- 18-Network Management and Monitoring Command Reference
- 01-EAA commands
- 02-Flow log commands
- 03-NETCONF commands
- 04-NQA commands
- 05-Packet capture commands
- 06-RMON commands
- 07-SNMP commands
- 08-Process monitoring and maintenance commands
- 09-Mirroring commands
- 10-Fast log output commands
- 11-System maintenance and debugging commands
09-Mirroring commands | 86.30 KB |
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
Port mirroring commands
The following compatibility matrix shows the support of hardware platforms for port mirroring:
Hardware series |
Models |
Product code |
Port mirroring compatibility |
WX1800H series |
WX1804H |
EWP-WX1804H-PWR-CN |
Yes |
WX2500H series |
WX2508H-PWR-LTE WX2510H WX2510H-F WX2540H WX2540H-F WX2560H |
EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H |
Yes |
WX3000H series |
WX3010H WX3010H-X WX3010H-L WX3024H WX3024H-L WX3024H-F |
EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F |
Yes |
WX3500H series |
WX3508H WX3510H WX3520H WX3520H-F WX3540H |
EWP-WX3508H EWP-WX3510H EWP-WX3520H EWP-WX3520H-F EWP-WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
EWP-WX5510E EWP-WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
EWP-WX5540H EWP-WX5560H EWP-WX5580H |
Yes |
Access controller modules |
LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F |
No |
Hardware series |
Models |
Product code |
WX1800H series |
WX1804H WX1810H WX1820H WX1840H |
EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL |
Yes |
WX3800H series |
WX3820H WX3840H |
EWP-WX3820H-GL EWP-WX3840H-GL |
Yes |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
Yes |
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local }
group-id: Specifies a mirroring group by its ID.
The following compatibility matrix shows the value ranges for the mirroring group ID:
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
WX1804H |
1 and 2 |
WX2500H series |
1 and 2 |
WX3000H series |
· WX3010H-L, WX3024H-L: 1 to 4 · WX3010H, WX3010H-X, WX3024H, WX3024H-F: 1 and 2 |
WX3500H series |
1 and 2 |
WX5500E series |
WX5510E WX5540E |
1 and 2 |
WX5500H series |
1 and 2 |
This command is not supported. |
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
1 and 2 |
WX3800H series |
WX3820H WX3840H |
1 and 2 |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
1 and 2 |
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet1/0/1 Inbound
Monitor port: GigabitEthernet1/0/2
Mirroring group |
Number of the mirroring group. |
Type |
Type of the mirroring group: Local. |
Status |
Status of the mirroring group: · Active—The mirroring group has taken effect. · Incomplete—The mirroring group configuration is not complete and does not take effect. |
Mirroring port |
Source port. |
Monitor port |
Destination port. |
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local
undo mirroring-group { group-id | all | local }
No mirroring groups exist.
group-id: Specifies a mirroring group ID.
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
WX1804H |
1 and 2 |
WX2500H series |
1 and 2 |
WX3000H series |
WX3500H series |
1 and 2 |
WX5500E series |
WX5510E WX5540E |
1 and 2 |
WX5500H series |
1 and 2 |
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
1 and 2 |
WX3800H series |
WX3820H WX3840H |
1 and 2 |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
1 and 2 |
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
WX1804H |
1 and 2 |
WX2500H series |
1 and 2 |
WX3000H series |
WX3500H series |
1 and 2 |
WX5500E series |
WX5510E WX5540E |
1 and 2 |
WX5500H series |
1 and 2 |
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
1 and 2 |
WX3800H series |
WX3820H WX3840H |
1 and 2 |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
1 and 2 |
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
A port can be used by only one mirroring group. A source port cannot be used as a monitor port.
# Create local mirroring group 1 to monitor the bidirectional traffic of port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
mirroring-group
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
WX1804H |
1 and 2 |
WX2500H series |
1 and 2 |
WX3000H series |
WX3500H series |
1 and 2 |
WX5500E series |
WX5510E WX5540E |
1 and 2 |
WX5500H series |
1 and 2 |
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
1 and 2 |
WX3800H series |
WX3820H WX3840H |
1 and 2 |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
1 and 2 |
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
A source port of a mirroring group cannot be used as the monitor port of any mirroring group.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 1/0/1.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
mirroring-group
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
WX1804H |
1 and 2 |
WX2500H series |
1 and 2 |
WX3000H series |
WX3500H series |
1 and 2 |
WX5500E series |
WX5510E WX5540E |
1 and 2 |
WX5500H series |
1 and 2 |
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
1 and 2 |
WX3800H series |
WX3820H WX3840H |
1 and 2 |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
1 and 2 |
Do not enable the spanning tree feature on the monitor port of a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
# Create local mirroring group 1 and configure GigabitEthernet 1/0/1 as its monitor port.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
mirroring-group
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
WX1804H |
1 and 2 |
WX2500H series |
1 and 2 |
WX3000H series |
WX3500H series |
1 and 2 |
WX5500E series |
WX5510E WX5540E |
1 and 2 |
WX5500H series |
1 and 2 |
Hardware series |
Models |
Product code |
Value range |
WX1800H series |
1 and 2 |
WX3800H series |
WX3820H WX3840H |
1 and 2 |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
1 and 2 |
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/1
mirroring-group
