04-Interface Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5426P02)-6W10404-Interface Command Reference
02-Ethernet interface commands
02-Ethernet interface commands 249.69 KB
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support parameters or commands that are available only in IRF mode.
Common Ethernet interface commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
Ethernet subinterface view
# Set the expected bandwidth of GigabitEthernet 1/0/1 to 1000 kbps.
[Sysname-GigabitEthernet1/0/1] bandwidth 1000
# Set the expected bandwidth of GigabitEthernet 1/0/1.1 to 1000 kbps.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] bandwidth 1000
speed
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
Do not enable the dampening function on an interface with spanning tree protocols enabled.
After an interface in down state is dampened, the interface state displayed through the display interface command, MIB, or Web is always down.
# Enable interface dampening on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dampening
# Enable interface dampening on GigabitEthernet 1/0/1, and set the following parameters:
·     Half life time to 2 seconds.
·     Reuse value to 800.
·     Suppression threshold to 3000.
·     Maximum suppression interval to 5 seconds.
[Sysname-GigabitEthernet1/0/1] dampening 2 800 3000 5
display interface
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] default
# Restore the default settings for GigabitEthernet 1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] default
description
The description of an interface is the interface name plus Interface (for example, GigabitEthernet1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of GigabitEthernet 1/0/1 to lan-interface.
[Sysname-GigabitEthernet1/0/1] description lan-interface
# Set the description of GigabitEthernet 1/0/1.1 to subinterface1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] description subinterface1/0/1.1
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
This command displays traffic statistics within a statistics polling interval specified by using the flow-interval command.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface         Total (pkts)   Broadcast (pkts)   Multicast (pkts)  Err (pkts)
GE1/0/1                      0                  0                  0           0
GE1/0/2                      0                  0                  0           0
GE1/0/3                      0                  0                  0           0
GE1/0/4                      0                  0                  0           0
GE1/0/5                      0                  0                  0           0
GE1/0/6                      0                  0                  0           0
GE1/0/7                  64306              43964              18669           0
GE1/0/8                      0                  0                  0           0
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow when any of the following conditions exist:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
·     flow-interval
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
GE1/0/1                     0             0                --               --
 Overflow: More than 14 digits.
       --: Not supported.
Usage (%)
Bandwidth usage (in percentage) of the interface for the last statistics polling interval.
Total (pps)
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval.
Broadcast (pps)
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval.
Multicast (pps)
Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval. .
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
In standalone mode:
In IRF mode:
display ethernet statistics slot slot-number
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
# (In standalone mode.) Display the Ethernet module statistics.
<Sysname> display ethernet statistics
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
# (In IRF mode.) Display the Ethernet module statistics for the specified slot.
<Sysname> display ethernet statistics slot 1
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
    ErrHdrLen       : 0
Table 3 Output description
Statistics about the Ethernet packets received by the Ethernet module:
·     Totalnum—Total number of received packets.
·     ETHIINum—Number of packets encapsulated by using Ethernet II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISISNum—Number of packets encapsulated by using ISIS. This field is not supported in the current software version.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets.
·     MPLS—Number of MPLS packets. This field is not supported in the current software version.
·     ISIS—Number of IS-IS packets.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS.This field is not supported in the current software version.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.
·     MbufRelayNum—Number of packets transparently sent.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module:
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQoSTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
reset ethernet statistics
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces except VA interfaces. For more information about VA interfaces, see PPP in Network Connectivity Configuration Guide.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display information about Layer 3 interface GigabitEthernet 1/0/1.
<Sysname> display interface gigabitethernet 1/0/1
Line protocol state: DOWN
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Media type is not sure, Port hardware type is No connector, promiscuous mode set
Port priority: 0
Flow-control is not enabled
The Maximum Frame Length is 4000
Last link flapping: Never
Current system time:2018-04-16 15:09:54
Last time when physical state changed to up:-
Last time when physical state changed to down:2018-04-16 09:19:12
 Last 300 second input: 0 packets/sec 0 bytes/sec -%
 Last 300 second output: 0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, 0 bytes
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 CRC, - frame, 0 overruns, 0 aborts
          - ignored, - parity errors
 Output (normal): 0 packets, 0 bytes
 Output: 0 output errors, 0 underruns, - buffer failures
          - aborts, 0 deferred, 0 collisions, 0 late collisions
          - lost carrier, - no carrier
# Display detailed information about Layer 2 interface GigabitEthernet 1/0/1.
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Maximum frame length: 9216
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters:  14:34:09 Tue 11/01/2011
Current system time:2017-12-09 10:59:08
Last time when physical state changed to down:2017-12-09 10:59:07
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command.
