address entries for these N_Ports. The switch assigns an FC address to the first N_Port that logs in to the F_Port in the way used when area ID-to-F_Port binding is not enabled. Subsequent N_Ports that log in to the same F_Port use the area ID of the first N_Port. For an F_Port that is an FC interface or FC aggregate interface, the switch generates only one direct route with a 16-bit mask. For an F_Port that is a VFC interface, the switch generates one direct route with a 24-bit mask for each N_Port.
If the area ID of the bound or desired FC address for an N_Port is different from the bound area ID for the F_Port, the N_Port cannot log in. Before enabling this command, correctly plan FC addresses for N_Ports.
# Enable area ID-to-F_Port binding.
[Sysname] fc port-bind-area enable
All nodes will be logged out, and FC ID persistence data will be deleted. Continue? [Y/N]:y
fc timer distributed-services
Use fc timer distributed-services to set the global distributed service timeout period.
Use undo fc timer distributed-services to restore the default.
fc timer distributed-services value
The global distributed service timeout period is 5000 milliseconds.
value: Specifies the distributed service timeout period in the range of 5000 to 10000 milliseconds.
The distributed service timeout period can be set in system view or VSAN view.
The setting in system view takes effect on all VSANs. The setting in VSAN view takes effect only on the current VSAN.
If you set the distributed service timeout period both globally and for a VSAN, the setting for the VSAN takes precedence.
# Set the global distributed service timeout period to 6000 milliseconds.
[Sysname] fc timer distributed-services 6000
fc timer error-detect
Use fc timer error-detect to set the global error detection timeout period.
Use undo fc timer error-detect to restore the default.
fc timer error-detect value
The global error detection timeout period is 2000 milliseconds.
value: Specifies the error detection timeout period in the range of 1000 to 10000 milliseconds.
The error detection timeout period can be set in system view or VSAN view.
If you set the error detection timeout period both globally and for a VSAN, the setting for the VSAN takes precedence.
# Set the global error detection timeout period to 6000 milliseconds.
[Sysname] fc timer error-detect 6000
timer error-detect
fc timer resource-allocation
Use fc timer resource-allocation to set the global resource allocation timeout period.
Use undo fc timer resource-allocation to restore the default.
fc timer resource-allocation value
The global resource allocation timeout period is 10000 milliseconds.
value: Specifies the resource allocation timeout period in the range of 5000 to 10000 milliseconds.
The resource allocation timeout period can be set in system view or VSAN view.
If you set the resource allocation timeout period both globally and for a VSAN, the setting for the VSAN takes precedence.
# Set the global resource allocation timeout period to 6000 milliseconds.
[Sysname] fc timer resource-allocation 6000
fc wwn default-fc4-type
Use fc wwn default-fc4-type to configure the default FC4 information for a node.
Use undo fc wwn default-fc4-type to delete the default FC4 information of a node.
fc wwn wwn-value default-fc4-type { type-value feature feature-map | scsi-fcp feature { feature-map | both | initiator | target } }
undo fc wwn wwn-value default-fc4-type { type-value | scsi-fcp }
The default FC4 information for a node is not configured for a node.
wwn-value: Specifies an N_Port by its WWN in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal).
type-value: Specifies a supported FC4-Type by its value in the range of 0 to 255. The FC4-Type field is 256 bits, each of which represents an FC4-Type. If a bit is set to 1, the FC4-Type that the bit represents is supported. Only one bit can be set to 1 at the same time.
scsi-fcp: Specifies the supported FC4-Type as SCSI-FCP, which has a type-value of 8.
feature feature-map: Specifies the Feature value for the supported FC4-Type. The value range for feature-map is 0 to 15. The Feature field is 4 bits, each of which represents a Feature. If a bit is set to 1, the Feature that the bit represents is supported. Multiple bits can be set to 1 at the same time. For example, if the value is set to 15, the node supports four Features of the FC4-Type. If the value is set to 0, the node supports none of the four Features. When you specify supported FC4-Type as SCSI-FCP, you can configure the following keywords:
·     initiator: Specifies support for the initiator Feature, which has a feature-map of 2.
·     target: Specifies support for the target Feature, which has a feature-map of 1.
·     both: Specifies support for both initiator and target Features, which has a feature-map of 3.
The switch records the default FC4 information in the name service database for a node when the following conditions exist:
·     The node does not register FC4 information.
·     The switch fails to obtain SCSI-FCP information from the node.
The switch replaces the default FC4 information with the registered FC4 information or obtained SCSI-FCP information when one of the following events occurs:
·     A node registers FC4 information.
·     The switch obtains the SCSI-FCP information.
You can execute this command multiple times to configure different FC4-Types for one N_Port.
# Configure the default FC4 information for the node with WWN 00:00:00:11:22:33:44:55.
[Sysname] fc wwn 00:00:00:11:22:33:44:55 default-fc4-type scsi-fcp feature target
[Sysname] fc wwn 00:00:00:11:22:33:44:55 default-fc4-type 9 feature 7
fcid persistent enable
Use fcid persistent enable to enable the persistent FC address feature in a VSAN.
Use undo fcid persistent enable to disable the persistent FC address feature in a VSAN.
The persistent FC address feature is enabled in a VSAN.
VSAN view
Manually configured persistent FC address entries take effect only when the persistent FC address feature is enabled. After you disable the persistent FC address feature, all static and dynamic persistent FC address entries are deleted.
An association between a WWN and its assigned FC address is recorded when the WWN logs in. When you re-enable the persistent FC address feature after you disable it, the system generates dynamic persistent FC address entries for the associations.
The system can store up to 40000 persistent FC address entries. When this limit is reached, the system deletes dynamic persistent FC address entries for all offline WWNs before generating new ones.
# Disable the persistent FC address feature in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] undo fcid persistent enable
wwn fcid
priority
Use priority to set the switch priority in a VSAN.
Use undo priority to restore the default.
priority priority
undo priority
The switch priority is 128 in a VSAN.
VSAN view
priority: Specifies the switch priority in the range of 1 to 254. A smaller value indicates a higher priority.
One FC switch can have different priorities in different VSANs. The FC switch with the highest priority in a VSAN will be selected as the principal switch in that VSAN.
To make the priority setting take effect, perform a disruptive reconfiguration by using the domain restart disruptive command.
# Set the switch priority to 64 in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] priority 64
domain restart
Use rdp request-polling-interval to set the interval for sending RDP request packets.
Use undo rdp request-polling-interval to restore the default.
rdp request-polling-interval interval
The interval for sending RDP request packets is 30 minutes.
interval: Specifies the interval for sending RDP request packets, in the range of 5 to 1440 minutes.
The interval for sending RDP request packets can be set only after Smart SAN is enabled for FC/FCoE.
# Set the interval for sending RDP request packets to 5 minutes.
[Sysname] rdp request-polling-interval 5
reset fcid persistent
Use reset fcid persistent to clear persistent FC address entries for offline WWNs.
reset fcid persistent [ static ] [ vsan vsan-id ]
static: Specifies static persistent FC address entries. If you do not specify this keyword, the command clears dynamic persistent FC address entries.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command clears persistent FC address entries for offline WWNs in all VSANs. On an FCF-NPV switch, this command clears the FC address entries for offline WWNs in only VSANs operating in FCF mode.
# Clear all dynamic persistent FC address entries in VSAN 1.
<Sysname> reset fcid persistent vsan 1
rscn aggregation enable
Use rscn aggregation enable to enable RSCN aggregation.
Use undo rscn aggregation enable to disable RSCN aggregation.
RSCN aggregation is disabled.
VSAN view
For multiple change events occurring within the RSCN aggregation timer interval, RSCN aggregation places the FC addressees of multiple nodes with changes into a single RSCN. This feature reduces the number of RSCNs sent to the concerned registered nodes.
As a best practice, enable RSCN aggregation and set the same RSCN aggregation timer value on all switches in a VSAN.
# Enable RSCN aggregation in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] rscn aggregation enable
rscn aggregation timer
Use rscn aggregation timer to set the RSCN aggregation timer.
Use undo rscn aggregation timer to restore the default.
rscn aggregation timer value
The RSCN aggregation timer is 2000 milliseconds.
VSAN view
value: Specifies the RSCN aggregation timer value in the range of 100 to 2000 milliseconds.
The RSCN aggregation timer takes effect only when RSCN aggregation is enabled.
# Set the RSCN aggregation timer of VSAN 1 to 1500 milliseconds.
[Sysname] vsan 1
[Sysname-vsan1] rscn aggregation timer 1500
smartsan enable
Use smartsan enable to enable Smart SAN.
Use undo smartsan enable to disable Smart SAN.
smartsan enable [ fcoe | iscsi ]
undo smartsan enable [ fcoe | iscsi ]
Smart SAN is disabled.
fcoe: Specifies Smart SAN for FC/FCoE.
iscsi: Specifies Smart SAN for iSCSI. This keyword is not supported in the current software version.
If you do not specify the fcoe or iscsi keyword, Smart SAN is enabled or disabled for both FC/FCoE and iSCSI.
The undo smartsan enable command deletes local peer zone information, but not peer zone information received from other switches. For more information about peer zones, see FC and FCoE Configuration Guide.
# Enable Smart SAN for FC/FCoE.
[Sysname] smartsan enable fcoe
snmp-agent trap enable fc-fabric
Use snmp-agent trap enable fc-fabric to enable SNMP notifications for the fabric module.
Use undo snmp-agent trap enable fc-fabric to disable SNMP notifications for the fabric module.
snmp-agent trap enable fc-fabric [ domain-id-change | fabric-change ] *
undo snmp-agent trap enable fc-fabric [ domain-id-change | fabric-change ] *
All SNMP notifications for the fabric module are disabled.
domain-id-change: Specifies notifications about domain ID changes.
fabric-change: Specifies notifications about fabric changes.
To report critical fabric module events to an NMS, enable SNMP notifications for the fabric module. For fabric module event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
If you do not specify a notification, this command enables all SNMP notifications for the fabric module.
After you enable SNMP notifications for domain ID changes, the switch generates a notification when its domain ID changes in a VSAN. The notification includes the VSAN ID, the switch WWN, and the new domain ID.
After you enable SNMP notifications for fabric changes, the switch generates a notification when it sends or receives a BF or RCF frame for fabric reconfiguration. The notification includes the VSAN ID for fabric reconfiguration.
# Enable all SNMP notifications for the fabric module.
[Sysname] snmp-agent trap enable fc-fabric
snmp-agent trap enable fc-name-service
Use snmp-agent trap enable fc-name-service to enable SNMP notifications for the name service module.
Use undo snmp-agent trap enable fc-name-service to disable SNMP notifications for the name service module.
snmp-agent trap enable fc-name-service [ login| logout ] *
undo snmp-agent trap enable fc-name-service [ login| logout ] *
All SNMP notifications for the name service module are disabled.
login: Specifies notifications about node login.
logout: Specifies notifications about node logout.
To report critical name service module events to an NMS, enable SNMP notifications for the name service module. For name service event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
If you do not specify a notification, this command enables all SNMP notifications for the name service module.
After you enable SNMP notifications for node login or logout, the switch generates a notification when a node registers or deregisters its name service information with the switch. The notification includes the VSAN ID, the switch WWN, and the WWN of the N_Port.
# Enable all SNMP notifications for the name service module.
[Sysname] snmp-agent trap enable fc-name-service
Use timer distributed-services to set the distributed service timeout period for a VSAN.
Use undo timer distributed-services to restore the default.
The distributed service timeout period is 5000 milliseconds for a VSAN.
VSAN view
# Set the distributed service timeout period to 6000 milliseconds for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] timer distributed-services 6000
timer error-detect
Use timer error-detect to set the error detection timeout period for a VSAN.
Use undo timer error-detect to restore the default.
The error detection timeout period is 2000 milliseconds for a VSAN.
VSAN view
# Set the error detection timeout period to 6000 milliseconds for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] timer error-detect 6000
Use timer resource-allocation to set the resource allocation timeout period for a VSAN.
Use undo timer resource-allocation to restore the default.
The resource allocation timeout period is 10000 milliseconds for a VSAN.
VSAN view
Only FCF, FCF-NPV, and NPV switches support this command.
# Set the resource allocation timeout period to 6000 milliseconds for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] timer resource-allocation 6000
wwn fcid
Use wwn fcid to configure a persistent FC address entry.
Use undo wwn fcid to delete a persistent FC address entry.
wwn wwn-value fcid fcid-value [ dynamic ]
undo wwn wwn-value fcid
No manually configured persistent FC address entries exist.
VSAN view
wwn-value: Specifies the WWN of an N_Port or NP_Port, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
fcid-value: Specifies an FC address in the format of xxxxxx, where x is a hexadecimal number. The first two digits indicate the domain ID, the next two digits indicate the area ID, and the remaining two digits indicate the port ID. The domain ID must be a runtime domain ID in the VSAN.
dynamic: Specifies the persistent FC address entry as dynamic. If you do not specify this keyword, the configured persistent FC address entry is static.
A WWN can be bound to only one FC address and vice versa. If a WWN has been assigned another FC address or the FC address has been assigned to another WWN, the persistent FC address entry cannot be configured.
When the entry limit (40000) is reached, the system deletes dynamic persistent FC address entries for all offline WWNs before adding new entries. If all persistent FC address entries are static or all WWNs are online, the system denies all new FLOGI requests.
# In VSAN 1, configure a static persistent FC address entry (WWN is 33:e8:00:05:30:00:16:df and FC address is 010312).
[Sysname] vsan 1
[Sysname-vsan1] wwn 33:e8:00:05:30:00:16:df fcid 010312
FC routing and forwarding commands
display fc exchange
Use display fc exchange to display FC exchange entries.
display fc exchange { link | protocol } [ slot slot-number ]
display fc exchange link verbose slot slot-number exid exid
link: Specifies link exchange entries.
protocol: Specifies protocol exchange entries.
verbose: Displays detailed information about link exchange entries.
exid exid: Displays link exchange entries for an exchange ID in the range of 0 to 65534.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays exchange entries for the master device.
The exchange is a basic concept of FC. All data frames and control frames are transmitted based on the exchange. An exchange indicates one data exchange between communication entities and can contain multiple bidirectional packet exchanges.
An exchange pair (initiating exchange and responding exchange) must be created for each data exchange. Service classes that provide reliable transmission services (classes 1, 2, and 6) perform packet acknowledgment, error detection, and packet retransmission based on the exchange pair.
Exchanges include the following categories:
·     Protocol exchange—Created only at the server end based on the protocol number and VSAN ID and used for monitoring connection establishment.
·     Link exchange—Created at both ends based on the exchange ID and used for packet exchange.
# Display the protocol exchange entries for slot 1.
<Sysname> display fc exchange protocol slot 1
 Local_ID:EXID     Remote_ID:EXID     State       Slot  Protocol
 0x000000:65535    0x000000:65535     LISTEN      1     6
# Display the link exchange entries for slot 2.
<Sysname> display fc exchange link slot 2
 0x060501:1024     0x010001:1025      ESTABLISHED 2     8
#  Display detailed information about the link exchange entry with exchange ID 1 for slot 1.
<Sysname> display fc exchange link verbose slot 1 exid 1
 slot: 1
 protocol: 8
 connection info: Local = 0x090801:1155 ,  Remote = 0x050001:1089
 PCB flags: 0x2
 FC Class: FC_CLASS_F
 connection state: ESTABLISHED
 VSAN ID: 25
Table 27 Command output
Local_ID:EXID/Local
FC address and exchange ID of the local end.
