HomeSupportConfigure & DeployConfiguration GuidesH3C SR6600 SR6600-X Routers Configuration Guides(V7)-R7809-6W30001-Fundamentals Configuration Guide
03-Login management configuration
03-Login management configuration 285.21 KB
Login overview·· 1
Using the console port for the first device access· 2
Configuring CLI login· 3
About CLI login· 3
User lines· 3
Login authentication modes· 3
User roles· 4
FIPS compliance· 4
Restrictions and guidelines: CLI login configuration· 4
Configuring console or AUX login· 5
About console, AUX, and USB login· 5
Restrictions and guidelines· 5
Console and AUX login configuration tasks at a glance· 5
Configuring console or AUX login authentication· 5
Configuring common console or AUX login settings· 7
Configuring Telnet login· 9
About Telnet login· 9
Restrictions and guidelines· 9
Configuring the device as a Telnet server 9
Using the device to log in to a Telnet server 12
Configuring SSH login· 13
About SSH login· 13
Configuring the device as an SSH server 13
Using the device to log in to an SSH server 15
Display and maintenance commands for CLI login· 15
Accessing the device through SNMP·· 17
Controlling user access to the device· 18
About login user access control 18
FIPS compliance· 18
Controlling Telnet and SSH logins· 18
Controlling Telnet logins· 18
Controlling SSH logins· 18
Example: Controlling Telnet login· 19
Controlling SNMP access· 19
About SNMP access control 19
Example: Controlling SNMP access· 20
Configuring command authorization· 20
About command authorization· 20
Restrictions and guidelines· 21
Procedure· 21
Example: Configuring command authorization· 22
Configuring command accounting· 23
About command accounting· 23
Restrictions and guidelines· 24
Procedure· 24
Example: Configuring command accounting· 25
Login overview
The device supports the following types of login methods:
·     CLI login—At the CLI, you can enter text commands to configure and manage the device.
To log in to the CLI, you can use one of the following methods:
¡     Connect to the console port.
¡     Connect to the AUX port.
¡     Use Telnet.
¡     Use SSH.
·     SNMP access—You can run SNMP on an NMS to access the device MIB, and perform Get and Set operations to configure and manage the device.
The first time you access the device, you can only log in to the CLI of the default MDC through the console port or AUX port unless the device is automatically configured at startup. After login, you can create non-default MDCs, change console login parameters, or configure other access methods.
Non-default MDCs do not have anyconsole or AUX ports. To log in to a non-default MDC for the first time, you must perform the following tasks:
·     Log in to the default MDC.
·     Switch to the non-default MDC by using the switchto mdc command.
After you log in to a non-default MDC, you can configure other access methods. Then, administrators of the default MDC and those of the non-default MDC can use the login methods to access the non-default MDC. For more information about MDC, see Virtual Technologies Configuration Guide.
In login management related descriptions, it is assumed that the device does not enter the automatic configuration process at startup.
Telnet is not supported in FIPS mode
Console login is the fundamental login method.
To log in through the console port, prepare a console terminal, for example, a PC. Make sure the console terminal has a terminal emulation program, such as HyperTerminal or PuTTY. For information about how to use terminal emulation programs, see the programs' user guides.
1.     Turn off the PC.
The serial ports on PCs do not support hot swapping. Before connecting a cable to or disconnecting a cable from a serial port on a PC, you must turn off the PC.
2.     Find the console cable shipped with the device and connect the DB-9 female connector of the console cable to the serial port of the PC.
3.     Identify the console port of the device carefully and connect the RJ-45 connector of the console cable to the console port.
IMPORTANT
IMPORTANT:
To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
Figure 1 Connecting a terminal to the console port
4.     Turn on the PC.
5.     On the PC, launch the terminal emulation program, and create a connection that uses the serial port connected to the device. Set the port properties so the port properties match the following console port default settings:
¡     Bits per second—9600 bps.
¡     Flow control—None.
