12-WLAN Advanced Features Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5426P02)-6W10412-WLAN Advanced Features Command Reference
09-WSA commands
09-WSA commands 80.60 KB
WSA commands
The AP models and serial numbers in this document are used only as examples. Support for AP models and serial numbers depends on the AC model.
display wlan spectrum-analysis channel-quality
Use display wlan spectrum-analysis channel-quality to display channel quality information.
display wlan spectrum-analysis channel-quality [ ap ap-name | ap-group ap-group-name ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters, numbers, underlines (_), dots (.), left brackets ([), right brackets (]), slashes (/), and hyphens (-).
ap-group ap-group-name: Specifies an AP group by its name, a case-insensitive string of 1 to 31 characters.
If you do not specify the ap ap-name or ap-group ap-group-name option, the command displays channel quality information detected by all APs.
# Display channel quality information detected by AP ap1.
<Sysname> display wlan spectrum-analysis channel-quality ap ap1
AP name   RID   Channel   Avg-AQ   Min-AQ   Interference
ap1       2     1         95       84       1
RID
Radio ID.
Channel
Channel number.
Avg-AQ
Average channel quality.
Min-AQ
Worst channel quality.
Interference
Number of detected interference devices.
display wlan spectrum-analysis device
Use display wlan spectrum-analysis device to display interference device information.
display wlan spectrum-analysis device [ ap ap-name | ap-group ap-group-name ]
If you do not specify the ap ap-name or ap-group ap-group-name option, the command displays information about interference devices detected by all APs.
# Display information about interference devices detected by AP ap1.
<Sysname> display wlan spectrum-analysis device ap ap1
Interference detected by ap1 Radio1
Device ID              : 0x0005
Type                   : Video device using fixed frequency
SI                     : 50
RSSI                   : -35
Duty cycle (%)         : 20
Affected channels      : 3,4,5,6,7
Detected time          : Jan 6 10:42:56 2014
Device ID              : 0x0007
Type                   : Bluetooth
SI                     : 80
RSSI                   : -49
Duty cycle (%)         : 35
Affected channels      : 1,3,5,6,10
Device ID              : 0x000a
Type                   : Microwave oven
SI                     : 32
RSSI                   : -25
Duty cycle (%)         : 50
Affected channels      : 1,2,7,13,14
Name of the AP and ID of the radio that detects the interference device.
Device ID
Interference device ID.
Interference device type.
SI
Severity index. A greater value represents greater interference.
RSSI
RSSI of the interference device.
Duty cycle (%)
Percentage of time in a ten second period where an interference device is active.
Affected channels
Channels affected by the interference device.
Detected time
Time when the interference device was most recently detected.
snmp-agent trap enable wsa
Use snmp-agent trap enable wsa to enable SNMP notifications for WSA.
Use undo snmp-agent trap enable wsa to disable SNMP notifications for WSA.
SNMP notifications for WSA are disabled.
To report critical WSA events to an NMS, enable SNMP notifications for WSA. For WSA notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for WSA.
<sysname> system view
[sysname] snmp-agent trap enable wsa
spectrum-analysis
Use spectrum-analysis enable to enable WSA.
Use spectrum-analysis disable to disable WSA.
Use undo spectrum-analysis to restore the default.
spectrum-analysis { disable | enable }
In radio view, the configuration in an AP group's radio view is used.
In an AP group's radio view, WSA is disabled.
Radio view
AP group radio view
With WSA enabled, APs collect interference device and channel quality information and periodically send the information to the AC for further analysis.
# Enable WSA for AP ap1.
[sysname] wlan ap ap1 model WA4320i-ACN
[sysname-wlan-ap-ap1] radio 1
[sysname-wlan-ap-ap1-radio-1] spectrum-analysis enable
# Enable WSA for the APs with model WA4320i-ACN in AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] spectrum-analysis enable
spectrum-analysis calibrate-channel sensitivity
Use spectrum-analysis calibrate-channel sensitivity to specify a channel quality sensitivity level.
Use undo spectrum-analysis calibrate-channel sensitivity to restore the default.
spectrum-analysis calibrate-channel sensitivity { high | low | medium }
In an AP group's radio view, the channel quality sensitivity level is medium.
Radio view
AP group radio view
high: Specifies the high sensitivity level. The corresponding channel quality value is 60.
low: Specifies the low sensitivity level. The corresponding channel quality value is 35.
medium: Specifies the medium sensitivity level. The corresponding channel quality value is 50.
WSA notifies RRM to perform DFS when the channel quality is lower than the channel quality value corresponding to the specified sensitivity level. Make sure WSA collaboration is enabled before you execute this command. For more information about WSA collaboration, see Radio Resource Management Configuration Guide.
A smaller channel quality value represents worse channel quality.