This field is ignored for a protocol exchange.
Remote_ID:EXID/Remote
FC address and exchange ID of the peer end.
State/connection state
Connection state of the FC exchange:
·     PREPARE—The protocol exchange is successfully bound, or the link exchange is waiting for the response packet.
·     LISTEN—The protocol exchange is monitoring the connection.
·     ESTABLISHED—The connection has been established.
·     ABTS—An ABTS was sent due to a connection timeout or error, and the ABTS ACK is being expected.
·     BA_ACC—An ABTS was received, an BA_ACC is replied, and an ACC ACK is being expected.
·     ABTS_ACK—An ABTS ACK was received, and a BA_ACC is being expected.
·     CLOSED—The connection is closed.
Slot/slot
Card where the FC exchange is created.
Protocol/protocol
FC protocol number.
PCB flags
FC exchange state flags:
·     0x1—The value 0 indicates the sending end, and 1 indicates the replying end.
·     0x2—The value 0 means there is no initiative, and 1 means there is initiative.
·     0x4—The value 1 indicates the first packet of the exchange.
·     0x8—The value 1 indicates that the exchange is waiting to be aged.
FC Class
FC connection service level (FC_CLASS_3 requires no ACK):
·     FC_CLASS_1.
·     FC_CLASS_2.
·     FC_CLASS_3.
·     FC_CLASS_F.
·     FC_CLASS_6.
display fc fib
Use display fc fib to display the FC FIB entries.
display fc fib [ fcid [ mask-length ] ] vsan vsan-id
fcid: Specifies a destination FC address in the range of 000000 to ffffff (hexadecimal).
mask-length: Specifies the mask length for the destination address, in the range of 0 to 24.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 4095.
The device looks up the VSAN ID and FC address in the FC FIB for the outgoing interface.
If you specify both the fcid and mask-length arguments, this command displays FC FIB entries for the specified FC address and mask length.
If you specify the fcid argument but not the mask-length argument, this command displays FC FIB entries for the specified FC address according to the longest matching rule.
If you do not specify the fcid argument or the mask-length argument, this command displays all FC FIB entries.
# Display all the FC FIB entries in VSAN 18.
<Sysname> display fc fib vsan 18
FC FIB information in VSAN 18:
  Destination count: 6
  FIB entry count: 7
  Destination/Mask              Interface
  0x030100/16                   Vfc1
  0x030100/16                   Vfc2
  0x030100/24                   Vfc3
  0xfffc01/24                   InLoop0
  0xfffffa/24                   InLoop0
  0xfffffc/24                   InLoop0
  0xfffffd/24                   InLoop0
# Display the FC FIB entries for the specified FC address according to the longest matching rule.
<Sysname> display fc fib 030100 vsan 18
  Destination count: 1
  FIB entry count: 1
  0x030100/24                   Vfc3
# Display the FC FIB entries for the specified FC address and mask length.
<Sysname> display fc fib 030100 16 vsan 18
  FIB entry count: 2
  0x030100/16                   Vfc1
  0x030100/16                   Vfc2
Table 28 Command output
Destination count
Number of destination addresses.
FIB entry count
Number of FIB entries, including equal-cost routes.
Destination/Mask
Destination address/mask length.
Outgoing interface.
display fc routing-table
Use display fc routing-table to display the FC routing table.
display fc routing-table [ vsan vsan-id ] [ statistics | verbose ]
display fc routing-table vsan vsan-id fcid [ mask | mask-length ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 4095. If you do not specify a VSAN, this command displays routing information of all VSANs.
fcid: Specifies the destination FC address for FC routes, in the range of 010000 to efffff (hexadecimal).
mask: Specifies a hexadecimal mask of the FC address. This argument is used together with the fcid argument. The value of this argument can be ff0000, ffff00, or ffffff. If you do not specify a hexadecimal mask, this command displays the routing information for the FC address fcid with masks 0xff0000, 0xffff00, and 0xffffff.
mask-length: Specifies a decimal mask of the FC address. This argument is used together with the fcid argument. The value of this argument can be 8, 16, or 24. If you do not specify a decimal mask, this command displays the routing information for the FC address fcid with masks 8, 16, and 24.
statistics: Displays the statistics for the FC routing table.
verbose: Displays detailed information about the FC routing table.
The routing table stores routes discovered by various routing protocols. You can use this command to display brief information, detailed information, and statistics about the routing table.
The display fc routing-table [ vsan vsan-id ] [ statistics | verbose ] command displays all routes in a VSAN or in all VSANs. The display fc routing-table vsan vsan-id fcid [ mask | mask-length ] [ verbose ] command displays one route in a VSAN.
If you specify do not specify the statistics or verbose keyword, this command displays brief information about the FC routing table.
The brief information contains information about only active routes. The detailed information contains information about both active and inactive routes.
# Display brief information about all the routes in VSAN 5.
<Sysname> display fc routing-table vsan 5
Routing Table: VSAN 5
  Destinations : 5          Routes : 8
  Destination/mask   Protocol   Preference   Cost     Interface
  0x040000/8         FSPF       20           100      Vfc1
  0x040000/8         FSPF       20           100      Vfc2
  0x040000/8         FSPF       20           100      Vfc3
  0x040000/8         FSPF       20           100      Vfc4
  0xfffc01/24        DIRECT     0            0        InLoop0
  0xfffffa/24        DIRECT     0            0        InLoop0
  0xfffffc/24        DIRECT     0            0        InLoop0
  0xfffffd/24        DIRECT     0            0        InLoop0
# Display detailed information about all the routes in VSAN 5.
<Sysname> display fc routing-table vsan 5 verbose
  Destinations : 5          Routes : 5
  Destination/mask: 0x120000/8
          Protocol: STATIC
        Preference: 10
              Cost: 0
         Interface: Vfc1
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffc01/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffffa/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffffc/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
  Destination/mask: 0xfffffd/24
          Protocol: DIRECT
        Preference: 0
              Cost: 0
         Interface: InLoop0
             State: Active
               Age: 0h21m36s
Table 29 Command output
VSAN
VSAN number.
Destination/mask
FC address/mask.
Protocol
Protocol type:
·     DIRECT—Direct routes.
·     STATIC—Static routes.
·     FSPF—FSPF routes.
Preference
Route preference.
Cost
Route cost.
Outgoing interface.
Route state: Active or Inactive.
Age
Lifetime of the route in the routing table, in the format of XXhXXmXXs.
# Display the statistics for all the routes in VSAN 5.
<Sysname> display fc routing-table vsan 5 statistics
  Protocol  route       active      added       deleted
  DIRECT    4           4           4           0
  STATIC    1           1           1           0
  FSPF      0           0           0           0
  Total     5           5           5           0
Table 30 Command output
VSAN
VSAN number.
Protocol
Protocol type:
·     FSPF—FSPF routes.
route
Number of routes of the specified protocol type.
active
Number of active routes of the specified protocol type.
added
Number of added routes of the specified protocol type.
deleted
Number of deleted routes of the specified protocol type.
Total
Total number of routes.
fc route-static
display fspf graceful-restart
Use display fspf graceful-restart to display FSPF GR status information.
display fspf graceful-restart [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays FSPF GR status information for all VSANs. On an FCF-NPV switch, this command displays the FSPF GR status information for only VSANs operating in FCF mode.
Only FCF and FCF-NPV switches support this command.
The FSPF GR status information includes the following:
·     Whether GR restarter is enabled.
·     Whether GR helper is enabled.
·     Number of GR restarters being restarted.
·     Number of GR helpers assisting in restarting the local device.
# Display FSPF GR status information.
<Sysname> display fspf graceful-restart
Graceful-restart capability      : Disable
Helper capability                : Enable
Graceful-restart period          : 120 seconds
FSPF graceful restart information of VSAN 1:
  Number of neighbors under helper : 0
  Number of restarting neighbors   : 0
FSPF graceful restart information of VSAN 2:
Table 31 Command output
Indicates whether GR restarter capability is enabled: Enable or Disable.
Helper capability
Indicates whether GR helper capability is enabled: Enable or Disable.
Number of neighbors acting as GR helpers.
Number of neighbors acting as GR restarters.
fspf graceful-restart helper
fspf graceful-restart interval
display fspf lsdb
Use display fspf lsdb to display FSPF link state database (LSDB) information.
display fspf lsdb [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays LSDB information for all VSANs. On an FCF-NPV switch, this command displays the LSDB information for only VSANs operating in FCF mode.
The FSPF LSDB information includes the total number of link state records (LSRs) and information about each LSR.
# Display FSPF LSDB information.
<Sysname> display fspf lsdb
FSPF LSDB information of VSAN 1(01):
  Total LSR count: 2
    FSPF Link State Database for Domain 01
      LSR Type                  : 1
      LSR Age                   : 0
      LSR Incarnation number    : 0x80000008
      LSR Checksum              : 0x7deb
      Number of links           : 1
      NbrDomainID    IfIndex    NbrIfIndex    LinkType    Cost
      2              0x68       0x68          1           265
    FSPF Link State Database for Domain 02
      LSR Type                  : 1
      LSR Age                   : 6
      LSR Checksum              : 0x7dea
      Number of links           : 1
      1              0x68       0x68          1           265
Table 32 Command output
LSDB information for a VSAN. The value in parentheses is the domain ID in decimal of the local switch.
LSDB information for a domain ID (switch).
LSR Type
LSR type, which can only be Switch Link Record (0x01).
LSR instance number.
NbrDomainID
Neighbor domain ID.
IfIndex
Outgoing interface index of the local switch.
NbrIfIndex
Neighbor interface index.
Link Type
Link type:
·     0x01—Point-to-point.
·     0xF0-FF—Vendor-defined.
Cost
Link cost.
display fspf neighbor
Use display fspf neighbor to display FSPF neighbor information.
display fspf neighbor [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays information about all FSPF neighbors. On an FCF-NPV switch, this command displays the FSPF neighbor information for only VSANs operating in FCF mode.
The FSPF neighbor information includes the following details:
·     Neighbor domain ID.
·     Neighbor interface index.
·     Outgoing interface index of the local switch.
·     Remaining dead interval of the neighbor.
·     Neighbor state.
# Display FSPF neighbor information.
<Sysname> display fspf neighbor
FSPF neighbor information of VSAN 1(01):
  Interface   NbrDomain   IfIndex   NbrIfIndex   Dead Time   State
  Vfc1        2           0x68      0x68         00:01:06    Full
Table 33 Command output
FSPF neighbor information for a VSAN. The value in parentheses is the domain ID in decimal of the local switch.
Interface name of the local switch.
NbrDomain
Neighbor domain ID in decimal.
IfIndex
NbrIfIndex
Dead Time
Remaining dead interval of the neighbor. If no hello packet is received from the neighbor after this interval, the neighbor state changes to Init.
Neighbor state:
·     Down—The neighbor does not start negotiation.
·     Init—The neighbor has started negotiation.
·     DB_Exchange—The neighbor has been discovered.
·     DB_Wait—The local switch has sent the LSR.
·     DB_Ack_Wait—The neighbor has sent the LSR.
·     Full—Synchronization is complete.
display fspf statistics
Use display fspf statistics to display FSPF statistics.
display fspf statistics [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the FSPF statistics for all VSANs. On an FCF-NPV switch, this command displays the FSPF statistics for only VSANs operating in FCF mode.
FSPF statistics contain global statistics and interface statistics.
·     Global statistics—Contain the current number of SPF calculations, number of error packets, total number of packets received and sent.
·     Interface statistics—Contain the total number of packets received and sent on each interface.
# Display FSPF statistics.
<Sysname> display fspf statistics
FSPF statistics of VSAN 1(01):
  SPF computing count: 6
  Statistics counters:
    Bad packet       : 0      Neighbor unknown   : 0
    Timer mismatch   : 0      Neighbor state low : 0
    Bad LSR          : 0
  Packet statistics:
    Type          Input        Output
    HELLO         50           50
    LSU           5            5
    LSA           4            4
  Interface Vfc1 statistics:
    Type          Input        Output
    HELLO         50           50
    LSU           5            5
    LSA           4            4
Table 34 Command output
FSPF statistics for a VSAN. The value in parentheses is the domain ID in decimal of the local switch.
SPF computing count
Number of SPF calculations.
Packet statistics on the interface.
Bad packet
Number of error packets.
Timer mismatch
Number of packets whose hello or dead interval does not match that of the neighbor.
Bad LSR
Number of error LSRs.
Neighbor unknown
Number of packets received from unknown neighbors.
Neighbor state low
Number of LSUs and LSAs received in Init state.
Packet type: Hello, LSU, or LSA.
Input
Number of packets received.
Output
Number of packets sent.
reset fspf counters
fc route-static
Use fc route-static to configure a static FC route.
Use undo fc route-static to delete a static FC route.
fc route-static fcid { mask | mask-length } interface-type interface-number [ cost cost-value ]
undo fc route-static fcid { mask | mask-length } interface-type interface-number
No static FC routes exist.
VSAN view
fcid: Specifies the destination FC address of the static FC route, in the range of 010000 to efffff (hexadecimal).
mask-length: Specifies the mask length of the FC address. This argument is used together with the fcid argument. The value of this argument can be 8, 16, or 24.
interface-type interface-number: Specifies the outgoing interface of the static FC route, which must be an existing FC interface, FC aggregate interface, or VFC interface on the FCF switch.
cost cost-value: Specifies the cost of the route, in the range of 0 to 65535. The default is 0.
Only FCF switches and VSANs operating in FCF mode support this command.
Static routes are manually configured by an administrator. After an administrator configures a static route, an FC frame to the specified destination is forwarded along the static route.
In a simple network, static routes are enough for implementing network connectivity. When the network fails or the network topology changes, you must manually modify the static routes.
Static routes support equal-cost routes. When you configure multiple equal-cost static routes to the same destination but with different outgoing interfaces, equal-cost routes are generated.
# Add a static FC route, whose destination FC address is 0x010000, mask is 8, outgoing interface is FC 1/0/1, and cost is 20.
[Sysname] vsan 5
[Sysname-vsan5] fc route-static 010000 8 fc 1/0/1 cost 20
# Add a static FC route, whose destination FC address is 0x010000, mask is 8, outgoing interface is VFC 1, and cost is 20.
[Sysname] vsan 5
[Sysname-vsan5] fc route-static 010000 8 vfc 1 cost 20
fspf cost
Use fspf cost to set the FSPF cost for an interface in a VSAN.
Use undo fspf cost to delete the FSPF cost setting of an interface in a VSAN.
fspf cost cost-value vsan vsan-id
undo fspf cost vsan vsan-id
The FSPF cost of an interface is calculated by using the formula 1.0e12/baud rate.
FC interface view
FC aggregate interface view
VFC interface view
cost-value: Specifies the FSPF cost in the range of 1 to 65535.
Each link has a cost. The route selection algorithm uses this value to determine the best route. The smaller the interface FSPF cost, the smaller the link cost.
# Set the FSPF cost to 1000 for FC 1/0/1 in VSAN 4.
[Sysname] interface fc 1/0/1
[Sysname-Fc1/0/1] fspf cost 1000 vsan 4
# Set the FSPF cost to 1000 for VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf cost 1000 vsan 4
fspf dead-interval
Use fspf dead-interval to set the dead interval for an interface in a VSAN.
Use undo fspf dead-interval to delete the dead interval setting of an interface in a VSAN.
fspf dead-interval interval vsan vsan-id
undo fspf dead-interval vsan vsan-id
The dead interval for an interface in a VSAN is 80 seconds.
