H3C LSWM124XG2Q & LSWM124XG2QL Interface Cards User Manal-6PW108
HomeSupportSwitchesS6800 SeriesInstall & UpgradeExpansion Interface Card ManualsH3C LSWM124XG2Q & LSWM124XG2QL Interface Cards User Manal-6PW108
01-Text
01-Text 510.17 KB
About the LSWM124XG2Q and LSWM124XG2QL interface cards
Important information
The LSWM124XG2Q and LSWM124XG2QL interface cards are applicable to multiple H3C switch models. For the interface card compatibility with switches, contact H3C Support or marketing staff.
Front panel
The LSWM124XG2Q and LSWM124XG2QL interface cards are similar in appearance except for their marks. Each provides 24 SFP+ ports and two QSFP+ ports. The SFP+ ports on the LSWM124XG2Q interface card support MACsec.
Figure 1 LSWM124XG2Q interface card front panel
(1) SFP+ port LED
(2) QSFP+ port LED
(3) QSFP+ port
(4) SFP+ port
Ports
·     As a best practice, use H3C transceiver modules and cables for the interface cards.
·     The transceiver module and cable types supported by the LSWM124XG2Q and LSWM124XG2QL interface cards vary by device model. For more information, see the installation guide or hardware reference for the device, or contact H3C Support or marketing staff.
·     The restrictions and guidelines for using the LSWM124XG2Q and LSWM124XG2QL interface cards vary by device model. For more information, see the installation guide or hardware reference for the device.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide at www.h3c.com.
SFP+ ports
You can install the following transceiver modules and cables in the SFP+ ports on the LSWM124XG2Q and LSWM124XG2QL interface cards:
·     SFP transceiver modules in Table 1 and Table 2.
·     SFP+ transceiver modules in Table 3 and Table 4.
·     SFP+ DAC cables in Table 5.
·     SFP+ AOC cables in Table 6.
Table 1 SFP transceiver modules available for the SFP+ ports (1)
Central wavelength (nm)
Connector
SFP-GE-T
N/A
RJ-45
SFP-GE-SX-MM850-A
850
LC
SFP-GE-LX-SM1310-A
1310
LC
SFP-GE-LH40-SM1310
1310
LC
SFP-GE-LH40-SM1550
1550
LC
SFP-GE-LH80-SM1550
1550
LC
Table 2 SFP transceiver modules available for the SFP+ ports (2)
Cable/fiber diameter (µm)
Modal bandwidth (MHz × km)
Max transmission distance
SFP-GE-T
Twisted pair
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
Multi-mode, 62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LH40-SM1310
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
Single-mode, 9/125
N/A
80 km
(49.71 miles)
Table 3 SFP+ transceiver modules available for the SFP+ ports (1)
Connector
SFP-XG-SX-MM850-A
850
LC
SFP-XG-LX-SM1310
1310
LC
SFP-XG-LH80-SM1550
1550
LC
Table 4 SFP+ transceiver modules available for the SFP+ ports (2)
Fiber diameter (µm)
SFP-XG-SX-MM850-A
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH80-SM1550
Single-mode, 9/125
N/A
80 km (49.71 miles)
Table 5 SFP+ DAC cables available for the SFP+ ports
SFP+ DAC cable
Cable length
Data rate
LSWM1STK
0.65 m (2.13 ft)
10.31 Gbps
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table 6 SFP+ AOC cables available for the SFP+ ports
SFP+ AOC cable
Cable length
Data rate
SFP-XG-D-AOC-7M
7 m (22.97 ft)
10.31 Gbps
SFP-XG-D-AOC-10M
10 m (32.81ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
IMPORTANT
IMPORTANT:
To install an SFP-XG-LH80-SM1550 transceiver module on an LSWM124XG2Q or LSWM124XG2QL interface card, make sure the device ambient temperature is in the range of 0°C to 40°C (32°F to 104°F).
QSFP+ ports
You can install the following transceiver modules and cables in the QSFP+ ports on the LSWM124XG2Q and LSWM124XG2QL interface cards:
·     QSFP+ modules in Table 7 and Table 8.
·     QSFP+ DAC cables in Table 9.
·     QSFP+ to SFP+ DAC cables in Table 10.
·     QSFP+ AOC cables in Table 11.
