03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS6800 SeriesReference GuidesCommand ReferencesH3C S6800 Switch Series Command References-Release 26xx-6W10703-Layer 2—LAN Switching Command Reference
16-Service loopback group commands
16-Service loopback group commands 48.15 KB
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Service Group ID: 5       Service Type: Tunnel
Member:
 Ten-GigabitEthernet1/0/1
 Ten-GigabitEthernet1/0/2
Service Group ID
Service loopback group ID.
Service Type
Service type of the service loopback group:
·     Multicast-tunnel—Supports multicast tunnel traffic.
·     Tunnel—Supports unicast tunnel traffic.
·     Multiport—Supports multiport ARP traffic.
·     VSI-gateway—Supports VSI gateway traffic.
Member
Member ports of the service loopback group.
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group group-id
A port does not belong to any service loopback group.
When you assign a port to a service loopback group, the system removes the configuration on the port. Make sure you are fully aware of the impact of this command before using it on a live network.
To avoid IRF split, do not assign a port to a service loopback group if that port is the only IRF physical interface of an IRF port.
Before assigning a port to a service loopback group, make sure the port supports the service type of the group.
A port can belong to only one service loopback group. You can assign a maximum of 32 ports to a service loopback group.
For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
# Assign Ten-GigabitEthernet 1/0/1 to service loopback group 5.
[Sysname-Ten-GigabitEthernet1/0/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | vsi-gateway }
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
multicast-tunnel: Specifies the multicast tunnel service.
tunnel: Specifies the unicast tunnel service.
multiport: Specifies the multiport ARP service.
vsi-gateway: Specifies the VSI gateway service.
Service loopback groups must work with other features, such as GRE. A service loopback group can be used by multiple features.
You must create a service loopback group before you can use it with a feature.
You can configure only one service loopback group for a service type. You cannot change the service type of a service loopback group.
To ensure correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify the unicast tunnel service for the group.
[Sysname] service-loopback group 5 type tunnel