FC interface view
VFC interface view
interval: Specifies the dead interval in the range of 2 to 65535 seconds.
After two switches establish a neighbor relationship, they send hello packets at the hello interval to each other to maintain the neighbor relationship. The dead interval specifies the time during which at least one hello packet must be received from a neighbor before the neighbor is considered nonexistent and is removed.
The dead interval must be greater than the hello interval and must be the same at the two ends of a link.
# Set the dead interval to 100 seconds for FC 1/0/1 in VSAN 4.
[Sysname-Fc1/0/1] fspf dead-interval 100 vsan 4
# Set the dead interval to 100 seconds for VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf dead-interval 100 vsan 4
fspf hello-interval
fspf enable
Use fspf enable to enable FSPF in a VSAN.
Use undo fspf enable to disable FSPF in a VSAN.
fspf enable
undo fspf enable
FSPF is enabled in a VSAN.
VSAN view
FSPF-related features work in a VSAN only after you enable FSPF in the VSAN.
# Enable FSPF in VSAN 4.
[Sysname] vsan 4
[Sysname-vsan4] fspf enable
Use fspf graceful-restart to enable FSPF GR.
Use undo fspf graceful-restart to disable FSPF GR.
FSPF GR is disabled.
FSPF Graceful Restart (GR) ensures nonstop forwarding of traffic by backing up FSPF configuration information in the following situations:
·     Protocol restart.
·     Active/standby switchover.
GR involves the following roles:
·     GR restarter—GR-capable device where a protocol restart or active/standby switchover occurs.
·     GR helper—The GR restarter's neighboring device that assists in the GR process.
# Enable FSPF GR.
[Sysname] fspf graceful-restart
Use fspf graceful-restart helper to enable FSPF GR helper.
Use undo fspf graceful-restart helper to disable FSPF GR helper.
FSPF GR helper is enabled.
The switch can assist the GR restarter in completing the GR process only after it is enabled with FSPF GR helper.
# Enable FSPF GR helper.
[Sysname] fspf graceful-restart helper
Use fspf graceful-restart interval to set the maximum FSPF GR interval.
Use undo fspf graceful-restart interval to restore the default.
fspf graceful-restart interval interval
The maximum FSPF GR interval is 120 seconds.
interval: Specifies the maximum FSPF GR interval in the range of 40 to 1800 seconds.
If the GR restarter fails to complete the GR process within the maximum FSPF GR interval, it immediately exits the GR process.
# Set the maximum FSPF GR interval to 100 seconds.
[Sysname] fspf graceful-restart interval 100
fspf hello-interval
Use fspf hello-interval to set the hello interval for an interface in a VSAN.
Use undo fspf hello-interval to delete the hello interval setting of an interface in a VSAN.
fspf hello-interval interval vsan vsan-id
undo fspf hello-interval vsan vsan-id
The hello interval for an interface in a VSAN is 20 seconds.
FC interface view
VFC interface view
interval: Specifies the hello interval in the range of 1 to 65534 seconds.
The hello interval specifies the time between the hello packets sent periodically by the switch to discover and maintain neighbor relationships.
The hello interval must be smaller than the dead interval and must be the same at the two ends of the link.
# Set the hello interval to 10 seconds for FC 1/0/1 in VSAN 4.
[Sysname-Fc1/0/1] fspf hello-interval 10 vsan 4
# Set the hello interval to 10 seconds for VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf hello-interval 10 vsan 4
fspf dead-interval
fspf min-ls-arrival
Use fspf min-ls-arrival to set the minimum LSR arrival interval for a VSAN.
Use undo fspf min-ls-arrival to restore the default.
fspf min-ls-arrival value
The minimum LSR arrival interval for a VSAN is 1 second.
VSAN view
value: Specifies the minimum LSR arrival interval in the range of 0 to 60 seconds.
The minimum LSR arrival interval specifies the interval between received LSR updates in a VSAN. Any LSR updates that arrive before this interval expires are dropped. This helps avoid frequent SPF calculations caused by LSDB updating.
# Set the minimum LSR arrival interval to 10 seconds for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fspf min-ls-arrival 10
fspf min-ls-interval
Use fspf min-ls-interval to set the minimum LSR refresh interval for a VSAN.
Use undo fspf min-ls-interval to restore the default.
fspf min-ls-interval interval
The minimum LSR refresh interval is 5 seconds for a VSAN.
VSAN view
interval: Specifies the minimum LSR refresh interval in the range of 1 to 60 seconds.
The minimum LSR refresh interval specifies the interval at which LSRs are refreshed. To reduce SPF calculations and LSR flooding in a fabric caused by frequent LSR refreshing, the switch will not refresh local LSRs within this interval.
# Set the minimum LSR refresh interval to 10 seconds for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fspf min-ls-interval 10
fspf retransmit-interval
Use fspf retransmit-interval to set the LSR retransmission interval for an interface in a VSAN.
Use undo fspf retransmit-interval to delete the LSR retransmission interval setting of an interface in a VSAN.
fspf retransmit-interval interval vsan vsan-id
undo fspf retransmit-interval vsan vsan-id
The LSR retransmission interval for an interface in a VSAN is 5 seconds.
FC interface view
VFC interface view
interval: Specifies the LSR retransmission interval in the range of 1 to 65535 seconds.
The LSR retransmission interval specifies the time to wait for an LSR acknowledgment from the neighbor before retransmitting the LSR.
# Set the LSR retransmission interval to 10 seconds for FC 1/0/1 in VSAN 4.
[Sysname-Fc1/0/1] fspf retransmit-interval 10 vsan 4
# Set the LSR retransmission interval to 10 seconds for VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf retransmit-interval 10 vsan 4
fspf silent
Use fspf silent to disable FSPF for an interface in a VSAN.
Use undo fspf silent to enable FSPF for an interface in a VSAN.
fspf silent vsan vsan-id
undo fspf silent vsan vsan-id
FSPF is enabled for all interfaces in a VSAN.
FC interface view
VFC interface view
With FSPF enabled, an interface can participate in the SPF calculation. To avoid SPF calculations on an interface, disable FSPF on the interface.
# Disable FSPF for FC 1/0/1 in VSAN 4.
[Sysname-Fc1/0/1] fspf silent vsan 4
# Disable FSPF for VFC 1 in VSAN 4.
[Sysname-Vfc1] fspf silent vsan 4
fspf spf-hold-time
Use fspf spf-hold-time to set the shortest SPF calculation interval for a VSAN.
Use undo fspf spf-hold-time to restore the default.
fspf spf-hold-time value
The shortest SPF calculation interval is 0 seconds in a VSAN.
VSAN view
value: Specifies the shortest SPF calculation interval in the range of 0 to 60 seconds.
When the LSDB changes, SPF calculations occur, which consume CPU resources. To prevent frequent SPF calculations from consuming too many CPU resources, you can set the shortest SPF calculation interval.
The shortest SPF calculation interval defines the minimum interval between two consecutive SPF calculations. Setting a small value means that FSPF responds quickly to fabric changes by recalculating routes in a VSAN. A small value consumes more CPU resources.
# Set the shortest SPF calculation interval to 10 seconds for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fspf spf-hold-time 10
reset fspf counters
Use reset fspf counters to clear FSPF statistics.
reset fspf counters [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command clears the FSPF statistics for all VSANs. On an FCF-NPV switch, this command clears the FSPF statistics for only VSANs operating in FCF mode.
# Clear FSPF statistics in VSAN 2.
<Sysname> reset fspf counters vsan 2
FC zone commands
delete zone database all
Use delete zone database all to delete zone database information.
VSAN view
This command deletes all zone sets, zones, and zone aliases in the zone database, but not the active zone set.
This command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
# Delete zone database information for VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] delete zone database all
This operation will delete all information of the zone database except active zone set. Continue? [Y/N]:y
display zone
Use display zone to display zone information.
display zone [ [ name zone-name ] vsan vsan-id ]
name zone-name: Specifies a zone by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
Table 35 Special symbols
Name
Symbol
Caret
Dollar sign
Minus sign
Underscore
_
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. On an FCF-NPV switch, this command displays the zone information for only VSANs operating in FCF mode.
If you specify both a zone and a VSAN, this command displays information about the specified zone in the specified VSAN.
If you specify only a VSAN, this command displays information about all zones in the specified VSAN.
If you do not specify a zone or a VSAN, this command displays information about all zones in all VSANs.
# Display information about all zones in all VSANs.
<Sysname> display zone
VSAN 1:
  zone name z1
    fcid 0x111111 initiator
    fcid 0x222222 target
    pwwn 11:11:11:11:22:22:22:22
    fwwn 02:0e:30:30:33:33:32:35
  zone name z2
    fcid 0x111111
    zone-alias name za1
    fcid 0x333333 initiator
Table 36 Command output
fcid
FC address of the zone member.
pwwn
pWWN of the zone member.
fwwn
fWWN of the zone member.
initiator
target
Role of a zone member. If no role is indicated, the member has both roles.
member (zone view)
zone clone
zone name
zone rename
display zone member
Use display zone member to display parent information for a zone member.
display zone member { fcid fcid | fwwn fwwn | pwwn pwwn | zone-alias zone-alias-name } [ vsan vsan-id ]
fcid fcid: Specifies a zone member by its FC address, in the format of xxxxxx, where x is a hexadecimal number.
fwwn fwwn: Specifies a zone member by its fWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
pwwn pwwn: Specifies a zone member by its pWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
zone-alias zone-alias-name: Specifies a zone alias name, a case-sensitive string of 1 to 64 characters. A zone alias name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays parent information for zone members in all VSANs. On an FCF-NPV switch, this command displays the parent information for zone members for only VSANs operating in FCF mode.
You can use this command to display parent information for a zone member specified by its FC address, pWWN, fWWN, or zone alias.
Parent information contains the following:
·     Zones and zone aliases to which the specified zone member belongs.
·     Zones to which the zone aliases belong.
·     VSANs to which the zones and zone aliases belong.
If a zone alias is not assigned to any zones, only the parent VSANs are displayed for the zone alias.
# Display parent information for zone member with FC address 010000 in VSAN 1.
<Sysname> display zone member fcid 010000 vsan 1
fcid 0x010000
  VSAN 1:
    zone z1
    zone z2
    zone z3
    zone-alias a1
      zone z2
      zone z3
# Display parent information for zone member with pWWN 11:22:33:44:55:66:77:88 in all VSANs.
<Sysname> display zone member pwwn 11:22:33:44:55:66:77:88
  VSAN 1:
    zone z1
    zone z2
    zone z3
    zone-alias a1
      zone z2
      zone z3
  VSAN 3:
    zone z1
# Display parent information for zone member with fWWN 12:22:33:44:55:66:77:88 in all VSANs.
<Sysname> display zone member fwwn 12:22:33:44:55:66:77:88
  VSAN 1:
    zone z1
    zone z2
    zone z3
    zone-alias a1
      zone z2
      zone z3
  VSAN 3:
    zone z1
# Display parent information for the zone alias za1 in VSAN 1.
<Sysname> display zone member zone-alias za1 vsan 1
zone-alias za1
  VSAN 1:
    zone z1
    zone z2
Table 37 Command output
fcid
FC address of the zone member for which parent information is displayed.
pwwn
pWWN of the zone member for which parent information is displayed.
fwwn
fWWN of the zone member for which parent information is displayed.
member (zone view)
member (zone alias view)
display zone statistics
Use display zone statistics to display zoning packet statistics.
display zone statistics [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays zoning packet statistics for all VSANs. On an FCF-NPV switch, this command displays the zoning packet statistics for only VSANs operating in FCF mode.
# Display zoning packet statistics in VSAN 2.
<Sysname> display zone statistics vsan 2
VSAN 2:
  Message type      Sent          Received
  Merge Request     19            23
  Merge Accept      17            18
  Merge Reject      6             1
  Change Request    144           18
  Change Accept     0             0
  Change Reject     0             0
Table 38 Command output
Merge Request
Number of Merge Request packets.
Merge Accept
Number of Merge Accept packets.
Merge Reject
Number of Merge Reject packets.
Change Request
Number of Distribution Request packets.
Change Accept
Number of Distribution Accept packets.
Change Reject
Number of Distribution Reject packets.
reset zone statistics
display zone status
Use display zone status to display the zoning configuration and status.
display zone status [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the zoning configuration and status for all VSANs. On an FCF-NPV switch, this command displays the zoning configuration and status for only VSANs operating in FCF mode.
The zoning configuration and status include the following:
·     Zoning mode.
·     Default zone policy.
·     Distribution and merge type (not displayed in enhanced zoning mode).
·     Zone database information (numbers of existing zone sets, zones, and zone aliases).
·     Zoning status.
# Display the zoning configuration and status in all VSANs.
<Sysname> display zone status
VSAN 1:
  Mode: basic
  Default zone: deny
  Distribute: active only
  Hard-zoning: enabled
  Full zoning database:
    Zonesets: 10, Zones: 20, Zone-aliases: 0
  Status: merging
VSAN 2:
  Mode: enhanced
  Default zone: permit
  Status: distributing
Table 39 Command output
Mode
Zoning mode: basic or enhanced.
Default zone
Default zone policy:
·     deny—Deny members in the default zone from accessing each other.
·     permit—Allow members in the default zone to access each other.
Distribute
Distribution and merge type:
·     active only—Incomplete distribution and merge.
·     full—Complete distribution and merge.
In enhanced zoning mode, zone distribution and merge are not affected by the distribution and merge type. The distribution and merge type is not displayed for the enhanced zoning mode.
Hard-zoning
Hard zoning status:
·     enabled—Hard zoning is in effect.
·     disabled (Administratively)—Hard zoning is not in effect because it is manually disabled.
·     disabled (No enough hardware resource)—Hard zoning is not in effect because hardware resources are insufficient.
Full Zoning Database
Zone database information, including the numbers of zone sets, zones, and zone aliases in a VSAN.
Status
Zoning status:
·     merging—A zone merge is in progress.
·     distributing—A zone distribution is in progress.
·     Free—Neither zone merge nor zone distribution is in progress.
In the merging or distributing state, zoning configuration is not allowed in the VSAN.
zone default-zone permit
zoneset distribute full
display zone-alias
Use display zone-alias to display zone alias information.
display zone-alias [ [ name zone-alias-name ] vsan vsan-id ]
name zone-alias-name: Specifies a zone alias by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. On an FCF-NPV switch, this command displays the zone alias information for only VSANs operating in FCF mode.
If you specify both a zone alias and a VSAN, this command displays information about the specified zone alias in the specified VSAN.
If you specify only a VSAN, this command displays information about all zone aliases in the specified VSAN.
If you do not specify a zone alias or a VSAN, this command displays information about all zone aliases in all VSANs.
# Display information about all zone aliases in all VSANs.
<Sysname> display zone-alias
VSAN 1:
  zone-alias name za1
  zone-alias name za2
    fcid 0x111111
    fwwn 12:11:11:11:22:22:22:22
VSAN 2:
  zone-alias name za1
Table 40 Command output
fcid
FC address of a zone member.
pwwn
pWWN of a zone member.
fwwn
fWWN of a zone member.
initiator
target
zone-alias clone
zone-alias name
zone-alias rename
display zoneset
Use display zoneset to display zone set information.
display zoneset [ [ name zoneset-name ] vsan vsan-id ]
name zoneset-name: Specifies a zone set by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
If you specify both a zone set and a VSAN, this command displays information about the specified zone set in the specified VSAN.