·     mac-address moving down—The interface has been shut down by the MAC address move suppression feature.
·     MAD ShutDown—The interface has been shut down by IRF MAD. This state occurs if the interface is on an IRF fabric placed in Recovery state after an IRF split.
·     STP DOWN—The interface has been shut down by the BPDU guard feature.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
·     DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include:
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
Internet address
IP address of the interface. The primary attribute indicates that the address is the primary IP address.
IPv4 packet framing format.
hardware address
MAC address of the interface.
IPv6 packet framing format.
Output queue - Urgent queuing: Size/Length/Discards
Statistics for the urgent queue in the output queue:
·     Number of buffered packets.
·     Maximum number of packets that can be buffered.
·     Number of dropped packets.
Output queue - Protocol queuing: Size/Length/Discards
Statistics for the protocol queue in the output queue:
Output queue - FIFO queuing: Size/Length/Discards
Statistics for the FIFO queue in the output queue:
Port priority
Port priority of the interface.
Loopback is set internal
An internal loopback test is running on the interface. This field depends on your configuration.
Loopback is set external
An external loopback test is running on the interface. This field depends on your configuration.
Loopback is not set
No loopback test is running on the interface. This field depends on your configuration.
100Mbps-speed mode
The interface is operating at 100 Mbps. This field depends on your configuration and the link parameter negotiation result.
1000Mbps-speed mode
The interface is operating at 1000 Mbps. This field depends on your configuration and the link parameter negotiation result.
10Gbps-speed mode
The interface is operating at 10 Gbps. This field depends on your configuration and the link parameter negotiation result.
40Gbps-speed mode
The interface is operating at 40 Gbps. This field depends on your configuration and the link parameter negotiation result.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
half-duplex mode
The interface is operating in half duplex mode. This field depends on your configuration and the link parameter negotiation result.
full-duplex mode
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command.
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result.
Maximum length of Ethernet frames allowed to pass through the interface.
The interface allows jumbo frames to pass through.
Broadcast max-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast max-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
MDI type
MDIX mode of the interface:
·     automdix.
·     mdi.
·     mdix.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
VLAN Passing
VLANs whose packets can be forwarded by the port. The VLANs must have been created.
VLAN permitted
VLANs whose packets are permitted by the port.
Trunk port encapsulation
Encapsulation protocol type for the trunk port.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS format.
Last time when physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has not changed to up.
Last time when physical state of the interface changed to down.
A hyphen (-) indicates that the physical state of the interface has not changed to down.
Last 300 second input:  0 packets/sec 0 bytes/sec 0%
Last 300 second output:  0 packets/sec 0 bytes/sec 0%
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
‌Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
‌Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
# Display brief information about all interfaces.
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP      Description
GE1/0/1              DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                DOWN DOWN     --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
GE1/0/2              DOWN auto    A      A    1
GE1/0/3              UP   1G(a)   F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about GigabitEthernet 1/0/1, including the complete description of the interface.
<Sysname> display interface gigabitethernet 1/0/1 brief description
Speed: (a) - auto
GE1/0/1              UP   1G(a)   F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
GE1/0/1              DOWN Not connected
Vlan2                DOWN Not connected
GE1/0/2              DOWN Not connected
Table 5 Command output
Brief information about Layer 3 interfaces.
Interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Brief information of interfaces in bridge mode:
Brief information about Layer 2 interfaces.
Type: A - access; T - trunk; H – hybrid
Link type options for interfaces.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down.
·     DOWN (Loopback detection down)—The loopback detection module has detected loops.
·     MAD ShutDown—The interface is on an IRF fabric placed by IRF MAD in Recovery state after an IRF split.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Port Security Disabled—The interface has been shut down by the intrusion detection mechanism because the interface received illegal packets.
