H3C S6890 Switch Series Config Examples-Release 36xx-6W100
HomeSupportSwitchesS6890 SeriesConfigure & DeployConfiguration ExamplesH3C S6890 Switch Series Config Examples-Release 36xx-6W100
Table of Contents
Related Documents
11-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides IPv6 over IPv4 tunneling with OSPFv3 configuration examples.
This document assumes that you have basic knowledge of IPv6 over IPv4 tunneling and OSPFv3.
Example: Configuring IPv6 over IPv4 tunneling with OSPFv3
As shown in Figure 1, in IPv6 networks, Device A, Device B, and Device C act as the gateways of the headquarters, Branch 1, and Branch 2, respectively.
Configure IPv6 over IPv4 tunnels to ensure that the headquarters can communicate with the two branches over IPv4 networks.
Configure OSPFv3 on the gateways to ensure the following:
·     The gateways have routes to destination IPv6 addresses through tunnel interfaces.
·     Branch 1 and Branch 2 can communicate with each other through the headquarters.
Figure 1 Network diagram
Device
IP address
Device A
Vlan-int10
20.1.1.1/24
Vlan-int20
2001::1/64
Tunnel1
3001::1/64
Tunnel2
4001::1/64
Device B
Vlan-int10
30.1.1.1/24
Vlan-int20
5001::1/64
Tunnel1
3001::2/64
Device C
Vlan-int10
40.1.1.1/24
Vlan-int20
6001::1/64
Tunnel2
4001::2/64
Software versions used
This configuration example was created and verified on Release 3606.
For tunnel interfaces to send and receive packets, you must configure a tunnel-type service loopback group.
On the device, a tunneled packet cannot be directly routed based on its destination address. It is sent to a tunnel-type service loopback group, which then delivers the packet to the forwarding module for Layer 3 forwarding.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Make sure the gateways can reach each other at IPv4.
Configuring IPv6 over IPv4 tunnels
·     Configure Device A:
# Configure an IP address for VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 20.1.1.1 24
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Create service loopback group 1, and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[DeviceA] interface Ten-GigabitEthernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceA-Ten-GigabitEthernet1/0/3] quit
# Configure an IPv6 over IPv4 tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode ipv6-ipv4
# Configure an IPv6 address for Tunnel 1.
[DeviceA-Tunnel1] ipv6 address 3001::1/64
# Specify VLAN-interface 10 as the source interface of Tunnel 1.
[DeviceA-Tunnel1] source vlan-interface 10
# Specify the destination address for Tunnel 1.
[DeviceA-Tunnel1] destination 30.1.1.1
[DeviceA-Tunnel1] quit
# Configure an IPv6 over IPv4 tunnel interface Tunnel 2.
[DeviceA] interface tunnel 2 mode ipv6-ipv4
# Configure an IPv6 address for Tunnel 2.
[DeviceA-Tunnel2] ipv6 address 4001::1/64
# Specify VLAN-interface 10 as the source interface of Tunnel 2.
[DeviceA-Tunnel2] source Vlan-interface 10
# Specify the destination address for Tunnel 2.
[DeviceA-Tunnel2] destination 40.1.1.1
[DeviceA-Tunnel2] quit
·     Configure Device B:
[DeviceB] vlan 10
[DeviceB-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] ip address 30.1.1.1 24
[DeviceB-Vlan-interface10] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface Ten-GigabitEthernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceB-Ten-GigabitEthernet1/0/3] quit
[DeviceB] interface tunnel 1 mode ipv6-ipv4
[DeviceB-Tunnel1] ipv6 address 3001::2/64
[DeviceB-Tunnel1] source vlan-interface 10
[DeviceB-Tunnel1] destination 20.1.1.1
[DeviceB-Tunnel1] quit
·     Configure Device C:
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceC-vlan10] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ip address 40.1.1.1 24
[DeviceC-Vlan-interface10] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface Ten-GigabitEthernet 1/0/3
[DeviceC-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceC-Ten-GigabitEthernet1/0/3] quit