If you specify only a VSAN, this command displays information about all zone sets in the specified VSAN.
If you do not specify a zone set or a VSAN, this command displays information about all zone sets in all VSANs.
# Display information about all zone sets in all VSANs.
<Sysname> display zoneset
VSAN 1:
  zoneset name zs1
    zone name z1
      fcid 0x111111
      fcid 0x222222
    zone name z2
      fcid 0x111111
      zone-alias name za1
        fcid 0x111112
  zoneset name zs2
    zone name z1
VSAN 2:
VSAN 3:
  zoneset name zs1
    zone name z1
Table 41 Command output
fcid
pwwn
member (zone set view)
zoneset clone
zoneset name
zoneset rename
display zoneset active
Use display zoneset active to display information about the active zone set.
display zoneset active [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays information about active zone sets for all VSANs. On an FCF-NPV switch, this command displays information about active zone sets for only VSANs operating in FCF mode.
A VSAN can have only one active zone set.
The following rules apply to the command output:
·     Zone members are displayed in the order of FC address, pWWN, and fWWN. Zone members specified by the same identifier are displayed in ascending order of ASCII codes corresponding to the identifier values.
·     For a zone member that exists in the local name service database, this command prefixes an asterisk (*) to the related line.
¡     If a zone member is specified by its pWWN, the switch performs the following operations:
-     Queries the associated FC address of the zone member from the name service database and displays the FC address.
-     Appends the pWWN enclosed in brackets ([]) to the FC address.
¡     If a zone member is specified by its fWWN, the switch displays FC addresses of all N_Ports that log in through the F_Port. Each FC address is followed by the fWWN enclosed in brackets ([]).
·     For a zone member that does not exist in the local name service database, only the configuration content is displayed.
·     Zone members cannot be displayed by zone alias in the active zone set. If a zone in the activated zone set has members with a zone alias, the non-overlapping N_Port members in the zone alias are added to the zone.
·     If members of the default zone are allowed to access each other, this command displays valid members in the default zone by FC address. Valid members in the default zone are members that have registered with the name service database and are not part of the active zone set.
# Display information about the active zone sets in all VSANs.
<Sysname> display zoneset active
  VSAN 1:
    zoneset name zs1
      zone name z1
        *fcid 0x222222
        *fcid 0x111111 [pwwn 20:00:00:05:30:00:25:a3]
      zone name z2
        fcid 0x123456
        pwwn 20:00:00:05:30:00:25:a4
        *fcid 0x333333 [pwwn 38:00:00:11:22:00:01:01]
      zone name #default-zone#
        *fcid 0x20abcd
        *fcid 0xabcdef
      zone name pz1
        type: peer-zoning
        *fcid 0x0a000c [pwwn 22:00:06:18:3a:73:ba:73] [principal]
        *fcid 0x0b0001 [pwwn 21:00:03:41:ab:24:f3:00]
        *fcid 0x010000
        *fcid 0x690001 [fwwn 28:00:0e:28:3f:79:1a:20]
      zone name pz2
        type: peer-zoning
        *fcid 0x0a0001 [pwwn 22:00:06:18:3a:1f:00:29] [principal]
        *fcid 0x020012
  VSAN 2:
  VSAN 3:
    zoneset name zs1
      zone name z1
         fcid 0x123456
        *fcid 0x222221 [fwwn 02:0e:30:30:33:33:32:35]
        *fcid 0x222222 [fwwn 02:0e:30:30:33:33:32:35]
        *fcid 0x222223 [fwwn 02:0e:30:30:33:33:32:35]
        fwwn aa:bb:cc:dd:ee:ff:00:11
# Display information about the active zone set in VSAN 1.
<Sysname> display zoneset active vsan 1
  VSAN 1:
    zoneset name zs1
      zone name z1
        *fcid 0x222222
      zone name z2
        fcid 0x123456
      zone name #default_zone#
        *fcid 0x20abcd
        *fcid 0xabcdef
      zone name pz1
        type: peer-zoning
        *fcid 0x010000
      zone name pz2
        type: peer-zoning
        *fcid 0x020012
Table 42 Command output
type
Zoning type.
Only peer zones support this field. This field displays peer-zoning for peer zones.
principal
Principal member in a peer zone.
All other members are peer members.
*fcid
FC address of a zone member that exists in the local name service database.
fcid
FC address of a zone member that does not exist in the local name service database.
pwwn
fwwn
zoneset activate name
Use member to add a member to a zone alias.
Use undo member to delete a member from a zone alias.
member { fcid fcid | fwwn fwwn | pwwn pwwn } [ initiator | target ]
undo member { fcid fcid | fwwn fwwn | pwwn pwwn }
No members exist in a zone alias.
Zone alias view
fcid fcid: Specifies a member by its FC address, in the format of xxxxxx, where x is a hexadecimal number.
fwwn fwwn: Specifies a member F_Port by its fWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number. Adding an F_Port to a zone alias adds all N_Ports that log in through the F_Port to that zone alias.
pwwn pwwn: Specifies a member by its pWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
initiator: Specifies a member as an initiator. If you do not specify the initiator or target keyword, the member acts as both an initiator and a target.
target: Specifies a member as a target. If you do not specify the initiator or target keyword, the member acts as both an initiator and a target.
The role of a member can be configured only in enhanced zoning mode and takes effect only when the Pairwise feature is enabled.
You can also use this command to change the role of a member.
If the role of a member is specified by using the same identifier (FC address, pWWN, fWWN, or zone alias) multiple times, the role of the member is the role most recently specified.
If the role of a member is specified by using different identifiers multiple times, the role of the member is the union of the specified roles. For example, if a member is specified as an initiator by using its FC address and specified as a target by using its pWWN, the member acts as both an initiator and a target.
# Create a zone alias named za1 and enter its view.
[Sysname] vsan 1
[Sysname-vsan1] zone-alias name za1
[Sysname-vsan1-zone-alias-za1]
# Add an N_Port with FC address 010000 to zone alias za1 as an initiator.
[Sysname-vsan1-zone-alias-za1] member fcid 010000 initiator
# Add an N_Port with pWWN 01:02:03:04:05:06:07:08 to zone alias za1 as a target.
[Sysname-vsan1-zone-alias-za1] member pwwn 01:02:03:04:05:06:07:08 target
# Add an F_Port with fWWN 08:07:06:05:04:03:02:01 to zone alias za1 as both an initiator and a target.
[Sysname-vsan2-zone-alias-za1] member fwwn 08:07:06:05:04:03:02:01
display zone-alias
pairwise-zoning enable
zone-alias name
Use member to add a zone to a zone set.
Use undo member to remove a zone from a zone set.
member zone-name
undo member zone-name
No zones exist in a zone set.
Zone set view
zone-name: Specifies an existing zone by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
# Create a zone named z1.
[Sysname] vsan 1
[Sysname-vsan1] zone name z1
[Sysname-vsan1-zone-z1] quit
# Create a zone set named zs1 and enter its view.
[Sysname-vsan1] zoneset name zs1
[Sysname-vsan1-zoneset-zs1]
# Add zone z1 to zone set zs1.
[Sysname-vsan1-zoneset-zs1] member z1
display zoneset
zone name
zoneset name
member (zone view)
Use member to add a member to a zone.
Use undo member to delete a member from a zone.
member { { fcid fcid | fwwn fwwn | pwwn pwwn } [ initiator | target ] | zone-alias zone-alias-name }
undo member { fcid fcid | fwwn fwwn | pwwn pwwn | zone-alias zone-alias-name }
No members exist in a user-created zone.
Zone view
fwwn fwwn: Specifies a member F_Port by its fWWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number. Adding an F_Port to a zone adds all N_Ports that log in through the F_Port to that zone.
zone-alias zone-alias-name: Specifies an existing zone alias by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
You can also use this command to change the role (initiator, target, or both) of a member.
You cannot use the undo member command to delete the primary member of a peer zone.
As a best practice, add one server HBA and one storage HBA to a zone. If a zone has one server HBA and multiple storage HBAs, you must enable the Pairwise feature for the zone.
# Create a zone named z1 and enter its view.
[Sysname] vsan 1
# Add an N_Port with FC address 010000 to zone z1 as an initiator.
[Sysname-vsan1-zone-z1] member fcid 010000 initiator
# Add an N_Port with pWWN 01:02:03:04:05:06:07:08 to zone z1 as a target.
[Sysname-vsan1-zone-z1] member pwwn 01:02:03:04:05:06:07:08 target
# Change the role of N_Port with pWWN 01:02:03:04:05:06:07:08 back to both initiator and target.
# Add an F_Port with fWWN 08:07:06:05:04:03:02:01 to zone z1 as both an initiator and a target.
[Sysname-vsan2-zone-z1] member fwwn 08:07:06:05:04:03:02:01
# Add zone alias za1 (existing) to zone z1.
[Sysname-vsan1-zone-z1] member zone-alias za1
display zone
display zone member
zone name
zone-alias name
Use pairwise-zoning enable to enable the Pairwise feature for a zone.
Use undo pairwise-zoning enable to disable the Pairwise feature for a zone.
The Pairwise feature is disabled for a zone.
Zone view
This command can be configured only in enhanced zoning mode.
The Pairwise feature runs on a per-zone basis. For the Pairwise feature to take effect, you must reactivate the active zone set after enabling the Pairwise feature.
The following roles are defined for zone members:
·     Initiator—Typically a server.
·     Target—Typically a storage device.
You can specify the role of a member as an initiator, a target, or both when adding the member. A member can have different roles in different zones.
When the Pairwise feature is disabled for a zone, member roles do not take effect in that zone.
When the Pairwise feature is enabled for a zone:
·     An initiator member can access target members.
·     A target member can access initiator members.
·     A member acting as both an initiator and a target can access both target members and initiator members.
The Pairwise feature status is distributed to the entire fabric when you configure the zoneset activate or zoneset distribute command.
# Enable the Pairwise feature for zone z1.
[Sysname] vsan 2
[Sysname-vsan2] zone name z1
[Sysname-vsan2-zone-z1] pairwise-zoning enable
member (zone view)
zoneset activate
zoneset distribute
Use reset zone statistics to clear zoning packet statistics.
reset zone statistics [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command clears zoning packet statistics for all VSANs.
# Clear zoning packet statistics for VSAN 2.
<Sysname> reset zone statistics vsan 2
snmp-agent trap enable fc-zone
Use snmp-agent trap enable fc-zone to enable SNMP notifications for the zoning module.
Use undo snmp-agent trap enable fc-zone to disable SNMP notifications for the zoning module.
snmp-agent trap enable fc-zone [ activation-completed | defaultzone-change | hardzone-change | merge-failed | merge-succeeded ] *
undo snmp-agent trap enable fc-zone [ activation-completed | defaultzone-change | hardzone-change | merge-failed | merge-succeeded ] *
All SNMP notifications for the zoning module are disabled.
activation-completed: Specifies notifications about zone set activation or deactivation.
defaultzone-change: Specifies notifications about default zone policy changes.
hardzone-change: Specifies notifications about hard zoning status changes.
merge-failed: Specifies notifications about for merge failures.
merge-succeeded: Specifies notifications about for merge successes.
To report critical zoning events to an NMS, enable SNMP notifications for the zoning module. For zoning event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
If you do not specify a notification, this command enables all SNMP notifications for the zoning module.
# Enable all SNMP notifications for the zoning module.
[Sysname] snmp-agent trap enable fc-zone
zone clone
Use zone clone to copy a zone.
zone clone src-name dest-name
VSAN view
src-name: Specifies the name of the source zone to be copied, a case-sensitive string of 1 to 64 characters. A source zone name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
dest-name: Specifies the name of the destination zone, a case-sensitive string of 1 to 64 characters. A destination zone name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
[Sysname] vsan 1
# Create a zone named z2 by copying z1.
[Sysname-vsan1] zone clone z1 z2
display zone
zone name
Use zone default-zone permit to allow members in the default zone to access each other.
Use undo zone default-zone permit to restore the default.
Members in the default zone cannot access each other.
VSAN view
In enhanced zoning mode, the switch distributes the default zone policy with other zone data during a distribution process. In basic zoning mode, you must manually configure a consistent default zone policy across the fabric.
When the switch performs a zoning mode switchover, it also distributes the default zone policy with other zone data.
In enhanced zoning mode, a zone merge requires that the default zone policy is the same on all participating switches. Otherwise, the merge fails, and the links between the switches are isolated.
# Allow members in the default zone to access each other.
[Sysname] vsan 1
[Sysname-vsan1] zone default-zone permit
display zone status
zone mode enhanced
zoneset activate
zoneset distribute
zone hard-zoning enable
Use zone hard-zoning enable to enable hard zoning in a VSAN.
Use undo zone hard-zoning enable to disable hard zoning in a VSAN.
Hard zoning is enabled in a VSAN.
VSAN view
Soft zoning is always in effect. Hard zoning takes effect only when the hardware resources are sufficient for deploying zone rules of the current VSAN. When the hardware resources are insufficient, the system performs the following operations:
·     Clears all deployed hardware zone rules to keep the integrity of rules.
·     Automatically disables hard zoning.
To improve the security for a VSAN, you can enable hard zoning for the VSAN. After hard zoning is enabled for a VSAN, the system begins to deploy all zone rules of the VSAN.
When soft zoning can meet the access control requirements of a VSAN, you can disable hard zoning for the VSAN to save the hardware resources. After hard zoning is disabled for a VSAN, the system clears the hardware zone rules already deployed for the VSAN and stops deploying new zone rules.
In enhanced zoning mode, the switch distributes hard zoning status with other zone data. In basic zoning mode, you must manually configure hard zoning to ensure consistency across the fabric.
To view the hard zoning status, use the display zone status command.
Do not configure this command when the switch is merging or distributing zones.
# Disable hard zoning for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] undo zone hard-zoning enable
display zone status
zone merge-control restrict
Use zone merge-control restrict to set the merge control mode to Restrict.
Use undo zone merge-control restrict to restore the default.
The merge control mode is Allow.
VSAN view
This command is supported only in enhanced zoning mode.
Two merge control modes are available: Restrict and Allow. For more information about the Restrict and Allow merge control modes, see FC and FCoE Configuration Guide.
In enhanced zoning mode, the merge control mode affects the result of a merge operation. A merge operation can succeed only when the merge control mode is the same on both participating switches. If the merge operation fails, the link connecting the participating switches is isolated.
To ensure a consistent merge control mode across the fabric, use the zone activate or zone distribute command after you configure this command.
# Set the merge control mode to Restrict for VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] zone merge-control restrict
# Set the merge control mode to Allow for VSAN 2.
[Sysname-vsan2] undo zone merge-control restrict
zone mode enhanced
zoneset activate
zoneset distribute
zone mode enhanced
Use zone mode enhanced to enable the enhanced zoning mode in a VSAN.
Use undo zone mode enhanced to restore the default.
zone mode enhanced
The basic zoning mode is enabled in a VSAN.
VSAN view
A zoning mode switchover causes a zone distribution to ensure zoning mode consistency across the fabric. You can switch from basic zoning to enhanced zoning only if the following conditions are met:
·     All switches in the fabric support the enhanced zoning mode.
·     No invalid static routes exist in the fabric.
After enhanced zoning is enabled on a switch, the switch checks ESS negotiation results for enhanced zoning support on other switches.
The switch performs ESS negotiation with all switches that appear in its routing table as destinations, including unreachable destinations in invalid static routes. The switch assumes that unreachable destinations do not support enhanced zoning.