# Set the channel quality sensitivity level to high for AP ap1.
[sysname-wlan-ap-ap1-radio-1] spectrum-analysis calibrate-channel sensitivity high
# Set the channel quality sensitivity level to high for the APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] spectrum-analysis calibrate-channel sensitivity high
calibrate-channel track spectrum-analysis
Use spectrum-analysis device to configure interference detection.
Use undo spectrum-analysis device to remove the configuration.
spectrum-analysis device { all | device-type } { disable | enable }
undo spectrum-analysis device { all | device-type }
In an AP group's radio view, APs detect all types of interference devices.
Radio view
AP group radio view
device-type: Specifies an interference device type.
all: Specifies all interference device types.
disable: Disables detecting the specified type of interference devices.
enable: Enables detecting the specified type of interference devices.
APs can detect only the types of interference devices in the feature database. The default feature database stores features about microwave ovens, Bluetooth devices, video devices using fixed frequency, frequency-hopping cordless networks, and Microsoft Xboxes.
Types of interference devices that can be detected vary by radio mode.
# Enable detecting Bluetooth devices for AP ap1.
[sysname-wlan-ap-ap1] radio 2
[sysname-wlan-ap-ap1-radio-2] spectrum-analysis device bluetooth enable
# Enable detecting Bluetooth devices for the APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-2] spectrum-analysis device bluetooth enable
spectrum-analysis trap channel-quality
Use spectrum-analysis trap channel-quality enable to enable channel quality notifications.
Use spectrum-analysis trap channel-quality disable to disable channel quality notifications.
Use undo spectrum-analysis trap channel-quality to restore the default.
spectrum-analysis trap channel-quality { disable | enable }
In an AP group's radio view, channel quality notifications are enabled.
Radio view
AP group radio view
Channel quality notifications take effect only when you also enable SNMP notifications for WSA.
# Disable channel quality notifications for AP ap1.
[sysname-wlan-ap-ap1-radio-1] spectrum-analysis trap channel-quality disable
# Disable channel quality notifications for the APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] spectrum-analysis trap channel-quality disable
spectrum-analysis trap channel-quality threshold
Use spectrum-analysis trap channel-quality threshold to set the channel quality threshold that triggers notifications.
Use undo spectrum-analysis trap channel-quality threshold to restore the default.
spectrum-analysis trap channel-quality threshold threshold-value
In an AP group's radio view, the channel quality threshold that triggers notifications is 35.
Radio view
AP group radio view
threshold-value: Specifies the channel quality threshold that triggers notifications, in the range of 1 to 100. A smaller channel quality value represents worse channel quality.
# Set the channel quality threshold that triggers notifications to 45 for AP ap1.
[sysname-wlan-ap-ap1-radio-1] spectrum-analysis trap channel-quality threshold 45
# Set the channel quality threshold that triggers notifications to 45 for the APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] spectrum-analysis trap channel-quality threshold 45
spectrum-analysis trap device
Use spectrum-analysis trap device to configure notifications for the specified type of interference devices.
Use undo spectrum-analysis trap device to restore the default.
spectrum-analysis trap device { all | device-type } { disable | enable }
undo spectrum-analysis trap device { all | device-type }
In an AP group's radio view, notifications are enabled for all types of interference devices.
Radio view
AP group radio view
disable: Disables notifications for the specified type of interference devices.
enable: Enables notifications for the specified type of interference devices.
Notifications for an interference device type take effect only when you also enable SNMP notifications for WSA.
# Disable notifications when Bluetooth devices are detected on AP ap1.
[sysname-wlan-ap-ap1-radio-2] undo spectrum-analysis trap device Bluetooth
# Disable notifications when Bluetooth devices are detected on the APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-2] undo spectrum-analysis trap device Bluetooth
spectrum-analysis trap device enable
Use spectrum-analysis trap device enable to enable interference device notifications.
Use spectrum-analysis trap device disable to disable interference device notifications.
spectrum-analysis trap device { disable | enable }
In an AP group's radio view, interference device notifications are enabled.
Radio view
AP group radio view
Interference device notifications take effect only when you also enable SNMP notifications for WSA.
# Disable interference device notifications for AP ap1.
[sysname-wlan-ap-ap1-radio-1] spectrum-analysis trap device disable
# Disable interference device notifications for the APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] spectrum-analysis trap device disable
wlan spectrum-analysis feature-db file
Use wlan spectrum-analysis feature-db file to import a feature database file.
Use undo wlan spectrum-analysis feature-db file to restore the default.
wlan spectrum-analysis feature-db file file-name
WSA uses the default feature database.
file file-name: Specifies a feature database file by its name.
A feature database stores features such as frequency hopping interval and pulse interval about specific types of interference devices.
Before configuring this command, you must upload the feature database file to the AC's storage media.
# Import the feature database file named feature.sadb.
[sysname] wlan spectrum-analysis feature-db file feature.sadb