·     Standby—The interface is a backup interface in standby state.
display packet-drop
Use display packet-drop to display information about packets dropped on an interface.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
summary: Displays the summary of dropped packets on all interfaces.
If you do not specify an interface type, this command displays information about dropped packets on all interfaces on the device.
If you specify an interface type but do not specify an interface number, this command displays information about dropped packets on all interfaces of the specified type.
# Display information about dropped packets on GigabitEthernet 1/0/1.
<Sysname> display packet-drop interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Packets dropped due to full GBP or insufficient bandwidth: 301
Packets dropped due to Fast Filter Processor (FFP): 261
Packets dropped due to STP non-forwarding state: 0
Packets dropped due to rate-limit: 143
Packets dropped due to broadcast-suppression: 301
Packets dropped due to unicast-suppression: 215
Packets dropped due to multicast-suppression: 241
Packets dropped due to Tx packet aging: 246
# Display the summary of dropped packets on all interfaces.
<Sysname> display packet-drop summary
All interfaces:
Table 6 Command output
Packets that are dropped because the buffer is used up or the bandwidth is insufficient.
Packets that are filtered out.
‌Packets that are dropped because STP is in the non-forwarding state.
Packets that are dropped due to the rate limit set on the device.
Packets that are dropped due to broadcast suppression.
Packets that are dropped due to unknown unicast suppression.
Packets that are dropped due to multicast suppression.
Outbound packets that are timed out.
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full | half }
undo duplex
Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
half: Configures the interface to operate in half duplex mode. In this mode, the interface can only receive or transmit packets at a given time.
# Configure GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
flow-control
Use flow-control to enable TxRx-mode generic flow control on an Ethernet interface.
Use undo flow-control to disable TxRx-mode generic flow control on the Ethernet interface.
flow-control
undo flow-control
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware series
Models
Product code
Command compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes:
·     WX2510H
·     WX2510H-F
·     WX2540H
·     WX2540H-F
·     WX2560H
No: WX2508H-PWR-LTE
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3010H-L
·     WX3024H
·     WX3024H-F
·     WX3024H-L
No: WX3010H-X
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes: WX5510E
No: WX5540E
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
TxRx-mode generic flow control is disabled on an Ethernet interface.
With TxRx-mode generic flow control configured, an interface can both send and receive flow control frames:
·     When congested, the interface sends a flow control frame to its peer.
·     Upon receiving a flow control frame from the peer, the interface suspends sending packets.
To implement flow control on a link, enable generic flow control at both ends of the link.
# Enable TxRx-mode generic flow control on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-control receive enable
Use flow-control receive enable to enable Rx-mode generic flow control on an Ethernet port.
Use undo flow-control to disable Rx-mode generic flow control on an Ethernet port.
undo flow-control
Hardware series
Models
Product code
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes:
·     WX2510H
·     WX2510H-F
·     WX2540H
·     WX2540H-F
·     WX2560H
No: WX2508H-PWR-LTE
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H-L
·     WX3024H
·     WX3024H-F
·     WX3024H-L
No:
·     WX3010H
·     WX3010H-X
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes: WX5510E
No: WX5540E
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
Rx-mode generic flow control is disabled on Ethernet interfaces.
With Rx-mode flow control enabled, an interface can receive but cannot send flow control frames.
·     When the interface receives a flow control frame from its peer, it suspends sending packets to the peer.
·     When traffic congestion occurs on the interface, it cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
# Enable Rx-mode generic flow control on GigabitEthernet 1/0/1.
[Sysname-gigabitethernet 1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
interface
Use interface to enter interface view, create a subinterface and enter its view, or enter the view of an existing subinterface.
# Enter the view of GigabitEthernet 1/0/1.
# Create Ethernet subinterface GigabitEthernet 1/0/1.1 and enter its view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within a specific length to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through.