After you change the zoning mode, the switch distributes the change to the entire fabric. If the distribution fails, the system prints a log message, and the change takes effect only on the local switch. In this case, to ensure zoning mode consistency across the fabric, manually trigger a complete distribution.
For a switchover from enhanced zoning to basic zoning, if the size of the active zone set exceeds the system limit in basic zoning mode, the switchover fails.
# Enable the enhanced zoning mode in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] zone mode enhanced
The zoning database in this switch would be distributed throughout the fabric. Continue? [Y/N]:y
display zone status
zoneset distribute
zone name
Use zone name to create a zone and enter its view, or enter the view of an existing zone.
Use undo zone name to delete a zone.
zone name zone-name
undo zone name zone-name
No zones exist.
VSAN view
zone-name: Specifies a zone name, a case-sensitive string of 1 to 64 characters. A zone name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
[Sysname] vsan 1
display zone
zone rename
Use zone rename to rename a zone.
zone rename old-name new-name
VSAN view
old-name: Specifies the name of the zone to be renamed, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
new-name: Specifies the new zone name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
After renaming a peer zone on the switch, you must modify the peer zone name on nodes to the same name.
[Sysname] vsan 1
# Rename zone z1 as z2.
[Sysname-vsan1] zone rename z1 z2
The command will cause inconsistency of peer zone information between the switch and nodes. Continue? [Y/N]:y
display zone
zone name
zone-alias clone
Use zone-alias clone to copy a zone alias.
zone-alias clone src-name dest-name
VSAN view
src-name: Specifies the name of the source zone alias to be copied, a case-sensitive string of 1 to 64 characters. A source zone alias name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
dest-name: Specifies the name of the destination zone alias, a case-sensitive string of 1 to 64 characters. A destination zone alias name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
# Create a zone alias named za1.
[Sysname] vsan 1
[Sysname-vsan1-zone-alias-za1] quit
# Create a zone alias named za2 by copying zone alias za1.
[Sysname-vsan1] zone-alias clone za1 za2
display zone-alias
zone-alias name
zone-alias name
Use zone-alias name to create a zone alias and enter its view, or enter the view of an existing zone alias.
Use undo zone-alias name to delete a zone alias.
zone-alias name zone-alias-name
undo zone-alias name zone-alias-name
No zone aliases exist.
VSAN view
zone-alias-name: Specifies the zone alias name, a case-sensitive string of 1 to 64 characters. A zone alias name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
[Sysname] vsan 1
display zone-alias
zone-alias rename
Use zone-alias rename to rename a zone alias.
zone-alias rename old-name new-name
VSAN view
old-name: Specifies the name of the zone alias to be renamed, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
new-name: Specifies the new zone alias name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
[Sysname] vsan 1
# Rename zone alias za1 as za2.
[Sysname-vsan1] zone-alias rename za1 za2
display zone-alias
zone-alias name
zoneset activate
Use zoneset activate to activate a zone set and distribute it to the entire fabric.
Use undo zoneset activate to delete an active zone set and distribute the deletion to the entire fabric.
zoneset activate name zoneset-name
VSAN view
name zoneset-name: Specifies the zone set to be activated by its name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
Each VSAN can have multiple zone sets. However, only one zone set can be active at a time. It is called the active zone set. The active zone set must contain at least one N_Port member and determines access control over N_Ports.
The system prints a log message if the distribution fails because of a network fault. To ensure a consistent active zone set across the fabric, reactivate the zone set after the network fault is fixed.
The distribution type specified by using the zoneset distribute full command applies to distribution operations triggered by the zoneset activate command.
In basic zoning mode, if the size of the zone set to be activated exceeds the system limit, the activation fails.
[Sysname] vsan 1
# Add an N_Port with FC address 010000 to zone z1.
# Create a zone set named zs1.
[Sysname-vsan1-zoneset-zs1] quit
# Activate zone set zs1 and distribute it to the entire fabric.
[Sysname-vsan1] zoneset activate name zs1
zoneset clone
Use zoneset clone to create a zone set by copying an existing zone set.
zoneset clone src-name dest-name
VSAN view
src-name: Specifies the name of the source zone set to be copied, a case-sensitive string of 1 to 64 characters. A source zone set name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
dest-name: Specifies the name of the destination zone set, a case-sensitive string of 1 to 64 characters. A destination zone set name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
[Sysname] vsan 1
# Create a zone set named zs1 by copying zone set zs2.
[Sysname-vsan1] zoneset clone zs1 zs2
display zoneset
zoneset name
zoneset distribute
Use zoneset distribute to trigger a one-time complete distribution, distributing both the active zone set and zone database.
zoneset distribute
VSAN view
After activating a zone set by using the zoneset activate command, you can modify the zone database configuration. The zoneset distribute command distributes the active zone set and the modified zone database to the entire fabric without changing the active zone set.
If the distribution fails, the system prints a log message. To ensure zone data consistency across the fabric, perform a new distribution.
# Trigger a complete distribution.
[Sysname] vsan 1
[Sysname-vsan1] zoneset distribute
Use zoneset distribute full to set the zone distribution and merge type to complete.
Use undo zoneset distribute full to restore the default.
The zone distribution and merge type is incomplete.
VSAN view
This command can be configured only in basic zoning mode. In enhanced zoning mode, the zone distribution and merge type is always complete, and this command is not supported.
Complete distribution (or merge) distributes (or merges) both the active zone set and zone database. Incomplete distribution (or merge) distributes (or merges) only the active zone set.
The set distribution type applies to distribution operations triggered by the zoneset activate command instead of the zoneset distribute command.
The set merge type applies to all merge operations.
# Set the zone distribution and merge type to complete.
[Sysname] vsan 1
[Sysname-vsan1] zoneset distribute full
display zone status
zoneset activate
zoneset name
Use zoneset name to create a zone set and enter its view, or enter the view of an existing zone set.
Use undo zoneset name to delete a zone set.
zoneset name zoneset-name
undo zoneset name zoneset-name
No zone sets exist.
VSAN view
zoneset-name: Specifies the zone set name, a case-sensitive string of 1 to 64 characters. A zone set name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
[Sysname] vsan 1
display zoneset
zoneset rename
Use zoneset rename to rename a zone set.
zoneset rename old-name new-name
VSAN view
old-name: Specifies the name of the zone set to be renamed, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
new-name: Specifies the new zone set name, a case-sensitive string of 1 to 64 characters. This name can contain letters (uppercase and lowercase), numbers, and special symbols (see Table 35). It must start with a letter.
[Sysname] vsan 1
# Rename zone set zs1 as zs2.
[Sysname-vsan1] zoneset rename zs1 zs2
display zoneset
zoneset name
zone-type peer-zone
Use zone-type peer-zone to convert a common zone to a peer zone and specify the principal member for the peer zone.
Use undo zone-type peer-zone to restore the default.
zone-type peer-zone principal-member wwn
A zone is a common zone.
Zone view
wwn: Specifies the principal member by its WWN, in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number. The principal member must be a port on a node.
Before configuring this command, you must first enable Smart SAN for FC/FCoE.
A zone enabled with the Pairwise feature cannot be converted to a peer zone.
This command sets the principal member to a target.
This command deletes the settings for the common zone.
# Convert a common zone named z1 to a peer zone and specify the port with WWN 20:00:10:00:00:ef:94:00 as the principal member for the peer zone.
[Sysname] vsan 2
[Sysname-vsan2-zone-z1] zone-type peer-zone principal-member 20:00:10:00:00:ef:94:00
# Convert a peer zone named z1 to a common zone.
[Sysname] vsan 2
[Sysname-vsan2-zone-z1] undo zone-type peer-zone
zone name
member (zone view)
smartsan enable
NPV commands
display fc nport
Use display fc nport to display the login information of interfaces.
display fc nport [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. The interface must be an FC interface, FC aggregate interface, or VFC interface operating in NP mode. If you do not specify an interface, this command displays the login information of all interfaces.
Only NPV and FCF-NPV switches support this command.
This command displays the login information sent by interfaces operating in NP mode to the FCF switch and management addresses obtained from the FCF switch.
This command displays the information only if the NPV switch successfully registers with the FCF switch.
# Display the login information of interfaces.
<Sysname> display fc nport
NP port: Vfc1
  Port-WWN: 20:00:00:41:22:a8:00:05
  FC4-types(FC4_features): NPV
  Symbolic-node-name: NPV-Sysname
  Symbolic-port-name: NPV-Sysname: Vfc1
  Node-IP-addr: 192.168.0.153
  Peer management address: snmp://192.168.0.151
                           snmp://192.168.0.152
NP port: Vfc2
  Port-WWN: 20:00:00:49:c9:28:c7:01
  Symbolic-port-name: NPV-Sysname:Vfc2
Table 43 Command output
FC4-types(FC4 features)
An interface operating in NP mode always registers NPV as its FC4 type and has no FC4 feature.
Symbolic-node-name
Symbolic name in the form of system-name, which is used for describing the N_Port connected to the interface.
Symbolic-port-name
Symbolic name in the form of system-name:port-name, which is used for describing the interface.
Node-IP-addr
IP address of the NPV switch.
List of management addresses obtained by the interface from the FCF switch.
For example, snmp://192.168.6.151 indicates that SNMP is used as the management protocol and the management address is 192.168.6.151.
If nothing is displayed, the FCF switch is not configured with management addresses.
display npv login
Use display npv login to display the nodes on downlink interfaces and their mapped uplink interfaces.
display npv login [ vsan vsan-id ] [ interface interface-type interface-number ]
display npv login [ vsan vsan-id ] count
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays information for all VSANs. On an FCF-NPV switch, this command displays the node login information for only VSANs operating in NPV mode.
interface interface-type interface-number: Specifies a downlink interface by its type and number. If you do not specify a downlink interface, this command displays information for all downlink interfaces.
count: Displays the total number of logged-in nodes.
# Display the nodes on downlink interfaces and their mapped uplink interfaces.
<Sysname> display npv login
Server        External
Interface VSAN FCID     Node WWN                Port WWN                Interface
Vfc2      1    0xae0002 20:00:00:23:89:c9:fc:02 20:00:00:23:89:c9:fc:02 Vfc1
Vfc3      1    0xae0003 10:00:00:00:c9:66:6b:60 20:00:00:00:c9:66:6b:60 Vfc1
# Display the number of logged-in nodes for VSAN 1.
<Sysname> display npv login vsan 1 count
Total entries: 2
# Display the number of logged-in nodes for each VSAN and the total number of logged-in nodes.
<Sysname> display npv login count
VSAN        Entries
1           2
2           1
Total entries: 3
Table 44 Command output
Server Interface
Name of the downlink interface.
External interface
Name of the uplink interface mapped by the downlink interface.
FCID
FC address of the node.
Port WWN
Port WWN of the node.
Entries
Number of logged-in nodes for a VSAN.
Total entries
Total number of logged-in nodes.
display npv status
Use display npv status to display the status information of interfaces in VSANs.
display npv status [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the status information of interfaces in all VSANs. On an FCF-NPV switch, this command displays the status information of interfaces in only VSANs operating in NPV mode.
The status information of each interface includes the VSAN tagging mode, interface state, and FC address.
# Display the status information of interfaces in VSAN 1.
<Sysname> display npv status vsan 1
External Interfaces:
  Interface: Vfc2  VSAN tagging mode: Tagging
    VSAN  State  FCID
    1     Up     0x010002
  Interface: Vfc3  VSAN tagging mode: Tagging
    VSAN  State  FCID
    1     Up     0x010001
  Number of External Interfaces: 2
Server Interfaces:
    VSAN  State
    1     Down
  Number of Server Interfaces: 1
# Display the status information of interfaces in all VSANs.
  Interface: Vfc1  VSAN tagging mode: Tagging
    VSAN  State  FCID
    2     Up     0x010003
    VSAN  State  FCID
    1     Up     0x010002
    2     Up     0x010003(Unavailable)
    2     Down
    VSAN  State  FCID
    1     Up     0x010001
  Number of External Interfaces: 3
Server Interfaces:
  Interface: Vfc4  VSAN tagging mode: Tagging
    VSAN  State
    2     Up
    VSAN  State
    1     Down
    2     Up
    3     Down
  Number of Server Interfaces: 2
Table 45 Command output
External Interfaces
List of uplink interfaces.
Server Interfaces
List of downlink interfaces.
Interface name.
State of the interface: Up or Down.
FCID
After an uplink interface comes up, the FC address allocated by the core switch is displayed. A downlink interface does not have an FC address.
One uplink interface can be up but it cannot work as an uplink interface when the following conditions exist:
·     An NPV switch is connected to two fabrics.
·     The two uplink interfaces of the NPV switch are assigned the same FC address in a VSAN.
In this case, Unavailable in parentheses is displayed after the FCID field.
Multiple fabrics can exist in an FC SAN. For example, in an FC SAN, if two FCF switches are not interconnected, each FCF switch forms a fabric.
display npv traffic-map
Use display npv traffic-map to display the traffic mapping information (downlink-to-uplink interface mappings).
display npv traffic-map [ vsan vsan-id ] [ interface interface-type interface-number ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the traffic mapping information for all VSANs. On an FCF-NPV switch, this command displays the traffic mapping information for only VSANs operating in NPV mode.
interface interface-type interface-number: Specifies a downlink interface by its type and number. If you do not specify a downlink interface, this command displays the traffic mapping information of all downlink interfaces.
# Display traffic mapping information.
<Sysname> display npv traffic-map
NPV traffic map information of VSAN 1:
Server interface       External interface
Vfc2                   Vfc1
Vfc3                   Vfc1
Vfc2                   Vfc4
npv auto-load-balance enable
Use npv auto-load-balance enable to enable automatic load balancing in a VSAN.
Use undo npv auto-load-balance enable to disable automatic load balancing in a VSAN.
Automatic load balancing is disabled in a VSAN.
VSAN view
Only NPV switches and VSANs operating in NPV mode support this command.
The automatic load-balancing process is as follows:
1.     The system starts a delay timer when it detects a new operational uplink interface.
2.     The system automatically redistributes downlink interfaces across all uplink interfaces when the timer expires.
If another uplink interface becomes operational before the timer expires, the system resets the timer.
The automatic load balancing feature might trigger a load-balancing process when a new uplink interface becomes operational, which causes traffic disruption. When this feature is disabled, downlink-to-uplink interface mappings are not affected.
# Enable automatic load balancing in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] npv auto-load-balance enable
npv auto-load-balance-interval
Use npv auto-load-balance-interval to set the delay timer for automatic load balancing in a VSAN.
Use undo npv auto-load-balance-interval to restore the default.
npv auto-load-balance-interval interval
The delay timer is 30 seconds for automatic load balancing in a VSAN.
VSAN view
interval: Specifies a value for the delay timer, in the range of 1 to 300 seconds.
The delay timer helps reduce network flapping caused by up/down events of uplink interfaces. If the link layer state of uplink interfaces is stable, set the delay timer to a smaller value. Otherwise, set the delay timer to a greater value.
# Set the delay timer for automatic load balancing to 20 seconds in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] npv auto-load-balance-interval 20
npv load-balance disruptive
Use npv load-balance disruptive to manually initiate a disruptive load-balancing process in a VSAN.
VSAN view
If the traffic load is not distributed evenly across the interfaces in a VSAN, you can use this command to manually initiate a disruptive load-balancing process. Then, some of the downlink interfaces mapped to the uplink interfaces that exceed the average uplink interface load are redistributed, and the nodes connected to the redistributed downlink interfaces log in again to the core switch. The average uplink interface load is calculated by using the following formula: total number of downlink interfaces/ total number of uplink interfaces. If the average uplink interface load is not an integer, it is rounded down to the nearest integer.