Table 7 QSFP+ transceiver modules available for the QSFP+ ports (1)
Connector
QSFP-40G-SR4-MM850
850
MPO
QSFP-40G-CSR4-MM850
850
MPO
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Table 8 QSFP+ transceiver modules available for the QSFP+ ports (2)
QSFP-40G-SR4-MM850
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
QSFP-40G-CSR4-MM850
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
Single-mode, 9/125
N/A
10 km (6.21 miles)
Single-mode, 9/125
N/A
2 km (1.24 miles)
Table 9 QSFP+ DAC cables available for the QSFP+ ports
QSFP+ DAC cable
Cable length
Data rate
LSWM1QSTK0
1 m (3.28 ft)
40 Gbps
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
Table 10 QSFP+ to SFP+ DAC cables available for the QSFP+ ports
Cable length
Data rate
LSWM1QSTK3
1 m (3.28 ft)
40 Gbps
LSWM1QSTK4
3 m (9.84 ft)
LSWM1QSTK5
5 m (16.40 ft)
Table 11 QSFP+ AOC cables available for the QSFP+ ports
QSFP+ AOC cable
Cable length
Data rate
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
40 Gbps
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
LEDs
The indications of the LEDs on the LSWM124XG2Q and LSWM124XG2QL interface cards vary by device model. For more information, see the installation guide or hardware reference for the device.
SFP+ port LEDs
Table 12 SFP+ port LED description
LED status
Steady green
A transceiver module is installed in the port. The port is operating at 10 Gbps, and a link is present on the port.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A transceiver module is installed in the port. The port is operating at 1 Gbps, and a link is present on the port.
Flashing yellow
The port is sending or receiving data at 1 Gbps.
Off
No transceiver module is installed in the port, or no link is present on the port.
QSFP+ port LEDs
Table 13 QSFP+ port LED description
LED status
Steady green
A transceiver module is installed in the port. The port is operating at 40 Gbps, and a link is present on the port.
Flashing green
The port is sending or receiving data at 40 Gbps.
Steady yellow
Flashing yellow
Off
Installing and removing the interface card
CAUTION-一纸通
CAUTION:
·     The LSWM124XG2Q and LSWM124XG2QL interface cards are hot swappable. However, do not install or remove them during the startup of the switch.
·     Before you install or remove an interface card, wear an ESD wrist strap and make sure the strap makes good skin contact and is reliably grounded.
·     To avoid device damage, do not use excessive force when you install or remove an interface card.
The installation and removal procedures are the same for the LSWM124XG2Q and LSWM124XG2QL interface cards. This section uses the LSWM124XG2Q interface card as an example.
Installing the interface card
Before you install the interface card, remove the filler panel (if any) from the target slot. Keep the removed filler panel secure for future use.
To install the interface card:
1.     Unpack the interface card.
Figure 2 LSWM124XG2Q interface card
(1) Ejector lever
(2) Latch
2.     Press the latch on the interface card to release the ejector lever.
3.     As shown by callout 1 in Figure 3, insert the interface card slowly into the slot along the guide rails.
4.     Rotate inward the ejector lever as shown by callout 2 in Figure 3 until the latch locks the ejector lever in place.
Figure 3 Installing the interface card
Removing the interface card
CAUTION-一纸通
CAUTION:
·     Before you remove the interface card, remove the cable from it to avoid cable damage.
·     After removing an interface card, if no new interface card is to be installed, install the filler panel as soon as possible to prevent dust and ensure good ventilation in the device.
To remove the interface card:
1.     Prepare an anti-static bag.
2.     Press the latch to release the ejector lever
3.     Rotate outward the ejector lever as shown by callout 1 in Figure 4.
4.     Pull out the interface card slowly out of the interface card slot, as shown by callout 2 in Figure 4.
5.     Place the removed interface card in the anti-static bag.
Figure 4 Removing the interface card
Installing and removing SFP, SFP+, and QSFP+ transceiver modules and cables
For information about installing and removing SFP/SFP+ transceiver modules and SFP+ cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
For information about installing and removing QSFP+ transceiver modules and cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
Verifying the installation
After the installation is complete, identify whether the interface card is operating correctly.
If the interface card fails to operate correctly, perform the following steps:
1.     Reinstall it following the installation procedures described in this document.
2.     If the issue persists, contact H3C Support.