The following compatibility matrixes show the value ranges for the maximum jumbo frame size:
Hardware series
Models
Product code
Value range
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
1518 to 4000
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
WX2508H-PWR-LTE: 1518 to 4000
WX2510H: 1518 to 4000
WX2510H-F: 1518 to 4000
WX2540H: 1518 to 4000
WX2540H-F: 1518 to 4000
WX2560H: 1700 to 4000
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
WX3010H: 1700 to 4000
WX3010H-X: 1700 to 4000
WX3010H-L: 1700 to 4080
WA3024H: 1700 to 4000
WX3024H-L: 1700 to 4080
WA3024H-F: 1700 to 4000
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
1700 to 4000
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
WX5510E: 1700 to 4000
WX5540E: 1700 to 3996
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
1700 to 3996
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
1700 to 3996
Hardware series
Models
Product code
Value range
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
1518 to 4000
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
1700 to 4000
WX5800H series
WX5860H
EWP-WX5860H-GL
1700 to 3996
# Allow jumbo frames to pass through GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] jumboframe enable
loopback
CAUTION
CAUTION:
After you enable loopback testing on an Ethernet interface, the interface does not forward data traffic.
Use loopback to enable loopback testing on an Ethernet interface.
Use undo loopback to disable loopback testing on an Ethernet interface.
undo loopback
Loopback testing is disabled on an Ethernet interface.
external: Enables external loopback testing on the Ethernet interface.
internal: Enables internal loopback testing on the Ethernet interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
The shutdown and loopback commands are mutually exclusive.
# Enable internal loopback testing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] loopback internal
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
Hardware series
Models
Product code
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
The default setting varies by interface card model.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
Interfaces operate differently depending on the hardware structure of interface cards. For a device:
·     Some Ethernet interfaces can operate only as Layer 2 Ethernet interfaces (in bridge mode).
·     Some Ethernet interfaces can operate only as Layer 3 Ethernet interfaces (in route mode).
·     Some Ethernet interfaces can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can use this command to set the link mode to bridge or route for these Ethernet interfaces.
Changing the link mode of an Ethernet interface also restores all commands (except shutdown) on the Ethernet interface to their defaults in the new link mode.
For a device supporting interface grouping, changing the link mode of interfaces in a group restores all interfaces in the group to the default speed.
# Configure GigabitEthernet 1/0/1 to operate in Layer 2 mode.
[Sysname-GigabitEthernet1/0/1] port link-mode bridge
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces except VA interfaces. For more information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for GigabitEthernet 1/0/1.
<Sysname> reset counters interface gigabitethernet 1/0/1
display counters interface
display counters rate interface
display interface
Use reset ethernet statistics to clear the Ethernet module statistics.
In standalone mode:
In IRF mode:
reset ethernet statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics for all IRF member devices. (In IRF mode.)
# (In standalone mode.) Clear the Ethernet module statistics.
<Sysname> reset ethernet statistics
# (In IRF mode.) Clear the Ethernet module statistics for the specified slot.
<Sysname> reset ethernet statistics slot 1
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics for an interface.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specify an interface type.
interface-number: Specify an interface number.
If you do not specify an interface type, this command clears dropped packet statistics for all interfaces on the device.
If you specify an interface type but do not specify an interface number, the command clears dropped packet statistics for all interfaces of the specified type.
# Clear dropped packet statistics for GigabitEthernet 1/0/1.
<Sysname> reset packet-drop interface gigabitethernet 1/0/1
# Clear dropped packet statistics for all interfaces.
display packet-drop
shutdown
Use shutdown to shut down an Ethernet interface or subinterface.
Use undo shutdown to bring up an Ethernet interface or subinterface.
shutdown
An Ethernet interface or subinterface is up.
Some interface configurations might require an interface restart before taking effect.
# Shut down and then bring up GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
# Shut down and then bring up GigabitEthernet 1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] shutdown
[Sysname-GigabitEthernet1/0/1.1] undo shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 100 | 1000 | 10000 | 40000 | auto }
undo speed
An Ethernet interface autonegotiates its speed.
100: Sets the interface speed to 100 Mbps.
The following compatibility matrixes show the support of hardware platforms for this keyword:
Hardware series
Models
Product code
Parameter compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3010H-L
·     WX3024H
·     WX3024H-L
·     WX3024H-F
No: WX3010H-X
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
No
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
Hardware series
Models
Product code
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H-X
·     WX3024H
·     WX3024H-F
No:
·     WX3010H
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
40000: Sets the interface speed to 40000 Mbps.
The following compatibility matrix shows the support of hardware platforms for this keyword:
Hardware series
Models
Product code
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes:
·     WX5560H
·     WX5580H
No: WX5540H
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module.