This feature redistributes downlink traffic across uplink interfaces for better load balancing. However, it causes traffic interruption on the nodes connected to all downlink interfaces.
# Manually initiate a disruptive load-balancing process in VSAN 1.
[Sysname] vsan 1
[Sysname-vsan1] npv load-balance disruptive
The command may cause traffic interruption. Continue? [Y/N]:y
npv traffic-map
Use npv traffic-map to configure an uplink-to-downlink interface mapping.
Use undo npv traffic-map to delete an uplink-to-downlink interface mapping.
npv traffic-map server-interface interface-type interface-number external-interface interface-type interface-number
undo npv traffic-map server-interface interface-type interface-number external-interface interface-type interface-number
No uplink-to-downlink interface mappings exist.
VSAN view
server-interface interface-type interface-number: Specifies a downlink interface by its type and number, which can only be an FC interface, FC aggregate interface, or VFC interface.
external-interface interface-type interface-number: Specifies an uplink interface by its type and number, which can only be an FC interface, FC aggregate interface, or VFC interface.
A downlink interface selects an uplink interface to map as follows:
·     When uplink-to-downlink interface mappings are configured for the downlink interface, the downlink interface can select an uplink interface from only the configured mappings.
·     When no uplink-to-downlink interface mapping is configured for the downlink interface, the downlink interface can select an uplink interface from all uplink interfaces in the same VSAN.
# Configure a mapping between FC 1/0/1 (downlink interface) and FC 1/0/2 (uplink interface).
[Sysname] vsan 10
[Sysname-vsan10] npv traffic-map server-interface fc 1/0/1 external-interface fc 1/0/2
# Configure a mapping between VFC 1 (downlink interface) and VFC 2 (uplink interface).
[Sysname] vsan 10
[Sysname-vsan10] npv traffic-map server-interface vfc 1 external-interface vfc 2
FIP snooping commands
The commands in this section are supported only on Transit switches.
display fip-snooping enode
Use display fip-snooping enode to display ENode information obtained by the Transit switch.
display fip-snooping enode [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays ENode information for all VLANs.
# Display ENode information obtained by the Transit switch.
<Sysname> display fip-snooping enode
VLAN 2:
Interface   ENode WWN                ENode MAC
XGE1/0/1    21:01:00:1b:32:a0:fa:18  000c-2999-eacd
Table 46 Command output
Ethernet interface connecting the Transit switch to the ENode.
ENode MAC
FCoE MAC address of the ENode.
display fip-snooping fcf
Use display fip-snooping fcf to display FCF switch information obtained by the Transit switch.
display fip-snooping fcf [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays FCF switch information for all VLANs.
# Display FCF switch information obtained by the Transit switch.
<Sysname> display fip-snooping fcf
VLAN 3:
Interface   FCF MAC        FCF WWN                 Fabric Name             ENode
XGE1/0/1    000c-2999-eacd 66:66:66:63:66:64:61:30 41:6e:64:69:61:6d:6f:21 1
XGE1/0/2    000c-2999-eaad 66:66:66:63:66:64:61:31 41:6e:64:69:61:6d:6f:22 2
Table 47 Command output
Ethernet interface connecting the Transit switch to the FCF switch.
FCF MAC
FCoE MAC address of the FCF switch.
ENode
Number of ENodes attached to an FCF switch.
display fip-snooping flushing-rules
Use display fip-snooping flushing-rules to display the FIP snooping rules that are being flushed.
display fip-snooping flushing-rules [ enode | fcf ] [ vlan vlan-id ]
enode: Specifies ENode FIP snooping rules.
fcf: Specifies FCF FIP snooping rules.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays the FIP snooping rules that are being flushed in all VLANs.
Only the FIP snooping rules that have been flushed can filter FCoE frames. FIP snooping rules that are being flushed cannot filter FCoE frames.
If you do not specify enode or fcf, this command displays both ENode and FCF FIP snooping rules that are being flushed.
# Display the FIP snooping rules that are being flushed.
<Sysname> display fip-snooping flushing-rules
VLAN 2:
  FCF flushing-rules information:
    Interface   Source MAC/Mask      Destination MAC/Mask
    XGE1/0/1    0000-1234-0212/48    0efc-0034-0111/24
  ENode flushing-rules information:
    XGE1/0/2    0efc-0034-0202/48    0000-1234-0101/48
VLAN 5:
    XGE1/0/3    0000-1234-2212/48    0efc-0034-2111/24
Table 48 Command output
Ethernet interface on the Transit switch.
display fip-snooping rules
Use display fip-snooping rules to display the flushed FIP snooping rules.
display fip-snooping rules [ enode | fcf ] [ vlan vlan-id ] [ slot slot-number ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays the flushed FIP snooping rules in all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the flushed FIP snooping rules for all member devices.
Only the flushed FIP snooping rules can filter FCoE frames. FIP snooping rules that are being flushed cannot filter FCoE frames.
If you do not specify the enode or fcf keyword, this command displays both ENode and FCF FIP snooping rules that have been flushed.
# Display all flushed FIP snooping rules for slot 1.
<Sysname> display fip-snooping rules slot 1
Slot 1:
  VLAN 2:
    FCF rules information:
      Interface   Source MAC/Mask     Destination MAC/Mask   Context
      XGE1/0/1    0000-1234-0202/48   0efc-0034-0101/24      ffffffff
    ENode rules information:
      XGE1/0/2    0efc-0034-0102/48   0000-1234-0201/48      ffffffff
  VLAN 4:
      XGE1/0/3    0000-1234-1202/48   0efc-0034-1101/24      ffffffff
Table 49 Command output
display fip-snooping sessions
Use display fip-snooping sessions to display information about FIP snooping sessions (connections between ENodes and FCF switches).
display fip-snooping sessions [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays information about FIP snooping sessions for all VLANs.
# Display information about FIP snooping sessions.
<Sysname> display fip-snooping sessions
VLAN 2:
FCF MAC         ENode MAC       VN_Port MAC     VN_Port WWN
0000-1234-0202  0000-1234-0100  0efc-00ae-0002  41:6e:64:69:61:6d:6f:21
Table 50 Command output
FCF MAC
ENode MAC
VN_Port MAC
MAC address of a VN_Port.
fip-snooping enable
Use fip-snooping enable to enable FIP snooping in a VLAN.
Use undo fip-snooping enable to disable FIP snooping in a VLAN.
fip-snooping enable
FIP snooping is disabled in a VLAN.
VLAN view
This command enables a VLAN on a Transit switch to process FCoE frames and FIP frames.
# Enable FIP snooping for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] fip-snooping enable
fip-snooping fc-map
Use fip-snooping fc-map to set an FC-MAP value for a VLAN.
Use undo fip-snooping fc-map to restore the default.
fip-snooping fc-map fc-map
The FC-MAP value for a VLAN is 0x0efc00.
VLAN view
fc-map: Specifies an FC-MAP value in the range of 0efc00 to 0efcff.
When an Ethernet interface in the FIP snooping VLAN receives a frame from the FCF switch, the following rules apply:
·     If the FC-MAP value in the incoming frame is the same as the value set for the FIP snooping VLAN, the Ethernet interface forwards the frame.
·     If the FC-MAP value in the incoming frame is different from the value set for the FIP snooping VLAN, the Ethernet interface drops the frame.
To set the FC-MAP value in frames sent out of an FCF switch, use the fcoe fcmap command.
# Set the FC-MAP value to 0x0efcff for VLAN 10.
[Sysname] vlan 10
[Sysname-vlan 10] fip-snooping fc-map 0efcff
Changing the FC-MAP will flap all interfaces. Continue? [Y/N]:y
fcoe fcmap
fip-snooping port-mode
Use fip-snooping port-mode to set the mode of an Ethernet interface.
Use undo fip-snooping port-mode to restore the default.
fip-snooping port-mode { enode | fcf }
An Ethernet interface operates in ENode mode.
enode: Specifies the ENode mode.
fcf: Specifies the FCF mode.
This command does not take effect on member ports of a Layer 2 aggregate interface.
Ethernet interfaces on a Transit switch can operate in ENode mode or FCF mode.
·     An Ethernet interface connected to an ENode must be configured to operate in ENode mode.
·     An Ethernet interface connected to an FCF switch must be configured to operate in FCF mode.
# Configure Ten-GigabitEthernet 1/0/2 to operate in FCF mode.
[Sysname-Ten-GigabitEthernet1/0/2] fip-snooping port-mode fcf
Port security commands
any-wwn
Use any-wwn to allow any WWN to log in through the specified interfaces.
Use undo any-wwn to delete the configuration.
any-wwn interface interface-list
undo any-wwn interface interface-list
WWNs are not allowed to log in through an interface.
VSAN view
interface interface-list: Specifies a space-separated list of up to 10 interface items. Each item specifies an interface or a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for interface-number2 must be greater than or equal to the value for interface-number1. The two interfaces that define an interface range must be the same type and on the same card. The interface type can only be FC interface (cannot be a member port of an FC aggregate interface), FC aggregate interface, or VFC interface.
Only FCF switches and VSANs operating in FCF mode support this command.
Enable port security before configuring this command.
After you add (or delete) a binding entry to (or from) the port security database, the switch performs authorization checks on devices already logged in. If a device on an interface specified in the binding entry passes authorization checks, the device is not logged out. Otherwise, the device is logged out.
# Allow any WWN to log in through FC 1/0/1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] any-wwn interface fc 1/0/1
# Allow any WWN to log in through VFC 1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] any-wwn interface vfc 1
display fc-port-security database
Use display fc-port-security database to display binding entries in the port security database.
display fc-port-security database { all | auto-learn | smartsan-learn | smartsan-static | static } [ interface interface-type interface-number ] [ vsan vsan-id ]
all: Specifies all binding entries, including static entries, learned entries, learning entries, Smart SAN learning entries, and Smart SAN static entries.
auto-learn: Specifies learned and learning entries.
smartsan-learn: Specifies Smart SAN learning entries.
smartsan-static: Specifies Smart SAN static entries.
static: Specifies static entries.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays binding entries for all interfaces.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays binding entries for all VSANs. On an FCF-NPV switch, this command displays the binding entries for only VSANs operating in FCF mode.
Only FCF and FCF-NPV switches support this command.
# Display all binding entries in the port security database for VSAN 2.
<Sysname> display fc-port-security database all vsan 2
Total entries: 9
Database for VSAN 2:
  Logging-in entity                Interface              Type
  Any WWN                          Vfc3                   Static
  20:33:44:78:66:77:ab:97(pWWN)    Any interface          Static
  20:36:44:78:66:77:ab:97(pWWN)    Vfc2                   Static
  20:36:44:78:66:77:ab:9e(pWWN)    Vfc2                   Learned
  20:86:44:65:90:2a:ab:36(pWWN)    Vfc2                   SmartSAN-Static
  20:86:44:62:90:2a:ab:3a(pWWN)    Vfc1                   Learning
  20:86:44:65:90:2a:ab:3c(pWWN)    Vfc6                   SmartSAN-Learning
  10:83:42:78:66:77:ab:93(nWWN)    Vfc3                   Static
  10:36:44:78:66:77:ab:96(sWWN)    Vfc4                   Static
Table 51 Command output
Logging-in entity
WWN of the device permitted by an entry. The WWN type is displayed in the parenthesis and can be one of the following:
·     pWWNWWN of an N_Port or NP_Port.
·     sWWNWWN of an FCF switch.
·     nWWNWWN of a node or an NPV switch.
Any WWN indicates a WWN of any device.
Interface through which a device logs in.
Any Interface indicates the device can log in through any interface.
Entry type:
·     Static—Manually configured entries.
·     Learned—Entries converted from existing learning entries when auto learning is disabled. A learned entry is not deleted when the corresponding device logs out.
·     Learning—Entries automatically learned by the auto learning feature. A learning entry is deleted when the corresponding device logs out.
·     SmartSAN-Learning—Entries automatically learned by the Smart SAN auto learning feature for Smart SAN-capable nodes whose Smart SAN Security Support field is not 0x00. A Smart SAN learning entry is deleted when the corresponding device logs out.
·     SmartSAN-Static—Entries manually configured for Smart SAN-capable nodes whose Smart SAN Security Support field is not 0x00. A Smart SAN static entry is not deleted when the corresponding device logs out. Smart SAN learning entries are converted to Smart SAN static entries when Smart SAN auto learning is disabled.
reset fc-port-security database
display fc-port-security statistics
Use display fc-port-security statistics to display port security statistics.
display fc-port-security statistics [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays port security statistics for all VSANs. On an FCF-NPV switch, this command displays the port security statistics for only VSANs operating in FCF mode.
# Display port security statistics for VSAN 2.
<Sysname> display fc-port-security statistics vsan 2
Statistics for VSAN 2:
  Number of permitted pWWN logins: 2
  Number of permitted nWWN logins: 2
  Number of permitted sWWN logins: 2
  Number of denied pWWN logins   : 0
  Number of denied nWWN logins   : 0
  Number of denied sWWN logins   : 0
  Total logins permitted  : 6
  Total logins denied     : 0
reset fc-port-security statistics
display fc-port-security status
Use display fc-port-security status to display the port security status.
display fc-port-security status [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the port security status in all VSANs. On an FCF-NPV switch, this command displays the port security status in only VSANs operating in FCF mode.
This command also displays the configuration of the fc-port-security command.
# Display the port security status in all VSANs.
<Sysname> display fc-port-security status
Status for VSAN 1:
  FC port security: Disabled
  Auto learn: Disabled
  SmartSAN auto learn: Disabled
Status for VSAN 2:
  FC port security: Enabled
  Auto learn: Enabled
  SmartSAN auto learn: Enabled
Table 52 Command output
FC port security
Status of port security:
·     Enabled.
·     Disabled.
Auto learn
Status of auto learning:
·     Enabled.
·     Disabled.
SmartSAN auto learn
Status of auto learning for Smart SAN-capable nodes whose Smart SAN Security Support field is not 0x00:
·     Enabled.
·     Disabled.
fc-port-security
fc-port-security enable
display fc-port-security violation
Use display fc-port-security violation to display security violation entries.
display fc-port-security violation [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays security violation entries for all VSANs. On an FCF-NPV switch, this command displays the security violation entries for only VSANs operating in FCF mode.
# Display security violation entries for VSAN 2.
<Sysname> display fc-port-security violation vsan 2
Total entries: 3
Violations for VSAN 2:
  Interface   Logging-in entity               Last time             Repeat count
  Vfc1        20:36:44:78:66:77:ab:97(pWWN)   2013/10/30 12:29:23   2
              20:00:00:e0:8b:06:d9:1d(nWWN)
  Vfc2        20:42:78:66:77:ab:98:12(pWWN)   2013/10/29 17:29:23   3
  Vfc3        10:36:44:78:66:77:ab:96(sWWN)   2013/10/28 11:30:23   12
Table 53 Command output
Interface through which a violating device attempted to log in.
Logging-in entity
WWN of a violating device. The WWN type is displayed in the parenthesis and can be one of the following:
Last time
Time when a violating device last attempted to log in.
Repeat count
Number of times that a violating device attempted to log in.
fc-port-security
Use fc-port-security to enable auto learning or Smart SAN auto learning in a VSAN.