[DeviceC] interface tunnel 2 mode ipv6-ipv4
[DeviceC-Tunnel2] ipv6 address 4001::2/64
[DeviceC-Tunnel2] source vlan-interface 10
[DeviceC-Tunnel2] destination 20.1.1.1
[DeviceC-Tunnel2] quit
Configuring OSPFv3
# Specify the router ID as 1.1.1.1.
[DeviceA] ospfv3
[DeviceA-ospfv3-1] router-id 1.1.1.1
[DeviceA-ospfv3-1] quit
# Enable OSPFv3 on Tunnel 1.
[DeviceA] interface Tunnel 1
[DeviceA-Tunnel1] ospfv3 1 area 0
# Enable OSPFv3 on Tunnel 2.
[DeviceA] interface Tunnel 2
[DeviceA-Tunnel2] ospfv3 1 area 0
# Enable OSPFv3 on VLAN-interface 20.
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] ospfv3 1 area 0
[DeviceA-Vlan-interface20] quit
# Specify the router ID as 2.2.2.2.
[DeviceB] ospfv3
[DeviceB-ospfv3-1] router-id 2.2.2.2
[DeviceB-ospfv3-1] quit
[DeviceB] interface Tunnel 1
[DeviceB-Tunnel1] ospfv3 1 area 0
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ospfv3 1 area 0
[DeviceB-Vlan-interface20] quit
# Specify the router ID as 3.3.3.3.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 3.3.3.3
[DeviceC-ospfv3-1] quit
[DeviceC] interface Tunnel 2
[DeviceC-Tunnel2] ospfv3 1 area 0
[DeviceC] interface vlan-interface 20
[DeviceC-Vlan-interface20] ospfv3 1 area 0
[DeviceC-Vlan-interface20] quit
# Ping PC 1 from PC 2.
D:\>ping6 -s 5001::3 2001::3
Pinging 2001::3
from 5001::3 with 32 bytes of data:
Reply from 2001::3: bytes=32 time=13ms
Reply from 2001::3: bytes=32 time=1ms
Reply from 2001::3: bytes=32 time<1ms
Ping statistics for 2001::3:
Minimum = 0ms, Maximum = 13ms, Average = 3ms
The output shows that the ping operation succeeds.
# Ping PC 3 from PC 2.
D:\>ping6 -s 5001::3 6001::3
Pinging 6001::3
from 6001::3 with 32 bytes of data:
Reply from 6001::3: bytes=32 time=13ms
Reply from 6001::3: bytes=32 time=1ms
Reply from 6001::3: bytes=32 time<1ms
Ping statistics for 6001::3:
Configuration files
·     Device A:
ospfv3 1
 router-id 1.1.1.1
 area 0.0.0.0
vlan 10
vlan 20
interface Vlan-interface10
 ip address 20.1.1.1 255.255.255.0
interface Vlan-interface20
 ospfv3 1 area 0.0.0.0
 ipv6 address 2001::1/64
 port link-mode bridge
 port access vlan 10
 port access vlan 20
interface Tunnel1 mode ipv6-ipv4
 source Vlan-interface10
interface Tunnel2 mode ipv6-ipv4
·     Device B:
ospfv3 1
 router-id 2.2.2.2
 area 0.0.0.0
vlan 10
vlan 20
 ip address 30.1.1.1 255.255.255.0
 ipv6 address 5001::1/64
 port access vlan 10
 port access vlan 20
·     Device C:
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.0
vlan 10
vlan 20
 ip address 40.1.1.1 255.255.255.0
 ipv6 address 6001::1/64
 port access vlan 10
 port access vlan 20
Related documentation
·     H3C S6890 Switch Series Layer 3—IP Routing Command Reference-R3606
·     H3C S6890 Switch Series Layer 3—IP Routing Configuration Guide-R3606
·     H3C S6890 Switch Series Layer 3—IP Services Command Reference-R3606
·     H3C S6890 Switch Series Layer 3—IP Services Configuration Guide-R3606