¡     Parity—None.
¡     Stop bits—1.
¡     Data bits—8.
6.     Power on the device and press Enter as prompted.
The user view prompt appears. You can enter commands to configure or manage the device. To get help, enter a question mark (?).
About CLI login
The device uses user lines (also called user interfaces) to manage CLI sessions and monitor user behavior. For a user line, you can configure access control settings, including the login authentication method and user roles.
User lines
User line types
The device supports the types of user lines listed in Table 1. Different user lines require different login methods.
Table 1 CLI login method and user line matrix
User line
Login method
Console line
Console port.
AUX line
Virtual type terminal (VTY) line
Telnet or SSH.
User line numbering
A user line has an absolute number and a relative number.
An absolute number uniquely identifies a user line among all user lines. The user lines are numbered starting from 0 and incrementing by 1, in the sequence ofconsole, AUX, and VTY lines. You can use the display line command without any parameters to view supported user lines and their absolute numbers.
A relative number uniquely identifies a user line among all user lines of the same type. The number format is user line type + number. All types of user lines are numbered starting from 0 and incrementing by 1. For example, the first VTY line is VTY 0.
User line assignment
The device assigns user lines to CLI login users depending on their login methods, as shown in Table 1. When a user logs in, the device checks the idle user lines for the login method, and assigns the lowest numbered user line to the user. For example, if VTY 0 and VTY 3 are idle when a user Telnets to the device, the device assigns VTY 0 to the user.
Each user line can be assigned only to one user at a time. If no user line is available, a CLI login attempt will be rejected.
You can configure login authentication to prevent illegal access to the device CLI.
In non-FIPS mode, the device supports the following login authentication modes:
·     None—Disables authentication. This mode allows access without authentication and is insecure.
·     Password—Requires password authentication. A user must provide the correct password at login.
·     Scheme—Uses the AAA module to provide local or remote login authentication. A user must provide the correct username and password at login.
In FIPS mode, the device supports only the scheme authentication mode.
Different login authentication modes require different user line configurations, as shown in Table 2.
Table 2 Configuration required for different login authentication modes
Authentication mode
Configuration tasks
None
Set the authentication mode to none.
Password
1.     Set the authentication mode to password.
2.     Set a password.
Scheme
1.     Set the authentication mode to scheme.
2.     Configure login authentication methods in ISP domain view. For more information, see Security Configuration Guide.
User roles
A user is assigned user roles at login. The user roles control the commands available for the user. For more information about user roles, see "Configuring RBAC."
The device assigns user roles based on the login authentication mode and user type.
·     In none or password authentication mode, the device assigns the user roles specified for the user line.
·     In scheme authentication mode, the device uses the following rules to assign user roles:
¡     For an SSH login user who uses publickey or password-publickey authentication, the device assigns the user roles specified for the local device management user with the same name.
¡     For other users, the device assigns user roles according to the user role configuration of the AAA module. If the AAA server does not assign any user roles and the default user role feature is disabled, a remote AAA authentication user cannot log in.
FIPS compliance
Telnet login is not supported in FIPS mode.
For commands that are available in both user line view and user line class view, the following rules apply:
·     A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
·     A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
·     A setting in user line class view takes effect only on users who log in after the setting is made. It does not affect users who are already online when the setting is made.
You can connect a terminal to the console or AUX port of the device to log in and manage the device, as shown in  and Figure 2. For information about the login procedure, see "Using the console port for the first device access."
Figure 2 Logging in through the console or AUX port
By default, console login is enabled and does not require authentication. The default user role is network-admin for a console user. To improve device security, configure password or scheme authentication for console login immediately after you log in to the device for the first time.
By default, AUX login is enabled and the authentication mode is password. The default user role is network-operator for an AUX user. Before login through the AUX port for the first time, a user must log in through the console port and configure AUX login settings. To improve device security, configure password or scheme authentication for AUX login immediately after you log in to the device for the first time.