Use undo fc-port-security to disable auto learning or Smart SAN auto learning in a VSAN.
fc-port-security { auto-learn | smartsan-learn }
undo fc-port-security { auto-learn | smartsan-learn }
Auto learning and Smart SAN auto learning are disabled in a VSAN.
VSAN view
auto-learn: Enables auto learning for nodes and switches.
smartsan-learn: Enables Smart SAN auto learning for Smart SAN-capable nodes whose Smart SAN Security Support field is not 0x00.
You can enable auto learning only after you enable port security. You can specify the smartsan-learn keyword only after you enable Smart SAN for FC/FCoE.
After you enable auto learning, all devices that are newly logged in are added to the port security database as learning entries. A learning entry does not affect device login and is deleted when the corresponding device logs out. When you disable auto learning, learning entries are converted to learned entries. A learned entry affects device login and is not deleted when the corresponding device logs out.
After you enable Smart SAN auto learning, the switch performs the following operations:
·     Learns binding entries for newly logged in nodes that are Smart SAN-capable and whose Smart SAN Security Support field is not 0x00.
·     Adds the entries to the port security database as Smart SAN learning entries.
A Smart SAN learning entry does not affect device login and is deleted when the corresponding device logs out. When you disable Smart SAN auto learning, Smart SAN learning entries are converted to Smart SAN static entries. A Smart SAN static entry affects device login and is not deleted when the corresponding device logs out.
# Enable auto learning in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fc-port-security enable
[Sysname-vsan2] fc-port-security auto-learn
# Disable auto learning in VSAN 2 to convert learning entries to learned entries.
[Sysname-vsan2] undo fc-port-security auto-learn
fc-port-security database copy
Use fc-port-security database copy to convert learned entries to static entries in a VSAN.
VSAN view
Learned entries do not survive a reboot. To make learned entries survive reboots, convert the learned entries to static entries.
# Convert learned entries to static entries in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fc-port-security database copy
Use fc-port-security enable to enable port security and auto learning or Smart SAN auto learning in a VSAN.
Use undo fc-port-security enable to disable port security in a VSAN.
fc-port-security enable [ all | auto-learn | smartsan-learn ]
Port security, auto learning, and Smart SAN auto learning are disabled in a VSAN.
VSAN view
all: Enables both auto learning and Smart SAN auto learning.
auto-learn: Enables auto learning.
smartsan-learn: Enables Smart SAN auto learning.
You can configure other port security settings only after you enable port security.
You can specify the all or smartsan-learn keyword only after you enable Smart SAN for FC/FCoE.
If you enable auto learning while enabling port security, the switch learns binding entries for both devices already logged in and devices newly logged in. If you enable port security without enabling auto learning, the switch logs out devices already logged in.
When you enable port security, you can also enable Smart SAN auto learning. Smart SAN auto learning  takes effect only when Smart SAN is enabled. If you enable Smart SAN auto learning when enabling port security, the switch performs the following operations:
·     Learns binding entries for both already logged in and newly logged in nodes that are Smart SAN-capable and whose Smart SAN Security Support field is not 0x00.
If you do not enable auto learning or Smart SAN auto learning, devices already logged in are logged out.
If you do not enable auto learning but enable Smart SAN auto learning, the switch adds Smart SAN learning entries for only Smart SAN-capable nodes whose Smart SAN Security Support field is not 0x00. Smart SAN-incapable nodes and switches are logged out.
# Enable port security and auto learning in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] fc-port-security enable auto-learn
nwwn
Use nwwn to allow an nWWN to log in through the specified interfaces.
Use undo nwwn to delete the configuration.
nwwn nwwn [ interface interface-list ]
undo nwwn nwwn [ interface interface-list ]
An nWWN is not allowed to log in through the specified interfaces.
VSAN view
nwwn: Specifies the nWWN (WWN of a node or an NPV switch) in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
interface interface-list: Specifies a space-separated list of up to 10 interface items. Each item specifies an interface or a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for interface-number2 must be greater than or equal to the value for interface-number1. The two interfaces that define an interface range must be the same type and on the same card. The interface type can only be FC interface (cannot be a member port of an FC aggregate interface), FC aggregate interface, or VFC interface. If you do not specify the interface interface-list option, the specified nWWN can log in through any interface.
After you add (or delete) a binding entry to (or from) the port security database, the switch performs authorization checks on devices already logged in. If the device specified in the binding entry or a device on a specified interface passes authorization checks, the device is not logged out. Otherwise, the device is logged out.
# Allow nWWN 20:36:44:78:66:77:ab:9e to log in through FC 1/0/1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] nwwn 20:36:44:78:66:77:ab:9e interface fc 1/0/1
# Allow nWWN 20:36:44:78:66:77:ab:9e to log in through VFC 1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] nwwn 20:36:44:78:66:77:ab:9e interface vfc 1
pwwn
Use pwwn to allow a pWWN to log in through the specified interfaces.
Use undo pwwn to delete the configuration.
pwwn pwwn [ interface interface-list ] [ smartsan-static ]
undo pwwn pwwn [ interface interface-list ] [ smartsan-static ]
A pWWN is not allowed to log in through the specified interfaces.
VSAN view
nwwn: Specifies the pWWN (WWN of an N_Port or NP_Port) in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
interface interface-list: Specifies a space-separated list of up to 10 interface items. Each item specifies an interface or a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for interface-number2 must be greater than or equal to the value for interface-number1. The two interfaces that define an interface range must be the same type and on the same card. The interface type can only be FC interface (cannot be a member port of an FC aggregate interface), FC aggregate interface, or VFC interface. If you do not specify the interface interface-list option, the specified pWWN can log in through any interface.
smartsan-static: Allows Smart SAN-capable N_Ports or NP_Ports whose Smart SAN Security Support field is not 0x00 to log in through the specified interfaces. The configured entry is a Smart SAN static entry. If you do not specify this keyword, the configured entry is a static entry.
Enable port security before configuring this command. You can specify the smartsan-static keyword only after you enable Smart SAN for FC/FCoE.
# Allow pWWN 20:36:44:78:66:77:ab:9e to log in through FC 1/0/1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] pwwn 20:36:44:78:66:77:ab:9e interface fc 1/0/1
# Allow pWWN 20:36:44:78:66:77:ab:9e to log in through VFC 1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] pwwn 20:36:44:78:66:77:ab:9e interface vfc 1
Use reset fc-port-security database to clear binding entries in the port security database.
reset fc-port-security database { all | auto-learn | smartsan-static | static } [ interface interface-type interface-number ] vsan vsan-id
all: Specifies all binding entries, including static entries, learned entries, learning entries, and Smart SAN static entries.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears binding entries for all interfaces.
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. On an FCF-NPV switch, this command clears the binding entries for only VSANs operating in FCF mode.
After you execute this command, the switch performs authorization checks on devices already logged in. Therefore, the switch might log out devices already logged in.
# Clear static binding entries in the port security database for VSAN 2.
<Sysname> reset fc-port-security database static vsan 2
Use reset fc-port-security statistics to clear port security statistics for a VSAN.
reset fc-port-security statistics vsan vsan-id
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. On an FCF-NPV switch, this command clears the port security statistics for only VSANs operating in FCF mode.
# Clear port security statistics for VSAN 2.
<Sysname> reset fc-port-security statistics vsan 2
snmp-agent trap enable fc-port-security
Use snmp-agent trap enable fc-port-security to enable SNMP notifications for port security.
Use undo snmp-agent trap enable fc-fabric to disable SNMP notifications for port security.
snmp-agent trap enable fc-port-security [ violation-happen ]
undo snmp-agent trap enable fc-port-security [ violation-happen ]
All SNMP notifications for port security are disabled.
violation-happen: Specifies notifications about only security violations. This keyword enables the switch to generate a notification when the switch detects a security violation. The notification includes the WWN of the violating device, the interface through which the violating device attempted to log in, and login time. If you do not specify this keyword, the command enables all SNMP notifications for port security.
To report critical port security events to an NMS, enable SNMP notifications for port security. For port security event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable all SNMP notifications for port security.
[Sysname] snmp-agent trap enable fc-port-security
swwn
Use swwn to allow an sWWN to log in through the specified interfaces.
Use undo swwn to delete the configuration.
swwn swwn [ interface interface-list ]
undo swwn swwn [ interface interface-list ]
An sWWN is not allowed to log in through the specified interfaces.
VSAN view
swwn: Specifies the sWWN (WWN of an FCF switch) in the format of xx:xx:xx:xx:xx:xx:xx:xx, where x is a hexadecimal number.
interface interface-list: Specifies a space-separated list of up to 10 interface items. Each item specifies an interface or a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for interface-number2 must be greater than or equal to the value for interface-number1. The two interfaces that define an interface range must be the same type and on the same card. The interface type can only be FC interface (cannot be a member port of an FC aggregate interface), FC aggregate interface, or VFC interface. If you do not specify the interface interface-list option, the specified sWWN can log in through any interface.
# Allow sWWN 20:36:44:78:66:77:ab:9e to log in through FC 1/0/1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] swwn 20:36:44:78:66:77:ab:9e interface fc 1/0/1
# Allow sWWN 20:36:44:78:66:77:ab:9e to log in through VFC 1 in VSAN 2.
[Sysname] vsan 2
[Sysname-vsan2] swwn 20:36:44:78:66:77:ab:9e interface vfc 1
FCS commands
The commands in this section are supported only on FCF and FCF-NPV switches.
display fcs database
Use display fcs database to display the local FCS database information, including IE and port information.
display fcs database [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the FCS database information in all VSANs. On an FCF-NPV switch, this command displays the FCS database information in only VSANs operating in FCF mode.
# Display the FCS database information in all VSANs.
<Sysname> display fcs database
FCS Local Database in VSAN 1:
  IE WWN                   : 10:00:00:11:22:00:01:01
  Domain ID                : 0x01
  Management address list  : snmp://192.168.6.100
                             snmp://192.168.0.100
  Fabric name              : 10:00:00:11:22:00:01:01
  Logical name             : IE-Sysname1
  Information list         : xxx#XXXX#xxxx
  IE_Ports:
    Interface   Port WWN                  Port type  Attached port WWNs
    Vfc2        2f:12:01:11:22:00:01:01   F_Port         2f:12:01:11:22:00:01:02
                                                     2f:12:01:11:22:00:01:03
                                                     2f:12:01:11:22:00:01:04
    Vfc1        38:00:00:11:22:00:01:01   E_Port     38:00:00:11:22:00:01:02
  IE WWN                   : 10:00:00:11:22:00:01:02
  Domain ID                : 0x02
  Management address list  : snmp://192.168.6.101
  Logical name             : IE-Sysname2
  IE_Ports:
    -           2f:15:01:11:22:00:01:01   F_Port     2f:15:01:11:22:00:01:02
    -           38:00:00:11:22:00:01:01   E_Port     38:00:00:11:22:00:01:02
FCS Local Database in VSAN 2:
  Domain ID                : 0x01
  IE_Ports:
Table 54 Command output
·     snmp://192.168.6.100—SNMP is supported by the IE, and the management IP address is 192.168.6.100.
·     Unknown—No management IP address is obtained from the IE.
·     NA—No management IP address is configured on the IE.
Fabric name
Name of the fabric where the IE resides.
Unknown indicates that the fabric name is not obtained from the IE.
Logical name
Device name of the IE.
Unknown indicates that the device name is not obtained from the IE.
Information list
Includes vendor name, model name/number, and release code.
Unknown indicates that the information list is not obtained from the IE.
Interface name.
The interface name is displayed for only interfaces on the local IE. For interfaces on non-local IEs, a hyphen (-) is displayed.
Port type
Port mode: E_Port or F_Port.
Unknown is displayed for port modes other than E_Port and F_Port.
Attached port WWNs
WWNs of connected ports.
NA indicates that the port does not connect to any ports.
fcs discovery start
display fcs discovery status
Use display fcs discovery status to display the topology discovery status.
display fcs discovery status [ vsan vsan-id ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the topology discovery status in all VSANs. On an FCF-NPV switch, this command displays the topology discovery status in only VSANs operating in FCF mode.
# Display the topology discovery status in all VSANs.
<Sysname> display fcs discovery status
VSAN    Discovery Status
1       inProgress
2       completed
3       localOnly
fcs discovery start
fcs discovery stop
display fcs ie
Use display fcs ie to display IE information.
display fcs ie [ vsan vsan-id ] [ nwwn wwn ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the IE information in all VSANs. On an FCF-NPV switch, this command displays the IE information in only VSANs operating in FCF mode.
nwwn wwn: Specifies a node by its WWN in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal). If you do not specify a node, this command displays the IE information for all nodes.
verbose: Displays detailed IE information. If you do not specify this keyword, the command displays brief IE information.
# Display the IE information in all VSANs.
<Sysname> display fcs ie
IE List for VSAN 1:
  IE WWN                   Domain ID   Mgmt addr list           Logical name
  10:00:00:11:22:00:01:01  0x01        snmp://192.168.6.100     Sysname
  10:00:00:11:22:00:01:02  0x02        snmp://192.168.6.101     Sysname
  Total 2 IEs in Fabric.
IE List for VSAN 2:
  Total 1 IEs in Fabric.
# Display the IE information in VSAN 1.
<Sysname> display fcs ie vsan 1
IE List for VSAN 1:
# Display the brief IE information for the node with WWN 10:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs ie vsan 1 nwwn 10:00:00:11:22:00:01:01
# Display the detailed IE information for the node with WWN 10:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs ie vsan 1 nwwn 10:00:00:11:22:00:01:01 verbose
IE Attributes:
  IE type                : Switch
  Domain ID              : 0x01
  Logical name           : Sysname
  Management address list: snmp://192.168.6.100
  Information list       :
    Vendor name      : xxx
    Model name/number: XXXX
    Release code     : xxxx
# Display the detailed IE information in all VSANs.
<Sysname> display fcs ie verbose
IE List for VSAN 1:
  IE Attributes:
    IE type                : Switch
    Domain ID              : 0x01
    Information list       :
      Vendor name      : xxx
      Release code     : xxxx
IE List for VSAN 2:
  IE Attributes:
    IE type                : Switch
    Domain ID              : 0x01
    Information list       :
      Vendor name      : xxx
      Release code     : xxxx
Table 55 Command output
IE type
The IE type can only be Switch.
Unknown is displayed for all other types.
Fabric name
Logical name
Mgmt addr list
Information list
fcs discovery start
display fcs port
Use display fcs port to display port information.
display fcs port [ vsan vsan-id ] [ pwwn wwn ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the port information in all VSANs. On an FCF-NPV switch, this command displays the port information in only VSANs operating in FCF mode.
pwwn wwn: Specifies a port by its WWN in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal). If you do not specify a port, this commands displays information about all ports.
verbose: Displays detailed port information. If you do not specify this keyword, the command displays brief port information.
# Display the port information for all VSANs.
<Sysname> display fcs port
Port List for VSAN 1:
  IE WWN: 10:00:00:11:22:00:01:01
    Port WWN                  Port type    Tx type             Module type
    2f:15:01:11:22:00:01:01   Unknown      Shortwave Laser     SFP with Serial ID
    38:00:00:11:22:00:01:01   E_Port       Shortwave Laser     SFP with Serial ID
    Total 2 switch-ports in IE.
  IE WWN: 10:00:00:11:22:00:01:02
    38:00:00:11:22:00:01:02   E_Port       Shortwave Laser     SFP with Serial ID
    Total 1 switch-ports in IE.