Support of an interface for the keywords depends on the interface type. For more information, use the speed ? command in interface view.
GE interfaces on the WX1804H, WX1810H, WX1840H, WX2510H, WX3010H, and WX3024H access controllers do not support the downshift feature. When you connect a 100-Mbps cable to GE interfaces, you must set the speed to 100 Mbps for one end and set the speed to 100 Mbps or auto on the other end.
# Configure GigabitEthernet 1/0/1 to autonegotiate the speed.
[Sysname-GigabitEthernet1/0/1] speed auto
Layer 2 Ethernet interface commands
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to disable broadcast suppression.
Hardware series
Model
Product code
Compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-X
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
Compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance.
The configured suppression threshold value in pps or kbps might be converted into a multiple of a step supported by the chip. As a result, the effective suppression threshold might be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the broadcast suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
The actual value is 10048 on port GigabitEthernet1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
·     multicast-suppression
unicast-suppression
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
Hardware series
Model
Product code
Compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-X
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
Compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance.
# Set the multicast storm suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] multicast-suppression kbps 10000
unicast-suppression
unicast-suppression
Use unicast-suppression to enable unknown unicast storm suppression and set the unknown unicast storm suppression threshold.
Use undo unicast-suppression to disable unknown unicast storm suppression.
Hardware series
Model
Product code
Compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-X
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
Compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
Ethernet interfaces do not suppress unknown unicast traffic.
ratio: Sets the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The unknown unicast storm suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the unknown unicast traffic drops below this threshold.
The unicast-suppression command uses the chip to physically suppress unknown unicast traffic. It has less influence on the device performance.
# Set the unknown unicast storm suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] unicast-suppression kbps 10000
Layer 3 Ethernet interface or subinterface commands
The following compatibility matrixes show the support of hardware platforms for Layer 3 Ethernet interfaces or subinterfaces:
Hardware series
Models
Product code
Layer 3 Ethernet interface or subinterface compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-X
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
mac-address
Use mac-address to set the MAC address of an Ethernet interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is configured for an Ethernet interface.
mac-address: Specifies a MAC address in the format of H-H-H.
When you set a MAC address for a Layer 3 Ethernet subinterface, select a MAC address different from that of the main interface.
# Set the MAC address of GigabitEthernet 1/0/1 to 0001-0001-0001.
[Sysname-GigabitEthernet1/0/1] mac-address 1-1-1
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
Hardware series
Models
Product code
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
By default, the MTU of an Ethernet interface or subinterface is 1500 bytes.
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
·     WX2508H-PWR-LTE, WX2510H, WX2510H-F, WX2540H-F, WX2560H:
·     WX2540H:
By default, the MTU of an Ethernet interface or subinterface is 1600 bytes.
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
·     WX3010H, WX3024H, WX3024H-F:
·     WX3010H-X, WX3010H-L, WX3024H-L:
This command is not supported.
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Hardware series
Models
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
WX5800H series
WX5860H
EWP-WX5860H-GL
size: Sets the MTU in bytes. The value range for this argument varies by interface type.
The following compatibility matrixes show the value ranges for the size argument:
Hardware series
Models
Product code
Value range
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
46 to 1560
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
46 to 1560
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
WX3010H: 46 to 1560
WX3010H-X: Not supported
WX3010H-L: Not supported
WX3024H: 46 to 1560
WX3024H-L: Not supported
WX3024H-F: 46 to 1560
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
Not supported
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Not supported
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Not supported
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Not supported
Hardware series
Models
Product code
Value range
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
46 to 1560
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Not supported
WX5800H series
WX5860H
EWP-WX5860H-GL
Not supported
A smaller MTU size results in more fragments. When you set the MTU for an interface, consider QoS queue lengths, for example, consider that the default FIFO queue length is 75. To prevent a too small MTU from causing packet drops in QoS queuing, you can perform one of the following configurations:
·     Tune the MTU with the mtu command.
·     Tune QoS queue lengths with the qos fifo queue-length command in Ethernet interface view.
For more information about tuning the QoS queue length, see QoS Configuration Guide.
# Set the MTU to 1430 bytes for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mtu 1430
# Set the MTU to 1430 bytes for GigabitEthernet 1/0/1.1.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] mtu 1430