A console or AUX login configuration change takes effect only on users who log in after the change is made. It does not affect users who are already online when the change is made.
In FIPS mode, the device supports only scheme authentication. You cannot disable authentication or configure password authentication.
To configure console or AUX login, perform the following tasks:
1.     Configuring console or AUX login authentication
¡     Disabling authentication for console or AUX login
¡     Configuring password authentication for console or AUX login
¡     Configuring scheme authentication for console or AUX login
2.     (Optional.) Configuring common console or AUX login settings
2.     Enter console/AUX line view or class view.
¡     Enter console or AUX line view.
line { aux | console } first-number [ last-number ]
¡     Enter console or AUX line class view.
line class { aux | console }
3.     Disable authentication.
authentication-mode none
By default, authentication is disabled for console login and password authentication is enabled for AUX login.
4.     Assign a user role.
user-role role-name
By default, a console or AUX user of the default MDC is assigned the network-admin user role. Non-default MDCs do not support console or AUX login.
¡     Enter console or AUX class view.
3.     Enable password authentication.
authentication-mode password
By default, authentication is disabled for console login, and password authentication is enabled for AUX login.
4.     Set a password.
set authentication password { hash | simple } string
By default, no password is set.
5.     Assign a user role.
user-role role-name
By default, a console user of the default MDC is assigned the network-admin user role, and an AUX user of the default MDC is assigned the network-operator user role. Non-default MDCs do not support console or AUX login.
3.     Enable scheme authentication.
In non-FIPS mode:
authentication-mode scheme
In FIPS mode:
By default, scheme authentication is enabled.
4.     Configure user authentication parameters in ISP domain view.
To use local authentication, configure a local user and set the relevant attributes. To use remote authentication, configure a RADIUS, LDAP, or HWTACACS scheme. For more information, see AAA in Security Configuration Guide.
Some common console or AUX login settings take effect immediately and can interrupt the current session. Use a login method different from console or AUX login to log in to the device before you change console or AUX login settings.
After you change console or AUX login settings, adjust the settings on the configuration terminal accordingly to ensure a successful login.
3.     Configure transmission parameters.
¡     Set the transmission rate.
speed speed-value
By default, the transmission rate is 9600 bps.
This command is not available in user line class view.
¡     Specify the parity mode.
By default, a user line does not use parity.
¡     Configure flow control.
By default, the device does not perform flow control.
¡     Specify the number of data bits for a character.
databits { 7 | 8 }
The default is 8.
Parameter
7
Uses standard ASCII characters.
8
Uses extended ASCII characters.
¡     Specify the number of stop bits for a character.
stopbits { 1 | 1.5 | 2 }
The default is 1.
Stop bits indicate the end of a character. The more the stop bits, the slower the transmission.
4.     Configure terminal attributes.
¡     Enable the terminal service.
shell
Be default, the terminal service is enabled on all user lines.
The undo shell command is not available in AUX line view.
The undo shell command is not available in console line view.
¡     Specify the terminal display type.
By default, the terminal display type is ANSI.
The device supports ANSI and VT100 terminal display types. As a best practice, specify VT100 type on both the device and the configuration terminal. You can also specify the ANSI type for both sides, but a display problem might occur if a command line has more than 80 characters.
¡     Set the maximum number of lines of command output to send to the terminal at a time.
screen-length screen-length
By default, the device sends a maximum of 24 lines to the terminal at a time.
To disable pausing between screens of output, set the value to 0.
¡     Set the size for the command history buffer.
history-command max-size value
By default, the buffer size is 10. The buffer for a user line can save a maximum of 10 history commands.
¡     Set the CLI connection idle-timeout timer.
By default, the CLI connection idle-timeout timer is 10 minutes.
If no interaction occurs between the device and the user within the idle-timeout interval, the system automatically terminates the user connection on the user line.
If you set the timeout timer to 0, the connection will not be aged out.