Port List for VSAN 2:
# Display the brief port information for the port with WWN 38:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs port vsan 1 pwwn 38:00:00:11:22:00:01:01
# Display the detailed port information for the port with WWN 38:00:00:11:22:00:01:01 in VSAN 1.
<Sysname> display fcs port vsan 1 pwwn 38:00:00:11:22:00:01:01 verbose
Port Attributes:
  Port WWN                         : 38:00:00:11:22:00:01:01
  Port type                        : E_Port
  Tx type                          : Shortwave Laser
  Module type                      : SFP with Serial ID
  Port number                      : 465
  Attached port WWNs               : 2f:15:01:11:22:00:01:02
  Port state                       : Offline
  Port speed capability            : 10Gbps, 16Gbps
  Port speed operation             : 10Gbps
  Port zoning enforcement status   : Soft, Hard
Table 56 Command output
Port type
Tx type
Transmitter type of the port:
·     10GBASE-CX4.
·     10GBASE-ER 1550nm laser.
·     10GBASE-EW 1550nm laser.
·     10GBASE-LR 1310nm laser.
·     10GBASE-LW 1310nm laser.
·     10GBASE-LX4 WWDM 1300nm laser.
·     10GBASE-SR 850nm laser.
·     10GBASE-SW 850nm laser.
·     Electrical-EL.
·     Long wave laser cost reduced-LC(1310nm).
·     Long wave laser-LL(1550nm).
·     Short wave laser-SN(850nm).
Unknown is displayed for cable types other than the preceding ones or for a VN interface.
Module type
Transceiver module type of the port:
·     GBIC with serial ID.
·     GBIC without serial ID.
·     GLM.
·     QSFP.
·     SFP-DWDM.
·     SFP with serial ID.
·     SFP without serial ID.
·     X2-DWDM.
·     X2 Medium.
·     X2 short.
·     X2 Tall.
·     XENPAK.
·     XFP.
·     XPAX Medium.
·     XPAX short.
·     XPAX Tall.
Other is displayed for transceiver module types other than the preceding ones.
Unknown is displayed when the transceiver module type cannot be obtained or when the port is a VN interface.
Port number
Port index.
Attached port WWNs
If the nodes are registered through an NPV switch, there might be multiple connected ports.
Port state
Current port state:
·     Online—The port link is connected.
·     Offline—The port link is not connected.
·     Unknown—Port state other than Online or Offline.
The supported speed can be one or more of the following options:
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     20 Gbps.
Unknown is displayed for speeds other than the preceding ones or for a VN interface.
The current speed can only be one of the following options:
·     1 Gbps.
·     2 Gbps.
·     4 Gbps.
·     8 Gbps.
·     10 Gbps.
·     16 Gbps.
·     20 Gbps.
Unknown is displayed for speeds other than the preceding ones or for a VN interface. Speed not established is displayed when the current port state is Offline.
Zoning type supported by the port: soft zoning or hard zoning.
Soft zoning and hard zoning can be both supported. NA is displayed when neither of them is supported.
fcs discovery start
fcs discovery start
Use fcs discovery start to start a topology discovery in VSANs.
fcs discovery start [ age interval ] vsan vsan-list
age interval: Specifies the aging time for the topology discovery information, in the range of 300 to 86400 seconds. The default is 900 seconds.
vsan vsan-list: Specifies a VSAN by its ID or a range of VSANs in the form of vsan-id1 to vsan-id2. The value range for the vsan-id argument is 1 to 3839. The value for vsan-id2 must be greater than or equal to the value for vsan-id1.
# Start a topology discovery in VSAN 1 through VSAN 100.
[Sysname] fcs discovery start vsan 1 to 100
display fcs ie
display fcs port
fcs discovery stop
Use fcs discovery stop to stop a topology discovery in VSANs.
fcs discovery stop vsan vsan-list
# Stop the topology discovery in VSAN 1 through VSAN 100.
[Sysname] fcs discovery stop vsan 1 to 100
fcs discovery start
FDMI commands
display fdmi database
Use display fdmi database to display the FDMI database information.
display fdmi database [ vsan vsan-id ] [ hba-id hba-id ] [ verbose ]
vsan vsan-id: Specifies a VSAN by its ID in the range of 1 to 3839. If you do not specify a VSAN, this command displays the FDMI database information for all VSANs. On an FCF-NPV switch, this command displays the FDMI database information in only VSANs operating in FCF mode.
hba-id hba-id: Specifies an HBA by its ID in the format of xx:xx:xx:xx:xx:xx:xx:xx (hexadecimal). If you do not specify an HBA, this command displays the FDMI database information for all HBAs.
verbose: Displays detailed FDMI database information. If you do not specify this keyword, the command displays brief FDMI database information.
The FDMI database includes information about only ports on HBAs that have successfully registered with the device.
# Display the brief FDMI database information for all VSANs.
<Sysname> display fdmi database
Registered HBA List for VSAN 1:
  HBA ID                        Port Name
  21:00:00:11:22:00:01:02       21:00:00:11:22:00:01:02
                                21:00:00:c0:dd:13:cc:d6
                                21:00:00:c0:dd:13:cc:d7
  38:00:00:11:22:00:01:01       21:00:00:c0:dd:13:cc:d4
                                21:00:00:c0:dd:13:cc:d5
Registered HBA List for VSAN 2:
  HBA ID                        Port Name
Table 57 Command output
Port Name
WWNs of the ports on the HBA.
# Display brief information about the HBA 38:00:00:11:22:00:01:01 in the FDMI database for VSAN 1.
<Sysname> display fdmi database vsan 1 hba-id 38:00:00:11:22:00:01:01
  HBA ID                        Port Name
# Display the detailed FDMI database information for the HBA 50:01:43:80:12:09:54:f4 in VSAN 1 when Smart SAN is disabled.
<Sysname> display fdmi database vsan 1 hba-id 50:01:43:80:12:09:54:f4 verbose
  HBA ID: 50:01:43:80:12:09:54:f4
    Manufacturer: QLogic Corporation
    Serial Number: MY5140209J
    Model: HPAK344A
    Model Description: QLogic HPAK344A Fibre Channel Adapter
    Node Name: 50:01:43:80:12:09:54:f5
    Node Symbolic Name: HPAK344A FW:v7.04.00 DVR:v9.1.14.22
    Hardware Version: PX2810403-21 G
    Driver Version: 9.1.14.22
    Option ROM Version: 3.28
    Firmware Version: 7.04.00
    OS Name and Version: Windows Server 2008 R2 Datacenter Service Pack 1
    Maximum CT Payload: 2048
    Vendor Identifier: QLOGIC
    Vendor Specific Information: 0x327A0941
    Number of Ports: 1
    Fabric Name: 20:01:00:e0:fc:a1:58:00
    Boot BIOS Version: 3.28
    Boot BIOS State: Enabled
      Port Name: 50:01:43:80:12:09:54:f4
        Port Symbolic Name: HPAK344A FW:v7.04.00 DVR:v9.1.14.22
        Port Identifier: 0x020000
        Port Type: 0x01(N)
        Supported Class of Service: 3
        Supported FC-4 Types: FCP
        Port Active FC-4 Types: FCP
        Supported Speed: 2 Gbps, 4 Gbps, 8 Gbps
        Current Speed: 8Gbps
        Maximum Frame Size: 2048
        OS Device Name: QLogic Adapter
        Host Name: WIN-NGCFD7VQUA2
        Port Fabric Name: 20:01:00:e0:fc:a1:58:00
        Port State: 0x00000001
        Number of Discovered Ports: 2
# Display the detailed FDMI database information for the HBA 50:01:43:80:12:09:54:f4 in VSAN 1 when Smart SAN is enabled and incoming packets include Smart SAN attributes.
    Model: HPAK344A
    Number of Ports: 1
        Port Type: 0x01(N)
        Number of Discovered Ports: 0
        Smart SAN Service Category: Smart SAN Initiator
        Smart SAN GUID: 50014380-1209-54f5-5001-4380120954f4
        Smart SAN Version: Smart SAN Version 1.0
        Smart SAN Product Name(Model): HPAK344A
        Smart SAN Port info: 0x01(Physical)
        Smart SAN QoS Support: 0x00(Not Supported)
        Smart SAN Security Support: 0x01(Tier-1)
        Smart SAN Connected Ports: 20:01:00:e0:fc:a1:58:03
Table 58 Command output
Manufacturer
Manufacturer of the HBA.
Serial Number
Serial number of the HBA.
Model
Model of the HBA.
Model Description
Model description for the HBA.
Node Name
WWN of the node where the HBA resides.
Node Symbolic Name
Symbolic name of the node where the HBA resides.
Hardware Version
Hardware version of the HBA.
Driver Version
Driver version of the HBA.
Option ROM Version
ROM version of the HBA.
Firmware Version
Firmware version of the HBA.
OS Name and Version
Operating system name and version number of the HBA.
Maximum CT Payload
Maximum length of CT payload allowed by the HBA.
The CT payload includes the basic header and extended header of CT packets, but not the FC header.
Vendor Identifier
T10 code of the manufacturer or OEM for the HBA.
Vendor-defined information, which is hexadecimal.
Number of Ports
Number of ports on the HBA.
Fabric Name
Name of the fabric where the HBA resides.
Boot BIOS Version
Boot BIOS version of the HBA.
Boot BIOS State
Boot BIOS state for the HBA: Enabled or Disabled.
Port Name
WWN of the port on the HBA.
Port Symbolic Name
Symbolic name of the port on the HBA.
Port Identifier
FC address of the port
Class of service supported by the port: Class 2 or Class 3.
FC-4 types supported by the port:
·     FCP.
·     GS3.
·     IP.
·     LLC/SNAP.
·     NPV.
·     SNMP.
·     SW-ILS.
·     VI.
FC-4 types active on the port, which can be one or more of the following options:
·     FCP.
·     GS3.
·     IP.
·     LLC/SNAP.
·     NPV.
·     SNMP.
·     SW-ILS.
·     VI.
Supported Speed
Speeds supported by the port:
·     1 Gbps
·     2 Gbps
·     4 Gbps
·     8 Gbps
·     10 Gbps
·     16 Gbps
·     20 Gbps
·     32 Gbps
·     40 Gbps
This field displays Unknown for speeds other than the preceding ones. This field displays Speed not obtained when the supported speeds cannot be determined.
Current Speed
·     1 Gbps
·     2 Gbps
·     4 Gbps
·     8 Gbps
·     10 Gbps
·     16 Gbps
·     20 Gbps
·     32 Gbps
·     40 Gbps
This field displays Unknown for speeds other than the preceding ones. This field displays Speed not obtained when the current speed cannot be determined.
OS Device Name
Operating system name for the port.
Host Name
Name of the node where the port resides.
Node Name
WWN of the node where the port resides.
Port Fabric Name
Name of the fabric where the port resides.
Smart SAN service category: Smart SAN Initiator or Smart SAN Target.
Smart SAN GUID
Smart SAN globally unique identifier.
Smart SAN Port Info
Port information:
·     0x01 (Physical)—The port is a physical port.
·     0x02 (NPIV)—The port supports NPIV.
·     0x03 (SRIOV)—The port supports SRIOV.
QoS support of the port: 0x00 (Not supported) and 0x01 (Supported).
Security types supported by the port:
·     0x00 (Not Supported).
·     0x01 (Tier-1).
·     0x02 (Tier-2).
·     0x03 (Tier-3).
This field displays ports on remote nodes discovered by the port.
FC ping commands
fcping
Use fcping to FCping a node or an FCF switch.
fcping [ -c count | -t timeout ] * fcid fcid vsan vsan-id
-c count: Specifies the number of echo requests to be sent, in the range of 0 to 2147483647. The default is 5. The value of 0 indicates that echo requests are continuously sent until you manually stop sending them.
-t timeout: Specifies the timeout value for an echo reply, in the range of 1 to 10 seconds. The default is 5 seconds. If the source does not receive an echo reply within the timeout period, it determines that the echo reply times out.
fcid fcid: Specifies the destination address.
·     If the destination is a node, the fcid argument indicates the FC address of the node.
·     If the destination is an FC switch, the fcid argument indicates the switch's domain controller address fffcxx (xx is the domain ID of the switch). For example, if the domain ID of the destination switch is 3, its domain controller address is fffc03.
To abort the FC ping operation during the execution of this command, press Ctrl+C.
# FCping the address fffc02 in VSAN 1.
<Sysname> fcping fcid fffc02 vsan 1
FCPING fcid 0xfffc02: 128 data bytes, press CTRL_C to break.
Reply from 0xfffc02: bytes = 128 time = 1.281 ms
Reply from 0xfffc02: bytes = 128 time = 0.890 ms
Reply from 0xfffc02: bytes = 128 time = 0.889 ms
Reply from 0xfffc02: bytes = 128 time = 0.892 ms
Reply from 0xfffc02: bytes = 128 time = 0.894 ms
--- 0xfffc02 fcping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 0.889/0.969/1.281 ms
The output shows that all FC ping packets were successfully received.
# FCping the address FFFC01 in VSAN 1.
<Sysname> fcping fcid fffc01 vsan 1
FCPING fcid 0xfffc01: 128 data bytes, press CTRL_C to break.
fcping: sendto: No route to host
fcping: sendto: ^C
--- 0xfffc01 fcping statistics ---
3 packet(s) transmitted
0 packet(s) received
100.00% packet loss
The output shows that FC ping packets were not received.
Table 59 Command output
Identify whether the device with destination address 0xfffc02 is reachable.
128 data bytes
Number of data bytes in each echo request.
During the execution of the command, press Ctrl+C to abort the FC ping operation.
The echo reply was received from the device whose destination address is 0xfffc02.
·     bytes—Number of data bytes in the echo reply.
·     time—Response time.
Request time out
No echo reply was received within the timeout period.
Echo requests failed to be delivered.
Statistics on the data received and sent in the FC ping operation.
Number of echo requests sent.
Number of echo replies received.
0.00% packet loss
Percentage of packets not responded to the total number of packets sent.
Minimum/average/maximum response time, in milliseconds.
FC tracert commands
fctracert
Use fctracert to detect bidirectional routing information between the local end and a destination. The destination can be a node or FCF switch.
fctracert [ -t timeout ] fcid fcid vsan vsan-id
-t timeout: Specifies the timeout value for the entire FC tracert process, in the range of 1 to 10 seconds. The default is 5 seconds.
vsan vsan-id: Specifies an existing VSAN by its ID in the range of 1 to 3839.
The bidirectional routing information includes WWNs and domain controller addresses of all switches on a round trip. The device supports a maximum of 255 hops for a round trip.
To abort the FC tracert operation during the execution of the command, press Ctrl+C.
# Detect bidirectional routing information between the local end and a node with FC address 0xd70000 in VSAN 1.
<Sysname> fctracert fcid d70000 vsan 1
Route present for: 0xd70000, press CTRL_C to break.
20:00:00:0b:46:00:02:82(0xfffcd5)
20:00:00:05:30:00:18:db(0xfffcd7)
Fctracert completed.
Table 60 Command output
Route present for
Path from a source to a destination.
During the execution of the command, press Ctrl+C to abort the FC tracert operation.
WWN value.
0xfffcd5
Domain controller address 0xfffcxx of the switch, where xx is the domain ID of the switch.
Fctracert uncompleted.
The FC tracert operation fails to be completed for the following possible reasons:
·     Resource is not enough.
·     Max hops reached.
·     Fabric is being built.
·     No route to destination port.
·     Destination port is not in fabric.
·     Destination port and source port are not in the same zone.
Service is unavailable.
The FC tracert service is not started, or internal processing fails.