5.     Specify the command to be automatically executed for login users on the lines.
auto-execute command command
By default, no command is specified for auto execution.
The device will automatically execute the specified command when a user logs in through the user line, and close the user connection after the command is executed.
This command is not available in AUX line view or AUX line class view.
This command is not available in console line view or console line class view.
6.     Configure shortcut keys.
¡     Specify the terminal session activation key.
activation-key character
By default, pressing Enter starts the terminal session.
¡     Specify the escape key.
escape-key { key-string | default }
By default, pressing Ctrl+C terminates a command.
¡     Set the user line locking key.
lock-key key-string
By default, no user line locking key is set.
About Telnet login
The device can act as a Telnet server to allow Telnet login, or as a Telnet client to Telnet to other devices.
Telnet login is not supported in FIPS mode. For more information about FIPS mode, see Security Configuration Guide.
A Telnet login configuration change takes effect only on users who log in after the change is made. It does not affect users who are already online when the change is made.
Telnet server configuration tasks at a glance
To configure the device as a Telnet server, perform the following tasks:
1.     Enabling the Telnet server
2.     Configuring Telnet login authentication
¡     Disabling authentication for Telnet login
¡     Configuring password authentication for Telnet login
¡     Configuring scheme authentication for Telnet login
3.     (Optional.) Configuring common Telnet server settings
4.     (Optional.) Configuring common VTY line settings
2.     Enable the Telnet server.
telnet server enable
By default, the Telnet server is disabled.
2.     Enter VTY line view or class view.
¡     Enter VTY line view.
line vty first-number [ last-number ]
¡     Enter VTY line class view.
line class vty
By default, password authentication is enabled for Telnet login.
In VTY line view, this command is associated with the protocol inbound command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
4.     (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user of the default MDC is assigned the network-operator user role. A VTY line user of a non-default MDC is assigned the mdc-operator user role.
line class vty
4.     Set a password.
set authentication password { hash | simple } password
5.     (Optional.) Assign a user role.
user-role role-name
By default, a VTY line user of the default MDC is assigned the user role network-operator. A VTY line user of a non-default MDC is assigned the user role mdc-operator.
line class vty
2.     Set the DSCP value for outgoing Telnet packets.
IPv4:
telnet server dscp dscp-value
IPv6:
By default, the DSCP value is 48.
3.     Specify the Telnet service port number.
IPv4:
IPv6:
By default, the Telnet service port number is 23.
4.     Set the maximum number of concurrent Telnet users.
aaa session-limit telnet max-sessions
By default, the maximum number of concurrent Telnet users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online Telnet users, no additional users can Telnet in until the number drops below the new limit.
For more information about this command, see Security Command Reference.
line class vty
3.     Configure VTY terminal attributes.
shell
By default, the terminal service is enabled on all user lines.
4.     Specify the supported protocols.
By default, Telnet and SSH are supported.
A protocol change takes effect only on users who log in after the setting is made. It does not affect users who are already online when the setting is made.
In VTY line view, this command is associated with the authentication-mode command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
5.     Specify the command to be automatically executed for login users on the user lines.
IMPORTANT
IMPORTANT:
Before you configure this command and save the configuration, make sure you can access the CLI to modify the configuration through other VTY lines or AUX lines.
For a VTY line, you can specify a command that is to be automatically executed when a user logs in. After executing the specified command, the system automatically disconnects the Telnet session.
¡     Specify the shortcut key for terminating a task.
escape-key { character | default }
The default setting is Ctrl+C.
lock-key key-string
You can use the device as a Telnet client to log in to a Telnet server.
Figure 3 Telnetting from the device to a Telnet server
Assign an IP address to the device and obtain the IP address of the Telnet server. If the device resides on a different subnet than the Telnet server, make sure the device and the Telnet server can reach each other.
2.     (Optional.) Specify the source IPv4 address or source interface for outgoing Telnet packets.
By default, no source IPv4 address or source interface is specified. The device uses the primary IPv4 address of the output interface as the source address for outgoing Telnet packets.
3.     Return to user view.
4.     Use the device to log in to a Telnet server.
IPv4:
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ]  [ source { interface interface-type interface-number | ip ip-address } ] [ dscp dscp-value ] [ escape character ]
IPv6:
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ]  [ source { interface interface-type interface-number | ipv6 ipv6-address } ] [ dscp dscp-value ] [ escape character ]
About SSH login
SSH offers a secure remote login method. By providing encryption and strong authentication, it protects devices against attacks such as IP spoofing and plaintext password interception. For more information, see Security Configuration Guide.
The device can act as an SSH server to allow Telnet login, or as an SSH client to log in to an SSH server.
This section provides the SSH server configuration procedure used when the SSH client authentication method is password. For more information about SSH and publickey authentication configuration, see Security Configuration Guide.
2.     Create local key pairs.
In non-FIPS mode:
public-key local create { dsa | ecdsa secp256r1 | rsa }
In FIPS mode:
public-key local create { ecdsa secp256r1 | rsa }
3.     Enable the SSH server.
ssh server enable
By default, the SSH server is disabled.
4.     (Optional.) Create an SSH user and specify the authentication mode.
ssh user username service-type stelnet authentication-type password
5.     Enter VTY line view or class view.
line class vty
6.     Enable scheme authentication.
In non-FIPS mode:
By default, password authentication is enabled for VTY lines.
In FIPS mode:
By default, scheme authentication is enabled for VTY lines.
7.     (Optional.) Specify the protocols for the user lines to support.
In non-FIPS mode:
In FIPS mode:
protocol inbound ssh
By default, SSH is supported.
8.     (Optional.) Set the maximum number of concurrent SSH users.
By default, the maximum number of concurrent SSH users is 32.
Changing this setting does not affect users who are currently online. If the new limit is less than the number of online SSH users, no additional SSH users can log in until the number drops below the new limit.
9.     (Optional.) Configure common settings for VTY lines:
a.     Return to system view.
b.     Configure common settings for VTY lines.
See "Configuring common VTY line settings."
You can use the device as an SSH client to log in to an SSH server.
Figure 4 Logging in to an SSH server from the device
Assign an IP address to the device and obtain the IP address of the SSH server. If the device resides on a different subnet than the SSH server, make sure the device and the SSH server can reach each other.
To use the device to log in to an SSH server, execute one of the following commands in user view:
IPv4:
ssh2 server
IPv6:
ssh2 ipv6 server
To work with the SSH server, you might need to specify a set of parameters. For more information, see Security Configuration Guide.
Remarks
Display user line information.
display line [ num1 | { aux | console | vty } num2 ] [ summary ]
N/A
Display the packet source setting for the Telnet client.
display telnet client
N/A
Display online CLI users.
display users [ all ]
N/A
Release a user line.
free line { num1 | { aux | console | vty } num2 }
Multiple users can log in to the device to simultaneously configure the device. When necessary, you can execute this command to release some connections.
You cannot use this command to release the connection you are using.
This command is available in user view.
Lock the current user line and set the password for unlocking the line.
lock
By default, the system does not lock any user lines.
This command is not supported in FIPS mode.
Lock the current user line and enable unlocking authentication.
lock reauthentication
By default, the system does not lock any user lines or initiate reauthentication.
To unlock the locked user line, you must press Enter and provide the login password to pass reauthentication.
This command is available in any view.
Send messages to user lines.
send { all | num1 | { aux | console | vty } num2 }
You can run SNMP on an NMS to access the device MIB and perform Get and Set operations to configure and manage the device.
Figure 5 SNMP access diagram
For more information about SNMP, see Network Management and Monitoring Configuration Guide.
Use ACLs to prevent unauthorized access, and configure command authorization and accounting to monitor and control user behavior.
To control user access, specify an ACL that has rules so only users permitted by the ACL can access the device.
·     If no ACL is applied, all users can access the device.
·     If the ACL for Telnet, SSH, or SNMP access control does not exist or does not have rules, no Telnet, SSH, or SNMP users can access the device.
For more information about ACLs, see ACL and QoS Configuration Guide.
FIPS compliance
Telnet isnot supported in FIPS mode.
2.     Apply an ACL to control Telnet logins.
IPv4:
telnet server acl [ mac ] acl-number
IPv6:
telnet server ipv6 acl { ipv6 | mac } acl-number
By default, no ACL is used to control Telnet logins.
3.     (Optional.) Enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
telnet server acl-deny-log enable
By default, logging is disabled for Telnet login attempts that are denied by the Telnet login control ACL.
2.     Apply an ACL to control SSH logins.
IPv4:
IPv6:
By default, no ACL is used to control SSH logins.
3.     (Optional.) Enable logging for SSH login attempts that are denied by the SSH login control ACL.
By default, logging is disabled for SSH login attempts that are denied by the SSH login control ACL.
For more information about ssh commands, see SSH in Security Command Reference.
As shown in Figure 6, the device is a Telnet server.
Configure the device to permit only Telnet packets sourced from Host A and Host B.
Figure 6 Network diagram
# Configure an ACL to permit packets sourced from Host A and Host B.
[Sysname] acl basic 2000 match-order config
[Sysname-acl-ipv4-basic-2000] rule 1 permit source 10.110.100.52 0
[Sysname-acl-ipv4-basic-2000] rule 2 permit source 10.110.100.46 0
# Apply the ACL to filter Telnet logins.
[Sysname] telnet server acl 2000
For information about SNMP access control, see SNMP in Network Management and Monitoring Configuration Guide.
As shown in Figure 7, the device is running SNMP.
Configure the device to allow Host A and Host B to access the device through SNMP.
Figure 7 Network diagram
Network diagram
# Create an ACL to permit packets sourced from Host A and Host B.
# Associate the ACL with the SNMP community and the SNMP group.
[Sysname] snmp-agent community read aaa acl 2000
[Sysname] snmp-agent group v2c groupa acl 2000
[Sysname] snmp-agent usm-user v2c usera groupa acl 2000
# Access the device from the NMS at 10.110.100.52 or 10.110.100.46. You can access the device. (Details not shown.)
# Access the device from any other NMS. You cannot access the device. (Details not shown.)
By default, commands available for a user depend only on the user's user roles. When the authentication mode is scheme, you can configure the command authorization feature to further control access to commands.
After you enable command authorization, a user can use only commands that are permitted by both the AAA scheme and user roles.
The command authorization method can be different from the user login authorization method.
For the command authorization feature to take effect, you must configure a command authorization method in ISP domain view. For more information, see AAA in Security Configuration Guide.
2.     Enter user line view or user line class view.
¡     Enter user line view.
line { first-number1 [ last-number1 ] | { aux | console | vty } first-number2 [ last-number2 ] }
¡     Enter user line class view.
line class { aux | console | vty }
A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class. A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
In non-FIPS mode:
By default, authentication is disabled for console login, and password authentication is enabled for AUX login and VTY login.
In FIPS mode:
4.     Enable command authorization.
By default, command authorization is disabled, and the commands available for a user only depend on the user role.
If the command authorization command is configured in user line class view, command authorization is enabled on all user lines in the class. You cannot configure the undo command authorization command in the view of a user line in the class.
As shown in Figure 8, Host A needs to log in to the device to manage the device.
Configure the device to perform the following operations:
·     Allow Host A to Telnet in after authentication.
·     Use the HWTACACS server to control the commands that the user can execute.
·     If the HWTACACS server is not available, use local authorization.
Network diagram
Figure 8 Network diagram
# Assign IP addresses to relevant interfaces. Make sure the device and the HWTACACS server can reach each other. Make sure the device and Host A can reach each other. (Details not shown.)
# Enable the Telnet server.
[Device] telnet server enable
# Enable scheme authentication for user lines VTY 0 through VTY 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
# Enable command authorization for the user lines.
[Device-line-vty0-63] command authorization
[Device-line-vty0-63] quit
# Create HWTACACS scheme tac.
[Device] hwtacacs scheme tac
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for authentication and authorization.
[Device-hwtacacs-tac] primary authentication 192.168.2.20 49
[Device-hwtacacs-tac] primary authorization 192.168.2.20 49
# Set the shared keys to expert.
[Device-hwtacacs-tac] key authentication simple expert
[Device-hwtacacs-tac] key authorization simple expert
# Remove domain names from usernames sent to the HWTACACS server.
[Device-hwtacacs-tac] user-name-format without-domain
[Device-hwtacacs-tac] quit
# Configure the system-defined domain (system).
[Device] domain system
# Use HWTACACS scheme tac for login user authentication and command authorization. Use local authentication and local authorization as the backup method.
[Device-isp-system] authentication login hwtacacs-scheme tac local
[Device-isp-system] authorization command hwtacacs-scheme tac local
[Device-isp-system] quit
# Create local user monitor. Set the simple password to 123, the service type to Telnet, and the default user role to level-1.
[Device] local-user monitor
[Device-luser-manage-monitor] password simple 123
[Device-luser-manage-monitor] service-type telnet
[Device-luser-manage-monitor] authorization-attribute user-role level-1
# Telnet to the device (10.110.100.77) from Host A. After login, execute the ip http enable command. Because you are not authorized to execute the command, the system displays Permission denied.
C:\> telnet 10.110.100.77
Trying 10.110.100.77 ...
Press CTRL+K to abort
Connected to 10.110.100.77 ...
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
login: monitor
Password:
[Device] ip http enable
Permission denied.
[Device]
# Execute the interface command. Because you are authorized to execute the command, you enter the interface view.
[Device] interface gigabitethernet 2/0/1
[Device-GigabitEthernet2/0/1]
Command accounting uses the HWTACACS server to record all executed commands to monitor user behavior on the device.
If command accounting is enabled but command authorization is not, every executed command is recorded. If both command accounting and command authorization are enabled, only authorized commands that are executed are recorded.
The command accounting method can be the same as or different from the command authorization method and user login authorization method.
For the command accounting feature to take effect, you must configure a command accounting method in ISP domain view. For more information, see Security Configuration Guide.
In non-FIPS mode:
In FIPS mode:
4.     Enable command accounting.
command accounting
By default, command accounting is disabled. The accounting server does not record the commands executed by users.
If the command accounting command is configured in user line class view, command accounting is enabled on all user lines in the class. You cannot configure the undo command accounting command in the view of a user line in the class.
As shown in Figure 9, users need to log in to the device to manage the device.
Configure the device to send commands executed by users to the HWTACACS server to monitor and control user operations on the device.
Figure 9 Network diagram
# Enable command accounting for user line console 0.
[Device] line console 0
[Device-line-console0] command accounting
[Device-line-console0] quit
# Enable command accounting for user lines VTY 0 through VTY 63.
[Device-line-vty0-63] command accounting
# Configure the scheme to use the HWTACACS server at 192.168.2.20:49 for accounting.
[Device-hwtacacs-tac] primary accounting 192.168.2.20 49
# Set the shared key to expert.
[Device-hwtacacs-tac] key accounting simple expert
# Configure the system-defined domain (system) to use the HWTACACS scheme for command accounting.
[Device-isp-system] accounting command hwtacacs-scheme tac
# Use Host A, Host B, and Host C as a Telnet or SSH client to log in to the device respectively, and perform VLAN and interface configuration. The accounting server processes accounting packets from the hosts as defined by the accounting settings. (Details not shown.)
